MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*This function profiles the performance of the AHF datastructure */ 00002 #include <iostream> 00003 #include <cassert> 00004 #include <ctime> 00005 #include <vector> 00006 #include "moab/Core.hpp" 00007 #include "moab/Range.hpp" 00008 #include "moab/MeshTopoUtil.hpp" 00009 #include "moab/HalfFacetRep.hpp" 00010 #include "moab/NestedRefine.hpp" 00011 #include "../TestUtil.hpp" 00012 #include "moab/CpuTimer.hpp" 00013 00014 #ifdef MOAB_HAVE_MPI 00015 #include "moab/ParallelComm.hpp" 00016 #include "MBParallelConventions.h" 00017 #include "moab/FileOptions.hpp" 00018 #include "MBTagConventions.hpp" 00019 #include "moab_mpi.h" 00020 #endif 00021 00022 using namespace moab; 00023 00024 #ifdef MOAB_HAVE_MPI 00025 std::string read_options; 00026 #endif 00027 00028 int number_tests_successful = 0; 00029 int number_tests_failed = 0; 00030 00031 struct mesh_mem 00032 { 00033 00034 /* unsigned long long total_storage; 00035 unsigned long long amortized_total_storage; 00036 unsigned long long entity_storage; 00037 unsigned long long amortized_entity_storage; 00038 unsigned long long adjacency_storage; 00039 unsigned long long amortized_adjacency_storage; 00040 unsigned long long tag_storage; 00041 unsigned long long amortized_tag_storage;*/ 00042 00043 // Total storage 00044 unsigned long long total_storage; 00045 unsigned long long total_amortized_storage; 00046 00047 // Adjacency storage 00048 unsigned long long adj_storage; 00049 unsigned long long amortized_adj_storage; 00050 00051 // Vertex storage 00052 unsigned long long vertex_storage; 00053 unsigned long long amortized_vertex_storage; 00054 00055 // Entity storage 00056 unsigned long long entity_storage; 00057 unsigned long long amortized_entity_storage; 00058 }; 00059 00060 enum OUTTYPE 00061 { 00062 TIME = 0, 00063 MEM, 00064 BOTH 00065 }; 00066 00067 void handle_error_code( ErrorCode rv, int& number_failed, int& number_successful ) 00068 { 00069 if( rv == MB_SUCCESS ) 00070 { 00071 #ifdef MOAB_HAVE_MPI 00072 int rank = 0; 00073 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00074 if( rank == 0 ) std::cout << "Success"; 00075 #else 00076 std::cout << "Success"; 00077 #endif 00078 number_successful++; 00079 } 00080 else 00081 { 00082 std::cout << "Failure"; 00083 number_failed++; 00084 } 00085 } 00086 00087 ErrorCode umr_perf_test( Core* mb, int* level_degrees, int num_levels, OUTTYPE output ) 00088 { 00089 ErrorCode error; 00090 Interface* mbImpl = mb; 00091 00092 mesh_mem* umem = new mesh_mem[num_levels + 2]; 00093 00094 CpuTimer* mt = new CpuTimer; 00095 double time_start, time_avg, time_total; 00096 00097 // Create ranges of entities in the initial mesh 00098 Range inverts, inedges, infaces, incells; 00099 error = mbImpl->get_entities_by_dimension( 0, 0, inverts ); 00100 error = mbImpl->get_entities_by_dimension( 0, 1, inedges ); 00101 error = mbImpl->get_entities_by_dimension( 0, 2, infaces ); 00102 error = mbImpl->get_entities_by_dimension( 0, 3, incells ); 00103 00104 Range init_ents; 00105 int dim = 0; 00106 if( inedges.size() ) 00107 { 00108 dim = 1; 00109 init_ents = inedges; 00110 } 00111 else if( infaces.size() ) 00112 { 00113 dim = 2; 00114 init_ents = infaces; 00115 } 00116 else if( incells.size() ) 00117 { 00118 dim = 3; 00119 init_ents = incells; 00120 } 00121 00122 std::cout << std::endl; 00123 std::cout << "Initial Mesh Size: " 00124 << "NV = " << inverts.size() << ", NE = " << init_ents.size() << std::endl; 00125 00126 if( output == MEM || output == BOTH ) 00127 { 00128 // Storage Costs before mesh hierarchy generation 00129 /* std::cout<<std::endl; 00130 unsigned long long sTotS, sTAS, sES, sAES, sAS, sAAS, sTS, sATS; 00131 sTotS = sTAS = sES = sAES = sAS = sAAS = sTS = sATS = 0; 00132 mbImpl->estimated_memory_use(NULL, 0, &sTotS, &sTAS, &sES, &sAES, &sAS, &sAAS, NULL, 0, 00133 &sTS, &sATS); 00134 00135 umem[0].total_storage = sTotS; 00136 umem[0].amortized_total_storage = sTAS; 00137 umem[0].entity_storage = sES; 00138 umem[0].amortized_entity_storage = sAES; 00139 umem[0].adjacency_storage = sAS; 00140 umem[0].amortized_adjacency_storage = sAAS; 00141 umem[0].tag_storage = sTS; 00142 umem[0].amortized_tag_storage = sATS;*/ 00143 00144 unsigned long long vTotS, vTAS, vES, vAES, vAS, vAAS, vTS, vATS; 00145 vTotS = vTAS = vES = vAES = vAS = vAAS = vTS = vATS = 0; 00146 mbImpl->estimated_memory_use( inverts, &vTotS, &vTAS, &vES, &vAES, &vAS, &vAAS, NULL, 0, &vTS, &vATS ); 00147 00148 unsigned long long eTotS, eTAS, eES, eAES, eAS, eAAS, eTS, eATS; 00149 eTotS = eTAS = eES = eAES = eAS = eAAS = eTS = eATS = 0; 00150 mbImpl->estimated_memory_use( init_ents, &eTotS, &eTAS, &eES, &eAES, &eAS, &eAAS, NULL, 0, &eTS, &eATS ); 00151 00152 umem[0].total_storage = vTotS + eTotS; 00153 umem[0].vertex_storage = vES; 00154 umem[0].entity_storage = eES; 00155 // umem[0].tag_storage = vTS+eTS; 00156 00157 std::cout << "MEMORY STORAGE:: Initial Mesh" << std::endl; 00158 std::cout << std::endl; 00159 std::cout << "Total storage = " << umem[0].total_storage << std::endl; 00160 std::cout << "Vertex storage = " << umem[0].vertex_storage << std::endl; 00161 std::cout << "Entity storage = " << umem[0].entity_storage << std::endl; 00162 // std::cout<<"Tag storage = "<< umem[0].tag_storage<<std::endl; 00163 00164 /* std::cout<<"Total storage = "<<umem[0].total_storage<<std::endl; 00165 std::cout<<"Total amortized storage = "<< umem[0].amortized_total_storage<<std::endl; 00166 std::cout<<"Entity storage = "<<umem[0].entity_storage<<std::endl; 00167 std::cout<<"Amortized entity storage = "<<umem[0].amortized_entity_storage<<std::endl; 00168 std::cout<<"Adjacency storage = "<< umem[0].adjacency_storage <<std::endl; 00169 std::cout<<"Amortized adjacency storage = "<<umem[0].amortized_adjacency_storage 00170 <<std::endl; std::cout<<"Tag storage = "<< umem[0].tag_storage<<std::endl; 00171 std::cout<<"Amortized tag storage = "<<umem[0].amortized_tag_storage <<std::endl;*/ 00172 std::cout << std::endl; 00173 } 00174 00175 // Create an hm object and generate the hierarchy 00176 std::cout << "Creating a hm object" << std::endl; 00177 NestedRefine uref( mb ); 00178 std::vector< EntityHandle > set; 00179 00180 std::cout << "Starting hierarchy generation" << std::endl; 00181 time_start = mt->time_elapsed(); 00182 error = uref.generate_mesh_hierarchy( num_levels, level_degrees, set );CHECK_ERR( error ); 00183 00184 time_total = mt->time_elapsed() - time_start; 00185 std::cout << "Finished hierarchy generation" << std::endl; 00186 00187 if( output == TIME || output == BOTH ) 00188 { 00189 std::cout << "Total time in secs:: generate mesh hierarchy:: L = " << num_levels << " :: " << time_total 00190 << std::endl; 00191 std::cout << std::endl; 00192 } 00193 00194 // Loop over each mesh level and check its topological properties 00195 for( int l = 0; l < num_levels; l++ ) 00196 { 00197 // Get the current mesh level using its meshset 00198 Range verts, ents; 00199 error = mbImpl->get_entities_by_type( set[l + 1], MBVERTEX, verts );CHECK_ERR( error ); 00200 error = mbImpl->get_entities_by_dimension( set[l + 1], dim, ents );CHECK_ERR( error ); 00201 00202 std::cout << "Mesh size for level " << l + 1 << " :: deg = " << level_degrees[l] << " :: NV = " << verts.size() 00203 << ", NE = " << ents.size() << std::endl; 00204 00205 if( output == MEM || output == BOTH ) 00206 { 00207 // Storage Costs 00208 std::cout << std::endl; 00209 unsigned long long vTotS, vTAS, vES, vAES, vAS, vAAS, vTS, vATS; 00210 vTotS = vTAS = vES = vAES = vAS = vAAS = vTS = vATS = 0; 00211 mbImpl->estimated_memory_use( verts, &vTotS, &vTAS, &vES, &vAES, &vAS, &vAAS, NULL, 0, &vTS, &vATS ); 00212 unsigned long long eTotS, eTAS, eES, eAES, eAS, eAAS, eTS, eATS; 00213 eTotS = eTAS = eES = eAES = eAS = eAAS = eTS = eATS = 0; 00214 mbImpl->estimated_memory_use( ents, &eTotS, &eTAS, &eES, &eAES, &eAS, &eAAS, NULL, 0, &eTS, &eATS ); 00215 00216 umem[l + 1].total_storage = vTotS + eTotS; 00217 umem[l + 1].vertex_storage = vES; 00218 umem[l + 1].entity_storage = eES; 00219 // umem[l+1].tag_storage = vTS+eTS; 00220 00221 /* umem[l+1].total_storage = vTotS+eTotS; 00222 umem[l+1].amortized_total_storage = vTAS+eTAS; 00223 umem[l+1].entity_storage = vES+eES; 00224 umem[l+1].amortized_entity_storage = vAES+eAES; 00225 umem[l+1].adjacency_storage = vAS+eAS; 00226 umem[l+1].amortized_adjacency_storage = vAAS+eAAS; 00227 umem[l+1].tag_storage = vTS+eTS; 00228 umem[l+1].amortized_tag_storage = vATS+eATS;*/ 00229 00230 std::cout << "MEMORY STORAGE:: Mesh level " << l + 1 << std::endl; 00231 std::cout << std::endl; 00232 std::cout << "Total storage = " << umem[l + 1].total_storage << std::endl; 00233 std::cout << "Vertex storage = " << umem[l + 1].vertex_storage << std::endl; 00234 std::cout << "Entity storage = " << umem[l + 1].entity_storage << std::endl; 00235 // std::cout<<"Tag storage = "<< umem[l+1].tag_storage<<std::endl; 00236 00237 /* std::cout<<"Total storage = "<<umem[l+1].total_storage<<std::endl; 00238 std::cout<<"Total amortized storage = "<< 00239 umem[l+1].amortized_total_storage<<std::endl; std::cout<<"Entity storage = 00240 "<<umem[l+1].entity_storage<<std::endl; std::cout<<"Amortized entity storage = 00241 "<<umem[l+1].amortized_entity_storage<<std::endl; std::cout<<"Adjacency storage = "<< 00242 umem[l+1].adjacency_storage <<std::endl; std::cout<<"Amortized adjacency storage = 00243 "<<umem[l+1].amortized_adjacency_storage <<std::endl; std::cout<<"Tag storage = "<< 00244 umem[l+1].tag_storage<<std::endl; std::cout<<"Amortized tag storage = 00245 "<<umem[l+1].amortized_tag_storage <<std::endl;*/ 00246 std::cout << std::endl; 00247 } 00248 00249 if( output == BOTH ) 00250 { 00251 // Loop over all