MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/MOABConfig.h" 00002 #include "FBiGeom.h" 00003 #include "iMesh.h" 00004 #include "iRel.h" 00005 00006 #include <cstdio> 00007 #include <cstdlib> 00008 #include <cstring> 00009 00010 #define DEFAULT_TEST_FILE shell.h5m 00011 #define DEFAULT_TEST_FILE1 shellQuad.h5m 00012 00013 // clang-format off 00014 00015 #define STRINGIFY_( X ) #X 00016 #define STRINGIFY( X ) STRINGIFY_( X ) 00017 #if defined( MESHDIR ) && defined( MOAB_HAVE_HDF5 ) 00018 #define DEFAULT_INPUT_FILE STRINGIFY( MESHDIR/fbigeom/DEFAULT_TEST_FILE ) 00019 #define DEFAULT_INPUT_FILE1 STRINGIFY( MESHDIR/fbigeom/DEFAULT_TEST_FILE1 ) 00020 #else 00021 #error Specify MESHDIR to compile test 00022 #endif 00023 00024 #define CHECK_SIZE_C( type, array, allocated_size, size ) \ 00025 if( NULL == *(array) || *(allocated_size) == 0 ) \ 00026 { \ 00027 *(array) = (type*)malloc( sizeof( type ) * (size) ); \ 00028 *(allocated_size) = size; \ 00029 } \ 00030 else if( *(allocated_size) < (size) ) \ 00031 { \ 00032 printf( " Array passed in is non-zero but too short.\n" ); \ 00033 } 00034 00035 // clang-format on 00036 00037 typedef void* iRel_EntityHandle; 00038 00039 /*! 00040 prints out a result string based on the value of error_code 00041 */ 00042 void handle_error_code( const int result, int* number_failed, int* number_not_implemented, int* number_successful ) 00043 { 00044 if( result ) 00045 { 00046 printf( "Success" ); 00047 ( *number_successful )++; 00048 } 00049 else 00050 { 00051 printf( "Failure" ); 00052 ( *number_failed )++; 00053 } 00054 } 00055 00056 int print_geom_info( FBiGeom_Instance geom, iBase_EntityHandle gent ) 00057 { 00058 /* print information about this entity */ 00059 int ent_type; 00060 int result; 00061 const char* type_names[] = { "Vertex", "Edge", "Face", "Region" }; 00062 00063 FBiGeom_getEntType( geom, gent, &ent_type, &result ); 00064 00065 if( iBase_SUCCESS != result ) 00066 { 00067 printf( "Trouble getting entity adjacencies or types." ); 00068 return 0; 00069 } 00070 00071 printf( "%s 0x%lx\n", type_names[ent_type], (unsigned long)gent ); 00072 00073 return 1; 00074 } 00075 00076 int print_mesh_info( iMesh_Instance mesh, iBase_EntityHandle ment ) 00077 { 00078 /* print information about this entity */ 00079 00080 /* get adjacencies first; assume not more than 50 */ 00081 iBase_EntityHandle adj_ents[50], *adj_ents_ptr = adj_ents; 00082 int ent_types[50], *ent_types_ptr = ent_types; 00083 int adj_ents_alloc = 50, adj_ents_size, ent_types_size, ent_types_allocated = 50; 00084 int result; 00085 iBase_TagHandle* ment_tags = NULL; 00086 int ment_tags_size, ment_tags_alloc; 00087 char** tag_names; 00088 int i; 00089 const char* type_names[] = { "Vertex", "Edge", "Face", "Region" }; 00090 int tag_type; 00091 00092 char* dum_handle = NULL; 00093 int dum_handle_alloc = 0, dum_handle_size = 0; 00094 int int_data; 00095 double dbl_data; 00096 iBase_EntityHandle eh_data; 00097 00098 iMesh_getEntAdj( mesh, ment, iBase_ALL_TYPES, &adj_ents_ptr, &adj_ents_alloc, &adj_ents_size, &result ); 00099 00100 if( iBase_SUCCESS != result ) return 0; 00101 00102 /* put this ent on the end, then get types */ 00103 adj_ents[adj_ents_size] = ment; 00104 iMesh_getEntArrType( mesh, adj_ents, adj_ents_size + 1, &ent_types_ptr, &ent_types_allocated, &ent_types_size, 00105 &result ); 00106 