MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #define IS_BUILDING_MB 00004 #include "moab/Range.hpp" 00005 #include "moab/FileOptions.hpp" 00006 00007 using namespace moab; 00008 00009 std::string cubfile = TestDir + "unittest/io/singlecyl.cub"; 00010 std::string ccmgfiler = TestDir + "unittest/io/singlecyl.ccmg"; 00011 std::string ccmgfilew = "singlecyl_tmp.ccmg"; 00012 00013 void test_read(); 00014 void test_write(); 00015 00016 int main() 00017 { 00018 int result = 0; 00019 00020 result += RUN_TEST( test_write ); 00021 result += RUN_TEST( test_read ); 00022 00023 return result; 00024 } 00025 00026 void test_write() 00027 { 00028 ErrorCode rval; 00029 Core moab; 00030 Interface& mb = moab; 00031 rval = mb.load_file( cubfile.c_str() ); 00032 if( MB_SUCCESS != rval ) std::cerr << "Trouble reading file " << cubfile << std::endl;CHECK_ERR( rval ); 00033 00034 rval = mb.write_file( ccmgfilew.c_str() ); 00035 if( MB_SUCCESS != rval ) std::cerr << "Trouble writing file " << ccmgfilew << std::endl;CHECK_ERR( rval ); 00036 } 00037 00038 void test_read() 00039 { 00040 ErrorCode rval; 00041 Core moab; 00042 Interface& mb = moab; 00043 rval = mb.load_file( ccmgfiler.c_str() );CHECK_ERR( rval ); 00044 }
