MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #include "MBTagConventions.hpp" 00004 #include "moab/CN.hpp" 00005 #include "moab/Range.hpp" 00006 #include "ReadNCDF.hpp" 00007 #include "moab/FileOptions.hpp" 00008 #define IS_BUILDING_MB 00009 #include "ExoIIUtil.hpp" 00010 #include <cmath> 00011 #include <algorithm> 00012 00013 using namespace moab; 00014 00015 /* Input test file: ho_test.g 00016 * 00017 * File is expected to contain at least one block for every 00018 * supported higher-order element type. The coordinates of 00019 * every higher-order node are expected to be the mean of the 00020 * adjacent corner vertices of the element. 00021 */ 00022 #ifdef MESHDIR 00023 static const char ho_file[] = STRINGIFY( MESHDIR ) "/io/ho_test.g"; 00024 static const char file_one[] = STRINGIFY( MESHDIR ) "/mbtest1.g"; 00025 static const char alt_file[] = STRINGIFY( MESHDIR ) "/io/hex_2x2x2_ss.exo"; 00026 static const char polyg[] = STRINGIFY( MESHDIR ) "/io/poly8-10.vtk"; 00027 static const char polyh[] = STRINGIFY( MESHDIR ) "/io/polyhedra.vtk"; 00028 static const char rpolyg[] = STRINGIFY( MESHDIR ) "/io/polyg.exo"; 00029 static const char rpolyh[] = STRINGIFY( MESHDIR ) "/io/polyh.exo"; 00030 #else 00031 static const char ho_file[] = "ho_test.g"; 00032 static const char file_one[] = "mbtest1.g"; 00033 static const char alt_file[] = "hex_2x2x2_ss.exo"; 00034 static const char polyg[] = "poly8-10.vtk"; 00035 static const char polyh[] = "polyhedra.vtk"; 00036 static const char rpolyg[] = "polyg.exo"; 00037 static const char rpolyh[] = "polyh.exo"; 00038 #endif 00039 00040 void read_file( Interface& moab, const char* input_file ); 00041 00042 // Check that element has expected higher-order nodes 00043 // and that each higher-order node is at the center 00044 // of the sub-entity it is on. 00045 void check_ho_element( Interface& moab, EntityHandle entity, int mid_nodes[4] ); 00046 00047 void test_read_side( int sideset_id, EntityType sideset_type, int sideset_nodes_per_elem, bool shell_side = false ); 00048 00049 // Validate elements of specified type. 00050 // Looks for a block containing the specified entity type 00051 // and with the specified mid-node flags set in its 00052 // HAS_MID_NODES_TAG. 00053 void test_ho_elements( EntityType type, int num_nodes ); 00054 00055 // Tests originally in MBTest.cpp 00056 void mb_vertex_coordinate_test(); 00057 void mb_bar_connectivity_test(); 00058 void mb_tri_connectivity_test(); 00059 void mb_quad_connectivity_test(); 00060 void mb_hex_connectivity_test(); 00061 void mb_tet_connectivity_test(); 00062 void mb_write_mesh_test(); 00063 00064 void test_types(); 00065 00066 void test_tri6() 00067 { 00068 test_ho_elements( MBTRI, 6 ); 00069 } 00070 void test_tri7() 00071 { 00072 test_ho_elements( MBTRI, 7 ); 00073 } 00074 00075 void test_quad5() 00076 { 00077 test_ho_elements( MBQUAD, 5 ); 00078 } 00079 void test_quad8() 00080 { 00081 test_ho_elements( MBQUAD, 8 ); 00082 } 00083 void test_quad9() 00084 { 00085 test_ho_elements( MBQUAD, 9 ); 00086 } 00087 00088 void test_tet8() 00089 { 00090 test_ho_elements( MBTET, 8 ); 00091 } 00092 void test_tet10() 00093 { 00094 test_ho_elements( MBTET, 10 ); 00095 } 00096 void test_tet14() 00097 { 00098 test_ho_elements( MBTET, 14 ); 00099 } 00100 00101 void test_hex9() 00102 { 00103 test_ho_elements( MBHEX, 9 ); 00104 } 00105 void test_hex20() 00106 { 00107 test_ho_elements( MBHEX, 20 ); 00108 } 00109 void test_hex27() 00110 { 00111 test_ho_elements( MBHEX, 27 ); 00112 } 00113 00114 void test_read_tri6_side() 00115 { 00116 test_read_side( 1, MBEDGE, 3 ); 00117 } // sideset 1 00118 void test_read_shell_side() 00119 { 00120 test_read_side( 3, MBQUAD, 9, true ); 00121 } // sideset 3 00122 void test_read_shell_edge() 00123 { 00124 test_read_side( 4, MBEDGE, 3 ); 00125 } // sideset 4 00126 void test_read_hex20_side() 00127 { 00128 test_read_side( 2, MBQUAD, 8 ); 00129 } // sideset 2 00130 00131 void test_read_block_ids(); 00132 void test_read_sideset_ids(); 00133 void test_read_nodeset_ids(); 00134 void test_write_polygons(); 00135 void test_write_polyhedra(); 00136 void test_read_polygons(); 00137 void test_read_polyhedra(); 00138 00139 void test_read_alternate_coord_format(); 00140 00141 int main() 00142 { 00143 int result = 0; 00144 00145 result += RUN_TEST( mb_vertex_coordinate_test ); 00146 result += RUN_TEST( mb_bar_connectivity_test ); 00147 result += RUN_TEST( mb_tri_connectivity_test ); 00148 result += RUN_TEST( mb_quad_connectivity_test ); 00149 