MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*========================================================================= 00002 00003 Module: $RCSfile: V_TriMetric.cpp,v $ 00004 00005 Copyright (c) 2007 Sandia Corporation. 00006 All rights reserved. 00007 See Copyright.txt or http://www.kitware.com/Copyright.htm for details. 00008 00009 This software is distributed WITHOUT ANY WARRANTY; without even 00010 the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR 00011 PURPOSE. See the above copyright notice for more information. 00012 00013 =========================================================================*/ 00014 00015 /* 00016 * 00017 * TriMetric.cpp contains quality calculations for Tris 00018 * 00019 * This file is part of VERDICT 00020 * 00021 */ 00022 00023 #define VERDICT_EXPORTS 00024 00025 #include "moab/verdict.h" 00026 #include "verdict_defines.hpp" 00027 #include "V_GaussIntegration.hpp" 00028 #include "VerdictVector.hpp" 00029 #include <memory.h> 00030 #include <cstddef> 00031 00032 // the average area of a tri 00033 static double verdict_tri_size = 0; 00034 static ComputeNormal compute_normal = NULL; 00035 00036 /*! 00037 get weights based on the average area of a set of 00038 tris 00039 */ 00040 static int v_tri_get_weight( double& m11, double& m21, double& m12, double& m22 ) 00041 { 00042 static const double rootOf3 = sqrt( 3.0 ); 00043 m11 = 1; 00044 m21 = 0; 00045 m12 = 0.5; 00046 m22 = 0.5 * rootOf3; 00047 double scale = sqrt( 2.0 * verdict_tri_size / ( m11 * m22 - m21 * m12 ) ); 00048 00049 m11 *= scale; 00050 m21 *= scale; 00051 m12 *= scale; 00052 m22 *= scale; 00053 00054 return 1; 00055 } 00056 00057 /*! sets the average area of a tri */ 00058 C_FUNC_DEF void v_set_tri_size( double size ) 00059 { 00060 verdict_tri_size = size; 00061 } 00062 00063 C_FUNC_DEF void v_set_tri_normal_func( ComputeNormal func ) 00064 { 00065 compute_normal = func; 00066 } 00067 00068 /*! 00069 the edge ratio of a triangle 00070 00071 NB (P. Pebay 01/14/07): 00072 Hmax / Hmin where Hmax and Hmin are respectively the maximum and the 00073 minimum edge lengths 00074 00075 */ 00076 C_FUNC_DEF double v_tri_edge_ratio( int /*num_nodes*/, double coordinates[][3] ) 00077 { 00078 00079 // three vectors for each side 00080 VerdictVector a( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00081 coordinates[1][2] - coordinates[0][2] ); 00082 00083 VerdictVector b( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00084 coordinates[2][2] - coordinates[1][2] ); 00085 00086 VerdictVector c( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1], 00087 coordinates[0][2] - coordinates[2][2] ); 00088 00089 double a2 = a.length_squared(); 00090 double b2 = b.length_squared(); 00091 double c2 = c.length_squared(); 00092 00093 double m2, M2; 00094 if( a2 < b2 ) 00095 { 00096 if( b2 < c2 ) 00097 { 00098 m2 = a2; 00099 M2 = c2; 00100 } 00101 else // b2 <= a2 00102 { 00103 if( a2 < c2 ) 00104 { 00105 m2 = a2; 00106 M2 = b2; 00107 } 00108 else // c2 <= a2 00109 { 00110 m2 = c2; 00111 M2 = b2; 00112 } 00113 } 00114 } 00115 else // b2 <= a2 00116 { 00117 if( a2 < c2 ) 00118 { 00119 m2 = b2; 00120 M2 = c2; 00121 } 00122 else // c2 <= a2 00123 { 00124 if( b2 < c2 ) 00125 { 00126 m2 = b2; 00127 M2 = a2; 00128 } 00129 else // c2 <= b2 00130 { 00131 m2 = c2; 00132 M2 = a2; 00133 } 00134 } 00135 } 00136 00137 if( m2 < VERDICT_DBL_MIN ) 00138 return (double)VERDICT_DBL_MAX; 00139 else 00140 { 00141 double edge_ratio; 00142 edge_ratio = sqrt( M2 / m2 ); 00143 00144 if( edge_ratio > 0 ) return (double)VERDICT_MIN( edge_ratio, VERDICT_DBL_MAX ); 00145 return (double)VERDICT_MAX( edge_ratio, -VERDICT_DBL_MAX ); 00146 } 00147 } 00148 00149 /*! 00150 the aspect ratio of a triangle 00151 00152 NB (P. Pebay 01/14/07): 00153 Hmax / ( 2.0 * sqrt(3.0) * IR) where Hmax is the maximum edge length 00154 and IR is the inradius 00155 00156 note that previous incarnations of verdict used "v_tri_aspect_ratio" to denote 00157 what is now called "v_tri_aspect_frobenius" 00158 00159 */ 00160 C_FUNC_DEF double v_tri_aspect_ratio( int /*num_nodes*/, double coordinates[][3] ) 00161 { 00162 static const double normal_coeff = sqrt( 3. ) / 6.; 00163 00164 // three vectors for each side 00165 VerdictVector a( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00166 coordinates[1][2] - coordinates[0][2] ); 00167 00168 VerdictVector b( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00169 coordinates[2][2] - coordinates[1][2] ); 00170 00171 VerdictVector c( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1], 00172 coordinates[0][2] - coordinates[2][2] ); 00173 00174 double a1 = a.length(); 00175 double b1 = b.length(); 00176 double c1 = c.length(); 00177 00178 double hm = a1 > b1 ? a1 : b1; 00179 hm = hm > c1 ? hm : c1; 00180 00181 VerdictVector ab = a * b; 00182 double denominator = ab.length(); 00183 00184 if( denominator < VERDICT_DBL_MIN ) 00185 return (double)VERDICT_DBL_MAX; 00186 else 00187 { 00188 double aspect_ratio; 00189 aspect_ratio = normal_coeff * hm * ( a1 + b1 + c1 ) / denominator; 00190 00191 if( aspect_ratio > 0 ) return (double)VERDICT_MIN( aspect_ratio, VERDICT_DBL_MAX ); 00192 return (double)VERDICT_MAX( aspect_ratio, -VERDICT_DBL_MAX ); 00193 } 00194 } 00195 00196 /*! 