MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "iMesh.h" 00002 #include "MBiMesh.hpp" 00003 #include "moab/Core.hpp" 00004 #include "moab/Range.hpp" 00005 #include "moab/IntxMesh/Intx2MeshOnSphere.hpp" 00006 #include "moab/IntxMesh/IntxUtils.hpp" 00007 #include "IntxUtilsCSLAM.hpp" 00008 00009 extern "C" void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle imesh_euler_set, int* ierr ) 00010 { 00011 using namespace moab; 00012 const double radius = 1.; 00013 const double gtol = 1.e-9; 00014 const bool debug = false; 00015 00016 Range ents; 00017 moab::Interface* mb = MOABI; 00018 *ierr = 1; 00019 00020 EntityHandle euler_set = (EntityHandle)imesh_euler_set; 00021 00022 Intx2MeshOnSphere worker( mb ); 00023 worker.set_radius_source_mesh( radius ); 00024 worker.set_radius_destination_mesh( radius ); 00025 worker.set_error_tolerance( gtol ); 00026 00027 EntityHandle covering_lagr_set; 00028 00029 ErrorCode rval = mb->create_meshset( MESHSET_SET, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't create covering set " ); 00030 00031 // we need to update the correlation tag and remote tuples 00032 rval = worker.create_departure_mesh_2nd_alg( euler_set, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't populate covering set " ); 00033 00034 if( debug ) 00035 { 00036 rval = mb->write_file( "lagr.h5m", 0, 0, &covering_lagr_set, 1 );MB_CHK_SET_ERR_RET( rval, "can't write covering set " ); 00037 } 00038 00039 // enforce convexity for the set 00040 rval = moab::IntxUtils::enforce_convexity( mb, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't write covering set " ); 00041 00042 EntityHandle outputSet; 00043 rval = mb->create_meshset( MESHSET_SET, outputSet );MB_CHK_SET_ERR_RET( rval, "can't create output set " ); 00044 00045 rval = worker.intersect_meshes( covering_lagr_set, euler_set, outputSet );MB_CHK_SET_ERR_RET( rval, "can't intersect " ); 00046 00047 if( debug ) 00048 { 00049 rval = mb->write_file( "output.vtk", 0, 0, &outputSet, 1 );MB_CHK_SET_ERR_RET( rval, "can't write covering set " ); 00050 } 00051 00052 // tagElem is the average computed at each element, from nodal values 00053 Tag tagElem = 0; 00054 std::string tag_name2( "TracerAverage" ); 00055 rval = mb->tag_get_handle( tag_name2.c_str(), 1, MB_TYPE_DOUBLE, tagElem, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_RET( rval, "can't get tracer tag " ); 00056 00057 // area of the euler element is fixed, store it; it is used to recompute the averages at each 00058 // time step 00059 Tag tagArea = 0; 00060 std::string tag_name4( "Area" ); 00061 rval = mb->tag_get_handle( tag_name4.c_str(), 1, MB_TYPE_DOUBLE, tagArea, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_RET( rval, "can't get area tag" ); 00062 00063 rval = worker.update_tracer_data( outputSet, tagElem, tagArea );MB_CHK_SET_ERR_RET( rval, "can't update tracer " ); 00064 00065 // everything can be deleted now from intx data; polygons, etc. 00066 00067 *ierr = 0; 00068 return; 00069 }
