MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*This unit test is for the convergence study of high order reconstruction under uniform 00002 * refinement*/ 00003 #include <iostream> 00004 #include <string> 00005 #include <sstream> 00006 #if defined( __MINGW32__ ) 00007 #include <sys/time.h> 00008 #else 00009 #include <ctime> 00010 #endif 00011 00012 #include <vector> 00013 #include <algorithm> 00014 #include "moab/Core.hpp" 00015 #include "moab/Range.hpp" 00016 #include "moab/MeshTopoUtil.hpp" 00017 #include "moab/NestedRefine.hpp" 00018 #include "moab/DiscreteGeometry/HiReconstruction.hpp" 00019 #include "TestUtil.hpp" 00020 #include "geomObject.cpp" 00021 #include <cmath> 00022 #include <cstdlib> 00023 #include <cassert> 00024 00025 #ifdef MOAB_HAVE_MPI 00026 #include "moab/ParallelComm.hpp" 00027 #include "MBParallelConventions.h" 00028 #include "ReadParallel.hpp" 00029 #include "moab/FileOptions.hpp" 00030 #include "MBTagConventions.hpp" 00031 #include "moab_mpi.h" 00032 #endif 00033 00034 using namespace moab; 00035 00036 #define nsamples 10 00037 00038 #ifdef MOAB_HAVE_MPI 00039 std::string read_options; 00040 #endif 00041 00042 ErrorCode load_meshset_hirec( const char* infile, 00043 Interface* mbimpl, 00044 EntityHandle& meshset, 00045 ParallelComm*& pc, 00046 const int degree, 00047 const int dim ) 00048 { 00049 ErrorCode error; 00050 error = mbimpl->create_meshset( moab::MESHSET_SET, meshset );MB_CHK_ERR( error ); 00051 #ifdef MOAB_HAVE_MPI 00052 int nprocs, rank; 00053 MPI_Comm comm = MPI_COMM_WORLD; 00054 MPI_Comm_size( comm, &nprocs ); 00055 MPI_Comm_rank( comm, &rank ); 00056 EntityHandle partnset; 00057 error = mbimpl->create_meshset( moab::MESHSET_SET, partnset );MB_CHK_ERR( error ); 00058 00059 if( nprocs > 1 ) 00060 { 00061 pc = moab::ParallelComm::get_pcomm( mbimpl, partnset, &comm ); 00062 } 00063 00064 if( nprocs > 1 ) 00065 { 00066 int nghlayers = degree > 0 ? HiReconstruction::estimate_num_ghost_layers( degree, true ) : 0; 00067 assert( nghlayers < 10 ); 00068 00069 if( nghlayers ) 00070 { 00071 // get ghost layers 00072 if( dim == 2 ) 00073 { 00074 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_" 00075 "SHARED_ENTS;PARALLEL_GHOSTS=2.0."; 00076 } 00077 else if( dim == 1 ) 00078 { 00079 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_" 00080 "SHARED_ENTS;PARALLEL_GHOSTS=1.0."; 00081 } 00082 else 00083 { 00084 MB_SET_ERR( MB_FAILURE, "unsupported dimension" ); 00085 } 00086 00087 read_options += (char)( '0' + nghlayers ); 00088 // std::cout << "On processor " << rank << " Degree=" << degree << " "<< read_options << 00089 // std::endl; 00090 } 00091 else 00092 { 00093 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; 00094 } 00095 00096 /*for debug*/ 00097 /*std::string outfile = std::string(infile); std::size_t dotpos = outfile.find_last_of("."); 00098 std::ostringstream convert; convert << rank; 00099 std::string localfile = outfile.substr(0,dotpos)+convert.str()+".vtk"; 00100 //write local mesh 00101 EntityHandle local; 00102 error = mbimpl->create_meshset(moab::MESHSET_SET,local);CHECK_ERR(error); 00103 std::string local_options = 00104 "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; error = 00105 mbimpl->load_file(infile,&local,local_options.c_str()); MB_CHK_ERR(error); error = 00106 mbimpl->write_file(localfile.c_str(),0,0,&local,1);*/ 00107 00108 error = mbimpl->load_file( infile, &meshset, read_options.c_str() );MB_CHK_ERR( error ); 00109 /*for debug 00110 //write local mesh with ghost layers 00111 localfile = outfile.substr(0,dotpos)+convert.str()+"_ghost.vtk"; 00112 error = mbimpl->write_file(localfile.c_str(),0,0,&meshset,1);*/ 00113 } 00114 else 00115 { 00116 error = mbimpl->load_file( infile, &meshset );MB_CHK_ERR( error ); 00117 } 00118 00119 #else 00120 assert( !pc && degree && dim ); 00121 error = mbimpl->load_file( infile, &meshset );MB_CHK_ERR( error ); 00122 #endif 00123 return error; 00124 } 00125 00126 ErrorCode closedsurface_uref_hirec_convergence_study( const char* infile, 00127 std::vector< int >& degs2fit, 00128 bool interp, 00129 int dim, 00130 geomObject* obj, 00131 int& ntestverts, 00132 std::vector< double >& geoml1errs, 00133 std::vector< double >& geoml2errs, 00134 std::vector< double >& geomlinferrs ) 00135 { 00136 Core moab; 00137 Interface* mbImpl = &moab; 00138 ParallelComm* pc = NULL; 00139 EntityHandle meshset; 00140 00141 #ifdef MOAB_HAVE_MPI 00142 int nprocs, rank; 00143 MPI_Comm comm = MPI_COMM_WORLD; 00144 MPI_Comm_size( comm, &nprocs ); 00145 MPI_Comm_rank( comm, &rank ); 00146 #endif 00147 00148 ErrorCode error; 00149 // mesh will be loaded and communicator pc will be updated 00150 int mxdeg = 1; 00151 for( size_t i = 0; i < degs2fit.size(); ++i ) 00152 { 00153 mxdeg = std::max( degs2fit[i], mxdeg ); 00154 } 00155 error = load_meshset_hirec( infile, mbImpl, meshset, pc, mxdeg, dim );MB_CHK_ERR( error ); 00156 00157 Range elems, elems_owned; 00158 error = mbImpl->get_entities_by_dimension( meshset, dim, elems );MB_CHK_ERR( error ); 00159 00160 #ifdef MOAB_HAVE_MPI 00161 00162 if( pc ) 00163 { 00164 error = pc->filter_pstatus( elems, PSTATUS_GHOST, PSTATUS_NOT, -1, &elems_owned );MB_CHK_ERR( error ); 00165 } 00166 else 00167 { 00168 elems_owned = elems; 00169 } 00170 00171 #endif 00172 00173 #ifdef MOAB_HAVE_MPI 00174 // std::cout << "Mesh has " << nelems << " elements on Processor " << rank << " in total;"; 00175 // std::cout << elems_owned.size() << " of which are locally owned elements" << std::endl; 00176 #else 00177 // std::cout << "Mesh has " << nelems << " elements" << std::endl; 00178 #endif 00179 00180 /************************ 00181 * convergence study * 00182 *************************/ 00183 // project onto exact geometry since each level with uref has only linear coordinates 00184 Range verts; 00185 error = mbImpl->get_entities_by_dimension( meshset, 0, verts );MB_CHK_ERR( error ); 00186 00187 for( Range::iterator ivert = verts.begin(); ivert != verts.end(); ++ivert ) 00188 { 00189 EntityHandle currvert = *ivert; 00190 double currcoords[3], exactcoords[3]; 00191 error = mbImpl->get_coords( &currvert, 1, currcoords );MB_CHK_ERR( error ); 00192 obj->project_points2geom( 3, currcoords, exactcoords, NULL ); 00193 00194 error = mbImpl->set_coords( &currvert, 1, exactcoords );MB_CHK_ERR( error ); 00195 // for debug 00196 /*error = mbImpl->get_coords(&currvert,1,currcoords); MB_CHK_ERR(error); 