vertices and get their coordinates 00252 time_start = mt->time_elapsed(); 00253 for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) 00254 { 00255 double coords[3]; 00256 EntityHandle vid = *i; 00257 error = uref.get_coordinates( &vid, 1, (int)l, &coords[0] );CHECK_ERR( error ); 00258 } 00259 time_total = mt->time_elapsed() - time_start; 00260 time_avg = time_total / (double)verts.size(); 00261 00262 std::cout << "Class NR :: OPERATION:: get_coordinates" 00263 << " :: Time_total = " << time_total << " :: Time_avg = " << time_avg << std::endl; 00264 00265 time_start = mt->time_elapsed(); 00266 for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) 00267 { 00268 double coords[3]; 00269 EntityHandle vid = *i; 00270 error = mbImpl->get_coords( &vid, 1, &coords[0] );CHECK_ERR( error ); 00271 } 00272 time_total = mt->time_elapsed() - time_start; 00273 time_avg = time_total / (double)verts.size(); 00274 00275 std::cout << "Class Core :: OPERATION:: get_coordinates" 00276 << " :: Time_total = " << time_total << " :: Time_avg = " << time_avg << std::endl; 00277 00278 // Loop over all entities and get their connectivity 00279 time_start = mt->time_elapsed(); 00280 for( Range::iterator i = ents.begin(); i != ents.end(); ++i ) 00281 { 00282 std::vector< EntityHandle > conn; 00283 error = uref.get_connectivity( *i, l, conn );CHECK_ERR( error ); 00284 } 00285 time_total = mt->time_elapsed() - time_start; 00286 time_avg = time_total / (double)ents.size(); 00287 std::cout << std::endl; 00288 std::cout << "Class NR :: OPERATION:: get_connectivity" 00289 << " :: Time_total = " << time_total << " :: Time_avg = " << time_avg << std::endl; 00290 00291 time_start = mt->time_elapsed(); 00292 for( Range::iterator i = ents.begin(); i != ents.end(); ++i ) 00293 { 00294 std::vector< EntityHandle > conn; 00295 error = mbImpl->get_connectivity( &*i, 1, conn );CHECK_ERR( error ); 00296 } 00297 time_total = mt->time_elapsed() - time_start; 00298 time_avg = time_total / (double)ents.size(); 00299 00300 std::cout << "Class Core :: OPERATION:: get_connectivity" 00301 << " :: Time_total = " << time_total << " :: Time_avg = " << time_avg << std::endl; 00302 std::cout << std::endl; 00303 } 00304 } 00305 00306 /* if (output == MEM || output == BOTH){ 00307 00308 unsigned long long sTotS, sTAS, sES, sAES, sAS, sAAS, sTS, sATS; 00309 sTotS = sTAS = sES = sAES = sAS = sAAS = sTS = sATS = 0; 00310 mbImpl->estimated_memory_use(NULL, 0, &sTotS, &sTAS, &sES, &sAES, &sAS, &sAAS, NULL, 0, 00311 &sTS, &sATS); 00312 00313 umem[num_levels+1].total_storage = sTotS; 00314 umem[num_levels+1].amortized_total_storage = sTAS; 00315 umem[num_levels+1].entity_storage = sES; 00316 umem[num_levels+1].amortized_entity_storage = sAES; 00317 umem[num_levels+1].adjacency_storage = sAS; 00318 umem[num_levels+1].amortized_adjacency_storage = sAAS; 00319 umem[num_levels+1].tag_storage = sTS; 00320 umem[num_levels+1].amortized_tag_storage = sATS; 00321 00322 std::cout<<"MEMORY STORAGE:: WHOLE MESH HIERARCHY"<<std::endl; 00323 std::cout<<std::endl; 00324 std::cout<<"Total storage = "<<umem[num_levels+1].total_storage<<std::endl; 00325 std::cout<<"Total amortized storage = "<< 00326 umem[num_levels+1].amortized_total_storage<<std::endl; std::cout<<"Entity