MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example TestErrorHandling.cpp \n 00002 * Description: This example tests MOAB's trace back error handler in serial. \n 00003 * 00004 * <b>To run</b>: ./TestErrorHandling <test_case_num(1 to 4)> \n 00005 */ 00006 00007 #include "moab/Core.hpp" 00008 #ifdef MOAB_HAVE_MPI 00009 #include "moab_mpi.h" 00010 #endif 00011 00012 #include <iostream> 00013 00014 using namespace moab; 00015 using namespace std; 00016 00017 // In this test case, an error MB_NOT_IMPLEMENTED is returned by MOAB 00018 ErrorCode TestErrorHandling_1() 00019 { 00020 Core moab; 00021 Interface& mb = moab; 00022 00023 // Load a CAM-FV file and read a variable on edges (not supported yet) 00024 string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" ); 00025 ErrorCode rval = mb.load_file( test_file.c_str(), NULL, "VARIABLE=US" );MB_CHK_ERR( rval ); 00026 00027 return MB_SUCCESS; 00028 } 00029 00030 // In this test case, an error MB_TYPE_OUT_OF_RANGE is returned by MOAB 00031 ErrorCode TestErrorHandling_2() 00032 { 00033 Core moab; 00034 Interface& mb = moab; 00035 00036 // Load a HOMME file with an invalid GATHER_SET option 00037 string test_file = string( MESH_DIR ) + string( "/io/homme3x3458.t.3.nc" ); 00038 ErrorCode rval = mb.load_file( test_file.c_str(), NULL, "VARIABLE=T;GATHER_SET=0.1" );MB_CHK_ERR( rval ); 00039 00040 return MB_SUCCESS; 00041 } 00042 00043 // In this test case, an error MB_FAILURE is returned by MOAB 00044 ErrorCode TestErrorHandling_3() 00045 { 00046 Core moab; 00047 Interface& mb = moab; 00048 00049 // Load a CAM-FV file with NOMESH option and a NULL file set 00050 string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" ); 00051 ErrorCode rval = mb.load_file( test_file.c_str(), NULL, "NOMESH;VARIABLE=" );MB_CHK_ERR( rval ); 00052 00053 return MB_SUCCESS; 00054 } 00055 00056 // In this test case, an error MB_VARIABLE_DATA_LENGTH is returned by MOAB 00057 ErrorCode TestErrorHandling_4() 00058 { 00059 Core moab; 00060 Interface& mb = moab; 00061 00062 // Create 100 vertices 00063 const int NUM_VTX = 100; 00064 vector< double > coords( 3 * NUM_VTX ); 00065 Range verts; 00066 ErrorCode rval = mb.create_vertices( &coords[0], NUM_VTX, verts );MB_CHK_SET_ERR( rval, "Failed to create vertices" ); 00067 00068 // Create a variable-length dense tag 00069 Tag tag; 00070 rval = mb.tag_get_handle( "var_len_den", 1, MB_TYPE_INTEGER, tag, MB_TAG_VARLEN | MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Failed to create a tag" ); 00071 00072 // Attempt to iterate over a variable-length tag, which will never be possible 00073 void* ptr = NULL; 00074 int count = 0; 00075 rval = mb.tag_iterate( tag, verts.begin(), verts.end(), count, ptr );MB_CHK_SET_ERR( rval, "Failed to iterate over tag on " << NUM_VTX << " vertices" ); 00076 00077 return MB_SUCCESS; 00078 } 00079 00080 int main( int argc, char** argv ) 00081 { 00082 if( argc < 2 ) 00083 { 00084 cout << "Usage: " << argv[0] << " <test_case_num(1 to 4)>" << endl; 00085 return 0; 00086 } 00087 00088 #ifdef MOAB_HAVE_MPI 00089 MPI_Init( &argc, &argv ); 00090 #endif 00091 00092 // Initialize error handler, optional for this example (using moab instances) 00093 MBErrorHandler_Init(); 00094 00095 ErrorCode rval = MB_SUCCESS; 00096 00097 int test_case_num = atoi( argv[1] ); 00098 switch( test_case_num ) 00099 { 00100 case 1: 00101 rval = TestErrorHandling_1();MB_CHK_ERR( rval ); 00102 break; 00103 case 2: 00104 rval = TestErrorHandling_2();MB_CHK_ERR( rval ); 00105 break; 00106 case 3: 00107 rval = TestErrorHandling_3();MB_CHK_ERR( rval ); 00108 break; 00109 case 4: 00110 rval = TestErrorHandling_4();MB_CHK_ERR( rval ); 00111 break; 00112 default: 00113 break; 00114 } 00115 00116 // Finalize error handler, optional for this example (using moab instances) 00117 MBErrorHandler_Finalize(); 00118 00119 #ifdef MOAB_HAVE_MPI 00120 MPI_Finalize(); 00121 #endif 00122 00123 return 0; 00124 }
