MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*This unit test is for the uniform refinement capability based on AHF datastructures*/ 00002 #include <iostream> 00003 #include <string> 00004 #include <sstream> 00005 #if defined( __MINGW32__ ) 00006 #include <sys/time.h> 00007 #else 00008 #include <ctime> 00009 #endif 00010 00011 #include <vector> 00012 #include <algorithm> 00013 #include "moab/Core.hpp" 00014 #include "moab/Range.hpp" 00015 #include "moab/MeshTopoUtil.hpp" 00016 #include "moab/ReadUtilIface.hpp" 00017 #include "moab/NestedRefine.hpp" 00018 #include "TestUtil.hpp" 00019 00020 #ifdef MOAB_HAVE_MPI 00021 #include "moab/ParallelComm.hpp" 00022 #include "MBParallelConventions.h" 00023 #include "ReadParallel.hpp" 00024 #include "moab/FileOptions.hpp" 00025 #include "MBTagConventions.hpp" 00026 #include "moab_mpi.h" 00027 #endif 00028 00029 using namespace moab; 00030 00031 #ifdef MOAB_HAVE_MPI 00032 std::string read_options; 00033 #endif 00034 00035 int number_tests_successful = 0; 00036 int number_tests_failed = 0; 00037 00038 void handle_error_code( ErrorCode rv, int& number_failed, int& number_successful ) 00039 { 00040 if( rv == MB_SUCCESS ) 00041 { 00042 #ifdef MOAB_HAVE_MPI 00043 int rank = 0; 00044 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00045 if( rank == 0 ) std::cout << "Success"; 00046 #else 00047 std::cout << "Success"; 00048 #endif 00049 number_successful++; 00050 } 00051 else 00052 { 00053 std::cout << "Failure"; 00054 number_failed++; 00055 } 00056 } 00057 00058 ErrorCode test_adjacencies( Interface* mbImpl, NestedRefine* nr, const Range& all_ents ) 00059 { 00060 MeshTopoUtil mtu( mbImpl ); 00061 ErrorCode error; 00062 Range verts, edges, faces, cells; 00063 verts = all_ents.subset_by_dimension( 0 ); 00064 edges = all_ents.subset_by_dimension( 1 ); 00065 faces = all_ents.subset_by_dimension( 2 ); 00066 cells = all_ents.subset_by_dimension( 3 ); 00067 00068 std::vector< EntityHandle > adjents; 00069 Range mbents, ahfents; 00070 00071 // Update the moab native data structures 00072 ReadUtilIface* read_face; 00073 error = mbImpl->query_interface( read_face );CHECK_ERR( error ); 00074 std::vector< EntityHandle > ents, conn; 00075 00076 if( !edges.empty() ) 00077 { 00078 conn.clear(); 00079 ents.clear(); 00080 00081 for( Range::iterator it = edges.begin(); it != edges.end(); it++ ) 00082 ents.push_back( *it ); 00083 // std::copy(edges.begin(), edges.end(), ents.begin()); 00084 error = mbImpl->get_connectivity( &ents[0], (int)ents.size(), conn );CHECK_ERR( error ); 00085 error = read_face->update_adjacencies( *ents.begin(), (int)ents.size(), 2, &conn[0] );CHECK_ERR( error ); 00086 } 00087 00088 if( !faces.empty() ) 00089 { 00090 conn.clear(); 00091 ents.clear(); 00092 00093 for( Range::iterator it = faces.begin(); it != faces.end(); it++ ) 00094 ents.push_back( *it ); 00095 00096 // std::copy(faces.begin(), faces.end(), ents.begin()); 00097 error = mbImpl->get_connectivity( &ents[0], 1, conn );CHECK_ERR( error ); 00098 int nvF = conn.size(); 00099 conn.clear(); 00100 error = mbImpl->get_connectivity( &ents[0], (int)ents.size(), conn );CHECK_ERR( error ); 00101 error = read_face->update_adjacencies( *ents.begin(), (int)ents.size(), nvF, &conn[0] );CHECK_ERR( error ); 00102 } 00103 00104 if( !cells.empty() ) 00105 { 00106 conn.clear(); 00107 ents.clear(); 00108 00109 for( Range::iterator it = cells.begin(); it != cells.end(); it++ ) 00110 ents.push_back( *it ); 00111 // std::copy(cells.begin(), cells.end(), ents.begin()); 00112 error = mbImpl->get_connectivity( &ents[0], 1, conn );CHECK_ERR( error ); 00113 int nvF = conn.size(); 00114 conn.clear(); 00115 error = mbImpl->get_connectivity( &ents[0], (int)ents.size(), conn );CHECK_ERR( error ); 00116 error = read_face->update_adjacencies( *ents.begin(), (int)ents.size(), nvF, &conn[0] );CHECK_ERR( error ); 00117 } 00118 00119 if( !edges.empty() ) 00120 { 00121 // 1D Queries // 00122 // IQ1: For every vertex, obtain incident edges 00123 for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) 00124 { 00125 adjents.clear(); 00126 mbents.clear(); 00127 ahfents.clear(); 00128 error = nr->get_adjacencies( *i, 1, adjents );CHECK_ERR( error ); 00129 error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error ); 00130 std::sort( adjents.begin(), adjents.end() ); 00131 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00132 00133 if( ahfents.size() != mbents.size() ) 00134 { 00135 std::cout << "ahf results = " << std::endl; 00136 ahfents.print(); 00137 std::cout << "native results = " << std::endl; 00138 mbents.print(); 00139 } 00140 00141 CHECK_EQUAL( adjents.size(), mbents.size() ); 00142 mbents = subtract( mbents, ahfents ); 00143 if( ahfents.size() != mbents.size() ) 00144 { 00145 // std::cout<<"ahf results = "<<std::endl; 00146 // ahfents.print(); 00147 // std::cout<<"native results = "<<std::endl; 00148 // mbents.print(); 00149 } 00150 // CHECK_EQUAL(adjents.size(),mbents.size()); 00151 CHECK( !mbents.size() ); 00152 } 00153 00154 // NQ1: For every edge, obtain