MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef PARALLELMERGEMESH_HPP 00002 #define PARALLELMERGEMESH_HPP 00003 00004 #include "moab/Types.hpp" 00005 #include <vector> 00006 #include "moab/Range.hpp" 00007 #include "moab/ParallelComm.hpp" 00008 00009 #include "moab/TupleList.hpp" 00010 #include "moab/gs.hpp" 00011 00012 /* 00013 Class to merge meshes in parallel 00014 Requires a ParallelComm and tolerance epsilon 00015 Currently uses a 1 dimensional partition of the global box 00016 */ 00017 00018 namespace moab 00019 { 00020 00021 class ParallelComm; 00022 class TupleList; 00023 00024 class ParallelMergeMesh 00025 { 00026 public: 00027 ParallelMergeMesh( ParallelComm* pc, const double epsilon ); 00028 00029 // Public Function to identify shared elements 00030 ErrorCode merge( EntityHandle levelset = 0, bool skip_local_merge = false, int dim = -1 ); 00031 00032 private: 00033 ParallelComm* myPcomm; 00034 Interface* myMB; 00035 std::vector< Range > mySkinEnts; 00036 double myEps; 00037 TupleList myTup, myMatches; 00038 gs_data::crystal_data myCD; 00039 00040 // Wrapper of merge() that performs the merge 00041 ErrorCode PerformMerge( EntityHandle levelset = 0, bool skip_local_merge = false, int dim = -1 ); 00042 // Determine the local skin entities (fills mySkinEnts) 00043 ErrorCode PopulateMySkinEnts( const EntityHandle meshset, int dim, bool skip_local_merge = false ); 00044 // Get the global bounding box 00045 ErrorCode GetGlobalBox( double* gbox ); 00046 // Fill out the local myTup before the first gather-scatter 00047 ErrorCode PopulateMyTup( double* gbox ); 00048 // Once myTup is filled and gather scattered, figure out the matches 00049 ErrorCode PopulateMyMatches(); 00050 // Sort the matching tuples 00051 ErrorCode SortMyMatches(); 00052 // Tag the shared elements once the myMatches has been filled 00053 ErrorCode TagSharedElements( int dim ); 00054 // Cleanup any data allocated by class members 00055 void CleanUp(); 00056 // Partition the global box by the number of procs 00057 // Returns results in lengths and parts, which needs to be of length 3 00058 ErrorCode PartitionGlobalBox( double* gbox, double* lengths, int* parts ); 00059 // A function for determining how many parts a side should be split into 00060 static int PartitionSide( double sideLeng, double restLen, unsigned numProcs, bool altRatio ); 00061 00062 // Swap 2 tuples 00063 static void SwapTuples( TupleList& tup, unsigned long a, unsigned long b ); 00064 00065 // Sort a tuple list by its real values 00066 static void SortTuplesByReal( TupleList& tup, double eps2 = 0 ); 00067 00068 // The recursive sorting function 00069 static void PerformRealSort( TupleList& tup, unsigned long left, unsigned long right, double eps2, uint tup_mr ); 00070 00071 // Determines whether tuple i is greater than tuple j 00072 static bool TupleGreaterThan( TupleList& tup, unsigned long vrI, unsigned long vrJ, double eps2, uint tup_mr ); 00073 }; 00074 00075 } // namespace moab 00076 00077 #endif