storage = 00327 "<<umem[num_levels+1].entity_storage<<std::endl; std::cout<<"Amortized entity storage = 00328 "<<umem[num_levels+1].amortized_entity_storage<<std::endl; std::cout<<"Adjacency storage = 00329 "<< umem[num_levels+1].adjacency_storage <<std::endl; std::cout<<"Amortized adjacency storage 00330 = "<<umem[num_levels+1].amortized_adjacency_storage <<std::endl; std::cout<<"Tag storage = 00331 "<< umem[num_levels+1].tag_storage<<std::endl; std::cout<<"Amortized tag storage = 00332 "<<umem[num_levels+1].amortized_tag_storage <<std::endl; std::cout<<std::endl; 00333 }*/ 00334 00335 return MB_SUCCESS; 00336 } 00337 00338 ErrorCode create_simple_mesh( Core* mb, EntityType type ) 00339 { 00340 ErrorCode error; 00341 Interface* mbImpl = mb; 00342 if( type == MBEDGE ) 00343 { 00344 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0, 00345 4, 1, 0, 3, 1, 0, 2, 1, 0, 1, 1, 0, 0, 1, 0 }; 00346 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00347 00348 const int conn[] = { 1, 0, 1, 2, 2, 3, 3, 4, 4, 5, 5, 6, 6, 7, 7, 8, 8, 9, 9, 0 }; 00349 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 2; 00350 00351 EntityHandle verts[num_vtx], edges[num_elems]; 00352 for( size_t i = 0; i < num_vtx; ++i ) 00353 { 00354 error = mbImpl->create_vertex( coords + 3 * i, verts[i] ); 00355 if( error != MB_SUCCESS ) return error; 00356 } 00357 00358 for( size_t i = 0; i < num_elems; ++i ) 00359 { 00360 EntityHandle c[2]; 00361 c[0] = verts[conn[2 * i]]; 00362 c[1] = verts[conn[2 * i + 1]]; 00363 00364 error = mbImpl->create_element( MBEDGE, c, 2, edges[i] ); 00365 if( error != MB_SUCCESS ) return error; 00366 } 00367 } 00368 else if( type == MBTRI ) 00369 { 00370 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 2.5, 1, 0, 1.5, 1, 0, 0.5, 1, 00371 0, -0.5, 1, 0, -0.5, -1, 0, 0.5, -1, 0, 1.5, -1, 0, 2.5, -1, 0 }; 00372 00373 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00374 00375 const int conn[] = { 0, 5, 6, 0, 1, 5, 1, 4, 5, 1, 2, 4, 2, 3, 4, 00376 7, 8, 0, 8, 1, 0, 8, 9, 1, 9, 2, 1, 9, 10, 2 }; 00377 00378 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 3; 00379 00380 EntityHandle verts[num_vtx], faces[num_elems]; 00381 for( size_t i = 0; i < num_vtx; ++i ) 00382 { 00383 error = mbImpl->create_vertex( coords + 3 * i, verts[i] ); 00384 if( error != MB_SUCCESS ) return error; 00385 } 00386 00387 for( size_t i = 0; i < num_elems; ++i ) 00388 { 00389 EntityHandle c[3]; 00390 for( int j = 0; j < 3; j++ ) 00391 c[j] = verts[conn[3 * i + j]]; 00392 00393 error = mbImpl->create_element( MBTRI, c, 3, faces[i] ); 00394 if( error != MB_SUCCESS ) return error; 00395 } 00396 } 00397 else if( type == MBQUAD ) 00398 { 00399 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0, 5, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 00400 3, 1, 0, 4, 1, 0, 5, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 3, 2, 0, 4, 2, 0, 5, 2, 0 }; 00401 00402 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00403 00404 const int conn[] = { 0, 1, 7, 6, 1, 2, 8, 7, 2, 3, 9, 8, 3, 4, 10, 9, 4, 5, 11, 10, 00405 6, 7, 13, 12, 7, 8, 14, 13, 8, 9, 15, 14, 9, 10, 16, 15, 10, 11, 17, 16 }; 00406 00407 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4; 00408 00409 EntityHandle