MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 ! PushParMeshIntoMoabF90: push parallel mesh into moab, F90 version 00002 ! 00003 ! This program shows how to push a mesh into MOAB in parallel from Fortran90, with sufficient 00004 ! information to resolve boundary sharing and exchange a layer of ghost information. 00005 ! To successfully link this example, you need to specify FCFLAGS that include: 00006 ! a) -DMOAB_HAVE_MPI, and 00007 ! b) flags required to link Fortran90 MPI programs with the C++ compiler; these flags 00008 ! can often be found on your system by inspecting the output of 'mpif90 -show' 00009 ! For example, using gcc, the link line looks like: 00010 ! make MOAB_DIR=<moab install dir> FCFLAGS="-DMOAB_HAVE_MPI -I/usr/lib/openmpi/include -pthread -I/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl" PushParMeshIntoMoabF90 00011 ! 00012 ! Usage: PushParMeshIntoMoab 00013 #define ERROR(rval) if (0 .ne. rval) call exit(1) 00014 00015 program PushParMeshIntoMoab 00016 00017 use ISO_C_BINDING 00018 implicit none 00019 00020 #include "moab/MOABConfig.h" 00021 #ifdef MOAB_HAVE_MPI 00022 # include "mpif.h" 00023 # include "iMeshP_f.h" 00024 #else 00025 # include "iMesh_f.h" 00026 #endif 00027 00028 ! declarations 00029 ! imesh is the instance handle 00030 iMesh_Instance imesh 00031 ! NUMV, NUME, NVPERE are the hardwired here; these are for the whole mesh, 00032 ! local mesh determined later 00033 integer NUMV, NUME, NVPERE 00034 parameter (NUMV = 8) ! # vertices in whole mesh 00035 parameter (NUME = 6) ! # elements in whole mesh 00036 parameter (NVPERE = 4) ! # vertices per element 00037 ! ents, verts will be arrays storing vertex/entity handles 00038 iBase_EntityHandle, pointer :: ents(:), verts(:) 00039 iBase_EntitySetHandle root_set 00040 TYPE(C_PTR) :: vertsPtr, entsPtr 00041 ! storage for vertex positions, element connectivity indices, global vertex ids 00042 real*8 coords(0:3*NUMV-1) 00043 integer iconn(0:4*NUME-1), gids(0:NUMV-1) 00044 ! 00045 ! local variables 00046 integer lgids(0:NUMV-1), lconn(0:4*NUME-1) 00047 real*8 lcoords(0:3*NUMV-1) 00048 integer lnumv, lvids(0:NUMV-1), gvids(0:NUMV-1) 00049 integer lvpe, ltp ! lvpe = # vertices per entity, ltp = element type 00050 integer ic, ie, iv, istart, iend, ierr, indv, lnume, rank, sz 00051 00052 #ifdef MOAB_HAVE_MPI 00053 ! local variables for parallel runs 00054 iMeshP_PartitionHandle imeshp 00055 ! integer MPI_COMM_WORLD 00056 #endif 00057 00058 ! vertex positions, cube; side 2 00059 ! (first index varying fastest) 00060 data coords / & 00061 -1., -1., -1, 1., -1., -1., 1., 1., -1., -1., 1., -1., & 00062 -1., -1., 1, 1., -1., 1., 1., 1., 1., -1., 1., 1. / 00063 00064 ! quad index numbering, each quad ccw, sides then bottom then top 00065 data iconn / & 00066 0, 1, 5, 4, & 00067 1, 2, 6, 5, & 00068 2, 3, 7, 6, & 00069 3, 0, 4, 7, & 00070 0, 3, 2, 1, & 00071 4, 5, 6, 7 / 00072 00073 data lvpe /4/ ! quads in this example 00074 data ltp / iMesh_QUADRILATERAL / ! from iBase_f.h 00075 00076 ! initialize global vertex ids 00077 do iv = 0, NUMV-1 00078 lgids(iv) = iv+1 00079 end do 00080 00081 #ifdef MOAB_HAVE_MPI 00082 ! init the parallel partition 00083 call MPI_INIT(ierr) 00084 call MPI_COMM_SIZE(MPI_COMM_WORLD, sz, ierr) 00085 call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr) 