MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * migrate_test will contain tests for migrating meshes in parallel environments, with iMOAB api 00003 * these methods are tested also in the example MigrateMesh.F90, with variable 00004 * numbers of processes; migrate_test is launched usually on 2 processes, and it tests 00005 * various cases 00006 * a mesh is read on senders tasks, sent to receivers tasks, and then written out for verification 00007 * It depends on hdf5 parallel for reading and writing in parallel 00008 */ 00009 00010 #include "moab/ParallelComm.hpp" 00011 #include "moab/Core.hpp" 00012 #include "moab_mpi.h" 00013 #include "moab/iMOAB.h" 00014 #include "TestUtil.hpp" 00015 00016 #define RUN_TEST_ARG2( A, B ) run_test( &( A ), #A, B ) 00017 00018 using namespace moab; 00019 00020 #define CHECKRC( rc, message ) \ 00021 if( 0 != ( rc ) ) \ 00022 { \ 00023 printf( "Error: %s\n", message ); \ 00024 return MB_FAILURE; \ 00025 } 00026 00027 int is_any_proc_error( int is_my_error ) 00028 { 00029 int result = 0; 00030 int err = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD ); 00031 return err || result; 00032 } 00033 00034 int run_test( ErrorCode ( *func )( const char* ), const char* func_name, const char* file_name ) 00035 { 00036 ErrorCode result = ( *func )( file_name ); 00037 int is_err = is_any_proc_error( ( MB_SUCCESS != result ) ); 00038 int rank; 00039 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00040 if( rank == 0 ) 00041 { 00042 if( is_err ) 00043 std::cout << func_name << " : FAILED!!" << std::endl; 00044 else 00045 std::cout << func_name << " : success" << std::endl; 00046 } 00047 00048 return is_err; 00049 } 00050 00051 ErrorCode migrate_1_1( const char* filename ); 00052 ErrorCode migrate_1_2( const char* filename ); 00053 ErrorCode migrate_2_1( const char* filename ); 00054 ErrorCode migrate_2_2( const char* filename ); 00055 ErrorCode migrate_4_2( const char* filename ); 00056 ErrorCode migrate_2_4( const char* filename ); 00057 ErrorCode migrate_4_3( const char* filename ); 00058 ErrorCode migrate_overlap( const char* filename ); 00059 00060 // some global variables, used by all tests 00061 int rank, size, ierr; 00062 00063 int compid1, compid2; // component ids are unique over all pes, and established in advance; 00064 int nghlay; // number of ghost layers for loading the file 00065 int groupTasks[4]; // at most 4 tasks 00066 int startG1, startG2, endG1, endG2; 00067 00068 MPI_Comm jcomm; // will be a copy of the global 00069 MPI_Group jgroup; 00070 00071 int main( int argc, char* argv[] ) 00072 { 00073 MPI_Init( &argc, &argv ); 00074 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00075 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00076 00077 MPI_Comm_dup( MPI_COMM_WORLD, &jcomm ); 00078 MPI_Comm_group( jcomm, &jgroup ); 00079 00080 std::string filename; 00081 filename = TestDir + "unittest/field1.h5m"; 00082 if( argc > 1 ) 00083 { 00084 filename = argv[1]; 00085 } 00086 int num_errors = 0; 00087 num_errors += RUN_TEST_ARG2( migrate_1_1, filename.c_str() ); 00088 num_errors += RUN_TEST_ARG2( migrate_1_2, filename.c_str() ); 00089 num_errors += RUN_TEST_ARG2( migrate_2_1, filename.c_str() ); 00090 num_errors += RUN_TEST_ARG2( migrate_2_2, filename.c_str() ); 00091 if( size >= 4 ) 00092 { 00093 num_errors += RUN_TEST_ARG2( migrate_4_2, filename.c_str() ); 00094 num_errors += RUN_TEST_ARG2( migrate_2_4, filename.c_str() ); 00095 num_errors += RUN_TEST_ARG2( migrate_4_3, filename.c_str() ); 00096 num_errors += RUN_TEST_ARG2( migrate_overlap, filename.c_str() ); 00097 } 00098 if( rank == 0 ) 00099 { 00100 if( !num_errors ) 00101 std::cout << "All tests passed" << std::endl; 00102 else 00103 