MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 ! push parallel mesh into moab, F90 version, test 00002 ! 00003 ! This program shows how to push a mesh into MOAB in parallel from Fortran90, with sufficient 00004 ! information to resolve boundary sharing and exchange a layer of ghost information. 00005 ! 00006 ! After resolving the sharing, mesh is saved to a file, then read back again, in parallel 00007 ! the mesh is just a set of 6 quads that form a cube; it is distributed to at most 6 processors 00008 ! by default, this test is run on 2 processors 00009 #define ERROR(rval) if (0 .ne. rval) call exit(1) 00010 00011 program imeshp_test 00012 00013 use ISO_C_BINDING 00014 implicit none 00015 00016 #include "moab/MOABConfig.h" 00017 #include "mpif.h" 00018 #include "iMeshP_f.h" 00019 00020 ! declarations 00021 ! imesh is the instance handle 00022 iMesh_Instance imesh 00023 ! second instance, to check loading of mesh saved from first instance 00024 iMesh_Instance imesh2 00025 00026 ! NUMV, NUME, NVPERE are the hardwired here; these are for the whole mesh, 00027 ! local mesh determined later 00028 integer NUMV, NUME, NVPERE 00029 parameter (NUMV = 8) ! # vertices in whole mesh 00030 parameter (NUME = 6) ! # elements in whole mesh 00031 parameter (NVPERE = 4) ! # vertices per element 00032 ! ents, verts will be arrays storing vertex/entity handles 00033 iBase_EntityHandle, pointer :: ents(:), verts(:) 00034 iBase_EntitySetHandle root_set, root_set2, new_set 00035 TYPE(C_PTR) :: vertsPtr, entsPtr 00036 ! storage for vertex positions, element connectivity indices, global vertex ids 00037 real*8 coords(0:3*NUMV-1) 00038 integer iconn(0:4*NUME-1), gids(0:NUMV-1) 00039 ! 00040 ! local variables 00041 integer lgids(0:NUMV-1), lconn(0:4*NUME-1) 00042 real*8 lcoords(0:3*NUMV-1) 00043 integer lnumv, lvids(0:NUMV-1), gvids(0:NUMV-1) 00044 integer lvpe, ltp ! lvpe = # vertices per entity, ltp = element type 00045 integer ic, ie, iv, istart, iend, ierr, indv, lnume, rank, sz 00046 integer iv2, ie2 ! after loading 00047 00048 ! local variables for parallel runs; index2 for second imesh instance, used for loading from file 00049 iMeshP_PartitionHandle imeshp, imeshp2 00050 iMeshP_PartHandle part, part2 00051 IBASE_HANDLE_T mpi_comm_c 00052 ! integer MPI_COMM_WORLD 00053 00054 00055 ! vertex positions, cube; side 2 00056 ! (first index varying fastest) 00057 data coords / & 00058 -1., -1., -1, 1., -1., -1., 1., 1., -1., -1., 1., -1., & 00059 -1., -1., 1, 1., -1., 1., 1., 1., 1., -1., 1., 1. / 00060 00061 ! quad index numbering, each quad ccw, sides then bottom then top 00062 data iconn / & 00063 0, 1, 5, 4, & 00064 1, 2, 6, 5, & 00065 2, 3, 7, 6, & 00066 3, 0, 4, 7, & 00067 0, 3, 2, 1, & 00068 4, 5, 6, 7 / 00069 00070 data lvpe /4/ ! quads in this example 00071 data ltp / iMesh_QUADRILATERAL / ! from iBase_f.h 00072 00073 ! initialize global vertex ids 00074 do iv = 0, NUMV-1 00075 lgids(iv) = iv+1 00076 end do 00077 00078 ! init the parallel partition 00079 call MPI_INIT(ierr) 00080 call MPI_COMM_SIZE(MPI_COMM_WORLD, sz, ierr) 00081 call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr) 00082 ERROR(ierr) 00083 ! compute starting/ending element numbers 00084 lnume = NUME / sz 00085 istart = rank * lnume 00086 iend = istart + lnume - 1 00087 if (rank .eq. sz-1) then 00088 iend = NUME-1 00089 lnume = iend - istart + 1 00090 endif 00091 00092 ! for my elements, figure out which vertices I use and accumulate local indices and coords 00093 ! lvids stores the local 0-based index for each vertex; -1 means vertex i isn't used locally 00094 ! also build up connectivity indices for local elements, in lconn 00095 