MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * ===================================================================================== 00003 * 00004 * Filename: TempestOnlineMapIO.cpp 00005 * 00006 * Description: All I/O implementations related to TempestOnlineMap 00007 * 00008 * Version: 1.0 00009 * Created: 02/06/2021 02:35:41 00010 * 00011 * Author: Vijay S. Mahadevan (vijaysm), [email protected] 00012 * Company: Argonne National Lab 00013 * 00014 * ===================================================================================== 00015 */ 00016 00017 #include "FiniteElementTools.h" 00018 #include "moab/Remapping/TempestOnlineMap.hpp" 00019 #include "moab/TupleList.hpp" 00020 00021 #ifdef MOAB_HAVE_NETCDFPAR 00022 #include "netcdfcpp_par.hpp" 00023 #else 00024 #include "netcdfcpp.h" 00025 #endif 00026 00027 #ifdef MOAB_HAVE_PNETCDF 00028 #include <pnetcdf.h> 00029 00030 #define ERR_PARNC( err ) \ 00031 if( err != NC_NOERR ) \ 00032 { \ 00033 fprintf( stderr, "Error at line %d: %s\n", __LINE__, ncmpi_strerror( err ) ); \ 00034 MPI_Abort( MPI_COMM_WORLD, 1 ); \ 00035 } 00036 00037 #endif 00038 00039 #ifdef MOAB_HAVE_MPI 00040 00041 #define MPI_CHK_ERR( err ) \ 00042 if( err ) \ 00043 { \ 00044 std::cout << "MPI Failure. ErrorCode (" << ( err ) << ") "; \ 00045 std::cout << "\nMPI Aborting... \n"; \ 00046 return moab::MB_FAILURE; \ 00047 } 00048 00049 int moab::TempestOnlineMap::rearrange_arrays_by_dofs( const std::vector< unsigned int >& gdofmap, 00050 DataArray1D< double >& vecFaceArea, 00051 DataArray1D< double >& dCenterLon, 00052 DataArray1D< double >& dCenterLat, 00053 DataArray2D< double >& dVertexLon, 00054 DataArray2D< double >& dVertexLat, 00055 std::vector< int >& masks, 00056 unsigned& N, // will have the local, after 00057 int nv, 00058 int& maxdof ) 00059 { 00060 // first decide maxdof, for partitioning 00061 unsigned int localmax = 0; 00062 for( unsigned i = 0; i < N; i++ ) 00063 if( gdofmap[i] > localmax ) localmax = gdofmap[i]; 00064 00065 // decide partitioning based on maxdof/size 00066 MPI_Allreduce( &localmax, &maxdof, 1, MPI_INT, MPI_MAX, m_pcomm->comm() ); 00067 // maxdof is 0 based, so actual number is +1 00068 // maxdof 00069 int size_per_task = ( maxdof + 1 ) / size; // based on this, processor to process dof x is x/size_per_task 00070 // so we decide to reorder by actual dof, such that task 0 has dofs from [0 to size_per_task), etc 00071 moab::TupleList tl; 00072 unsigned numr = 2 * nv + 3; // doubles: area, centerlon, center lat, nv (vertex lon, vertex lat) 00073 tl.initialize( 3, 0, 0, numr, N ); // to proc, dof, then 00074 tl.enableWriteAccess(); 00075 // populate 00076 for( unsigned i = 0; i < N; i++ ) 00077 { 00078 int gdof = gdofmap[i]; 00079 int to_proc = gdof / size_per_task; 00080 int mask = masks[i]; 00081 if( to_proc >= size ) to_proc = size - 1; // the last ones go to last proc 00082 int n = tl.get_n(); 00083 tl.vi_wr[3 * n] = to_proc; 00084 tl.vi_wr[3 * n + 1] = gdof; 00085 tl.vi_wr[3 * n + 2] = mask; 00086 tl.vr_wr[n * numr] = vecFaceArea[i]; 00087 tl.vr_wr[n * numr + 1] = dCenterLon[i]; 00088 tl.vr_wr[n * numr + 2] = dCenterLat[i]; 00089 for( int j = 0; j < nv; j++ ) 00090 { 00091 tl.vr_wr[n * numr + 3 + j] = dVertexLon[i][j]; 00092 tl.vr_wr[n * numr + 3 + nv + j] = dVertexLat[i][j]; 00093 } 00094 tl.inc_n(); 00095 } 00096 00097 // now do the heavy communication 00098 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tl, 0 ); 00099 00100 // after communication, on each processor we should have tuples coming in 00101 // still need to order by global dofs; then rearrange input vectors 00102 moab::TupleList::buffer sort_buffer; 00103 sort_buffer.buffer_init( tl.get_n() ); 00104 tl.sort( 1, &sort_buffer ); 00105 // count how many are unique, and collapse 00106 int nb_unique = 1; 00107 for( unsigned i = 0; i < tl.get_n() - 1; i++ ) 00108 { 00109 if( tl.vi_wr[3 * i + 1] != tl.vi_wr[3 * i + 4] ) nb_unique++; 00110 } 00111 vecFaceArea.Allocate( nb_unique ); 00112 dCenterLon.Allocate( nb_unique ); 00113 dCenterLat.Allocate( nb_unique ); 00114 dVertexLon.Allocate( nb_unique, nv ); 00115 dVertexLat.Allocate( nb_unique, nv ); 00116 masks.resize( nb_unique ); 00117 int current_size = 1; 00118 vecFaceArea[0] = tl.vr_wr[0]; 00119 dCenterLon[0] = tl.vr_wr[1]; 00120 dCenterLat[0] = tl.vr_wr[2]; 00121 masks[0] = tl.vi_wr[2]; 00122 for( int j = 0; j < nv; j++ ) 00123 { 00124 dVertexLon[0][j] = tl.vr_wr[3 + j]; 00125 dVertexLat[0][j] = tl.vr_wr[3 + nv + j]; 00126 } 00127 for( unsigned i = 0; i < tl.get_n() - 1; i++ ) 00128 { 00129 int i1 = i + 1; 00130 if( tl.vi_wr[3 * i + 1] != tl.vi_wr[3 * i + 4] ) 00131 { 00132 vecFaceArea[current_size] = tl.vr_wr[i1 * numr]; 00133 dCenterLon[current_size] = tl.vr_wr[i1 * numr + 1]; 00134 dCenterLat[current_size] = tl.vr_wr[i1 * numr + 2]; 00135 for( int j = 0; j < nv; j++ ) 00136 { 00137 dVertexLon[current_size][j] = tl.vr_wr[i1 * numr + 3 + j]; 00138 dVertexLat[current_size][j] = tl.vr_wr[i1 * numr + 3 + nv + j]; 00139 } 00140 masks[current_size] = tl.vi_wr[3 * i1 + 2]; 00141 current_size++; 00142 } 00143 else 00144 { 00145 vecFaceArea[current_size - 1] += tl.vr_wr[i1 * numr]; // accumulate areas; will come here only for cgll ? 00146 } 00147 } 00148 00149 N = current_size; // or nb_unique, should be the same 00150 return 0; 00151 } 00152 #endif 00153 00154 /////////////////////////////////////////////////////////////////////////////// 00155 00156 moab::ErrorCode moab::TempestOnlineMap::WriteParallelMap( const std::string& strFilename ) 00157 { 00158 moab::ErrorCode rval; 00159 00160 size_t lastindex = strFilename.find_last_of( "." ); 00161 std::string extension = strFilename.substr( lastindex + 1, strFilename.size() ); 00162 00163 // Write the map file to disk in parallel 00164 if( extension == "nc" ) 00165 { 00166 /* Invoke the actual call to write the parallel map to disk in SCRIP format */ 00167 rval = this->WriteSCRIPMapFile( strFilename.c_str() );MB_CHK_ERR( rval ); 00168 } 00169 else 00170 { 00171 /* Write to the parallel H5M format */ 00172 rval = this->WriteHDF5MapFile( strFilename.c_str() );MB_CHK_ERR( rval ); 00173 } 00174 00175 return rval; 00176 } 00177 00178 /////////////////////////////////////////////////////////////////////////////// 00179 00180 moab::ErrorCode moab::TempestOnlineMap::WriteSCRIPMapFile( const std::string& strFilename ) 00181 { 00182 NcError error( NcError::silent_nonfatal ); 00183 00184 #ifdef MOAB_HAVE_NETCDFPAR 00185 bool is_independent = true; 00186 ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strFilename.c_str(), NcFile::Replace, NcFile::Netcdf4 ); 00187 // ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strFilename.c_str(), NcmpiFile::replace, NcmpiFile::classic5 ); 00188 #else 00189 NcFile ncMap( strFilename.c_str(), NcFile::Replace ); 00190 #endif 00191 00192 if( !ncMap.is_valid() ) 00193 { 00194 _EXCEPTION1( "Unable to open output map file \"%s\"", strFilename.c_str() ); 00195 } 00196 00197 // Attributes 00198 ncMap.add_att( "Title", "MOAB-TempestRemap Online Regridding Weight Generator" ); 00199 00200 /** 00201 * Need to get the global maximum of number of vertices per element 00202 * Key issue is that when calling InitializeCoordinatesFromMeshFV, the allocation for 00203 *dVertexLon/dVertexLat are made based on the maximum vertices in the current process. However, 00204 *when writing this out, other processes may have a different size for the same array. This is 00205 *hence a mess to consolidate in h5mtoscrip eventually. 