MOAB: Mesh Oriented datABase
(version 5.4.1)
Functions | |
| void | get_signs_for_node_local_coord_hex (int node_id, double &sign_y1, double &sign_y2, double &sign_y3) |
| void | initialize (int n=2, int m=4, int dim=2, int tri=0) |
| void | get_gauss_pts_and_weight () |
| void | get_tri_rule_pts_and_weight () |
| void | calculate_shape_function_2d_tri () |
| void | calculate_shape_function_2d_quad () |
| void | get_shape_func (double shape_function[], double dndy1_at_gauss_pts[], double dndy2_at_gauss_ptsp[], double gauss_weight[]) |
| void | get_shape_func (double shape_function[], double dndy1_at_gauss_pts[], double dndy2_at_gauss_pts[], double dndy3_at_gauss_pts[], double gauss_weight[]) |
| void | calculate_derivative_at_nodes (double dndy1_at_nodes[][maxNumberNodes], double dndy2_at_nodes[][maxNumberNodes]) |
| void | calculate_shape_function_3d_hex () |
| void | calculate_derivative_at_nodes_3d (double dndy1_at_nodes[][maxNumberNodes], double dndy2_at_nodes[][maxNumberNodes], double dndy3_at_nodes[][maxNumberNodes]) |
| void | calculate_derivative_at_nodes_2d_tri (double dndy1_at_nodes[][maxNumberNodes], double dndy2_at_nodes[][maxNumberNodes]) |
| void | calculate_shape_function_3d_tet () |
| void | get_tet_rule_pts_and_weight () |
| void | calculate_derivative_at_nodes_3d_tet (double dndy1_at_nodes[][maxNumberNodes], double dndy2_at_nodes[][maxNumberNodes], double dndy3_at_nodes[][maxNumberNodes]) |
| void | get_node_local_coord_tet (int node_id, double &y1, double &y2, double &y3, double &y4) |
| void GaussIntegration::calculate_derivative_at_nodes | ( | double | dndy1_at_nodes[][maxNumberNodes], |
| double | dndy2_at_nodes[][maxNumberNodes] | ||
Definition at line 340 of file V_GaussIntegration.cpp.
References numberNodes.
Referenced by v_quad_distortion().
double y1 = 0., y2 = 0.;
int i;
for( i = 0; i < numberNodes; i++ )
switch( i )
case 0:
y1 = -1.;
y2 = -1.;
break;
case 1:
y1 = 1.;
y2 = -1.;
break;
case 2:
y1 = 1.;
y2 = 1.;
break;
case 3:
y1 = -1.;
y2 = 1.;
break;
// midside nodes if there is any
case 4:
y1 = 0.;
y2 = -1.;
break;
case 5:
y1 = 1.;
y2 = 0.;
break;
case 6:
y1 = 0.;
y2 = 1.;
break;
case 7:
y1 = -1.;
y2 = 0.;
break;
switch( numberNodes )
case 4:
// dn_i/dy1 evaluated at node i
dndy1_at_nodes[i][0] = -0.25 * ( 1 - y2 );
dndy1_at_nodes[i][1] = 0.25 * ( 1 - y2 );
dndy1_at_nodes[i][2] = 0.25 * ( 1 + y2 );
dndy1_at_nodes[i][3] = -0.25 * ( 1 + y2 );
// dn_i/dy2 evaluated at node i
dndy2_at_nodes[i][0] = -0.25 * ( 1 - y1 );
dndy2_at_nodes[i][1] = -0.25 * ( 1 + y1 );
dndy2_at_nodes[i][2] = 0.25 * ( 1 + y1 );
dndy2_at_nodes[i][3] = 0.25 * ( 1 - y1 );
break;
case 8:
dndy1_at_nodes[i][0] = 0.25 * ( 1 - y2 ) * ( 2.0 * y1 + y2 );
dndy1_at_nodes[i][1] = 0.25 * ( 1 - y2 ) * ( 2.0 * y1 - y2 );
dndy1_at_nodes[i][2] = 0.25 * ( 1 + y2 ) * ( 2.0 * y1 + y2 );
dndy1_at_nodes[i][3] = 0.25 * ( 1 + y2 ) * ( 2.0 * y1 - y2 );
dndy1_at_nodes[i][4] = -y1 * ( 1 - y2 );
dndy1_at_nodes[i][5] = 0.5 * ( 1 - y2 * y2 );
dndy1_at_nodes[i][6] = -y1 * ( 1 + y2 );
dndy1_at_nodes[i][7] = -0.5 * ( 1 - y2 * y2 );
dndy2_at_nodes[i][0] = 0.25 * ( 1 - y1 ) * ( 2.0 * y2 + y1 );
dndy2_at_nodes[i][1] = 0.25 * ( 1 + y1 ) * ( 2.0 * y2 - y1 );
dndy2_at_nodes[i][2] = 0.25 * ( 1 + y1 ) * ( 2.0 * y2 + y1 );
dndy2_at_nodes[i][3] = 0.25 * ( 1 - y1 ) * ( 2.0 * y2 - y1 );
dndy2_at_nodes[i][4] = -0.5 * ( 1 - y1 * y1 );
dndy2_at_nodes[i][5] = -y2 * ( 1 + y1 );
dndy2_at_nodes[i][6] = 0.5 * ( 1 - y1 * y1 );
dndy2_at_nodes[i][7] = -y2 * ( 1 - y1 );
break;
| void GaussIntegration::calculate_derivative_at_nodes_2d_tri | ( | double | dndy1_at_nodes[][maxNumberNodes], |
Definition at line 706 of file V_GaussIntegration.cpp.
