MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/Range.hpp" 00003 #include "moab/ScdInterface.hpp" 00004 #include "moab/HomXform.hpp" 00005 #include "moab/ReadUtilIface.hpp" 00006 #include "TestUtil.hpp" 00007 #include <cstdlib> 00008 #include <algorithm> 00009 00010 void test_coords_connect_iterate(); 00011 void test_scd_invalid(); 00012 void test_iterates(); 00013 00014 using namespace moab; 00015 00016 int main() 00017 { 00018 int failures = 0; 00019 00020 failures += RUN_TEST( test_coords_connect_iterate ); 00021 failures += RUN_TEST( test_scd_invalid ); 00022 failures += RUN_TEST( test_iterates ); 00023 00024 if( failures ) std::cerr << "<<<< " << failures << " TESTS FAILED >>>>" << std::endl; 00025 00026 return failures; 00027 } 00028 00029 void test_coords_connect_iterate() 00030 { 00031 // create 1000 vertices 00032 const unsigned int NUM_VTX = 1000; 00033 Core moab; 00034 Interface& mb = moab; 00035 std::vector< double > coords( 3 * NUM_VTX ); 00036 for( unsigned int i = 0; i < NUM_VTX; i++ ) 00037 coords[3 * i] = coords[3 * i + 1] = coords[3 * i + 2] = i; 00038 00039 Range verts, hexes, faces, edges, dead; 00040 ErrorCode rval = mb.create_vertices( &coords[0], NUM_VTX, verts );CHECK_ERR( rval ); 00041 00042 // create a bunch of hexes from those 00043 ReadUtilIface* rui; 00044 EntityHandle *orig_connect, start_hex; 00045 rval = mb.query_interface( rui );CHECK_ERR( rval ); 00046 rval = rui->get_element_connect( NUM_VTX / 8, 8, MBHEX, 1, start_hex, orig_connect );CHECK_ERR( rval ); 00047 std::copy( verts.begin(), verts.end(), orig_connect ); 00048 hexes.insert( start_hex, start_hex + NUM_VTX / 8 - 1 ); 00049 00050 // delete about 1% of vertices 00051 const int step = 100; 00052 int remaining = NUM_VTX; 00053 Range::iterator vit = verts.begin(); 00054 EntityHandle entities[2]; 00055 for( int j = 0; j < remaining; j += step ) 00056 { 00057 entities[0] = start_hex + j / 8; 00058 entities[1] = *vit; 00059 rval = mb.delete_entities( entities, 2 );CHECK_ERR( rval ); 00060 dead.insert( *vit ); 00061 dead.insert( start_hex + j / 8 ); 00062 vit = verts.erase( vit ); 00063 vit += step - 1; 00064 hexes.erase( start_hex + j / 8 ); 00065 } 00066 00067 // Remove some additional values from the range 00068 // so that our handle blocks don't always align with 00069 // sequences 00070 verts.erase( verts.begin() + ( step - 5 ), verts.begin() + ( step + 5 ) ); 00071 hexes.erase( hexes.begin() + ( step / 8 - 5 ), hexes.begin() + ( step / 8 + 5 ) ); 00072 00073 // Check that we get back expected values 00074 double *xcoord, *ycoord, *zcoord; 00075 vit = verts.begin(); 00076 int count, total = 0; 00077 while( vit != verts.end() ) 00078 { 00079 rval = mb.coords_iterate( vit, verts.end(), xcoord, ycoord, zcoord, count ); 00080 if( MB_SUCCESS && ( !xcoord || !ycoord || !zcoord ) ) rval = MB_FAILURE;CHECK_ERR( rval ); 00081 00082 assert( total + count <= (int)verts.size() ); 00083 for( int i = 0; i < count; i++ ) 00084 { 00085 // vertex handles start at 1, so need to subtract one 00086 double val = *vit + (double)i - 1.0; 00087 CHECK_REAL_EQUAL( val, xcoord[i], 1.0e-10 ); 00088 CHECK_REAL_EQUAL( val, ycoord[i], 1.0e-10 ); 00089 CHECK_REAL_EQUAL( val, zcoord[i], 1.0e-10 ); 