neighbor edges 00155 for( Range::iterator i = edges.begin(); i != edges.end(); ++i ) 00156 { 00157 adjents.clear(); 00158 mbents.clear(); 00159 ahfents.clear(); 00160 error = nr->get_adjacencies( *i, 1, adjents );CHECK_ERR( error ); 00161 error = mtu.get_bridge_adjacencies( *i, 0, 1, mbents );CHECK_ERR( error ); 00162 CHECK_EQUAL( adjents.size(), mbents.size() ); 00163 std::sort( adjents.begin(), adjents.end() ); 00164 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00165 mbents = subtract( mbents, ahfents ); 00166 CHECK( !mbents.size() ); 00167 } 00168 } 00169 00170 if( !faces.empty() ) 00171 { 00172 // IQ21: For every vertex, obtain incident faces 00173 for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) 00174 { 00175 adjents.clear(); 00176 mbents.clear(); 00177 ahfents.clear(); 00178 error = nr->get_adjacencies( *i, 2, adjents );CHECK_ERR( error ); 00179 error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error ); 00180 CHECK_EQUAL( adjents.size(), mbents.size() ); 00181 std::sort( adjents.begin(), adjents.end() ); 00182 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00183 mbents = subtract( mbents, ahfents ); 00184 CHECK( !mbents.size() ); 00185 } 00186 00187 // IQ22: For every edge, obtain incident faces 00188 if( !edges.empty() ) 00189 { 00190 for( Range::iterator i = edges.begin(); i != edges.end(); ++i ) 00191 { 00192 adjents.clear(); 00193 mbents.clear(); 00194 ahfents.clear(); 00195 error = nr->get_adjacencies( *i, 2, adjents );CHECK_ERR( error ); 00196 error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error ); 00197 CHECK_EQUAL( adjents.size(), mbents.size() ); 00198 std::sort( adjents.begin(), adjents.end() ); 00199 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00200 mbents = subtract( mbents, ahfents ); 00201 CHECK( !mbents.size() ); 00202 } 00203 } 00204 00205 // NQ2: For every face, obtain neighbor faces 00206 for( Range::iterator i = faces.begin(); i != faces.end(); ++i ) 00207 { 00208 adjents.clear(); 00209 mbents.clear(); 00210 ahfents.clear(); 00211 error = nr->get_adjacencies( *i, 2, adjents );CHECK_ERR( error ); 00212 error = mtu.get_bridge_adjacencies( *i, 1, 2, mbents );CHECK_ERR( error ); 00213 CHECK_EQUAL( adjents.size(), mbents.size() ); 00214 std::sort( adjents.begin(), adjents.end() ); 00215 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00216 mbents = subtract( mbents, ahfents ); 00217 CHECK( !mbents.size() ); 00218 } 00219 00220 if( !edges.empty() ) 00221 { 00222 for( Range::iterator i = faces.begin(); i != faces.end(); ++i ) 00223 { 00224 adjents.clear(); 00225 mbents.clear(); 00226 ahfents.clear(); 00227 error = nr->get_adjacencies( *i, 1, adjents );CHECK_ERR( error ); 00228 error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error ); 00229 CHECK_EQUAL( adjents.size(), mbents.size() ); 00230 std::sort( adjents.begin(), adjents.end() ); 00231 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00232 mbents = subtract( mbents, ahfents ); 00233 CHECK( !mbents.size() ); 00234 } 00235 } 00236 } 00237 00238 if( !cells.empty() ) 00239 { 00240 // IQ 31: For every vertex, obtain incident cells 00241 for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) 00242 { 00243 adjents.clear(); 00244 mbents.clear(); 00245 ahfents.clear(); 00246 error = nr->get_adjacencies( *i, 3, adjents );CHECK_ERR( error ); 00247 error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error ); 00248 00249 if( adjents.size() != mbents.size() ) 00250 { 00251 // std::cout<<"ahf results = "<<std::endl; 00252 // ahfents.print(); 00253 // std::cout<<"native results = "<<std::endl; 00254 // mbents.print(); 00255 } 00256 00257 CHECK_EQUAL( adjents.size(), mbents.size() ); 00258 std::sort( adjents.begin(), adjents.end() ); 00259 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00260 mbents = subtract( mbents, ahfents ); 00261 CHECK( !mbents.size() ); 00262 } 00263 00264 if( !edges.empty() ) 00265 { 00266 for( Range::iterator i = edges.begin(); i != edges.end(); ++i ) 00267 { 00268 adjents.clear(); 00269 mbents.clear(); 00270 ahfents.clear(); 00271 error = nr->get_adjacencies( *i, 3, adjents );CHECK_ERR( error ); 00272 error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error ); 00273 CHECK_EQUAL( adjents.size(), mbents.size() ); 00274 std::sort( adjents.begin(), adjents.end() ); 00275 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00276 mbents = subtract( mbents, ahfents ); 00277 CHECK( !mbents.size() ); 00278 } 00279 } 00280 00281 if( !faces.empty() ) 00282 { 00283 for( Range::iterator i = faces.begin(); i != faces.end(); ++i ) 00284 { 00285 adjents.clear(); 00286 mbents.clear(); 00287 ahfents.clear(); 00288 error = nr->get_adjacencies( *i, 3, adjents );CHECK_ERR( error ); 00289 error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error ); 00290 CHECK_EQUAL( adjents.size(), mbents.size() ); 00291 std::sort( adjents.begin(), adjents.end() ); 00292 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00293 mbents = subtract( mbents, ahfents ); 00294 CHECK( !mbents.size() ); 00295 } 00296 } 00297 00298 // NQ3: For every cell, obtain neighbor cells 00299 for( Range::iterator i = cells.begin(); i != cells.end(); ++i ) 00300 { 00301 adjents.clear(); 00302 mbents.clear(); 00303 ahfents.clear(); 00304 error = nr->get_adjacencies( *i, 3, adjents );CHECK_ERR( error ); 00305 error = mtu.get_bridge_adjacencies( *i, 2, 3, mbents );CHECK_ERR( error ); 00306 CHECK_EQUAL( adjents.size(), mbents.size() ); 00307 std::sort( adjents.begin(), adjents.end() ); 00308 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00309 mbents = subtract( mbents, ahfents ); 00310 CHECK( !mbents.size() ); 00311 } 00312 00313 if( !edges.empty() ) 00314 { 00315 for( Range::iterator i = cells.begin(); i != cells.end(); ++i ) 00316 { 00317 adjents.clear(); 00318 mbents.clear(); 00319 ahfents.clear(); 00320 error = nr->get_adjacencies( *i, 1, adjents );CHECK_ERR( error ); 00321 error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error ); 00322 CHECK_EQUAL( adjents.size(), mbents.size() ); 00323 std::sort( adjents.begin(), adjents.end() ); 00324 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00325 mbents = subtract( mbents, ahfents ); 00326 CHECK( !mbents.size() ); 00327 } 00328 } 00329 00330 if( !faces.empty() ) 00331 { 00332 for( Range::iterator i = cells.begin(); i != cells.end(); ++i ) 00333 { 00334 adjents.clear(); 00335 mbents.clear(); 00336 ahfents.clear(); 00337 error = nr->get_adjacencies( *i, 2, adjents );CHECK_ERR( error ); 00338 error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error ); 00339 CHECK_EQUAL( adjents.size(), mbents.size() ); 00340 std::sort( adjents.begin(), adjents.end() ); 00341 std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); 00342 mbents = subtract( mbents, ahfents ); 00343 CHECK( !mbents.size() ); 00344 } 00345 } 00346 } 00347 00348 return MB_SUCCESS; 00349 } 00350 00351 ErrorCode refine_entities( Interface* mb, 00352 ParallelComm* pc, 00353 EntityHandle fset, 00354 int* level_degrees, 00355 const int num_levels, 00356 bool output ) 00357 { 00358 ErrorCode error; 00359 00360 // Get the range of entities in the initial mesh 00361 Range init_ents[4]; 00362 00363 int dim[3] = { 1, 2, 3 }; 00364 00365 if( output ) 00366 { 00367 // int inents = init_ents.size(); 00368 std::stringstream file; 00369 #ifdef MOAB_HAVE_MPI 00370 file << "MESH_LEVEL_0.h5m"; 00371 #else 00372 file << "MESH_LEVEL_0.vtk"; 00373 #endif 00374 std::string str = file.str(); 00375 const char* output_file = str.c_str(); 00376 #ifdef MOAB_HAVE_MPI 00377 error = mb->write_file( output_file, 0, ";;PARALLEL=WRITE_PART" );CHECK_ERR( error ); 00378 #else 00379 error = mb->write_file( output_file, 0, NULL );CHECK_ERR( error ); 00380 #endif 00381 } 00382 00383 // Create an hm object and generate the hierarchy 00384 std::cout << "Creating a hm object" << std::endl; 00385 00386 #ifdef MOAB_HAVE_MPI 00387 Range averts, aedges, afaces, acells; 00388 error = mb->get_entities_by_dimension( fset, 0, averts );MB_CHK_ERR( error ); 00389 error = mb->get_entities_by_dimension( fset, 1, aedges );MB_CHK_ERR( error ); 00390 error = mb->get_entities_by_dimension( fset, 2, afaces );MB_CHK_ERR( error ); 00391 error = mb->get_entities_by_dimension( fset, 3, acells );MB_CHK_ERR( error ); 00392 00393 /* filter based on parallel status */ 00394 if( pc ) 00395 { 00396 error = pc->filter_pstatus( averts, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[0] );MB_CHK_ERR( error ); 00397 error = pc->filter_pstatus( aedges, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[1] );MB_CHK_ERR( error ); 00398 error = pc->filter_pstatus( afaces, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[2] );MB_CHK_ERR( error ); 00399 error = pc->filter_pstatus( acells, PSTATUS_GHOST, PSTATUS_NOT, -1, &init_ents[3] );MB_CHK_ERR( error ); 00400 } 00401 else 00402 { 00403 init_ents[0] = averts; 00404 init_ents[1] = aedges; 00405 init_ents[2] = afaces; 00406 init_ents[3] = acells; 00407 } 00408 #else 00409 error = mb->get_entities_by_dimension( fset, 0, init_ents[0] );CHECK_ERR( error ); 00410 error = mb->get_entities_by_dimension( fset, 1, init_ents[1] );CHECK_ERR( error ); 00411 error = mb->get_entities_by_dimension( fset, 2, init_ents[2] );CHECK_ERR( error ); 00412 error = mb->get_entities_by_dimension( fset, 3, init_ents[3] );CHECK_ERR( error ); 00413 #endif 00414 00415 NestedRefine uref( dynamic_cast< Core* >( mb ), pc, fset ); 00416 std::vector< EntityHandle > set; 00417 00418 std::cout << "Starting hierarchy generation" << std::endl; 00419 bool opt = true; 00420 // bool opt = false; 00421 error = uref.generate_mesh_hierarchy( num_levels, level_degrees, set, opt );CHECK_ERR( error ); 00422 std::cout << "Finished hierarchy generation in " << uref.timeall.tm_total << " secs" << std::endl; 00423 #ifdef MOAB_HAVE_MPI 00424 if( pc ) 00425 { 00426 std::cout << "Time taken for refinement " << uref.timeall.tm_refine << " secs" << std::endl; 00427 std::cout << "Time taken for resolving shared interface " << uref.timeall.tm_resolve << " secs" << std::endl; 00428 } 00429 #endif 00430 00431 // error = uref.exchange_ghosts(set, 1); CHECK_ERR(error); 00432 00433 std::cout << std::endl; 00434 std::cout << "Mesh size for level 0 :: inverts = " << init_ents[0].size() << ", inedges = " << init_ents[1].size() 00435 << ", infaces = " << init_ents[2].size() << ", incells = " << init_ents[3].size() << std::endl; 00436 00437 Range prev_ents[4]; 00438 for( int i = 0; i < 4; i++ ) 00439 prev_ents[i] = init_ents[i]; 00440 00441 // Loop over each mesh level and check its topological properties 00442 for( int l = 0; l < num_levels; l++ ) 00443 { 00444 Range all_ents; 00445 error = mb->get_entities_by_handle( set[l + 1], all_ents );CHECK_ERR( error ); 00446 00447 Range ents[4]; 00448 for( int k = 0; k < 4; k++ ) 00449 ents[k] = all_ents.subset_by_dimension( k ); 00450 00451 if( ents[0].empty() || all_ents.empty() ) std::cout << "Something is not right" << std::endl; 00452 00453 std::cout << std::endl; 00454 std::cout << "Mesh size for level " << l + 1 << " :: nverts = " << ents[0].size() 00455 << ", nedges = " << ents[1].size() << ", nfaces = " << ents[2].size() 00456 << ", ncells = " << ents[3].size() << std::endl; 00457 00458 // Check if the number of new entities created are correct. 00459 00460 for( int type = 1; type < 3; type++ ) 00461 { 00462 int factor = 1; 00463 if( !ents[type + 1].empty() ) 00464 { 00465 00466 for( int p = 0; p <= l; p++ ) 00467 { 00468 for( int d = 0; d < dim[type]; d++ ) 00469 factor *= level_degrees[p]; 00470 } 00471 int expected_nents = factor * init_ents[type + 1].size(); 00472 CHECK_EQUAL( expected_nents, (int)ents[type + 1].size() ); 00473 } 00474 } 00475 00476 // Check adjacencies 00477 error = test_adjacencies( mb, &uref, all_ents );CHECK_ERR( error ); 00478 00479 // Check interlevel child-parent query between previous and current level 00480 for( int type = 1; type < 3; type++ ) 00481 { 00482 if( !prev_ents[type + 1].empty() ) 00483 { 00484 for( Range::iterator e = prev_ents[type + 1].begin(); e != prev_ents[type + 1].end(); e++ ) 00485 { 00486 std::vector< EntityHandle > children; 00487 error = uref.parent_to_child( *e, l, l + 1, children );CHECK_ERR( error ); 00488 for( int i = 0; i < (int)children.size(); i++ ) 00489 { 00490 EntityHandle parent; 00491 error = uref.child_to_parent( children[i], l + 1, l, &parent );CHECK_ERR( error ); 00492 assert( parent == *e ); 00493 } 00494 } 00495 } 00496 } 00497 00498 for( int i = 0; i < 4; i++ ) 00499 prev_ents[i] = ents[i]; 00500 00501 // Print out the boundary vertices 00502 /* EntityHandle bnd_set; 00503 error = mb->create_meshset(MESHSET_SET, bnd_set); MB_CHK_ERR(error); 00504 std::vector<EntityHandle> vbnd; 00505 00506 for (int k=0; k<3; k++){ 00507 std::cout<<"Finding boundary of dimension "<<k<<" with size 00508 "<<ents[k].size()<<std::endl; if (ents[k].size() != 0){ for (Range::iterator v = 00509 ents[k].begin(); v != ents[k].end(); v++) 00510 { 00511 EntityHandle ent = *v; 00512 bool bnd = uref.is_entity_on_boundary(ent); 00513 if (bnd) 00514 vbnd.push_back(*v); 00515 } 00516 } 00517 } 00518 00519 std::cout<<"vbnd.size = "<<vbnd.size()<<std::endl; 00520 error = mb->add_entities(bnd_set, &vbnd[0], (int)vbnd.size()); MB_CHK_ERR(error); 00521 if (output) 00522 { 00523 std::stringstream file; 00524 file << "VBND_LEVEL_" <<l+1<<".vtk"; 00525 std::string str = file.str(); 00526 const char* output_file = str.c_str(); 00527 char * write_opts = NULL; 00528 error = mb->write_file(output_file, 0, write_opts, &bnd_set, 1); CHECK_ERR(error); 00529 }*/ 00530 00531 // Print out the mesh 00532 if( output ) 00533 { 00534 std::stringstream file; 00535 00536 #ifdef MOAB_HAVE_MPI 00537 file << "MESH_LEVEL_" << l + 1 << ".h5m"; 00538 #else 00539 file << "MESH_LEVEL_" << l + 1 << ".vtk"; 00540 #endif 00541 std::string str = file.str(); 00542 const char* output_file = str.c_str(); 00543 #ifdef MOAB_HAVE_MPI 00544 error = mb->write_file( output_file, 0, ";;PARALLEL=WRITE_PART", &set[l + 1], 1 );CHECK_ERR( error ); 00545 #else 00546 error = mb->write_file( output_file, 0, NULL, &set[l + 1], 1 );CHECK_ERR( error ); 00547 #endif 00548 } 00549 } 00550 00551 // Check interlevel child-parent query between initial and most refined mesh 00552 for( int type = 1; type < 3; type++ ) 00553 { 00554 if( !init_ents[type + 1].empty() ) 00555 { 00556 for( Range::iterator e = init_ents[type + 1].begin(); e != init_ents[type + 1].end(); e++ ) 00557 { 00558 std::vector< EntityHandle > children; 00559 error = uref.parent_to_child( *e, 0, num_levels, children );CHECK_ERR( error ); 00560 for( int i = 0; i < (int)children.size(); i++ ) 00561 { 00562 EntityHandle parent; 00563 error = uref.child_to_parent( children[i], num_levels, 0, &parent );CHECK_ERR( error ); 00564 assert( parent == *e ); 00565 } 00566 } 00567 } 00568 } 00569 00570 // Print out the whole hierarchy into a single file 00571 /* if (output) 00572 { 00573 std::stringstream file; 00574 file << "MESH_HIERARCHY.vtk"; 00575 std::string str = file.str(); 00576 const char* output_file = str.c_str(); 00577 error = mb->write_file(output_file); CHECK_ERR(error); 