Referenced by v_tri_distortion().
double y1 = 0., y2 = 0., y3;
int i;
switch( i )
case 0:
y1 = 1.;
y2 = 0.;
break;
case 1:
y1 = 0.;
y2 = 1.;
break;
case 2:
y1 = 0.;
y2 = 0.;
break;
case 3:
y1 = 0.5;
y2 = 0.5;
break;
case 4:
y1 = 0.;
y2 = 0.5;
break;
case 5:
y1 = 0.5;
y2 = 0.0;
break;
y3 = 1. - y1 - y2;
dndy1_at_nodes[i][0] = 4 * y1 - 1.;
dndy1_at_nodes[i][1] = 0;
dndy1_at_nodes[i][2] = 1 - 4. * y3;
dndy1_at_nodes[i][3] = 4. * y2;
dndy1_at_nodes[i][4] = -4. * y2;
dndy1_at_nodes[i][5] = 4. * ( 1 - 2 * y1 - y2 );
dndy2_at_nodes[i][0] = 0.0;
dndy2_at_nodes[i][1] = 4. * y2 - 1.;
dndy2_at_nodes[i][2] = 1 - 4. * y3;
dndy2_at_nodes[i][3] = 4. * y1;
dndy2_at_nodes[i][4] = 4. * ( 1 - y1 - 2. * y2 );
dndy2_at_nodes[i][5] = -4. * y1;
| void GaussIntegration::calculate_derivative_at_nodes_3d | ( | double | dndy1_at_nodes[][maxNumberNodes], |
| double | dndy2_at_nodes[][maxNumberNodes], | ||
| double | dndy3_at_nodes[][maxNumberNodes] | ||
Definition at line 431 of file V_GaussIntegration.cpp.
References get_signs_for_node_local_coord_hex(), and numberNodes.
Referenced by v_hex_distortion().
double y1, y2, y3, sign_node_y1, sign_node_y2, sign_node_y3;
double y1_term, y2_term, y3_term, y123_temp;
int node_id, node_id_2;
for( node_id = 0; node_id < numberNodes; node_id++ )
get_signs_for_node_local_coord_hex( node_id, y1, y2, y3 );
case 8:
for( node_id_2 = 0; node_id_2 < numberNodes; node_id_2++ )
get_signs_for_node_local_coord_hex( node_id_2, sign_node_y1, sign_node_y2, sign_node_y3 );
y1_term = 1 + sign_node_y1 * y1;
y2_term = 1 + sign_node_y2 * y2;
y3_term = 1 + sign_node_y3 * y3;
dndy1_at_nodes[node_id][node_id_2] = 0.125 * sign_node_y1 * y2_term * y3_term;
dndy2_at_nodes[node_id][node_id_2] = 0.125 * sign_node_y2 * y1_term * y3_term;
dndy3_at_nodes[node_id][node_id_2] = 0.125 * sign_node_y3 * y1_term * y2_term;
break;
case 20:
y123_temp = sign_node_y1 * y1 + sign_node_y2 * y2 + sign_node_y3 * y3 - 2.;
switch( node_id_2 )
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7: {
dndy1_at_nodes[node_id][node_id_2] = 0.125 * sign_node_y1 * y2_term * y3_term * y123_temp +
0.125 * y1_term * y2_term * y3_term * sign_node_y1;
dndy2_at_nodes[node_id][node_id_2] = 0.125 * sign_node_y2 * y1_term * y3_term * y123_temp +
0.125 * y1_term * y2_term * y3_term * sign_node_y2;
dndy3_at_nodes[node_id][node_id_2] = 0.125 * sign_node_y3 * y1_term * y2_term * y123_temp +
0.125 * y1_term * y2_term * y3_term * sign_node_y3;
