MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "MeshOutputFunctor.hpp" 00002 00003 #include "SplitVertices.hpp" 00004 #include "moab/ParallelComm.hpp" 00005 #include "RefinerTagManager.hpp" 00006 00007 #include <iostream> 00008 #include <set> 00009 #include <iterator> 00010 #include <algorithm> 00011 00012 #undef MB_DEBUG 00013 00014 namespace moab 00015 { 00016 00017 MeshOutputFunctor::MeshOutputFunctor( RefinerTagManager* tag_mgr ) 00018 { 00019 this->mesh_in = tag_mgr->get_input_mesh(); 00020 this->mesh_out = tag_mgr->get_output_mesh(); 00021 this->input_is_output = ( this->mesh_in == this->mesh_out ); 00022 this->tag_manager = tag_mgr; 00023 this->destination_set = 0; // don't place output entities in a set by default. 00024 00025 // When the input mesh and the output mesh are different, this map serves 00026 // as a dictionary from input vertices to output vertices. 00027 this->vertex_map = new SplitVertices< 1 >( this->tag_manager ); 00028 00029 // Hold information about newly-created vertices on subdivided edges and faces. 00030 this->split_vertices.resize( 4 ); 00031 this->split_vertices[0] = 0; // Vertices (0-faces) cannot be split 00032 this->split_vertices[1] = new SplitVertices< 1 >( this->tag_manager ); 00033 this->split_vertices[2] = new SplitVertices< 2 >( this->tag_manager ); 00034 this->split_vertices[3] = new SplitVertices< 3 >( this->tag_manager ); 00035 00036 // Hold information about newly-created mesh entities (other than split vertices) 00037 // This is necessary in order for global IDs to be assigned consistently across processes. 00038 this->new_entities.resize( 5 ); 00039 this->new_entities[0] = new EntitySource( 1, this->tag_manager ); 00040 this->new_entities[1] = new EntitySource( 2, this->tag_manager ); 00041 this->new_entities[2] = new EntitySource( 3, this->tag_manager ); 00042 this->new_entities[3] = new EntitySource( 4, this->tag_manager ); 00043 this->new_entities[4] = new EntitySource( 5, this->tag_manager ); 00044 } 00045 00046 MeshOutputFunctor::~MeshOutputFunctor() 00047 { 00048 delete this->vertex_map; 00049 for( int i = 1; i < 4; ++i ) 00050 delete this->split_vertices[i]; 00051 for( int i = 0; i < 5; ++i ) 00052 delete this->new_entities[i]; 00053 } 00054 00055 void MeshOutputFunctor::print_vert_crud( EntityHandle vout, 00056 int nvhash, 00057 EntityHandle* vhash, 00058 const double* vcoords, 00059 const void* /*vtags*/ ) 00060 { 00061 std::cout << "+ {"; 00062 for( int i = 0; i < nvhash; ++i ) 00063 std::cout << " " << vhash[i]; 00064 std::cout << " } -> " << vout << " "; 00065 00066 std::cout << "[ " << vcoords[0]; 00067 for( int i = 1; i < 6; ++i ) 00068 std::cout << ", " << vcoords[i]; 00069 std::cout << " ] "; 00070 00071 #if 0 00072 double* x = (double*)vtags; 00073 int* m = (int*)( (char*)vtags + 2 * sizeof( double ) ); 00074 std::cout << "< " << x[0] 00075 << ", " << x[1]; 00076 for ( int i = 0; i < 4; ++i ) 00077 std::cout << ", " << m[i]; 00078 #endif // 0 00079 00080 std::cout << " >\n"; 00081 // std::cout << "##############################\n"; 00082 // this->mesh_out->list_entities( 0, 1 ); 00083 // std::cout << "##############################\n"; 00084 } 00085 00086 void MeshOutputFunctor::assign_global_ids( ParallelComm* comm ) 00087 { 00088 // First, we must gather the number of entities in each 00089 // partition (for all partitions, not just those resident locally). 