00578 }*/ 00579 00580 return MB_SUCCESS; 00581 } 00582 00583 ErrorCode create_single_entity( Interface* mbImpl, EntityType type ) 00584 { 00585 ErrorCode error; 00586 if( type == MBEDGE ) 00587 { 00588 const double coords[] = { 0.0, 0.0, 0.0, 1.0, 0.0, 0.0 }; 00589 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00590 00591 const int conn[] = { 0, 1 }; 00592 const size_t num_elems = sizeof( conn ) / sizeof( conn[0] ) / 2; 00593 00594 std::cout << "Specify verts and ents" << std::endl; 00595 00596 EntityHandle verts[num_vtx], edges[num_elems]; 00597 for( size_t i = 0; i < num_vtx; ++i ) 00598 { 00599 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00600 } 00601 00602 std::cout << "Created vertices" << std::endl; 00603 00604 for( size_t i = 0; i < num_elems; ++i ) 00605 { 00606 EntityHandle c[2]; 00607 c[0] = verts[conn[0]]; 00608 c[1] = verts[conn[1]]; 00609 00610 error = mbImpl->create_element( MBEDGE, c, 2, edges[i] );CHECK_ERR( error ); 00611 } 00612 00613 std::cout << "Created ents" << std::endl; 00614 } 00615 else if( type == MBTRI ) 00616 { 00617 const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0 }; 00618 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00619 00620 const int conn[] = { 0, 1, 2 }; 00621 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 3; 00622 00623 EntityHandle verts[num_vtx], faces[num_elems]; 00624 for( size_t i = 0; i < num_vtx; ++i ) 00625 { 00626 error = mbImpl->create_vertex( coords + 3 * i, verts[i] ); 00627 if( error != MB_SUCCESS ) return error; 00628 } 00629 00630 for( size_t i = 0; i < num_elems; ++i ) 00631 { 00632 EntityHandle c[3]; 00633 for( int j = 0; j < 3; j++ ) 00634 c[j] = verts[conn[3 * i + j]]; 00635 00636 error = mbImpl->create_element( MBTRI, c, 3, faces[i] );CHECK_ERR( error ); 00637 } 00638 } 00639 else if( type == MBQUAD ) 00640 { 00641 const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0 }; 00642 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00643 00644 const int conn[] = { 0, 1, 2, 3 }; 00645 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 3; 00646 00647 EntityHandle verts[num_vtx], faces[num_elems]; 00648 for( size_t i = 0; i < num_vtx; ++i ) 00649 { 00650 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00651 } 00652 00653 for( size_t i = 0; i < num_elems; ++i ) 00654 { 00655 EntityHandle c[4]; 00656 for( int j = 0; j < 4; j++ ) 00657 c[j] = verts[conn[j]]; 00658 00659 error = mbImpl->create_element( MBQUAD, c, 4, faces[i] );CHECK_ERR( error ); 00660 } 00661 } 00662 else if( type == MBTET ) 00663 { 00664 const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1 }; 00665 00666 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00667 00668 const int conn[] = { 0, 1, 2, 3 }; 00669 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4; 00670 00671 EntityHandle verts[num_vtx], cells[num_elems]; 00672 for( size_t i = 0; i < num_vtx; ++i ) 00673 { 00674 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00675 } 00676 00677 for( size_t i = 0; i < num_elems; ++i ) 00678 { 00679 EntityHandle c[4]; 00680 for( int j = 0; j < 4; j++ ) 00681 c[j] = verts[conn[j]]; 00682 00683 error = mbImpl->create_element( MBTET, c, 4, cells[i] );CHECK_ERR( error ); 00684 } 00685 } 00686 else if( type == MBHEX ) 00687 { 00688 const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 }; 00689 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00690 00691 const int conn[] = { 0, 1, 2, 3, 4, 5, 6, 7 }; 00692 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 8; 00693 00694 EntityHandle verts[num_vtx], cells[num_elems]; 00695 for( size_t i = 0; i < num_vtx; ++i ) 00696 { 00697 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00698 } 00699 00700 for( size_t i = 0; i < num_elems; ++i ) 00701 { 00702 EntityHandle c[8]; 00703 for( int j = 0; j < 8; j++ ) 00704 c[j] = verts[conn[j]]; 00705 00706 error = mbImpl->create_element( MBHEX, c, 8, cells[i] );CHECK_ERR( error ); 00707 } 00708 } 00709 return MB_SUCCESS; 00710 } 00711 00712 ErrorCode create_mesh( Interface* mbImpl, EntityType type ) 00713 { 00714 ErrorCode error; 00715 if( type == MBEDGE ) 00716 { 00717 const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0 }; 00718 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00719 00720 const int conn[] = { 1, 0, 0, 3, 2, 0, 0, 4 }; 00721 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 2; 00722 00723 EntityHandle verts[num_vtx], edges[num_elems]; 00724 for( size_t i = 0; i < num_vtx; ++i ) 00725 { 00726 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00727 } 00728 00729 for( size_t i = 0; i < num_elems; ++i ) 00730 { 00731 EntityHandle c[2]; 00732 c[0] = verts[conn[2 * i]]; 00733 c[1] = verts[conn[2 * i + 1]]; 00734 00735 error = mbImpl->create_element( MBEDGE, c, 2, edges[i] );CHECK_ERR( error ); 00736 } 00737 } 00738 else if( type == MBTRI ) 00739 { 00740 const double coords[] = { 0, 0, 0, 1, -1, 0, 1, 1, 0, -1, 1, 0, -1, -1, 0, 0, 0, 1 }; 00741 00742 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00743 00744 const int conn[] = { 0, 1, 2, 0, 2, 