result += RUN_TEST( mb_hex_connectivity_test ); 00150 result += RUN_TEST( mb_tet_connectivity_test ); 00151 result += RUN_TEST( mb_write_mesh_test ); 00152 00153 result += RUN_TEST( test_types ); 00154 00155 result += RUN_TEST( test_tri6 ); 00156 result += RUN_TEST( test_tri7 ); 00157 result += RUN_TEST( test_quad5 ); 00158 result += RUN_TEST( test_quad8 ); 00159 result += RUN_TEST( test_quad9 ); 00160 result += RUN_TEST( test_tet8 ); 00161 result += RUN_TEST( test_tet10 ); 00162 result += RUN_TEST( test_tet14 ); 00163 result += RUN_TEST( test_hex9 ); 00164 result += RUN_TEST( test_hex20 ); 00165 result += RUN_TEST( test_hex27 ); 00166 00167 result += RUN_TEST( test_read_tri6_side ); 00168 result += RUN_TEST( test_read_shell_side ); 00169 result += RUN_TEST( test_read_shell_edge ); 00170 result += RUN_TEST( test_read_hex20_side ); 00171 00172 result += RUN_TEST( test_read_block_ids ); 00173 result += RUN_TEST( test_read_sideset_ids ); 00174 result += RUN_TEST( test_read_nodeset_ids ); 00175 00176 result += RUN_TEST( test_read_alternate_coord_format ); 00177 00178 result += RUN_TEST( test_write_polygons ); 00179 result += RUN_TEST( test_write_polyhedra ); 00180 result += RUN_TEST( test_read_polygons ); 00181 result += RUN_TEST( test_read_polyhedra ); 00182 00183 return result; 00184 } 00185 00186 void load_file_one( Interface* iface ) 00187 { 00188 ErrorCode error = iface->load_mesh( file_one ); 00189 if( MB_SUCCESS != error ) 00190 { 00191 std::cout << "Failed to load input file: " << file_one << std::endl; 00192 std::string error_reason; 00193 iface->get_last_error( error_reason ); 00194 std::cout << error_reason << std::endl; 00195 } 00196 CHECK_ERR( error ); 00197 } 00198 00199 /*! 00200 @test 00201 Vertex Coordinates 00202 @li Get coordinates of vertex 1 correctly 00203 @li Get coordinates of vertex 8 correctly 00204 @li Get coordinates of vertex 6 correctly 00205 */ 00206 void mb_vertex_coordinate_test() 00207 { 00208 double coords[3]; 00209 EntityHandle handle; 00210 ErrorCode error; 00211 int err; 00212 00213 Core moab; 00214 Interface* MB = &moab; 00215 load_file_one( MB ); 00216 00217 // coordinate 2 should be {1.5, -1.5, 3.5} 00218 00219 handle = CREATE_HANDLE( MBVERTEX, 2, err ); 00220 error = MB->get_coords( &handle, 1, coords );CHECK_ERR( error ); 00221 const double exp2[] = { 1.5, -1.5, 3.5 }; 00222 CHECK_ARRAYS_EQUAL( exp2, 3, coords, 3 ); 00223 00224 // coordinate 9 should be {1, -2, 3.5} 00225 handle = CREATE_HANDLE( MBVERTEX, 9, err ); 00226 error = MB->get_coords( &handle, 1, coords );CHECK_ERR( error ); 00227 const double exp9[] = { 1, -2, 3.5 }; 00228 CHECK_ARRAYS_EQUAL( exp9, 3, coords, 3 ); 00229 00230 // coordinate 7 should be {0.5, -2, 3.5} 00231 handle = CREATE_HANDLE( MBVERTEX, 7, err ); 00232 error = MB->get_coords( &handle, 1, coords );CHECK_ERR( error ); 00233 const double exp7[] = { 0.5, -2, 3.5 }; 00234 CHECK_ARRAYS_EQUAL( exp7, 3, coords, 3 ); 00235 00236 int node_count = 0; 00237 error = MB->get_number_entities_by_type( 0, MBVERTEX, node_count );CHECK_ERR( error ); 00238 // Number of vertices (node_count) should be 83 assuming no gaps in the handle space 00239 CHECK_EQUAL( 47, node_count ); 00240 } 00241 00242 /*! 00243 @test 00244 MB Bar Element Connectivity Test 00245 @li Get coordinates for 2 node bar elements 00246 */ 00247 00248 void mb_bar_connectivity_test() 00249 { 00250 Core moab; 00251 Interface* MB = &moab; 00252 load_file_one( MB ); 00253 00254 std::vector< EntityHandle > conn; 00255 Range bars; 00256 00257 ErrorCode error = MB->get_entities_by_type( 0, MBEDGE, bars );CHECK_ERR( error ); 00258 00259 // get the connectivity of the second bar 00260 EntityHandle handle = *( ++bars.begin() ); 00261 00262 error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); 00263 00264 CHECK_EQUAL( (size_t)2, conn.size() ); 00265 00266 // from ncdump the connectivity of bar 2 (0 based) is 00267 // 14, 13 00268 CHECK_EQUAL( (EntityHandle)14, conn[0] ); 00269 CHECK_EQUAL( (EntityHandle)13, conn[1] ); 00270 00271 // Now try getting the connectivity of one of the vertices for fun. 00272 // just return the vertex in the connectivity 00273 handle = conn[0]; 00274 error = MB->get_connectivity( &handle, 1, conn ); 00275 CHECK_EQUAL( MB_FAILURE, error ); 00276 } 00277 00278 void mb_tri_connectivity_test() 00279 { 00280 Core moab; 00281 Interface* MB = &moab; 00282 load_file_one( MB ); 00283 00284 std::vector< EntityHandle > conn; 00285 Range tris; 00286 ErrorCode error = MB->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( error ); 00287 00288 // get the connectivity of the second tri 00289 EntityHandle handle = *( ++tris.begin() ); 00290 00291 error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); 00292 00293 CHECK_EQUAL( (size_t)3, conn.size() ); 00294 00295 // from ncdump the connectivity of tri 2 (0 based) is 00296 // 45, 37, 38 00297 00298 CHECK_EQUAL( (EntityHandle)45, conn[0] ); 00299 CHECK_EQUAL( (EntityHandle)37, conn[1] ); 00300 CHECK_EQUAL( (EntityHandle)38, conn[2] ); 00301 } 00302 00303 void mb_quad_connectivity_test() 00304 { 00305 Core moab; 00306 Interface* MB = &moab; 00307 load_file_one( MB ); 00308 00309 std::vector< EntityHandle > conn; 00310 Range quads; 00311 00312 ErrorCode error = MB->get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( error ); 00313 00314 // get the connectivity of the second quad 00315 EntityHandle handle = *( ++quads.begin() ); 00316 00317 error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); 00318 00319 CHECK_EQUAL( (size_t)4, conn.size() ); 00320 00321 // from ncdump the connectivity of quad 2 (0 based) is 00322 // 20, 11, 12, 26, 00323 00324 CHECK_EQUAL( (EntityHandle)20, conn[0] ); 00325 CHECK_EQUAL( (EntityHandle)11, conn[1] ); 00326 CHECK_EQUAL( (EntityHandle)12, conn[2] ); 00327 CHECK_EQUAL( (EntityHandle)26, conn[3] ); 00328 } 00329 00330 void mb_hex_connectivity_test() 00331 { 00332 Core moab; 00333 Interface* MB = &moab; 00334 load_file_one( MB ); 00335 00336 std::vector< EntityHandle > conn; 00337 Range hexes; 00338 00339 ErrorCode error = MB->get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( error ); 00340 00341 // get the connectivity of the second hex 00342 EntityHandle handle = *( ++hexes.begin() ); 00343 00344 error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); 00345 00346 CHECK_EQUAL( (size_t)8, conn.size() ); 00347 00348 // from ncdump the connectivity of hex 1 (0 based) is 00349 // 19, 13, 16, 23, 21, 14, 18, 27 00350 00351 CHECK_EQUAL( (EntityHandle)19, conn[0] ); 00352 CHECK_EQUAL( (EntityHandle)13, conn[1] ); 00353 CHECK_EQUAL( (EntityHandle)16, conn[2] ); 00354 CHECK_EQUAL( (EntityHandle)23, conn[3] ); 00355 CHECK_EQUAL( (EntityHandle)21, conn[4] ); 00356 CHECK_EQUAL( (EntityHandle)14, conn[5] ); 00357 CHECK_EQUAL( (EntityHandle)18, conn[6] ); 00358 CHECK_EQUAL( (EntityHandle)27, conn[7] ); 00359 } 00360 00361 void mb_tet_connectivity_test() 00362 { 00363 Core moab; 00364 Interface* MB = &moab; 00365 load_file_one( MB ); 00366 00367 std::vector< EntityHandle > conn; 00368 Range tets; 00369 ErrorCode error = MB->get_entities_by_type( 0, MBTET, tets );CHECK_ERR( error ); 00370 00371 // get the connectivity of the second tet 00372 EntityHandle handle = *( ++tets.begin() ); 00373 00374 error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); 00375 00376 CHECK_EQUAL( (size_t)4, conn.size() ); 00377 00378 // from ncdump the connectivity of tet 2 (0 based) is: 00379 // 35, 34, 32, 43 00380 00381 CHECK_EQUAL( (EntityHandle)35, conn[0] ); 00382 CHECK_EQUAL( (EntityHandle)34, conn[1] ); 00383 CHECK_EQUAL( (EntityHandle)32, conn[2] ); 00384 CHECK_EQUAL( (EntityHandle)43, conn[3] ); 00385 } 00386 00387 void mb_write_mesh_test() 00388 { 00389 Core moab; 00390 Interface* MB = &moab; 00391 load_file_one( MB ); 00392 ErrorCode result; 00393 00394 std::string file_name = "mb_write.g"; 00395 00396 // no need to get lists, write out the whole mesh 00397 result = MB->write_mesh( file_name.c_str() );CHECK_ERR( result ); 00398 00399 //---------The following tests outputting meshsets that are in meshsets of blocks ---/ 00400 00401 // lets create a block meshset and put some entities and meshsets into it 00402 EntityHandle block_ms; 00403 result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_ms );CHECK_ERR( result ); 00404 00405 // make another meshset to put quads in, so SHELLs can be written out 00406 EntityHandle block_of_shells; 00407 result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_of_shells );CHECK_ERR( result ); 00408 00409 // tag the meshset so it's a block, with id 100 00410 int id = 100; 00411 Tag tag_handle; 00412 const int negone = -1; 00413 result = MB->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); 00414 result = MB->tag_set_data( tag_handle, &block_ms, 1, &id );CHECK_ERR( result ); 00415 id = 101; 00416 result = MB->tag_set_data( tag_handle, &block_of_shells, 1, &id );CHECK_ERR( result ); 00417 00418 // set dimension tag on this to ensure shells get output; reuse id variable 00419 result = MB->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); 00420 id = 3; 00421 result = MB->tag_set_data( tag_handle, &block_of_shells, 1, &id );CHECK_ERR( result ); 00422 00423 // get some entities (tets) 00424 Range temp_range; 00425 result = MB->get_entities_by_type( 0, MBHEX, temp_range );CHECK_ERR( result ); 00426 00427 Range::iterator iter, end_iter; 00428 iter = temp_range.begin(); 00429 end_iter = temp_range.end(); 00430 00431 // add evens to 'block_ms' 00432 std::vector< EntityHandle > temp_vec; 00433 for( ; iter != end_iter; ++iter ) 00434 { 00435 if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter ); 00436 } 00437 result = MB->add_entities( block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); 00438 00439 // make another meshset 00440 EntityHandle ms_of_block_ms; 00441 result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_block_ms );CHECK_ERR( result ); 00442 00443 // add some entities to it 00444 temp_vec.clear(); 00445 iter = temp_range.begin(); 00446 for( ; iter != end_iter; ++iter ) 00447 { 00448 if( ID_FROM_HANDLE( *iter ) % 2 ) // add all odds 00449 temp_vec.push_back( *iter ); 00450 } 00451 result = MB->add_entities( ms_of_block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); 00452 00453 // add the other meshset to the block's meshset 00454 result = MB->add_entities( block_ms, &ms_of_block_ms, 1 );CHECK_ERR( result ); 00455 00456 //---------------testing sidesets----------------/ 00457 00458 // lets create a sideset meshset and put some entities and meshsets into it 00459 EntityHandle sideset_ms; 00460 result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, sideset_ms );CHECK_ERR( result ); 00461 00462 // tag the meshset so it's a sideset, with id 104 00463 id = 104; 00464 result = MB->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); 00465 00466 result = MB->tag_set_data( tag_handle, &sideset_ms, 1, &id );CHECK_ERR( result ); 00467 00468 // get some entities (tris) 00469 temp_range.clear(); 00470 result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result ); 00471 00472 iter = temp_range.begin(); 00473 end_iter = temp_range.end(); 00474 00475 // add evens to 'sideset_ms' 00476 temp_vec.clear(); 00477 for( ; iter != end_iter; ++iter ) 00478 { 00479 if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter ); 00480 } 00481 result = MB->add_entities( sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); 00482 00483 // make another meshset 00484 EntityHandle ms_of_sideset_ms; 00485 result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_sideset_ms );CHECK_ERR( result ); 00486 00487 // add some entities to it 00488 temp_vec.clear(); 00489 iter = temp_range.begin(); 00490 for( ; iter != end_iter; ++iter ) 00491 { 00492 if( ID_FROM_HANDLE( *iter ) % 2 ) // add all odds 00493 temp_vec.push_back( *iter ); 00494 } 00495 result = MB->add_entities( ms_of_sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); 00496 00497 // add the other meshset to the sideset's meshset 00498 result = MB->add_entities( sideset_ms, &ms_of_sideset_ms, 1 );CHECK_ERR( result ); 00499 00500 //---------test sense on meshsets (reverse/foward)-------// 00501 00502 // get all quads whose x-coord = 2.5 and put them into a meshset_a 00503 EntityHandle meshset_a; 00504 result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_a );CHECK_ERR( result ); 00505 00506 temp_range.clear(); 00507 result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result ); 00508 00509 std::vector< EntityHandle > nodes1, entity_vec; 00510 std::copy( temp_range.begin(), temp_range.end(), std::back_inserter( entity_vec ) ); 00511 result = MB->get_connectivity( &entity_vec[0], entity_vec.size(), nodes1 );CHECK_ERR( result ); 00512 assert( nodes1.size() == 4 * temp_range.size() ); 00513 temp_vec.clear(); 00514 std::vector< double > coords( 3 * nodes1.size() ); 00515 result = MB->get_coords( &nodes1[0], nodes1.size(), &coords[0] );CHECK_ERR( result ); 00516 00517 unsigned int k = 0; 00518 for( Range::iterator it = temp_range.begin(); it != temp_range.end(); ++it ) 00519 { 00520 if( coords[12 * k] == 2.5 && coords[12 * k + 3] == 2.5 && coords[12 * k + 6] == 2.5 && 00521 coords[12 * k + 9] == 2.5 ) 00522 temp_vec.push_back( *it ); 00523 k++; 00524 } 00525 result = MB->add_entities( meshset_a, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); 00526 result = MB->add_entities( block_of_shells, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); 00527 00528 // put these quads into a different meshset_b and