if( iBase_SUCCESS != result ) 00107 { 00108 printf( "Trouble getting entity adjacencies or types." ); 00109 return 0; 00110 } 00111 00112 /* get tags on ment */ 00113 iMesh_getAllTags( mesh, ment, &ment_tags, &ment_tags_alloc, &ment_tags_size, &result ); 00114 00115 printf( "Trouble getting tags on an entity or their names." ); 00116 00117 /* while we're at it, get all the tag names */ 00118 00119 tag_names = (char**)malloc( ment_tags_size * sizeof( char* ) ); 00120 00121 for( i = 0; i < ment_tags_size; i++ ) 00122 { 00123 tag_names[i] = (char*)malloc( 120 * sizeof( char ) ); 00124 iMesh_getTagName( mesh, ment_tags[i], tag_names[i], &result, 120 ); 00125 } 00126 00127 /* now print the information */ 00128 printf( "%s %ld:\n", type_names[ent_types[ent_types_size - 1]], (long)ment ); 00129 printf( "Adjacencies:" ); 00130 for( i = 0; i < adj_ents_size; i++ ) 00131 { 00132 if( i > 0 ) printf( ", " ); 00133 printf( "%s %ld", type_names[ent_types[i]], (long)adj_ents[i] ); 00134 } 00135 printf( "\nTags: \n" ); 00136 for( i = 0; i < ment_tags_size; i++ ) 00137 { 00138 printf( "%s ", tag_names[i] ); 00139 iMesh_getTagType( mesh, ment_tags[i], &tag_type, &result ); 00140 if( iBase_SUCCESS != result ) 00141 printf( "(trouble getting type...)\n" ); 00142 else 00143 { 00144 dum_handle = NULL; 00145 dum_handle_alloc = 0, dum_handle_size = 0; 00146 00147 switch( tag_type ) 00148 { 00149 case iBase_INTEGER: 00150 iMesh_getIntData( mesh, ment, ment_tags[i], &int_data, &result ); 00151 printf( "(Int value=%d)", int_data ); 00152 break; 00153 case iBase_DOUBLE: 00154 iMesh_getDblData( mesh, ment, ment_tags[i], &dbl_data, &result ); 00155 printf( "(Dbl value=%f)", dbl_data ); 00156 break; 00157 case iBase_ENTITY_HANDLE: 00158 iMesh_getEHData( mesh, ment, ment_tags[i], &eh_data, &result ); 00159 printf( "(EH value=%ld)", (long)eh_data ); 00160 break; 00161 case iBase_BYTES: 00162 iMesh_getData( mesh, ment, ment_tags[i], (void**)&dum_handle, &dum_handle_alloc, &dum_handle_size, 00163 &result ); 00164 if( NULL != dum_handle && dum_handle_size > 0 ) printf( "(Opaque value=%c)", dum_handle[0] ); 00165 break; 00166 } 00167 } 00168 00169 printf( "\n" ); 00170 } 00171 printf( "(end tags)\n\n" ); 00172 free( ment_tags ); 00173 return 1; 00174 } 00175 00176 /*! 00177 @test 00178 Load Mesh 00179 @li Load a geom and a mesh file 00180 */ 00181 int load_geom_mesh_test( const char* geom_filename, 00182 const char* mesh_filename, 00183 FBiGeom_Instance geom, 00184 iMesh_Instance mesh ) 00185 { 00186 /* load a geom */ 00187 int result; 00188 FBiGeom_load( geom, geom_filename, 0, &result, strlen( geom_filename ), 0 ); 00189 if( iBase_SUCCESS != result ) 00190 { 00191 printf( "ERROR : can not load a geometry\n" ); 00192 return 0; 00193 } 00194 00195 /* load a mesh */ 00196 iMesh_load( mesh, 0, mesh_filename, 0, &result, strlen( mesh_filename ), 0 ); 00197 if( iBase_SUCCESS != result ) 00198 { 00199 printf( "ERROR : can not load a mesh\n" ); 00200 return 0; 00201 } 00202 00203 return 1; 00204 } 00205 00206 /*! 