MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * cslam_par_test.cpp 00003 * test to trigger intersection on a sphere in parallel 00004 * it will start from an eulerian mesh (mesh + velocity from Mark Taylor) 00005 * file: VELO00.h5m; mesh + velo at 850 milibar, in an unstructured mesh refined from 00006 * a cube sphere grid 00007 * the mesh is read in parallel (euler mesh); 00008 * 00009 * lagrangian mesh is obtained using 00010 * pos (t-dt) = pos(t) -Velo(t)*dt 00011 * then, project on the sphere with a given radius 00012 * 00013 * Created on: Apr 22, 2013 00014 */ 00015 00016 #include <iostream> 00017 #include <sstream> 00018 #include <ctime> 00019 #include <cstdlib> 00020 #include <cstdio> 00021 #include <cstring> 00022 #include "moab/Core.hpp" 00023 #include "moab/Interface.hpp" 00024 #include "moab/IntxMesh/Intx2MeshOnSphere.hpp" 00025 #include <cmath> 00026 #include "TestUtil.hpp" 00027 #include "moab/ParallelComm.hpp" 00028 #include "moab/ProgOptions.hpp" 00029 #include "MBParallelConventions.h" 00030 #include "moab/ReadUtilIface.hpp" 00031 #include "MBTagConventions.hpp" 00032 00033 #include "moab/IntxMesh/IntxUtils.hpp" 00034 #include "IntxUtilsCSLAM.hpp" 00035 00036 // for M_PI 00037 #include <cmath> 00038 00039 using namespace moab; 00040 // some input data 00041 double EPS1 = 0.2; // this is for box error 00042 std::string input_mesh_file( "VELO00_16p.h5m" ); // input file, partitioned correctly 00043 double Radius = 1.0; // change to radius 00044 double deltaT = 1.e-6; 00045 void test_intx_in_parallel_elem_based(); 00046 00047 int main( int argc, char** argv ) 00048 { 00049 MPI_Init( &argc, &argv ); 00050 EPS1 = 0.000002; 00051 int result = 0; 00052 00053 if( argc > 1 ) 00054 { 00055 int index = 1; 00056 while( index < argc ) 00057 { 00058 if( !strcmp( argv[index], "-eps" ) ) // this is for box error 00059 { 00060 EPS1 = atof( argv[++index] ); 00061 } 00062 if( !strcmp( argv[index], "-input" ) ) 00063 { 00064 input_mesh_file = argv[++index]; 00065 } 00066 if( !strcmp( argv[index], "-radius" ) ) 00067 { 00068 Radius = atof( argv[++index] ); 00069 } 00070 if( !strcmp( argv[index], "-deltaT" ) ) 00071 { 00072 deltaT = atof( argv[++index] ); 00073 } 00074 index++; 00075 } 00076 } 00077 std::cout << " run: -input " << input_mesh_file << " -eps " << EPS1 << " -radius " << Radius << " -deltaT " 00078 << deltaT << "\n"; 00079 00080 result += RUN_TEST( test_intx_in_parallel_elem_based ); 00081 00082 MPI_Finalize(); 00083 return result; 00084 } 00085 // will save the LOC tag on the euler nodes 00086 ErrorCode compute_lagrange_mesh_on_sphere( Interface* mb, EntityHandle euler_set ) 00087 { 00088 /* 00089 * get all quads first, then vertices, then move them on the surface of the sphere 00090 * radius is 1, usually 00091 * pos (t-dt) = pos(t) -Velo(t)*dt; this will be lagrange mesh, on each processor 00092 */ 00093 Range quads; 00094 ErrorCode rval = mb->get_entities_by_type( euler_set, MBQUAD, quads );MB_CHK_ERR( rval ); 00095 00096 Range connecVerts; 00097 rval = mb->get_connectivity( quads, connecVerts );MB_CHK_ERR( rval ); 00098 00099 // the LOC tag, should be provided by the user? 00100 Tag tagh = 0; 00101 std::string tag_name( "DP" ); 00102 rval = mb->tag_get_handle( tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval ); 00103 void* data; // pointer to the DP in memory, for each vertex 00104 int count; 00105 00106 rval = mb->tag_iterate( tagh, connecVerts.begin(), connecVerts.end(), count, data );MB_CHK_ERR( rval ); 00107 // here we are checking contiguity 00108 assert( count == (int)connecVerts.size() ); 00109 double* ptr_DP = (double*)data; 00110 // get the coordinates of the old mesh, and move it around using velocity tag 00111 00112 Tag tagv = 0; 00113 std::string velo_tag_name( "VELO" ); 00114 rval = mb->tag_get_handle( velo_tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagv, MB_TAG_DENSE );MB_CHK_ERR( rval ); 00115 00116 /*void *datavelo; // pointer to the VELO in memory, for each vertex 00117 00118 rval = mb->tag_iterate(tagv, connecVerts.begin(), connecVerts.end(), count, datavelo);MB_CHK_ERR(rval);*/ 00119 // here we are checking contiguity 00120 assert( count == (int)connecVerts.size() ); 00121 // now put the vertices in the right place.... 