tag them with a reverse sense tag 00529 EntityHandle meshset_b; 00530 result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_b );CHECK_ERR( result ); 00531 00532 result = MB->add_entities( meshset_b, &meshset_a, 1 );CHECK_ERR( result ); 00533 00534 result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( result ); 00535 00536 int reverse_value = -1; 00537 result = MB->tag_set_data( tag_handle, &meshset_b, 1, &reverse_value );CHECK_ERR( result ); 00538 00539 // get some random quad, whose x-coord != 2.5, and put it into a different meshset_c 00540 // and tag it with a reverse sense tag 00541 00542 iter = temp_range.begin(); 00543 end_iter = temp_range.end(); 00544 00545 temp_vec.clear(); 00546 for( ; iter != end_iter; ++iter ) 00547 { 00548 std::vector< EntityHandle > nodes; 00549 result = MB->get_connectivity( &( *iter ), 1, nodes );CHECK_ERR( result ); 00550 00551 bool not_equal_2_5 = true; 00552 for( unsigned int ku = 0; ku < nodes.size(); ku++ ) 00553 { 00554 double coords2[3] = { 0 }; 00555 00556 result = MB->get_coords( &( nodes[ku] ), 1, coords2 );CHECK_ERR( result ); 00557 00558 if( coords2[0] == 2.5 ) 00559 { 00560 not_equal_2_5 = false; 00561 break; 00562 } 00563 } 00564 00565 if( not_equal_2_5 && nodes.size() > 0 ) 00566 { 00567 temp_vec.push_back( *iter ); 00568 break; 00569 } 00570 } 00571 00572 EntityHandle meshset_c; 00573 MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_c ); 00574 00575 result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle );CHECK_ERR( result ); 00576 00577 reverse_value = -1; 00578 result = MB->tag_set_data( tag_handle, &meshset_c, 1, &reverse_value );CHECK_ERR( result ); 00579 00580 MB->add_entities( meshset_c, &temp_vec[0], temp_vec.size() ); 00581 MB->add_entities( block_of_shells, &temp_vec[0], temp_vec.size() ); 00582 00583 // create another meshset_abc, adding meshset_a, meshset_b, meshset_c 00584 EntityHandle meshset_abc; 00585 MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_abc ); 00586 00587 temp_vec.clear(); 00588 temp_vec.push_back( meshset_a ); 00589 temp_vec.push_back( meshset_b ); 00590 temp_vec.push_back( meshset_c ); 00591 00592 MB->add_entities( meshset_abc, &temp_vec[0], temp_vec.size() ); 00593 00594 // tag it so it's a sideset 00595 id = 444; 00596 result = MB->tag_get_handle( "NEUMANN_SET", 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); 00597 00598 result = MB->tag_set_data( tag_handle, &meshset_abc, 1, &id );CHECK_ERR( result ); 00599 00600 //---------------do nodesets now -----------------// 00601 00602 // lets create a nodeset meshset and put some entities and meshsets into it 00603 EntityHandle nodeset_ms; 00604 MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, nodeset_ms ); 00605 00606 // tag the meshset so it's a nodeset, with id 119 00607 id = 119; 00608 result = MB->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); 00609 00610 result = MB->tag_set_data( tag_handle, &nodeset_ms, 1, &id );CHECK_ERR( result ); 00611 00612 // get all Quads 00613 temp_range.clear(); 00614 result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result ); 00615 00616 // get all the nodes of the tris 00617 Range nodes_of_quads; 00618 iter = temp_range.begin(); 00619 end_iter = temp_range.end(); 00620 00621 for( ; iter != end_iter; ++iter ) 00622 { 00623 std::vector< EntityHandle > nodes; 00624 result = MB->get_connectivity( &( *iter ), 1, nodes );CHECK_ERR( result ); 00625 00626 for( unsigned int ku = 0; ku < nodes.size(); ku++ ) 00627 nodes_of_quads.insert( nodes[ku] ); 00628 } 00629 00630 iter = nodes_of_quads.begin(); 00631 end_iter = nodes_of_quads.end(); 00632 00633 // add evens to 'nodeset_ms' 00634 temp_vec.clear(); 00635 for( ; iter != end_iter; ++iter ) 00636 { 00637 if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter ); 00638 } 00639 MB->add_entities( nodeset_ms, &temp_vec[0], temp_vec.size() ); 00640 00641 // make another meshset 00642 EntityHandle ms_of_nodeset_ms; 00643 MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_nodeset_ms ); 00644 00645 // add some entities to it 00646 temp_vec.clear(); 00647 iter = nodes_of_quads.begin(); 00648 end_iter = nodes_of_quads.end(); 00649 for( ; iter != end_iter; ++iter ) 00650 { 00651 if( ID_FROM_HANDLE( *iter ) % 2 ) // add all odds 00652 temp_vec.push_back( *iter ); 00653 } 00654 MB->add_entities( ms_of_nodeset_ms, &temp_vec[0], temp_vec.size() ); 00655 00656 // add the other meshset to the nodeset's meshset 00657 MB->add_entities( nodeset_ms, &ms_of_nodeset_ms, 1 ); 00658 