MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * par_intx_sph.cpp 00003 * test to trigger intersection on a sphere in parallel 00004 * it will start from an eulerian mesh 00005 * the mesh is read in parallel; lagrangian mesh is manufactured on the fly (part of the test), in 00006 * a different set. 00007 * 00008 * intersections will be performed on the euler mesh 00009 * Created on: Nov 14, 2012 00010 */ 00011 00012 #include <iostream> 00013 #include <sstream> 00014 #include <ctime> 00015 #include <cstdlib> 00016 #include <cstdio> 00017 #include <cstring> 00018 #include "moab/Core.hpp" 00019 #include "moab/Interface.hpp" 00020 #include "moab/IntxMesh/Intx2MeshOnSphere.hpp" 00021 #include <cmath> 00022 #include "TestUtil.hpp" 00023 #include "moab/ParallelComm.hpp" 00024 #include "moab/ProgOptions.hpp" 00025 #include "MBParallelConventions.h" 00026 #include "moab/ReadUtilIface.hpp" 00027 #include "MBTagConventions.hpp" 00028 00029 #include "moab/IntxMesh/IntxUtils.hpp" 00030 00031 // for M_PI 00032 #include <cmath> 00033 00034 using namespace moab; 00035 // some input data 00036 double EPS1 = 0.2; // this is for box error 00037 std::string input_mesh_file( "Homme_2pt.h5m" ); // input file, partitioned correctly 00038 std::string mpas_file( "mpas_p8.h5m" ); 00039 double CubeSide = 6.; // the above file starts with cube side 6; radius depends on cube side 00040 double radius; 00041 void test_intx_in_parallel_elem_based(); 00042 void test_intx_mpas(); 00043 00044 int main( int argc, char** argv ) 00045 { 00046 MPI_Init( &argc, &argv ); 00047 EPS1 = 0.2; 00048 int result = 0; 00049 00050 if( argc > 1 ) 00051 { 00052 int index = 1; 00053 while( index < argc ) 00054 { 00055 if( !strcmp( argv[index], "-eps" ) ) // this is for box error 00056 { 00057 EPS1 = atof( argv[++index] ); 00058 } 00059 if( !strcmp( argv[index], "-input" ) ) 00060 { 00061 input_mesh_file = argv[++index]; 00062 } 00063 if( !strcmp( argv[index], "-cube" ) ) 00064 { 00065 CubeSide = atof( argv[++index] ); 00066 } 00067 index++; 00068 } 00069 } 00070 00071 radius = CubeSide / 2 * sqrt( 3. ); 00072 result += RUN_TEST( test_intx_in_parallel_elem_based ); 00073 radius = 1.; 00074 result += RUN_TEST( test_intx_mpas ); 00075 00076 MPI_Finalize(); 00077 return result; 00078 } 00079 // will save the LOC tag on the euler nodes 00080 ErrorCode manufacture_lagrange_mesh_on_sphere( Interface* mb, EntityHandle euler_set ) 00081 { 00082 /* 00083 * get all quads first, then vertices, then move them on the surface of the sphere 00084 * radius is in, it comes from MeshKit/python/examples/manufHomme.py : 00085 * length = 6. 00086 * each edge of the cube will be divided using this meshcount 00087 * meshcount = 11 00088 * circumscribed sphere radius 00089 * radius = length * math.sqrt(3) /2 00090 */ 00091 // radius = CubeSide/2*sqrt(3.);// our value depends on cube side 00092 Range quads; 00093 ErrorCode rval = mb->get_entities_by_dimension( euler_set, 2, quads );CHECK_ERR( rval ); 00094 00095 Range connecVerts; 00096 rval = mb->get_connectivity( quads, connecVerts );CHECK_ERR( rval ); 00097 00098 // the LOC tag, should be provided by the user? 00099 Tag tagh = 0; 00100 std::string tag_name( "DP" ); 00101 rval = mb->tag_get_handle( tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT );CHECK_ERR( rval ); 00102 void* data; // pointer to the LOC in memory, for each vertex 00103 int count; 00104 00105 rval = mb->tag_iterate( tagh, connecVerts.begin(), connecVerts.end(), count, data );CHECK_ERR( rval ); 00106 // here we are checking contiguity 00107 assert( count == (int)connecVerts.size() ); 00108 double* ptr_DP = (double*)data; 00109 // get the coordinates of the old mesh, and move it around the sphere in the same way as in the 00110 // python script 00111 00112 // now put the vertices in the right place.... 