00122 // int vix=0; // vertex index in new array 00123 00124 for( Range::iterator vit = connecVerts.begin(); vit != connecVerts.end(); ++vit ) 00125 { 00126 EntityHandle oldV = *vit; 00127 CartVect posi; 00128 rval = mb->get_coords( &oldV, 1, &( posi[0] ) );MB_CHK_ERR( rval ); 00129 CartVect velo; 00130 rval = mb->tag_get_data( tagv, &oldV, 1, (void*)&( velo[0] ) );MB_CHK_ERR( rval ); 00131 // do some mumbo jumbo, as in python script 00132 CartVect newPos = posi - deltaT * velo; 00133 double len1 = newPos.length(); 00134 newPos = Radius * newPos / len1; 00135 00136 ptr_DP[0] = newPos[0]; 00137 ptr_DP[1] = newPos[1]; 00138 ptr_DP[2] = newPos[2]; 00139 ptr_DP += 3; // increment to the next node 00140 } 00141 00142 return rval; 00143 } 00144 00145 void test_intx_in_parallel_elem_based() 00146 { 00147 std::string opts = std::string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ) + 00148 std::string( ";PARALLEL_RESOLVE_SHARED_ENTS" ); 00149 Core moab; 00150 Interface& mb = moab; 00151 EntityHandle euler_set; 00152 ErrorCode rval; 00153 rval = mb.create_meshset( MESHSET_SET, euler_set );MB_CHK_ERR_RET( rval ); 00154 std::string example( TestDir + "unittest/" + input_mesh_file ); 00155 00156 rval = mb.load_file( example.c_str(), &euler_set, opts.c_str() ); 00157 00158 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );MB_CHK_ERR_RET( rval ); 00159 00160 rval = pcomm->check_all_shared_handles();MB_CHK_ERR_RET( rval ); 00161 00162 // everybody will get a DP tag, including the non owned entities; so exchange tags is not 00163 // required for LOC (here) 00164 rval = compute_lagrange_mesh_on_sphere( &mb, euler_set );MB_CHK_ERR_RET( rval ); 00165 00166 int rank = pcomm->proc_config().proc_rank(); 00167 00168 std::stringstream ste; 00169 ste << "initial" << rank << ".vtk"; 00170 mb.write_file( ste.str().c_str(), 0, 0, &euler_set, 1 ); 00171 00172 Intx2MeshOnSphere worker( &mb ); 00173 00174 worker.set_radius_source_mesh( Radius ); 00175 worker.set_radius_destination_mesh( Radius ); 00176 worker.set_box_error( EPS1 ); // 00177 // worker.SetEntityType(MBQUAD); 00178 00179 worker.set_error_tolerance( Radius * 1.e-8 ); 00180 std::cout << "error tolerance epsilon_1=" << Radius * 1.e-8 << "\n"; 00181 // worker.locate_departure_points(euler_set); 00182 00183 rval = worker.FindMaxEdges( euler_set, euler_set ); // departure will be the same max_edges 00184 // we need to make sure the covering set is bigger than the euler mesh 00185 EntityHandle covering_lagr_set; 00186 rval = mb.create_meshset( MESHSET_SET, covering_lagr_set );MB_CHK_ERR_RET( rval ); 00187 00188 rval = worker.create_departure_mesh_2nd_alg( euler_set, covering_lagr_set );MB_CHK_ERR_RET( rval ); 00189 00190 std::stringstream ss; 00191 ss << "partial" << rank << ".vtk"; 00192 mb.write_file( ss.str().c_str(), 0, 0, &covering_lagr_set, 1 ); 00193 EntityHandle outputSet; 00194 rval = mb.create_meshset( MESHSET_SET, outputSet );MB_CHK_ERR_RET( rval ); 00195 rval = worker.intersect_meshes( covering_lagr_set, euler_set, outputSet );MB_CHK_ERR_RET( rval ); 00196 00197 // std::string opts_write("PARALLEL=WRITE_PART"); 00198 // rval = mb.write_file("manuf.h5m", 0, opts_write.c_str(), &outputSet, 1); 00199 // std::string opts_write(""); 00200 std::stringstream outf; 00201 outf << "intersect" << rank << ".h5m"; 00202 rval = mb.write_file( outf.str().c_str(), 0, 0, &outputSet, 1 );MB_CHK_ERR_RET( rval ); 00203 00204 moab::IntxAreaUtils sphAreaUtils; 00205 double intx_area = sphAreaUtils.area_on_sphere( &mb, outputSet, Radius ); 00206 double arrival_area = sphAreaUtils.area_on_sphere( &mb, euler_set, Radius ); 00207 std::cout << "On rank : " << rank << " arrival area: " << arrival_area << " intersection area:" << intx_area 00208 << " rel error: " << fabs( ( intx_area - arrival_area ) / arrival_area ) << "\n"; 00209 }