00197 assert(currcoords[0]==exactcoords[0]&&currcoords[1]==exactcoords[1]&&currcoords[2]==exactcoords[2]);*/ 00198 } 00199 00200 // test ahf on mesh with ghost layers 00201 /*Range verts_owned; 00202 #ifdef MOAB_HAVE_MPI 00203 if(pc){ 00204 error = 00205 pc->filter_pstatus(verts,PSTATUS_GHOST,PSTATUS_NOT,-1,&verts_owned);MB_CHK_ERR(error); }else{ 00206 verts_owned = verts; 00207 } 00208 00209 HalfFacetRep *ahf = new HalfFacetRep(&moab,pc,meshset); 00210 error = ahf->initialize(); MB_CHK_ERR(error); 00211 00212 for(int i=0;i<nprocs;++i){ 00213 if(rank==i){ 00214 std::cout << "Processor " << rank << " Local elements: \n"; 00215 for(Range::iterator ielem=elems.begin();ielem!=elems.end();++ielem){ 00216 EntityHandle currelem = *ielem; 00217 std::vector<EntityHandle> conn; 00218 error = mbImpl->get_connectivity(&currelem,1,conn); MB_CHK_ERR(error); 00219 std::cout << *ielem << ": "; 00220 for(size_t k=0;k<conn.size();++k) std::cout << conn[k] << " "; 00221 std::cout << std::endl; 00222 } 00223 00224 std::cout << "Processor " << rank << " Local owned elements: \n"; 00225 for(Range::iterator ielem=elems_owned.begin();ielem!=elems_owned.end();++ielem){ 00226 EntityHandle currelem = *ielem; 00227 std::vector<EntityHandle> conn; 00228 error = mbImpl->get_connectivity(&currelem,1,conn); MB_CHK_ERR(error); 00229 std::cout << *ielem << ": "; 00230 for(size_t k=0;k<conn.size();++k) std::cout << conn[k] << " "; 00231 std::cout << std::endl; 00232 } 00233 00234 00235 std::cout << "Processor " << rank << " Local vertices: "; 00236 for(Range::iterator ivert=verts.begin();ivert!=verts.end();++ivert){ 00237 std::cout << *ivert << " "; 00238 } 00239 std::cout << std::endl; 00240 std::cout << "Processor " << rank << " Local owned vertices: "; 00241 for(Range::iterator ivert=verts_owned.begin();ivert!=verts_owned.end();++ivert){ 00242 std::cout << *ivert << " "; 00243 } 00244 std::cout << std::endl; 00245 00246 for(Range::iterator ivert=verts_owned.begin();ivert!=verts_owned.end();++ivert){ 00247 EntityHandle currvid = *ivert; 00248 std::cout << "Processor " << rank << " local verts: " << *ivert << " has 00249 adjfaces: "; std::vector<EntityHandle> adjfaces; 00250 //error = ahf->get_up_adjacencies(currvid,2,adjfaces); MB_CHK_ERR(error); 00251 error = mbImpl->get_adjacencies(&currvid,1,2,false,adjfaces); MB_CHK_ERR(error); 00252 for(size_t k=0;k<adjfaces.size();++k){ 00253 std::cout << adjfaces[k] << " "; 00254 } 00255 std::cout << std::endl; 00256 } 00257 00258 for(Range::iterator ivert=verts.begin();ivert!=verts.end();++ivert){ 00259 EntityHandle currvid = *ivert; 00260 std::cout << "Processor " << rank << " all verts: " << *ivert << " has adjfaces: 00261 "; std::vector<EntityHandle> adjfaces; 00262 //error = ahf->get_up_adjacencies(*ivert,2,adjfaces); MB_CHK_ERR(error); 00263 error = mbImpl->get_adjacencies(&currvid,1,2,false,adjfaces); MB_CHK_ERR(error); 00264 for(size_t k=0;k<adjfaces.size();++k){ 00265 std::cout << adjfaces[k] << " "; 00266 } 00267 std::cout << std::endl; 00268 } 00269 00270 }else{ 00271 MPI_Barrier(MPI_COMM_WORLD); 00272 } 00273 } 00274 exit(0); 00275 #endif*/ 00276 00277 // generate random points on each elements, assument 3D coordinates 00278 int nvpe = TYPE_FROM_HANDLE( *elems.begin() ) == MBTRI ? 