00659 // no need to get lists, write out the whole mesh 00660 file_name = "mb_write2.g"; 00661 std::vector< EntityHandle > output_list; 00662 output_list.push_back( block_ms ); 00663 output_list.push_back( sideset_ms ); 00664 output_list.push_back( meshset_abc ); 00665 output_list.push_back( nodeset_ms ); 00666 output_list.push_back( block_of_shells ); 00667 result = MB->write_mesh( file_name.c_str(), &output_list[0], output_list.size() );CHECK_ERR( result ); 00668 } 00669 00670 struct TestType 00671 { 00672 EntityType moab_type; 00673 ExoIIElementType exo_type; 00674 int num_nodes; 00675 std::string name; 00676 }; 00677 00678 void check_type( const TestType& type ) 00679 { 00680 int has_mid_nodes[4]; 00681 CN::HasMidNodes( type.moab_type, type.num_nodes, has_mid_nodes ); 00682 00683 CHECK_EQUAL( type.moab_type, ExoIIUtil::ExoIIElementMBEntity[type.exo_type] ); 00684 CHECK_EQUAL( type.name, std::string( ExoIIUtil::ElementTypeNames[type.exo_type] ) ); 00685 CHECK_EQUAL( type.num_nodes, ExoIIUtil::VerticesPerElement[type.exo_type] ); 00686 auto dim = CN::Dimension( type.moab_type ); 00687 if( 3 == dim ) CHECK_EQUAL( has_mid_nodes[3], ExoIIUtil::HasMidNodes[type.exo_type][3] ); 00688 if( 2 <= dim ) CHECK_EQUAL( has_mid_nodes[2], ExoIIUtil::HasMidNodes[type.exo_type][2] ); 00689 if( 1 <= dim ) CHECK_EQUAL( has_mid_nodes[1], ExoIIUtil::HasMidNodes[type.exo_type][1] ); 00690 00691 Core moab; 00692 ExoIIUtil tool( &moab ); 00693 CHECK_EQUAL( type.exo_type, tool.element_name_to_type( type.name.c_str() ) ); 00694 CHECK_EQUAL( type.name, std::string( tool.element_type_name( type.exo_type ) ) ); 00695 } 00696 00697 void test_types() 00698 { 00699 const TestType types[] = { { MBVERTEX, EXOII_SPHERE, 1, "SPHERE" }, 00700 { MBEDGE, EXOII_SPRING, 1, "SPRING" }, 00701 { MBEDGE, EXOII_BAR, 2, "BAR" }, 00702 { MBEDGE, EXOII_BAR2, 2, "BAR2" }, 00703 { MBEDGE, EXOII_BAR3, 3, "BAR3" }, 00704 { MBEDGE, EXOII_BEAM, 2, "BEAM" }, 00705 { MBEDGE, EXOII_BEAM2, 2, "BEAM2" }, 00706 { MBEDGE, EXOII_BEAM3, 3, "BEAM3" }, 00707 { MBEDGE, EXOII_TRUSS, 2, "TRUSS" }, 00708 { MBEDGE, EXOII_TRUSS2, 2, "TRUSS2" }, 00709 { MBEDGE, EXOII_TRUSS3, 3, "TRUSS3" }, 00710 { MBTRI, EXOII_TRI, 3, "TRI" }, 00711 { MBTRI, EXOII_TRI3, 3, "TRI3" }, 00712 { MBTRI, EXOII_TRI6, 6, "TRI6" }, 00713 { MBTRI, EXOII_TRI7, 7, "TRI7" }, 00714 { MBQUAD, EXOII_QUAD, 4, "QUAD" }, 00715 { MBQUAD, EXOII_QUAD4, 4, "QUAD4" }, 00716 { MBQUAD, EXOII_QUAD5, 5, "QUAD5" }, 00717 { MBQUAD, EXOII_QUAD8, 8, "QUAD8" }, 00718 { MBQUAD, EXOII_QUAD9, 9, "QUAD9" }, 00719 { MBQUAD, EXOII_SHELL, 4, "SHELL" }, 00720 { MBQUAD, EXOII_SHELL4, 4, "SHELL4" }, 00721 { MBQUAD, EXOII_SHELL5, 5, "SHELL5" }, 00722 { MBQUAD, EXOII_SHELL8, 8, "SHELL8" }, 00723 { MBQUAD, EXOII_SHELL9, 9, "SHELL9" }, 00724 { MBTET, EXOII_TETRA, 4, "TETRA" }, 00725 { MBTET, EXOII_TETRA4, 4, "TETRA4" }, 00726 { MBTET, EXOII_TET4, 4, "TET4" }, 00727 { MBTET, EXOII_TETRA8, 8, "TETRA8" }, 00728 { MBTET, EXOII_TETRA10, 10, "TETRA10" }, 00729 { MBTET, EXOII_TETRA14, 14, "TETRA14" }, 00730 { MBPYRAMID, EXOII_PYRAMID, 5, "PYRAMID" }, 00731 { MBPYRAMID, EXOII_PYRAMID5, 5, "PYRAMID5" }, 00732 { MBPYRAMID, EXOII_PYRAMID10, 10, "PYRAMID10" }, 00733 { MBPYRAMID, EXOII_PYRAMID13, 13, "PYRAMID13" }, 00734 { MBPYRAMID, EXOII_PYRAMID18, 18, "PYRAMID18" }, 00735 { MBPRISM, EXOII_WEDGE, 6, "WEDGE" }, 00736 { MBKNIFE, EXOII_KNIFE, 7, "KNIFE" }, 00737 { MBHEX, EXOII_HEX, 8, "HEX" }, 00738 { MBHEX, EXOII_HEX8, 8, "HEX8" }, 00739 { MBHEX, EXOII_HEX9, 9, "HEX9" }, 00740 { MBHEX, EXOII_HEX20, 20, "HEX20" }, 00741 { MBHEX, EXOII_HEX27, 27, "HEX27" }, 00742 { MBHEX, EXOII_HEXSHELL, 12, "HEXSHELL" } }; 00743 const int num_types = sizeof( types ) / sizeof( types[0] ); 00744 for( int i = 0; i < num_types; ++i ) 00745 check_type( types[i] ); 00746 } 00747 00748 void read_file( Interface& moab, const char* input_file ) 00749 { 00750 ErrorCode rval = moab.load_file( input_file );CHECK_ERR( rval ); 00751 } 00752 00753 void write_and_read( Interface& write_mb, Interface& read_mb, EntityHandle block = 0 ) 00754 { 00755 const char* tmp_file = "exodus_test_tmp.g"; 00756 ErrorCode rval; 00757 00758 EntityHandle* write_set_list = █ 00759 int write_set_list_len = 0; //(block != 0); 00760 rval = write_mb.write_file( tmp_file, "EXODUS", 0, write_set_list, write_set_list_len ); 00761 if( MB_SUCCESS != rval ) remove( tmp_file );CHECK_ERR( rval ); 00762 00763 rval = read_mb.load_file( tmp_file ); 00764 remove( tmp_file );CHECK_ERR( rval ); 00765 } 00766 00767 void