00197 the radius ratio of a triangle 00198 00199 NB (P. Pebay 01/13/07): 00200 CR / (3.0*IR) where CR is the circumradius and IR is the inradius 00201 00202 this quality metric is also known to VERDICT, for tetrahedral elements only, 00203 a the "aspect beta" 00204 00205 */ 00206 C_FUNC_DEF double v_tri_radius_ratio( int /*num_nodes*/, double coordinates[][3] ) 00207 { 00208 00209 // three vectors for each side 00210 VerdictVector a( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00211 coordinates[1][2] - coordinates[0][2] ); 00212 00213 VerdictVector b( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00214 coordinates[2][2] - coordinates[1][2] ); 00215 00216 VerdictVector c( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1], 00217 coordinates[0][2] - coordinates[2][2] ); 00218 00219 double a2 = a.length_squared(); 00220 double b2 = b.length_squared(); 00221 double c2 = c.length_squared(); 00222 00223 VerdictVector ab = a * b; 00224 double denominator = ab.length_squared(); 00225 00226 if( denominator < VERDICT_DBL_MIN ) return (double)VERDICT_DBL_MAX; 00227 00228 double radius_ratio; 00229 radius_ratio = .25 * a2 * b2 * c2 * ( a2 + b2 + c2 ) / denominator; 00230 00231 if( radius_ratio > 0 ) return (double)VERDICT_MIN( radius_ratio, VERDICT_DBL_MAX ); 00232 return (double)VERDICT_MAX( radius_ratio, -VERDICT_DBL_MAX ); 00233 } 00234 00235 /*! 00236 the Frobenius aspect of a tri 00237 00238 srms^2/(2 * sqrt(3.0) * area) 00239 where srms^2 is sum of the lengths squared 00240 00241 NB (P. Pebay 01/14/07): 00242 this method was called "aspect ratio" in earlier incarnations of VERDICT 00243 00244 */ 00245 00246 C_FUNC_DEF double v_tri_aspect_frobenius( int /*num_nodes*/, double coordinates[][3] ) 00247 { 00248 static const double two_times_root_of_3 = 2 * sqrt( 3.0 ); 00249 00250 // three vectors for each side 00251 VerdictVector side1( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00252 coordinates[1][2] - coordinates[0][2] ); 00253 00254 VerdictVector side2( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00255 coordinates[2][2] - coordinates[1][2] ); 00256 00257 VerdictVector side3( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1], 00258 coordinates[0][2] - coordinates[2][2] ); 00259 00260 // sum the lengths squared of each side 00261 double srms = ( side1.length_squared() + side2.length_squared() + side3.length_squared() ); 00262 00263 // find two times the area of the triangle by cross product 00264 double areaX2 = ( ( side1 * ( -side3 ) ).length() ); 00265 00266 if( areaX2 == 0.0 ) return (double)VERDICT_DBL_MAX; 00267 00268 double aspect = (double)( srms / ( two_times_root_of_3 * ( areaX2 ) ) ); 00269 if( aspect > 0 ) return (double)VERDICT_MIN( aspect, VERDICT_DBL_MAX ); 00270 return (double)VERDICT_MAX( aspect, -VERDICT_DBL_MAX ); 00271 } 00272 00273 /*! 00274 The area of a tri 00275 00276 0.5 * jacobian at a node 00277 */ 00278 C_FUNC_DEF double v_tri_area( int /*num_nodes*/, double coordinates[][3] ) 00279 { 00280 // two vectors for two sides 00281 VerdictVector side1( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00282 coordinates[1][2] - coordinates[0][2] ); 00283 00284 VerdictVector side3( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1], 00285 coordinates[2][2] - coordinates[0][2] ); 00286 00287 // the cross product of the two vectors representing two sides of the 00288 // triangle 00289 VerdictVector tmp = side1 * side3; 00290 00291 // return the magnitude of the vector divided by two 00292 double area = 0.5 * tmp.length(); 00293 if( area > 0 ) return (double)VERDICT_MIN( area, VERDICT_DBL_MAX ); 00294 return (double)VERDICT_MAX( area, -VERDICT_DBL_MAX ); 00295 } 00296 00297 /*! 00298 The minimum angle of a tri 00299 00300 The minimum angle of a tri is the minimum angle between 00301 two adjacents sides out of all three corners of the triangle. 