3 : 4; 00279 std::vector< double > testpnts, testnaturalcoords; 00280 ntestverts = elems_owned.size() * nsamples; 00281 testpnts.reserve( 3 * elems_owned.size() * nsamples ); 00282 testnaturalcoords.reserve( nvpe * elems_owned.size() * nsamples ); 00283 00284 for( Range::iterator ielem = elems_owned.begin(); ielem != elems_owned.end(); ++ielem ) 00285 { 00286 EntityHandle currelem = *ielem; 00287 std::vector< EntityHandle > conn; 00288 error = mbImpl->get_connectivity( &currelem, 1, conn );MB_CHK_ERR( error ); 00289 std::vector< double > elemcoords( 3 * conn.size() ); 00290 error = mbImpl->get_coords( &( conn[0] ), conn.size(), &( elemcoords[0] ) );MB_CHK_ERR( error ); 00291 EntityType type = TYPE_FROM_HANDLE( currelem ); 00292 00293 for( int s = 0; s < nsamples; ++s ) 00294 { 00295 if( type == MBTRI ) 00296 { 00297 double a = (double)rand() / RAND_MAX, b = (double)rand() / RAND_MAX, c = (double)rand() / RAND_MAX, sum; 00298 sum = a + b + c; 00299 00300 if( sum < 1e-12 ) 00301 { 00302 --s; 00303 continue; 00304 } 00305 else 00306 { 00307 a /= sum, b /= sum, c /= sum; 00308 } 00309 00310 assert( a > 0 && b > 0 && c > 0 && fabs( a + b + c - 1 ) < 1e-12 ); 00311 testpnts.push_back( a * elemcoords[0] + b * elemcoords[3] + c * elemcoords[6] ); 00312 testpnts.push_back( a * elemcoords[1] + b * elemcoords[4] + c * elemcoords[7] ); 00313 testpnts.push_back( a * elemcoords[2] + b * elemcoords[5] + c * elemcoords[8] ); 00314 testnaturalcoords.push_back( a ), testnaturalcoords.push_back( b ), testnaturalcoords.push_back( c ); 00315 } 00316 else if( type == MBQUAD ) 00317 { 00318 double xi = (double)rand() / RAND_MAX, eta = (double)rand() / RAND_MAX, N[4]; 00319 xi = 2 * xi - 1; 00320 eta = 2 * eta - 1; 00321 N[0] = ( 1 - xi ) * ( 1 - eta ) / 4, N[1] = ( 1 + xi ) * ( 1 - eta ) / 4, 00322 N[2] = ( 1 + xi ) * ( 1 + eta ) / 4, N[3] = ( 1 - xi ) * ( 1 + eta ) / 4; 00323 testpnts.push_back( N[0] * elemcoords[0] + N[1] * elemcoords[3] + N[2] * elemcoords[6] + 00324 N[3] * elemcoords[9] ); 00325 testpnts.push_back( N[0] * elemcoords[1] + N[1] * elemcoords[4] + N[2] * elemcoords[7] + 00326 N[3] * elemcoords[10] ); 00327 testpnts.push_back( N[0] * elemcoords[2] + N[1] * elemcoords[5] + N[2] * elemcoords[8] + 00328 N[3] * elemcoords[11] ); 00329 testnaturalcoords.push_back( N[0] ), testnaturalcoords.push_back( N[1] ), 00330 testnaturalcoords.push_back( N[2] ), testnaturalcoords.push_back( N[3] ); 00331 } 00332 else 00333 { 00334 throw std::invalid_argument( "NOT SUPPORTED ELEMENT TYPE" ); 00335 } 00336 } 00337 } 00338 00339 // Compute error of linear interpolation in PARALLEL 00340 double l1err, l2err, linferr; 00341 geoml1errs.clear(); 00342 geoml2errs.clear(); 00343 geomlinferrs.clear(); 00344 obj->compute_projecterror( 3, elems_owned.size() * nsamples, &( testpnts[0] ), l1err, l2err, linferr ); 00345 geoml1errs.push_back( l1err ); 00346 geoml2errs.push_back( l2err ); 00347 geomlinferrs.push_back( linferr ); 00348 /*Perform high order projection and compute error*/ 00349 // initialize 00350 HiReconstruction hirec( &moab, pc, meshset ); 00351 00352 for( size_t ideg = 0; ideg < degs2fit.size(); ++ideg ) 00353 { 00354 // High order reconstruction 00355 error = hirec.reconstruct3D_surf_geom( degs2fit[ideg], interp, true, true );MB_CHK_ERR( error ); 00356 00357 int index = 0; 00358 // for debug 00359 /*double maxlinferr=0,elemlinferr=0,eleml1err=0,eleml2err; 00360 EntityHandle elem_maxerr;*/ 00361 00362 for( Range::iterator ielem = elems_owned.begin(); ielem != elems_owned.end(); ++ielem, ++index ) 00363 { 00364 // Projection 00365 error = 00366 hirec.hiproj_walf_in_element( *ielem, nvpe, nsamples, &( testnaturalcoords[nvpe * nsamples * index] ), 00367 &( testpnts[3 * nsamples * index] ) );MB_CHK_ERR( error ); 00368 // for debug 00369 /*obj->compute_projecterror(3,nsamples,&(testpnts[3*nsamples*index]),eleml1err,eleml2err,elemlinferr); 00370 if(elemlinferr>maxlinferr){ 00371 maxlinferr = elemlinferr; elem_maxerr = *ielem; 00372 }*/ 00373 } 00374 00375 assert( (size_t)index == elems_owned.size() ); 00376 // Estimate error 00377 obj->compute_projecterror( 3, elems_owned.size() * nsamples, &( testpnts[0] ), l1err, l2err, linferr ); 00378 geoml1errs.push_back( l1err ); 00379 geoml2errs.push_back( l2err ); 00380 geomlinferrs.push_back( linferr ); 00381 00382 // for debug 00383 /*std::cout << "Degree " << degs2fit[ideg] << " has L-inf error " << maxlinferr << " at 00384 element " << elems_owned.index(elem_maxerr) << ":"; std::vector<EntityHandle> conn; error = 00385 mbImpl->get_connectivity(&elem_maxerr,1,conn); MB_CHK_ERR(error); for(size_t 00386 ii=0;ii<conn.size();++ii) std::cout << verts.index(conn[ii]) << " "; std::cout << std::endl; 00387 00388 for(size_t ii=0;ii<conn.size();++ii){ 00389 //assume triangle 00390 std::vector<double> vertexcoords(3,0); 00391 error = mbImpl->get_coords(&(conn[ii]),1,&(vertexcoords[0])); MB_CHK_ERR(error); 00392 std::cout << verts.index(conn[ii]) << ":" << vertexcoords[0] << " "<< vertexcoords[1] << 00393 " "<< vertexcoords[2] << "\n"; GEOMTYPE geomtype; std::vector<double> local_coords_system, 00394 local_coeffs; int deg_out; bool local_interp; bool hasfit = 00395 hirec.get_fittings_data(conn[ii],geomtype,local_coords_system,deg_out,local_coeffs,local_interp); 00396 assert(hasfit); std::cout << "Local fitting result: " << std::endl; std::cout << "Geom Type: 00397 " << geomtype << std::endl; std::cout << "Local coordinates system: " << std::endl; 00398 std::cout << local_coords_system[0] << "\t" << local_coords_system[1] << "\t" << 00399 local_coords_system[2] << std::endl; std::cout << local_coords_system[3] << "\t" << 00400 local_coords_system[4] << "\t" << local_coords_system[5] << std::endl; std::cout << 00401 local_coords_system[6] << "\t" << local_coords_system[7] << "\t" << local_coords_system[8] 00402 << std::endl; std::cout << "Fitting degree is " << deg_out << " interp is " << local_interp 00403 << std::endl; std::cout << "Fitting coefficients are :" << std::endl; for(size_t 00404 kk=0;kk<local_coeffs.size();++kk) std::cout << local_coeffs[kk] << "\t"; std::cout << 00405 std::endl; 00406 }*/ 00407 } 00408 00409 return error; 00410 } 00411 00412 void usage() 00413 { 00414 std::cout << "usage: mpirun -np <number of processors> ./uref_hirec_test_parallel <prefix of " 00415 "files> -str <first number> -end <lastnumber> -suffix <suffix> -interp <0=least " 00416 "square, 1=interpolation> -dim <mesh dimension> -geom <s=sphere,t=torus>" 00417 << std::endl; 00418 } 00419 00420 int main( int argc, char* argv[] ) 00421 { 00422 #ifdef MOAB_HAVE_MPI 00423 MPI_Init( &argc, &argv ); 00424 int nprocs, rank; 00425 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00426 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00427 #endif 00428 std::string prefix, suffix, istr, iend; 00429 int dim = 2, geom = 0; 00430 bool interp = false; 00431 ErrorCode error; 00432 00433 if( argc == 1 ) 00434 { 00435 usage(); 00436 prefix = TestDir + "unittest/sphere_quads_5_ML_"; 00437 suffix = ".h5m"; 00438 istr = "0"; 00439 iend = "1"; 00440 std::cout << "Using defaults: MeshFiles/unittest/sphere_quads_5_ML_*.h5m -str 0 -end 1 " 00441 "-suffix \".h5m\" -interp 0 -dim 2 -geom s" 00442 << std::endl; 00443 } 00444 else 00445 { 00446 prefix = std::string( argv[1] ); 00447 bool hasdim = false; 00448 00449 for( int i = 2; i < argc; ++i ) 00450 { 00451 if( i + 1 != argc ) 00452 { 00453 if( std::string( argv[i] ) == "-suffix" ) 00454 { 00455 suffix = std::string( argv[++i] ); 00456 } 00457 else if( std::string( argv[i] ) == "-str" ) 00458 { 00459 istr = std::string( argv[++i] ); 00460 } 00461 else if( std::string( argv[i] ) == "-end" ) 00462 { 00463 iend = std::string( argv[++i] ); 00464 } 00465 else if( std::string( argv[i] ) == "-interp" ) 00466 { 00467 interp = atoi( argv[++i] ); 00468 } 00469 else if( std::string( argv[i] ) == "-dim" ) 00470 { 00471 dim = atoi( argv[++i] ); 00472 hasdim = true; 00473 } 00474 else if( std::string( argv[i] ) == "-geom" ) 00475 { 00476 geom = std::string( argv[++i] ) == "s" ? 0 : 1; 00477 } 00478 else 00479 { 00480 #ifdef MOAB_HAVE_MPI 00481 00482 if( 0 == rank ) 00483 { 00484 usage(); 00485 } 00486 00487 MPI_Finalize(); 00488 #else 00489 usage(); 00490 #endif 00491 return 0; 00492 } 00493 } 00494 } 00495 00496 if( !hasdim ) 00497 { 00498 #ifdef MOAB_HAVE_MPI 00499 00500 if( 0 == rank ) 00501 { 00502 std::cout << "Dimension of input mesh should be provided, positive and less than 3" << std::endl; 00503 } 00504 00505 #else 00506 std::cout << "Dimension of input mesh should be provided, positive and less than 3" << std::endl; 00507 #endif 00508 return 0; 00509 } 00510 00511 if( dim > 2 || dim <= 0 ) 00512 { 00513 #ifdef MOAB_HAVE_MPI 00514 00515 if( 0 == rank ) 00516 { 00517 std::cout << "Input dimesion should be positive and less than 3;" << std::endl; 00518 } 00519 00520 #else 00521 std::cout << "Input dimesion should be positive and less than 3;" << std::endl; 00522 #endif 00523 return 0; 00524 } 00525 00526 #ifdef MOAB_HAVE_MPI 00527 00528 if( 0 == rank ) 00529 { 00530 std::cout << "Testing on " << prefix + istr + "-" + iend + suffix << " with dimension " << dim << "\n"; 00531 std::string opts = interp ? "interpolation" : "least square fitting"; 00532 std::cout << "High order reconstruction in " << opts << std::endl; 00533 } 00534 00535 #else 00536 std::cout << "Testing on " << prefix + istr + "-" + iend + suffix << " with dimension " << dim << "\n"; 00537 std::string opts = interp ? "interpolation" : "least