3, 0, 3, 4, 0, 4, 1, 0, 5, 3, 0, 2, 5, 0, 4, 5, 0, 5, 1 }; 00745 00746 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 3; 00747 00748 EntityHandle verts[num_vtx], faces[num_elems]; 00749 for( size_t i = 0; i < num_vtx; ++i ) 00750 { 00751 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00752 } 00753 00754 for( size_t i = 0; i < num_elems; ++i ) 00755 { 00756 EntityHandle c[3]; 00757 for( int j = 0; j < 3; j++ ) 00758 c[j] = verts[conn[3 * i + j]]; 00759 00760 error = mbImpl->create_element( MBTRI, c, 3, faces[i] );CHECK_ERR( error ); 00761 } 00762 } 00763 else if( type == MBQUAD ) 00764 { 00765 const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, -1, 1, 0, -1, 0, 0, 00766 -1, -1, 0, 0, -1, 0, 1, -1, 0, 0, 1, 1, 0, 0, 1, 0, -1, 1 }; 00767 00768 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00769 00770 const int conn[] = { 0, 1, 2, 3, 0, 3, 4, 5, 7, 8, 1, 0, 6, 7, 0, 5, 0, 3, 9, 10, 0, 10, 11, 7 }; 00771 00772 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4; 00773 00774 EntityHandle verts[num_vtx], faces[num_elems]; 00775 for( size_t i = 0; i < num_vtx; ++i ) 00776 { 00777 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00778 } 00779 00780 for( size_t i = 0; i < num_elems; ++i ) 00781 { 00782 EntityHandle c[4]; 00783 for( int j = 0; j < 4; j++ ) 00784 c[j] = verts[conn[4 * i + j]]; 00785 00786 error = mbImpl->create_element( MBQUAD, c, 4, faces[i] );CHECK_ERR( error ); 00787 } 00788 } 00789 else if( type == MBTET ) 00790 { 00791 const double coords[] = { 0, -1, 0, 0, 2, 0, 1, 0, 0, -0.5, 0, 0, 0, 0, 1, 0, 0, -2 }; 00792 00793 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00794 00795 const int conn[] = { 0, 2, 1, 4, 3, 0, 1, 4, 5, 2, 1, 0, 5, 0, 1, 3 }; 00796 00797 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4; 00798 00799 EntityHandle verts[num_vtx], cells[num_elems]; 00800 for( size_t i = 0; i < num_vtx; ++i ) 00801 { 00802 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00803 } 00804 00805 for( size_t i = 0; i < num_elems; ++i ) 00806 { 00807 EntityHandle c[4]; 00808 for( int j = 0; j < 4; j++ ) 00809 c[j] = verts[conn[4 * i + j]]; 00810 00811 error = mbImpl->create_element( MBTET, c, 4, cells[i] );CHECK_ERR( error ); 00812 } 00813 } 00814 else if( type == MBHEX ) 00815 { 00816 const double coords[] = { 0, -1, 0, 1, -1, 0, 1, 1, 0, 0, 1, 0, -1, 1, 0, -1, -1, 0, 00817 0, -1, 1, 1, -1, 1, 1, 1, 1, 0, 1, 1, -1, 1, 1, -1, -1, 1, 00818 0, -1, -1, 1, -1, -1, 1, 1, -1, 0, 1, -1, -1, 1, -1, -1, -1, -1 }; 00819 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00820 00821 const int conn[] = { 0, 1, 2, 3, 6, 7, 8, 9, 5, 0, 3, 4, 11, 6, 9, 10, 00822 12, 13, 14, 15, 0, 1, 2, 3, 17, 12, 15, 16, 5, 0, 3, 4 }; 00823 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 8; 00824 00825 EntityHandle verts[num_vtx], cells[num_elems]; 00826 for( size_t i = 0; i < num_vtx; ++i ) 00827 { 00828 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00829 } 00830 00831 for( size_t i = 0; i < num_elems; ++i ) 00832 { 00833 EntityHandle c[8]; 00834 for( int j = 0; j < 8; j++ ) 00835 c[j] = verts[conn[8 * i + j]]; 00836 00837 error = mbImpl->create_element( MBHEX, c, 8, cells[i] );CHECK_ERR( error ); 00838 } 00839 } 00840 return MB_SUCCESS; 00841 } 00842 00843 ErrorCode create_simple_mesh( Interface* mbImpl, EntityType type ) 00844 { 00845 ErrorCode error; 00846 if( type == MBEDGE ) 00847 { 00848 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0, 00849 4, 1, 0, 3, 1, 0, 2, 1, 0, 1, 1, 0, 0, 1, 0 }; 00850 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00851 00852 const int conn[] = { 1, 0, 1, 2, 2, 3, 3, 4, 4, 5, 5, 6, 6, 7, 7, 8, 8, 9, 9, 0 }; 00853 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 2; 00854 00855 EntityHandle verts[num_vtx], edges[num_elems]; 00856 for( size_t i = 0; i < num_vtx; ++i ) 00857 { 00858 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00859 } 00860 00861 for( size_t i = 0; i < num_elems; ++i ) 00862 { 00863 EntityHandle c[2]; 00864 c[0] = verts[conn[2 * i]]; 00865 c[1] = verts[conn[2 * i + 1]]; 00866 00867 error = mbImpl->create_element( MBEDGE, c, 2, edges[i] );CHECK_ERR( error ); 00868 } 00869 } 00870 else if( type == MBTRI ) 00871 { 00872 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 2.5, 1, 0, 1.5, 1, 0, 0.5, 1, 00873 0, -0.5, 1, 0, -0.5, -1, 0, 0.5, -1, 0, 1.5, -1, 0, 2.5, -1, 0 }; 00874 00875 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00876 00877 const int conn[] = { 0, 5, 6, 0, 1, 5, 1, 4, 5, 1, 2, 4, 2, 3, 4, 00878 7, 8, 0, 8, 1, 0, 8, 9, 1, 9, 2, 1, 9, 10, 2 }; 00879 00880 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 3; 00881 00882 EntityHandle verts[num_vtx], faces[num_elems]; 00883 for( size_t i = 0; i < num_vtx; ++i ) 00884 { 00885 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00886 } 00887 00888 for( size_t i = 0; i < num_elems; ++i ) 00889 { 00890 EntityHandle c[3]; 00891 for( int j = 0; j < 3; j++ ) 00892 c[j] = verts[conn[3 * i + j]]; 00893 00894 error = mbImpl->create_element( MBTRI, c, 3, faces[i] );CHECK_ERR( error ); 