check_ho_elements( Interface& moab, EntityHandle block, EntityType type, int mid_nodes[4] ) 00768 { 00769 ErrorCode rval; 00770 Range elems; 00771 rval = moab.get_entities_by_handle( block, elems, ( type != MBENTITYSET ? true : false ) );CHECK_ERR( rval ); 00772 CHECK( !elems.empty() ); 00773 CHECK( elems.all_of_type( type ) ); 00774 for( Range::const_iterator i = elems.begin(); i != elems.end(); ++i ) 00775 check_ho_element( moab, *i, mid_nodes ); 00776 } 00777 00778 // Check that element has expected higher-order nodes 00779 // and that each higher-order node is at the center 00780 // of the sub-entity it is on. 00781 void check_ho_element( Interface& moab, EntityHandle entity, int mid_nodes[4] ) 00782 { 00783 // get element info 00784 const EntityType type = TYPE_FROM_HANDLE( entity ); 00785 const EntityHandle* conn; 00786 int conn_len; 00787 ErrorCode rval = moab.get_connectivity( entity, conn, conn_len );CHECK_ERR( rval ); 00788 std::vector< double > coords( 3 * conn_len ); 00789 rval = moab.get_coords( conn, conn_len, &coords[0] );CHECK_ERR( rval ); 00790 00791 // calculate and verify expected number of mid nodes 00792 int num_nodes = CN::VerticesPerEntity( type ); 00793 for( int d = 1; d <= CN::Dimension( type ); ++d ) 00794 if( mid_nodes[d] ) num_nodes += CN::NumSubEntities( type, d ); 00795 CHECK_EQUAL( num_nodes, conn_len ); 00796 00797 // verify that each higher-order node is at the center 00798 // of its respective sub-entity. 00799 for( int i = CN::VerticesPerEntity( type ); i < num_nodes; ++i ) 00800 { 00801 // get sub-entity owning ho-node 00802 int sub_dim, sub_num; 00803 CN::HONodeParent( type, num_nodes, i, sub_dim, sub_num ); 00804 // get corner vertex indices 00805 int sub_conn[8], num_sub; 00806 if( sub_dim < CN::Dimension( type ) ) 00807 { 00808 CN::SubEntityVertexIndices( type, sub_dim, sub_num, sub_conn ); 00809 EntityType sub_type = CN::SubEntityType( type, sub_dim, sub_num ); 00810 num_sub = CN::VerticesPerEntity( sub_type ); 00811 } 00812 else 00813 { 00814 num_sub = CN::VerticesPerEntity( type ); 00815 for( int j = 0; j < num_sub; ++j ) 00816 sub_conn[j] = j; 00817 } 00818 // calculate mean of corner vertices 00819 double mean[3] = { 0, 0, 0 }; 00820 for( int j = 0; j < num_sub; ++j ) 00821 { 00822 int co = 3 * sub_conn[j]; 00823 mean[0] += coords[co]; 00824 mean[1] += coords[co + 1]; 00825 mean[2] += coords[co + 2]; 00826 } 00827 mean[0] /= num_sub; 00828 mean[1] /= num_sub; 00829 mean[2] /= num_sub; 00830 // verify that higher-order node is at expected location 00831 CHECK_REAL_EQUAL( mean[0], coords[3 * i], 1e-6 ); 00832 CHECK_REAL_EQUAL( mean[1], coords[3 * i + 1], 1e-6 ); 00833 CHECK_REAL_EQUAL( mean[2], coords[3 * i + 2], 1e-6 ); 00834 } 00835 } 00836 00837 EntityHandle find_block( Interface& mb, EntityType type, const int has_mid_nodes[4] ) 00838 { 00839 00840 ErrorCode rval; 00841 Tag ho_tag, block_tag; 00842 const int negone = -1; 00843 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, block_tag, 0, &negone );CHECK_ERR( rval ); 00844 const int mids[] = { -1, -1, -1, -1 }; 00845 rval = mb.tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, ho_tag, 0, mids );CHECK_ERR( rval ); 00846 00847 // get material sets with expected higher-order nodes 00848 Range blocks; 00849 Tag tags[2] = { ho_tag, block_tag }; 00850 const void* vals[2] = { has_mid_nodes, NULL }; 00851 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, blocks );CHECK_ERR( rval ); 00852 00853 for( Range::iterator i = blocks.begin(); i != blocks.end(); ++i ) 00854 { 00855 int n; 00856 rval = mb.get_number_entities_by_type( *i, type, n );CHECK_ERR( rval ); 00857 if( n > 0 ) return *i; 00858 } 00859 00860 CHECK( false ); // no block matching element type description 00861 return 0; 00862 } 00863 00864 EntityHandle find_sideset( Interface& mb, int sideset_id, EntityType /*side_type*/ ) 00865 { 00866 ErrorCode rval; 00867 Tag ss_tag; 00868 const int negone = -1; 00869 rval = mb.tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, ss_tag, 0, &negone );CHECK_ERR( rval ); 00870 00871 const void* tag_vals[] = { &sideset_id }; 00872 Range side_sets; 00873 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &ss_tag, tag_vals, 1, side_sets );CHECK_ERR( rval ); 00874 CHECK_EQUAL( 1, (int)side_sets.size() ); 00875 return side_sets.front(); 00876 } 00877 00878 // Validate elements of specified type. 00879 // Looks for a block containing the specified entity type 00880 // and with the specified mid-node flags set in its 00881 // HAS_MID_NODES_TAG. 