00207 @test 00208 TSTTLasso create relation Test 00209 @li Create relation between geom and mesh 00210 */ 00211 int create_relation_test( iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle* pair ) 00212 { 00213 int result; 00214 00215 iBase_Instance iface1, iface2; 00216 int type1, type2; 00217 int ent_or_set1, ent_or_set2; 00218 int status1, status2; 00219 00220 iRel_PairHandle tmp_pair; 00221 iRel_PairHandle* pair_ptr = &tmp_pair; 00222 int pairs_alloc = 1, pairs_size; 00223 00224 /* create an relation, entity to set */ 00225 iRel_createPair( assoc, geom, iRel_ENTITY, iRel_FBIGEOM_IFACE, iRel_ACTIVE, mesh, iRel_SET, iRel_IMESH_IFACE, 00226 iRel_ACTIVE, pair, &result ); 00227 if( iBase_SUCCESS != result ) 00228 { 00229 printf( "Couldn't create a new relation.\n" ); 00230 return 0; 00231 } 00232 00233 iRel_getPairInfo( assoc, *pair, &iface1, &ent_or_set1, &type1, &status1, &iface2, &ent_or_set2, &type2, &status2, 00234 &result ); 00235 if( iBase_SUCCESS != result ) 00236 { 00237 printf( "Couldn't retrieve relation info.\n" ); 00238 return 0; 00239 } 00240 if( iface1 != geom || ent_or_set1 != iRel_ENTITY || type1 != iRel_FBIGEOM_IFACE || iface2 != mesh || 00241 ent_or_set2 != iRel_SET || type2 != iRel_IMESH_IFACE ) 00242 { 00243 printf( "Unexpected relation info returned.\n" ); 00244 return 0; 00245 } 00246 00247 iRel_findPairs( assoc, geom, &pair_ptr, &pairs_alloc, &pairs_size, &result ); 00248 if( iBase_SUCCESS != result ) 00249 { 00250 printf( "Couldn't find relation pair when querying geom.\n" ); 00251 return 0; 00252 } 00253 if( pairs_size != 1 || tmp_pair != *pair ) 00254 { 00255 printf( "Unexpected relation pairs returned when querying geom.\n" ); 00256 return 0; 00257 } 00258 00259 iRel_findPairs( assoc, mesh, &pair_ptr, &pairs_alloc, &pairs_size, &result ); 00260 if( iBase_SUCCESS != result ) 00261 { 00262 printf( "Couldn't find relation pair when querying mesh.\n" ); 00263 return 0; 00264 } 00265 if( pairs_size != 1 || tmp_pair != *pair ) 00266 { 00267 printf( "Unexpected relation pairs returned when querying mesh.\n" ); 00268 return 0; 00269 } 00270 00271 return 1; 00272 } 00273 00274 /*! 00275 @test 00276 TSTTLasso relate geom and mesh Test 00277 @li Check relation between geom and mesh 00278 */ 00279 int relate_geom_mesh_test( iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair ) 00280 { 00281 /* relate geometry entities with coresponding mesh entity sets */ 00282 iBase_EntityHandle* gentities = NULL; 00283 int gentities_size = 0, gentities_alloc = 0; 00284 int result; 00285 00286 iBase_EntitySetHandle* mentity_handles = NULL; 00287 int mentity_handles_size = 0, mentity_handles_alloc = 0; 00288 00289 const char* dim_tag_name = "GEOM_DIMENSION"; 00290 iBase_TagHandle dim_tag_mesh; 00291 00292 iBase_EntitySetHandle* mentities_vec; 00293 int mentities_vec_size; 00294 int i; 00295 00296 iBase_EntitySetHandle* out_mentities = NULL; 00297 int out_mentities_size = 0, out_mentities_alloc = 0; 00298 00299 iBase_EntitySetHandle* out_mentities2 = NULL; 00300 int out_mentities2_size = 0, out_mentities2_alloc = 0; 00301 00302 iBase_EntityHandle* out_gentities = NULL; 00303 int out_gentities_size = 0, out_gentities_alloc = 0; 00304 00305 FBiGeom_getEntities( geom, NULL, iBase_VERTEX, &gentities, &gentities_alloc, &gentities_size, &result ); 00306 if( iBase_SUCCESS != result ) 00307 { 00308 printf( "Failed to get gentities by type in relate_geom_mesh_test.\n" ); 00309 return 0; 00310 } 00311 00312 iRel_inferEntArrRelations( assoc, pair, gentities, gentities_size, 0, &result ); 00313 if( iBase_SUCCESS != result ) 00314 { 00315 printf( "Failed to relate geom entities in relate_geom_mesh_test.