verts[num_vtx], faces[num_elems]; 00410 for( size_t i = 0; i < num_vtx; ++i ) 00411 { 00412 error = mbImpl->create_vertex( coords + 3 * i, verts[i] ); 00413 if( error != MB_SUCCESS ) return error; 00414 } 00415 00416 for( size_t i = 0; i < num_elems; ++i ) 00417 { 00418 EntityHandle c[4]; 00419 for( int j = 0; j < 4; j++ ) 00420 c[j] = verts[conn[4 * i + j]]; 00421 00422 error = mbImpl->create_element( MBQUAD, c, 4, faces[i] ); 00423 if( error != MB_SUCCESS ) return error; 00424 } 00425 } 00426 else if( type == MBTET ) 00427 { 00428 const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0, 0, 0, 1 }; 00429 00430 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00431 00432 const int conn[] = { 0, 1, 2, 5, 3, 0, 2, 5, 4, 1, 0, 5, 4, 0, 3, 5 }; 00433 00434 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4; 00435 00436 EntityHandle verts[num_vtx], cells[num_elems]; 00437 for( size_t i = 0; i < num_vtx; ++i ) 00438 { 00439 error = mbImpl->create_vertex( coords + 3 * i, verts[i] ); 00440 if( error != MB_SUCCESS ) return error; 00441 } 00442 00443 for( size_t i = 0; i < num_elems; ++i ) 00444 { 00445 EntityHandle c[4]; 00446 for( int j = 0; j < 4; j++ ) 00447 c[j] = verts[conn[4 * i + j]]; 00448 00449 error = mbImpl->create_element( MBTET, c, 4, cells[i] ); 00450 if( error != MB_SUCCESS ) return error; 00451 } 00452 } 00453 else if( type == MBHEX ) 00454 { 00455 const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 00456 0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1 }; 00457 const size_t num_vtx = sizeof( coords ) / sizeof( double ) / 3; 00458 00459 const int conn[] = { 0, 1, 4, 3, 9, 10, 13, 12, 1, 2, 5, 4, 10, 11, 14, 13, 00460 3, 4, 7, 6, 12, 13, 16, 15, 4, 5, 8, 7, 13, 14, 17, 16 }; 00461 const size_t num_elems = sizeof( conn ) / sizeof( int ) / 8; 00462 00463 EntityHandle verts[num_vtx], cells[num_elems]; 00464 for( size_t i = 0; i < num_vtx; ++i ) 00465 { 00466 error = mbImpl->create_vertex( coords + 3 * i, verts[i] ); 00467 if( error != MB_SUCCESS ) return error; 00468 } 00469 00470 for( size_t i = 0; i < num_elems; ++i ) 00471 { 00472 EntityHandle c[8]; 00473 for( int j = 0; j < 8; j++ ) 00474 c[j] = verts[conn[8 * i + j]]; 00475 00476 error = mbImpl->create_element( MBHEX, c, 8, cells[i] ); 00477 if( error != MB_SUCCESS ) return error; 00478 } 00479 } 00480 return MB_SUCCESS; 00481 } 00482 00483 ErrorCode test_mesh( EntityType type, int* level_degrees, int num_level ) 00484 { 00485 ErrorCode error; 00486 Core mb; 00487 00488 error = create_simple_mesh( &mb, type ); 00489 if( error != MB_SUCCESS ) return error; 00490 00491 OUTTYPE output = BOTH; 00492 error = umr_perf_test( &mb, level_degrees, num_level, output ); 00493 if( error != MB_SUCCESS ) return error; 00494 00495 return MB_SUCCESS; 00496 } 00497 00498 ErrorCode test_1D() 00499 { 00500 ErrorCode error; 00501 std::cout << std::endl; 00502 std::cout << "EntityType = MBEDGE" << std::endl; 00503 00504 std::cout << "Deg = 2" << std::endl; 00505 int deg[7] = { 5, 5, 2, 2, 2, 2, 2 }; 00506 int len = sizeof( deg ) / sizeof( int ); 00507 error = test_mesh( MBEDGE, deg, len ); 00508 if( error != MB_SUCCESS ) return error; 00509 00510 std::cout << std::endl; 00511 std::cout << "Deg = 3" << std::endl; 00512 deg[4] = 3; 00513 