, including all inherited members.
| allocate_elements(long num_elements, int vert_per_element, EntityType type, EntityHandle &start_handle_out, EntityHandle *&conn_array_out, std::vector< Range > &append_to_this) | moab::ReadVtk | [protected] |
| allocate_vertices(long num_vtx, EntityHandle &start_handle_out, double *&x_coord_array_out, double *&y_coord_array_out, double *&z_coord_array_out) | moab::ReadVtk | [protected] |
| factory(Interface *) | moab::ReadVtk | [static] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadVtk | [virtual] |
| mdbImpl | moab::ReadVtk | [private] |
| mPartitionTagName | moab::ReadVtk | [private] |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::ReadVtk | [virtual] |
| read_vertices(FileTokenizer &tokens, long num_verts, EntityHandle &start_handle_out) | moab::ReadVtk | [protected] |
| readMeshIface | moab::ReadVtk | [private] |
| ReadVtk(Interface *impl=NULL) | moab::ReadVtk | |
| store_file_ids(Tag tag, const Range &vertices, const std::vector< Range > &elements) | moab::ReadVtk | [protected] |
| vtk_create_structured_elems(const long *dims, EntityHandle first_vtx, std::vector< Range > &elem_list) | moab::ReadVtk | [protected] |
| vtk_read_attrib_data(FileTokenizer &tokens, std::vector< Range > &entities) | moab::ReadVtk | [protected] |
| vtk_read_color_attrib(FileTokenizer &tokens, std::vector< Range > &entities, const char *name) | moab::ReadVtk | [protected] |
| vtk_read_dataset(FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &element_list) | moab::ReadVtk | [protected] |
| vtk_read_field(FileTokenizer &tokens) | moab::ReadVtk | [protected] |
| vtk_read_field_attrib(FileTokenizer &tokens, std::vector< Range > &entities, const char *name) | moab::ReadVtk | [protected] |
| vtk_read_polydata(FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list) | moab::ReadVtk | [protected] |
| vtk_read_polygons(FileTokenizer &tokens, EntityHandle first_vtx, std::vector< Range > &elem_list) | moab::ReadVtk | [protected] |
| vtk_read_rectilinear_grid(FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list) | moab::ReadVtk | [protected] |
| vtk_read_scalar_attrib(FileTokenizer &tokens, std::vector< Range > &entities, const char *name) | moab::ReadVtk | [protected] |
| vtk_read_structured_grid(FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list) | moab::ReadVtk | [protected] |
| vtk_read_structured_points(FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list) | moab::ReadVtk | [protected] |
| vtk_read_tag_data(FileTokenizer &tokens, int type, size_t per_elem, std::vector< Range > &entities, const char *name) | moab::ReadVtk | [protected] |
| vtk_read_tensor_attrib(FileTokenizer &tokens, std::vector< Range > &entities, const char *name) | moab::ReadVtk | [protected] |
| vtk_read_texture_attrib(FileTokenizer &tokens, std::vector< Range > &entities, const char *name) | moab::ReadVtk | [protected] |
| vtk_read_unstructured_grid(FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list) | moab::ReadVtk | [protected] |
| vtk_read_vector_attrib(FileTokenizer &tokens, std::vector< Range > &entities, const char *name) | moab::ReadVtk | [protected] |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
| ~ReadVtk() | moab::ReadVtk | [virtual] |