break;
case 8:
case 10:
case 16:
case 18: {
dndy1_at_nodes[node_id][node_id_2] = -0.5 * y1 * y2_term * y3_term;
dndy2_at_nodes[node_id][node_id_2] = 0.25 * ( 1 - y1 * y1 ) * sign_node_y2 * y3_term;
dndy3_at_nodes[node_id][node_id_2] = 0.25 * ( 1 - y1 * y1 ) * y2_term * sign_node_y3;
break;
case 9:
case 11:
case 17:
case 19: {
dndy1_at_nodes[node_id][node_id_2] = 0.25 * ( 1 - y2 * y2 ) * sign_node_y1 * y3_term;
dndy2_at_nodes[node_id][node_id_2] = -0.5 * y2 * y1_term * y3_term;
dndy3_at_nodes[node_id][node_id_2] = 0.25 * ( 1 - y2 * y2 ) * y1_term * sign_node_y3;
break;
case 12:
case 13:
case 14:
case 15: {
dndy1_at_nodes[node_id][node_id_2] = 0.25 * ( 1 - y3 * y3 ) * sign_node_y1 * y2_term;
dndy2_at_nodes[node_id][node_id_2] = 0.25 * ( 1 - y3 * y3 ) * y1_term * sign_node_y2;
dndy3_at_nodes[node_id][node_id_2] = -0.5 * y3 * y1_term * y2_term;
break;
break;
| void GaussIntegration::calculate_derivative_at_nodes_3d_tet | ( | double | dndy1_at_nodes[][maxNumberNodes], |
Definition at line 915 of file V_GaussIntegration.cpp.
References get_node_local_coord_tet(), and numberNodes.
Referenced by v_tet_distortion().
double y1, y2, y3, y4;
int i;
case 10: {
get_node_local_coord_tet( i, y1, y2, y3, y4 );
dndy1_at_nodes[i][0] = 1 - 4 * y4;
dndy1_at_nodes[i][1] = 4 * y1 - 1.;
dndy1_at_nodes[i][2] = 0;
dndy1_at_nodes[i][3] = 0;
dndy1_at_nodes[i][4] = 4. * ( y4 - y1 );
dndy1_at_nodes[i][5] = 4. * y2;
dndy1_at_nodes[i][6] = -4. * y2;
dndy1_at_nodes[i][7] = -4. * y3;
dndy1_at_nodes[i][8] = 4. * y3;
dndy1_at_nodes[i][9] = 0;
dndy2_at_nodes[i][0] = 1 - 4 * y4;
dndy2_at_nodes[i][1] = 0;
dndy2_at_nodes[i][2] = 4. * y2 - 1.;
dndy2_at_nodes[i][3] = 0;
dndy2_at_nodes[i][4] = -4. * y1;
dndy2_at_nodes[i][5] = 4. * y1;
dndy2_at_nodes[i][6] = 4. * ( y4 - y2 );
dndy2_at_nodes[i][7] = -4. * y3;
dndy2_at_nodes[i][8] = 0.;
dndy2_at_nodes[i][9] = 4. * y3;
dndy3_at_nodes[i][0] = 1 - 4 * y4;
dndy3_at_nodes[i][1] = 0;
dndy3_at_nodes[i][2] = 0;
dndy3_at_nodes[i][3] = 4. * y3 - 1.;
dndy3_at_nodes[i][4] = -4. * y1;
dndy3_at_nodes[i][5] = 0;
dndy3_at_nodes[i][6] = -4. * y2;
dndy3_at_nodes[i][7] = 4. * ( y4 - y3 );
dndy3_at_nodes[i][8] = 4. * y1;
dndy3_at_nodes[i][9] = 4. * y2;
break;
case 4: {
dndy1_at_nodes[i][0] = -1.;
dndy1_at_nodes[i][1] = 1;
dndy2_at_nodes[i][0] = -1.;
dndy2_at_nodes[i][2] = 1;
dndy3_at_nodes[i][0] = -1.;
dndy3_at_nodes[i][3] = 1;
break;
Definition at line 141 of file V_GaussIntegration.cpp.