std::cout << num_errors << " TESTS FAILED!" << std::endl; 00104 } 00105 00106 MPI_Group_free( &jgroup ); 00107 MPI_Comm_free( &jcomm ); 00108 MPI_Finalize(); 00109 return num_errors; 00110 } 00111 00112 ErrorCode migrate( const char* filename, const char* outfile ) 00113 { 00114 // first create MPI groups 00115 00116 std::string filen( filename ); 00117 MPI_Group group1, group2; 00118 for( int i = startG1; i <= endG1; i++ ) 00119 groupTasks[i - startG1] = i; 00120 00121 ierr = MPI_Group_incl( jgroup, endG1 - startG1 + 1, groupTasks, &group1 ); 00122 CHECKRC( ierr, "can't create group1" ) 00123 00124 for( int i = startG2; i <= endG2; i++ ) 00125 groupTasks[i - startG2] = i; 00126 00127 ierr = MPI_Group_incl( jgroup, endG2 - startG2 + 1, groupTasks, &group2 ); 00128 CHECKRC( ierr, "can't create group2" ) 00129 00130 // create 2 communicators, one for each group 00131 int tagcomm1 = 1, tagcomm2 = 2; 00132 MPI_Comm comm1, comm2; 00133 ierr = MPI_Comm_create_group( jcomm, group1, tagcomm1, &comm1 ); 00134 CHECKRC( ierr, "can't create comm1" ) 00135 00136 ierr = MPI_Comm_create_group( jcomm, group2, tagcomm2, &comm2 ); 00137 CHECKRC( ierr, "can't create comm2" ) 00138 00139 ierr = iMOAB_Initialize( 0, 0 ); // not really needed anything from argc, argv, yet; maybe we should 00140 CHECKRC( ierr, "can't initialize iMOAB" ) 00141 00142 // give some dummy values to component ids, just to differentiate between them 00143 // the par comm graph is unique between components 00144 compid1 = 4; 00145 compid2 = 7; 00146 int context_id = -1; // default context; will be now set to compid1 or compid2 00147 00148 int appID1; 00149 iMOAB_AppID pid1 = &appID1; 00150 int appID2; 00151 iMOAB_AppID pid2 = &appID2; 00152 00153 if( comm1 != MPI_COMM_NULL ) 00154 { 00155 ierr = iMOAB_RegisterApplication( "APP1", &comm1, &compid1, pid1 ); 00156 CHECKRC( ierr, "can't register app1 " ) 00157 } 00158 if( comm2 != MPI_COMM_NULL ) 00159 { 00160 ierr = iMOAB_RegisterApplication( "APP2", &comm2, &compid2, pid2 ); 00161 CHECKRC( ierr, "can't register app2 " ) 00162 } 00163 00164 int method = 0; // trivial partition for sending 00165 if( comm1 != MPI_COMM_NULL ) 00166 { 00167 00168 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00169 00170 nghlay = 0; 00171 00172 ierr = iMOAB_LoadMesh( pid1, filen.c_str(), readopts.c_str(), &nghlay ); 00173 CHECKRC( ierr, "can't load mesh " ) 00174 ierr = iMOAB_SendMesh( pid1, &jcomm, &group2, &compid2, &method ); // send to component 2 00175 CHECKRC( ierr, "cannot send elements" ) 00176 } 00177 00178 if( comm2 != MPI_COMM_NULL ) 00179 { 00180 ierr = iMOAB_ReceiveMesh( pid2, &jcomm, &group1, &compid1 ); // receive from component 1 00181 CHECKRC( ierr, "cannot receive elements" ) 00182 std::string wopts; 00183 wopts = "PARALLEL=WRITE_PART;"; 00184 ierr = iMOAB_WriteMesh( pid2, outfile, wopts.c_str() ); 00185 CHECKRC( ierr, "cannot write received mesh" ) 00186 } 00187 00188 MPI_Barrier( jcomm ); 00189 00190 // we can now free the sender buffers 00191 if( comm1 != MPI_COMM_NULL ) ierr = iMOAB_FreeSenderBuffers( pid1, &context_id ); 00192 00193 // exchange tag, from component to component 00194 // one is receiving, one is sending the tag; the one that is sending needs to have communicator 00195 // not null 00196 int size_tag = 1; // a double dense tag, on elements 00197 int tagType = DENSE_DOUBLE; 00198 int tagIndex2 = 0, tagIndex1 = 0; // these will be tag indices on each app pid 00199 00200 std::string fileAfterTagMigr( outfile ); // has h5m 00201 int sizen = fileAfterTagMigr.length(); 00202 fileAfterTagMigr.erase( sizen - 4, 4 ); // erase extension .h5m 00203 fileAfterTagMigr = fileAfterTagMigr + "_tag.h5m"; 00204 00205 // now send a tag from component 