00206 **/ 00207 00208 /* Let us compute all relevant data for the current original source mesh on the process */ 00209 DataArray1D< double > vecSourceFaceArea, vecTargetFaceArea; 00210 DataArray1D< double > dSourceCenterLon, dSourceCenterLat, dTargetCenterLon, dTargetCenterLat; 00211 DataArray2D< double > dSourceVertexLon, dSourceVertexLat, dTargetVertexLon, dTargetVertexLat; 00212 if( m_srcDiscType == DiscretizationType_FV || m_srcDiscType == DiscretizationType_PCLOUD ) 00213 { 00214 this->InitializeCoordinatesFromMeshFV( 00215 *m_meshInput, dSourceCenterLon, dSourceCenterLat, dSourceVertexLon, dSourceVertexLat, 00216 ( this->m_remapper->m_source_type == moab::TempestRemapper::RLL ), /* fLatLon = false */ 00217 m_remapper->max_source_edges ); 00218 00219 vecSourceFaceArea.Allocate( m_meshInput->vecFaceArea.GetRows() ); 00220 for( unsigned i = 0; i < m_meshInput->vecFaceArea.GetRows(); ++i ) 00221 vecSourceFaceArea[i] = m_meshInput->vecFaceArea[i]; 00222 } 00223 else 00224 { 00225 DataArray3D< double > dataGLLJacobianSrc; 00226 this->InitializeCoordinatesFromMeshFE( *m_meshInput, m_nDofsPEl_Src, dataGLLNodesSrc, dSourceCenterLon, 00227 dSourceCenterLat, dSourceVertexLon, dSourceVertexLat ); 00228 00229 // Generate the continuous Jacobian for input mesh 00230 GenerateMetaData( *m_meshInput, m_nDofsPEl_Src, false /* fBubble */, dataGLLNodesSrc, dataGLLJacobianSrc ); 00231 00232 if( m_srcDiscType == DiscretizationType_CGLL ) 00233 { 00234 GenerateUniqueJacobian( dataGLLNodesSrc, dataGLLJacobianSrc, vecSourceFaceArea ); 00235 } 00236 else 00237 { 00238 GenerateDiscontinuousJacobian( dataGLLJacobianSrc, vecSourceFaceArea ); 00239 } 00240 } 00241 00242 if( m_destDiscType == DiscretizationType_FV || m_destDiscType == DiscretizationType_PCLOUD ) 00243 { 00244 this->InitializeCoordinatesFromMeshFV( 00245 *m_meshOutput, dTargetCenterLon, dTargetCenterLat, dTargetVertexLon, dTargetVertexLat, 00246 ( this->m_remapper->m_target_type == moab::TempestRemapper::RLL ), /* fLatLon = false */ 00247 m_remapper->max_target_edges ); 00248 00249 vecTargetFaceArea.Allocate( m_meshOutput->vecFaceArea.GetRows() ); 00250 for( unsigned i = 0; i < m_meshOutput->vecFaceArea.GetRows(); ++i ) 00251 { 00252 vecTargetFaceArea[i] = m_meshOutput->vecFaceArea[i]; 00253 } 00254 } 00255 else 00256 { 00257 DataArray3D< double > dataGLLJacobianDest; 00258 this->InitializeCoordinatesFromMeshFE( *m_meshOutput, m_nDofsPEl_Dest, dataGLLNodesDest, dTargetCenterLon, 00259 dTargetCenterLat, dTargetVertexLon, dTargetVertexLat ); 00260 00261 // Generate the continuous Jacobian for input mesh 00262 GenerateMetaData( *m_meshOutput, m_nDofsPEl_Dest, false /* fBubble */, dataGLLNodesDest, dataGLLJacobianDest ); 00263 00264 if( m_destDiscType == DiscretizationType_CGLL ) 00265 { 00266 GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianDest, vecTargetFaceArea ); 00267 } 00268 else 00269 { 00270 GenerateDiscontinuousJacobian( dataGLLJacobianDest, vecTargetFaceArea ); 00271 } 00272 } 00273 00274 // Map dimensions 00275 unsigned nA = ( vecSourceFaceArea.GetRows() ); 00276 unsigned nB = ( vecTargetFaceArea.GetRows() ); 00277 00278 std::vector< int > masksA, masksB; 00279 ErrorCode rval = m_remapper->GetIMasks( moab::Remapper::SourceMesh, masksA );MB_CHK_SET_ERR( rval, "Trouble getting masks for source" ); 00280 rval = m_remapper->GetIMasks( moab::Remapper::TargetMesh, masksB );MB_CHK_SET_ERR( rval, "Trouble getting masks for target" ); 00281 00282 // Number of nodes per Face 00283 int nSourceNodesPerFace = dSourceVertexLon.GetColumns(); 00284 int nTargetNodesPerFace = dTargetVertexLon.GetColumns(); 00285 // if source or target cells have triangles at poles, center of those triangles need to come from 00286 // the original quad, not from center in 3d, converted to 2d again 00287 // start copy OnlineMap.cpp tempestremap 00288 // right now, do this only for source mesh; copy the logic for target mesh 00289 00290 for( unsigned i = 0; i < nA; i++ ) 00291 { 00292 const Face& face = m_meshInput->faces[i]; 00293 00294 int nNodes = face.edges.size(); 00295 int indexNodeAtPole = -1; 00296 if( 3 == nNodes ) // check if one node at the poles 00297 { 00298 for( int j = 0; j < nNodes; j++ ) 00299 if( fabs( fabs( dSourceVertexLat[i][j] ) - 90.0 ) < 1.0e-12 ) 00300 { 00301 indexNodeAtPole = j; 00302 break; 00303 } 00304 } 00305 if( indexNodeAtPole < 0 ) continue; // continue i loop, do nothing 00306 // recompute center of cell, from 3d data; add one 2 nodes at pole, and average 00307 int nodeAtPole = face[indexNodeAtPole]; // use the overloaded operator 00308 Node nodePole = m_meshInput->nodes[nodeAtPole]; 00309 Node newCenter = nodePole * 2; 00310 for( int j = 1; j < nNodes; j++ ) 00311 { 00312 int indexi = ( indexNodeAtPole + j ) % nNodes; // nNodes is 3 ! 00313 const Node& node = m_meshInput->nodes[face[indexi]]; 00314 newCenter = newCenter + node; 00315 } 00316 newCenter = newCenter * 0.25; 00317 newCenter = newCenter.Normalized(); 00318 00319 #ifdef VERBOSE 00320 double iniLon = dSourceCenterLon[i], iniLat = dSourceCenterLat[i]; 00321 #endif 00322 // dSourceCenterLon, dSourceCenterLat 00323 XYZtoRLL_Deg( newCenter.x, newCenter.y, newCenter.z, dSourceCenterLon[i], dSourceCenterLat[i] ); 00324 #ifdef VERBOSE 00325 std::cout << " modify center of triangle from " << iniLon << " " << iniLat << " to " << dSourceCenterLon[i] 00326 << " " << dSourceCenterLat[i] << "\n"; 00327 #endif 00328 } 00329 00330 // first move data if in parallel 00331 #if defined( MOAB_HAVE_MPI ) 00332 int max_row_dof, max_col_dof; // output; arrays will be re-distributed in chunks [maxdof/size] 00333 // if (size > 1) 00334 { 00335 00336 int ierr = rearrange_arrays_by_dofs( srccol_gdofmap, vecSourceFaceArea, dSourceCenterLon, dSourceCenterLat, 00337 dSourceVertexLon, dSourceVertexLat, masksA, nA, nSourceNodesPerFace, 00338 max_col_dof ); // now nA will be close to maxdof/size 00339 if( ierr != 0 ) 00340 { 00341 _EXCEPTION1( "Unable to arrange source data %d ", nA ); 00342 } 00343 // rearrange target data: (nB) 00344 // 00345 ierr = rearrange_arrays_by_dofs( row_gdofmap, vecTargetFaceArea, dTargetCenterLon, dTargetCenterLat, 00346 dTargetVertexLon, dTargetVertexLat, masksB, nB, nTargetNodesPerFace, 00347 max_row_dof ); // now nA will be close to maxdof/size 00348 if( ierr != 0 ) 00349 { 00350 _EXCEPTION1( "Unable to arrange target data %d ", nB ); 00351 } 00352 } 00353 #endif 00354 00355 // Number of non-zeros in the remap matrix operator 00356 int nS = m_weightMatrix.nonZeros(); 00357 00358 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_NETCDFPAR ) 00359 int locbuf[5] = { (int)nA, (int)nB, nS, nSourceNodesPerFace, nTargetNodesPerFace }; 00360 int offbuf[3] = { 0, 0, 0 }; 00361 int globuf[5] = { 0, 0, 0, 0, 0 }; 00362 MPI_Scan( locbuf, offbuf, 3, MPI_INT, MPI_SUM, m_pcomm->comm() ); 00363 MPI_Allreduce( locbuf, globuf, 3, MPI_INT, MPI_SUM, m_pcomm->comm() ); 00364 MPI_Allreduce( &locbuf[3], &globuf[3], 2, MPI_INT, MPI_MAX, m_pcomm->comm() ); 00365 00366 // MPI_Scan is inclusive of data in current rank; modify accordingly. 00367 offbuf[0] -= nA; 00368 offbuf[1] -= nB; 00369 offbuf[2] -= nS; 00370 00371 #else 00372 int offbuf[3] = { 0, 0, 0 }; 00373 int globuf[5] = { (int)nA, (int)nB, nS, nSourceNodesPerFace, nTargetNodesPerFace }; 00374 #endif 00375 00376 // Write output dimensions entries 00377 unsigned nSrcGridDims = ( m_vecSourceDimSizes.size() ); 00378 unsigned nDstGridDims = ( m_vecTargetDimSizes.size() ); 00379 00380 NcDim* dimSrcGridRank = ncMap.add_dim( "src_grid_rank", nSrcGridDims ); 00381 NcDim* dimDstGridRank = ncMap.add_dim( "dst_grid_rank", nDstGridDims ); 00382 00383 NcVar* varSrcGridDims = ncMap.add_var( "src_grid_dims", ncInt, dimSrcGridRank ); 00384 NcVar* varDstGridDims = ncMap.add_var( "dst_grid_dims", ncInt, dimDstGridRank ); 00385 00386 #ifdef MOAB_HAVE_NETCDFPAR 00387 ncMap.enable_var_par_access( varSrcGridDims, is_independent ); 00388 ncMap.enable_var_par_access( varDstGridDims, is_independent ); 00389 #endif 00390 00391 char szDim[64]; 00392 if( ( nSrcGridDims == 1 ) && ( m_vecSourceDimSizes[0] != (int)nA ) ) 00393 { 00394 varSrcGridDims->put( &globuf[0], 1 ); 00395 varSrcGridDims->add_att( "name0", "num_dof" ); 00396 } 00397 else 00398 { 00399 for( unsigned i = 0; i < m_vecSourceDimSizes.size(); i++ ) 00400 { 00401 int tmp = ( i == 0 ? globuf[0] : m_vecSourceDimSizes[i] ); 00402 varSrcGridDims->set_cur( nSrcGridDims - i - 1 ); 00403 varSrcGridDims->put( &( tmp ), 1 ); 00404 } 00405 00406 for( unsigned i = 0; i < m_vecSourceDimSizes.size(); i++ ) 00407 { 