do iv = 0, NUMV-1 00096 lvids(iv) = -1 00097 end do 00098 lnumv = -1 00099 do ie = istart, iend 00100 do iv = 0, lvpe-1 00101 indv = iconn(lvpe*ie + iv) 00102 if (lvids(indv) .eq. -1) then 00103 lnumv = lnumv + 1 ! increment local # verts 00104 do ic = 0, 2 ! cache local coords 00105 lcoords(3*lnumv+ic) = coords(3*indv+ic) 00106 end do 00107 lvids(indv) = lnumv 00108 gvids(lnumv) = 1+indv 00109 end if 00110 lconn(lvpe*(ie-istart)+iv) = lvids(indv) 00111 end do ! do iv 00112 end do ! do ie 00113 00114 lnumv = lnumv + 1 00115 00116 ! now create the mesh; this also initializes parallel sharing and ghost exchange 00117 imesh = 0 00118 imeshp = 0 00119 call create_mesh(imesh, imeshp, part, MPI_COMM_WORLD, lnumv, lnume, gvids, lvpe, ltp, lcoords, lconn, & 00120 vertsPtr, entsPtr, ierr) 00121 ERROR(ierr) 00122 call c_f_pointer(vertsPtr, verts, [lnumv]) 00123 call c_f_pointer(entsPtr, ents, [lnume]) 00124 00125 ! this will save the mesh in parallel 00126 call iMeshP_saveAll(%VAL(imesh), %VAL(imeshp), %VAL(part), "test2.h5m", " moab:PARALLEL=WRITE_PART ", ierr) 00127 ERROR(ierr) 00128 call iMesh_getRootSet(%VAL(imesh), root_set, ierr) 00129 ERROR(ierr) 00130 call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_VERTEX), iv, ierr) 00131 ERROR(ierr) 00132 call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_FACE), ie, ierr) 00133 ERROR(ierr) 00134 00135 ! load the saved mesh in a new instance, in parallel 00136 call iMesh_newMesh("MOAB", imesh2, ierr) 00137 ERROR(ierr) 00138 call iMesh_getRootSet(%VAL(imesh2), root_set2, ierr) 00139 ERROR(ierr) 00140 call iMeshP_getCommunicator(%VAL(imesh2), MPI_COMM_WORLD, mpi_comm_c, ierr) 00141 ERROR(ierr) 00142 call iMeshP_createPartitionAll(%VAL(imesh2), %VAL(mpi_comm_c), imeshp2, ierr) 00143 ERROR(ierr) 00144 call iMeshP_createPart(%VAL(imesh2), %VAL(imeshp2), part2, ierr) 00145 ERROR(ierr) 00146 iv2 = 0 00147 ie2 = 0 00148 ! see if load works in a new file set 00149 call iMesh_createEntSet(%VAL(imesh2), %VAL(0), new_set, ierr) 00150 ERROR(ierr) 00151 call iMeshP_loadAll( %VAL(imesh2), %VAL(imeshp2), %VAL(new_set), "test2.h5m", & 00152 " moab:PARALLEL=READ_PART moab:PARALLEL_RESOLVE_SHARED_ENTS moab:PARTITION=PARALLEL_PARTITION ", & 00153 ierr) 00154 ERROR(ierr) 00155 00156 call iMeshP_getNumOfTypeAll(%VAL(imesh2), %VAL(imeshp2), %VAL(root_set2), %VAL(iBase_VERTEX), iv2, ierr) 00157 ERROR(ierr) 00158 call iMeshP_getNumOfTypeAll(%VAL(imesh2), %VAL(imeshp2), %VAL(root_set2), %VAL(iBase_FACE), ie2, ierr) 00159 ERROR(ierr) 00160 00161 if ( (iv.ne.iv2 ) .or. (ie.ne.ie2) ) then 00162 write(0, *) "inconsistent number of elements and vertices" 00163 write(0, *) " saved: " , iv, ie, " loaded: " , iv2, ie2 00164 call exit(1) 00165 endif 00166 00167 call iMesh_dtor(%VAL(imesh), ierr); 00168 ERROR(ierr); 00169 call iMesh_dtor(%VAL(imesh2), ierr); 00170 ERROR(ierr); 00171 00172 call MPI_FINALIZE(ierr) 00173 stop 00174 end program imeshp_test 00175 00176 subroutine create_mesh( & 00177 ! interfaces 00178 imesh, imeshp, part, & 00179 ! input 00180 comm, numv, nume, vgids, nvpe, tp, posn, iconn, & 00181 ! output 00182 vertsPtr, entsPtr, ierr) 00183 ! 00184 ! create a mesh with numv vertices and nume elements, with elements of type tp 00185 ! vertices have positions in posn (3 coordinates each, interleaved xyzxyz...), indexed from 0 00186 ! elements have nvpe vertices per entity, with connectivity indices stored in iconn, referencing 00187 ! vertices using 0-based indices; vertex and entity handles are output in arrays passed in 00188 ! 00189 ! if imesh/imeshp are 0, imesh/imeshp are initialized in this subroutine 00190 ! 