00090 int lnparts = this->proc_partition_counts.size(); 00091 std::vector< unsigned char > lpdefns; 00092 std::vector< int > lpsizes; 00093 lpdefns.resize( ProcessSet::SHARED_PROC_BYTES * lnparts ); 00094 lpsizes.resize( lnparts ); 00095 #ifdef MB_DEBUG 00096 std::cout << "**** Partition Counts ****\n"; 00097 #endif // MB_DEBUG 00098 int i = 0; 00099 std::map< ProcessSet, int >::iterator it; 00100 for( it = this->proc_partition_counts.begin(); it != this->proc_partition_counts.end(); ++it, ++i ) 00101 { 00102 for( int j = 0; j < ProcessSet::SHARED_PROC_BYTES; ++j ) 00103 lpdefns[ProcessSet::SHARED_PROC_BYTES * i + j] = it->first.data()[j]; 00104 lpsizes[i] = it->second; 00105 #ifdef MB_DEBUG 00106 std::cout << "Partition " << it->first << ": " << it->second << "\n"; 00107 #endif // MB_DEBUG 00108 } 00109 00110 if( !comm ) return; 00111 00112 std::vector< int > nparts; 00113 std::vector< int > dparts; 00114 // unsigned long prank = comm->proc_config().proc_rank(); 00115 unsigned long psize = comm->proc_config().proc_size(); 00116 nparts.resize( psize ); 00117 dparts.resize( psize + 1 ); 00118 MPI_Allgather( &lnparts, 1, MPI_INT, &nparts[0], 1, MPI_INT, comm->proc_config().proc_comm() ); 00119 // unsigned long ndefs = 0; 00120 for( unsigned long rank = 1; rank <= psize; ++rank ) 00121 { 00122 dparts[rank] = nparts[rank - 1] + dparts[rank - 1]; 00123 #ifdef MB_DEBUG 00124 std::cout << "Proc " << rank << ": " << nparts[rank - 1] << " partitions, offset: " << dparts[rank] << "\n"; 00125 #endif // MB_DEBUG 00126 } 00127 std::vector< unsigned char > part_defns; 00128 std::vector< int > part_sizes; 00129 part_defns.resize( ProcessSet::SHARED_PROC_BYTES * dparts[psize] ); 00130 part_sizes.resize( dparts[psize] ); 00131 MPI_Allgatherv( &lpsizes[0], lnparts, MPI_INT, &part_sizes[0], &nparts[0], &dparts[0], MPI_INT, 00132 comm->proc_config().proc_comm() ); 00133 for( unsigned long rank = 0; rank < psize; ++rank ) 00134 { 00135 nparts[rank] *= ProcessSet::SHARED_PROC_BYTES; 00136 dparts[rank] *= ProcessSet::SHARED_PROC_BYTES; 00137 } 00138 MPI_Allgatherv( &lpdefns[0], ProcessSet::SHARED_PROC_BYTES * lnparts, MPI_UNSIGNED_CHAR, &part_defns[0], &nparts[0], 00139 &dparts[0], MPI_UNSIGNED_CHAR, comm->proc_config().proc_comm() ); 00140 00141 // Now that we have the number of new entities in every partition, we 00142 // can deterministically assign the same GID to the same entity even 00143 // when shared across processors because we have an ordering that is 00144 // identical on all processes -- the vertex splits. 00145 for( int j = 0; j < dparts[psize]; ++j ) 00146 { 00147 ProcessSet pset( &part_defns[ProcessSet::SHARED_PROC_BYTES * j] ); 00148 std::map< ProcessSet, int >::iterator mit = this->proc_partition_counts.find( pset ); 00149 if( mit != this->proc_partition_counts.end() ) 00150 { 00151 #ifdef MB_DEBUG 00152 std::cout << "Partition " << pset << ( mit->second == part_sizes[j] ? " matches" : " broken" ) << ".\n"; 00153 #endif // MB_DEBUG 00154 } 00155 else 00156 { 00157 this->proc_partition_counts[pset] = part_sizes[j]; 00158 } 00159 } 00160 00161 std::map< ProcessSet, int > gids; 00162 std::map< ProcessSet, int >::iterator pcit; 00163 EntityHandle start_gid = 100; // FIXME: Get actual maximum GID across all processes and add 1 00164 for( pcit = this->proc_partition_counts.begin(); pcit != this->proc_partition_counts.end(); ++pcit ) 00165 { 00166 gids[pcit->first] = start_gid; 00167 start_gid += pcit->second; 00168 #ifdef MB_DEBUG 00169 std::cout << "Partition " << pcit->first << ": " << pcit->second << " # [" << gids[pcit->first] << "]\n"; 00170 #endif // MB_DEBUG 00171 } 00172 std::vector< SplitVerticesBase* >::iterator vit; 00173 vit = this->split_vertices.begin(); 00174 ++vit; // Skip split_vertices[0] since it's empty. 