MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef SCD_ELEMENT_DATA_HPP 00017 #define SCD_ELEMENT_DATA_HPP 00018 00019 // 00020 // Class: ScdElementData 00021 // 00022 // Purpose: represent a rectangular element of mesh 00023 // 00024 // A ScdElement represents a rectangular element of mesh, including both vertices and 00025 // elements, and the parametric space used to address that element. Vertex data, 00026 // i.e. coordinates, may not be stored directly in the element, but the element returns 00027 // information about the vertex handles of vertices in the element. Vertex and element 00028 // handles associated with the element are each contiguous. 00029 00030 #include "SequenceData.hpp" 00031 #include "moab/HomXform.hpp" 00032 #include "moab/CN.hpp" 00033 #include "ScdVertexData.hpp" 00034 #include "Internals.hpp" 00035 #include "moab/Range.hpp" 00036 00037 #include <vector> 00038 #include <algorithm> 00039 00040 namespace moab 00041 { 00042 00043 class ScdElementData : public SequenceData 00044 { 00045 00046 //! structure to hold references to bounding vertex blocks 00047 class VertexDataRef 00048 { 00049 private: 00050 HomCoord minmax[2]; 00051 HomXform xform, invXform; 00052 ScdVertexData* srcSeq; 00053 00054 public: 00055 friend class ScdElementData; 00056 00057 VertexDataRef( const HomCoord& min, const HomCoord& max, const HomXform& tmp_xform, ScdVertexData* this_seq ); 00058 00059 bool contains( const HomCoord& coords ) const; 00060 }; 00061 00062 private: 00063 //! parameter min/max/stride for vertices, in homogeneous coords ijkh; elements 00064 //! are one less than max 00065 HomCoord boxParams[3]; 00066 00067 //! difference between max and min params plus one (i.e. # VERTICES in 00068 //! each parametric direction) 00069 int dIJK[3]; 00070 00071 //! difference between max and min params (i.e. # ELEMENTS in 00072 //! each parametric direction) 00073 int dIJKm1[3]; 00074 00075 //! whether scd element rectangle is periodic in i and possibly j 00076 int isPeriodic[2]; 00077 00078 //! bare constructor, so compiler doesn't create one for me 00079 ScdElementData(); 00080 00081 //! list of bounding vertex blocks 00082 std::vector< VertexDataRef > vertexSeqRefs; 00083 00084 public: 00085 //! constructor 00086 ScdElementData( EntityHandle start_handle, 00087 const int imin, 00088 const int jmin, 00089 const int kmin, 00090 const int imax, 00091 const int jmax, 00092 const int kmax, 00093 int* is_periodic ); 00094 00095 virtual ~ScdElementData(); 00096 00097 //! get handle of vertex at homogeneous coords 00098 inline EntityHandle get_vertex( const HomCoord& coords ) const; 00099 inline EntityHandle get_vertex( int i, int j, int k ) const 00100 { 00101 return get_vertex( HomCoord( i, j, k ) ); 00102 } 00103 00104 //! get handle of element at i, j, k 00105 EntityHandle get_element( const int i, const int j, const int k ) const; 00106 00107 //! get min params for this element 00108 const HomCoord& min_params() const; 00109 00110 //! get max params for this element 00111 const HomCoord& max_params() const; 00112 00113 //! get the number of vertices in each direction, inclusive 00114 void param_extents( int& di, int& dj, int& dk ) const; 00115 00116 //! given a handle, get the corresponding parameters 00117 ErrorCode get_params( const EntityHandle