00191 00192 use ISO_C_BINDING 00193 implicit none 00194 00195 #ifdef MOAB_HAVE_MPI 00196 # include "iMeshP_f.h" 00197 # include "mpif.h" 00198 #else 00199 # include "iMesh_f.h" 00200 #endif 00201 00202 ! subroutine arguments 00203 iMesh_Instance imesh 00204 TYPE(C_PTR) :: vertsPtr, entsPtr 00205 integer numv, nume, nvpe, vgids(0:*), iconn(0:*), ierr, tp 00206 real*8 posn(0:*) 00207 00208 iMeshP_PartitionHandle imeshp 00209 integer comm 00210 00211 00212 ! local variables 00213 integer comm_sz, comm_rank, numa, numo, iv, ie 00214 TYPE(C_PTR) :: statsPtr 00215 integer, allocatable, target :: stats(:) 00216 iBase_TagHandle tagh 00217 integer i 00218 iBase_EntityHandle, pointer :: verts(:), ents(:) 00219 iBase_EntityHandle, allocatable :: conn(:) 00220 iBase_EntitySetHandle root_set 00221 iBase_EntitySetHandle file_set 00222 00223 IBASE_HANDLE_T mpi_comm_c 00224 TYPE(C_PTR) :: partsPtr 00225 iMeshP_PartHandle, pointer :: parts(:) 00226 iMeshP_PartHandle part 00227 integer partsa, partso 00228 character (len=10) filename 00229 00230 ! create the Mesh instance 00231 if (imesh .eq. 0) then 00232 call iMesh_newMesh("MOAB", imesh, ierr) 00233 end if 00234 00235 00236 if (imeshp .eq. 0) then 00237 call iMeshP_getCommunicator(%VAL(imesh), MPI_COMM_WORLD, mpi_comm_c, ierr) 00238 ERROR(ierr) 00239 call iMeshP_createPartitionAll(%VAL(imesh), %VAL(mpi_comm_c), imeshp, ierr) 00240 ERROR(ierr) 00241 call iMeshP_createPart(%VAL(imesh), %VAL(imeshp), part, ierr) 00242 ERROR(ierr) 00243 else 00244 partsa = 0 00245 call iMeshP_getLocalParts(%VAL(imesh), %VAL(imeshp), partsPtr, partsa, partso, ierr) 00246 ERROR(ierr) 00247 call c_f_pointer(partsPtr, parts, [partso]) 00248 part = parts(1) 00249 end if 00250 call MPI_COMM_RANK(comm, comm_rank, ierr) 00251 ERROR(ierr) 00252 call MPI_COMM_SIZE(comm, comm_sz, ierr) 00253 ERROR(ierr) 00254 00255 ! create the vertices, all in one call 00256 numa = 0 00257 call iMesh_createVtxArr(%VAL(imesh), %VAL(numv), %VAL(iBase_INTERLEAVED), posn, %VAL(3*numv), & 00258 vertsPtr, numa, numo, ierr) 00259 ERROR(ierr) 00260 00261 ! fill in the connectivity array, based on indexing from iconn 00262 allocate (conn(0:nvpe*nume-1)) 00263 call c_f_pointer(vertsPtr, verts, [numv]) 00264 do i = 0, nvpe*nume-1 00265 conn(i) = verts(1+iconn(i)) 00266 end do 00267 ! create the elements 00268 numa = 0 00269 allocate(stats(0:nume-1)) 00270 statsPtr = C_LOC(stats(0)) 00271 call iMesh_createEntArr(%VAL(imesh), %VAL(tp), conn, %VAL(nvpe*nume), & 00272 entsPtr, numa, numo, statsPtr, numa, numo, ierr) 00273 deallocate(stats) 00274 deallocate(conn) 00275 00276 ! take care of parallel stuff 00277 00278 ! add entities to part, using iMesh 00279 call c_f_pointer(entsPtr, ents, [numo]) 00280 call iMesh_addEntArrToSet(%VAL(imesh), ents, %VAL(numo), %VAL(part), ierr) 00281 ERROR(ierr) 00282 ! set global ids on vertices, needed for sharing between procs 00283 call iMesh_getTagHandle(%VAL(imesh), "GLOBAL_ID", tagh, ierr, %VAL(9)) 00284 if (iBase_SUCCESS .ne. ierr) then 00285 ! didn't get handle, need to create the tag 00286 call iMesh_createTag(%VAL(imesh), "GLOBAL_ID", %VAL(iBase_INTEGER), tagh, ierr) 00287 ERROR(ierr) 00288 end if 00289 call iMesh_setIntArrData(%VAL(imesh), verts, %VAL(numv), %VAL(tagh), vgids, %VAL(numv), ierr) 00290 ERROR(ierr) 00291 ! now resolve shared verts and exchange ghost cells 00292 call iMeshP_syncMeshAll(%VAL(imesh), %VAL(imeshp), ierr) 00293 ERROR(ierr) 00294 00295 call iMeshP_createGhostEntsAll(%VAL(imesh), %VAL(imeshp), %VAL(2), %VAL(1), %VAL(1), %VAL(0), ierr) 00296 ERROR(ierr) 00297 00298 call iMesh_freeMemory(%VAL(imesh), vertsPtr); 00299 call iMesh_freeMemory(%VAL(imesh), entsPtr); 00300 00301 return 00302 end subroutine create_mesh