00302 */ 00303 C_FUNC_DEF double v_tri_minimum_angle( int /*num_nodes*/, double coordinates[][3] ) 00304 { 00305 00306 // vectors for all the sides 00307 VerdictVector sides[4]; 00308 sides[0].set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00309 coordinates[1][2] - coordinates[0][2] ); 00310 sides[1].set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00311 coordinates[2][2] - coordinates[1][2] ); 00312 sides[2].set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1], 00313 coordinates[2][2] - coordinates[0][2] ); 00314 00315 // in case we need to find the interior angle 00316 // between sides 0 and 1 00317 sides[3] = -sides[1]; 00318 00319 // calculate the lengths squared of the sides 00320 double sides_lengths[3]; 00321 sides_lengths[0] = sides[0].length_squared(); 00322 sides_lengths[1] = sides[1].length_squared(); 00323 sides_lengths[2] = sides[2].length_squared(); 00324 00325 if( sides_lengths[0] == 0.0 || sides_lengths[1] == 0.0 || sides_lengths[2] == 0.0 ) return 0.0; 00326 00327 // using the law of sines, we know that the minimum 00328 // angle is opposite of the shortest side 00329 00330 // find the shortest side 00331 int short_side = 0; 00332 if( sides_lengths[1] < sides_lengths[0] ) short_side = 1; 00333 if( sides_lengths[2] < sides_lengths[short_side] ) short_side = 2; 00334 00335 // from the shortest side, calculate the angle of the 00336 // opposite angle 00337 double min_angle; 00338 if( short_side == 0 ) 00339 { 00340 min_angle = sides[2].interior_angle( sides[1] ); 00341 } 00342 else if( short_side == 1 ) 00343 { 00344 min_angle = sides[0].interior_angle( sides[2] ); 00345 } 00346 else 00347 { 00348 min_angle = sides[0].interior_angle( sides[3] ); 00349 } 00350 00351 if( min_angle > 0 ) return (double)VERDICT_MIN( min_angle, VERDICT_DBL_MAX ); 00352 return (double)VERDICT_MAX( min_angle, -VERDICT_DBL_MAX ); 00353 } 00354 00355 /*! 00356 The maximum angle of a tri 00357 00358 The maximum angle of a tri is the maximum angle between 00359 two adjacents sides out of all three corners of the triangle. 00360 */ 00361 C_FUNC_DEF double v_tri_maximum_angle( int /*num_nodes*/, double coordinates[][3] ) 00362 { 00363 00364 // vectors for all the sides 00365 VerdictVector sides[4]; 00366 sides[0].set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00367 coordinates[1][2] - coordinates[0][2] ); 00368 sides[1].set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00369 coordinates[2][2] - coordinates[1][2] ); 00370 sides[2].set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1], 00371 coordinates[2][2] - coordinates[0][2] ); 00372 00373 // in case we need to find the interior angle 00374 // between sides 0 and 1 00375 sides[3] = -sides[1]; 00376 00377 // calculate the lengths squared of the sides 00378 double sides_lengths[3]; 00379 sides_lengths[0] = sides[0].length_squared(); 00380 sides_lengths[1] = sides[1].length_squared(); 00381 sides_lengths[2] = sides[2].length_squared(); 00382 00383 if( sides_lengths[0] == 0.0 || sides_lengths[1] == 0.0 || sides_lengths[2] == 0.0 ) 00384 { 00385 return 0.0; 00386 } 00387 00388 // using the law of sines, we know that the maximum 00389 // angle is opposite of the longest side 00390 00391 // find the longest side 00392 int short_side = 0; 00393 if( sides_lengths[1] > sides_lengths[0] ) short_side = 1; 00394 if( sides_lengths[2] > sides_lengths[short_side] ) short_side = 2; 00395 00396 // from the longest side, calculate the angle of the 00397 // opposite angle 00398 double max_angle; 00399 if( short_side == 0 ) 00400 { 00401 max_angle = sides[2].interior_angle( sides[1] ); 00402 } 00403 else if( short_side == 1 ) 00404 { 00405 max_angle = sides[0].interior_angle( sides[2] ); 00406 } 00407 else 00408 { 00409 max_angle = sides[0].interior_angle( sides[3] ); 00410 } 00411 00412 if( max_angle > 0 ) return (double)VERDICT_MIN( max_angle, VERDICT_DBL_MAX ); 00413 return (double)VERDICT_MAX( max_angle, -VERDICT_DBL_MAX ); 00414 } 00415 00416 /*! 