MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * This imoab_coupler test will simulate coupling between 3 components 00003 * 3 meshes will be loaded from 3 files (atm, ocean, lnd), and they will be migrated to 00004 * all processors (coupler pes); then, intx will be performed between migrated meshes 00005 * and weights will be generated, such that a field from one component will be transferred to 00006 * the other component 00007 * currently, the atm will send some data to be projected to ocean and land components 00008 * 00009 * first, intersect atm and ocn, and recompute comm graph 1 between atm and atm_cx, for ocn intx 00010 * second, intersect atm and lnd, and recompute comm graph 2 between atm and atm_cx for lnd intx 00011 00012 */ 00013 00014 #include "moab/Core.hpp" 00015 #ifndef MOAB_HAVE_MPI 00016 #error mbtempest tool requires MPI configuration 00017 #endif 00018 00019 // MPI includes 00020 #include "moab_mpi.h" 00021 #include "moab/ParallelComm.hpp" 00022 #include "MBParallelConventions.h" 00023 00024 #include "moab/iMOAB.h" 00025 #include "TestUtil.hpp" 00026 #include "moab/CpuTimer.hpp" 00027 #include "moab/ProgOptions.hpp" 00028 #include <iostream> 00029 #include <sstream> 00030 00031 #include "imoab_coupler_utils.hpp" 00032 00033 using namespace moab; 00034 00035 //#define GRAPH_INFO 00036 00037 #ifndef MOAB_HAVE_TEMPESTREMAP 00038 #error The climate coupler test example requires MOAB configuration with TempestRemap 00039 #endif 00040 00041 #define ENABLE_ATMOCN_COUPLING 00042 #define ENABLE_ATMCPLOCN_COUPLING 00043 00044 #if( !defined( ENABLE_ATMOCN_COUPLING ) && !defined( ENABLE_ATMCPLOCN_COUPLING ) ) 00045 #error Enable either OCN (ENABLE_ATMOCN_COUPLING) and/or LND (ENABLE_ATMCPLOCN_COUPLING) for coupling 00046 #endif 00047 00048 int main( int argc, char* argv[] ) 00049 { 00050 int ierr; 00051 int rankInGlobalComm, numProcesses; 00052 MPI_Group jgroup; 00053 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00054 std::string readoptsLnd( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ); 00055 00056 // Timer data 00057 moab::CpuTimer timer; 00058 double timer_ops; 00059 std::string opName; 00060 00061 int repartitioner_scheme = 0; 00062 #ifdef MOAB_HAVE_ZOLTAN 00063 repartitioner_scheme = 2; // use the graph partitioner in that caseS 00064 #endif 00065 00066 MPI_Init( &argc, &argv ); 00067 MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm ); 00068 MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); 00069 00070 MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup 00071 00072 std::string atmFilename = TestDir + "unittest/wholeATM_T.h5m"; 00073 // on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ; 00074 // intx atm/ocn is not in e3sm yet, give a number 00075 // 6 * 100+ 18 = 618 : atmocnid 00076 // 9 LND, 10 CPLLND 00077 // 6 * 100 + 10 = 610 atmlndid: 00078 // cmpatm is for atm on atm pes 00079 // cmpocn is for ocean, on ocean pe 00080 // cplatm is for atm on coupler pes 00081 // cplocn is for ocean on coupelr pes 00082 // atmocnid is for intx atm / ocn on coupler pes 00083 // 00084 int rankInAtmComm = -1; 00085 int cmpatm = 5, 00086 cplatm = 6; // component ids are unique over all pes, and established in advance; 00087 #ifdef ENABLE_ATMOCN_COUPLING 00088 std::string ocnFilename = TestDir + "unittest/recMeshOcn.h5m"; 00089 std::string baseline = TestDir + "unittest/baseline1.txt"; 00090 int rankInOcnComm = -1; 00091 int cmpocn = 17, cplocn = 18, 00092 atmocnid = 618; // component ids are unique over all pes, and established in advance; 00093 #endif 00094 00095 #ifdef ENABLE_ATMCPLOCN_COUPLING 00096 int cplatm2 = 10, 00097 atm2ocnid = 610; // component ids are unique over all pes, and established in advance; 00098 #endif 00099 00100 int rankInCouComm = -1; 00101 00102 int nghlay = 0; // number of ghost layers for loading the file 00103 std::vector< int > groupTasks; 00104 int startG1 = 0, startG2 = 0, 00105 endG1 = numProcesses - 1, endG2 = numProcesses - 1; // Support launch of imoab_coupler test on any combo of 2*x processes 00106 int startG4 = startG1, endG4 = endG1; // these are for coupler layout 00107 int context_id = -1; // used now for freeing buffers 00108 00109 // default: load atm on 2 proc, ocean on 2, land on 2; migrate to 2 procs, then compute intx 00110 // later, we need to compute weight matrix with tempestremap 00111 00112 ProgOptions opts; 00113 opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename ); 00114 #ifdef ENABLE_ATMOCN_COUPLING 00115 opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename ); 00116 #endif 00117 opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 ); 00118 opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 ); 00119 #ifdef ENABLE_ATMOCN_COUPLING 00120 opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 ); 00121 opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 ); 00122 #endif 00123 00124 opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 ); 00125 opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 ); 00126 00127 opts.addOpt< int >( "partitioning,p", "partitioning option for migration", &repartitioner_scheme ); 00128 00129 int n = 1; // number of send/receive / project / send back cycles 00130 opts.addOpt< int >( "iterations,n", "number of iterations for coupler", &n ); 00131 00132 bool no_regression_test = false; 00133 opts.addOpt< void >( "no_regression,r", "do not do regression test against baseline 1", &no_regression_test ); 00134 opts.parseCommandLine( argc, argv ); 00135 00136 char fileWriteOptions[] = "PARALLEL=WRITE_PART"; 00137 00138 if( !rankInGlobalComm ) 00139 { 00140 std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 << 00141 #ifdef ENABLE_ATMOCN_COUPLING 00142 "\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 << 00143 #endif 00144 "\n partitioning (0 trivial, 1 graph, 2 geometry) " << repartitioner_scheme << "\n "; 00145 } 00146 00147 // load files on 3 different communicators, groups 00148 // first groups has task 0, second group tasks 0 and 1 00149 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00150 // first groups has task 0, second group tasks 0 and 1 00151 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00152 MPI_Group atmPEGroup; 00153 MPI_Comm atmComm; 00154 ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm ); 00155 CHECKIERR( ierr, "Cannot create atm MPI group and communicator " ) 00156 00157 #ifdef ENABLE_ATMOCN_COUPLING 00158 MPI_Group ocnPEGroup; 00159 MPI_Comm ocnComm; 00160 ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm ); 00161 CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " ) 00162 #endif 00163 00164 // we will always have a coupler 00165 MPI_Group couPEGroup; 00166 MPI_Comm couComm; 00167 ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm ); 00168 CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " ) 00169 00170 // atm_coupler 00171 MPI_Group joinAtmCouGroup; 00172 MPI_Comm atmCouComm; 00173 ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm ); 00174 CHECKIERR( ierr, "Cannot create joint atm cou communicator" ) 00175 00176 #ifdef ENABLE_ATMOCN_COUPLING 00177 // ocn_coupler 00178 MPI_Group joinOcnCouGroup; 00179 MPI_Comm ocnCouComm; 00180 ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm ); 00181 CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) 00182 #endif 00183 00184 ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should 00185 CHECKIERR( ierr, "Cannot initialize iMOAB" ) 00186 00187 int cmpAtmAppID = -1; 00188 iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm 00189 int cplAtmAppID = -1; // -1 means it is not initialized 00190 iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs 00191 #ifdef ENABLE_ATMOCN_COUPLING 00192 int cmpOcnAppID = -1; 00193 iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn 00194 int cplOcnAppID = -1, cplAtmOcnAppID = -1; // -1 means it is not initialized 00195 iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs 00196 iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm -ocn on coupler PEs 00197 #endif 00198 00199 #ifdef ENABLE_ATMCPLOCN_COUPLING 00200 int cplAtm2AppID = -1; // -1 means it is not initialized 00201 iMOAB_AppID cplAtm2PID = &cplAtm2AppID; // atm on second coupler PEs 00202 int cplAtm2OcnAppID = -1; // -1 means it is not initialized 00203 iMOAB_AppID cplAtm2OcnPID = &cplAtm2OcnAppID; // intx atm - lnd on coupler PEs 00204 #endif 00205 00206 if( couComm != MPI_COMM_NULL ) 00207 { 00208 MPI_Comm_rank( couComm, &rankInCouComm ); 00209 // Register all the applications on the coupler PEs 00210 ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm, 00211 cplAtmPID ); // atm on coupler pes 00212 CHECKIERR( ierr, "Cannot register ATM over coupler PEs" ) 00213 #ifdef ENABLE_ATMOCN_COUPLING 00214 ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn, 00215 cplOcnPID ); // ocn on coupler pes 00216 CHECKIERR( ierr, "Cannot register OCN over coupler PEs" ) 00217 #endif 00218 #ifdef ENABLE_ATMCPLOCN_COUPLING 00219 ierr = iMOAB_RegisterApplication( "ATMX2", &couComm, &cplatm2, 00220 cplAtm2PID ); // second atm on coupler pes 00221 CHECKIERR( ierr, "Cannot register second ATM over coupler PEs" ) 00222 #endif 00223 } 00224 00225 if( atmComm != MPI_COMM_NULL ) 00226 { 00227 MPI_Comm_rank( atmComm, &rankInAtmComm ); 00228 ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID ); 00229 CHECKIERR( ierr, "Cannot register ATM App" ) 00230 } 00231 00232 #ifdef ENABLE_ATMOCN_COUPLING 00233 if( ocnComm != MPI_COMM_NULL ) 00234 { 00235 MPI_Comm_rank( ocnComm, &rankInOcnComm ); 00236 ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID ); 00237 CHECKIERR( ierr, "Cannot register OCN App" ) 00238 } 00239 #endif 00240 00241 // atm 00242 ierr = 00243 