References get_gauss_pts_and_weight(), and numberGaussPoints.
int ife = 0, i, j;
double y1, y2;
get_gauss_pts_and_weight();
case 4:
for( i = 0; i < numberGaussPoints; i++ )
for( j = 0; j < numberGaussPoints; j++ )
y1 = gaussPointY[i];
y2 = gaussPointY[j];
shapeFunction[ife][0] = 0.25 * ( 1 - y1 ) * ( 1 - y2 );
shapeFunction[ife][1] = 0.25 * ( 1 + y1 ) * ( 1 - y2 );
shapeFunction[ife][2] = 0.25 * ( 1 + y1 ) * ( 1 + y2 );
shapeFunction[ife][3] = 0.25 * ( 1 - y1 ) * ( 1 + y2 );
dndy1GaussPts[ife][0] = -0.25 * ( 1 - y2 );
dndy1GaussPts[ife][1] = 0.25 * ( 1 - y2 );
dndy1GaussPts[ife][2] = 0.25 * ( 1 + y2 );
dndy1GaussPts[ife][3] = -0.25 * ( 1 + y2 );
dndy2GaussPts[ife][0] = -0.25 * ( 1 - y1 );
dndy2GaussPts[ife][1] = -0.25 * ( 1 + y1 );
dndy2GaussPts[ife][2] = 0.25 * ( 1 + y1 );
dndy2GaussPts[ife][3] = 0.25 * ( 1 - y1 );
totalGaussWeight[ife] = gaussWeight[i] * gaussWeight[j];
ife++;
break;
case 8:
shapeFunction[ife][0] = 0.25 * ( 1 - y1 ) * ( 1 - y2 ) * ( -y1 - y2 - 1 );
shapeFunction[ife][1] = 0.25 * ( 1 + y1 ) * ( 1 - y2 ) * ( y1 - y2 - 1 );
shapeFunction[ife][2] = 0.25 * ( 1 + y1 ) * ( 1 + y2 ) * ( y1 + y2 - 1 );
shapeFunction[ife][3] = 0.25 * ( 1 - y1 ) * ( 1 + y2 ) * ( -y1 + y2 - 1 );
shapeFunction[ife][4] = 0.5 * ( 1 - y1 * y1 ) * ( 1 - y2 );
shapeFunction[ife][5] = 0.5 * ( 1 - y2 * y2 ) * ( 1 + y1 );
shapeFunction[ife][6] = 0.5 * ( 1 - y1 * y1 ) * ( 1 + y2 );
shapeFunction[ife][7] = 0.5 * ( 1 - y2 * y2 ) * ( 1 - y1 );
dndy1GaussPts[ife][0] = 0.25 * ( 1 - y2 ) * ( 2.0 * y1 + y2 );
dndy1GaussPts[ife][1] = 0.25 * ( 1 - y2 ) * ( 2.0 * y1 - y2 );
dndy1GaussPts[ife][2] = 0.25 * ( 1 + y2 ) * ( 2.0 * y1 + y2 );
dndy1GaussPts[ife][3] = 0.25 * ( 1 + y2 ) * ( 2.0 * y1 - y2 );
dndy1GaussPts[ife][4] = -y1 * ( 1 - y2 );
dndy1GaussPts[ife][5] = 0.5 * ( 1 - y2 * y2 );
dndy1GaussPts[ife][6] = -y1 * ( 1 + y2 );
dndy1GaussPts[ife][7] = -0.5 * ( 1 - y2 * y2 );
dndy2GaussPts[ife][0] = 0.25 * ( 1 - y1 ) * ( 2.0 * y2 + y1 );
dndy2GaussPts[ife][1] = 0.25 * ( 1 + y1 ) * ( 2.0 * y2 - y1 );
dndy2GaussPts[ife][2] = 0.25 * ( 1 + y1 ) * ( 2.0 * y2 + y1 );
dndy2GaussPts[ife][3] = 0.25 * ( 1 - y1 ) * ( 2.0 * y2 - y1 );
dndy2GaussPts[ife][4] = -0.5 * ( 1 - y1 * y1 );
dndy2GaussPts[ife][5] = -y2 * ( 1 + y1 );
dndy2GaussPts[ife][6] = 0.5 * ( 1 - y1 * y1 );
dndy2GaussPts[ife][7] = -y2 * ( 1 - y1 );
ife++;
break;
Definition at line 668 of file V_GaussIntegration.cpp.
