MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/AdaptiveKDTree.hpp" 00003 #include "moab/Range.hpp" 00004 #include "moab/CartVect.hpp" 00005 #include "moab/GeomUtil.hpp" 00006 #include <iostream> 00007 #include <ctime> 00008 #include <cstdlib> 00009 #include <cassert> 00010 #include <sstream> 00011 00012 #define CHK( ErrorCode ) \ 00013 do \ 00014 { \ 00015 if( MB_SUCCESS != ( ErrorCode ) ) fail( ( ErrorCode ), __FILE__, __LINE__ ); \ 00016 } while( false ) 00017 00018 using namespace moab; 00019 00020 static void fail( ErrorCode error_code, const char* file_name, int line_number ); 00021 00022 enum TreeType 00023 { 00024 UseKDTree, 00025 UseNoTree, 00026 UseDefaultTree = UseKDTree 00027 }; 00028 00029 const char* default_str = "(default)"; 00030 const char* empty_str = ""; 00031 inline const char* is_default_tree( TreeType type ) 00032 { 00033 return type == UseDefaultTree ? default_str : empty_str; 00034 } 00035 00036 const long DEFAULT_NUM_TEST = 100000; 00037 const long HARD_MAX_UNIQUE_POINTS = 100000; 00038 const long HARD_MIN_UNIQUE_POINTS = 1000; 00039 const long FRACTION_UNIQUE_POINTS = 100; 00040 00041 static void usage( char* argv0, bool help = false ) 00042 { 00043 const char* usage_str = "[-k|-v] [-n <N>] [-d <N>] [-e <N>] <input_mesh>"; 00044 if( !help ) 00045 { 00046 std::cerr << "Usage: " << argv0 << " " << usage_str << std::endl; 00047 std::cerr << " : " << argv0 << " -h" << std::endl; 00048 exit( 1 ); 00049 } 00050 00051 std::cout << "Usage: " << argv0 << " " << usage_str << std::endl 00052 << " -k : Use kD Tree " << is_default_tree( UseKDTree ) << std::endl 00053 << " -v : Use no tree" << is_default_tree( UseNoTree ) << std::endl 00054 << " -n : Specify number of test points (default = " << DEFAULT_NUM_TEST << ")" << std::endl 00055 << " -d : Specify maximum tree depth" << std::endl 00056 << " -e : Specify maximum elements per leaf" << std::endl 00057 << " <input_mesh> : Mesh to build and query." << std::endl 00058 << std::endl; 00059 exit( 0 ); 00060 } 00061 00062 static void generate_random_points( Interface& mesh, 00063 size_t num_points, 00064 std::vector< CartVect >& points, 00065 std::vector< EntityHandle >& point_elems ); 00066 00067 static void do_kdtree_test( Interface& mesh, 00068 int tree_depth, 00069 int elem_per_leaf, 00070 long num_test, 00071 const std::vector< CartVect >& points, 00072 std::vector< EntityHandle >& point_elems, 00073 clock_t& build_time, 00074 clock_t& test_time, 00075 size_t& depth ); 00076 00077 static void do_linear_test( Interface& mesh, 00078 int tree_depth, 00079 int elem_per_leaf, 00080 long num_test, 00081 const std::vector< CartVect >& points, 00082 std::vector< EntityHandle >& point_elems, 00083 clock_t& build_time, 00084 clock_t& test_time, 00085 size_t& depth ); 00086 00087 int main( int argc, char* argv[] ) 00088 { 00089 00090 const char* input_file = 0; 00091 long tree_depth = -1; 00092 long elem_per_leaf = -1; 00093 long num_points = DEFAULT_NUM_TEST; 00094 TreeType type = UseDefaultTree; 00095 char* endptr; 00096 00097 // PARSE ARGUMENTS 00098 00099 long* valptr = 0; 00100 for( int i = 1; i < argc; ++i ) 00101 { 00102 if( valptr ) 00103 { 00104 *valptr = strtol( argv[i], &endptr, 0 ); 00105 