00895 } 00896 } 00897 else if( type == MBQUAD ) 00898 { 00899 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0, 5, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 00900 3, 1, 0, 4, 1, 0, 5, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 3, 2, 0, 4, 2, 0, 5, 2, 0 }; 00901 00902 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00903 00904 const int conn[] = { 0, 1, 7, 6, 1, 2, 8, 7, 2, 3, 9, 8, 3, 4, 10, 9, 4, 5, 11, 10, 00905 6, 7, 13, 12, 7, 8, 14, 13, 8, 9, 15, 14, 9, 10, 16, 15, 10, 11, 17, 16 }; 00906 00907 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4; 00908 00909 EntityHandle verts[num_vtx], faces[num_elems]; 00910 for( size_t i = 0; i < num_vtx; ++i ) 00911 { 00912 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00913 } 00914 00915 for( size_t i = 0; i < num_elems; ++i ) 00916 { 00917 EntityHandle c[4]; 00918 for( int j = 0; j < 4; j++ ) 00919 c[j] = verts[conn[4 * i + j]]; 00920 00921 error = mbImpl->create_element( MBQUAD, c, 4, faces[i] );CHECK_ERR( error ); 00922 } 00923 } 00924 else if( type == MBTET ) 00925 { 00926 const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0, 0, 0, 1 }; 00927 00928 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00929 00930 const int conn[] = { 0, 1, 2, 5, 3, 0, 2, 5, 4, 1, 0, 5, 4, 0, 3, 5 }; 00931 00932 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4; 00933 00934 EntityHandle verts[num_vtx], cells[num_elems]; 00935 for( size_t i = 0; i < num_vtx; ++i ) 00936 { 00937 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00938 } 00939 00940 for( size_t i = 0; i < num_elems; ++i ) 00941 { 00942 EntityHandle c[4]; 00943 for( int j = 0; j < 4; j++ ) 00944 c[j] = verts[conn[4 * i + j]]; 00945 00946 error = mbImpl->create_element( MBTET, c, 4, cells[i] );CHECK_ERR( error ); 00947 } 00948 } 00949 else if( type == MBHEX ) 00950 { 00951 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 00952 0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1 }; 00953 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00954 00955 const int conn[] = { 0, 1, 4, 3, 9, 10, 13, 12, 1, 2, 5, 4, 10, 11, 14, 13, 00956 3, 4, 7, 6, 12, 13, 16, 15, 4, 5, 8, 7, 13, 14, 17, 16 }; 00957 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 8; 00958 00959 EntityHandle verts[num_vtx], cells[num_elems]; 00960 for( size_t i = 0; i < num_vtx; ++i ) 00961 { 00962 error = mbImpl->create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( error ); 00963 } 00964 00965 for( size_t i = 0; i < num_elems; ++i ) 00966 { 00967 EntityHandle c[8]; 00968 for( int j = 0; j < 8; j++ ) 00969 c[j] = verts[conn[8 * i + j]]; 00970 00971 error = mbImpl->create_element( MBHEX, c, 8, cells[i] );CHECK_ERR( error ); 00972 } 00973 } 00974 return MB_SUCCESS; 00975 } 00976 00977 ErrorCode test_entities( int mesh_type, EntityType type, int* level_degrees, int num_levels, bool output ) 00978 { 00979 ErrorCode error; 00980 Core mb; 00981 Interface* mbimpl = &mb; 00982 00983 // Create entities 00984 if( mesh_type == 1 ) 00985 { 00986 error = create_single_entity( mbimpl, type ); 00987 if( error != MB_SUCCESS ) return error; 00988 std::cout << "Entity created successfully" << std::endl; 00989 } 00990 else if( mesh_type == 2 ) 00991 { 00992 error = create_mesh( mbimpl, type ); 00993 if( error != MB_SUCCESS ) return error; 00994 std::cout << "Small mesh created successfully" << std::endl; 00995 } 00996 else if( mesh_type == 3 ) 00997 { 00998 error = create_simple_mesh( mbimpl, type ); 00999 if( error != MB_SUCCESS ) return error; 01000 std::cout << "Small simple mesh created successfully" << std::endl; 01001 } 01002 01003 // Generate hierarchy 01004 error = refine_entities( mbimpl, 0, 0, level_degrees, num_levels, output ); 01005 if( error != MB_SUCCESS ) return error; 01006 01007 return MB_SUCCESS; 01008 } 01009 ErrorCode test_1D() 01010 { 01011 ErrorCode error; 01012 01013 std::cout << "Testing EDGE" << std::endl; 01014 EntityType type = MBEDGE; 01015 01016 std::cout << "Testing single entity" << std::endl; 01017 int deg[3] = { 2, 3, 5 }; 01018 int len = sizeof( deg ) / sizeof( int ); 01019 error = test_entities( 1, type, deg, len, false );CHECK_ERR( error ); 01020 01021 std::cout << std::endl; 01022 std::cout << "Testing a small mesh" << std::endl; 01023 error = test_entities( 2, type, deg, len, false );CHECK_ERR( error ); 01024 01025 std::cout << std::endl; 01026 std::cout << "Testing a small simple mesh" << std::endl; 01027 int degree[4] = { 5, 5, 2, 2 }; 01028 len = sizeof( degree ) / sizeof( int ); 01029 error = test_entities( 3, type, degree, len, false );CHECK_ERR( error ); 01030 01031 return MB_SUCCESS; 01032 } 01033 01034 ErrorCode test_2D() 01035 { 01036 ErrorCode error; 01037 01038 std::cout << "Testing TRI" << std::endl; 01039 EntityType type = MBTRI; 01040 01041 std::cout << "Testing single entity" << std::endl; 01042 int deg[3] = { 2, 3, 5 }; 01043 int len = sizeof( deg ) / sizeof( int ); 01044 error = test_entities( 1, type, deg, len, false );CHECK_ERR( error ); 01045 01046 std::cout << std::endl; 01047 