, including all inherited members.
| _times | moab::ReadHDF5 | [private] |
| ADJACENCY_TIME enum value | moab::ReadHDF5 | [protected] |
| bcastDuplicateReads | moab::ReadHDF5 | [private] |
| bcastSummary | moab::ReadHDF5 | [private] |
| blockedCoordinateIO | moab::ReadHDF5 | [private] |
| bufferSize | moab::ReadHDF5 | [private] |
| CHILD enum value | moab::ReadHDF5 | |
| clean_up_read(const FileOptions &opts) | moab::ReadHDF5 | [private] |
| collIO | moab::ReadHDF5 | [private] |
| Comm typedef | moab::ReadHDF5 | |
| CONTENT enum value | moab::ReadHDF5 | |
| convert_id_to_handle(EntityHandle *in_out_array, size_t array_length) | moab::ReadHDF5 | |
| convert_id_to_handle(EntityHandle *in_out_array, size_t array_length, size_t &array_length_out) const | moab::ReadHDF5 | [inline] |
| convert_id_to_handle(EntityHandle *in_out_array, size_t array_length, const RangeMap< long, EntityHandle > &id_map) | moab::ReadHDF5 | [static] |
| convert_id_to_handle(EntityHandle *in_out_array, size_t array_length, size_t &array_length_out, const RangeMap< long, EntityHandle > &id_map) | moab::ReadHDF5 | [static] |
| convert_range_to_handle(const EntityHandle *ranges, size_t num_ranges, Range &merge) | moab::ReadHDF5 | |
| convert_range_to_handle(const EntityHandle *ranges, size_t num_ranges, const RangeMap< long, EntityHandle > &id_map, Range &merge) | moab::ReadHDF5 | [static] |
| cputime | moab::ReadHDF5 | [private] |
| create_tag(const mhdf_TagDesc &info, Tag &handle, hid_t &type) | moab::ReadHDF5 | [private] |
| dataBuffer | moab::ReadHDF5 | [private] |
| dbgOut | moab::ReadHDF5 | [private] |
| debug_barrier_line(int lineno) | moab::ReadHDF5 | [private] |
| debugTrack | moab::ReadHDF5 | [private] |
| delete_non_side_elements(const Range &side_ents) | moab::ReadHDF5 | [private] |
| DELETE_NON_SIDEELEM_TIME enum value | moab::ReadHDF5 | [protected] |
| errorHandler | moab::ReadHDF5 | [private] |
| factory(Interface *) | moab::ReadHDF5 | [static] |
| fileInfo | moab::ReadHDF5 | [private] |
| filePtr | moab::ReadHDF5 | [private] |
| find_int_tag(const char *name, int &index_out) | moab::ReadHDF5 | [private] |
| find_sets_containing(Range &sets_out, bool read_set_containing_parents) | moab::ReadHDF5 | [private] |
| find_sets_containing(hid_t content_handle, hid_t content_type, long content_len, bool read_set_containing_parents, Range &file_ids) | moab::ReadHDF5 | [private] |
| FIND_SETS_CONTAINING_TIME enum value | moab::ReadHDF5 | [protected] |
| GET_ELEMENTS_TIME enum value | moab::ReadHDF5 | [protected] |
| GET_NODEADJ_TIME enum value | moab::ReadHDF5 | [protected] |
| GET_NODES_TIME enum value | moab::ReadHDF5 | [protected] |
| get_partition(Range &tmp_file_ids, int num_parts, int part_number) | moab::ReadHDF5 | [private] |
| GET_PARTITION_TIME enum value | moab::ReadHDF5 | [protected] |
| GET_POLYHEDRA_TIME enum value | moab::ReadHDF5 | [protected] |
| get_set_contents(const Range &sets, Range &file_ids) | moab::ReadHDF5 | [private] |
| GET_SET_CONTENTS_TIME enum value | moab::ReadHDF5 | [protected] |
| GET_SET_IDS_TIME enum value | moab::ReadHDF5 | [protected] |
| GET_SIDEELEM_TIME enum value | moab::ReadHDF5 | [protected] |
| get_subset_ids(const ReaderIface::IDTag *subset_list, int subset_list_length, Range &file_ids_out) | moab::ReadHDF5 | [private] |
| get_tagged_entities(int tag_index, Range &file_ids_out) | moab::ReadHDF5 | [private] |
| handleType | moab::ReadHDF5 | [private] |
| idConnectivityList | moab::ReadHDF5 | [private] |
| IDMap typedef | moab::ReadHDF5 | [private] |
| idMap | moab::ReadHDF5 | [private] |
| iFace | moab::ReadHDF5 | [private] |
| indepIO | moab::ReadHDF5 | [private] |
| init() | moab::ReadHDF5 | [private] |
| insert_in_id_map(const Range &file_ids, EntityHandle start_id) | moab::ReadHDF5 | |
| insert_in_id_map(long file_id, EntityHandle handle) | moab::ReadHDF5 | |
| is_error(mhdf_Status &status) | moab::ReadHDF5 | [inline, private] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadHDF5 | [virtual] |
| load_file_impl(const FileOptions &opts) | moab::ReadHDF5 | [protected] |
| load_file_partial(const ReaderIface::IDTag *subset_list, int subset_list_length, int num_parts, int part_number, const FileOptions &opts) | moab::ReadHDF5 | [protected] |
| moab() const | moab::ReadHDF5 | [inline] |