square fitting"; 00538 std::cout << "High order reconstruction in " << opts << std::endl; 00539 #endif 00540 } 00541 00542 geomObject* obj; 00543 00544 if( geom == 0 ) 00545 { 00546 obj = new sphere(); 00547 } 00548 else 00549 { 00550 obj = new torus(); 00551 } 00552 00553 std::vector< int > degs2fit; 00554 for( int d = 1; d <= 6; ++d ) 00555 { 00556 degs2fit.push_back( d ); 00557 } 00558 00559 int begin = atoi( istr.c_str() ), end = atoi( iend.c_str() ) + 1; 00560 #ifdef MOAB_HAVE_MPI 00561 std::vector< std::vector< double > > geoml1errs_global, geoml2errs_global, geomlinferrs_global; 00562 00563 if( rank == 0 ) 00564 { 00565 geoml1errs_global = 00566 std::vector< std::vector< double > >( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); 00567 geoml2errs_global = 00568 std::vector< std::vector< double > >( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); 00569 geomlinferrs_global = 00570 std::vector< std::vector< double > >( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); 00571 } 00572 00573 #else 00574 std::vector< std::vector< double > > geoml1errs_global( 1 + degs2fit.size(), 00575 std::vector< double >( end - begin, 0 ) ); 00576 std::vector< std::vector< double > > geoml2errs_global( 1 + degs2fit.size(), 00577 std::vector< double >( end - begin, 0 ) ); 00578 std::vector< std::vector< double > > geomlinferrs_global( 1 + degs2fit.size(), 00579 std::vector< double >( end - begin, 0 ) ); 00580 #endif 00581 00582 for( int i = begin; i < end; ++i ) 00583 { 00584 std::ostringstream convert; 00585 convert << i; 00586 std::string infile = prefix + convert.str() + suffix; 00587 int ntestverts; 00588 std::vector< double > geoml1errs, geoml2errs, geomlinferrs; 00589 00590 #ifdef MOAB_HAVE_MPI 00591 std::cout << "Processor " << rank << " is working on file " << infile << std::endl; 00592 #endif 00593 error = closedsurface_uref_hirec_convergence_study( infile.c_str(), degs2fit, interp, dim, obj, ntestverts, 00594 geoml1errs, geoml2errs, geomlinferrs );MB_CHK_ERR( error ); 00595 assert( geoml1errs.size() == 1 + degs2fit.size() && geoml2errs.size() == 1 + degs2fit.size() && 00596 geomlinferrs.size() == 1 + degs2fit.size() ); 00597 #ifdef MOAB_HAVE_MPI 00598 00599 if( nprocs > 1 ) 00600 { 00601 int ntestverts_global = 0; 00602 MPI_Reduce( &ntestverts, &ntestverts_global, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); 00603 00604 for( size_t d = 0; d < degs2fit.size() + 1; ++d ) 00605 { 00606 double local_l1err = ntestverts * geoml1errs[d], 00607 local_l2err = geoml2errs[d] * ( geoml2errs[d] * ntestverts ), local_linferr = geomlinferrs[d]; 00608 std::cout << "On Processor " << rank << " with mesh " << i 00609 << " Degree = " << ( d == 0 ? 0 : degs2fit[d - 1] ) << " L1:" << geoml1errs[d] 00610 << " L2:" << geoml2errs[d] << " Li:" << geomlinferrs[d] << std::endl; 00611 double global_l1err = 0, global_l2err = 0, global_linferr = 0; 00612 MPI_Reduce( &local_l1err, &global_l1err, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); 00613 MPI_Reduce( &local_l2err, &global_l2err, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); 00614 MPI_Reduce( &local_linferr, &global_linferr, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); 