std::cout << "Testing a small mesh" << std::endl; 01048 error = test_entities( 2, type, deg, len, false );CHECK_ERR( error ); 01049 01050 std::cout << std::endl; 01051 std::cout << "Testing a small simple mesh" << std::endl; 01052 int degree[2] = { 5, 2 }; 01053 int length = sizeof( degree ) / sizeof( int ); 01054 error = test_entities( 3, type, degree, length, false );CHECK_ERR( error ); 01055 01056 std::cout << std::endl; 01057 std::cout << "Testing QUAD" << std::endl; 01058 type = MBQUAD; 01059 01060 std::cout << "Testing single entity" << std::endl; 01061 error = test_entities( 1, type, deg, len, false );CHECK_ERR( error ); 01062 01063 std::cout << std::endl; 01064 std::cout << "Testing a small mesh" << std::endl; 01065 error = test_entities( 2, type, deg, len, false );CHECK_ERR( error ); 01066 01067 std::cout << std::endl; 01068 std::cout << "Testing a small simple mesh" << std::endl; 01069 error = test_entities( 3, type, degree, length, false );CHECK_ERR( error ); 01070 01071 return MB_SUCCESS; 01072 } 01073 01074 ErrorCode test_3D() 01075 { 01076 ErrorCode error; 01077 01078 std::cout << "Testing TET" << std::endl; 01079 EntityType type = MBTET; 01080 int deg[2] = { 2, 3 }; 01081 int len = sizeof( deg ) / sizeof( int ); 01082 01083 std::cout << "Testing single entity" << std::endl; 01084 error = test_entities( 1, type, deg, len, false );CHECK_ERR( error ); 01085 01086 std::cout << std::endl; 01087 std::cout << "Testing a small mesh" << std::endl; 01088 error = test_entities( 2, type, deg, len, false );CHECK_ERR( error ); 01089 01090 std::cout << std::endl; 01091 std::cout << "Testing a small simple mesh" << std::endl; 01092 int degree[4] = { 2, 2, 2, 2 }; 01093 int length = sizeof( degree ) / sizeof( int ); 01094 error = test_entities( 3, type, degree, length, false );CHECK_ERR( error ); 01095 01096 std::cout << std::endl; 01097 std::cout << "Testing HEX" << std::endl; 01098 type = MBHEX; 01099 01100 std::cout << "Testing single entity" << std::endl; 01101 error = test_entities( 1, type, deg, len, false );CHECK_ERR( error ); 01102 01103 std::cout << std::endl; 01104 std::cout << "Testing a small mesh" << std::endl; 01105 error = test_entities( 2, type, deg, len, false );CHECK_ERR( error ); 01106 01107 std::cout << std::endl; 01108 std::cout << "Testing a small simple mesh" << std::endl; 01109 error = test_entities( 3, type, degree, length, false );CHECK_ERR( error ); 01110 01111 return MB_SUCCESS; 01112 } 01113 01114 ErrorCode test_mesh( const char* filename, int* level_degrees, int num_levels ) 01115 { 01116 Core moab; 01117 Interface* mbImpl = &moab; 01118 ParallelComm* pc = NULL; 01119 EntityHandle fileset; 01120 01121 ErrorCode error; 01122 error = mbImpl->create_meshset( moab::MESHSET_SET, fileset );CHECK_ERR( error ); 01123 01124 #ifdef MOAB_HAVE_MPI 01125 MPI_Comm comm = MPI_COMM_WORLD; 01126 EntityHandle partnset; 01127 error = mbImpl->create_meshset( moab::MESHSET_SET, partnset );MB_CHK_ERR( error ); 01128 pc = moab::ParallelComm::get_pcomm( mbImpl, partnset, &comm ); 01129 01130 int procs = 1; 01131 MPI_Comm_size( MPI_COMM_WORLD, &procs ); 01132 01133 if( procs > 1 ) 01134 { 01135 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS"; 01136 01137 error = mbImpl->load_file( filename, &fileset, read_options.c_str() );CHECK_ERR( error ); 01138 01139 // DBG 01140 std::set< unsigned int > shprocs; 01141 error = pc->get_comm_procs( shprocs );CHECK_ERR( error ); 01142 std::cout << "#sprocs = " << shprocs.size() << std::endl; 01143 // DBG 01144 } 01145 else if( procs == 1 ) 01146 { 01147 #endif 01148 error = mbImpl->load_file( filename, &fileset );CHECK_ERR( error ); 01149 #ifdef MOAB_HAVE_MPI 01150 } 01151 #endif 01152 01153 // Generate hierarchy 01154 error = refine_entities( &moab, pc, fileset, level_degrees, num_levels, false );CHECK_ERR( error ); 01155 01156 return MB_SUCCESS; 01157 } 01158 01159 int main( int argc, char* argv[] ) 01160 { 01161 #ifdef MOAB_HAVE_MPI 01162 MPI_Init( &argc, &argv ); 01163 01164 int nprocs, rank; 01165 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 01166 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01167 #endif 01168 01169 ErrorCode result; 01170 if( argc == 1 ) 01171 { 01172 result = test_1D(); 01173 handle_error_code( result, number_tests_failed, number_tests_successful ); 01174 std::cout << "\n"; 01175 01176 result = test_2D(); 01177 handle_error_code( result, number_tests_failed, number_tests_successful ); 01178 std::cout << "\n"; 01179 01180 result = test_3D(); 01181 handle_error_code( result, number_tests_failed, number_tests_successful ); 01182 std::cout << "\n"; 01183 } 01184 else if( argc == 2 ) 01185 { 01186 const char* filename = argv[1]; 01187 int deg[1] = { 2 }; 01188 int len = sizeof( deg ) / sizeof( int ); 01189 result = test_mesh( filename, deg, len ); 01190 handle_error_code( result, number_tests_failed, number_tests_successful ); 01191 std::cout << "\n"; 01192 } 01193 01194 #ifdef MOAB_HAVE_MPI 01195 MPI_Finalize(); 01196 #endif 01197 01198 return number_tests_failed; 01199 }