00113 // int vix=0; // vertex index in new array 00114 double t = 0.1, T = 5; // check the script 00115 double time = 0.05; 00116 double rot = M_PI / 10; 00117 for( Range::iterator vit = connecVerts.begin(); vit != connecVerts.end(); ++vit ) 00118 { 00119 EntityHandle oldV = *vit; 00120 CartVect posi; 00121 rval = mb->get_coords( &oldV, 1, &( posi[0] ) );CHECK_ERR( rval ); 00122 // do some mumbo jumbo, as in python script 00123 moab::IntxUtils::SphereCoords sphCoord = moab::IntxUtils::cart_to_spherical( posi ); 00124 double lat1 = sphCoord.lat - 2 * M_PI * t / T; // 0.1/5 00125 double uu = 3 * radius / T * pow( sin( lat1 ), 2 ) * sin( 2 * sphCoord.lon ) * cos( M_PI * t / T ); 00126 uu += 2 * M_PI * cos( sphCoord.lon ) / T; 00127 double vv = 3 * radius / T * ( sin( 2 * lat1 ) ) * cos( sphCoord.lon ) * cos( M_PI * t / T ); 00128 double vx = -uu * sin( sphCoord.lon ) - vv * sin( sphCoord.lat ) * cos( sphCoord.lon ); 00129 double vy = -uu * cos( sphCoord.lon ) - vv * sin( sphCoord.lat ) * sin( sphCoord.lon ); 00130 double vz = vv * cos( sphCoord.lat ); 00131 posi = posi + time * CartVect( vx, vy, vz ); 00132 double x2 = posi[0] * cos( rot ) - posi[1] * sin( rot ); 00133 double y2 = posi[0] * sin( rot ) + posi[1] * cos( rot ); 00134 CartVect newPos( x2, y2, posi[2] ); 00135 double len1 = newPos.length(); 00136 newPos = radius * newPos / len1; 00137 00138 ptr_DP[0] = newPos[0]; 00139 ptr_DP[1] = newPos[1]; 00140 ptr_DP[2] = newPos[2]; 00141 ptr_DP += 3; // increment to the next node 00142 } 00143 00144 return rval; 00145 } 00146 00147 void test_intx_in_parallel_elem_based() 00148 { 00149 std::string opts = std::string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ) + 00150 std::string( ";PARALLEL_RESOLVE_SHARED_ENTS" ); 00151 Core moab; 00152 Interface& mb = moab; 00153 EntityHandle euler_set; 00154 ErrorCode rval; 00155 rval = mb.create_meshset( MESHSET_SET, euler_set );CHECK_ERR( rval ); 00156 std::string example( TestDir + "unittest/" + input_mesh_file ); 00157 00158 rval = mb.load_file( example.c_str(), &euler_set, opts.c_str() );CHECK_ERR( rval ); 00159 00160 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00161 CHECK( NULL != pcomm ); 00162 00163 rval = pcomm->check_all_shared_handles();CHECK_ERR( rval ); 00164 00165 // everybody will get a DP tag, including the non owned entities; so exchange tags is not 00166 // required for LOC (here) 00167 rval = manufacture_lagrange_mesh_on_sphere( &mb, euler_set );CHECK_ERR( rval ); 00168 00169 int rank = pcomm->proc_config().proc_rank(); 00170 00171 std::stringstream ste; 00172 ste << "initial" << rank << ".vtk"; 00173 mb.write_file( ste.str().c_str(), 0, 0, &euler_set, 1 ); 00174 00175 Intx2MeshOnSphere worker( &mb ); 00176 00177 // double radius= CubeSide/2 * sqrt(3.) ; // input 00178 worker.set_radius_source_mesh( radius ); 00179 worker.set_radius_destination_mesh( radius ); 00180 worker.set_box_error( EPS1 ); // 00181 // worker.SetEntityType(MBQUAD); 00182 00183 worker.set_error_tolerance( radius * 1.e-8 ); 00184 std::cout << "error tolerance epsilon_1=" << radius * 1.e-8 << "\n"; 00185 // worker.locate_departure_points(euler_set); 00186 // set pcomm 00187 worker.set_parallel_comm( pcomm ); 00188 00189 rval = worker.FindMaxEdges( euler_set, euler_set ); // use euler set for both, it is just finding max_edges_1 and 2 00190 // we need to make sure the covering set is bigger than the euler mesh 00191 EntityHandle covering_lagr_set; 00192 rval = mb.create_meshset( MESHSET_SET, covering_lagr_set );CHECK_ERR( rval ); 00193 00194 rval = worker.create_departure_mesh_2nd_alg( euler_set, covering_lagr_set );CHECK_ERR( rval ); 00195 00196 std::stringstream ss; 00197 ss << "partial" << rank << ".vtk"; 00198 mb.write_file( ss.str().c_str(), 0, 0, &covering_lagr_set, 1 ); 00199 EntityHandle outputSet; 00200 rval = mb.create_meshset( MESHSET_SET, outputSet );CHECK_ERR( rval ); 00201 rval = worker.intersect_meshes( covering_lagr_set, euler_set, outputSet );CHECK_ERR( rval ); 00202 00203 IntxAreaUtils areaAdaptor; 00204 // std::string opts_write("PARALLEL=WRITE_PART"); 00205 // rval = mb.write_file("manuf.h5m", 0, opts_write.c_str(), &outputSet, 1); 00206 // std::string opts_write(""); 00207 std::stringstream outf; 00208 outf << "intersect" << rank << ".h5m"; 00209 rval = mb.write_file( outf.str().c_str(), 0, 0, &outputSet, 1 ); 00210 double intx_area = areaAdaptor.area_on_sphere( &mb, outputSet, radius ); 00211 double arrival_area = areaAdaptor.area_on_sphere( &mb, euler_set, radius ); 00212 std::cout << "On rank : " << rank << " arrival area: " << arrival_area << " intersection area:" << intx_area 00213 << " rel error: " << fabs( ( intx_area - arrival_area ) / arrival_area ) << "\n";CHECK_ERR( rval ); 00214 } 00215 00216 void test_intx_mpas() 00217 { 00218 std::string opts = std::string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ) + 00219 std::string( ";PARALLEL_RESOLVE_SHARED_ENTS" ); 00220 Core moab; 00221 Interface& mb = moab; 00222 EntityHandle euler_set; 00223 ErrorCode rval; 00224 rval = mb.create_meshset( MESHSET_SET, euler_set );CHECK_ERR( rval ); 00225 std::string example( TestDir + "unittest/" + mpas_file ); 00226 00227 rval = mb.load_file( example.c_str(), &euler_set, opts.c_str() ); 00228 00229 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00230 00231 rval = pcomm->check_all_shared_handles();CHECK_ERR( rval ); 00232 00233 // everybody will get a DP tag, including the non owned entities; so exchange tags is not 00234 // required for LOC (here) 00235 rval = manufacture_lagrange_mesh_on_sphere( &mb, euler_set );CHECK_ERR( rval ); 00236 00237 int rank = pcomm->proc_config().proc_rank(); 00238 00239 std::stringstream ste; 00240 ste << "initial" << rank << ".vtk"; 00241 mb.write_file( ste.str().c_str(), 0, 0, &euler_set, 1 ); 00242 00243 Intx2MeshOnSphere worker( &mb ); 00244 00245 // double radius= CubeSide/2 * sqrt(3.) ; // input 00246 worker.set_radius_source_mesh( radius ); 00247 worker.set_radius_destination_mesh( radius ); 00248 worker.set_box_error( EPS1 ); // 00249 // worker.SetEntityType(MBQUAD); 00250 00251 worker.set_error_tolerance( radius * 1.e-8 ); 00252 std::cout << "error tolerance epsilon_1=" << radius * 1.e-8 << "\n"; 00253 // worker.locate_departure_points(euler_set); 00254 00255 rval = worker.FindMaxEdges( euler_set, euler_set ); 00256 00257 // we need to make sure the covering set is bigger than the euler mesh 00258 EntityHandle covering_lagr_set; 00259 rval = mb.create_meshset( MESHSET_SET, covering_lagr_set );CHECK_ERR( rval ); 00260 00261 // set pcomm 00262 worker.set_parallel_comm( pcomm ); 00263 00264 rval = worker.create_departure_mesh_2nd_alg( euler_set, covering_lagr_set );CHECK_ERR( rval ); 00265 00266 std::stringstream ss; 00267 ss << "partial" << rank << ".vtk"; 00268 mb.write_file( ss.str().c_str(), 0, 0, &covering_lagr_set, 1 ); 00269 rval = moab::IntxUtils::enforce_convexity( &mb, covering_lagr_set, rank );CHECK_ERR( rval ); 00270 std::stringstream ss2; 00271 ss2 << "partialConvex" << rank << ".vtk"; 00272 mb.write_file( ss2.str().c_str(), 0, 0, &covering_lagr_set, 1 ); 00273 EntityHandle outputSet; 00274 rval = mb.create_meshset( MESHSET_SET, outputSet );CHECK_ERR( rval ); 00275 rval = worker.intersect_meshes( covering_lagr_set, euler_set, outputSet );CHECK_ERR( rval ); 00276 00277 // std::string opts_write("PARALLEL=WRITE_PART"); 00278 // rval = mb.write_file("manuf.h5m", 0, opts_write.c_str(), &outputSet, 1); 00279 // std::string opts_write(""); 00280 std::stringstream outf; 00281 outf << "intersect" << rank << ".h5m"; 00282 rval = mb.write_file( outf.str().c_str(), 0, 0, &outputSet, 1 ); 00283 00284 IntxAreaUtils areaAdaptor; 00285 double intx_area = areaAdaptor.area_on_sphere( &mb, outputSet, radius ); 00286 double arrival_area = areaAdaptor.area_on_sphere( &mb, euler_set, radius ); 00287 std::cout << "On rank : " << rank << " arrival area: " << arrival_area << " intersection area:" << intx_area 00288 << " rel error: " << fabs( ( intx_area - arrival_area ) / arrival_area ) << "\n";CHECK_ERR( rval ); 00289 }