References get_tri_rule_pts_and_weight(), and totalNumberGaussPts.
int ife;
double y1, y2, y3;
get_tri_rule_pts_and_weight();
for( ife = 0; ife < totalNumberGaussPts; ife++ )
y1 = y1Area[ife];
y2 = y2Area[ife];
y3 = 1.0 - y1 - y2;
shapeFunction[ife][0] = y1 * ( 2. * y1 - 1. );
shapeFunction[ife][1] = y2 * ( 2. * y2 - 1. );
shapeFunction[ife][2] = y3 * ( 2. * y3 - 1. );
shapeFunction[ife][3] = 4. * y1 * y2;
shapeFunction[ife][4] = 4. * y2 * y3;
shapeFunction[ife][5] = 4. * y1 * y3;
dndy1GaussPts[ife][0] = 4 * y1 - 1.;
dndy1GaussPts[ife][1] = 0;
dndy1GaussPts[ife][2] = 1 - 4. * y3;
dndy1GaussPts[ife][3] = 4. * y2;
dndy1GaussPts[ife][4] = -4. * y2;
dndy1GaussPts[ife][5] = 4. * ( 1 - 2 * y1 - y2 );
dndy2GaussPts[ife][0] = 0.0;
dndy2GaussPts[ife][1] = 4. * y2 - 1.;
dndy2GaussPts[ife][2] = 1 - 4. * y3;
dndy2GaussPts[ife][3] = 4. * y1;
dndy2GaussPts[ife][4] = 4. * ( 1 - y1 - 2. * y2 );
dndy2GaussPts[ife][5] = -4. * y1;
Definition at line 220 of file V_GaussIntegration.cpp.
References get_gauss_pts_and_weight(), get_signs_for_node_local_coord_hex(), numberGaussPoints, and numberNodes.
int ife = 0, i, j, k, node_id;
case 8:
for( k = 0; k < numberGaussPoints; k++ )
y3 = gaussPointY[k];
get_signs_for_node_local_coord_hex( node_id, sign_node_y1, sign_node_y2, sign_node_y3 );
shapeFunction[ife][node_id] = 0.125 * y1_term * y2_term * y3_term;
dndy1GaussPts[ife][node_id] = 0.125 * sign_node_y1 * y2_term * y3_term;
dndy2GaussPts[ife][node_id] = 0.125 * sign_node_y2 * y1_term * y3_term;
dndy3GaussPts[ife][node_id] = 0.125 * sign_node_y3 * y1_term * y2_term;
totalGaussWeight[ife] = gaussWeight[i] * gaussWeight[j] * gaussWeight[k];
ife++;
break;
case 20:
switch( node_id )
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7: {
shapeFunction[ife][node_id] = 0.125 * y1_term * y2_term * y3_term * y123_temp;
dndy1GaussPts[ife][node_id] = 0.125 * sign_node_y1 * y123_temp * y2_term * y3_term +
dndy2GaussPts[ife][node_id] = 0.125 * sign_node_y2 * y1_term * y3_term * y123_temp +
dndy3GaussPts[ife][node_id] = 0.125 * sign_node_y3 * y1_term * y2_term * y123_temp +
break;
case 8:
case 10:
case 16:
case 18: {
shapeFunction[ife][node_id] = 0.25 * ( 1 - y1 * y1 ) * y2_term * y3_term;
dndy1GaussPts[ife][node_id] = -0.5 * y1 * y2_term * y3_term;
dndy2GaussPts[ife][node_id] = 0.25 * ( 1 - y1 * y1 ) * sign_node_y2 * y3_term;
dndy3GaussPts[ife][node_id] = 0.25 * ( 1 - y1 * y1 ) * y2_term * sign_node_y3;
break;
case 9:
case 11:
case 17:
case 19: {
shapeFunction[ife][node_id] = 0.25 * ( 1 - y2 * y2 ) * y1_term * y3_term;
dndy1GaussPts[ife][node_id] = 0.25 * ( 1 - y2 * y2 ) * sign_node_y1 * y3_term;
dndy2GaussPts[ife][node_id] = -0.5 * y2 * y1_term * y3_term;
dndy3GaussPts[ife][node_id] = 0.25 * ( 1 - y2 * y2 ) * y1_term * sign_node_y3;
break;
case 12:
case 13:
case 14:
case 15: {
shapeFunction[ife][node_id] = 0.25 * ( 1 - y3 * y3 ) * y1_term * y2_term;
dndy1GaussPts[ife][node_id] = 0.25 * ( 1 - y3 * y3 ) * sign_node_y1 * y2_term;
dndy2GaussPts[ife][node_id] = 0.25 * ( 1 - y3 * y3 ) * y1_term * sign_node_y2;
dndy3GaussPts[ife][node_id] = -0.5 * y3 * y1_term * y2_term;
break;
ife++;
break;
Definition at line 809 of file V_GaussIntegration.cpp.