if( *valptr < 1 || *endptr ) 00106 { 00107 std::cerr << "Invalid value for '" << argv[i - 1] << "' flag: " << argv[i] << std::endl; 00108 exit( 1 ); 00109 } 00110 valptr = 0; 00111 } 00112 else if( argv[i][0] == '-' && argv[i][1] && !argv[i][2] ) 00113 { 00114 switch( argv[i][1] ) 00115 { 00116 case 'h': 00117 usage( argv[0], true ); 00118 break; 00119 case 'k': 00120 type = UseKDTree; 00121 break; 00122 case 'v': 00123 type = UseNoTree; 00124 break; 00125 case 'd': 00126 valptr = &tree_depth; 00127 break; 00128 case 'e': 00129 valptr = &elem_per_leaf; 00130 break; 00131 case 'n': 00132 valptr = &num_points; 00133 break; 00134 default: 00135 std::cerr << "Invalid flag: " << argv[i] << std::endl; 00136 usage( argv[0] ); 00137 break; 00138 } 00139 } 00140 else if( !input_file ) 00141 { 00142 input_file = argv[i]; 00143 } 00144 else 00145 { 00146 std::cerr << "Unexpected argument: " << argv[i] << std::endl; 00147 usage( argv[0] ); 00148 } 00149 } 00150 if( valptr ) 00151 { 00152 std::cerr << "Expected value following '" << argv[argc - 1] << "' flag" << std::endl; 00153 usage( argv[0] ); 00154 } 00155 if( !input_file ) 00156 { 00157 std::cerr << "No input file specified." << std::endl; 00158 usage( argv[0] ); 00159 } 00160 00161 // LOAD MESH 00162 00163 Core moab; 00164 Interface& mb = moab; 00165 ErrorCode rval; 00166 std::string init_msg, msg; 00167 mb.get_last_error( init_msg ); 00168 rval = mb.load_file( input_file ); 00169 if( MB_SUCCESS != rval ) 00170 { 00171 std::cerr << input_file << " : failed to read file." << std::endl; 00172 mb.get_last_error( msg ); 00173 if( msg != init_msg ) std::cerr << "message : " << msg << std::endl; 00174 } 00175 00176 // GENERATE TEST POINTS 00177 00178 int num_unique = num_points / FRACTION_UNIQUE_POINTS; 00179 if( num_unique > HARD_MAX_UNIQUE_POINTS ) 00180 num_unique = HARD_MAX_UNIQUE_POINTS; 00181 else if( num_unique < HARD_MIN_UNIQUE_POINTS ) 00182 num_unique = num_points; 00183 std::vector< CartVect > points; 00184 std::vector< EntityHandle > elems; 00185 generate_random_points( mb, num_unique, points, elems ); 00186 00187 // GET MEMORY USE BEFORE BUILDING TREE 00188 00189 unsigned long long init_total_storage; 00190 mb.estimated_memory_use( 0, 0, &init_total_storage ); 00191 00192 // RUN TIMING TEST 00193 clock_t build_time, test_time; 00194 size_t actual_depth = 0; 00195 std::vector< EntityHandle > results( points.size() ); 00196 switch( type ) 00197 { 00198 default: 00199 case UseKDTree: 00200 do_kdtree_test( mb, tree_depth, elem_per_leaf, num_points, points, results, build_time, test_time, 00201 actual_depth ); 00202 break; 00203 case UseNoTree: 00204 do_linear_test( mb, tree_depth, elem_per_leaf, num_points, points, results, build_time, test_time, 00205 actual_depth ); 00206 break; 00207 } 00208 00209 unsigned long long fini_total_storage; 00210 mb.estimated_memory_use( 0, 0, &fini_total_storage ); 00211 00212 // VALIDATE RESULTS 00213 int fail = 0; 00214 if( results != elems ) 00215 { 00216 std::cout << "WARNING: Test produced invalid results" << std::endl; 00217 fail = 1; 00218 } 00219 00220 // SUMMARIZE RESULTS 00221 std::cout << "Number of test queries: " << num_points << std::endl; 00222 std::cout << "Tree