00417 The condition of a tri 00418 00419 Condition number of the jacobian matrix at any corner 00420 */ 00421 C_FUNC_DEF double v_tri_condition( int /*num_nodes*/, double coordinates[][3] ) 00422 { 00423 static const double rt3 = sqrt( 3.0 ); 00424 00425 VerdictVector v1( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00426 coordinates[1][2] - coordinates[0][2] ); 00427 00428 VerdictVector v2( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1], 00429 coordinates[2][2] - coordinates[0][2] ); 00430 00431 VerdictVector tri_normal = v1 * v2; 00432 double areax2 = tri_normal.length(); 00433 00434 if( areax2 == 0.0 ) return (double)VERDICT_DBL_MAX; 00435 00436 double condition = (double)( ( ( v1 % v1 ) + ( v2 % v2 ) - ( v1 % v2 ) ) / ( areax2 * rt3 ) ); 00437 00438 // check for inverted if we have access to the normal 00439 if( compute_normal ) 00440 { 00441 // center of tri 00442 double point[3], surf_normal[3]; 00443 point[0] = ( coordinates[0][0] + coordinates[1][0] + coordinates[2][0] ) / 3; 00444 point[1] = ( coordinates[0][1] + coordinates[1][1] + coordinates[2][1] ) / 3; 00445 point[2] = ( coordinates[0][2] + coordinates[1][2] + coordinates[2][2] ) / 3; 00446 00447 // dot product 00448 compute_normal( point, surf_normal ); 00449 if( ( tri_normal.x() * surf_normal[0] + tri_normal.y() * surf_normal[1] + tri_normal.z() * surf_normal[2] ) < 00450 0 ) 00451 return (double)VERDICT_DBL_MAX; 00452 } 00453 return (double)VERDICT_MIN( condition, VERDICT_DBL_MAX ); 00454 } 00455 00456 /*! 00457 The scaled jacobian of a tri 00458 00459 minimum of the jacobian divided by the lengths of 2 edge vectors 00460 */ 00461 C_FUNC_DEF double v_tri_scaled_jacobian( int /*num_nodes*/, double coordinates[][3] ) 00462 { 00463 static const double detw = 2. / sqrt( 3.0 ); 00464 VerdictVector first, second; 00465 double jacobian; 00466 00467 VerdictVector edge[3]; 00468 edge[0].set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00469 coordinates[1][2] - coordinates[0][2] ); 00470 00471 edge[1].set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1], 00472 coordinates[2][2] - coordinates[0][2] ); 00473 00474 edge[2].set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00475 coordinates[2][2] - coordinates[1][2] ); 00476 first = edge[1] - edge[0]; 00477 second = edge[2] - edge[0]; 00478 00479 VerdictVector cross = first * second; 00480 jacobian = cross.length(); 00481 00482 double max_edge_length_product; 00483 max_edge_length_product = 00484 VERDICT_MAX( edge[0].length() * edge[1].length(), 00485 VERDICT_MAX( edge[1].length() * edge[2].length(), edge[0].length() * edge[2].length() ) ); 00486 00487 if( max_edge_length_product < VERDICT_DBL_MIN ) return (double)0.0; 00488 00489 jacobian *= detw; 00490 jacobian /= max_edge_length_product; 00491 00492 if( compute_normal ) 00493 { 00494 // center of tri 00495 double point[3], surf_normal[3]; 00496 point[0] = ( coordinates[0][0] + coordinates[1][0] + coordinates[2][0] ) / 3; 00497 point[1] = ( coordinates[0][1] + coordinates[1][1] + coordinates[2][1] ) / 3; 00498 point[2] = ( coordinates[0][2] + coordinates[1][2] + coordinates[2][2] ) / 3; 00499 00500 // dot product 00501 compute_normal( point, surf_normal ); 00502 if( ( cross.x() * surf_normal[0] + cross.y() * surf_normal[1] + cross.z() * surf_normal[2] ) < 0 ) 00503 jacobian *= -1; 00504 } 00505 00506 if( jacobian > 0 ) return (double)VERDICT_MIN( jacobian, VERDICT_DBL_MAX ); 00507 return (double)VERDICT_MAX( jacobian, -VERDICT_DBL_MAX ); 00508 } 00509 00510 /*! 00511 The shape of a tri 00512 00513 2 / condition number of weighted jacobian matrix 00514 */ 00515 C_FUNC_DEF double v_tri_shape( int num_nodes, double coordinates[][3] ) 00516 { 00517 double condition = v_tri_condition( num_nodes, coordinates ); 00518 00519 double shape; 00520 if( condition <= VERDICT_DBL_MIN ) 00521 shape = VERDICT_DBL_MAX; 00522 else 00523 shape = ( 1 / condition ); 00524 00525 if( shape > 0 ) return (double)VERDICT_MIN( shape, VERDICT_DBL_MAX ); 00526 return (double)VERDICT_MAX( shape, -VERDICT_DBL_MAX ); 00527 } 00528 00529 /*! 00530 The relative size of a tri 00531 00532 Min(J,1/J) where J is the determinant of the weighted jacobian matrix. 00533 */ 00534 C_FUNC_DEF double v_tri_relative_size_squared( int /*num_nodes*/, double coordinates[][3] ) 00535 { 00536 double w11, w21, w12, w22; 00537 00538 VerdictVector xxi, xet, tri_normal; 00539 00540 v_tri_get_weight( w11, w21, w12, w22 ); 00541 00542 double detw = determinant( w11, w21, w12, w22 ); 00543 00544 if( detw == 0.0 ) return 0.0; 00545 00546 xxi.set( coordinates[0][0] - coordinates[1][0], coordinates[0][1] - coordinates[1][1], 00547 coordinates[0][2] - coordinates[1][2] ); 00548 00549 xet.set( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1], 00550 coordinates[0][2] - coordinates[2][2] ); 00551 00552 tri_normal = xxi * xet; 00553 00554 double deta = tri_normal.length(); 00555 if( deta == 0.0 || detw == 0.0 ) return 0.0; 00556 00557 double size = pow( deta / detw, 2 ); 00558 00559 double rel_size = VERDICT_MIN( size, 1.0 / size ); 00560 00561 if( rel_size > 0 ) return (double)VERDICT_MIN( rel_size, VERDICT_DBL_MAX ); 00562 return (double)VERDICT_MAX( rel_size, -VERDICT_DBL_MAX ); 00563 } 00564 00565 /*! 