MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 // tests dual construction code 00002 00003 #include "moab/Core.hpp" 00004 #include "moab/Range.hpp" 00005 #include "moab/MeshTopoUtil.hpp" 00006 #include "moab/DualTool.hpp" 00007 #include "../TestUtil.hpp" 00008 #include <iostream> 00009 #include <string> 00010 00011 using namespace moab; 00012 00013 std::string default_input = TestDir + "unittest/hex01.vtk"; 00014 const char default_output[] = "dual.vtk"; 00015 00016 Interface* gMB; 00017 00018 int main( int argc, char* argv[] ) 00019 { 00020 const char* f1 = default_input.c_str(); 00021 const char* f2 = default_output; 00022 if( argc <= 2 ) 00023 { 00024 std::cout << "Usage: dual_test <mesh_file_name> <out file>" << std::endl; 00025 std::cout << "using default input : " << default_input << " and output " << default_output << "\n"; 00026 } 00027 else 00028 { 00029 f1 = argv[1]; 00030 f2 = argv[2]; 00031 } 00032 00033 gMB = new Core(); 00034 00035 // read the mesh file 00036 ErrorCode result = gMB->load_mesh( f1 ); 00037 if( MB_SUCCESS != result ) 00038 { 00039 std::cout << "Problems reading file " << argv[1] << "." << std::endl; 00040 delete gMB; 00041 return 1; 00042 } 00043 00044 // make sure aentities are created 00045 Range all_verts; 00046 result = gMB->get_entities_by_dimension( 0, 0, all_verts ); 00047 if( MB_SUCCESS != result ) std::cout << "Problem getting vertices." << std::endl; 00048 00049 MeshTopoUtil( gMB ).construct_aentities( all_verts ); 00050 00051 // get counts before constructing dual 00052 int num_edges; 00053 result = gMB->get_number_entities_by_dimension( 0, 1, num_edges ); 00054 if( MB_SUCCESS != result ) std::cout << "Problem getting number of edges." << std::endl; 00055 00056 // see if it's all-hex or all-quad, and construct hex/quad dual if so 00057 int num_hex, num_quad, num_3d, num_2d; 00058 result = gMB->get_number_entities_by_dimension( 0, 2, num_2d ); 00059 if( MB_SUCCESS != result ) return 0; 00060 result = gMB->get_number_entities_by_dimension( 0, 3, num_3d ); 00061 if( MB_SUCCESS != result ) return 0; 00062 result = gMB->get_number_entities_by_type( 0, MBQUAD, num_quad ); 00063 if( MB_SUCCESS != result ) return 0; 00064 result = gMB->get_number_entities_by_type( 0, MBHEX, num_hex ); 00065 if( MB_SUCCESS != result ) return 0; 00066 00067 // construct the dual for this mesh 00068 DualTool dt( gMB ); 00069 if( num_quad == num_2d && num_hex == num_3d ) 00070 result = dt.construct_hex_dual( 0, 0 ); 00071 else 00072 result = dt.construct_dual( 0, 0 ); 00073 if( MB_SUCCESS != result ) 00074 { 00075 std::cout << "Problems constructing dual." << std::endl; 00076 return 0; 00077 } 00078 00079 // print information about the dual 00080 Range dual_cells, dual_faces; 00081 result = dt.get_dual_entities( 0, 0, 2, dual_faces ); 00082 if( MB_SUCCESS != result ) 00083 std::cout << "Problem getting dual faces." << std::endl; 00084 else 00085 std::cout << "Found " << dual_faces.size() << "/" << num_edges << " dual faces." << std::endl; 00086 00087 result = dt.get_dual_entities( 0, 0, 3, dual_cells ); 00088 if( MB_SUCCESS != result ) 00089 std::cout << "Problem getting dual cells." << std::endl; 00090 else 00091 std::cout << "Found " << dual_cells.size() << "/" << all_verts.size() << " dual cells." << std::endl; 00092 00093 // print information about dual hyperplanes, if any 00094 Tag hp_tag; 00095 Range hp_sets; 00096 if( num_2d == num_quad ) 00097 { 00098 // get sets with the right tag 00099 result = gMB->tag_get_handle( DualTool::DUAL_CURVE_TAG_NAME, 1, MB_TYPE_HANDLE, hp_tag ); 00100 if( MB_SUCCESS == result ) 00101 { 00102 result = gMB->get_entities_by_type_and_tag( 0, MBENTITYSET, &hp_tag, NULL, 1, hp_sets ); 00103 if( MB_SUCCESS == result && !hp_sets.empty() ) 00104 std::cout << "Found " << hp_sets.size() << " 1d dual hyperplanes (chords)." << std::endl; 00105 } 00106 } 00107 00108 if( num_3d == num_hex ) 00109 { 00110 // get sets with the right tag 00111 result = gMB->tag_get_handle( DualTool::DUAL_SURFACE_TAG_NAME, 1, MB_TYPE_HANDLE, hp_tag ); 00112 if( MB_SUCCESS == result ) 00113 { 00114 hp_sets.clear(); 00115 result = gMB->get_entities_by_type_and_tag( 0, MBENTITYSET, &hp_tag, NULL, 1, hp_sets ); 00116 if( MB_SUCCESS == result && !hp_sets.empty() ) 00117 std::cout << "Found " << hp_sets.size() << " 2d dual hyperplanes (sheets)." << std::endl; 00118 } 00119 } 00120 00121 // write GMV file 00122 gMB->write_file( f2 ); 00123 delete gMB; 00124 00125 return 0; 00126 }
