MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef READ_VTK_HPP 00017 #define READ_VTK_HPP 00018 00019 #include "moab/Forward.hpp" 00020 #include "moab/ReaderIface.hpp" 00021 00022 #include <string> 00023 00024 namespace moab 00025 { 00026 00027 class ReadUtilIface; 00028 class FileTokenizer; 00029 00030 class ReadVtk : public ReaderIface 00031 { 00032 00033 public: 00034 static ReaderIface* factory( Interface* ); 00035 00036 //! load a file 00037 ErrorCode load_file( const char* file_name, 00038 const EntityHandle* file_set, 00039 const FileOptions& opts, 00040 const SubsetList* subset_list = 0, 00041 const Tag* file_id_tag = 0 ); 00042 00043 ErrorCode read_tag_values( const char* file_name, 00044 const char* tag_name, 00045 const FileOptions& opts, 00046 std::vector< int >& tag_values_out, 00047 const SubsetList* subset_list = 0 ); 00048 00049 //! Constructor 00050 ReadVtk( Interface* impl = NULL ); 00051 00052 //! Destructor 00053 virtual ~ReadVtk(); 00054 00055 protected: 00056 ErrorCode allocate_vertices( long num_vtx, 00057 EntityHandle& start_handle_out, 00058 double*& x_coord_array_out, 00059 double*& y_coord_array_out, 00060 double*& z_coord_array_out ); 00061 00062 ErrorCode read_vertices( FileTokenizer& tokens, long num_verts, EntityHandle& start_handle_out ); 00063 00064 ErrorCode allocate_elements( long num_elements, 00065 int vert_per_element, 00066 EntityType type, 00067 EntityHandle& start_handle_out, 00068 EntityHandle*& conn_array_out, 00069 std::vector< Range >& append_to_this ); 00070 00071 ErrorCode vtk_read_dataset( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& element_list ); 00072 00073 ErrorCode vtk_read_structured_points( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& elem_list ); 00074 00075 ErrorCode vtk_read_structured_grid( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& elem_list ); 00076 00077 ErrorCode vtk_read_rectilinear_grid( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& elem_list ); 00078 00079 ErrorCode vtk_read_polydata( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& elem_list ); 00080 00081 ErrorCode vtk_read_polygons( FileTokenizer& tokens, EntityHandle first_vtx, std::vector< Range >& elem_list ); 00082 00083 ErrorCode vtk_read_unstructured_grid( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& elem_list ); 00084 00085 ErrorCode vtk_create_structured_elems( const long* dims, EntityHandle first_vtx, std::vector< Range >& elem_list ); 00086 00087 ErrorCode vtk_read_field( FileTokenizer& tokens ); 00088 00089 ErrorCode vtk_read_attrib_data( FileTokenizer& tokens, std::vector< Range >& entities ); 00090 00091 ErrorCode vtk_read_tag_data( FileTokenizer& tokens, 00092 int type, 00093 size_t per_elem, 00094 std::vector< Range >& entities, 00095 const char* name ); 00096 00097 ErrorCode vtk_read_scalar_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ); 00098 00099 ErrorCode vtk_read_color_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ); 00100 00101 ErrorCode vtk_read_vector_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ); 00102 00103 ErrorCode vtk_read_texture_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ); 00104 00105 ErrorCode vtk_read_tensor_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ); 00106 00107 ErrorCode vtk_read_field_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ); 00108 00109 ErrorCode store_file_ids( Tag tag, const Range& vertices, const std::vector< Range >& elements ); 00110 00111 private: 00112 ReadUtilIface* readMeshIface; 00113 00114 //------------member variables ------------// 00115 00116 //! interface instance 00117 Interface* mdbImpl; 00118 00119 //! A field which, if present and having a single integer for storage, should be used to 00120 //! partition the mesh by range. Defaults to MATERIAL_SET_TAG_NAME 00121 std::string mPartitionTagName; 00122 }; 00123 00124 } // namespace moab 00125 00126 #endif