00882 void test_ho_elements( EntityType type, int num_nodes ) 00883 { 00884 Core mb_impl1, mb_impl2; 00885 Interface &mb1 = mb_impl1, &mb2 = mb_impl2; 00886 int ho_flags[4]; 00887 CN::HasMidNodes( type, num_nodes, ho_flags ); 00888 00889 // read file 00890 read_file( mb1, ho_file ); 00891 // test element connectivity order 00892 EntityHandle block = find_block( mb1, type, ho_flags ); 00893 CHECK( block != 0 ); 00894 check_ho_elements( mb1, block, type, ho_flags ); 00895 00896 // write block and read it back in 00897 write_and_read( mb1, mb2, block ); 00898 // test element connectivity order on re-read data 00899 block = find_block( mb2, type, ho_flags ); 00900 CHECK( block != 0 ); 00901 check_ho_elements( mb2, block, type, ho_flags ); 00902 } 00903 00904 void test_read_side( int id, EntityType sideset_type, int sideset_nodes_per_elem, bool shell_side ) 00905 { 00906 // read test file 00907 Core mb_impl; 00908 Interface& moab = mb_impl; 00909 read_file( moab, ho_file ); 00910 00911 // get side set 00912 EntityHandle set = find_sideset( moab, id, sideset_type ); 00913 CHECK( set != 0 ); 00914 00915 // check expected element connectivity 00916 int ho_flags[4]; 00917 CN::HasMidNodes( sideset_type, sideset_nodes_per_elem, ho_flags ); 00918 check_ho_elements( moab, set, sideset_type, ho_flags ); 00919 00920 if( shell_side ) return; 00921 00922 // check that each element is on the boundary of the mesh 00923 Range elems; 00924 ErrorCode rval = mb_impl.get_entities_by_handle( set, elems );CHECK_ERR( rval ); 00925 00926 int dim = CN::Dimension( sideset_type ); 00927 for( Range::iterator i = elems.begin(); i != elems.end(); ++i ) 00928 { 00929 Range adj; 00930 rval = mb_impl.get_adjacencies( &*i, 1, dim + 1, false, adj, Interface::UNION );CHECK_ERR( rval ); 00931 CHECK_EQUAL( 1, (int)adj.size() ); 00932 } 00933 } 00934 00935 void test_read_ids_common( const char* file_name, const char* tag_name, const int* expected_vals, int num_expected ) 00936 { 00937 Core mb; 00938 ReadNCDF reader( &mb ); 00939 00940 FileOptions opts( "" ); 00941 std::vector< int > values; 00942 ErrorCode rval = reader.read_tag_values( file_name, tag_name, opts, values );CHECK_ERR( rval ); 00943 00944 std::vector< int > expected( expected_vals, expected_vals + num_expected ); 00945 std::sort( values.begin(), values.end() ); 00946 std::sort( expected.begin(), expected.end() ); 00947 CHECK_EQUAL( expected, values ); 00948 } 00949 00950 void test_read_block_ids() 00951 { 00952 const int expected[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 }; 00953 test_read_ids_common( ho_file, MATERIAL_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) ); 00954 } 00955 00956 void test_read_sideset_ids() 00957 { 00958 const int expected[] = { 1, 2, 3, 4 }; 00959 test_read_ids_common( ho_file, NEUMANN_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) ); 00960 } 00961 00962 void test_read_nodeset_ids() 00963 { 00964 test_read_ids_common( ho_file, DIRICHLET_SET_TAG_NAME, 0, 0 ); 00965 } 00966 00967 void test_read_alternate_coord_format() 00968 { 00969 Core moab; 00970 Interface& mb = moab; 00971 ErrorCode rval = mb.load_file( alt_file );CHECK_ERR( rval ); 00972 00973 const double exp[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 }; 00974 00975 Range hexes; 00976 rval = mb.get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( rval ); 00977 CHECK_EQUAL( (size_t)1, hexes.size() ); 00978 EntityHandle hex = hexes.front(); 00979 const EntityHandle* conn; 00980 int len; 00981 rval = mb.get_connectivity( hex, conn, len );CHECK_ERR( rval ); 00982 CHECK_EQUAL( 8, len ); 00983 double act[3 * 8]; 00984 rval = mb.get_coords( conn, len, act );CHECK_ERR( rval ); 00985 CHECK_ARRAYS_EQUAL( exp, 3 * 8, act, 3 * 8 ); 00986 } 00987 void test_write_polygons() 00988 { 00989 Core moab; 00990 Interface& mb = moab; 00991 ErrorCode rval = mb.load_file( polyg );CHECK_ERR( rval ); 00992 rval = mb.write_file( "polyg.exo" );CHECK_ERR( rval ); 00993 } 00994 00995 void test_write_polyhedra() 00996 { 00997 Core moab; 00998 Interface& mb = moab; 00999 ErrorCode rval = mb.load_file( polyh );CHECK_ERR( rval ); 01000 rval = mb.write_file( "polyh.exo" );CHECK_ERR( rval ); 01001 } 01002 void test_read_polygons() 01003 { 01004 Core moab; 01005 Interface& mb = moab; 01006 ErrorCode rval = mb.load_file( rpolyg );CHECK_ERR( rval ); 01007 } 01008 void test_read_polyhedra() 01009 { 01010 Core moab; 01011 Interface& mb = moab; 01012 ErrorCode rval = mb.load_file( rpolyh );CHECK_ERR( rval ); 01013 }