00175 ++vit; // Skip split_vertices[1] since those entries already have global IDs... they exist in 00176 // the input mesh. 00177 for( /* skip */; vit != this->split_vertices.end(); ++vit ) 00178 { 00179 ( *vit )->assign_global_ids( gids ); 00180 } 00181 std::vector< EntitySource* >::iterator sit; 00182 for( sit = this->new_entities.begin(); sit != this->new_entities.end(); ++sit ) 00183 { 00184 if( *sit ) ( *sit )->assign_global_ids( gids ); 00185 } 00186 } 00187 00188 void MeshOutputFunctor::exchange_handles( ParallelComm* ) {} 00189 00190 void MeshOutputFunctor::assign_tags( EntityHandle vhandle, const void* vtags ) 00191 { 00192 if( !vhandle ) return; // Ignore bad vertices 00193 00194 int num_tags = this->tag_manager->get_number_of_vertex_tags(); 00195 Tag tag_handle; 00196 int tag_offset; 00197 for( int i = 0; i < num_tags; ++i ) 00198 { 00199 this->tag_manager->get_output_vertex_tag( i, tag_handle, tag_offset ); 00200 this->mesh_out->tag_set_data( tag_handle, &vhandle, 1, vtags ); 00201 } 00202 } 00203 00204 EntityHandle MeshOutputFunctor::map_vertex( EntityHandle vhash, const double* vcoords, const void* vtags ) 00205 { 00206 if( this->input_is_output ) 00207 { // Don't copy the original vertex! 00208 #ifdef MB_DEBUG 00209 this->print_vert_crud( vhash, 1, &vhash, vcoords, vtags ); 00210 #endif // MB_DEBUG 00211 return vhash; 00212 } 00213 EntityHandle vertex_handle; 00214 bool newly_created = 00215 this->vertex_map->find_or_create( &vhash, vcoords, vertex_handle, this->proc_partition_counts, false ); 00216 if( newly_created ) 00217 { 00218 std::vector< int > gid; 00219 this->assign_tags( vertex_handle, vtags ); 00220 if( this->tag_manager->get_input_gids( 1, &vhash, gid ) == MB_SUCCESS ) 00221 { 00222 this->tag_manager->set_gid( vertex_handle, gid[0] ); 00223 } 00224 } 00225 if( !vertex_handle ) 00226 { 00227 std::cerr << "Could not insert vertex into new mesh!\n"; 00228 } 00229 #ifdef MB_DEBUG 00230 this->print_vert_crud( vertex_handle, 1, &vhash, vcoords, vtags ); 00231 std::cout << "\nMap vert: " << vhash << " to: " << vertex_handle << "\n"; 00232 #endif // MB_DEBUG 00233 return vertex_handle; 00234 } 00235 00236 EntityHandle MeshOutputFunctor::operator()( int nvhash, EntityHandle* vhash, const double* vcoords, const void* vtags ) 00237 { 00238 EntityHandle vertex_handle; 00239 if( nvhash < 4 ) 00240 { 00241 bool newly_created = this->split_vertices[nvhash]->find_or_create( vhash, vcoords, vertex_handle, 00242 this->proc_partition_counts, true ); 00243 if( newly_created ) 00244 { 00245 this->assign_tags( vertex_handle, vtags ); 00246 } 00247 if( !vertex_handle ) 00248 { 00249 std::cerr << "Could not insert mid-edge vertex!\n"; 00250 } 00251 #ifdef MB_DEBUG 00252 std::cout << "(-" << nvhash << "-) "; 00253 this->print_vert_crud( vertex_handle, nvhash, vhash, vcoords, vtags ); 00254 #endif // MB_DEBUG 00255 } 00256 else 00257 { 00258 vertex_handle = 0; 00259 std::cerr << "Not handling splits on faces with " << nvhash << " corners yet.\n"; 00260 } 00261 return vertex_handle; 00262 } 00263 00264 void MeshOutputFunctor::operator()( EntityHandle h ) 00265 { 00266 #ifdef MB_DEBUG 00267 std::cout << h << " "; 00268 #endif // MB_DEBUG 00269 if( !this->input_is_output ) 00270 { 00271 // FIXME: Copy to output mesh 00272 } 00273 this->elem_vert.push_back( h ); 00274 } 00275 00276 void MeshOutputFunctor::operator()( EntityType etyp ) 00277 { 00278 EntityHandle elem_handle; 00279 int nconn = this->elem_vert.size(); 00280 bool newly_created = this->new_entities[nconn]->create_element( etyp, nconn, &this->elem_vert[0], elem_handle, 00281 this->proc_partition_counts ); 00282 if( newly_created ) 00283 { 00284 #ifdef MB_DEBUG 00285 std::cout << " *** "; 00286 #endif // MB_DEBUG 00287 // FIXME: Handle tag assignment for elements as well as vertices 00288 this->tag_manager->assign_element_tags( elem_handle ); 00289 } 00290 #ifdef MB_DEBUG 00291 std::cout << "---------> " << elem_handle << " ( " << etyp << " )\n\n"; 00292 #endif // MB_DEBUG 00293 this->elem_vert.clear(); 00294 } 00295 00296 } // namespace moab