00566 The shape and size of a tri 00567 00568 Product of the Shape and Relative Size 00569 */ 00570 C_FUNC_DEF double v_tri_shape_and_size( int num_nodes, double coordinates[][3] ) 00571 { 00572 double size, shape; 00573 00574 size = v_tri_relative_size_squared( num_nodes, coordinates ); 00575 shape = v_tri_shape( num_nodes, coordinates ); 00576 00577 double shape_and_size = size * shape; 00578 00579 if( shape_and_size > 0 ) return (double)VERDICT_MIN( shape_and_size, VERDICT_DBL_MAX ); 00580 return (double)VERDICT_MAX( shape_and_size, -VERDICT_DBL_MAX ); 00581 } 00582 00583 /*! 00584 The distortion of a tri 00585 00586 TODO: make a short definition of the distortion and comment below 00587 */ 00588 C_FUNC_DEF double v_tri_distortion( int num_nodes, double coordinates[][3] ) 00589 { 00590 00591 double distortion; 00592 int total_number_of_gauss_points = 0; 00593 VerdictVector aa, bb, cc, normal_at_point, xin; 00594 double element_area = 0.; 00595 00596 aa.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00597 coordinates[1][2] - coordinates[0][2] ); 00598 00599 bb.set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1], 00600 coordinates[2][2] - coordinates[0][2] ); 00601 00602 VerdictVector tri_normal = aa * bb; 00603 00604 int number_of_gauss_points = 0; 00605 if( num_nodes == 3 ) 00606 { 00607 distortion = 1.0; 00608 return (double)distortion; 00609 } 00610 00611 else if( num_nodes == 6 ) 00612 { 00613 total_number_of_gauss_points = 6; 00614 number_of_gauss_points = 6; 00615 } 00616 00617 distortion = VERDICT_DBL_MAX; 00618 double shape_function[maxTotalNumberGaussPoints][maxNumberNodes]; 00619 double dndy1[maxTotalNumberGaussPoints][maxNumberNodes]; 00620 double dndy2[maxTotalNumberGaussPoints][maxNumberNodes]; 00621 double weight[maxTotalNumberGaussPoints]; 00622 00623 // create an object of GaussIntegration 00624 int number_dims = 2; 00625 int is_tri = 1; 00626 GaussIntegration::initialize( number_of_gauss_points, num_nodes, number_dims, is_tri ); 00627 GaussIntegration::calculate_shape_function_2d_tri(); 00628 GaussIntegration::get_shape_func( shape_function[0], dndy1[0], dndy2[0], weight ); 00629 00630 // calculate element area 00631 int ife, ja; 00632 for( ife = 0; ife < total_number_of_gauss_points; ife++ ) 00633 { 00634 aa.set( 0.0, 0.0, 0.0 ); 00635 bb.set( 0.0, 0.0, 0.0 ); 00636 00637 for( ja = 0; ja < num_nodes; ja++ ) 00638 { 00639 xin.set( coordinates[ja][0], coordinates[ja][1], coordinates[ja][2] ); 00640 aa += dndy1[ife][ja] * xin; 00641 bb += dndy2[ife][ja] * xin; 00642 } 00643 normal_at_point = aa * bb; 00644 double jacobian = normal_at_point.length(); 00645 element_area += weight[ife] * jacobian; 00646 } 00647 00648 element_area *= 0.8660254; 00649 double dndy1_at_node[maxNumberNodes][maxNumberNodes]; 00650 double dndy2_at_node[maxNumberNodes][maxNumberNodes]; 00651 00652 GaussIntegration::calculate_derivative_at_nodes_2d_tri( dndy1_at_node, dndy2_at_node ); 00653 00654 VerdictVector normal_at_nodes[7]; 00655 00656 // evaluate normal at nodes and distortion values at nodes 00657 int jai = 0; 00658 for( ja = 0; ja < num_nodes; ja++ ) 00659 { 00660 aa.set( 0.0, 0.0, 0.0 ); 00661 bb.set( 0.0, 0.0, 0.0 ); 00662 for( jai = 0; jai < num_nodes; jai++ ) 00663 { 00664 xin.set( coordinates[jai][0], coordinates[jai][1], coordinates[jai][2] ); 00665 aa += dndy1_at_node[ja][jai] * xin; 00666 bb += dndy2_at_node[ja][jai] * xin; 00667 } 00668 normal_at_nodes[ja] = aa * bb; 00669 normal_at_nodes[ja].normalize(); 00670 } 00671 00672 // determine if element is flat 00673 bool flat_element = true; 00674 double dot_product; 00675 00676 for( ja = 0; ja < num_nodes; ja++ ) 00677 { 00678 dot_product = normal_at_nodes[0] % normal_at_nodes[ja]; 00679 if( fabs( dot_product ) < 0.99 ) 00680 { 00681 flat_element = false; 00682 break; 00683 } 00684 } 00685 00686 // take into consideration of the thickness of the element 00687 double thickness, thickness_gauss; 00688 double distrt; 00689 // get_tri_thickness(tri, element_area, thickness ); 00690 thickness = 0.001 * sqrt( element_area ); 00691 00692 // set thickness gauss point location 00693 double zl = 0.5773502691896; 00694 if( flat_element ) zl = 0.0; 00695 00696 int no_gauss_pts_z = ( flat_element ) ? 