ehandle, int& i, int& j, int& k ) const; 00118 00119 //! return whether rectangle is periodic in i 00120 inline int is_periodic_i() const 00121 { 00122 return isPeriodic[0]; 00123 }; 00124 00125 //! return whether rectangle is periodic in j 00126 inline int is_periodic_j() const 00127 { 00128 return isPeriodic[1]; 00129 }; 00130 00131 inline void is_periodic( int is_p[2] ) const 00132 { 00133 is_p[0] = isPeriodic[0]; 00134 is_p[1] = isPeriodic[1]; 00135 } 00136 00137 //! convenience functions for parameter extents 00138 int i_min() const 00139 { 00140 return ( boxParams[0].hom_coord() )[0]; 00141 } 00142 int j_min() const 00143 { 00144 return ( boxParams[0].hom_coord() )[1]; 00145 } 00146 int k_min() const 00147 { 00148 return ( boxParams[0].hom_coord() )[2]; 00149 } 00150 int i_max() const 00151 { 00152 return ( boxParams[1].hom_coord() )[0]; 00153 } 00154 int j_max() const 00155 { 00156 return ( boxParams[1].hom_coord() )[1]; 00157 } 00158 int k_max() const 00159 { 00160 return ( boxParams[1].hom_coord() )[2]; 00161 } 00162 00163 //! test the bounding vertex sequences and determine whether they fully 00164 //! define the vertices covering this element block's parameter space 00165 bool boundary_complete() const; 00166 00167 //! test whether this sequence contains these parameters 00168 inline bool contains( const HomCoord& coords ) const; 00169 00170 //! test whether *vertex parameterization* in this sequence contains these parameters 00171 inline bool contains_vertex( const HomCoord& coords ) const; 00172 00173 //! get connectivity of an entity given entity's parameters 00174 inline ErrorCode get_params_connectivity( const int i, 00175 const int j, 00176 const int k, 00177 std::vector< EntityHandle >& connectivity ) const; 00178 00179 //! add a vertex seq ref to this element sequence; 00180 //! if bb_input is true, bounding box (in eseq-local coords) of vseq being added 00181 //! is input in bb_min and bb_max (allows partial sharing of vseq rather than the whole 00182 //! vseq); if it's false, the whole vseq is referenced and the eseq-local coordinates 00183 //! is computed from the transformed bounding box of the vseq 00184 ErrorCode add_vsequence( ScdVertexData* vseq, 00185 const HomCoord& p1, 00186 const HomCoord& q1, 00187 const HomCoord& p2, 00188 const HomCoord& q2, 00189 const HomCoord& p3, 00190 const HomCoord& q3, 00191 bool bb_input = false, 00192 const HomCoord& bb_min = HomCoord::unitv[0], 00193 const HomCoord& bb_max = HomCoord::unitv[0] ); 00194 00195 SequenceData* subset( EntityHandle start, 00196 EntityHandle end, 00197 const int* sequence_data_sizes, 00198 const int* tag_data_sizes ) const; 00199 00200 static EntityID calc_num_entities( EntityHandle start_handle, 00201 int irange, 00202 int jrange, 00203 int krange, 00204 int* is_periodic = NULL ); 00205 00206 unsigned long get_memory_use() const; 00207 }; 00208 00209 inline EntityHandle ScdElementData::get_element( const int i, const int j, const int k ) const 00210 { 00211 return start_handle() + ( i - i_min() ) + ( j - j_min() ) * dIJKm1[0] + ( k - k_min() ) * dIJKm1[0] * dIJKm1[1]; 00212 } 00213 00214 inline const HomCoord& ScdElementData::min_params() const 00215 { 00216 return boxParams[0]; 00217 } 00218 00219 inline const HomCoord& ScdElementData::max_params() const 00220 { 00221 return boxParams[1]; 