2, towards component 1 00206 if( comm2 != MPI_COMM_NULL ) 00207 { 00208 ierr = iMOAB_DefineTagStorage( pid2, "element_field", &tagType, &size_tag, &tagIndex2 ); 00209 CHECKRC( ierr, "failed to get tag element_field " ); 00210 // this tag is already existing in the file 00211 00212 // first, send from compid2 to compid1, from comm2, using common joint comm 00213 // as always, use nonblocking sends 00214 // contex_id should be now compid1 00215 context_id = compid1; 00216 ierr = iMOAB_SendElementTag( pid2, "element_field", &jcomm, &context_id ); 00217 CHECKRC( ierr, "cannot send tag values" ) 00218 } 00219 // receive on component 1 00220 if( comm1 != MPI_COMM_NULL ) 00221 { 00222 ierr = iMOAB_DefineTagStorage( pid1, "element_field", &tagType, &size_tag, &tagIndex1 ); 00223 CHECKRC( ierr, "failed to get tag DFIELD " ); 00224 context_id = compid2; 00225 ierr = iMOAB_ReceiveElementTag( pid1, "element_field", &jcomm, &context_id ); 00226 CHECKRC( ierr, "cannot send tag values" ) 00227 std::string wopts; 00228 wopts = "PARALLEL=WRITE_PART;"; 00229 ierr = iMOAB_WriteMesh( pid1, fileAfterTagMigr.c_str(), wopts.c_str() ); 00230 CHECKRC( ierr, "cannot write received mesh" ) 00231 } 00232 00233 MPI_Barrier( jcomm ); 00234 00235 // we can now free the sender buffers 00236 if( comm2 != MPI_COMM_NULL ) ierr = iMOAB_FreeSenderBuffers( pid2, &context_id ); 00237 00238 if( comm2 != MPI_COMM_NULL ) 00239 { 00240 ierr = iMOAB_DeregisterApplication( pid2 ); 00241 CHECKRC( ierr, "cannot deregister app 2 receiver" ) 00242 } 00243 00244 if( comm1 != MPI_COMM_NULL ) 00245 { 00246 ierr = iMOAB_DeregisterApplication( pid1 ); 00247 CHECKRC( ierr, "cannot deregister app 1 sender" ) 00248 } 00249 00250 ierr = iMOAB_Finalize(); 00251 CHECKRC( ierr, "did not finalize iMOAB" ) 00252 00253 if( MPI_COMM_NULL != comm1 ) MPI_Comm_free( &comm1 ); 00254 if( MPI_COMM_NULL != comm2 ) MPI_Comm_free( &comm2 ); 00255 00256 MPI_Group_free( &group1 ); 00257 MPI_Group_free( &group2 ); 00258 return MB_SUCCESS; 00259 } 00260 // migrate from task 0 to task 1, non overlapping 00261 ErrorCode migrate_1_1( const char* filename ) 00262 { 00263 startG1 = endG1 = 0; 00264 startG2 = endG2 = 1; 00265 return migrate( filename, "migrate11.h5m" ); 00266 } 00267 // migrate from task 0 to 2 tasks (0 and 1) 00268 ErrorCode migrate_1_2( const char* filename ) 00269 { 00270 startG1 = endG1 = startG2 = 0; 00271 endG2 = 1; 00272 return migrate( filename, "migrate12.h5m" ); 00273 } 00274 00275 // migrate from 2 tasks (0, 1) to 1 task (0) 00276 ErrorCode migrate_2_1( const char* filename ) 00277 { 00278 startG1 = endG2 = startG2 = 0; 00279 endG1 = 1; 00280 return migrate( filename, "migrate21.h5m" ); 00281 } 00282 00283 // migrate from 2 tasks to 2 tasks (overkill) 00284 ErrorCode migrate_2_2( const char* filename ) 00285 { 00286 startG1 = startG2 = 0; 00287 endG1 = endG2 = 1; 00288 return migrate( filename, "migrate22.h5m" ); 00289 } 00290 // migrate from 4 tasks to 2 tasks 00291 ErrorCode migrate_4_2( const char* filename ) 00292 { 00293 startG1 = startG2 = 0; 00294 endG2 = 1; 00295 endG1 = 3; 00296 return migrate( filename, "migrate42.h5m" ); 00297 } 00298 00299 ErrorCode migrate_2_4( const char* filename ) 00300 { 00301 startG1 = startG2 = 0; 00302 endG2 = 3; 00303 endG1 = 1; 00304 return migrate( filename, "migrate24.h5m" ); 00305 } 00306 00307 ErrorCode migrate_4_3( const char* filename ) 00308 { 00309 startG1 = startG2 = 0; 00310 endG2 = 2; 00311 endG1 = 3; 00312 return migrate( filename, "migrate43.h5m" ); 00313 } 00314 00315 ErrorCode migrate_overlap( const char* filename ) 00316 { 00317 startG1 = 0; 00318 startG2 = 1; 00319 endG1 = 1; 00320 endG2 = 2; 00321 return migrate( filename, "migrate_over.h5m" ); 00322 }