1 : 2; 00697 double thickness_z; 00698 00699 // loop on integration points 00700 int igz; 00701 for( ife = 0; ife < total_number_of_gauss_points; ife++ ) 00702 { 00703 // loop on the thickness direction gauss points 00704 for( igz = 0; igz < no_gauss_pts_z; igz++ ) 00705 { 00706 zl = -zl; 00707 thickness_z = zl * thickness / 2.0; 00708 00709 aa.set( 0.0, 0.0, 0.0 ); 00710 bb.set( 0.0, 0.0, 0.0 ); 00711 cc.set( 0.0, 0.0, 0.0 ); 00712 00713 for( ja = 0; ja < num_nodes; ja++ ) 00714 { 00715 xin.set( coordinates[jai][0], coordinates[jai][1], coordinates[jai][2] ); 00716 xin += thickness_z * normal_at_nodes[ja]; 00717 aa += dndy1[ife][ja] * xin; 00718 bb += dndy2[ife][ja] * xin; 00719 thickness_gauss = shape_function[ife][ja] * thickness / 2.0; 00720 cc += thickness_gauss * normal_at_nodes[ja]; 00721 } 00722 00723 normal_at_point = aa * bb; 00724 distrt = cc % normal_at_point; 00725 if( distrt < distortion ) distortion = distrt; 00726 } 00727 } 00728 00729 // loop through nodal points 00730 for( ja = 0; ja < num_nodes; ja++ ) 00731 { 00732 for( igz = 0; igz < no_gauss_pts_z; igz++ ) 00733 { 00734 zl = -zl; 00735 thickness_z = zl * thickness / 2.0; 00736 00737 aa.set( 0.0, 0.0, 0.0 ); 00738 bb.set( 0.0, 0.0, 0.0 ); 00739 cc.set( 0.0, 0.0, 0.0 ); 00740 00741 for( jai = 0; jai < num_nodes; jai++ ) 00742 { 00743 xin.set( coordinates[jai][0], coordinates[jai][1], coordinates[jai][2] ); 00744 xin += thickness_z * normal_at_nodes[ja]; 00745 aa += dndy1_at_node[ja][jai] * xin; 00746 bb += dndy2_at_node[ja][jai] * xin; 00747 if( jai == ja ) 00748 thickness_gauss = thickness / 2.0; 00749 else 00750 thickness_gauss = 0.; 00751 cc += thickness_gauss * normal_at_nodes[jai]; 00752 } 00753 } 00754 00755 normal_at_point = aa * bb; 00756 double sign_jacobian = ( tri_normal % normal_at_point ) > 0 ? 1. : -1.; 00757 distrt = sign_jacobian * ( cc % normal_at_point ); 00758 00759 if( distrt < distortion ) distortion = distrt; 00760 } 00761 if( element_area * thickness != 0 ) 00762 distortion *= 1. / ( element_area * thickness ); 00763 else 00764 distortion *= 1.; 00765 00766 if( distortion > 0 ) return (double)VERDICT_MIN( distortion, VERDICT_DBL_MAX ); 00767 return (double)VERDICT_MAX( distortion, -VERDICT_DBL_MAX ); 00768 } 00769 00770 /*! 00771 tri_quality for calculating multiple tri metrics at once 00772 00773 using this method is generally faster than using the individual 00774 method multiple times. 00775 00776 */ 00777 C_FUNC_DEF void v_tri_quality( int num_nodes, 00778 double coordinates[][3], 00779 unsigned int metrics_request_flag, 00780 TriMetricVals* metric_vals ) 00781 { 00782 00783 memset( metric_vals, 0, sizeof( TriMetricVals ) ); 00784 00785 // for starts, lets set up some basic and common information 00786 00787 /* node numbers and side numbers used below 00788 00789 2 00790 ++ 00791 / \ 00792 2 / \ 1 00793 / \ 00794 / \ 00795 0 ---------+ 1 00796 0 00797 */ 00798 00799 // vectors for each side 00800 VerdictVector sides[3]; 00801 sides[0].set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00802 coordinates[1][2] - coordinates[0][2] ); 00803 sides[1].set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00804 coordinates[2][2] - coordinates[1][2] ); 00805 sides[2].set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1], 00806 coordinates[2][2] - coordinates[0][2] ); 00807 VerdictVector tri_normal = sides[0] * sides[2]; 00808 // if we have access to normal information, check to see if the 00809 // element is inverted. If we don't have the normal information 00810 // that we need for this, assume the element is not inverted. 00811 // This flag will be used for condition number, jacobian, shape, 00812 // and size and shape. 00813 bool is_inverted = false; 00814 if( compute_normal ) 00815 { 00816 // center of tri 00817 double point[3], surf_normal[3]; 00818 point[0] = ( coordinates[0][0] + coordinates[1][0] + coordinates[2][0] ) / 3; 00819 point[1] = ( coordinates[0][1] + coordinates[1][1] + coordinates[2][1] ) / 3; 00820 point[2] = ( coordinates[0][2] + coordinates[1][2] + coordinates[2][2] ) / 3; 00821 // dot product 00822 compute_normal( point, surf_normal ); 00823 if( ( tri_normal.x() * surf_normal[0] + tri_normal.y() * surf_normal[1] + tri_normal.z() * surf_normal[2] ) < 00824 0 ) 00825 is_inverted = true; 00826 } 00827 00828 // lengths squared of each side 00829 double sides_lengths_squared[3]; 00830 sides_lengths_squared[0] = sides[0].length_squared(); 00831 sides_lengths_squared[1] = sides[1].length_squared(); 00832 sides_lengths_squared[2] = sides[2].length_squared(); 00833 00834 // if we are doing angle calcuations 00835 if( metrics_request_flag & ( V_TRI_MINIMUM_ANGLE | V_TRI_MAXIMUM_ANGLE ) ) 00836 { 00837 // which is short and long side 00838 int short_side = 0, long_side = 0; 00839 00840 if( sides_lengths_squared[1] < sides_lengths_squared[0] ) short_side = 1; 00841 if( sides_lengths_squared[2] < sides_lengths_squared[short_side] ) short_side = 2; 00842 00843 