MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "moab/Defines.h" 00017 #include "moab/Core.hpp" 00018 #include "ReadWriteExoII.hpp" 00019 #include "moab/_MBSet.hpp" 00020 00021 #include <iostream> 00022 00023 using namespace moab; 00024 00025 std::ostream& operator<<( std::ostream& out, const std::vector< int >& v ) 00026 { 00027 std::copy( v.begin(), v.end(), std::ostream_iterator< int >( std::cout, " " ) ); 00028 return out; 00029 } 00030 00031 int main( int argc, char* argv[] ) 00032 { 00033 // check for file name on command line 00034 if( 2 != argc ) 00035 { 00036 std::cout << "Usage: " << argv[0] << " <exoII_file_name>" << std::endl; 00037 return 1; 00038 } 00039 00040 Core mdb; 00041 ReadWriteExoII reader( &mdb ); 00042 ErrorCode result = reader.load_file( argv[1], NULL ); 00043 00044 std::cout << "Result of reading file = " << ( MB_FAILURE == result ? "FAILURE." : "SUCCESS." ) << std::endl; 00045 00046 // print some data about the mesh 00047 int num_nodes = mdb.total_num_nodes(); 00048 int num_elements = mdb.total_num_elements(); 00049 std::cout << "Total number of nodes, elements read = " << num_nodes << ", " << num_elements << std::endl; 00050 00051 // get the nodeset meshsets and blocks 00052 std::vector< MB_MBSet* > blocks, nodesets, sidesets; 00053 std::vector< int > block_ids, nodeset_ids, sideset_ids; 00054 const std::set< MB_MBSet* >& gms = MB_MBSet::GlobalMBSets(); 00055 00056 std::set< MB_MBSet* >::const_iterator this_it = gms.begin(), end_it = MB_MBSet::GlobalMBSets().end(); 00057 MB_MBSet* this_meshset; 00058 int bc_tag; 00059 for( ; this_it != end_it; ++this_it ) 00060 { 00061 // get the next set 00062 this_meshset = *this_it; 00063 00064 bc_tag = reader.get_block_id( this_meshset ); 00065 if( -1 != bc_tag ) 00066 { 00067 blocks.push_back( this_meshset ); 00068 block_ids.push_back( bc_tag ); 00069 } 00070 00071 // same for nodeset tag 00072 bc_tag = reader.get_nodeset_id( this_meshset ); 00073 if( -1 != bc_tag ) 00074 { 00075 nodesets.push_back( this_meshset ); 00076 nodeset_ids.push_back( bc_tag ); 00077 } 00078 00079 // same for sideset tag 00080 bc_tag = reader.get_sideset_id( this_meshset ); 00081 if( -1 != bc_tag ) 00082 { 00083 sidesets.push_back( this_meshset ); 00084 sideset_ids.push_back( bc_tag ); 00085 } 00086 } 00087 00088 // std::vector<int>::iterator set_it; 00089 std::cout << "Block numbers read: " << std::endl; 00090 if( !blocks.empty() ) 00091 std::cout << block_ids << std::endl; 00092 else 00093 std::cout << "(no blocks)" << std::endl; 00094 00095 std::cout << "Nodeset numbers read: " << std::endl; 00096 if( !nodesets.empty() ) 00097 std::cout << nodeset_ids << std::endl; 00098 else 00099 std::cout << "(no nodesets)" << std::endl; 00100 00101 std::cout << "Sideset numbers read: " << std::endl; 00102 if( !sidesets.empty() ) 00103 std::cout << sideset_ids << std::endl; 00104 else 00105 std::cout << "(no sidesets)" << std::endl; 00106 }