deg[5] = 3; 00514 deg[6] = 3; 00515 error = test_mesh( MBEDGE, deg, len ); 00516 if( error != MB_SUCCESS ) return error; 00517 00518 std::cout << std::endl; 00519 std::cout << "Deg = 5" << std::endl; 00520 deg[4] = 5; 00521 deg[5] = 5; 00522 deg[6] = 5; 00523 error = test_mesh( MBEDGE, deg, len ); 00524 if( error != MB_SUCCESS ) return error; 00525 00526 return MB_SUCCESS; 00527 } 00528 00529 ErrorCode test_2D() 00530 { 00531 ErrorCode error; 00532 EntityType type = MBTRI; 00533 std::cout << std::endl; 00534 std::cout << "EntityType = MBTRI" << std::endl; 00535 00536 std::cout << "Deg = 2" << std::endl; 00537 int deg[5] = { 5, 2, 2, 2, 2 }; 00538 int len = sizeof( deg ) / sizeof( int ); 00539 error = test_mesh( type, deg, len ); 00540 if( error != MB_SUCCESS ) return error; 00541 00542 std::cout << std::endl; 00543 std::cout << "Deg = 3" << std::endl; 00544 deg[2] = 3; 00545 deg[3] = 3; 00546 deg[4] = 3; 00547 error = test_mesh( type, deg, len ); 00548 if( error != MB_SUCCESS ) return error; 00549 00550 std::cout << std::endl; 00551 std::cout << "Deg = 5" << std::endl; 00552 deg[2] = 5; 00553 deg[3] = 5; 00554 deg[4] = 5; 00555 error = test_mesh( type, deg, len ); 00556 if( error != MB_SUCCESS ) return error; 00557 00558 type = MBQUAD; 00559 std::cout << std::endl; 00560 std::cout << "EntityType = MBQUAD" << std::endl; 00561 00562 std::cout << "Deg = 2" << std::endl; 00563 deg[2] = 2; 00564 deg[3] = 2; 00565 deg[4] = 2; 00566 error = test_mesh( type, deg, len ); 00567 if( error != MB_SUCCESS ) return error; 00568 00569 std::cout << std::endl; 00570 std::cout << "Deg = 3" << std::endl; 00571 deg[2] = 3; 00572 deg[3] = 3; 00573 deg[4] = 3; 00574 error = test_mesh( type, deg, len ); 00575 if( error != MB_SUCCESS ) return error; 00576 00577 std::cout << std::endl; 00578 std::cout << "Deg = 5" << std::endl; 00579 deg[2] = 5; 00580 deg[3] = 5; 00581 deg[4] = 5; 00582 error = test_mesh( type, deg, len ); 00583 if( error != MB_SUCCESS ) return error; 00584 00585 return MB_SUCCESS; 00586 } 00587 00588 ErrorCode test_3D() 00589 { 00590 ErrorCode error; 00591 EntityType type = MBTET; 00592 std::cout << std::endl; 00593 std::cout << "EntityType = MBTET" << std::endl; 00594 00595 std::cout << "Deg = 2" << std::endl; 00596 int deg[6] = { 2, 2, 2, 2, 2, 2 }; 00597 int len = sizeof( deg ) / sizeof( int ); 00598 error = test_mesh( type, deg, len ); 00599 if( error != MB_SUCCESS ) return error; 00600 00601 std::cout << std::endl; 00602 std::cout << "Deg = 3" << std::endl; 00603 deg[3] = 3; 00604 deg[4] = 3; 00605 deg[5] = 3; 00606 error = test_mesh( type, deg, len ); 00607 if( error != MB_SUCCESS ) return error; 00608 00609 type = MBHEX; 00610 std::cout << std::endl; 00611 std::cout << "EntityType = MBHEX" << std::endl; 00612 00613 std::cout << "Deg = 2" << std::endl; 00614 deg[3] = 2; 00615 deg[4] = 2; 00616 deg[5] = 2; 00617 error = test_mesh( type, deg, len ); 00618 if( error != MB_SUCCESS ) return error; 00619 00620 std::cout << std::endl; 00621 std::cout << "Deg = 3" << std::endl; 00622 deg[3] = 3; 00623 deg[4] = 3; 00624 deg[5] = 3; 00625 error = test_mesh( type, deg, len ); 00626 if( error != MB_SUCCESS ) return error; 00627 00628 return MB_SUCCESS; 00629 } 00630 00631 ErrorCode perf_inmesh( const