00408 sprintf( szDim, "name%i", i ); 00409 varSrcGridDims->add_att( szDim, m_vecSourceDimNames[nSrcGridDims - i - 1].c_str() ); 00410 } 00411 } 00412 00413 if( ( nDstGridDims == 1 ) && ( m_vecTargetDimSizes[0] != (int)nB ) ) 00414 { 00415 varDstGridDims->put( &globuf[1], 1 ); 00416 varDstGridDims->add_att( "name0", "num_dof" ); 00417 } 00418 else 00419 { 00420 for( unsigned i = 0; i < m_vecTargetDimSizes.size(); i++ ) 00421 { 00422 int tmp = ( i == 0 ? globuf[1] : m_vecTargetDimSizes[i] ); 00423 varDstGridDims->set_cur( nDstGridDims - i - 1 ); 00424 varDstGridDims->put( &( tmp ), 1 ); 00425 } 00426 00427 for( unsigned i = 0; i < m_vecTargetDimSizes.size(); i++ ) 00428 { 00429 sprintf( szDim, "name%i", i ); 00430 varDstGridDims->add_att( szDim, m_vecTargetDimNames[nDstGridDims - i - 1].c_str() ); 00431 } 00432 } 00433 00434 // Source and Target mesh resolutions 00435 NcDim* dimNA = ncMap.add_dim( "n_a", globuf[0] ); 00436 NcDim* dimNB = ncMap.add_dim( "n_b", globuf[1] ); 00437 00438 // Number of nodes per Face 00439 NcDim* dimNVA = ncMap.add_dim( "nv_a", globuf[3] ); 00440 NcDim* dimNVB = ncMap.add_dim( "nv_b", globuf[4] ); 00441 00442 // Write coordinates 00443 NcVar* varYCA = ncMap.add_var( "yc_a", ncDouble, dimNA ); 00444 NcVar* varYCB = ncMap.add_var( "yc_b", ncDouble, dimNB ); 00445 00446 NcVar* varXCA = ncMap.add_var( "xc_a", ncDouble, dimNA ); 00447 NcVar* varXCB = ncMap.add_var( "xc_b", ncDouble, dimNB ); 00448 00449 NcVar* varYVA = ncMap.add_var( "yv_a", ncDouble, dimNA, dimNVA ); 00450 NcVar* varYVB = ncMap.add_var( "yv_b", ncDouble, dimNB, dimNVB ); 00451 00452 NcVar* varXVA = ncMap.add_var( "xv_a", ncDouble, dimNA, dimNVA ); 00453 NcVar* varXVB = ncMap.add_var( "xv_b", ncDouble, dimNB, dimNVB ); 00454 00455 // Write masks 00456 NcVar* varMaskA = ncMap.add_var( "mask_a", ncInt, dimNA ); 00457 NcVar* varMaskB = ncMap.add_var( "mask_b", ncInt, dimNB ); 00458 00459 #ifdef MOAB_HAVE_NETCDFPAR 00460 ncMap.enable_var_par_access( varYCA, is_independent ); 00461 ncMap.enable_var_par_access( varYCB, is_independent ); 00462 ncMap.enable_var_par_access( varXCA, is_independent ); 00463 ncMap.enable_var_par_access( varXCB, is_independent ); 00464 ncMap.enable_var_par_access( varYVA, is_independent ); 00465 ncMap.enable_var_par_access( varYVB, is_independent ); 00466 ncMap.enable_var_par_access( varXVA, is_independent ); 00467 ncMap.enable_var_par_access( varXVB, is_independent ); 00468 ncMap.enable_var_par_access( varMaskA, is_independent ); 00469 ncMap.enable_var_par_access( varMaskB, is_independent ); 00470 #endif 00471 00472 varYCA->add_att( "units", "degrees" ); 00473 varYCB->add_att( "units", "degrees" ); 00474 00475 varXCA->add_att( "units", "degrees" ); 00476 varXCB->add_att( "units", "degrees" ); 00477 00478 varYVA->add_att( "units", "degrees" ); 00479 varYVB->add_att( "units", "degrees" ); 00480 00481 varXVA->add_att( "units", "degrees" ); 00482 varXVB->add_att( "units", "degrees" ); 00483 00484 // Verify dimensionality 00485 if( dSourceCenterLon.GetRows() != nA ) 00486 { 00487 _EXCEPTIONT( "Mismatch between dSourceCenterLon and nA" ); 00488 } 00489 if( dSourceCenterLat.GetRows() != nA ) 00490 { 00491 _EXCEPTIONT( "Mismatch between dSourceCenterLat and nA" ); 00492 } 00493 if( dTargetCenterLon.GetRows() != nB ) 00494 { 00495 _EXCEPTIONT( "Mismatch between dTargetCenterLon and nB" ); 00496 } 00497 if( dTargetCenterLat.GetRows() != nB ) 00498 { 00499 _EXCEPTIONT( "Mismatch between dTargetCenterLat and nB" ); 00500 } 00501 if( dSourceVertexLon.GetRows() != nA ) 00502 { 00503 _EXCEPTIONT( "Mismatch between dSourceVertexLon and nA" ); 00504 } 00505 if( dSourceVertexLat.GetRows() != nA ) 00506 { 00507 _EXCEPTIONT( "Mismatch between dSourceVertexLat and nA" ); 00508 } 00509 if( dTargetVertexLon.GetRows() != nB ) 00510 { 00511 _EXCEPTIONT( "Mismatch between dTargetVertexLon and nB" ); 00512 } 00513 if( dTargetVertexLat.GetRows() != nB ) 00514 { 00515 _EXCEPTIONT( "Mismatch between dTargetVertexLat and nB" ); 00516 } 00517 00518 varYCA->set_cur( (long)offbuf[0] ); 00519 varYCA->put( &( dSourceCenterLat[0] ), nA ); 00520 varYCB->set_cur( (long)offbuf[1] ); 00521 varYCB->put( &( dTargetCenterLat[0] ), nB ); 00522 00523 varXCA->set_cur( (long)offbuf[0] ); 00524 varXCA->put( &( dSourceCenterLon[0] ), nA ); 00525 varXCB->set_cur( (long)offbuf[1] ); 00526 varXCB->put( &( dTargetCenterLon[0] ), nB ); 00527 00528 varYVA->set_cur( (long)offbuf[0] ); 00529 varYVA->put( &( dSourceVertexLat[0][0] ), nA, nSourceNodesPerFace ); 00530 varYVB->set_cur( (long)offbuf[1] ); 00531 varYVB->put( &( dTargetVertexLat[0][0] ), nB, nTargetNodesPerFace ); 00532 00533 varXVA->set_cur( (long)offbuf[0] ); 00534 varXVA->put( &( dSourceVertexLon[0][0] ), nA, nSourceNodesPerFace ); 00535 varXVB->set_cur( (long)offbuf[1] ); 00536 varXVB->put( &( dTargetVertexLon[0][0] ), nB, nTargetNodesPerFace ); 00537 00538 varMaskA->set_cur( (long)offbuf[0] ); 00539 varMaskA->put( &( masksA[0] ), nA ); 00540 varMaskB->set_cur( (long)offbuf[1] ); 00541 varMaskB->put( &( masksB[0] ), nB ); 00542 00543 // Write areas 00544 NcVar* varAreaA = ncMap.add_var( "area_a", ncDouble, dimNA ); 00545 #ifdef MOAB_HAVE_NETCDFPAR 00546 ncMap.enable_var_par_access( varAreaA, is_independent ); 00547 #endif 00548 varAreaA->set_cur( (long)offbuf[0] ); 00549 varAreaA->put( &( vecSourceFaceArea[0] ), nA ); 00550 00551 NcVar* varAreaB = ncMap.add_var( "area_b", ncDouble, dimNB ); 00552 #ifdef MOAB_HAVE_NETCDFPAR 00553 ncMap.enable_var_par_access( varAreaB, is_independent ); 00554 #endif 00555 varAreaB->set_cur( (long)offbuf[1] ); 00556 varAreaB->put( &( vecTargetFaceArea[0] ), nB ); 00557 00558 // Write SparseMatrix entries 00559 DataArray1D< int > vecRow( nS ); 00560 DataArray1D< int > vecCol( nS ); 00561 DataArray1D< double > vecS( nS ); 00562 DataArray1D< double > dFracA( nA ); 00563 DataArray1D< double > dFracB( nB ); 00564 00565 moab::TupleList tlValRow, tlValCol; 00566 unsigned numr = 1; // 00567 // value has to be sent to processor row/nB for for fracA and col/nA for fracB 00568 // vecTargetArea (indexRow ) has to be sent for fracA (index col?) 00569 // vecTargetFaceArea will have to be sent to col index, with its index ! 00570 tlValRow.initialize( 2, 0, 0, numr, nS ); // to proc(row), global row , value 00571 tlValCol.initialize( 3, 0, 0, numr, nS ); // to proc(col), global row / col, value 00572 tlValRow.enableWriteAccess(); 00573 tlValCol.enableWriteAccess(); 00574 /* 00575 * 00576 dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ]; 00577 dFracB[ row ] += val ; 00578 */ 00579 int offset = 0; 00580 #if defined( MOAB_HAVE_MPI ) 00581 int nAbase = ( max_col_dof + 1 ) / size; // it is nA, except last rank ( == size - 1 ) 00582 int nBbase = ( max_row_dof + 1 ) / size; // it is nB, except last rank ( == size - 1 ) 00583 #endif 00584 for( int i = 0; i < m_weightMatrix.outerSize(); ++i ) 00585 { 00586 for( WeightMatrix::InnerIterator it( m_weightMatrix, i ); it; ++it ) 00587 { 00588 vecRow[offset] = 1 + this->GetRowGlobalDoF( it.row() ); // row index 00589 vecCol[offset] = 1 + this->GetColGlobalDoF( it.col() ); // col index 00590 vecS[offset] = it.value(); // value 00591 00592 #if defined( MOAB_HAVE_MPI ) 00593 { 00594 // value M(row, col) will contribute to procRow and procCol values for fracA and fracB 00595 int procRow = ( vecRow[offset] - 1 ) / nBbase; 00596 if( procRow >= size ) procRow = size - 1; 00597 int procCol = ( vecCol[offset] - 1 ) / nAbase; 00598 if( procCol >= size ) procCol = size - 1; 00599 int nrInd = tlValRow.get_n(); 00600 tlValRow.vi_wr[2 * nrInd] = procRow; 00601 tlValRow.vi_wr[2 * nrInd + 1] = vecRow[offset] - 1; 00602 tlValRow.vr_wr[nrInd] = vecS[offset]; 00603 tlValRow.inc_n(); 00604 int ncInd = tlValCol.get_n(); 00605 tlValCol.vi_wr[3 * ncInd] = procCol; 00606 tlValCol.vi_wr[3 * ncInd + 1] = vecRow[offset] - 1; 00607 tlValCol.vi_wr[3 * ncInd + 2] = vecCol[offset] - 1; // this is column 00608 tlValCol.vr_wr[ncInd] = vecS[offset]; 00609 tlValCol.inc_n(); 00610 } 00611 00612 #endif 00613 offset++; 00614 } 00615 } 00616 #if defined( MOAB_HAVE_MPI ) 00617 // need to send values for their row and col processors, to compute fractions there 00618 // now do the heavy communication 00619 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tlValCol, 0 ); 00620 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tlValRow, 0 ); 00621 00622 // we have now, for example, dFracB[ row ] += val ; 00623 // so we know that on current task, we received tlValRow 00624 // reminder dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ]; 00625 // dFracB[ row ] += val ; 00626 for( unsigned i = 0; i < tlValRow.get_n(); i++ ) 00627 { 00628 // int fromProc = tlValRow.vi_wr[2 * i]; 00629 int gRowInd = tlValRow.vi_wr[2 * i + 1]; 00630 int localIndexRow = gRowInd - nBbase * rank; // modulo nBbase rank is from 0 to size - 1; 00631 double wgt = tlValRow.vr_wr[i]; 00632 assert( localIndexRow >= 0 ); 00633 assert( nB - localIndexRow > 0 ); 00634 dFracB[localIndexRow] += wgt; 00635 } 00636 // to compute dFracA we need vecTargetFaceArea[ row ]; we know the row, and we can get the proc we need it from 00637 00638 std::set< int > neededRows; 00639 for( unsigned i = 0; i < tlValCol.get_n(); i++ ) 00640 { 00641 int rRowInd = tlValCol.vi_wr[3 * i + 1]; 00642 neededRows.insert( rRowInd ); 00643 // we need vecTargetFaceAreaGlobal[ rRowInd ]; this exists on proc procRow 00644 } 00645 moab::TupleList tgtAreaReq; 00646 tgtAreaReq.initialize( 2, 0, 0, 0, neededRows.size() ); 00647 tgtAreaReq.enableWriteAccess(); 00648 for( std::set< int >::iterator sit = neededRows.begin(); sit != neededRows.end(); sit++ ) 00649 { 00650 int neededRow = *sit; 00651 int procRow = neededRow / nBbase; 00652 if( procRow >= size ) procRow = size - 1; 00653 int nr = tgtAreaReq.get_n(); 00654 tgtAreaReq.vi_wr[2 * nr] = procRow; 00655 tgtAreaReq.vi_wr[2 * nr + 1] = neededRow; 00656 tgtAreaReq.inc_n(); 00657 } 00658 00659 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tgtAreaReq, 0 ); 00660 // we need to send back the tgtArea corresponding to row 00661 moab::TupleList tgtAreaInfo; // load it with tgtArea at row 00662 tgtAreaInfo.initialize( 2, 0, 0, 1, tgtAreaReq.get_n() ); 00663 tgtAreaInfo.enableWriteAccess(); 00664 for( unsigned i = 0; i < tgtAreaReq.get_n(); i++ ) 00665 { 00666 int from_proc = tgtAreaReq.vi_wr[2 * i]; 00667 int row = tgtAreaReq.vi_wr[2 * i + 1]; 00668 int locaIndexRow = row - rank * nBbase; 00669 double areaToSend = vecTargetFaceArea[locaIndexRow]; 00670 // int remoteIndex = tgtAreaReq.vi_wr[3*i + 2] ; 00671 00672 tgtAreaInfo.vi_wr[2 * i] = from_proc; // send back requested info 00673 tgtAreaInfo.vi_wr[2 * i + 1] = row; 00674 tgtAreaInfo.vr_wr[i] = areaToSend; // this will be tgt area at row 00675 tgtAreaInfo.inc_n(); 00676 } 00677 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tgtAreaInfo, 0 ); 00678 00679 std::map< int, double > areaAtRow; 00680 for( unsigned i = 0; i < tgtAreaInfo.get_n(); i++ ) 00681 { 00682 // we have received from proc, value for row ! 00683 int row = tgtAreaInfo.vi_wr[2 * i + 1]; 00684 areaAtRow[row] = tgtAreaInfo.vr_wr[i]; 00685 } 00686 00687 // we have now for rows the 00688 // it is ordered by index, so: 00689 // now compute reminder dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ]; 00690 // tgtAreaInfo will have at index i the area we need (from row) 00691 // there should be an easier way :( 00692 for( unsigned i = 0; i < tlValCol.get_n(); i++ ) 00693 { 00694 int rRowInd = tlValCol.vi_wr[3 * i + 1]; 00695 int colInd = tlValCol.vi_wr[3 * i + 2]; 00696 double val = tlValCol.vr_wr[i]; 00697 int localColInd = colInd - rank * nAbase; // < local nA 00698 // we need vecTargetFaceAreaGlobal[ rRowInd ]; this exists on proc procRow 00699 auto itMap = areaAtRow.find( rRowInd ); // it should be different from end 00700 if( itMap != areaAtRow.end() ) 00701 { 00702 double areaRow = itMap->second; // we fished a lot for this ! 00703 dFracA[localColInd] += val / vecSourceFaceArea[localColInd] * areaRow; 00704 } 00705 } 00706 00707 #endif 00708 // Load in data 00709 NcDim* dimNS = ncMap.add_dim( "n_s", globuf[2] ); 00710 00711 NcVar* varRow = ncMap.add_var( "row", ncInt, dimNS ); 00712 NcVar* varCol = ncMap.add_var( "col", ncInt, dimNS ); 00713 NcVar* varS = ncMap.add_var( "S", ncDouble, dimNS ); 00714 #ifdef MOAB_HAVE_NETCDFPAR 00715 ncMap.enable_var_par_access( varRow, is_independent ); 00716 ncMap.enable_var_par_access( varCol, is_independent ); 00717 ncMap.enable_var_par_access( varS, is_independent ); 00718 #endif 00719 00720 varRow->set_cur( (long)offbuf[2] ); 00721 varRow->put( vecRow, nS ); 00722 00723 varCol->set_cur( (long)offbuf[2] ); 00724 varCol->put( vecCol, nS ); 00725 00726 varS->set_cur( (long)offbuf[2] ); 00727 varS->put( &( vecS[0] ), nS ); 00728 00729 // Calculate and write fractional coverage arrays 00730 NcVar* varFracA = ncMap.add_var( "frac_a", ncDouble, dimNA ); 00731 #ifdef MOAB_HAVE_NETCDFPAR 00732 ncMap.enable_var_par_access( varFracA, is_independent ); 00733 #endif 00734 varFracA->add_att( "name", "fraction of target coverage of source dof" ); 00735 varFracA->add_att( "units", "unitless" ); 00736 varFracA->set_cur( (long)offbuf[0] ); 00737 varFracA->put( &( dFracA[0] ), nA ); 00738 00739 NcVar* varFracB = ncMap.add_var( "frac_b", ncDouble, dimNB ); 00740 #ifdef MOAB_HAVE_NETCDFPAR 00741 ncMap.enable_var_par_access( varFracB, is_independent ); 00742 #endif 00743 varFracB->add_att( "name", "fraction of source coverage of target dof" ); 00744 varFracB->add_att( "units", "unitless" ); 00745 varFracB->set_cur( (long)offbuf[1] ); 00746 varFracB->put( &( dFracB[0] ), nB ); 00747 00748 // Add global attributes 00749 // std::map<std::string, std::string>::const_iterator iterAttributes = 00750 // mapAttributes.begin(); 00751 // for (; iterAttributes != mapAttributes.end(); iterAttributes++) { 00752 // ncMap.add_att( 00753 // iterAttributes->first.c_str(), 00754 // iterAttributes->second.c_str()); 00755 // } 00756 00757 ncMap.close(); 00758 00759 return moab::MB_SUCCESS; 00760 } 00761 00762 /////////////////////////////////////////////////////////////////////////////// 00763 00764 moab::ErrorCode moab::TempestOnlineMap::WriteHDF5MapFile( const std::string& strOutputFile ) 00765 { 00766 moab::ErrorCode rval; 00767 00768 /** 00769 * Need to get the global maximum of number of vertices per element 00770 * Key issue is that when calling InitializeCoordinatesFromMeshFV, the allocation for 00771 *dVertexLon/dVertexLat are made based on the maximum vertices in the current process. However, 00772 *when writing this out, other processes may have a different size for the same array. This is 00773 *hence a mess to consolidate in h5mtoscrip eventually. 00774 **/ 00775 00776 /* Let us compute all relevant data for the current original source mesh on the process */ 00777 DataArray1D< double > vecSourceFaceArea, vecTargetFaceArea; 00778 DataArray1D< double > dSourceCenterLon, dSourceCenterLat, dTargetCenterLon, dTargetCenterLat; 00779 DataArray2D< double > dSourceVertexLon, dSourceVertexLat, dTargetVertexLon, dTargetVertexLat; 00780 if( m_srcDiscType == DiscretizationType_FV || m_srcDiscType == DiscretizationType_PCLOUD ) 00781 { 00782 this->InitializeCoordinatesFromMeshFV( 00783 *m_meshInput, dSourceCenterLon, dSourceCenterLat, dSourceVertexLon, dSourceVertexLat, 00784 ( this->m_remapper->m_source_type == moab::TempestRemapper::RLL ) /* fLatLon = false */, 00785 m_remapper->max_source_edges ); 00786 00787 vecSourceFaceArea.Allocate( m_meshInput->vecFaceArea.GetRows() ); 00788 for( unsigned i = 0; i < m_meshInput->vecFaceArea.GetRows(); ++i ) 00789 vecSourceFaceArea[i] = m_meshInput->vecFaceArea[i]; 00790 } 00791 else 00792 { 00793 DataArray3D< double > dataGLLJacobianSrc; 00794 this->InitializeCoordinatesFromMeshFE( *m_meshInput, m_nDofsPEl_Src, dataGLLNodesSrc, dSourceCenterLon, 00795 dSourceCenterLat, dSourceVertexLon, dSourceVertexLat ); 00796 00797 // Generate the continuous Jacobian for input mesh 00798 GenerateMetaData( *m_meshInput, m_nDofsPEl_Src, false /* fBubble */, dataGLLNodesSrc, dataGLLJacobianSrc ); 00799 00800 if( m_srcDiscType == DiscretizationType_CGLL ) 00801 { 00802 GenerateUniqueJacobian( dataGLLNodesSrc, dataGLLJacobianSrc, m_meshInput->vecFaceArea ); 00803 } 00804 else 00805 { 00806 GenerateDiscontinuousJacobian( dataGLLJacobianSrc, m_meshInput->vecFaceArea ); 00807 } 00808 00809 vecSourceFaceArea.Allocate( m_meshInput->faces.size() * m_nDofsPEl_Src * m_nDofsPEl_Src ); 00810 int offset = 0; 00811 for( size_t e = 0; e < m_meshInput->faces.size(); e++ ) 00812 { 00813 for( int s = 0; s < m_nDofsPEl_Src; s++ ) 00814 { 00815 for( int t = 0; t < m_nDofsPEl_Src; t++ ) 00816 { 00817 vecSourceFaceArea[srccol_dtoc_dofmap[offset + s * m_nDofsPEl_Src + t]] = 00818 dataGLLJacobianSrc[s][t][e]; 00819 } 00820 } 00821 offset += m_nDofsPEl_Src * m_nDofsPEl_Src; 00822 } 00823 } 00824 00825 if( m_destDiscType == DiscretizationType_FV || m_destDiscType == DiscretizationType_PCLOUD ) 00826 { 00827 this->InitializeCoordinatesFromMeshFV( 00828 *m_meshOutput, dTargetCenterLon, dTargetCenterLat, dTargetVertexLon, dTargetVertexLat, 00829 ( this->m_remapper->m_target_type == moab::TempestRemapper::RLL ) /* fLatLon = false */, 00830 m_remapper->max_target_edges ); 00831 00832 vecTargetFaceArea.Allocate( m_meshOutput->vecFaceArea.GetRows() ); 00833 for( unsigned i = 0; i < m_meshOutput->vecFaceArea.GetRows(); ++i ) 00834 vecTargetFaceArea[i] = m_meshOutput->vecFaceArea[i]; 00835 } 00836 else 00837 { 00838 DataArray3D< double > dataGLLJacobianDest; 00839 this->InitializeCoordinatesFromMeshFE( *m_meshOutput, m_nDofsPEl_Dest, dataGLLNodesDest, dTargetCenterLon, 00840 dTargetCenterLat, dTargetVertexLon, dTargetVertexLat ); 00841 00842 // Generate the continuous Jacobian for input mesh 00843 GenerateMetaData( *m_meshOutput, m_nDofsPEl_Dest, false /* fBubble */, dataGLLNodesDest, dataGLLJacobianDest ); 00844 00845 if( m_destDiscType == DiscretizationType_CGLL ) 00846 { 00847 GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianDest, m_meshOutput->vecFaceArea ); 00848 } 00849 else 00850 { 00851 GenerateDiscontinuousJacobian( dataGLLJacobianDest, m_meshOutput->vecFaceArea ); 00852 } 00853 00854 vecTargetFaceArea.Allocate( m_meshOutput->faces.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest ); 00855 int offset = 0; 00856 for( size_t e = 0; e < m_meshOutput->faces.size(); e++ ) 00857 { 00858 for( int s = 0; s < m_nDofsPEl_Dest; s++ ) 00859 { 00860 for( int t = 0; t < m_nDofsPEl_Dest; t++ ) 00861 { 00862 vecTargetFaceArea[row_dtoc_dofmap[offset + s * m_nDofsPEl_Dest + t]] = dataGLLJacobianDest[s][t][e]; 00863 } 00864 } 00865 offset += m_nDofsPEl_Dest * m_nDofsPEl_Dest; 00866 } 00867 } 00868 00869 moab::EntityHandle& m_meshOverlapSet = m_remapper->m_overlap_set; 00870 int tot_src_ents = m_remapper->m_source_entities.size(); 00871 int tot_tgt_ents = m_remapper->m_target_entities.size(); 00872 int tot_src_size = dSourceCenterLon.GetRows(); 00873 int tot_tgt_size = m_dTargetCenterLon.GetRows(); 00874 int tot_vsrc_size = dSourceVertexLon.GetRows() * dSourceVertexLon.GetColumns(); 00875 int tot_vtgt_size = m_dTargetVertexLon.GetRows() * m_dTargetVertexLon.GetColumns(); 00876 00877 const int weightMatNNZ = m_weightMatrix.nonZeros(); 00878 moab::Tag tagMapMetaData, tagMapIndexRow, tagMapIndexCol, tagMapValues, srcEleIDs, tgtEleIDs; 00879 rval = m_interface->tag_get_handle( "SMAT_DATA", 13, moab::MB_TYPE_INTEGER, tagMapMetaData, 00880 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00881 rval = m_interface->tag_get_handle( "SMAT_ROWS", weightMatNNZ, moab::MB_TYPE_INTEGER, tagMapIndexRow, 00882 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00883 rval = m_interface->tag_get_handle( "SMAT_COLS", weightMatNNZ, moab::MB_TYPE_INTEGER, tagMapIndexCol, 00884 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00885 rval = m_interface->tag_get_handle( "SMAT_VALS", weightMatNNZ, moab::MB_TYPE_DOUBLE, tagMapValues, 00886 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00887 rval = m_interface->tag_get_handle( "SourceGIDS", tot_src_size, moab::MB_TYPE_INTEGER, srcEleIDs, 00888 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00889 rval = m_interface->tag_get_handle( "TargetGIDS", tot_tgt_size, moab::MB_TYPE_INTEGER, tgtEleIDs, 00890 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00891 moab::Tag srcAreaValues, tgtAreaValues; 00892 rval = m_interface->tag_get_handle( "SourceAreas", tot_src_size, moab::MB_TYPE_DOUBLE, srcAreaValues, 00893 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00894 rval = m_interface->tag_get_handle( "TargetAreas", tot_tgt_size, moab::MB_TYPE_DOUBLE, tgtAreaValues, 00895 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00896 moab::Tag tagSrcCoordsCLon, tagSrcCoordsCLat, tagTgtCoordsCLon, tagTgtCoordsCLat; 00897 rval = m_interface->tag_get_handle( "SourceCoordCenterLon", tot_src_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsCLon, 00898 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00899 rval = m_interface->tag_get_handle( "SourceCoordCenterLat", tot_src_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsCLat, 00900 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00901 rval = m_interface->tag_get_handle( "TargetCoordCenterLon", tot_tgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsCLon, 00902 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00903 rval = m_interface->tag_get_handle( "TargetCoordCenterLat", tot_tgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsCLat, 00904 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00905 moab::Tag tagSrcCoordsVLon, tagSrcCoordsVLat, tagTgtCoordsVLon, tagTgtCoordsVLat; 00906 rval = m_interface->tag_get_handle( "SourceCoordVertexLon", tot_vsrc_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsVLon, 00907 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00908 rval = m_interface->tag_get_handle( "SourceCoordVertexLat", tot_vsrc_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsVLat, 00909 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00910 rval = m_interface->tag_get_handle( "TargetCoordVertexLon", tot_vtgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsVLon, 00911 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00912 rval = m_interface->tag_get_handle( "TargetCoordVertexLat", tot_vtgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsVLat, 00913 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00914 moab::Tag srcMaskValues, tgtMaskValues; 00915 if( m_iSourceMask.IsAttached() ) 00916 { 00917 rval = m_interface->tag_get_handle( "SourceMask", m_iSourceMask.GetRows(), moab::MB_TYPE_INTEGER, srcMaskValues, 00918 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00919 } 00920 if( m_iTargetMask.IsAttached() ) 00921 { 00922 rval = m_interface->tag_get_handle( "TargetMask", m_iTargetMask.GetRows(), moab::MB_TYPE_INTEGER, tgtMaskValues, 00923 moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" ); 00924 } 00925 00926 std::vector< int > smatrowvals( weightMatNNZ ), smatcolvals( weightMatNNZ ); 00927 std::vector< double > smatvals( weightMatNNZ ); 00928 // const double* smatvals = m_weightMatrix.valuePtr(); 00929 // Loop over the matrix entries and find the max global ID for rows and columns 00930 for( int k = 0, offset = 0; k < m_weightMatrix.outerSize(); ++k ) 00931 { 00932 for( moab::TempestOnlineMap::WeightMatrix::InnerIterator it( m_weightMatrix, k ); it; ++it, ++offset ) 00933 { 00934 smatrowvals[offset] = this->GetRowGlobalDoF( it.row() ); 00935 smatcolvals[offset] = this->GetColGlobalDoF( it.col() ); 00936 smatvals[offset] = it.value(); 00937 } 00938 } 00939 00940 /* Set the global IDs for the DoFs */ 00941 //// 00942 // col_gdofmap [ col_ldofmap [ 0 : local_ndofs ] ] = GDOF 00943 // row_gdofmap [ row_ldofmap [ 0 : local_ndofs ] ] = GDOF 00944 //// 00945 int maxrow = 0, maxcol = 0; 00946 std::vector< int > src_global_dofs( tot_src_size ), tgt_global_dofs( tot_tgt_size ); 00947 for( int i = 0; i < tot_src_size; ++i ) 00948 { 00949 src_global_dofs[i] = srccol_gdofmap[i]; 00950 maxcol = ( src_global_dofs[i] > maxcol ) ? src_global_dofs[i] : maxcol; 00951 } 00952 00953 for( int i = 0; i < tot_tgt_size; ++i ) 00954 { 00955 tgt_global_dofs[i] = row_gdofmap[i]; 00956 maxrow = ( tgt_global_dofs[i] > maxrow ) ? tgt_global_dofs[i] : maxrow; 00957 } 00958 00959 /////////////////////////////////////////////////////////////////////////// 00960 // The metadata in H5M file contains the following data: 00961 // 00962 // 1. n_a: Total source entities: (number of elements in source mesh) 00963 // 2. n_b: Total target entities: (number of elements in target mesh) 00964 // 3. nv_a: Max edge size of elements in source mesh 00965 // 4. nv_b: Max edge size of elements in target mesh 00966 // 5. maxrows: Number of rows in remap weight matrix 00967 // 6. maxcols: Number of cols in remap weight matrix 00968 // 7. nnz: Number of total nnz in sparse remap weight matrix 00969 // 8. np_a: The order of the field description on the source mesh: >= 1 00970 // 9. np_b: The order of the field description on the target mesh: >= 1 00971 // 10. method_a: The type of discretization for field on source mesh: [0 = FV, 1 = cGLL, 2 = 00972 // dGLL] 00973 // 11. method_b: The type of discretization for field on target mesh: [0 = FV, 1 = cGLL, 2 = 00974 // dGLL] 00975 // 12. conserved: Flag to specify whether the remap operator has conservation constraints: [0, 00976 // 1] 00977 // 13. monotonicity: Flags to specify whether the remap operator has monotonicity constraints: 00978 // [0, 1, 2] 00979 // 00980 /////////////////////////////////////////////////////////////////////////// 00981 int map_disc_details[6]; 00982 map_disc_details[0] = m_nDofsPEl_Src; 00983 map_disc_details[1] = m_nDofsPEl_Dest; 00984 map_disc_details[2] = ( m_srcDiscType == DiscretizationType_FV || m_srcDiscType == DiscretizationType_PCLOUD 00985 ? 0 00986 : ( m_srcDiscType == DiscretizationType_CGLL ? 1 : 2 ) ); 00987 map_disc_details[3] = ( m_destDiscType == DiscretizationType_FV || m_destDiscType == DiscretizationType_PCLOUD 00988 ? 0 00989 : ( m_destDiscType == DiscretizationType_CGLL ? 1 : 2 ) ); 00990 map_disc_details[4] = ( m_bConserved ? 1 : 0 ); 00991 map_disc_details[5] = m_iMonotonicity; 00992 00993 #ifdef MOAB_HAVE_MPI 00994 int loc_smatmetadata[13] = { tot_src_ents, 00995 tot_tgt_ents, 00996 m_remapper->max_source_edges, 00997 m_remapper->max_target_edges, 00998 maxrow + 1, 00999 maxcol + 1, 01000 weightMatNNZ, 01001 map_disc_details[0], 01002 map_disc_details[1], 01003 map_disc_details[2], 01004 map_disc_details[3], 01005 map_disc_details[4], 01006 map_disc_details[5] }; 01007 rval = m_interface->tag_set_data( tagMapMetaData, &m_meshOverlapSet, 1, &loc_smatmetadata[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01008 int glb_smatmetadata[13] = { 0, 01009 0, 01010 0, 01011 0, 01012 0, 01013 0, 01014 0, 01015 map_disc_details[0], 01016 map_disc_details[1], 01017 map_disc_details[2], 01018 map_disc_details[3], 01019 map_disc_details[4], 01020 map_disc_details[5] }; 01021 int loc_buf[7] = { 01022 tot_src_ents, tot_tgt_ents, weightMatNNZ, m_remapper->max_source_edges, m_remapper->max_target_edges, 01023 maxrow, maxcol }; 01024 int glb_buf[4] = { 0, 0, 0, 0 }; 01025 MPI_Reduce( &loc_buf[0], &glb_buf[0], 3, MPI_INT, MPI_SUM, 0, m_pcomm->comm() ); 01026 glb_smatmetadata[0] = glb_buf[0]; 01027 glb_smatmetadata[1] = glb_buf[1]; 01028 glb_smatmetadata[6] = glb_buf[2]; 01029 MPI_Reduce( &loc_buf[3], &glb_buf[0], 4, MPI_INT, MPI_MAX, 0, m_pcomm->comm() ); 01030 glb_smatmetadata[2] = glb_buf[0]; 01031 glb_smatmetadata[3] = glb_buf[1]; 01032 glb_smatmetadata[4] = glb_buf[2]; 01033 glb_smatmetadata[5] = glb_buf[3]; 01034 #else 01035 int glb_smatmetadata[13] = { tot_src_ents, 01036 tot_tgt_ents, 01037 m_remapper->max_source_edges, 01038 m_remapper->max_target_edges, 01039 maxrow, 01040 maxcol, 01041 weightMatNNZ, 01042 map_disc_details[0], 01043 map_disc_details[1], 01044 map_disc_details[2], 01045 map_disc_details[3], 01046 map_disc_details[4], 01047 map_disc_details[5] }; 01048 #endif 01049 // These values represent number of rows and columns. So should be 1-based. 01050 glb_smatmetadata[4]++; 01051 glb_smatmetadata[5]++; 01052 01053 if( this->is_root ) 01054 { 01055 std::cout << " " << this->rank << " Writing remap weights with size [" << glb_smatmetadata[4] << " X " 01056 << glb_smatmetadata[5] << "] and NNZ = " << glb_smatmetadata[6] << std::endl; 01057 EntityHandle root_set = 0; 01058 rval = m_interface->tag_set_data( tagMapMetaData, &root_set, 1, &glb_smatmetadata[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01059 } 01060 01061 int dsize; 01062 const int numval = weightMatNNZ; 01063 const void* smatrowvals_d = smatrowvals.data(); 01064 const void* smatcolvals_d = smatcolvals.data(); 01065 const void* smatvals_d = smatvals.data(); 01066 rval = m_interface->tag_set_by_ptr( tagMapIndexRow, &m_meshOverlapSet, 1, &smatrowvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01067 rval = m_interface->tag_set_by_ptr( tagMapIndexCol, &m_meshOverlapSet, 1, &smatcolvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01068 rval = m_interface->tag_set_by_ptr( tagMapValues, &m_meshOverlapSet, 1, &smatvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01069 01070 /* Set the global IDs for the DoFs */ 01071 const void* srceleidvals_d = src_global_dofs.data(); 01072 const void* tgteleidvals_d = tgt_global_dofs.data(); 01073 dsize = src_global_dofs.size(); 01074 rval = m_interface->tag_set_by_ptr( srcEleIDs, &m_meshOverlapSet, 1, &srceleidvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01075 dsize = tgt_global_dofs.size(); 01076 rval = m_interface->tag_set_by_ptr( tgtEleIDs, &m_meshOverlapSet, 1, &tgteleidvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01077 01078 /* Set the source and target areas */ 01079 const void* srcareavals_d = vecSourceFaceArea; 01080 const void* tgtareavals_d = vecTargetFaceArea; 01081 dsize = tot_src_size; 01082 rval = m_interface->tag_set_by_ptr( srcAreaValues, &m_meshOverlapSet, 1, &srcareavals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01083 dsize = tot_tgt_size; 01084 rval = m_interface->tag_set_by_ptr( tgtAreaValues, &m_meshOverlapSet, 1, &tgtareavals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01085 01086 /* Set the coordinates for source and target center vertices */ 01087 const void* srccoordsclonvals_d = &dSourceCenterLon[0]; 01088 const void* srccoordsclatvals_d = &dSourceCenterLat[0]; 01089 dsize = dSourceCenterLon.GetRows(); 01090 rval = m_interface->tag_set_by_ptr( tagSrcCoordsCLon, &m_meshOverlapSet, 1, &srccoordsclonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01091 rval = m_interface->tag_set_by_ptr( tagSrcCoordsCLat, &m_meshOverlapSet, 1, &srccoordsclatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01092 const void* tgtcoordsclonvals_d = &m_dTargetCenterLon[0]; 01093 const void* tgtcoordsclatvals_d = &m_dTargetCenterLat[0]; 01094 dsize = vecTargetFaceArea.GetRows(); 01095 rval = m_interface->tag_set_by_ptr( tagTgtCoordsCLon, &m_meshOverlapSet, 1, &tgtcoordsclonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01096 rval = m_interface->tag_set_by_ptr( tagTgtCoordsCLat, &m_meshOverlapSet, 1, &tgtcoordsclatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01097 01098 /* Set the coordinates for source and target element vertices */ 01099 const void* srccoordsvlonvals_d = &( dSourceVertexLon[0][0] ); 01100 const void* srccoordsvlatvals_d = &( dSourceVertexLat[0][0] ); 01101 dsize = dSourceVertexLon.GetRows() * dSourceVertexLon.GetColumns(); 01102 rval = m_interface->tag_set_by_ptr( tagSrcCoordsVLon, &m_meshOverlapSet, 1, &srccoordsvlonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01103 rval = m_interface->tag_set_by_ptr( tagSrcCoordsVLat, &m_meshOverlapSet, 1, &srccoordsvlatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01104 const void* tgtcoordsvlonvals_d = &( m_dTargetVertexLon[0][0] ); 01105 const void* tgtcoordsvlatvals_d = &( m_dTargetVertexLat[0][0] ); 01106 dsize = m_dTargetVertexLon.GetRows() * m_dTargetVertexLon.GetColumns(); 01107 