setup_component_coupler_meshes( cmpAtmPID, cmpatm, cplAtmPID, cplatm, &atmComm, &atmPEGroup, &couComm, 00244 &couPEGroup, &atmCouComm, atmFilename, readopts, nghlay, repartitioner_scheme ); 00245 CHECKIERR( ierr, "Cannot load and migrate atm mesh" ) 00246 00247 #ifdef ENABLE_ATMOCN_COUPLING 00248 // ocean 00249 ierr = 00250 setup_component_coupler_meshes( cmpOcnPID, cmpocn, cplOcnPID, cplocn, &ocnComm, &ocnPEGroup, &couComm, 00251 &couPEGroup, &ocnCouComm, ocnFilename, readopts, nghlay, repartitioner_scheme ); 00252 CHECKIERR( ierr, "Cannot load and migrate ocn mesh" ) 00253 00254 #endif // #ifdef ENABLE_ATMOCN_COUPLING 00255 00256 #ifdef ENABLE_ATMCPLOCN_COUPLING 00257 00258 if( atmComm != MPI_COMM_NULL ) 00259 { 00260 // then send mesh to second coupler pes 00261 ierr = iMOAB_SendMesh( cmpAtmPID, &atmCouComm, &couPEGroup, &cplatm2, 00262 &repartitioner_scheme ); // send to coupler pes 00263 CHECKIERR( ierr, "cannot send elements to coupler-2" ) 00264 } 00265 // now, receive mesh, on coupler communicator; first mesh 1, atm 00266 if( couComm != MPI_COMM_NULL ) 00267 { 00268 ierr = iMOAB_ReceiveMesh( cplAtm2PID, &atmCouComm, &atmPEGroup, 00269 &cmpatm ); // receive from component 00270 CHECKIERR( ierr, "cannot receive elements on coupler app" ) 00271 } 00272 00273 // we can now free the sender buffers 00274 if( atmComm != MPI_COMM_NULL ) 00275 { 00276 int context_id = cplatm; 00277 ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &context_id ); 00278 CHECKIERR( ierr, "cannot free buffers used to send atm mesh" ) 00279 } 00280 00281 if( couComm != MPI_COMM_NULL && 1 == n ) 00282 { // write only for n==1 case 00283 char outputFileLnd[] = "recvAtm2.h5m"; 00284 ierr = iMOAB_WriteMesh( cplAtm2PID, outputFileLnd, fileWriteOptions ); 00285 CHECKIERR( ierr, "cannot write second atm mesh after receiving" ) 00286 } 00287 00288 #endif // #ifdef ENABLE_ATMCPLOCN_COUPLING 00289 00290 MPI_Barrier( MPI_COMM_WORLD ); 00291 00292 #ifdef ENABLE_ATMOCN_COUPLING 00293 if( couComm != MPI_COMM_NULL ) 00294 { 00295 // now compute intersection between OCNx and ATMx on coupler PEs 00296 ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID ); 00297 CHECKIERR( ierr, "Cannot register atm/ocn intersection over coupler pes " ) 00298 } 00299 #endif 00300 #ifdef ENABLE_ATMCPLOCN_COUPLING 00301 if( couComm != MPI_COMM_NULL ) 00302 { 00303 // now compute intersection between LNDx and ATMx on coupler PEs 00304 ierr = iMOAB_RegisterApplication( "ATM2OCN", &couComm, &atm2ocnid, cplAtm2OcnPID ); 00305 CHECKIERR( ierr, "Cannot register atm2/ocn intersection over coupler pes " ) 00306 } 00307 #endif 00308 00309 int disc_orders[3] = { 4, 1, 1 }; 00310 const std::string weights_identifiers[2] = { "scalar", "scalar-pc" }; 00311 const std::string disc_methods[3] = { "cgll", "fv", "pcloud" }; 00312 const std::string dof_tag_names[3] = { "GLOBAL_DOFS", "GLOBAL_ID", "GLOBAL_ID" }; 00313 #ifdef ENABLE_ATMOCN_COUPLING 00314 if( couComm != MPI_COMM_NULL ) 00315 { 00316 PUSH_TIMER( "Compute ATM-OCN mesh intersection" ) 00317 ierr = iMOAB_ComputeMeshIntersectionOnSphere( 00318 cplAtmPID, cplOcnPID, 00319 cplAtmOcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes 00320 // basically, atm was redistributed according to target (ocean) partition, to "cover" the 00321 // ocean partitions check if intx valid, write some h5m intx file 00322 CHECKIERR( ierr, "cannot compute intersection for atm/ocn" ) 00323 POP_TIMER( couComm, rankInCouComm ) 00324 #ifdef VERBOSE 00325 char prefix[] = "intx_atmocn"; 00326 ierr = iMOAB_WriteLocalMesh( cplAtmOcnPID, prefix, strlen( prefix ) ); 00327 CHECKIERR( ierr, "failed to write local intx mesh" ); 00328 #endif 00329 } 00330 00331 if( atmCouComm != MPI_COMM_NULL ) 00332 { 00333 // the new graph will be for sending data from atm comp to coverage mesh; 00334 // it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID 00335 // results are in cplAtmOcnPID, intx mesh; remapper also has some info about coverage mesh 00336 // after this, the sending of tags from atm pes to coupler pes will use the new par comm 00337 // graph, that has more precise info about what to send for ocean cover ; every time, we 00338 // will 00339 // use the element global id, which should uniquely identify the element 00340 PUSH_TIMER( "Compute OCN coverage graph for ATM mesh" ) 00341 ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmOcnPID, &cmpatm, &cplatm, 00342 &cplocn ); // it happens over joint communicator 00343 CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean" ) 00344 POP_TIMER( atmCouComm, rankInAtmComm ) // hijack this rank 00345 } 00346 #endif 00347 00348 #ifdef ENABLE_ATMCPLOCN_COUPLING 00349 if( couComm != MPI_COMM_NULL ) 00350 { 00351 PUSH_TIMER( "Compute ATM-OCN mesh intersection" ) 00352 ierr = iMOAB_ComputeMeshIntersectionOnSphere( 00353 cplAtm2PID, cplOcnPID, 00354 cplAtm2OcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes 00355 // basically, atm was redistributed according to target (ocean) partition, to "cover" the 00356 // ocean partitions check if intx valid, write some h5m intx file 00357 CHECKIERR( ierr, "cannot compute intersection for atm2/ocn" ) 00358 POP_TIMER( couComm, rankInCouComm ) 00359 // } 00360 // if( atmCouComm != MPI_COMM_NULL ) 00361 // { 00362 // the new graph will be for sending data from atm comp to coverage mesh for land mesh; 00363 // it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID 00364 // results are in cplAtmLndPID, intx mesh; remapper also has some info about coverage mesh 00365 // after this, the sending of tags from atm pes to coupler pes will use the new par comm 00366 // graph, that has more precise info about what to send (specifically for land cover); every 00367 // time, 00368 /// we will use the element global id, which should uniquely identify the element 00369 PUSH_TIMER( "Compute OCN coverage graph for ATM2 mesh" ) 00370 // Context: cplatm2 already holds the comm-graph for communicating between atm component and coupler2 00371 // We just need to create a comm graph to internally transfer data from coupler atm to coupler ocean 00372 // ierr = iMOAB_CoverageGraph( &couComm, cplAtm2PID, cplAtm2OcnPID, cplAtm2OcnPID, &cplatm2, &atm2ocnid, 00373 // &cplocn ); // it happens over joint communicator 00374 int type1 = 1; 00375 int type2 = 1; 00376 ierr = iMOAB_ComputeCommGraph( cplAtm2PID, cplAtm2OcnPID, &couComm, &couPEGroup, &couPEGroup, &type1, &type2, 00377 &cplatm2, &atm2ocnid ); 00378 CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean from atm2" ) 00379 POP_TIMER( couComm, rankInCouComm ) // hijack this rank 00380 } 00381 #endif 00382 00383 MPI_Barrier( MPI_COMM_WORLD ); 00384 00385 int fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 0, fNoConserve = 0, fNoBubble = 1, fInverseDistanceMap = 0; 00386 00387 #ifdef ENABLE_ATMOCN_COUPLING 00388 #ifdef VERBOSE 00389 if( couComm != MPI_COMM_NULL && 1 == n ) 00390 { // write only for n==1 case 00391 char serialWriteOptions[] = ""; // for writing in serial 00392 std::stringstream outf; 00393 outf << "intxAtmOcn_" << rankInCouComm << ".h5m"; 00394 std::string intxfile = outf.str(); // write in serial the intx file, for debugging 00395 ierr = iMOAB_WriteMesh( cplAtmOcnPID, intxfile.c_str(), serialWriteOptions ); 00396 CHECKIERR( ierr, "cannot write intx file result" ) 00397 } 00398 #endif 00399 00400 if( couComm != MPI_COMM_NULL ) 00401 { 00402 PUSH_TIMER( "Compute the projection weights with TempestRemap" ) 00403 ierr = 00404 iMOAB_ComputeScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0].c_str(), disc_methods[0].c_str(), 00405 &disc_orders[0], disc_methods[1].c_str(), &disc_orders[1], &fNoBubble, 00406 &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve, 00407 &fValidate, dof_tag_names[0].c_str(), dof_tag_names[1].c_str() ); 00408 CHECKIERR( ierr, "cannot compute scalar projection weights" ) 00409 POP_TIMER( couComm, rankInCouComm ) 00410 00411 // Let us now write the map file to disk and then read it back to test the I/O API in iMOAB 00412 #ifdef MOAB_HAVE_NETCDF 00413 { 00414 const std::string atmocn_map_file_name = "atm_ocn_map2.nc"; 00415 ierr = iMOAB_WriteMappingWeightsToFile( cplAtmOcnPID, weights_identifiers[0].c_str(), 00416 atmocn_map_file_name.c_str() ); 00417 CHECKIERR( ierr, "failed to write map file to disk" ); 00418 00419 const std::string intx_from_file_identifier = "map-from-file"; 00420 int dummyCpl = -1; 00421 int dummy_rowcol = -1; 00422 int dummyType = 0; 00423 ierr = iMOAB_LoadMappingWeightsFromFile( cplAtmOcnPID, &dummyCpl, &dummy_rowcol, &dummyType, 00424 intx_from_file_identifier.c_str(), atmocn_map_file_name.c_str() ); 00425 CHECKIERR( ierr, "failed to load map file from disk" ); 00426 } 00427 #endif 00428 } 00429 00430 #endif 00431 00432 MPI_Barrier( MPI_COMM_WORLD ); 00433 00434 #ifdef ENABLE_ATMCPLOCN_COUPLING 00435 if( couComm != MPI_COMM_NULL ) 00436 { 00437 PUSH_TIMER( "Compute the projection weights with TempestRemap for atm2/ocn" ) 00438 ierr = 00439 iMOAB_ComputeScalarProjectionWeights( cplAtm2OcnPID, weights_identifiers[0].c_str(), disc_methods[0].c_str(), 00440 &disc_orders[0], disc_methods[1].c_str(), &disc_orders[1], &fNoBubble, 00441 &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve, 00442 &fValidate, dof_tag_names[0].c_str(), dof_tag_names[1].c_str() ); 00443 CHECKIERR( ierr, "cannot compute scalar projection weights for atm2/ocn" ) 00444 POP_TIMER( couComm, rankInCouComm ) 00445 00446 // Let us now write the map file to disk and then read it back to test the I/O API in iMOAB 00447 #ifdef MOAB_HAVE_NETCDF 00448 { 00449 const std::string atmocn_map_file_name = "atm2_ocn_map.nc"; 00450 ierr = iMOAB_WriteMappingWeightsToFile( cplAtm2OcnPID, weights_identifiers[0].c_str(), 00451 atmocn_map_file_name.c_str() ); 