char* filename, int* level_degrees, int num_levels, OUTTYPE output ) 00632 { 00633 ErrorCode error; 00634 Core mb; 00635 Interface* mbImpl = &mb; 00636 00637 #ifdef MOAB_HAVE_MPI 00638 int procs = 1; 00639 MPI_Comm_size( MPI_COMM_WORLD, &procs ); 00640 00641 if( procs > 1 ) 00642 { 00643 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; 00644 00645 error = mbImpl->load_file( filename, 0, read_options.c_str() );CHECK_ERR( error ); 00646 } 00647 else if( procs == 1 ) 00648 { 00649 #endif 00650 error = mbImpl->load_file( filename );CHECK_ERR( error ); 00651 #ifdef MOAB_HAVE_MPI 00652 } 00653 #endif 00654 // OUTTYPE output = MEM; 00655 error = umr_perf_test( &mb, level_degrees, num_levels, output ); 00656 if( error != MB_SUCCESS ) return error; 00657 00658 return MB_SUCCESS; 00659 } 00660 00661 int main( int argc, char* argv[] ) 00662 { 00663 00664 #ifdef MOAB_HAVE_MPI 00665 MPI_Init( &argc, &argv ); 00666 00667 int nprocs, rank; 00668 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00669 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00670 #endif 00671 00672 #ifdef MOAB_HAVE_MPI 00673 if( rank == 0 ) std::cout << " para_umr_perf: "; 00674 #else 00675 std::cout << "umr_perf:"; 00676 #endif 00677 00678 if( argc == 1 ) 00679 { 00680 ErrorCode result; 00681 00682 result = test_1D(); 00683 handle_error_code( result, number_tests_failed, number_tests_successful ); 00684 std::cout << "\n"; 00685 00686 result = test_2D(); 00687 handle_error_code( result, number_tests_failed, number_tests_successful ); 00688 std::cout << "\n"; 00689 00690 result = test_3D(); 00691 handle_error_code( result, number_tests_failed, number_tests_successful ); 00692 std::cout << "\n"; 00693 } 00694 00695 else if( argc == 2 ) 00696 { 00697 const char* filename = argv[1]; 00698 ErrorCode result; 00699 00700 OUTTYPE output = MEM; 00701 00702 if( output == MEM ) 00703 { 00704 int deg[3] = { 2, 2, 2 }; 00705 int len = sizeof( deg ) / sizeof( int ); 00706 result = perf_inmesh( filename, deg, len, output ); 00707 handle_error_code( result, number_tests_failed, number_tests_successful ); 00708 std::cout << "\n"; 00709 00710 deg[0] = 3; 00711 deg[1] = 3; 00712 deg[2] = 3; 00713 result = perf_inmesh( filename, deg, len, output ); 00714 handle_error_code( result, number_tests_failed, number_tests_successful ); 00715 std::cout << "\n"; 00716 00717 /* deg[0] = 5; deg[1] = 5; deg[2] = 5; 00718 result = perf_inmesh(filename, deg, len, output); 00719 handle_error_code(result, number_tests_failed, number_tests_successful); 00720 std::cout<<"\n";*/ 00721 } 00722 else if( output == TIME ) 00723 { 00724 for( int L = 0; L < 3; L++ ) 00725 { 00726 int* level_degrees = new int[L + 1]; 00727 for( int i = 0; i < L + 1; i++ ) 00728 { 00729 level_degrees[i] = 3; 00730 } 00731 00732 result = perf_inmesh( filename, level_degrees, L + 1, output ); 00733 handle_error_code( result, number_tests_failed, number_tests_successful ); 00734 std::cout << "\n"; 00735 00736 delete[] level_degrees; 00737 } 00738 } 00739 } 00740 else 00741 { 00742 std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl; 00743 return 1; 00744 } 00745 00746 #ifdef MOAB_HAVE_MPI 00747 MPI_Finalize(); 00748 #endif 00749 00750 return number_tests_failed; 00751 }