rval = m_interface->tag_set_by_ptr( tagTgtCoordsVLon, &m_meshOverlapSet, 1, &tgtcoordsvlonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01108 rval = m_interface->tag_set_by_ptr( tagTgtCoordsVLat, &m_meshOverlapSet, 1, &tgtcoordsvlatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01109 01110 /* Set the masks for source and target meshes if available */ 01111 if( m_iSourceMask.IsAttached() ) 01112 { 01113 const void* srcmaskvals_d = m_iSourceMask; 01114 dsize = m_iSourceMask.GetRows(); 01115 rval = m_interface->tag_set_by_ptr( srcMaskValues, &m_meshOverlapSet, 1, &srcmaskvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01116 } 01117 01118 if( m_iTargetMask.IsAttached() ) 01119 { 01120 const void* tgtmaskvals_d = m_iTargetMask; 01121 dsize = m_iTargetMask.GetRows(); 01122 rval = m_interface->tag_set_by_ptr( tgtMaskValues, &m_meshOverlapSet, 1, &tgtmaskvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" ); 01123 } 01124 01125 #ifdef MOAB_HAVE_MPI 01126 const char* writeOptions = ( this->size > 1 ? "PARALLEL=WRITE_PART" : "" ); 01127 #else 01128 const char* writeOptions = ""; 01129 #endif 01130 01131 // EntityHandle sets[3] = {m_remapper->m_source_set, m_remapper->m_target_set, m_remapper->m_overlap_set}; 01132 EntityHandle sets[1] = { m_remapper->m_overlap_set }; 01133 rval = m_interface->write_file( strOutputFile.c_str(), NULL, writeOptions, sets, 1 );MB_CHK_ERR( rval ); 01134 01135 #ifdef WRITE_SCRIP_FILE 01136 sstr.str( "" ); 01137 sstr << ctx.outFilename.substr( 0, lastindex ) << "_" << proc_id << ".nc"; 01138 std::map< std::string, std::string > mapAttributes; 01139 mapAttributes["Creator"] = "MOAB mbtempest workflow"; 01140 if( !ctx.proc_id ) std::cout << "Writing offline map to file: " << sstr.str() << std::endl; 01141 this->Write( strOutputFile.c_str(), mapAttributes, NcFile::Netcdf4 ); 01142 sstr.str( "" ); 01143 #endif 01144 01145 return moab::MB_SUCCESS; 01146 } 01147 01148 /////////////////////////////////////////////////////////////////////////////// 01149 01150 void print_progress( const int barWidth, const float progress, const char* message ) 01151 { 01152 std::cout << message << " ["; 01153 int pos = barWidth * progress; 01154 for( int i = 0; i < barWidth; ++i ) 01155 { 01156 if( i < pos ) 01157 std::cout << "="; 01158 else if( i == pos ) 01159 std::cout << ">"; 01160 else 01161 std::cout << " "; 01162 } 01163 std::cout << "] " << int( progress * 100.0 ) << " %\r"; 01164 std::cout.flush(); 01165 } 01166 01167 /////////////////////////////////////////////////////////////////////////////// 01168 01169 moab::ErrorCode moab::TempestOnlineMap::ReadParallelMap( const char* strSource, 01170 const std::vector< int >& owned_dof_ids, 01171 bool row_partition ) 01172 { 01173 NcError error( NcError::silent_nonfatal ); 01174 01175 NcVar *varRow = NULL, *varCol = NULL, *varS = NULL; 01176 int nS = 0, nA = 0, nB = 0; 01177 #ifdef MOAB_HAVE_PNETCDF 01178 // some variables will be used just in the case netcdfpar reader fails 01179 int ncfile = -1, ret = 0; 01180 int ndims, nvars, ngatts, unlimited; 01181 #endif 01182 #ifdef MOAB_HAVE_NETCDFPAR 01183 bool is_independent = true; 01184 ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strSource, NcFile::ReadOnly, NcFile::Netcdf4 ); 01185 // ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strFilename.c_str(), NcmpiFile::replace, NcmpiFile::classic5 ); 01186 #else 01187 NcFile ncMap( strSource, NcFile::ReadOnly ); 01188 #endif 01189 01190 #define CHECK_EXCEPTION( obj, type, varstr ) \ 01191 { \ 01192 if( obj == NULL ) \ 01193 { \ 01194 _EXCEPTION3( "Map file \"%s\" does not contain %s \"%s\"", strSource, type, varstr ); \ 01195 } \ 01196 } 01197 01198 // Read SparseMatrix entries 01199 01200 if( ncMap.is_valid() ) 01201 { 01202 NcDim* dimNS = ncMap.get_dim( "n_s" ); 01203 CHECK_EXCEPTION( dimNS, "dimension", "n_s" ); 01204 01205 NcDim* dimNA = ncMap.get_dim( "n_a" ); 01206 CHECK_EXCEPTION( dimNA, "dimension", "n_a" ); 01207 01208 NcDim* dimNB = ncMap.get_dim( "n_b" ); 01209 CHECK_EXCEPTION( dimNB, "dimension", "n_b" ); 01210 01211 // store total number of nonzeros 01212 nS = dimNS->size(); 01213 nA = dimNA->size(); 01214 nB = dimNB->size(); 01215 01216 varRow = ncMap.get_var( "row" ); 01217 CHECK_EXCEPTION( varRow, "variable", "row" ); 01218 01219 varCol = ncMap.get_var( "col" ); 01220 CHECK_EXCEPTION( varCol, "variable", "col" ); 01221 01222 varS = ncMap.get_var( "S" ); 01223 CHECK_EXCEPTION( varS, "variable", "S" ); 01224 01225 #ifdef MOAB_HAVE_NETCDFPAR 01226 ncMap.enable_var_par_access( varRow, is_independent ); 01227 ncMap.enable_var_par_access( varCol, is_independent ); 01228 ncMap.enable_var_par_access( varS, is_independent ); 01229 #endif 01230 } 01231 else 01232 { 01233 #ifdef MOAB_HAVE_PNETCDF 01234 // read the file using pnetcdf directly, in parallel; need to have MPI, we do not check that anymore 01235 // why build wth pnetcdf without MPI ? 01236 // ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strSource, NcFile::ReadOnly, NcFile::Netcdf4 ); 01237 ret = ncmpi_open( m_pcomm->comm(), strSource, NC_NOWRITE, MPI_INFO_NULL, &ncfile ); 01238 ERR_PARNC( ret ); // bail out completely 01239 ret = ncmpi_inq( ncfile, &ndims, &nvars, &ngatts, &unlimited ); 01240 ERR_PARNC( ret ); 01241 // find dimension ids for n_S 01242 int ins; 01243 ret = ncmpi_inq_dimid( ncfile, "n_s", &ins ); 01244 ERR_PARNC( ret ); 01245 MPI_Offset leng; 01246 ret = ncmpi_inq_dimlen( ncfile, ins, &leng ); 01247 ERR_PARNC( ret ); 01248 nS = (int)leng; 01249 ret = ncmpi_inq_dimid( ncfile, "n_b", &ins ); 01250 ERR_PARNC( ret ); 01251 ret = ncmpi_inq_dimlen( ncfile, ins, &leng ); 01252 ERR_PARNC( ret ); 01253 nB = (int)leng; 01254 #else 01255 _EXCEPTION1( "cannot read the file %s", strSource ); 01256 #endif 01257 } 01258 01259 // Let us declare the map object for every process 01260 SparseMatrix< double >& sparseMatrix = this->GetSparseMatrix(); 01261 01262 int localSize = nS / size; 01263 long offsetRead = rank * localSize; 01264 // leftovers on last rank 01265 if( rank == size - 1 ) 01266 { 01267 localSize += nS % size; 01268 } 01269 01270 std::vector< int > vecRow, vecCol; 01271 std::vector< double > vecS; 01272 vecRow.resize( localSize ); 01273 vecCol.resize( localSize ); 01274 vecS.resize( localSize ); 01275 01276 if( ncMap.is_valid() ) 01277 { 01278 varRow->set_cur( (long)( offsetRead ) ); 01279 varRow->get( &( vecRow[0] ), localSize ); 01280 01281 varCol->set_cur( (long)( offsetRead ) ); 01282 varCol->get( &( vecCol[0] ), localSize ); 01283 01284 varS->set_cur( (long)( offsetRead ) ); 01285 varS->get( &( vecS[0] ), localSize ); 01286 01287 ncMap.close(); 01288 } 01289 else 01290 { 01291 #ifdef MOAB_HAVE_PNETCDF 01292 // fill the local vectors with the variables from pnetcdf file; first inquire, then fill 01293 MPI_Offset start = (MPI_Offset)offsetRead; 01294 MPI_Offset count = (MPI_Offset)localSize; 01295 int varid; 01296 ret = ncmpi_inq_varid( ncfile, "S", &varid ); 01297 ERR_PARNC( ret ); 01298 ret = ncmpi_get_vara_double_all( ncfile, varid, &start, &count, &vecS[0] ); 01299 ERR_PARNC( ret ); 01300 ret = ncmpi_inq_varid( ncfile, "row", &varid ); 01301 ERR_PARNC( ret ); 01302 ret = ncmpi_get_vara_int_all( ncfile, varid, &start, &count, &vecRow[0] ); 01303 ERR_PARNC( ret ); 01304 ret = ncmpi_inq_varid( ncfile, "col", &varid ); 01305 ERR_PARNC( ret ); 01306 ret = ncmpi_get_vara_int_all( ncfile, varid, &start, &count, &vecCol[0] ); 01307 ERR_PARNC( ret ); 01308 ret = ncmpi_close( ncfile ); 01309 ERR_PARNC( ret ); 01310 #endif 01311 } 01312 01313 // Now let us set the necessary global-to-local ID maps so that A*x operations 01314 // can be performed cleanly as if map was computed online 01315 row_dtoc_dofmap.clear(); 01316 // row_dtoc_dofmap.reserve( nB / size ); 01317 col_dtoc_dofmap.clear(); 01318 rowMap.clear(); 01319 colMap.clear(); 01320 // col_dtoc_dofmap.reserve( 2 * nA / size ); 01321 // row_dtoc_dofmap.resize( m_nTotDofs_Dest, UINT_MAX ); 01322 // col_dtoc_dofmap.resize( m_nTotDofs_SrcCov, UINT_MAX ); 01323 