00090 } 00091 00092 // Check that we can set values and get the right values back 00093 for( int i = 0; i < count; i++ ) 00094 { 00095 xcoord[i] *= 2.0; 00096 ycoord[i] *= 2.0; 00097 zcoord[i] *= 2.0; 00098 } 00099 00100 std::vector< double > dum( 3 * count ); 00101 Range dum_verts( *vit, *vit + count - 1 ); 00102 rval = mb.get_coords( dum_verts, &dum[0] );CHECK_ERR( rval ); 00103 for( int i = 0; i < count; i++ ) 00104 { 00105 // vertex handles start at 1, so need to subtract 1 from expected value 00106 double val = 2.0 * ( *vit + (double)i - 1 ); 00107 CHECK_REAL_EQUAL( val, xcoord[i], 1.0e-10 ); 00108 CHECK_REAL_EQUAL( val, ycoord[i], 1.0e-10 ); 00109 CHECK_REAL_EQUAL( val, zcoord[i], 1.0e-10 ); 00110 } 00111 00112 vit += count; 00113 total += count; 00114 } 00115 00116 // now check connectivity 00117 Range::iterator hit = hexes.begin(); 00118 EntityHandle* connect = NULL; 00119 EntityHandle dum_connect[8]; 00120 int num_connect; 00121 while( hit != hexes.end() ) 00122 { 00123 rval = mb.connect_iterate( hit, hexes.end(), connect, num_connect, count ); 00124 if( MB_SUCCESS && !connect ) rval = MB_FAILURE;CHECK_ERR( rval ); 00125 CHECK_EQUAL( num_connect, 8 ); 00126 00127 // should be equal to initial connectivity 00128 for( int i = 0; i < count; i++ ) 00129 { 00130 EntityHandle first = 8 * ( *hit - start_hex + i ) + 1; 00131 for( unsigned int j = 0; j < 8; j++ ) 00132 dum_connect[j] = first + j; 00133 CHECK_ARRAYS_EQUAL( connect, 8, &dum_connect[0], 8 ); 00134 connect += 8; 00135 } 00136 00137 hit += count; 00138 // total += count; 00139 } 00140 00141 // ok, done 00142 } 00143 00144 void test_scd_invalid() 00145 { 00146 // check that we get errors from structured mesh 00147 Core moab; 00148 Interface& mb = moab; 00149 ScdInterface* scdi; 00150 ErrorCode rval = mb.query_interface( scdi );CHECK_ERR( rval ); 00151 00152 // make an arbitrary structured mesh 00153 const int NUM_DIMS = 10; 00154 HomCoord low( 0, 0, 0 ), high( NUM_DIMS, NUM_DIMS, NUM_DIMS ); 00155 ScdBox* new_box = NULL; 00156 rval = scdi->construct_box( low, high, NULL, 0, new_box );CHECK_ERR( rval ); 00157 CHECK( new_box != NULL ); 00158 00159 EntityHandle start_hex = new_box->start_element(); 00160 Range hexes( start_hex, start_hex + NUM_DIMS * NUM_DIMS * NUM_DIMS - 1 ); 00161 00162 // should be able to get vertices used by this box 00163 Range verts; 00164 rval = mb.get_adjacencies( hexes, 0, false, verts, Interface::UNION );CHECK_ERR( rval ); 00165 CHECK_EQUAL( (int)verts.size(), (int)( ( NUM_DIMS + 1 ) * ( NUM_DIMS + 1 ) * ( NUM_DIMS + 1 ) ) ); 00166 00167 // should NOT be able to get connect iterator 00168 EntityHandle* connect; 00169 int count, num_connect; 00170 // expected failure 00171 rval = mb.connect_iterate( hexes.begin(), hexes.end(), connect, num_connect, count ); 00172 CHECK_EQUAL( rval, MB_FAILURE ); 00173 } 00174 00175 // these tests are for sequences that result in contiguous entity ranges 00176 // sequences are still broken in memory 00177 void test_iterates() 00178 { 00179 // create 400 vertices, in 2 separate sequences 00180 // also, create 50 hexes, in 2 separate sequences 00181 const int NUM_VTX = 400; 00182 const int NUM_HEX = 50; 00183 Core moab; 00184 Interface& mb = moab; 