References get_tet_rule_pts_and_weight(), and totalNumberGaussPts.
int ife;
get_tet_rule_pts_and_weight();
case 10: // 10 nodes quadratic tet
// y1,y2,y3,y4 are the volume coordinates
y1 = y1Volume[ife];
y2 = y2Volume[ife];
y3 = y3Volume[ife];
y4 = y4Volume[ife];
// shape function is the same as in ABAQUS
// it is different from that in all the FEA book
// in which node is the first node
// here at node 1 y4=1
shapeFunction[ife][0] = y4 * ( 2. * y4 - 1. );
shapeFunction[ife][1] = y1 * ( 2. * y1 - 1. );
shapeFunction[ife][2] = y2 * ( 2. * y2 - 1. );
shapeFunction[ife][3] = y3 * ( 2. * y3 - 1. );
shapeFunction[ife][4] = 4. * y1 * y4;
shapeFunction[ife][5] = 4. * y1 * y2;
shapeFunction[ife][6] = 4. * y2 * y4;
shapeFunction[ife][7] = 4. * y3 * y4;
shapeFunction[ife][8] = 4. * y1 * y3;
shapeFunction[ife][9] = 4. * y2 * y3;
dndy1GaussPts[ife][0] = 1 - 4 * y4;
dndy1GaussPts[ife][1] = 4 * y1 - 1.;
dndy1GaussPts[ife][2] = 0;
dndy1GaussPts[ife][3] = 0;
dndy1GaussPts[ife][4] = 4. * ( y4 - y1 );
dndy1GaussPts[ife][5] = 4. * y2;
dndy1GaussPts[ife][6] = -4. * y2;
dndy1GaussPts[ife][7] = -4. * y3;
dndy1GaussPts[ife][8] = 4. * y3;
dndy1GaussPts[ife][9] = 0;
dndy2GaussPts[ife][0] = 1 - 4 * y4;
dndy2GaussPts[ife][1] = 0;
dndy2GaussPts[ife][2] = 4. * y2 - 1.;
dndy2GaussPts[ife][3] = 0;
dndy2GaussPts[ife][4] = -4. * y1;
dndy2GaussPts[ife][5] = 4. * y1;
dndy2GaussPts[ife][6] = 4. * ( y4 - y2 );
dndy2GaussPts[ife][7] = -4. * y3;
dndy2GaussPts[ife][8] = 0.;
dndy2GaussPts[ife][9] = 4. * y3;
dndy3GaussPts[ife][0] = 1 - 4 * y4;
dndy3GaussPts[ife][1] = 0;
dndy3GaussPts[ife][2] = 0;
dndy3GaussPts[ife][3] = 4. * y3 - 1.;
dndy3GaussPts[ife][4] = -4. * y1;
dndy3GaussPts[ife][5] = 0;
dndy3GaussPts[ife][6] = -4. * y2;
dndy3GaussPts[ife][7] = 4. * ( y4 - y3 );
dndy3GaussPts[ife][8] = 4. * y1;
dndy3GaussPts[ife][9] = 4. * y2;
break;
case 4: // four node linear tet for debug purpose
y1 = y1Volume[ife];
y2 = y2Volume[ife];
y3 = y3Volume[ife];
y4 = y4Volume[ife];
shapeFunction[ife][0] = y4;
shapeFunction[ife][1] = y1;
shapeFunction[ife][2] = y2;
shapeFunction[ife][3] = y3;
dndy1GaussPts[ife][0] = -1.;
dndy1GaussPts[ife][1] = 1;
dndy2GaussPts[ife][0] = -1.;
dndy2GaussPts[ife][2] = 1;
dndy3GaussPts[ife][0] = -1.;
dndy3GaussPts[ife][3] = 1;
break;
Definition at line 115 of file V_GaussIntegration.cpp.