\n" ); 00316 return 0; 00317 } 00318 00319 /* relate coresponding mesh entity sets for geometry entities */ 00320 /* get 1-dimensional mesh entitysets */ 00321 00322 iMesh_getEntSets( mesh, NULL, 1, &mentity_handles, &mentity_handles_alloc, &mentity_handles_size, &result ); 00323 if( iBase_SUCCESS != result ) 00324 { 00325 printf( "Problem to get all entity sets.\n" ); 00326 return 0; 00327 } 00328 00329 /* get geom dimension tags for mesh entitysets */ 00330 iMesh_createTag( mesh, dim_tag_name, 1, iBase_INTEGER, &dim_tag_mesh, &result, 15 ); 00331 if( iBase_SUCCESS != result && result != iBase_TAG_ALREADY_EXISTS ) 00332 { 00333 printf( "Couldn't create geom dim tag for mesh entities.\n" ); 00334 return 0; 00335 } 00336 00337 /* get 1-dimensional mesh entitysets */ 00338 mentities_vec = (iBase_EntitySetHandle*)malloc( mentity_handles_size * sizeof( iBase_EntitySetHandle ) ); 00339 mentities_vec_size = 0; 00340 00341 for( i = 0; i < mentity_handles_size; i++ ) 00342 { 00343 int dim; 00344 iMesh_getEntSetIntData( mesh, mentity_handles[i], dim_tag_mesh, &dim, &result ); 00345 if( iBase_SUCCESS != result ) continue; 00346 00347 if( dim == 1 ) mentities_vec[mentities_vec_size++] = mentity_handles[i]; 00348 } 00349 00350 iRel_inferSetArrRelations( assoc, pair, mentities_vec, mentities_vec_size, 1, &result ); 00351 if( iBase_SUCCESS != result ) 00352 { 00353 printf( "Failed to relate mesh entities in relate_geom_mesh_test.\n" ); 00354 return 0; 00355 } 00356 00357 /* relate all geometry and mesh entities */ 00358 iRel_inferAllRelations( assoc, pair, &result ); 00359 if( iBase_SUCCESS != result ) 00360 { 00361 printf( "Failed to relate all geom and mesh entities in relate_geom_mesh_test.\n" ); 00362 return 0; 00363 } 00364 00365 /* reset geom entities list and get all geom entities (prev 00366 only vertices) */ 00367 free( gentities ); 00368 gentities = NULL; 00369 gentities_alloc = 0; 00370 FBiGeom_getEntities( geom, NULL, iBase_ALL_TYPES, &gentities, &gentities_alloc, &gentities_size, &result ); 00371 if( iBase_SUCCESS != result ) 00372 { 00373 printf( "Failed to get gentities by type in relate_geom_mesh_test.\n" ); 00374 return 0; 00375 } 00376 00377 /* get related mesh entity sets for geometry entities */ 00378 iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc, 00379 &out_mentities_size, &result ); 00380 if( iBase_SUCCESS != result ) 00381 { 00382 printf( "Failed to get geom entities in relate_geom_mesh_test.\n" ); 00383 return 0; 00384 } 00385 00386 if( out_mentities_size != gentities_size ) 00387 { 00388 printf( "Number of input geom entities and output mesh entity sets should be same\n" ); 00389 return 0; 00390 } 00391 00392 /* now try deleting this relation */ 00393 iRel_rmvEntArrRelation( assoc, pair, gentities, gentities_size, 0, &result ); 00394 if( iBase_SUCCESS != result ) 00395 { 00396 printf( "Failed to remove relation in relate_geom_mesh_test.\n" ); 00397 return 0; 00398 } 00399 iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities2, &out_mentities2_alloc, 00400 &out_mentities2_size, &result ); 00401 if( iBase_SUCCESS == result ) 00402 { 00403 printf( "Shouldn't have gotten mesh sets in relate_geom_mesh_test.\n" ); 00404 return 0; 00405 } 00406 00407 /* restore the relation, since we need it later */ 00408 iRel_setEntArrSetArrRelation( assoc, pair, gentities, gentities_size, out_mentities, out_mentities_size, &result ); 00409 if( iBase_SUCCESS != result ) 00410 { 00411 printf( "Failed to restore relation in relate_geom_mesh_test.