MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef MB_SETITERATOR_HPP 00002 #define MB_SETITERATOR_HPP 00003 00004 #include "moab/Interface.hpp" 00005 00006 namespace moab 00007 { 00008 00009 class Core; 00010 00011 /** \class Meshset iterator 00012 * \brief A class to iterator over MOAB Meshsets 00013 */ 00014 class SetIterator 00015 { 00016 public: 00017 friend class Core; 00018 00019 //! destructor 00020 virtual ~SetIterator(); 00021 00022 //! get the ent set for this iterator 00023 inline EntityHandle ent_set() const 00024 { 00025 return entSet; 00026 }; 00027 00028 //! get the chunk size of this iterator 00029 inline unsigned int chunk_size() const 00030 { 00031 return chunkSize; 00032 }; 00033 00034 //! get the entity type for this iterator 00035 inline EntityType ent_type() const 00036 { 00037 return entType; 00038 }; 00039 00040 //! get the dimension for this iterator 00041 inline int ent_dimension() const 00042 { 00043 return entDimension; 00044 }; 00045 00046 /** \brief get the next chunkSize entities 00047 * Return the next chunkSize entities. 00048 * \param arr Array of entities returned. 00049 * \param atend Returns true if iterator is at the end of iterable values, otherwise false 00050 */ 00051 virtual ErrorCode get_next_arr( std::vector< EntityHandle >& arr, bool& atend ) = 0; 00052 00053 //! reset the iterator to the beginning of the set 00054 virtual ErrorCode reset() = 0; 00055 00056 protected: 00057 /** \brief Constructor 00058 * \param core MOAB Core instance 00059 * \param ent_set EntitySet to which this iterator corresponds 00060 * \param chunk_size Chunk size of this iterator 00061 * \param ent_type Entity type for this iterator 00062 * \param ent_dim Entity dimension for this iterator 00063 */ 00064 inline SetIterator( Core* core, 00065 EntityHandle eset, 00066 unsigned int chunk_sz, 00067 EntityType ent_tp, 00068 int ent_dim, 00069 bool check_valid = false ) 00070 : myCore( core ), entSet( eset ), chunkSize( chunk_sz ), entType( ent_tp ), entDimension( ent_dim ), 00071 checkValid( check_valid ){}; 00072 00073 //! Core instance 00074 Core* myCore; 00075 00076 //! handle for entity set corresponding to this iterator 00077 EntityHandle entSet; 00078 00079 //! chunk size of this iterator 00080 unsigned int chunkSize; 00081 00082 //! entity type this iterator iterates over 00083 EntityType entType; 00084 00085 //! dimension this iterator iterates over 00086 int entDimension; 00087 00088 //! check for entity validity before returning handles 00089 bool checkValid; 00090 }; 00091 00092 /** \class Set-type set iterator 00093 * \brief A class to iterator over MOAB set-type meshsets 00094 */ 00095 class RangeSetIterator : public SetIterator 00096 { 00097 public: 00098 friend class Core; 00099 00100 /** \brief Destructor 00101 */ 00102 virtual ~RangeSetIterator(); 00103 00104 /** \brief get the next chunkSize entities 00105 * Return the next chunkSize entities. 00106 * \param arr Array of entities returned. 00107 * \param atend Returns true if iterator is at the end of iterable values, otherwise false 00108 */ 00109 virtual ErrorCode get_next_arr( std::vector< EntityHandle >& arr, bool& atend ); 00110 00111 //! reset the iterator to the beginning of the set 00112 virtual ErrorCode reset(); 00113 00114 protected: 00115 /** \brief Constructor 00116 * \param core MOAB Core instance 00117 * \param ent_set EntitySet to which this iterator corresponds 00118 * \param chunk_size Chunk size of this iterator 00119 * \param ent_type Entity type for this iterator 00120 * \param ent_dim Entity dimension for this iterator 00121 */ 00122 RangeSetIterator( Core* core, 00123 EntityHandle ent_set, 00124 int chunk_size, 00125 EntityType ent_type, 00126 int ent_dimension, 00127 bool check_valid = false ); 00128 00129 private: 00130 ErrorCode get_next_by_type( const EntityHandle*& ptr, int count, std::vector< EntityHandle >& arr, bool& atend ); 00131 00132 ErrorCode get_next_by_dimension( const EntityHandle*& ptr, 00133 int count, 00134 std::vector< EntityHandle >& arr, 00135 bool& atend ); 00136 00137 //! Build the special pair vector for the root set 00138 ErrorCode build_pair_vec(); 00139 00140 //! Current iterator position, 0 if at beginning 00141 EntityHandle iterPos; 00142 00143 //! Special range pair ptr for root set 00144 EntityHandle* pairPtr; 00145 00146 //! Number of range pairs 00147 int numPairs; 00148 }; 00149 00150 /** \class List-type set iterator 00151 * \brief A class to iterator over MOAB list-type meshsets 00152 */ 00153 class VectorSetIterator : public SetIterator 00154 { 00155 public: 00156 friend class Core; 00157 00158 /** \brief get the next chunkSize entities 00159 * Return the next chunkSize entities. 00160 * \param arr Array of entities returned. 00161 * \param atend Returns true if iterator is at the end of iterable values, otherwise false 00162 */ 00163 virtual ErrorCode get_next_arr( std::vector< EntityHandle >& arr, bool& atend ); 00164 00165 //! reset the iterator to the beginning of the set 00166 virtual ErrorCode reset(); 00167 00168 //! decrement the position by the specified number; returns MB_FAILURE if resulting index is < 0 00169 inline ErrorCode decrement( int num ); 00170 00171 protected: 00172 /** \brief Constructor 00173 * \param core MOAB Core instance 00174 * \param ent_set EntitySet to which this iterator corresponds 00175 * \param chunk_size Chunk size of this iterator 00176 * \param ent_type Entity type for this iterator 00177 * \param ent_dim Entity dimension for this iterator 00178 */ 00179 inline VectorSetIterator( Core* core, 00180 EntityHandle eset, 00181 int chunk_sz, 00182 EntityType ent_tp, 00183 int ent_dim, 00184 bool check_valid = false ) 00185 : SetIterator( core, eset, chunk_sz, ent_tp, ent_dim, check_valid ), iterPos( 0 ) 00186 { 00187 } 00188 00189 private: 00190 //! Current iterator position, 0 if at beginning 00191 int iterPos; 00192 }; 00193 00194 inline ErrorCode VectorSetIterator::decrement( int num ) 00195 { 00196 iterPos -= num; 00197 return ( iterPos < 0 ? MB_FAILURE : MB_SUCCESS ); 00198 } 00199 00200 } // namespace moab 00201 00202 #endif