Referenced by calculate_shape_function_2d_quad(), and calculate_shape_function_3d_hex().
switch( numberGaussPoints )
case 1:
gaussPointY[0] = 0.0;
gaussWeight[0] = 2.0;
break;
case 2:
gaussPointY[0] = -0.577350269189626;
gaussPointY[1] = 0.577350269189626;
gaussWeight[0] = 1.0;
gaussWeight[1] = 1.0;
break;
case 3:
gaussPointY[0] = -0.774596669241483;
gaussPointY[1] = 0.0;
gaussPointY[2] = 0.774596669241483;
gaussWeight[0] = 0.555555555555555;
gaussWeight[1] = 0.888888888888889;
gaussWeight[2] = 0.555555555555555;
break;
| void GaussIntegration::get_node_local_coord_tet | ( | int | node_id, |
| double & | y1, | ||
| double & | y2, | ||
| double & | y3, | ||
| double & | y4 | ||
Definition at line 990 of file V_GaussIntegration.cpp.
Referenced by calculate_derivative_at_nodes_3d_tet().
switch( node_id )
case 0:
y1 = 0.;
y2 = 0.;
y3 = 0.;
y4 = 1.;
break;
case 1:
y1 = 1.;
y2 = 0.;
y3 = 0.;
y4 = 0.;
break;
case 2:
y1 = 0.;
y2 = 1.;
y3 = 0.;
y4 = 0.;
break;
case 3:
y1 = 0.;
y2 = 0.;
y3 = 1.;
y4 = 0.;
break;
case 4:
y1 = 0.5;
y2 = 0.;
y3 = 0.;
y4 = 0.5;
break;
case 5:
y1 = 0.5;
y2 = 0.5;
y3 = 0.;
y4 = 0.;
break;
case 6:
y1 = 0.;
y2 = 0.5;
y3 = 0.;
y4 = 0.5;
break;
case 7:
y1 = 0.;
y2 = 0.0;
y3 = 0.5;
y4 = 0.5;
break;
case 8:
y1 = 0.5;
y2 = 0.;
y3 = 0.5;
y4 = 0.0;
break;
case 9:
y1 = 0.;
y2 = 0.5;
y3 = 0.5;
y4 = 0.;
break;
| void GaussIntegration::get_shape_func | ( | double | shape_function[], |
| double | dndy1_at_gauss_pts[], | ||
| double | dndy2_at_gauss_ptsp[], | ||
| double | gauss_weight[] | ||
Definition at line 73 of file V_GaussIntegration.cpp.
References maxNumberNodes, numberNodes, and totalNumberGaussPts.
Referenced by v_hex_distortion(), v_quad_distortion(), v_tet_distortion(), and v_tri_distortion().
int i, j;
for( i = 0; i < totalNumberGaussPts; i++ )
for( j = 0; j < numberNodes; j++ )
shape_function[i * maxNumberNodes + j] = shapeFunction[i][j];
dndy1_at_gauss_pts[i * maxNumberNodes + j] = dndy1GaussPts[i][j];
dndy2_at_gauss_pts[i * maxNumberNodes + j] = dndy2GaussPts[i][j];
gauss_weight[i] = totalGaussWeight[i];
| double | dndy2_at_gauss_pts[], | ||
| double | dndy3_at_gauss_pts[], | ||
Definition at line 93 of file V_GaussIntegration.cpp.
int i, j;
dndy3_at_gauss_pts[i * maxNumberNodes + j] = dndy3GaussPts[i][j];
| void GaussIntegration::get_signs_for_node_local_coord_hex | ( | int | node_id, |
| double & | sign_y1, | ||
| double & | sign_y2, | ||
| double & | sign_y3 | ||
Definition at line 520 of file V_GaussIntegration.cpp.
Referenced by calculate_derivative_at_nodes_3d(), and calculate_shape_function_3d_hex().