00086 ERROR(ierr) 00087 ! compute starting/ending element numbers 00088 lnume = NUME / sz 00089 istart = rank * lnume 00090 iend = istart + lnume - 1 00091 if (rank .eq. sz-1) then 00092 iend = NUME-1 00093 lnume = iend - istart + 1 00094 endif 00095 ! for my elements, figure out which vertices I use and accumulate local indices and coords 00096 ! lvids stores the local 0-based index for each vertex; -1 means vertex i isn't used locally 00097 ! also build up connectivity indices for local elements, in lconn 00098 do iv = 0, NUMV-1 00099 lvids(iv) = -1 00100 end do 00101 lnumv = -1 00102 do ie = istart, iend 00103 do iv = 0, lvpe-1 00104 indv = iconn(lvpe*ie + iv) 00105 if (lvids(indv) .eq. -1) then 00106 lnumv = lnumv + 1 ! increment local # verts 00107 do ic = 0, 2 ! cache local coords 00108 lcoords(3*lnumv+ic) = coords(3*indv+ic) 00109 end do 00110 lvids(indv) = lnumv 00111 gvids(lnumv) = 1+indv 00112 end if 00113 lconn(lvpe*(ie-istart)+iv) = lvids(indv) 00114 end do ! do iv 00115 end do ! do ie 00116 00117 lnumv = lnumv + 1 00118 00119 ! now create the mesh; this also initializes parallel sharing and ghost exchange 00120 imesh = 0 00121 imeshp = 0 00122 call create_mesh(imesh, imeshp, MPI_COMM_WORLD, lnumv, lnume, gvids, lvpe, ltp, lcoords, lconn, & 00123 vertsPtr, entsPtr, ierr) 00124 ERROR(ierr) 00125 call c_f_pointer(vertsPtr, verts, [lnumv]) 00126 call c_f_pointer(entsPtr, ents, [lnume]) 00127 00128 ! get/report number of vertices, elements 00129 call iMesh_getRootSet(%VAL(imesh), root_set, ierr) 00130 ERROR(ierr) 00131 iv = 0 00132 ie = 0 00133 call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_VERTEX), iv, ierr) 00134 ERROR(ierr) 00135 call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_FACE), ie, ierr) 00136 ERROR(ierr) 00137 if (rank .eq. 0) then 00138 write(0,*) "Number of vertices = ", iv 00139 write(0,*) "Number of entities = ", ie 00140 endif 00141 00142 ! from here, can use verts and ents as (1-based) arrays of entity handles for input to other iMesh functions 00143 00144 call MPI_FINALIZE(ierr) 00145 #else 00146 write(0, *) "compile with MPI for better experience\n" 00147 #endif 00148 stop 00149 end program PushParMeshIntoMoab 00150 00151 #ifdef MOAB_HAVE_MPI 00152 subroutine create_mesh( & 00153 ! interfaces 00154 imesh, imeshp, & 00155 ! input 00156 comm, numv, nume, vgids, nvpe, tp, posn, iconn, & 00157 ! output 00158 vertsPtr, entsPtr, ierr) 00159 ! 00160 ! create a mesh with numv vertices and nume elements, with elements of type tp 00161 ! vertices have positions in posn (3 coordinates each, interleaved xyzxyz...), indexed from 0 00162 ! elements have nvpe vertices per entity, with connectivity indices stored in iconn, referencing 00163 ! vertices using 0-based indices; vertex and entity handles are output in arrays passed in 00164 ! 00165 ! if imesh/imeshp are 0, imesh/imeshp are initialized in this subroutine 00166 ! 