if( sides_lengths_squared[1] > sides_lengths_squared[0] ) long_side = 1; 00844 if( sides_lengths_squared[2] > sides_lengths_squared[long_side] ) long_side = 2; 00845 00846 // calculate the minimum angle of the tri 00847 if( metrics_request_flag & V_TRI_MINIMUM_ANGLE ) 00848 { 00849 if( sides_lengths_squared[0] == 0.0 || sides_lengths_squared[1] == 0.0 || sides_lengths_squared[2] == 0.0 ) 00850 { 00851 metric_vals->minimum_angle = 0.0; 00852 } 00853 else if( short_side == 0 ) 00854 metric_vals->minimum_angle = (double)sides[2].interior_angle( sides[1] ); 00855 else if( short_side == 1 ) 00856 metric_vals->minimum_angle = (double)sides[0].interior_angle( sides[2] ); 00857 else 00858 metric_vals->minimum_angle = (double)sides[0].interior_angle( -sides[1] ); 00859 } 00860 00861 // calculate the maximum angle of the tri 00862 if( metrics_request_flag & V_TRI_MAXIMUM_ANGLE ) 00863 { 00864 if( sides_lengths_squared[0] == 0.0 || sides_lengths_squared[1] == 0.0 || sides_lengths_squared[2] == 0.0 ) 00865 { 00866 metric_vals->maximum_angle = 0.0; 00867 } 00868 else if( long_side == 0 ) 00869 metric_vals->maximum_angle = (double)sides[2].interior_angle( sides[1] ); 00870 else if( long_side == 1 ) 00871 metric_vals->maximum_angle = (double)sides[0].interior_angle( sides[2] ); 00872 else 00873 metric_vals->maximum_angle = (double)sides[0].interior_angle( -sides[1] ); 00874 } 00875 } 00876 00877 // calculate the area of the tri 00878 // the following metrics depend on area 00879 if( metrics_request_flag & 00880 ( V_TRI_AREA | V_TRI_SCALED_JACOBIAN | V_TRI_SHAPE | V_TRI_RELATIVE_SIZE_SQUARED | V_TRI_SHAPE_AND_SIZE ) ) 00881 { 00882 metric_vals->area = (double)( ( sides[0] * sides[2] ).length() * 0.5 ); 00883 } 00884 00885 // calculate the aspect ratio 00886 if( metrics_request_flag & V_TRI_ASPECT_FROBENIUS ) 00887 { 00888 // sum the lengths squared 00889 double srms = sides_lengths_squared[0] + sides_lengths_squared[1] + sides_lengths_squared[2]; 00890 00891 // calculate once and reuse 00892 static const double twoTimesRootOf3 = 2 * sqrt( 3.0 ); 00893 00894 double div = ( twoTimesRootOf3 * ( ( sides[0] * sides[2] ).length() ) ); 00895 00896 if( div == 0.0 ) 00897 metric_vals->aspect_frobenius = (double)VERDICT_DBL_MAX; 00898 else 00899 metric_vals->aspect_frobenius = (double)( srms / div ); 00900 } 00901 00902 // calculate the scaled jacobian 00903 if( metrics_request_flag & V_TRI_SCALED_JACOBIAN ) 00904 { 00905 // calculate once and reuse 00906 static const double twoOverRootOf3 = 2 / sqrt( 3.0 ); 00907 // use the area from above 00908 00909 double tmp = tri_normal.length() * twoOverRootOf3; 00910 00911 // now scale it by the lengths of the sides 00912 double min_scaled_jac = VERDICT_DBL_MAX; 00913 double temp_scaled_jac; 00914 for( int i = 0; i < 3; i++ ) 00915 { 00916 if( sides_lengths_squared[i % 3] == 0.0 || sides_lengths_squared[( i + 2 ) % 3] == 0.0 ) 00917 temp_scaled_jac = 0.0; 00918 else 00919 temp_scaled_jac = 00920 tmp / sqrt( sides_lengths_squared[i % 3] ) / sqrt( sides_lengths_squared[( i + 2 ) % 3] ); 00921 if( temp_scaled_jac < min_scaled_jac ) min_scaled_jac = temp_scaled_jac; 00922 } 00923 // multiply by -1 if the normals are in opposite directions 00924 if( is_inverted ) 00925 { 00926 min_scaled_jac *= -1; 00927 } 00928 metric_vals->scaled_jacobian = (double)min_scaled_jac; 00929 } 00930 00931 // calculate the condition number 00932 if( metrics_request_flag & V_TRI_CONDITION ) 00933 { 00934 // calculate once and reuse 00935 static const double rootOf3 = sqrt( 3.0 ); 00936 // if it is inverted, the condition number is considered to be infinity. 00937 if( is_inverted ) 00938 { 00939 metric_vals->condition = VERDICT_DBL_MAX; 00940 } 00941 else 00942 { 00943 double area2x = ( sides[0] * sides[2] ).length(); 00944 if( area2x == 0.0 ) 00945 metric_vals->condition = (double)( VERDICT_DBL_MAX ); 00946 else 00947 metric_vals->condition = (double)( ( sides[0] % sides[0] + sides[2] % sides[2] - sides[0] % sides[2] ) / 00948 ( area2x * rootOf3 ) ); 00949 } 00950 } 00951 00952 // calculate the shape 00953 if( metrics_request_flag & V_TRI_SHAPE || metrics_request_flag & V_TRI_SHAPE_AND_SIZE ) 00954 { 00955 // if element is inverted, shape is zero. We don't need to 00956 // calculate anything. 