switch( node_id )
case 0:
sign_node_y1 = -1.;
sign_node_y2 = -1.;
sign_node_y3 = -1.;
break;
case 1:
sign_node_y1 = 1.;
sign_node_y2 = -1.;
sign_node_y3 = -1.;
break;
case 2:
sign_node_y1 = 1.;
sign_node_y2 = 1.;
sign_node_y3 = -1.;
break;
case 3:
sign_node_y1 = -1.;
sign_node_y2 = 1.;
sign_node_y3 = -1.;
break;
case 4:
sign_node_y1 = -1.;
sign_node_y2 = -1.;
sign_node_y3 = 1.;
break;
case 5:
sign_node_y1 = 1.;
sign_node_y2 = -1.;
sign_node_y3 = 1.;
break;
case 6:
sign_node_y1 = 1.;
sign_node_y2 = 1.;
sign_node_y3 = 1.;
break;
case 7:
sign_node_y1 = -1.;
sign_node_y2 = 1.;
sign_node_y3 = 1.;
break;
case 8:
sign_node_y1 = 0;
sign_node_y2 = -1.;
sign_node_y3 = -1.;
break;
case 9:
sign_node_y1 = 1.;
sign_node_y2 = 0;
sign_node_y3 = -1.;
break;
case 10:
sign_node_y1 = 0;
sign_node_y2 = 1.;
sign_node_y3 = -1.;
break;
case 11:
sign_node_y1 = -1.;
sign_node_y2 = 0.;
sign_node_y3 = -1.;
break;
case 12:
sign_node_y1 = -1.;
sign_node_y2 = -1.;
sign_node_y3 = 0.;
break;
case 13:
sign_node_y1 = 1.;
sign_node_y2 = -1.;
sign_node_y3 = 0.;
break;
case 14:
sign_node_y1 = 1.;
sign_node_y2 = 1.;
sign_node_y3 = 0.;
break;
case 15:
sign_node_y1 = -1.;
sign_node_y2 = 1.;
sign_node_y3 = 0.;
break;
case 16:
sign_node_y1 = 0;
sign_node_y2 = -1.;
sign_node_y3 = 1.;
break;
case 17:
sign_node_y1 = 1.;
sign_node_y2 = 0;
sign_node_y3 = 1.;
break;
case 18:
sign_node_y1 = 0;
sign_node_y2 = 1.;
sign_node_y3 = 1.;
break;
case 19:
sign_node_y1 = -1.;
sign_node_y2 = 0.;
sign_node_y3 = 1.;
break;
Definition at line 760 of file V_GaussIntegration.cpp.
Referenced by calculate_shape_function_3d_tet().
// get tetrahedron rule integration points and weight
double a, b;
case 1:
// 1 integration point formula, degree of precision 1
y1Volume[0] = 0.25;
y2Volume[0] = 0.25;
y3Volume[0] = 0.25;
y4Volume[0] = 0.25;
totalGaussWeight[0] = 1.;
break;
case 4:
// 4 integration points formula, degree of precision 2
a = 0.58541020;
b = 0.13819660;
y1Volume[0] = a;
y2Volume[0] = b;
y3Volume[0] = b;
y4Volume[0] = b;
y1Volume[1] = b;
y2Volume[1] = a;
y3Volume[1] = b;
y4Volume[1] = b;
y1Volume[2] = b;
y2Volume[2] = b;
y3Volume[2] = a;
y4Volume[2] = b;
y1Volume[3] = b;
y2Volume[3] = b;
y3Volume[3] = b;
y4Volume[3] = a;
int i;
for( i = 0; i < 4; i++ )
totalGaussWeight[i] = 0.25;
break;
Definition at line 630 of file V_GaussIntegration.cpp.
Referenced by calculate_shape_function_2d_tri().
// get triangular rule integration points and weight
case 6:
y1Area[0] = 0.09157621;
y2Area[0] = 0.09157621;
y1Area[1] = 0.09157621;
y2Area[1] = 0.8168476;
y1Area[2] = 0.8168476;
y2Area[2] = 0.09157621;
y1Area[3] = 0.4459485;
y2Area[3] = 0.4459485;
y1Area[4] = 0.4459485;
y2Area[4] = 0.1081030;
y1Area[5] = 0.1081030;
y2Area[5] = 0.4459485;
int i;
for( i = 0; i < 3; i++ )
totalGaussWeight[i] = 0.06348067;
for( i = 3; i < 6; i++ )
totalGaussWeight[i] = 0.1289694;
break;
| void GaussIntegration::initialize | ( | int | n = 2, |
| int | m = 4, |
| int | dim = 2, |
| int | tri = 0 |
Definition at line 50 of file V_GaussIntegration.cpp.
References dim, and numberGaussPoints.
Referenced by moab::Core::Core(), v_hex_distortion(), v_quad_distortion(), v_tet_distortion(), and v_tri_distortion().
numberGaussPoints = n;
numberNodes = m;
numberDims = dim;
if( tri == 1 )
// triangular element
if( numberDims == 2 )
totalNumberGaussPts = numberGaussPoints;
else if( numberDims == 3 )
else if( tri == 0 )
totalNumberGaussPts = numberGaussPoints * numberGaussPoints;
totalNumberGaussPts = numberGaussPoints * numberGaussPoints * numberGaussPoints;
