MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "cgm2moab.hpp" 00002 #include "moab/ProgOptions.hpp" 00003 00004 #include "moab/Core.hpp" 00005 #include "moab/Range.hpp" 00006 #include "moab/CartVect.hpp" 00007 #include "MBTagConventions.hpp" 00008 #include "moab/GeomQueryTool.hpp" 00009 #include "moab/GeomTopoTool.hpp" 00010 00011 #include <sstream> 00012 #include <iomanip> 00013 #include <cstdlib> 00014 #include <algorithm> 00015 #include <cstdio> 00016 00017 using namespace moab; 00018 00019 bool verbose = false; 00020 00021 void chkerr( Interface* mbi, ErrorCode code, int line, const char* file ) 00022 { 00023 00024 if( code != MB_SUCCESS ) 00025 { 00026 std::cerr << "Error: " << mbi->get_error_string( code ) << " (" << code << ")" << std::endl; 00027 std::string message; 00028 if( MB_SUCCESS == mbi->get_last_error( message ) && !message.empty() ) 00029 std::cerr << "Error message: " << message << std::endl; 00030 std::string fname = file; 00031 size_t slash = fname.find_last_of( '/' ); 00032 if( slash != fname.npos ) 00033 { 00034 fname = fname.substr( slash + 1 ); 00035 } 00036 std::cerr << "At " << fname << " line: " << line << std::endl; 00037 std::exit( EXIT_FAILURE ); 00038 } 00039 } 00040 00041 void chkerr( Interface& mbi, ErrorCode code, int line, const char* file ) 00042 { 00043 chkerr( &mbi, code, line, file ); 00044 } 00045 00046 void chkerr( GeomTopoTool& gtt, ErrorCode code, int line, const char* file ) 00047 { 00048 chkerr( gtt.get_moab_instance(), code, line, file ); 00049 } 00050 00051 /** 00052 * Estimate the volume of the surface (actually multiplied by a factor of six). 00053 * See DagMC::measure_volume, from which this code is borrowed, for algorithmic details. 00054 * For our purpose, all that matters is the signedness. 00055 * 00056 * @param offset Offset to apply to surface to avoid a zero result. 00057 */ 00058 static ErrorCode get_signed_volume( Interface* MBI, 00059 const EntityHandle surf_set, 00060 const CartVect& offset, 00061 double& signed_volume ) 00062 { 00063 ErrorCode rval; 00064 Range tris; 00065 rval = MBI->get_entities_by_type( surf_set, MBTRI, tris ); 00066 if( MB_SUCCESS != rval ) return rval; 00067 00068 signed_volume = 0.0; 00069 const EntityHandle* conn; 00070 int len; 00071 CartVect coords[3]; 00072 for( Range::iterator j = tris.begin(); j != tris.end(); ++j ) 00073 { 00074 rval = MBI->get_connectivity( *j, conn, len, true ); 00075 if( MB_SUCCESS != rval ) return rval; 00076 if( 3 != len ) return MB_INVALID_SIZE; 00077 rval = MBI->get_coords( conn, 3, coords[0].array() ); 00078 if( MB_SUCCESS != rval ) return rval; 00079 00080 // Apply offset to avoid calculating 0 for cases when the origin is in the 00081 // plane of the surface. 00082 for( unsigned int k = 0; k < 3; ++k ) 00083 { 00084 coords[k] += offset; 00085 } 00086 00087 coords[1] -= coords[0]; 00088 coords[2] -= coords[0]; 00089 signed_volume += ( coords[0] % ( coords[1] * coords[2] ) ); 00090 } 00091 return MB_SUCCESS; 00092 } 00093 00094 /** 00095 * Replace the triangles in an old surface with those in a new surface, ensuring 00096 * that their surfaces senses match before the replacement 00097 */ 00098 static ErrorCode replace_surface( Interface* mbi, 00099 EntityHandle old_surf, 00100 EntityHandle old_file_set, 00101 EntityHandle new_surf, 00102 const Tag& senseTag ) 00103 { 00104 00105 ErrorCode rval; 00106 00107 // Get the signed volume for each surface representation. If a volume comes 00108 // back as zero, it's probably because a planar surface passes through the 00109 // origin. In that case, try applying random offsets until reasonable 00110 // values are returned. 