00452 CHECKIERR( ierr, "failed to write map file to disk" ); 00453 00454 const std::string intx_from_file_identifier = "map2-from-file"; 00455 int dummyCpl = -1; 00456 int dummy_rowcol = -1; 00457 int dummyType = 0; 00458 ierr = iMOAB_LoadMappingWeightsFromFile( cplAtm2OcnPID, &dummyCpl, &dummy_rowcol, &dummyType, 00459 intx_from_file_identifier.c_str(), atmocn_map_file_name.c_str() ); 00460 CHECKIERR( ierr, "failed to load map file from disk" ); 00461 } 00462 #endif 00463 } 00464 #endif 00465 00466 int tagIndex[2]; 00467 int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE }; 00468 int atmCompNDoFs = disc_orders[0] * disc_orders[0], ocnCompNDoFs = 1 /*FV*/; 00469 00470 const char* bottomFields = "a2oTbot:a2oUbot:a2oVbot"; 00471 const char* bottomProjectedFields = "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj"; 00472 const char* bottomSourceFields2 = "a2oT2bot_src:a2oU2bot_src:a2oV2bot_src"; 00473 const char* bottomProjectedFields3 = "a2oT2bot_proj:a2oU2bot_proj:a2oV2bot_proj"; 00474 00475 if( couComm != MPI_COMM_NULL ) 00476 { 00477 ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00478 CHECKIERR( ierr, "failed to define the field tag a2oTbot" ); 00479 ierr = iMOAB_DefineTagStorage( cplAtm2PID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00480 CHECKIERR( ierr, "failed to define the field tag a2oTbot" ); 00481 00482 #ifdef ENABLE_ATMOCN_COUPLING 00483 ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00484 CHECKIERR( ierr, "failed to define the field tag a2oTbot_proj" ); 00485 #endif 00486 #ifdef ENABLE_ATMCPLOCN_COUPLING 00487 ierr = iMOAB_DefineTagStorage( cplAtm2PID, bottomSourceFields2, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00488 CHECKIERR( ierr, "failed to define the field tag a2oT2bot_proj" ); 00489 ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields3, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00490 CHECKIERR( ierr, "failed to define the field tag a2oT2bot_proj" ); 00491 #endif 00492 } 00493 00494 // need to make sure that the coverage mesh (created during intx method) received the tag that 00495 // need to be projected to target so far, the coverage mesh has only the ids and global dofs; 00496 // need to change the migrate method to accommodate any GLL tag 00497 // now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh 00498 // (cplAtmPID), using the new coverage graph communicator 00499 00500 // make the tag 0, to check we are actually sending needed data 00501 { 00502 if( cplAtmAppID >= 0 ) 00503 { 00504 int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; 00505 /* 00506 * Each process in the communicator will have access to a local mesh instance, which 00507 * will contain the original cells in the local partition and ghost entities. Number of 00508 * vertices, primary cells, visible blocks, number of sidesets and nodesets boundary 00509 * conditions will be returned in numProcesses 3 arrays, for local, ghost and total 00510 * numbers. 00511 */ 00512 ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc ); 00513 CHECKIERR( ierr, "failed to get num primary elems" ); 00514 int numAllElem = nelem[2]; 00515 std::vector< double > vals; 00516 int storLeng = atmCompNDoFs * numAllElem *3; // 3 tags 00517 int eetype = 1; 00518 00519 vals.resize( storLeng ); 00520 for( int k = 0; k < storLeng; k++ ) 00521 vals[k] = 0.; 00522 00523 ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomFields, &storLeng, &eetype, &vals[0] ); 00524 CHECKIERR( ierr, "cannot make tag nul" ) 00525 // set the tag to 0 00526 } 00527 if( cplAtm2AppID >= 0 ) 00528 { 00529 int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; 00530 /* 00531 * Each process in the communicator will have access to a local mesh instance, which 00532 * will contain the original cells in the local partition and ghost entities. Number of 00533 * vertices, primary cells, visible blocks, number of sidesets and nodesets boundary 00534 * conditions will be returned in numProcesses 3 arrays, for local, ghost and total 00535 * numbers. 00536 */ 00537 ierr = iMOAB_GetMeshInfo( cplAtm2PID, nverts, nelem, nblocks, nsbc, ndbc ); 00538 CHECKIERR( ierr, "failed to get num primary elems" ); 00539 int numAllElem = nelem[2]; 00540 std::vector< double > vals; 00541 int storLeng = atmCompNDoFs * numAllElem * 3; // 3 tags 00542 int eetype = 1; 00543 00544 vals.resize( storLeng ); 00545 for( int k = 0; k < storLeng; k++ ) 00546 vals[k] = 0.; 00547 00548 ierr = iMOAB_SetDoubleTagStorage( cplAtm2PID, bottomSourceFields2, &storLeng, &eetype, &vals[0] ); 00549 CHECKIERR( ierr, "cannot make tag nul" ) 00550 // set the tag to 0 00551 } 00552 } 00553 00554 // start a virtual loop for number of iterations 00555 for( int iters = 0; iters < n; iters++ ) 00556 { 00557 #ifdef ENABLE_ATMOCN_COUPLING 00558 PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" ) 00559 if( atmComm != MPI_COMM_NULL ) 00560 { 00561 // as always, use nonblocking sends 00562 // this is for projection to ocean: 00563 ierr = iMOAB_SendElementTag( cmpAtmPID, bottomFields, &atmCouComm, &cplocn ); 00564 CHECKIERR( ierr, "cannot send tag values" ) 00565 } 00566 if( couComm != MPI_COMM_NULL ) 00567 { 00568 // receive on atm on coupler pes, that was redistributed according to coverage 00569 ierr = iMOAB_ReceiveElementTag( cplAtmPID, bottomFields, &atmCouComm, &cplocn ); 00570 CHECKIERR( ierr, "cannot receive tag values" ) 00571 } 00572 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00573 00574 // we can now free the sender buffers 00575 if( atmComm != MPI_COMM_NULL ) 00576 { 00577 ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cplocn ); // context is for ocean 00578 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) 00579 } 00580 #ifdef VERBOSE 00581 if( couComm != MPI_COMM_NULL && 1 == n ) 00582 { 00583 // write only for n==1 case 00584 char outputFileRecvd[] = "recvAtmCoupOcn.h5m"; 00585 ierr = iMOAB_WriteMesh( cplAtmPID, outputFileRecvd, fileWriteOptions ); 00586 CHECKIERR( ierr, "could not write recvAtmCoupOcn.h5m to disk" ) 00587 } 00588 #endif 00589 00590 if( couComm != MPI_COMM_NULL ) 00591 { 00592 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00593 on the source mesh and get the projection on the target mesh */ 00594 PUSH_TIMER( "Apply Scalar projection weights" ) 00595 ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0].c_str(), bottomFields, 00596 bottomProjectedFields ); 00597 CHECKIERR( ierr, "failed to compute projection weight application" ); 00598 POP_TIMER( couComm, rankInCouComm ) 00599 if( 1 == n ) // write only for n==1 case 00600 { 00601 char outputFileTgt[] = "fOcnOnCpl1.h5m"; 00602 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions ); 00603 CHECKIERR( ierr, "could not write fOcnOnCpl1.h5m to disk" ) 00604 } 00605 } 00606 00607 // send the projected tag back to ocean pes, with send/receive tag 00608 if( ocnComm != MPI_COMM_NULL ) 00609 { 00610 int tagIndexIn2; 00611 ierr = 00612 iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); 00613 CHECKIERR( ierr, "failed to define the field tag for receiving back the tags " 00614 "a2oTbot_proj, a2oUbot_proj, a2oVbot_proj on ocn pes" ); 00615 } 00616 // send the tag to ocean pes, from ocean mesh on coupler pes 00617 // from couComm, using common joint comm ocn_coupler 00618 // as always, use nonblocking sends 00619 // original graph (context is -1_ 00620 if( couComm != MPI_COMM_NULL ) 00621 { 00622 // need to use ocean comp id for context 00623 context_id = cmpocn; // id for ocean on comp 00624 ierr = 00625 iMOAB_SendElementTag( cplOcnPID, bottomProjectedFields, &ocnCouComm, &context_id ); 00626 CHECKIERR( ierr, "cannot send tag values back to ocean pes" ) 00627 } 00628 00629 // receive on component 2, ocean 00630 if( ocnComm != MPI_COMM_NULL ) 00631 { 00632 context_id = cplocn; // id for ocean on coupler 00633 ierr = iMOAB_ReceiveElementTag( cmpOcnPID, bottomProjectedFields, &ocnCouComm, 00634 &context_id ); 00635 CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" ) 00636 } 00637 00638 MPI_Barrier( MPI_COMM_WORLD ); 00639 00640 if( couComm != MPI_COMM_NULL ) 00641 { 00642 context_id = cmpocn; 00643 ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id ); 00644 CHECKIERR( ierr, "cannot free send/receive buffers for OCN context" ) 00645 } 00646 if( ocnComm != MPI_COMM_NULL && 1 == n ) // write only for n==1 case 00647 { 00648 char outputFileOcn[] = "OcnWithProj.h5m"; 00649 ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions ); 00650 CHECKIERR( ierr, "could not write OcnWithProj.h5m to disk" ) 00651 // test results only for n == 1, for bottomTempProjectedField 00652 if( !no_regression_test ) 00653 { 00654 // the same as remap test 00655 // get temp field on ocean, from conservative, the global ids, and dump to the baseline file 00656 // first get GlobalIds from ocn, and fields: 00657 int nverts[3], nelem[3]; 00658 ierr = iMOAB_GetMeshInfo( cmpOcnPID, nverts, nelem, 0, 0, 0 ); 00659 CHECKIERR( ierr, "failed to get ocn mesh info" ); 00660 std::vector< int > gidElems; 00661 gidElems.resize( nelem[2] ); 00662 std::vector< double > tempElems; 00663 tempElems.resize( nelem[2] ); 00664 // get global id storage 00665 const std::string GidStr = "GLOBAL_ID"; // hard coded too 00666 int tag_type = DENSE_INTEGER, ncomp = 1, tagInd = 0; 00667 ierr = iMOAB_DefineTagStorage( cmpOcnPID, GidStr.c_str(), &tag_type, &ncomp, &tagInd ); 00668 CHECKIERR( ierr, "failed to define global id tag" ); 00669 00670 int ent_type = 1; 00671 ierr = iMOAB_GetIntTagStorage( cmpOcnPID, GidStr.c_str(), &nelem[2], &ent_type, &gidElems[0] ); 00672 CHECKIERR( ierr, "failed to get global ids" ); 00673 ierr = iMOAB_GetDoubleTagStorage( cmpOcnPID, "a2oTbot_proj", &nelem[2], &ent_type, 00674 &tempElems[0] ); 00675 