| mpiComm | moab::ReadHDF5 | [private] |
| myPcomm | moab::ReadHDF5 | [private] |
| nativeParallel | moab::ReadHDF5 | [private] |
| NUM_TIMES enum value | moab::ReadHDF5 | [protected] |
| PARENT enum value | moab::ReadHDF5 | |
| print_times() | moab::ReadHDF5 | [protected] |
| read_adjacencies(hid_t adjacency_table, long table_length) | moab::ReadHDF5 | [private] |
| read_all_set_meta() | moab::ReadHDF5 | [private] |
| read_dense_tag(Tag tag_handle, const char *ent_name, hid_t hdf_read_type, hid_t data_table, long start_id, long count) | moab::ReadHDF5 | [private] |
| read_elems(int index) | moab::ReadHDF5 | [private] |
| read_elems(int index, const Range &file_ids, Range *node_ids=0) | moab::ReadHDF5 | [private] |
| read_elems(const mhdf_ElemDesc &elems, const Range &file_ids, Range *node_ids=0) | moab::ReadHDF5 | [private] |
| read_elems(int index, const Range &element_file_ids, Range &node_file_ids) | moab::ReadHDF5 | [private] |
| read_node_adj_elems(const mhdf_ElemDesc &group, Range *read_entities=0) | moab::ReadHDF5 | [private] |
| read_node_adj_elems(const mhdf_ElemDesc &group, hid_t connectivity_handle, Range *read_entities=0) | moab::ReadHDF5 | [private] |
| read_nodes(const Range &node_file_ids) | moab::ReadHDF5 | [private] |
| read_poly(const mhdf_ElemDesc &elems, const Range &file_ids) | moab::ReadHDF5 | [private] |
| read_qa(EntityHandle file_set) | moab::ReadHDF5 | [private] |
| READ_QA_TIME enum value | moab::ReadHDF5 | [protected] |
| read_set_data(const Range &set_file_ids, EntityHandle set_start_handle, ReadHDF5Dataset &set_data_set, SetMode which_data, Range *file_ids_out=0) | moab::ReadHDF5 | [private] |
| READ_SET_IDS_RECURS_TIME enum value | moab::ReadHDF5 | [protected] |
| read_set_ids_recursive(Range &sets_in_out, bool containted_sets, bool child_sets) | moab::ReadHDF5 | [private] |
| read_sets(const Range &set_file_ids) | moab::ReadHDF5 | [private] |
| read_sets_partial(const Range &sets_in) | moab::ReadHDF5 | [private] |
| READ_SETS_TIME enum value | moab::ReadHDF5 | [protected] |
| read_sparse_tag(Tag tag_handle, hid_t hdf_read_type, hid_t ent_table, hid_t val_table, long num_entities) | moab::ReadHDF5 | [private] |
| read_sparse_tag_indices(const char *name, hid_t id_table, EntityHandle start_offset, Range &offset_range, Range &handle_range, std::vector< EntityHandle > &handle_vect) | moab::ReadHDF5 | [private] |
| read_tag(int index) | moab::ReadHDF5 | [private] |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::ReadHDF5 | [virtual] |
| read_tag_values_all(int tag_index, std::vector< int > &results) | moab::ReadHDF5 | [protected] |
| read_tag_values_partial(int tag_index, const Range &file_ids, std::vector< int > &results) | moab::ReadHDF5 | [protected] |
| READ_TAGS_TIME enum value | moab::ReadHDF5 | [protected] |
| read_var_len_tag(Tag tag_handle, hid_t hdf_read_type, hid_t ent_table, hid_t val_table, hid_t off_table, long num_entities, long num_values) | moab::ReadHDF5 | [private] |
| ReadHDF5(Interface *iface) | moab::ReadHDF5 | |
| ReadTimingValues enum name | moab::ReadHDF5 | [protected] |
| readUtil | moab::ReadHDF5 | [private] |
| search_tag_values(int tag_index, const std::vector< int > &sorted_values, Range &file_ids_out, bool sets_only=false) | moab::ReadHDF5 | [private] |
| search_tag_values(hid_t tag_table, unsigned long table_size, const std::vector< int > &sorted_values, std::vector< EntityHandle > &value_indices) | moab::ReadHDF5 | [private] |
| SET_META_TIME enum value | moab::ReadHDF5 | [protected] |
| set_up_read(const char *file_name, const FileOptions &opts) | moab::ReadHDF5 | [private] |
| setMeta | moab::ReadHDF5 | [private] |
| SetMode enum name | moab::ReadHDF5 | |
| store_file_ids(Tag tag) | moab::ReadHDF5 | [private] |
| STORE_FILE_IDS_TIME enum value | moab::ReadHDF5 | [protected] |
| store_sets_file_ids() | moab::ReadHDF5 | [private] |
| SUBSET_IDS_TIME enum value | moab::ReadHDF5 | [protected] |
| timer | moab::ReadHDF5 | [private] |
| TOTAL_TIME enum value | moab::ReadHDF5 | [protected] |
| update_connectivity() | moab::ReadHDF5 | [private] |
| UPDATECONN_TIME enum value | moab::ReadHDF5 | [protected] |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
| ~ReadHDF5() | moab::ReadHDF5 | [virtual] |