00222 } 00223 00224 //! get the number of vertices in each direction, inclusive 00225 inline void ScdElementData::param_extents( int& di, int& dj, int& dk ) const 00226 { 00227 di = dIJK[0]; 00228 dj = dIJK[1]; 00229 dk = dIJK[2]; 00230 } 00231 00232 inline ErrorCode ScdElementData::get_params( const EntityHandle ehandle, int& i, int& j, int& k ) const 00233 { 00234 if( TYPE_FROM_HANDLE( ehandle ) != TYPE_FROM_HANDLE( start_handle() ) ) return MB_FAILURE; 00235 00236 int hdiff = ehandle - start_handle(); 00237 00238 // use double ?: test below because on some platforms, both sides of the : are 00239 // evaluated, and if dIJKm1[1] is zero, that'll generate a divide-by-zero 00240 k = ( dIJKm1[1] > 0 ? hdiff / ( dIJKm1[1] > 0 ? dIJKm1[0] * dIJKm1[1] : 1 ) : 0 ); 00241 j = ( hdiff - ( k * dIJKm1[0] * dIJKm1[1] ) ) / dIJKm1[0]; 00242 i = hdiff % dIJKm1[0]; 00243 00244 k += boxParams[0].k(); 00245 j += boxParams[0].j(); 00246 i += boxParams[0].i(); 00247 00248 return ( ehandle >= start_handle() && ehandle < start_handle() + size() && i >= i_min() && i <= i_max() && 00249 j >= j_min() && j <= j_max() && k >= k_min() && k <= k_max() ) 00250 ? MB_SUCCESS 00251 : MB_FAILURE; 00252 } 00253 00254 inline bool ScdElementData::contains( const HomCoord& temp ) const 00255 { 00256 // upper bound is < instead of <= because element params max is one less 00257 // than vertex params max, except in case of 2d or 1d sequence 00258 return ( ( dIJKm1[0] && temp.i() >= boxParams[0].i() && temp.i() < boxParams[0].i() + dIJKm1[0] ) && 00259 ( ( !dIJKm1[1] && temp.j() == boxParams[1].j() ) || 00260 ( dIJKm1[1] && temp.j() >= boxParams[0].j() && temp.j() < boxParams[0].j() + dIJKm1[1] ) ) && 00261 ( ( !dIJKm1[2] && temp.k() == boxParams[1].k() ) || 00262 ( dIJKm1[2] && temp.k() >= boxParams[0].k() && temp.k() < boxParams[0].k() + dIJKm1[2] ) ) ); 00263 } 00264 00265 inline bool ScdElementData::contains_vertex( const HomCoord& temp ) const 00266 { 00267 // upper bound is < instead of <= because element params max is one less 00268 // than vertex params max, except in case of 2d or 1d sequence 00269 return ( ( dIJK[0] && temp.i() >= boxParams[0].i() && temp.i() < boxParams[0].i() + dIJK[0] ) && 00270 ( ( !dIJK[1] && temp.j() == boxParams[1].j() ) || 00271 ( dIJK[1] && temp.j() >= boxParams[0].j() && temp.j() < boxParams[0].j() + dIJK[1] ) ) && 00272 ( ( !dIJK[2] && temp.k() == boxParams[1].k() ) || 00273 ( dIJK[2] && temp.k() >= boxParams[0].k() && temp.k() < boxParams[0].k() + dIJK[2] ) ) ); 00274 } 00275 00276 inline bool ScdElementData::VertexDataRef::contains( const HomCoord& coords ) const 00277 { 00278 return ( minmax[0] <= coords && minmax[1] >= coords ); 00279 } 00280 00281 inline ScdElementData::VertexDataRef::VertexDataRef( const HomCoord& this_min, 00282 const HomCoord& this_max, 00283 const HomXform& tmp_xform, 00284 ScdVertexData* this_seq ) 00285 : xform( tmp_xform ), invXform( tmp_xform.inverse() ), srcSeq( this_seq ) 00286 { 00287 minmax[0] = HomCoord( this_min ); 00288 minmax[1] = HomCoord( this_max ); 00289 } 00290 00291 inline EntityHandle ScdElementData::get_vertex( const HomCoord& coords ) const 00292 { 00293 assert( boundary_complete() ); 00294 for( std::vector< VertexDataRef >::const_iterator it = vertexSeqRefs.begin(); it != vertexSeqRefs.end(); ++it ) 00295 { 00296 