01324 #ifdef MOAB_HAVE_MPI 01325 // bother with tuple list only if size > 1 01326 // otherwise, just fill the sparse matrix 01327 if( size > 1 ) 01328 { 01329 std::vector< int > ownership; 01330 // the default trivial partitioning scheme 01331 int nDofs = nB; // this is for row partitioning 01332 if( !row_partition ) nDofs = nA; // column partitioning 01333 01334 // assert(row_major_ownership == true); // this block is valid only for row-based partitioning 01335 ownership.resize( size ); 01336 int nPerPart = nDofs / size; 01337 int nRemainder = nDofs % size; // Keep the remainder in root 01338 ownership[0] = nPerPart + nRemainder; 01339 for( int ip = 1, roffset = ownership[0]; ip < size; ++ip ) 01340 { 01341 roffset += nPerPart; 01342 ownership[ip] = roffset; 01343 } 01344 moab::TupleList* tl = new moab::TupleList; 01345 unsigned numr = 1; // 01346 tl->initialize( 3, 0, 0, numr, localSize ); // to proc, row, col, value 01347 tl->enableWriteAccess(); 01348 // populate 01349 for( int i = 0; i < localSize; i++ ) 01350 { 01351 int rowval = vecRow[i] - 1; // dofs are 1 based in the file 01352 int colval = vecCol[i] - 1; 01353 int to_proc = -1; 01354 int dof_val = colval; 01355 if( row_partition ) dof_val = rowval; 01356 01357 if( ownership[0] > dof_val ) 01358 to_proc = 0; 01359 else 01360 { 01361 for( int ip = 1; ip < size; ++ip ) 01362 { 01363 if( ownership[ip - 1] <= dof_val && ownership[ip] > dof_val ) 01364 { 01365 to_proc = ip; 01366 break; 01367 } 01368 } 01369 } 01370 01371 int n = tl->get_n(); 01372 tl->vi_wr[3 * n] = to_proc; 01373 tl->vi_wr[3 * n + 1] = rowval; 01374 tl->vi_wr[3 * n + 2] = colval; 01375 tl->vr_wr[n] = vecS[i]; 01376 tl->inc_n(); 01377 } 01378 // heavy communication 01379 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, *tl, 0 ); 01380 01381 if( owned_dof_ids.size() > 0 ) 01382 { 01383 // we need to send desired dof to the rendez_vous point 01384 moab::TupleList tl_re; // 01385 tl_re.initialize( 2, 0, 0, 0, owned_dof_ids.size() ); // to proc, value 01386 tl_re.enableWriteAccess(); 01387 // send first to rendez_vous point, decided by trivial partitioning 01388 01389 for( size_t i = 0; i < owned_dof_ids.size(); i++ ) 01390 { 01391 int to_proc = -1; 01392 int dof_val = owned_dof_ids[i] - 1; // dofs are 1 based in the file, partition from 0 ? 01393 01394 if( ownership[0] > dof_val ) 01395 to_proc = 0; 01396 else 01397 { 01398 for( int ip = 1; ip < size; ++ip ) 01399 { 01400 if( ownership[ip - 1] <= dof_val && ownership[ip] > dof_val ) 01401 { 01402 to_proc = ip; 01403 break; 01404 } 01405 } 01406 } 01407 01408 int n = tl_re.get_n(); 01409 tl_re.vi_wr[2 * n] = to_proc; 01410 tl_re.vi_wr[2 * n + 1] = dof_val; 01411 01412 tl_re.inc_n(); 01413 } 01414 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tl_re, 0 ); 01415 // now we know in tl_re where do we need to send back dof_val 01416 moab::TupleList::buffer sort_buffer; 01417 sort_buffer.buffer_init( tl_re.get_n() ); 01418 tl_re.sort( 1, &sort_buffer ); // so now we order by value 01419 01420 sort_buffer.buffer_init( tl->get_n() ); 01421 int indexOrder = 2; // colVal 01422 if( row_partition ) indexOrder = 1; // rowVal 01423 //tl->sort( indexOrder, &sort_buffer ); 01424 01425 std::map< int, int > startDofIndex, endDofIndex; // indices in tl_re for values we want 01426 int dofVal = -1; 01427 if( tl_re.get_n() > 0 ) dofVal = tl_re.vi_rd[1]; // first dof val on this rank 01428 startDofIndex[dofVal] = 0; 01429 endDofIndex[dofVal] = 0; // start and end 01430 for( unsigned k = 1; k < tl_re.get_n(); k++ ) 01431 { 01432 int newDof = tl_re.vi_rd[2 * k + 1]; 01433 if( dofVal == newDof ) 01434 { 01435 endDofIndex[dofVal] = k; // increment by 1 actually 01436 } 01437 else 01438 { 01439 dofVal = newDof; 01440 startDofIndex[dofVal] = k; 01441 endDofIndex[dofVal] = k; 01442 } 01443 } 01444 01445 // basically, for each value we are interested in, index in tl_re with those values are 01446 // tl_re.vi_rd[2*startDofIndex+1] == valDof == tl_re.vi_rd[2*endDofIndex+1] 01447 // so now we have ordered 01448 // tl_re shows to what proc do we need to send the tuple (row, col, val) 01449 moab::TupleList* tl_back = new moab::TupleList; 01450 unsigned numr = 1; // 01451 // localSize is a good guess, but maybe it should be bigger ? 01452 // this could be bigger for repeated dofs 01453 tl_back->initialize( 3, 0, 0, numr, tl->get_n() ); // to proc, row, col, value 01454 tl_back->enableWriteAccess(); 01455 // now loop over tl and tl_re to see where to send 01456 // form the new tuple, which will contain the desired dofs per task, per row or column distribution 01457 01458 for( unsigned k = 0; k < tl->get_n(); k++ ) 01459 { 01460 int valDof = tl->vi_rd[3 * k + indexOrder]; // 1 for row, 2 for column // first value, it should be 01461 for( int ire = startDofIndex[valDof]; ire <= endDofIndex[valDof]; ire++ ) 01462 { 01463 int to_proc = tl_re.vi_rd[2 * ire]; 01464 int n = tl_back->get_n(); 01465 tl_back->vi_wr[3 * n] = to_proc; 01466 tl_back->vi_wr[3 * n + 1] = tl->vi_rd[3 * k + 1]; // row 01467 tl_back->vi_wr[3 * n + 2] = tl->vi_rd[3 * k + 2]; // col 01468 tl_back->vr_wr[n] = tl->vr_rd[k]; 01469 tl_back->inc_n(); 01470 } 01471 } 01472 01473 // now communicate to the desired tasks: 01474 ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, *tl_back, 0 ); 01475 01476 tl_re.reset(); // clear memory, although this will go out of scope 01477 tl->reset(); 01478 tl = tl_back; 01479 } 01480 01481 int rindexMax = 0, cindexMax = 0; 01482 // populate the sparsematrix, using rowMap and colMap 01483 int n = tl->get_n(); 01484 for( int i = 0; i < n; i++ ) 01485 { 01486 int rindex, cindex; 01487 const int& vecRowValue = tl->vi_wr[3 * i + 1]; 01488 const int& vecColValue = tl->vi_wr[3 * i + 2]; 01489 01490 std::map< int, int >::iterator riter = rowMap.find( vecRowValue ); 01491 if( riter == rowMap.end() ) 01492 { 01493 rowMap[vecRowValue] = rindexMax; 01494 rindex = rindexMax; 01495 row_gdofmap.push_back( vecRowValue ); 01496 // row_dtoc_dofmap.push_back( vecRowValue ); 01497 rindexMax++; 01498 } 01499 else 01500 rindex = riter->second; 01501 01502 std::map< int, int >::iterator citer = colMap.find( vecColValue ); 01503 if( citer == colMap.end() ) 01504 { 01505 colMap[vecColValue] = cindexMax; 01506 cindex = cindexMax; 01507 col_gdofmap.push_back( vecColValue ); 01508 // col_dtoc_dofmap.push_back( vecColValue ); 01509 cindexMax++; 01510 } 01511 else 01512 cindex = citer->second; 01513 01514 sparseMatrix( rindex, cindex ) = tl->vr_wr[i]; 01515 } 01516 tl->reset(); 01517 } 01518 else 01519 #endif 01520 { 01521 int rindexMax = 0, cindexMax = 0; 01522 01523 for( int i = 0; i < nS; i++ ) 01524 { 01525 int rindex, cindex; 01526 const int& vecRowValue = vecRow[i] - 1; // the rows, cols are 1 based in the file 01527 const int& vecColValue = vecCol[i] - 1; 01528 01529 std::map< int, int >::iterator riter = rowMap.find( vecRowValue ); 01530 if( riter == rowMap.end() ) 01531 { 01532 rowMap[vecRowValue] = rindexMax; 01533 rindex = rindexMax; 01534 row_gdofmap.push_back( vecRowValue ); 01535 // row_dtoc_dofmap.push_back( vecRowValue ); 01536 rindexMax++; 01537 } 01538 else 01539 rindex = riter->second; 01540 01541 std::map< int, int >::iterator citer = colMap.find( vecColValue ); 01542 if( citer == colMap.end() ) 01543 { 01544 colMap[vecColValue] = cindexMax; 01545 cindex = cindexMax; 01546 col_gdofmap.push_back( vecColValue ); 01547 // col_dtoc_dofmap.push_back( vecColValue ); 01548 cindexMax++; 01549 } 01550 else 01551 cindex = citer->second; 01552 01553 sparseMatrix( rindex, cindex ) = vecS[i]; 01554 } 01555 } 01556 01557 m_nTotDofs_SrcCov = sparseMatrix.GetColumns(); 01558 m_nTotDofs_Dest = sparseMatrix.GetRows(); 01559 01560 #ifdef MOAB_HAVE_EIGEN3 01561 this->copy_tempest_sparsemat_to_eigen3(); 01562 #endif 01563 01564 // Reset the source and target data first 01565 m_rowVector.setZero(); 01566 m_colVector.setZero(); 01567 01568 return moab::MB_SUCCESS; 01569 } 01570 01571 ///////////////////////////////////////////////////////////////////////////////