00957 if( is_inverted ) 00958 { 00959 metric_vals->shape = 0.0; 00960 } 00961 else 00962 { // otherwise, we calculate the shape 00963 // calculate once and reuse 00964 static const double rootOf3 = sqrt( 3.0 ); 00965 // reuse area from before 00966 double area2x = metric_vals->area * 2; 00967 // dot products 00968 double dots[3] = { sides[0] % sides[0], sides[2] % sides[2], sides[0] % sides[2] }; 00969 00970 // add the dots 00971 double sum_dots = dots[0] + dots[1] - dots[2]; 00972 00973 // then the finale 00974 if( sum_dots == 0.0 ) 00975 metric_vals->shape = 0.0; 00976 else 00977 metric_vals->shape = (double)( rootOf3 * area2x / sum_dots ); 00978 } 00979 } 00980 00981 // calculate relative size squared 00982 if( metrics_request_flag & V_TRI_RELATIVE_SIZE_SQUARED || metrics_request_flag & V_TRI_SHAPE_AND_SIZE ) 00983 { 00984 // get weights 00985 double w11, w21, w12, w22; 00986 v_tri_get_weight( w11, w21, w12, w22 ); 00987 // get the determinant 00988 double detw = determinant( w11, w21, w12, w22 ); 00989 // use the area from above and divide with the determinant 00990 if( metric_vals->area == 0.0 || detw == 0.0 ) 00991 metric_vals->relative_size_squared = 0.0; 00992 else 00993 { 00994 double size = metric_vals->area * 2.0 / detw; 00995 // square the size 00996 size *= size; 00997 // value ranges between 0 to 1 00998 metric_vals->relative_size_squared = (double)VERDICT_MIN( size, 1.0 / size ); 00999 } 01000 } 01001 01002 // calculate shape and size 01003 if( metrics_request_flag & V_TRI_SHAPE_AND_SIZE ) 01004 { 01005 metric_vals->shape_and_size = metric_vals->relative_size_squared * metric_vals->shape; 01006 } 01007 01008 // calculate distortion 01009 if( metrics_request_flag & V_TRI_DISTORTION ) metric_vals->distortion = v_tri_distortion( num_nodes, coordinates ); 01010 01011 // take care of any over-flow problems 01012 if( metric_vals->aspect_frobenius > 0 ) 01013 metric_vals->aspect_frobenius = (double)VERDICT_MIN( metric_vals->aspect_frobenius, VERDICT_DBL_MAX ); 01014 else 01015 metric_vals->aspect_frobenius = (double)VERDICT_MAX( metric_vals->aspect_frobenius, -VERDICT_DBL_MAX ); 01016 01017 if( metric_vals->area > 0 ) 01018 metric_vals->area = (double)VERDICT_MIN( metric_vals->area, VERDICT_DBL_MAX ); 01019 else 01020 metric_vals->area = (double)VERDICT_MAX( metric_vals->area, -VERDICT_DBL_MAX ); 01021 01022 if( metric_vals->minimum_angle > 0 ) 01023 metric_vals->minimum_angle = (double)VERDICT_MIN( metric_vals->minimum_angle, VERDICT_DBL_MAX ); 01024 else 01025 metric_vals->minimum_angle = (double)VERDICT_MAX( metric_vals->minimum_angle, -VERDICT_DBL_MAX ); 01026 01027 if( metric_vals->maximum_angle > 0 ) 01028 metric_vals->maximum_angle = (double)VERDICT_MIN( metric_vals->maximum_angle, VERDICT_DBL_MAX ); 01029 else 01030 metric_vals->maximum_angle = (double)VERDICT_MAX( metric_vals->maximum_angle, -VERDICT_DBL_MAX ); 01031 01032 if( metric_vals->condition > 0 ) 01033 metric_vals->condition = (double)VERDICT_MIN( metric_vals->condition, VERDICT_DBL_MAX ); 01034 else 01035 metric_vals->condition = (double)VERDICT_MAX( metric_vals->condition, -VERDICT_DBL_MAX ); 01036 01037 if( metric_vals->shape > 0 ) 01038 metric_vals->shape = (double)VERDICT_MIN( metric_vals->shape, VERDICT_DBL_MAX ); 01039 else 01040 metric_vals->shape = (double)VERDICT_MAX( metric_vals->shape, -VERDICT_DBL_MAX ); 01041 01042 if( metric_vals->scaled_jacobian > 0 ) 01043 metric_vals->scaled_jacobian = (double)VERDICT_MIN( metric_vals->scaled_jacobian, VERDICT_DBL_MAX ); 01044 else 01045 metric_vals->scaled_jacobian = (double)VERDICT_MAX( metric_vals->scaled_jacobian, -VERDICT_DBL_MAX ); 01046 01047 if( metric_vals->relative_size_squared > 0 ) 01048 metric_vals->relative_size_squared = (double)VERDICT_MIN( metric_vals->relative_size_squared, VERDICT_DBL_MAX ); 01049 else 01050 metric_vals->relative_size_squared = 01051 (double)VERDICT_MAX( metric_vals->relative_size_squared, -VERDICT_DBL_MAX ); 01052 01053 if( metric_vals->shape_and_size > 0 ) 01054 metric_vals->shape_and_size = (double)VERDICT_MIN( metric_vals->shape_and_size, VERDICT_DBL_MAX ); 01055 else 01056 metric_vals->shape_and_size = (double)VERDICT_MAX( metric_vals->shape_and_size, -VERDICT_DBL_MAX ); 01057 01058 if( metric_vals->distortion > 0 ) 01059 metric_vals->distortion = (double)VERDICT_MIN( metric_vals->distortion, VERDICT_DBL_MAX ); 01060 else 01061 metric_vals->distortion = (double)VERDICT_MAX( metric_vals->distortion, -VERDICT_DBL_MAX ); 01062 01063 if( metrics_request_flag & V_TRI_EDGE_RATIO ) 01064 { 01065 metric_vals->edge_ratio = v_tri_edge_ratio( 3, coordinates ); 01066 } 01067 if( metrics_request_flag & V_TRI_RADIUS_RATIO ) 01068 { 01069 metric_vals->radius_ratio = v_tri_radius_ratio( 3, coordinates ); 01070 } 01071 if( metrics_request_flag & V_TRI_ASPECT_FROBENIUS ) // there is no V_TRI_ASPECT_RATIO ! 01072 { 01073 metric_vals->aspect_ratio = v_tri_radius_ratio( 3, coordinates ); 01074 } 01075 }