if( ( *it ).minmax[0] <= coords && ( *it ).minmax[1] >= coords ) 00297 { 00298 // first get the vertex block-local parameters 00299 HomCoord local_coords = coords / ( *it ).xform; 00300 00301 assert( ( *it ).srcSeq->contains( local_coords ) ); 00302 00303 // now get the vertex handle for those coords 00304 return ( *it ).srcSeq->get_vertex( local_coords ); 00305 } 00306 } 00307 00308 // got here, it's an error 00309 return 0; 00310 } 00311 00312 inline ErrorCode ScdElementData::add_vsequence( ScdVertexData* vseq, 00313 const HomCoord& p1, 00314 const HomCoord& q1, 00315 const HomCoord& p2, 00316 const HomCoord& q2, 00317 const HomCoord& p3, 00318 const HomCoord& q3, 00319 bool bb_input, 00320 const HomCoord& bb_min, 00321 const HomCoord& bb_max ) 00322 { 00323 // compute the transform given the vseq-local parameters and the mapping to 00324 // this element sequence's parameters passed in minmax 00325 HomXform M; 00326 M.three_pt_xform( p1, q1, p2, q2, p3, q3 ); 00327 00328 // min and max in element seq's parameter system may not be same as those in 00329 // vseq's system, so need to take min/max 00330 00331 HomCoord minmax[2]; 00332 if( bb_input ) 00333 { 00334 minmax[0] = bb_min; 00335 minmax[1] = bb_max; 00336 } 00337 else 00338 { 00339 minmax[0] = vseq->min_params() * M; 00340 minmax[1] = vseq->max_params() * M; 00341 } 00342 00343 // check against other vseq's to make sure they don't overlap 00344 for( std::vector< VertexDataRef >::const_iterator vsit = vertexSeqRefs.begin(); vsit != vertexSeqRefs.end(); 00345 ++vsit ) 00346 if( ( *vsit ).contains( minmax[0] ) || ( *vsit ).contains( minmax[1] ) ) return MB_FAILURE; 00347 00348 HomCoord tmp_min( std::min( minmax[0].i(), minmax[1].i() ), std::min( minmax[0].j(), minmax[1].j() ), 00349 std::min( minmax[0].k(), minmax[1].k() ) ); 00350 HomCoord tmp_max( std::max( minmax[0].i(), minmax[1].i() ), std::max( minmax[0].j(), minmax[1].j() ), 00351 std::max( minmax[0].k(), minmax[1].k() ) ); 00352 00353 // set up a new vertex sequence reference 00354 VertexDataRef tmp_seq_ref( tmp_min, tmp_max, M, vseq ); 00355 00356 // add to the list 00357 vertexSeqRefs.push_back( tmp_seq_ref ); 00358 00359 return MB_SUCCESS; 00360 } 00361 00362 inline ErrorCode ScdElementData::get_params_connectivity( const int i, 00363 const int j, 00364 const int k, 00365 std::vector< EntityHandle >& connectivity ) const 00366 { 00367 if( contains( HomCoord( i, j, k ) ) == false ) return MB_FAILURE; 00368 00369 int ip1 = ( isPeriodic[0] ? ( i + 1 ) % dIJKm1[0] : i + 1 ), 00370 jp1 = ( isPeriodic[1] ? ( j + 1 ) % dIJKm1[1] : j + 1 ); 00371 00372 connectivity.push_back( get_vertex( i, j, k ) ); 00373 connectivity.push_back( get_vertex( ip1, j, k ) ); 00374 if( CN::Dimension( TYPE_FROM_HANDLE( start_handle() ) ) < 2 ) return MB_SUCCESS; 00375 connectivity.push_back( get_vertex( ip1, jp1, k ) ); 00376 connectivity.push_back( get_vertex( i, jp1, k ) ); 00377 if( CN::Dimension( TYPE_FROM_HANDLE( start_handle() ) ) < 3 ) return MB_SUCCESS; 00378 connectivity.push_back( get_vertex( i, j, k + 1 ) ); 00379 connectivity.push_back( get_vertex( ip1, j, k + 1 ) ); 00380 connectivity.push_back( get_vertex( ip1, jp1, k + 1 ) ); 00381 connectivity.push_back( get_vertex( i, jp1, k + 1 ) ); 00382 return MB_SUCCESS; 00383 } 00384 00385 } // namespace moab 00386 00387 #endif