CHECKIERR( ierr, "failed to get temperature field" ); 00676 int err_code = 1; 00677 check_baseline_file( baseline, gidElems, tempElems, 1.e-9, err_code ); 00678 if( 0 == err_code ) 00679 std::cout << " passed baseline test atm2ocn on ocean task " << rankInOcnComm << "\n"; 00680 } 00681 } 00682 #endif 00683 00684 #ifdef ENABLE_ATMCPLOCN_COUPLING 00685 PUSH_TIMER( "Send/receive data from atm2 component to coupler of all data" ) 00686 if( atmComm != MPI_COMM_NULL ) 00687 { 00688 // as always, use nonblocking sends 00689 // this is for projection to ocean: 00690 ierr = iMOAB_SendElementTag( cmpAtmPID, bottomFields, &atmCouComm, &cplatm2 ); 00691 CHECKIERR( ierr, "cannot send tag values" ) 00692 } 00693 if( couComm != MPI_COMM_NULL ) 00694 { 00695 // receive on atm on coupler pes, that was redistributed according to coverage 00696 ierr = iMOAB_ReceiveElementTag( cplAtm2PID, bottomFields, &atmCouComm, &cmpatm ); 00697 CHECKIERR( ierr, "cannot receive tag values" ) 00698 } 00699 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00700 00701 // we can now free the sender buffers 00702 if( atmComm != MPI_COMM_NULL ) 00703 { 00704 ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cplatm ); // context is for ocean 00705 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) 00706 } 00707 // #ifdef VERBOSE 00708 if( couComm != MPI_COMM_NULL && 1 == n ) 00709 { // write only for n==1 case 00710 char outputFileRecvd[] = "recvAtm2CoupFull.h5m"; 00711 ierr = iMOAB_WriteMesh( cplAtm2PID, outputFileRecvd, fileWriteOptions ); 00712 CHECKIERR( ierr, "could not write recvAtmCoupLnd.h5m to disk" ) 00713 } 00714 // #endif 00715 00716 PUSH_TIMER( "Send/receive data from atm2 coupler to ocean coupler based on coverage data" ) 00717 if( couComm != MPI_COMM_NULL ) 00718 { 00719 // as always, use nonblocking sends 00720 // this is for projection to ocean: 00721 ierr = iMOAB_SendElementTag( cplAtm2PID, bottomFields, &couComm, &atm2ocnid ); 00722 CHECKIERR( ierr, "cannot send tag values" ) 00723 00724 // receive on atm on coupler pes, that was redistributed according to coverage 00725 // receive in the coverage mesh, basically 00726 ierr = iMOAB_ReceiveElementTag( cplAtm2OcnPID, bottomSourceFields2, &couComm, &cplatm2 ); 00727 CHECKIERR( ierr, "cannot receive tag values" ) 00728 } 00729 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00730 00731 // we can now free the sender buffers 00732 if( couComm != MPI_COMM_NULL ) 00733 { 00734 ierr = iMOAB_FreeSenderBuffers( cplAtm2PID, &atm2ocnid ); // context is intx external id 00735 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) 00736 } 00737 // #ifdef VERBOSE 00738 // we should not write this one, is should be the same as recvAtm2CoupFull above 00739 /* if( couComm != MPI_COMM_NULL && 1 == n ) 00740 { // write only for n==1 case 00741 char outputFileRecvd[] = "recvAtm2CoupOcnCtx.h5m"; 00742 ierr = iMOAB_WriteMesh( cplAtm2PID, outputFileRecvd, fileWriteOptions ); 00743 CHECKIERR( ierr, "could not write recvAtmCoupLnd.h5m to disk" ) 00744 } 00745 // #endif*/ 00746 00747 if( couComm != MPI_COMM_NULL ) 00748 { 00749 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00750 on the source mesh and get the projection on the target mesh */ 00751 PUSH_TIMER( "Apply Scalar projection weights" ) 00752 ierr = iMOAB_ApplyScalarProjectionWeights( cplAtm2OcnPID, weights_identifiers[0].c_str(), 00753 bottomSourceFields2, bottomProjectedFields3 ); 00754 CHECKIERR( ierr, "failed to compute projection weight application" ); 00755 POP_TIMER( couComm, rankInCouComm ) 00756 if( 1 == n ) // write only for n==1 case 00757 { 00758 char outputFileTgt[] = "fOcnOnCpl0.h5m"; 00759 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions ); 00760 CHECKIERR( ierr, "could not write the second fOcnOnCpl0.h5m to disk" ) 00761 } 00762 } 00763 00764 std::cout << "applied scalar projection\n"; 00765 // send the projected tag back to ocean pes, with send/receive tag 00766 if( ocnComm != MPI_COMM_NULL ) 00767 { 00768 int tagIndexIn2; 00769 ierr = iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields3, &tagTypes[1], 00770 &ocnCompNDoFs, &tagIndexIn2 ); 00771 CHECKIERR( ierr, "failed to define the field tag for receiving back the tags " 00772 "a2oTbot_proj, a2oUbot_proj, a2oVbot_proj on ocn pes" ); 00773 } 00774 std::cout << "defined tag agian on ocn\n"; 00775 // send the tag to ocean pes, from ocean mesh on coupler pes 00776 // from couComm, using common joint comm ocn_coupler 00777 // as always, use nonblocking sends 00778 // original graph (context is -1_ 00779 if( couComm != MPI_COMM_NULL ) 00780 { 00781 // need to use ocean comp id for context 00782 context_id = cmpocn; // id for ocean on comp 00783 ierr = iMOAB_SendElementTag( cplOcnPID, bottomProjectedFields3, &ocnCouComm, &context_id ); 00784 CHECKIERR( ierr, "cannot send tag values back to ocean pes" ) 00785 } 