\n" ); 00412 return 0; 00413 } 00414 00415 /* get related geometry entities for mesh entity sets */ 00416 iRel_getSetArrEntArrRelation( assoc, pair, out_mentities, out_mentities_size, 1, &out_gentities, 00417 &out_gentities_alloc, &out_gentities_size, &result ); 00418 if( iBase_SUCCESS != result ) 00419 { 00420 printf( "Failed to get mesh entities in relate_geom_mesh_test.\n" ); 00421 return 0; 00422 } 00423 00424 if( out_mentities_size != out_gentities_size ) 00425 { 00426 printf( "Number of input mesh entity sets and output geom entities should be same\n" ); 00427 return 0; 00428 } 00429 free( mentity_handles ); 00430 mentity_handles = NULL; 00431 free( gentities ); 00432 gentities = NULL; 00433 free( mentity_handles ); 00434 mentity_handles = NULL; 00435 free( out_mentities ); 00436 out_mentities = NULL; 00437 free( mentities_vec ); 00438 mentities_vec = NULL; 00439 free( out_gentities ); 00440 out_gentities = NULL; 00441 return 1; 00442 } 00443 00444 /*! 00445 @test 00446 TSTTAssoc move to test 00447 @li Move meshes onto the given geometry 00448 */ 00449 int query_relations_test( iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair ) 00450 { 00451 /* get all the geom entities, and find relation to some mesh entity */ 00452 iBase_EntityHandle* gentities = NULL; 00453 int gentities_size = 0, gentities_alloc = 0; 00454 int result; 00455 00456 iBase_EntitySetHandle* out_mentities = NULL; 00457 int out_mentities_size, out_mentities_alloc = 0; 00458 00459 char descr[120]; 00460 int i; 00461 int is_list; 00462 00463 iBase_EntityHandle* out_gentities = NULL; 00464 int out_gentities_size, out_gentities_alloc = 0; 00465 00466 FBiGeom_getEntities( geom, NULL, iBase_ALL_TYPES, &gentities, &gentities_alloc, &gentities_size, &result ); 00467 if( iBase_SUCCESS != result ) 00468 { 00469 printf( "Problem getting all geom entities.\n" ); 00470 return 0; 00471 } 00472 00473 iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc, 00474 &out_mentities_size, &result ); 00475 /* might not all be */ 00476 if( iBase_SUCCESS != result ) 00477 { 00478 printf( "Failed to get mesh entities related to geom entities in query_relations_test.\n" ); 00479 00480 iRel_getDescription( assoc, descr, sizeof( descr ) - 1 ); 00481 printf( "Entities missing relations: %s\n", descr ); 00482 00483 for( i = 0; i < gentities_size; i++ ) 00484 { 00485 print_geom_info( geom, gentities[i] ); 00486 } 00487 00488 return 0; 00489 } 00490 00491 /* check that they're all non-null */ 00492 if( out_mentities_size != gentities_size ) 00493 { 00494 printf( "Number of mesh & related geom entities don't match.\n" ); 00495 return 0; 00496 } 00497 00498 /* check to make sure they're mesh sets; how to do that? */ 00499 for( i = 0; i < out_mentities_size; i++ ) 00500 { 00501 iMesh_isList( mesh, (iBase_EntitySetHandle)out_mentities[i], &is_list, &result ); 00502 if( iBase_SUCCESS != result ) 00503 { 00504 printf( "Entity set returned from classification wasn't valid.\n" ); 00505 return 0; 00506 } 00507 } 00508 00509 /* now turn around and check classification of those mesh entities */ 00510 iRel_getSetArrEntArrRelation( assoc, pair, out_mentities, out_mentities_size, 1, &out_gentities, 00511 &out_gentities_alloc, &out_gentities_size, &result ); 00512 if( iBase_SUCCESS != result ) 00513 { 00514 printf( "Failed to get geom entities related to mesh entities in query_relations_test.