build time: " << ( (double)build_time ) / CLOCKS_PER_SEC << " seconds" << std::endl; 00223 std::cout << "Total query time: " << ( (double)test_time ) / CLOCKS_PER_SEC << " seconds" << std::endl; 00224 std::cout << "Time per query: " << ( (double)test_time ) / CLOCKS_PER_SEC / num_points << " seconds" << std::endl; 00225 std::cout << "Tree depth: " << actual_depth << std::endl; 00226 if( actual_depth ) 00227 std::cout << "Total query time/depth: " << ( (double)test_time ) / CLOCKS_PER_SEC / actual_depth << " seconds" 00228 << std::endl; 00229 std::cout << std::endl; 00230 std::cout << "Bytes before tree construction: " << init_total_storage << std::endl; 00231 std::cout << "Bytes after tree construction: " << fini_total_storage << std::endl; 00232 std::cout << "Difference: " << fini_total_storage - init_total_storage << " bytes" << std::endl; 00233 return fail; 00234 } 00235 00236 void fail( ErrorCode error_code, const char* file, int line ) 00237 { 00238 std::cerr << "Internal error (error code " << error_code << ") at " << file << ":" << line << std::endl; 00239 abort(); 00240 } 00241 00242 const int HexSign[8][3] = { { -1, -1, -1 }, { 1, -1, -1 }, { 1, 1, -1 }, { -1, 1, -1 }, 00243 { -1, -1, 1 }, { 1, -1, 1 }, { 1, 1, 1 }, { -1, 1, 1 } }; 00244 00245 static CartVect random_point_in_hex( Interface& mb, EntityHandle hex ) 00246 { 00247 const double f = RAND_MAX / 2; 00248 CartVect xi( ( (double)rand() - f ) / f, ( (double)rand() - f ) / f, ( (double)rand() - f ) / f ); 00249 CartVect coords[8]; 00250 const EntityHandle* conn; 00251 int len; 00252 ErrorCode rval = mb.get_connectivity( hex, conn, len, true ); 00253 if( len != 8 && MB_SUCCESS != rval ) 00254 { 00255 std::cerr << "Invalid element" << std::endl; 00256 assert( false ); 00257 abort(); 00258 } 00259 rval = mb.get_coords( conn, 8, reinterpret_cast< double* >( coords ) ); 00260 CHK( rval ); 00261 00262 CartVect point( 0, 0, 0 ); 00263 for( unsigned i = 0; i < 8; ++i ) 00264 { 00265 double coeff = 0.125; 00266 for( unsigned j = 0; j < 3; ++j ) 00267 coeff *= 1 + HexSign[i][j] * xi[j]; 00268 point += coeff * coords[i]; 00269 } 00270 00271 return point; 00272 } 00273 00274 void generate_random_points( Interface& mb, 00275 size_t num_points, 00276 std::vector< CartVect >& points, 00277 std::vector< EntityHandle >& point_elems ) 00278 { 00279 Range elems; 00280 ErrorCode rval; 00281 rval = mb.get_entities_by_dimension( 0, 3, elems ); 00282 CHK( rval ); 00283 if( !elems.all_of_type( MBHEX ) ) 00284 { 00285 std::cerr << "Warning: ignoring non-hexahedral elements." << std::endl; 00286 std::pair< Range::iterator, Range::iterator > p = elems.equal_range( MBHEX ); 00287 elems.erase( p.second, elems.end() ); 00288 elems.erase( elems.begin(), p.first ); 00289 } 00290 if( elems.empty() ) 00291 { 00292 std::cerr << "Input file contains no hexahedral elements." << std::endl; 00293 exit( 1 ); 00294 } 00295 00296 points.resize( num_points ); 00297 point_elems.resize( num_points ); 00298 const size_t num_elem = elems.size(); 00299 for( size_t i = 0; i < num_points; ++i ) 00300 { 00301 size_t offset = 0; 00302 for( size_t x = num_elem; x > 0; x /= RAND_MAX ) 00303 offset += rand(); 00304 offset %= num_elem; 00305 