00786 std::cout << "sent ocn data from coupler to component\n"; 00787 00788 // receive on component 2, ocean 00789 if( ocnComm != MPI_COMM_NULL ) 00790 { 00791 context_id = cplocn; // id for ocean on coupler 00792 ierr = iMOAB_ReceiveElementTag( cmpOcnPID, bottomProjectedFields3, &ocnCouComm, 00793 &context_id ); 00794 CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" ) 00795 } 00796 std::cout << "received ocn data from coupler to component\n"; 00797 00798 MPI_Barrier( MPI_COMM_WORLD ); 00799 00800 if( couComm != MPI_COMM_NULL ) 00801 { 00802 context_id = cmpocn; 00803 ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id ); 00804 CHECKIERR( ierr, "cannot free send/receive buffers for OCN context" ) 00805 } 00806 std::cout << "freed send/recv ocn data from coupler to component\n"; 00807 if( ocnComm != MPI_COMM_NULL && 1 == n ) // write only for n==1 case 00808 { 00809 char outputFileOcn[] = "Ocn2WithProj.h5m"; 00810 ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions ); 00811 CHECKIERR( ierr, "could not write Ocn2WithProj.h5m to disk" ) 00812 // test results only for n == 1, for bottomTempProjectedField 00813 if( !no_regression_test ) 00814 { 00815 // the same as remap test 00816 // get temp field on ocean, from conservative, the global ids, and dump to the baseline file 00817 // first get GlobalIds from ocn, and fields: 00818 int nverts[3], nelem[3]; 00819 ierr = iMOAB_GetMeshInfo( cmpOcnPID, nverts, nelem, 0, 0, 0 ); 00820 CHECKIERR( ierr, "failed to get ocn mesh info" ); 00821 std::vector< int > gidElems; 00822 gidElems.resize( nelem[2] ); 00823 std::vector< double > tempElems; 00824 tempElems.resize( nelem[2] ); 00825 // get global id storage 00826 const std::string GidStr = "GLOBAL_ID"; // hard coded too 00827 int tag_type = DENSE_INTEGER, ncomp = 1, tagInd = 0; 00828 ierr = iMOAB_DefineTagStorage( cmpOcnPID, GidStr.c_str(), &tag_type, &ncomp, &tagInd ); 00829 CHECKIERR( ierr, "failed to define global id tag" ); 00830 00831 int ent_type = 1; 00832 ierr = iMOAB_GetIntTagStorage( cmpOcnPID, GidStr.c_str(), &nelem[2], &ent_type, &gidElems[0] ); 00833 CHECKIERR( ierr, "failed to get global ids" ); 00834 ierr = iMOAB_GetDoubleTagStorage( cmpOcnPID, "a2oTbot_proj", &nelem[2], &ent_type, &tempElems[0] ); 00835 CHECKIERR( ierr, "failed to get temperature field" ); 00836 int err_code = 1; 00837 check_baseline_file( baseline, gidElems, tempElems, 1.e-9, err_code ); 00838 if( 0 == err_code ) 00839 std::cout << " passed baseline test atm2ocn on ocean task " << rankInOcnComm << "\n"; 00840 } 00841 00842 std::cout << "wrote ocn data on component to disk\n"; 00843 } 00844 #endif // ENABLE_ATMCPLOCN_COUPLING 00845 00846 } // end loop iterations n 00847 #ifdef ENABLE_ATMCPLOCN_COUPLING 00848 if( couComm != MPI_COMM_NULL ) 00849 { 00850 ierr = iMOAB_DeregisterApplication( cplAtm2OcnPID ); 00851 CHECKIERR( ierr, "cannot deregister app intx AO" ) 00852 } 00853 #endif // ENABLE_ATMCPLOCN_COUPLING 00854 00855 #ifdef ENABLE_ATMOCN_COUPLING 00856 if( couComm != MPI_COMM_NULL ) 00857 { 00858 ierr = iMOAB_DeregisterApplication( cplAtmOcnPID ); 00859 CHECKIERR( ierr, "cannot deregister app intx AO" ) 00860 } 00861 if( ocnComm != MPI_COMM_NULL ) 00862 { 00863 ierr = iMOAB_DeregisterApplication( cmpOcnPID ); 00864 CHECKIERR( ierr, "cannot deregister app OCN1" ) 00865 } 00866 #endif // ENABLE_ATMOCN_COUPLING 00867 00868 if( atmComm != MPI_COMM_NULL ) 00869 { 00870 ierr = iMOAB_DeregisterApplication( cmpAtmPID ); 00871 CHECKIERR( ierr, "cannot deregister app ATM1" ) 00872 } 00873 00874 #ifdef ENABLE_ATMOCN_COUPLING 00875 if( couComm != MPI_COMM_NULL ) 00876 { 00877 ierr = iMOAB_DeregisterApplication( cplOcnPID ); 00878 CHECKIERR( ierr, "cannot deregister app OCNX" ) 00879 } 00880 #endif // ENABLE_ATMOCN_COUPLING 00881 00882 if( couComm != MPI_COMM_NULL ) 00883 { 00884 ierr = iMOAB_DeregisterApplication( cplAtmPID ); 00885 CHECKIERR( ierr, "cannot deregister app ATMX" ) 00886 } 00887 00888 //#endif 00889 ierr = iMOAB_Finalize(); 00890 CHECKIERR( ierr, "did not finalize iMOAB" ) 00891 00892 // free atm coupler group and comm 00893 if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm ); 00894 MPI_Group_free( &joinAtmCouGroup ); 00895 if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm ); 00896 00897 #ifdef ENABLE_ATMOCN_COUPLING 00898 if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm ); 00899 // free ocn - coupler group and comm 00900 if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm ); 00901 MPI_Group_free( &joinOcnCouGroup ); 00902 #endif 00903 00904 if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm ); 00905 00906 MPI_Group_free( &atmPEGroup ); 00907 #ifdef ENABLE_ATMOCN_COUPLING 00908 MPI_Group_free( &ocnPEGroup ); 00909 #endif 00910 MPI_Group_free( &couPEGroup ); 00911 MPI_Group_free( &jgroup ); 00912 00913 MPI_Finalize(); 00914 00915 return 0; 00916 }