\n" ); 00515 return 0; 00516 } 00517 00518 /* check that they're all non-null */ 00519 if( out_mentities_size != out_gentities_size ) 00520 { 00521 printf( "Number of geom & related mesh entities don't match.\n" ); 00522 return 0; 00523 } 00524 00525 free( gentities ); 00526 gentities = NULL; 00527 free( out_mentities ); 00528 out_mentities = NULL; 00529 free( out_gentities ); 00530 out_gentities = NULL; 00531 /* ok, we're done */ 00532 return 1; 00533 } 00534 00535 int main( int argc, char* argv[] ) 00536 { 00537 /* Check command line arg */ 00538 const char* geom_filename = DEFAULT_INPUT_FILE; 00539 const char* mesh_filename = DEFAULT_INPUT_FILE1; 00540 00541 int result; 00542 int number_tests = 0; 00543 int number_tests_successful = 0; 00544 int number_tests_not_implemented = 0; 00545 int number_tests_failed = 0; 00546 00547 FBiGeom_Instance geom; 00548 iMesh_Instance mesh; 00549 iRel_Instance assoc; 00550 iRel_PairHandle pair; 00551 00552 if( argc == 2 && !strcmp( argv[1], "-h" ) ) 00553 { 00554 printf( "Usage: %s <geom_filename> <mesh_filename>\n", argv[0] ); 00555 return 1; 00556 } 00557 else if( argc == 2 ) 00558 { 00559 geom_filename = argv[1]; 00560 mesh_filename = argv[1]; 00561 } 00562 else if( argc == 3 ) 00563 { 00564 geom_filename = argv[1]; 00565 mesh_filename = argv[2]; 00566 } 00567 00568 /* initialize the Geometry */ 00569 FBiGeom_newGeom( 0, &geom, &result, 0 ); 00570 00571 /* initialize the Mesh */ 00572 iMesh_newMesh( 0, &mesh, &result, 0 ); 00573 00574 /* initialize the Associate */ 00575 iRel_create( 0, &assoc, &result, 0 ); 00576 00577 /* Print out Header information */ 00578 printf( "\n\niRel TEST PROGRAM:\n\n" ); 00579 00580 /* load_geom_mesh test */ 00581 printf( " load_geom_mesh: " ); 00582 result = load_geom_mesh_test( geom_filename, mesh_filename, geom, mesh ); 00583 handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful ); 00584 number_tests++; 00585 printf( "\n" ); 00586 00587 /* create_relation test */ 00588 printf( " create_relation: " ); 00589 result = create_relation_test( assoc, geom, mesh, &pair ); 00590 handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful ); 00591 number_tests++; 00592 printf( "\n" ); 00593 00594 /* relate_geom_mesh test */ 00595 printf( " relate_geom_mesh: " ); 00596 result = relate_geom_mesh_test( assoc, geom, mesh, pair ); 00597 handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful ); 00598 number_tests++; 00599 printf( "\n" ); 00600 00601 /* query_relations test */ 00602 printf( " query_relations: " ); 00603 result = query_relations_test( assoc, geom, mesh, pair ); 00604 handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful ); 00605 number_tests++; 00606 printf( "\n" ); 00607 00608 /* summary */ 00609 00610 printf( "\niRel TEST SUMMARY: \n" ); 00611 printf( " Number Tests: %d\n", number_tests ); 00612 printf( " Number Successful: %d\n", number_tests_successful ); 00613 printf( " Number Not Implemented: %d\n", number_tests_not_implemented ); 00614 printf( " Number Failed: %d\n", number_tests_failed ); 00615 printf( "\n\n" ); 00616 00617 iRel_destroy( assoc, &result ); 00618 iMesh_dtor( mesh, &result ); 00619 FBiGeom_dtor( geom, &result ); 00620 00621 return number_tests_failed != 0; 00622 }