00185 std::vector< double > coords( 3 * NUM_VTX / 2 ); 00186 for( unsigned int i = 0; i < NUM_VTX / 2; i++ ) 00187 { 00188 coords[3 * i] = i; 00189 coords[3 * i + 1] = 10 * i; 00190 coords[3 * i + 2] = 100 * i; 00191 } 00192 00193 Range verts, hexes; 00194 ErrorCode rval = mb.create_vertices( &coords[0], NUM_VTX / 2, verts );CHECK_ERR( rval ); 00195 00196 // create more vertices, with same coordinates 00197 Range v2; 00198 rval = mb.create_vertices( &coords[0], NUM_VTX / 2, v2 );CHECK_ERR( rval ); 00199 Range ver = unite( verts, v2 ); 00200 // range of vertices is contiguous, but its memory for vertices is not!! 00201 CHECK_EQUAL( (int)ver.psize(), 1 ); 00202 // create a bunch of hexes from those 00203 ReadUtilIface* rui; 00204 EntityHandle start_hex; 00205 rval = mb.query_interface( rui );CHECK_ERR( rval ); 00206 00207 Range::iterator vertIter = ver.begin(); 00208 for( int i = 0; i < NUM_HEX; i += NUM_HEX / 2 ) 00209 { 00210 EntityHandle *orig_connect, current_hex; 00211 Range::iterator vertIterEnd = vertIter + ( 25 * 8 ); 00212 rval = rui->get_element_connect( 25, 8, MBHEX, 1, current_hex, orig_connect );CHECK_ERR( rval ); 00213 std::copy( vertIter, vertIterEnd, orig_connect ); 00214 hexes.insert( current_hex, current_hex + 24 ); 00215 vertIter += ( NUM_HEX / 2 * 8 ); 00216 } 00217 00218 // make sure hexes range is contiguous 00219 CHECK_EQUAL( (int)hexes.psize(), 1 ); 00220 start_hex = hexes.front(); 00221 Tag idtag = moab.globalId_tag(); 00222 00223 for( int i = 0; i < NUM_HEX; i++, start_hex++ ) 00224 { 00225 rval = mb.tag_set_data( idtag, &start_hex, 1, &i );CHECK_ERR( rval ); 00226 } 00227 int count = 0; 00228 int total = 0; 00229 00230 // now check connectivity 00231 start_hex = hexes.front(); 00232 Range::iterator hit = hexes.begin(); 00233 EntityHandle* connect = NULL; 00234 EntityHandle dum_connect[8]; 00235 int num_connect; 00236 while( hit != hexes.end() ) 00237 { 00238 rval = mb.connect_iterate( hit, hexes.end(), connect, num_connect, count ); 00239 if( MB_SUCCESS && !connect ) rval = MB_FAILURE; 00240 00241 CHECK_ERR( rval ); 00242 CHECK_EQUAL( num_connect, 8 ); 00243 CHECK_EQUAL( count, NUM_HEX / 2 ); 00244 // should be equal to initial connectivity 00245 for( int i = 0; i < count; i++ ) 00246 { 00247 EntityHandle first = 8 * ( *hit - start_hex + i ) + 1; 00248 for( unsigned int j = 0; j < 8; j++ ) 00249 dum_connect[j] = first + j; 00250 CHECK_ARRAYS_EQUAL( connect, 8, &dum_connect[0], 8 ); 00251 connect += 8; 00252 } 00253 00254 hit += count; 00255 total += count; 00256 } 00257 00258 hit = hexes.begin(); 00259 void* ptr; 00260 while( hit != hexes.end() ) 00261 { 00262 // get contiguous block of tag data, of size of the sequence allocated 00263 rval = mb.tag_iterate( idtag, hit, hexes.end(), count, ptr );CHECK_ERR( rval ); 00264 CHECK_EQUAL( count, NUM_HEX / 2 ); 00265 hit += count; 00266 } 00267 00268 hit = ver.begin(); 00269 // coords_iterate 00270 double* xc; 00271 double* yc; 00272 double* zc; 00273 while( hit != ver.end() ) 00274 { 00275 // get contiguous block of coords 00276 00277 rval = mb.coords_iterate( hit, ver.end(), xc, yc, zc, count );CHECK_ERR( rval ); 00278 CHECK_EQUAL( count, NUM_VTX / 2 ); 00279 hit += count; 00280 } 00281 }