point_elems[i] = elems[offset]; 00306 points[i] = random_point_in_hex( mb, point_elems[i] ); 00307 } 00308 } 00309 00310 void do_kdtree_test( Interface& mb, 00311 int tree_depth, 00312 int elem_per_leaf, 00313 long num_test, 00314 const std::vector< CartVect >& points, 00315 std::vector< EntityHandle >& point_elems, 00316 clock_t& build_time, 00317 clock_t& test_time, 00318 size_t& depth ) 00319 { 00320 ErrorCode rval; 00321 clock_t init = clock(); 00322 AdaptiveKDTree tool( &mb ); 00323 EntityHandle root; 00324 std::ostringstream options; 00325 if( tree_depth > 0 ) options << "MAX_DEPTH=" << tree_depth << ";"; 00326 if( elem_per_leaf > 0 ) options << "MAX_PER_LEAF=" << elem_per_leaf << ";"; 00327 Range all_hexes; 00328 rval = mb.get_entities_by_type( 0, MBHEX, all_hexes ); 00329 CHK( rval ); 00330 FileOptions opt( options.str().c_str() ); 00331 rval = tool.build_tree( all_hexes, &root, &opt ); 00332 CHK( rval ); 00333 all_hexes.clear(); 00334 build_time = clock() - init; 00335 00336 EntityHandle leaf; 00337 std::vector< EntityHandle > hexes; 00338 std::vector< EntityHandle >::iterator j; 00339 CartVect coords[8]; 00340 const EntityHandle* conn; 00341 int len; 00342 for( long i = 0; i < num_test; ++i ) 00343 { 00344 const size_t idx = (size_t)i % points.size(); 00345 rval = tool.point_search( points[idx].array(), leaf, 1.0e-10, 1.0e-6, NULL, &root ); 00346 CHK( rval ); 00347 hexes.clear(); 00348 rval = mb.get_entities_by_handle( leaf, hexes ); 00349 CHK( rval ); 00350 for( j = hexes.begin(); j != hexes.end(); ++j ) 00351 { 00352 rval = mb.get_connectivity( *j, conn, len, true ); 00353 CHK( rval ); 00354 rval = mb.get_coords( conn, 8, reinterpret_cast< double* >( coords ) ); 00355 CHK( rval ); 00356 if( GeomUtil::point_in_trilinear_hex( coords, points[idx], 1e-12 ) ) 00357 { 00358 point_elems[idx] = *j; 00359 break; 00360 } 00361 } 00362 if( j == hexes.end() ) point_elems[idx] = 0; 00363 } 00364 00365 test_time = clock() - build_time; 00366 double tmp_box[3]; 00367 unsigned max_d; 00368 tool.get_info( root, tmp_box, tmp_box, max_d ); 00369 depth = max_d; 00370 } 00371 00372 void do_linear_test( Interface& mb, 00373 int, 00374 int, 00375 long num_test, 00376 const std::vector< CartVect >& points, 00377 std::vector< EntityHandle >& point_elems, 00378 clock_t& build_time, 00379 clock_t& test_time, 00380 size_t& depth ) 00381 { 00382 clock_t init = clock(); 00383 Range hexes; 00384 ErrorCode rval = mb.get_entities_by_type( 0, MBHEX, hexes ); 00385 CHK( rval ); 00386 depth = 0; 00387 point_elems.resize( points.size() ); 00388 build_time = clock() - init; 00389 00390 CartVect coords[8]; 00391 const EntityHandle* conn; 00392 int len; 00393 for( long i = 0; i < num_test; ++i ) 00394 { 00395 const size_t idx = (size_t)i % points.size(); 00396 for( Range::iterator h = hexes.begin(); h != hexes.end(); ++h ) 00397 { 00398 rval = mb.get_connectivity( *h, conn, len, true ); 00399 CHK( rval ); 00400 rval = mb.get_coords( conn, 8, reinterpret_cast< double* >( coords ) ); 00401 CHK( rval ); 00402 if( GeomUtil::point_in_trilinear_hex( coords, points[idx], 1e-12 ) ) 00403 { 00404 point_elems[idx] = *h; 00405 break; 00406 } 00407 } 00408 } 00409 00410 test_time = clock() - build_time; 00411 }
