MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "vtkMoabReader.h" 00002 00003 #include "SimpleMoab.h" 00004 #include "DataSetConverter.h" 00005 00006 00007 #include "vtkNew.h" 00008 #include "vtkObjectFactory.h" 00009 #include "vtkInformation.h" 00010 #include "vtkInformationVector.h" 00011 #include "vtkMultiBlockDataSet.h" 00012 #include "vtkUnstructuredGrid.h" 00013 00014 #include "vtkPolyData.h" 00015 00016 00017 vtkStandardNewMacro(vtkMoabReader) 00018 //------------------------------------------------------------------------------ 00019 vtkMoabReader::vtkMoabReader() 00020 { 00021 this->SetNumberOfInputPorts(0); 00022 this->FileName = NULL; 00023 } 00024 00025 //------------------------------------------------------------------------------ 00026 vtkMoabReader::~vtkMoabReader() 00027 { 00028 } 00029 00030 //------------------------------------------------------------------------------ 00031 int vtkMoabReader::RequestInformation(vtkInformation *request, 00032 vtkInformationVector **inputVector, 00033 vtkInformationVector *outputVector) 00034 { 00035 00036 //todo. Walk the file and display all the 2d and 3d elements that the users 00037 //could possibly want to load 00038 return this->Superclass::RequestInformation(request,inputVector,outputVector); 00039 } 00040 00041 //------------------------------------------------------------------------------ 00042 int vtkMoabReader::RequestData(vtkInformation *vtkNotUsed(request), 00043 vtkInformationVector **vtkNotUsed(inputVector), 00044 vtkInformationVector *outputVector) 00045 { 00046 //First pass is lets load in all 3d elements in a block called Volumes, 00047 //and load all 2d elements in a block called Surfaces 00048 00049 vtkInformation* outInfo = outputVector->GetInformationObject(0); 00050 vtkMultiBlockDataSet *output = 00051 vtkMultiBlockDataSet::SafeDownCast(outInfo->Get(vtkDataObject::DATA_OBJECT())); 00052 00053 vtkNew<vtkMultiBlockDataSet> volumeRoot; 00054 vtkNew<vtkMultiBlockDataSet> boundaryRoot; 00055 vtkNew<vtkMultiBlockDataSet> surfaceRoot; 00056 vtkNew<vtkMultiBlockDataSet> materialRoot; 00057 vtkNew<vtkMultiBlockDataSet> neumannRoot; 00058 vtkNew<vtkMultiBlockDataSet> dirichletRoot; 00059 00060 const int blockIndex = output->GetNumberOfBlocks(); 00061 output->SetBlock(blockIndex,volumeRoot.GetPointer()); 00062 output->SetBlock(blockIndex+1,boundaryRoot.GetPointer()); 00063 output->SetBlock(blockIndex+2,surfaceRoot.GetPointer()); 00064 output->SetBlock(blockIndex+3,materialRoot.GetPointer()); 00065 output->SetBlock(blockIndex+4,neumannRoot.GetPointer()); 00066 output->SetBlock(blockIndex+5,dirichletRoot.GetPointer()); 00067 00068 //boring work, set the names of the blocks 00069 output->GetMetaData(blockIndex)->Set(vtkCompositeDataSet::NAME(), "Volumes"); 00070 output->GetMetaData(blockIndex+1)->Set(vtkCompositeDataSet::NAME(), "Boundary"); 00071 output->GetMetaData(blockIndex+2)->Set(vtkCompositeDataSet::NAME(), "Surfaces"); 00072 output->GetMetaData(blockIndex+3)->Set(vtkCompositeDataSet::NAME(), "Material"); 00073 output->GetMetaData(blockIndex+4)->Set(vtkCompositeDataSet::NAME(), "Neumann Sets"); 00074 output->GetMetaData(blockIndex+5)->Set(vtkCompositeDataSet::NAME(), "Dirichlet Sets"); 00075 00076 smoab::GeomTag geom3Tag(3); 00077 smoab::GeomTag geom2Tag(2); 00078 smoab::GeomTag geom1Tag(1); 00079 smoab::MaterialTag matTag; 00080 smoab::NeumannTag neTag; 00081 smoab::DirichletTag diTag; 00082 00083 smoab::Interface interface(this->FileName); 00084 this->CreateSubBlocks(volumeRoot, &interface, &geom3Tag); 00085 this->CreateSubBlocks(boundaryRoot, &interface, &geom3Tag, &geom2Tag); 00086 00087 this->CreateSubBlocks(surfaceRoot, &interface, &geom2Tag); 00088 this->CreateSubBlocks(materialRoot, &interface, &matTag, &geom3Tag); 00089 this->CreateSubBlocks(neumannRoot, &interface, &neTag); 00090 this->CreateSubBlocks(dirichletRoot, &interface, &diTag); 00091 00092 return 1; 00093 } 00094 00095 00096 //------------------------------------------------------------------------------ 00097 void vtkMoabReader::CreateSubBlocks(vtkNew<vtkMultiBlockDataSet> & root, 00098 smoab::Interface* interface, 00099 smoab::Tag const* parentTag, 00100 smoab::Tag const* extractTag) 00101 { 00102 if(!extractTag) 00103 { 00104 extractTag = parentTag; 00105 } 00106 //basic premise: query the database for all tagged elements and create a new 00107 //multiblock elemenent for each 00108 smoab::DataSetConverter converter(*interface,extractTag); 00109 converter.readMaterialIds(true); 00110 converter.readProperties(true); 00111 00112 smoab::EntityHandle rootHandle = interface->getRoot(); 00113 smoab::Range parents = interface->findEntityRootParents(rootHandle); 00114 smoab::Range dimEnts = interface->findEntitiesWithTag(*parentTag, 00115 rootHandle); 00116 00117 smoab::Range geomParents = smoab::intersect(parents,dimEnts); 00118 00119 parents.clear(); //remove this range as it is unneeded 00120 dimEnts.clear(); 00121 00122 //now each item in range can be extracted into a different grid 00123 typedef smoab::Range::iterator iterator; 00124 vtkIdType index = 0; 00125 for(iterator i=geomParents.begin(); i != geomParents.end(); ++i) 00126 { 00127 vtkNew<vtkUnstructuredGrid> block; 00128 //fill the dataset with geometry and properties 00129 converter.fill(*i, block.GetPointer(),index); 00130 00131 //only add it if we have cells found 00132 if(block->GetNumberOfCells() > 0) 00133 { 00134 root->SetBlock(index,block.GetPointer()); 00135 std::string name = interface->name(*i); 00136 if(name.size() > 0) 00137 { 00138 root->GetMetaData(index)->Set(vtkCompositeDataSet::NAME(), name.c_str()); 00139 } 00140 ++index; 00141 } 00142 } 00143 } 00144 00145 //------------------------------------------------------------------------------ 00146 void vtkMoabReader::PrintSelf(ostream& os, vtkIndent indent) 00147 { 00148 this->Superclass::PrintSelf(os,indent); 00149 }