00615 00616 if( rank == 0 ) 00617 { 00618 geoml1errs_global[d][i - begin] = global_l1err / ntestverts_global; 00619 geoml2errs_global[d][i - begin] = sqrt( global_l2err / ntestverts_global ); 00620 geomlinferrs_global[d][i - begin] = global_linferr; 00621 } 00622 } 00623 } 00624 else 00625 { 00626 for( size_t d = 0; d < degs2fit.size() + 1; ++d ) 00627 { 00628 geoml1errs_global[d][i - begin] = geoml1errs[d]; 00629 geoml2errs_global[d][i - begin] = geoml2errs[d]; 00630 geomlinferrs_global[d][i - begin] = geomlinferrs[d]; 00631 } 00632 } 00633 00634 #else 00635 00636 for( size_t d = 0; d < degs2fit.size() + 1; ++d ) 00637 { 00638 geoml1errs_global[d][i - begin] = geoml1errs[d]; 00639 geoml2errs_global[d][i - begin] = geoml2errs[d]; 00640 geomlinferrs_global[d][i - begin] = geomlinferrs[d]; 00641 } 00642 00643 #endif 00644 } 00645 00646 #ifdef MOAB_HAVE_MPI 00647 00648 if( rank == 0 ) 00649 { 00650 std::cout << "Degrees: 0 "; 00651 00652 for( size_t ideg = 0; ideg < degs2fit.size(); ++ideg ) 00653 { 00654 std::cout << degs2fit[ideg] << " "; 00655 } 00656 00657 std::cout << std::endl; 00658 std::cout << "L1-norm error: \n"; 00659 00660 for( size_t i = 0; i < geoml1errs_global.size(); ++i ) 00661 { 00662 for( size_t j = 0; j < geoml1errs_global[i].size(); ++j ) 00663 { 00664 std::cout << geoml1errs_global[i][j] << " "; 00665 } 00666 00667 std::cout << std::endl; 00668 } 00669 00670 std::cout << "L2-norm error: \n"; 00671 00672 for( size_t i = 0; i < geoml2errs_global.size(); ++i ) 00673 { 00674 for( size_t j = 0; j < geoml2errs_global[i].size(); ++j ) 00675 { 00676 std::cout << geoml2errs_global[i][j] << " "; 00677 } 00678 00679 std::cout << std::endl; 00680 } 00681 00682 std::cout << "Linf-norm error: \n"; 00683 00684 for( size_t i = 0; i < geomlinferrs_global.size(); ++i ) 00685 { 00686 for( size_t j = 0; j < geomlinferrs_global[i].size(); ++j ) 00687 { 00688 std::cout << geomlinferrs_global[i][j] << " "; 00689 } 00690 00691 std::cout << std::endl; 00692 } 00693 } 00694 00695 #else 00696 std::cout << "Degrees: 0 "; 00697 00698 for( size_t ideg = 0; ideg < degs2fit.size(); ++ideg ) 00699 { 00700 std::cout << degs2fit[ideg] << " "; 00701 } 00702 00703 std::cout << std::endl; 00704 std::cout << "L1-norm error: \n"; 00705 00706 for( size_t i = 0; i < geoml1errs_global.size(); ++i ) 00707 { 00708 for( size_t j = 0; j < geoml1errs_global[i].size(); ++j ) 00709 { 00710 std::cout << geoml1errs_global[i][j] << " "; 00711 } 00712 00713 std::cout << std::endl; 00714 } 00715 00716 std::cout << "L2-norm error: \n"; 00717 00718 for( size_t i = 0; i < geoml2errs_global.size(); ++i ) 00719 { 00720 for( size_t j = 0; j < geoml2errs_global[i].size(); ++j ) 00721 { 00722 std::cout << geoml2errs_global[i][j] << " "; 00723 } 00724 00725 std::cout << std::endl; 00726 } 00727 00728 std::cout << "Linf-norm error: \n"; 00729 00730 for( size_t i = 0; i < geomlinferrs_global.size(); ++i ) 00731 { 00732 for( size_t j = 0; j < geomlinferrs_global[i].size(); ++j ) 00733 { 00734 std::cout << geomlinferrs_global[i][j] << " "; 00735 } 00736 00737 std::cout << std::endl; 00738 } 00739 00740 #endif 00741 #ifdef MOAB_HAVE_MPI 00742 MPI_Finalize(); 00743 #endif 00744 }