00167 00168 use ISO_C_BINDING 00169 implicit none 00170 00171 # include "iMeshP_f.h" 00172 # include "mpif.h" 00173 00174 ! subroutine arguments 00175 iMesh_Instance imesh 00176 TYPE(C_PTR) :: vertsPtr, entsPtr 00177 integer numv, nume, nvpe, vgids(0:*), iconn(0:*), ierr, tp 00178 real*8 posn(0:*) 00179 #ifdef MOAB_HAVE_MPI 00180 iMeshP_PartitionHandle imeshp 00181 integer comm 00182 #endif 00183 00184 ! local variables 00185 integer comm_sz, comm_rank, numa, numo, iv, ie 00186 TYPE(C_PTR) :: statsPtr 00187 integer, allocatable, target :: stats(:) 00188 iBase_TagHandle tagh 00189 integer i 00190 iBase_EntityHandle, pointer :: verts(:), ents(:) 00191 iBase_EntityHandle, allocatable :: conn(:) 00192 iBase_EntitySetHandle root_set 00193 iBase_EntitySetHandle file_set 00194 #ifdef MOAB_HAVE_MPI 00195 IBASE_HANDLE_T mpi_comm_c 00196 TYPE(C_PTR) :: partsPtr 00197 iMeshP_PartHandle, pointer :: parts(:) 00198 iMeshP_PartHandle part 00199 integer partsa, partso 00200 character (len=10) filename 00201 #endif 00202 00203 ! create the Mesh instance 00204 if (imesh .eq. 0) then 00205 call iMesh_newMesh("MOAB", imesh, ierr) 00206 end if 00207 00208 #ifdef MOAB_HAVE_MPI 00209 if (imeshp .eq. 0) then 00210 call iMeshP_getCommunicator(%VAL(imesh), MPI_COMM_WORLD, mpi_comm_c, ierr) 00211 ERROR(ierr) 00212 call iMeshP_createPartitionAll(%VAL(imesh), %VAL(mpi_comm_c), imeshp, ierr) 00213 ERROR(ierr) 00214 call iMeshP_createPart(%VAL(imesh), %VAL(imeshp), part, ierr) 00215 ERROR(ierr) 00216 else 00217 partsa = 0 00218 call iMeshP_getLocalParts(%VAL(imesh), %VAL(imeshp), partsPtr, partsa, partso, ierr) 00219 ERROR(ierr) 00220 call c_f_pointer(partsPtr, parts, [partso]) 00221 part = parts(1) 00222 end if 00223 call MPI_COMM_RANK(comm, comm_rank, ierr) 00224 ERROR(ierr) 00225 call MPI_COMM_SIZE(comm, comm_sz, ierr) 00226 ERROR(ierr) 00227 #endif 00228 00229 ! create the vertices, all in one call 00230 numa = 0 00231 call iMesh_createVtxArr(%VAL(imesh), %VAL(numv), %VAL(iBase_INTERLEAVED), posn, %VAL(3*numv), & 00232 vertsPtr, numa, numo, ierr) 00233 ERROR(ierr) 00234 00235 ! fill in the connectivity array, based on indexing from iconn 00236 allocate (conn(0:nvpe*nume-1)) 00237 call c_f_pointer(vertsPtr, verts, [numv]) 00238 do i = 0, nvpe*nume-1 00239 conn(i) = verts(1+iconn(i)) 00240 end do 00241 ! create the elements 00242 numa = 0 00243 allocate(stats(0:nume-1)) 00244 statsPtr = C_LOC(stats(0)) 00245 call iMesh_createEntArr(%VAL(imesh), %VAL(tp), conn, %VAL(nvpe*nume), & 00246 entsPtr, numa, numo, statsPtr, numa, numo, ierr) 00247 deallocate(stats) 00248 deallocate(conn) 00249 00250 #ifdef MOAB_HAVE_MPI 00251 ! take care of parallel stuff 00252 00253 ! add entities to part, using iMesh 00254 call c_f_pointer(entsPtr, ents, [numo]) 00255 call iMesh_addEntArrToSet(%VAL(imesh), ents, %VAL(numo), %VAL(part), ierr) 00256 ERROR(ierr) 00257 ! set global ids on vertices, needed for sharing between procs 00258 call iMesh_getTagHandle(%VAL(imesh), "GLOBAL_ID", tagh, ierr, %VAL(9)) 00259 if (iBase_SUCCESS .ne. ierr) then 00260 ! didn't get handle, need to create the tag 00261 call iMesh_createTag(%VAL(imesh), "GLOBAL_ID", %VAL(iBase_INTEGER), tagh, ierr) 00262 ERROR(ierr) 00263 end if 00264 call iMesh_setIntArrData(%VAL(imesh), verts, %VAL(numv), %VAL(tagh), vgids, %VAL(numv), ierr) 00265 ERROR(ierr) 00266 ! now resolve shared verts and exchange ghost cells 00267 call iMeshP_syncMeshAll(%VAL(imesh), %VAL(imeshp), ierr) 00268 ERROR(ierr) 00269 00270 call iMeshP_createGhostEntsAll(%VAL(imesh), %VAL(imeshp), %VAL(2), %VAL(1), %VAL(1), %VAL(0), ierr) 00271 ERROR(ierr) 00272 00273 #endif 00274 00275 return 00276 end subroutine create_mesh 00277 #endif