00111 00112 CartVect offset; // start with no offset 00113 const double min_vol = 0.1; // try again if abs(vol) < this value 00114 00115 double old_vol = 0, new_vol = 0; 00116 00117 bool success = false; 00118 int num_attempts = 100; 00119 00120 while( num_attempts-- > 0 ) 00121 { 00122 00123 rval = get_signed_volume( mbi, old_surf, offset, old_vol ); 00124 if( MB_SUCCESS != rval ) return rval; 00125 00126 rval = get_signed_volume( mbi, new_surf, offset, new_vol ); 00127 if( MB_SUCCESS != rval ) return rval; 00128 00129 if( std::fabs( old_vol ) >= min_vol && std::fabs( new_vol ) >= min_vol ) 00130 { 00131 success = true; 00132 break; 00133 } 00134 00135 // haven't succeeded yet: randomize the offset vector 00136 const int max_random = 10; 00137 for( int i = 0; i < 3; ++i ) 00138 { 00139 offset[i] = std::rand() % max_random; 00140 } 00141 } 00142 00143 if( !success ) 00144 { 00145 std::cerr << "Error: could not calculate a surface volume" << std::endl; 00146 return MB_FAILURE; 00147 } 00148 00149 // If the sign is different, reverse the old surf senses so that both 00150 // representations have the same signed volume. 00151 if( ( old_vol < 0 && new_vol > 0 ) || ( old_vol > 0 && new_vol < 0 ) ) 00152 { 00153 00154 EntityHandle old_surf_volumes[2]; 00155 rval = mbi->tag_get_data( senseTag, &old_surf, 1, old_surf_volumes ); 00156 if( MB_SUCCESS != rval ) return rval; 00157 00158 std::swap( old_surf_volumes[0], old_surf_volumes[1] ); 00159 00160 rval = mbi->tag_set_data( senseTag, &old_surf, 1, old_surf_volumes ); 00161 if( MB_SUCCESS != rval ) return rval; 00162 } 00163 00164 int num_old_tris, num_new_tris; 00165 00166 // Remove the tris from the old surf. Also remove them from the 00167 // old_file_set because it is not TRACKING. 00168 Range old_tris; 00169 rval = mbi->get_entities_by_type( old_surf, MBTRI, old_tris ); 00170 if( MB_SUCCESS != rval ) return rval; 00171 num_old_tris = old_tris.size(); 00172 rval = mbi->remove_entities( old_surf, old_tris ); 00173 if( MB_SUCCESS != rval ) return rval; 00174 rval = mbi->remove_entities( old_file_set, old_tris ); 00175 if( MB_SUCCESS != rval ) return rval; 00176 rval = mbi->delete_entities( old_tris ); 00177 if( MB_SUCCESS != rval ) return rval; 00178 00179 // Add the new_surf's triangles to the old_surf 00180 Range new_tris; 00181 rval = mbi->get_entities_by_type( new_surf, MBTRI, new_tris ); 00182 if( MB_SUCCESS != rval ) return rval; 00183 num_new_tris = new_tris.size(); 00184 rval = mbi->add_entities( old_surf, new_tris ); 00185 if( MB_SUCCESS != rval ) return rval; 00186 00187 if( verbose ) 00188 { 00189 std::cout << num_old_tris << " tris -> " << num_new_tris << " tris" << std::endl; 00190 } 00191 00192 return MB_SUCCESS; 00193 } 00194 00195 /** 00196 * Given an "old" file and a "new" file, replace the facets in any surface of the old 00197 * file with facets from the new file. 00198 */ 00199 static ErrorCode merge_input_surfs( Interface* mbi, 00200 const EntityHandle old_file_set, 00201 const EntityHandle new_file_set, 00202 const Tag& idTag, 00203 const Tag& dimTag, 00204 const Tag& senseTag ) 00205 { 00206 ErrorCode rval; 00207 00208 const int two = 2; 00209 const Tag tags[2] = { dimTag, idTag }; 00210 const void* tag_vals[2] = { &two, NULL }; 00211 00212 Range old_surfs; 00213 rval = mbi->get_entities_by_type_and_tag( old_file_set, MBENTITYSET, &dimTag, tag_vals, 1, old_surfs ); 00214 if( MB_SUCCESS != rval ) return rval; 00215 00216 int count = 0; 00217 00218 for( Range::iterator i = old_surfs.begin(); i != old_surfs.end(); ++i ) 00219 { 00220 EntityHandle old_surf = *i; 00221 00222 int surf_id; 00223 rval = mbi->tag_get_data( idTag, &old_surf, 1, &surf_id ); 00224 if( MB_SUCCESS != rval ) return rval; 00225 00226 Range new_surf_range; 00227 tag_vals[1] = &surf_id; 00228 rval = mbi->get_entities_by_type_and_tag( new_file_set, MBENTITYSET, tags, tag_vals, 2, new_surf_range ); 00229 if( MB_SUCCESS != rval ) return rval; 00230 00231 if( new_surf_range.size() != 1 ) 00232 { 00233 if( new_surf_range.size() > 1 ) 00234 { 00235 std::cerr << "Warning: surface " << surf_id << " has more than one representation in new file" 00236 << std::endl; 00237 } 00238 continue; 00239 } 00240 00241 // Now we have found a surf in new_file_set to replace an old surf 00242 EntityHandle new_surf = new_surf_range[0]; 00243 00244 // TODO: check for quads and convert to triangles 00245 00246 if( verbose ) 00247 { 00248 std::cout << "Surface " << surf_id << ": " << std::flush; 00249 } 00250 rval = replace_surface( mbi, old_surf, old_file_set, new_surf, senseTag ); 00251 if( MB_SUCCESS != rval ) return rval; 00252 count++; 00253 } 00254 00255 std::cout << "Replaced " << count << " surface" << ( count == 1 ? "." : "s." ) << std::endl; 00256 00257 return MB_SUCCESS; 00258 } 00259 00260 int main( int argc, char* argv[] ) 00261 { 00262 00263 ProgOptions po( "cgm2moab: a tool for preprocessing CAD and mesh files for analysis" ); 00264 00265 std::string input_file; 00266 std::string output_file = "dagmc_preproc_out.h5m"; 00267 int grid = 50; 00268 00269 po.addOpt< void >( ",v", "Verbose output", &verbose ); 00270 po.addOpt< std::string >( "outmesh,o", "Specify output file name (default " + output_file + ")", &output_file ); 00271 po.addOpt< void >( "no-outmesh,", "Do not write an output mesh" ); 00272 po.addOpt< std::string >( ",m", "Specify alternate input mesh to override surfaces in input_file" ); 00273 po.addOpt< std::string >( "obb-vis,O", "Specify obb visualization output file (default none)" ); 00274 po.addOpt< int >( "obb-vis-divs", "Resolution of obb visualization grid (default 50)", &grid ); 00275 po.addOpt< void >( "obb-stats,S", "Print obb statistics. With -v, print verbose statistics." ); 00276 po.addOpt< std::vector< int > >( "vols,V", 00277 "Specify a set of volumes (applies to --obb_vis and --obb_stats, default all)" ); 00278 po.addOptionHelpHeading( "Options for loading CAD files" ); 00279 po.addOpt< double >( "ftol,f", "Faceting distance tolerance", po.add_cancel_opt ); 00280 po.addOpt< double >( "ltol,l", "Faceting edge length tolerance", po.add_cancel_opt ); 00281 po.addOpt< int >( "atol,a", "Faceting normal angle tolerance (degrees)", po.add_cancel_opt ); 00282 po.addOpt< void >( "all-warnings", "Verbose warnings about attributes and curve tolerances" ); 00283 po.addOpt< void >( "no-attribs", "Do not actuate CGM attributes" ); 00284 po.addOpt< void >( "fatal_curves", "Fatal Error when curves cannot be faceted" ); 00285 00286 po.addRequiredArg< std::string >( "input_file", "Path to input file for preprocessing", &input_file ); 00287 00288 po.parseCommandLine( argc, argv ); 00289 00290 /* Check that user has asked for at least one useful thing to be done */ 00291 bool obb_task = po.numOptSet( "obb-vis" ) || po.numOptSet( "obb-stats" ); 00292 00293 if( po.numOptSet( "no-outmesh" ) && !obb_task ) 00294 { 00295 po.error( "Nothing to do. Please specify an OBB-related option, or remove --no_outmesh." ); 00296 } 00297 00298 /* Load input file, with CAD processing options, if specified */ 00299 std::string options; 00300 #define OPTION_APPEND( X ) \ 00301 { \ 00302 if( options.length() ) options += ";"; \ 00303 options += ( X ); \ 00304 } 00305 00306 if( po.numOptSet( "no-attribs" ) ) 00307 { 00308 OPTION_APPEND( "CGM_ATTRIBS=no" ); 00309 } 00310 00311 if( po.numOptSet( "fatal_curves" ) ) 00312 { 00313 OPTION_APPEND( "FATAL_ON_CURVES" ); 00314 } 00315 00316 if( po.numOptSet( "all-warnings" ) ) 00317 { 00318 OPTION_APPEND( "VERBOSE_CGM_WARNINGS" ); 00319 } 00320 00321 // This is more roundabout than necessary, but we don't want *any* of the CGM-specific options 00322 // to appear in the option string unless they were explicitly requested 00323 double tol; 00324 static const int tol_prec = 12; 00325 if( po.getOpt( "ftol", &tol ) ) 00326 { 00327 std::stringstream s; 00328 s << "FACET_DISTANCE_TOLERANCE=" << std::setprecision( tol_prec ) << tol; 00329 OPTION_APPEND( s.str() ); 00330 } 00331 00332 if( po.getOpt( "ltol", &tol ) ) 00333 { 00334 std::stringstream s; 00335 s << "MAX_FACET_EDGE_LENGTH=" << std::setprecision( tol_prec ) << tol; 00336 OPTION_APPEND( s.str() ); 00337 } 00338 00339 int atol; 00340 if( po.getOpt( "atol", &atol ) ) 00341 { 00342 std::stringstream s; 00343 s << "FACET_NORMAL_TOLERANCE=" << atol; 00344 OPTION_APPEND( s.str() ); 00345 } 00346 00347 #undef OPTION_APPEND 00348 00349 /* Load main input file */ 00350 if( verbose ) 00351 { 00352 std::cout << "Loading file " << input_file << std::endl; 00353 if( options.length() ) std::cout << "Option string: " << options << std::endl; 00354 } 00355 00356 EntityHandle input_file_set; 00357 ErrorCode ret; 00358 Core mbi; 00359 00360 ret = mbi.create_meshset( 0, input_file_set ); 00361 CHECKERR( mbi, ret ); 00362 00363 ret = mbi.load_file( input_file.c_str(), &input_file_set, options.c_str() ); 00364 if( ret == MB_UNHANDLED_OPTION ) 00365 { 00366 std::cerr << "Warning: unhandled option while loading input_file, will proceed anyway" << std::endl; 00367 } 00368 else 00369 { 00370 CHECKERR( mbi, ret ); 00371 } 00372 00373 /* Iterate through any -m alternate mesh files and replace surfaces */ 00374 00375 std::vector< std::string > m_list; 00376 po.getOptAllArgs( ",m", m_list ); 00377 00378 if( m_list.size() > 0 ) 00379 { 00380 00381 if( obb_task ) 00382 { 00383 std::cerr << "Warning: using obb features in conjunction with -m may not work correctly!" << std::endl; 00384 } 00385 00386 // Create tags 00387 Tag dimTag, idTag, senseTag; 00388 ret = mbi.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, dimTag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00389 CHECKERR( mbi, ret ); 00390 00391 idTag = mbi.globalId_tag(); 00392 00393 ret = mbi.tag_get_handle( "GEOM_SENSE_2", 2, MB_TYPE_HANDLE, senseTag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00394 CHECKERR( mbi, ret ); 00395 00396 for( std::vector< std::string >::iterator i = m_list.begin(); i != m_list.end(); ++i ) 00397 { 00398 std::cout << "Loading alternate mesh file " << *i << std::endl; 00399 00400 EntityHandle alt_file_set; 00401 ret = mbi.create_meshset( 0, alt_file_set ); 00402 CHECKERR( mbi, ret ); 00403 00404 ret = mbi.load_file( ( *i ).c_str(), &alt_file_set ); 00405 CHECKERR( mbi, ret ); 00406 00407 if( verbose ) std::cout << "Merging input surfaces..." << std::flush; 00408 00409 ret = merge_input_surfs( &mbi, input_file_set, alt_file_set, idTag, dimTag, senseTag ); 00410 CHECKERR( mbi, ret ); 00411 00412 if( verbose ) std::cout << "done." << std::endl; 00413 } 00414 } 00415 00416 /* Write output file */ 00417 00418 if( !po.numOptSet( "no-outmesh" ) ) 00419 { 00420 if( verbose ) 00421 { 00422 std::cout << "Writing " << output_file << std::endl; 00423 } 00424 ret = mbi.write_file( output_file.c_str(), NULL, NULL, &input_file_set, 1 ); 00425 CHECKERR( mbi, ret ); 00426 } 00427 00428 /* OBB statistics and visualization */ 00429 if( obb_task ) 00430 { 00431 00432 if( verbose ) 00433 { 00434 std::cout << "Loading data into GeomTopoTool" << std::endl; 00435 } 00436 GeomTopoTool* gtt = new GeomTopoTool( &mbi, false ); 00437 ret = gtt->find_geomsets(); 00438 CHECKERR( *gtt, ret ); 00439 ret = gtt->construct_obb_trees(); 00440 CHECKERR( *gtt, ret ); 00441 } 00442 return 0; 00443 }
