MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "EdgeSizeSimpleImplicit.hpp" 00003 #include "SimplexTemplateRefiner.hpp" 00004 #include "MeshRefiner.hpp" 00005 #include "moab/Interface.hpp" 00006 #include "MBParallelConventions.h" 00007 00008 #ifdef MOAB_HAVE_MPI 00009 #include "moab/ParallelComm.hpp" 00010 #include "moab_mpi.h" 00011 #if defined( __MINGW32__ ) || defined( __MINGW64__ ) 00012 #include <time.h> 00013 #include <sys/time.h> 00014 #endif 00015 #endif // MOAB_HAVE_MPI 00016 00017 #include "TestUtil.hpp" 00018 00019 #include <iostream> 00020 #include <sstream> 00021 #include <map> 00022 00023 #include <ctime> 00024 00025 using namespace moab; 00026 00027 int TestMeshRefiner( int argc, char* argv[] ) 00028 { 00029 int nprocs, rank; 00030 #ifdef MOAB_HAVE_MPI 00031 MPI_Init( &argc, &argv ); 00032 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00033 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00034 #else // MOAB_HAVE_MPI 00035 nprocs = 1; 00036 rank = 0; 00037 #endif // MOAB_HAVE_MPI 00038 // sleep(20); 00039 00040 // Create the input mesh and, if -new-mesh is specified, an output mesh 00041 std::string ifname = argc > 1 ? argv[1] : TestDir + "fourVolsBare.cub"; 00042 bool input_is_output = false, do_output = false; 00043 std::string output_filename; 00044 if( argc > 2 ) 00045 { 00046 if( !strcmp( argv[2], "-new-mesh" ) ) 00047 input_is_output = true; 00048 else 00049 { 00050 do_output = true; 00051 output_filename = std::string( argv[2] ); 00052 } 00053 } 00054 00055 Interface* imesh = new Core; // ( rank, nprocs ); 00056 Interface* omesh = input_is_output ? imesh : new Core; // ( rank, nprocs ); 00057 00058 #ifdef MOAB_HAVE_MPI 00059 // Use an ParallelComm object to help set up the input mesh 00060 ParallelComm* ipcomm = new ParallelComm( imesh, MPI_COMM_WORLD ); 00061 // ReadParallel* readpar = new ReadParallel( imesh, ipcomm ); 00062 #endif // MOAB_HAVE_MPI 00063 00064 EntityHandle set_handle; 00065 std::ostringstream parallel_options; 00066 #ifdef MOAB_HAVE_MPI 00067 if( nprocs > 1 ) 00068 { 00069 parallel_options << "PARALLEL=READ_DELETE" 00070 << ";" // NB: You can use BCAST_DELETE or READ_DELETE here. 00071 //<< "PARALLEL=BCAST_DELETE" << ";" // NB: You can use BCAST_DELETE or READ_DELETE here. 00072 << "PARTITION=MATERIAL_SET" 00073 << ";" 00074 << "PARTITION_DISTRIBUTE" 00075 << ";" 00076 << "PARALLEL_RESOLVE_SHARED_ENTS" 00077 << ";" 00078 << "CPUTIME"; 00079 } 00080 #endif 00081 ErrorCode rval = imesh->create_meshset( MESHSET_SET, set_handle ); 00082 if( MB_SUCCESS != rval ) 00083 { 00084 std::cout << "Trouble creating set, exiting." << std::endl; 00085 return 1; 00086 } 00087 00088 rval = imesh->load_file( ifname.c_str(), &set_handle, parallel_options.str().c_str() ); 00089 if( MB_SUCCESS != rval ) 00090 { 00091 std::cout << "Trouble reading mesh file " << ifname << ", exiting." << std::endl; 00092 return 1; 00093 } 00094 00095 // Print out what we have so far, one process at a time 00096 for( int i = 0; i < nprocs; ++i ) 00097 { 00098 MPI_Barrier( MPI_COMM_WORLD ); 00099 if( i == rank ) 00100 { 00101 std::cout << "\n************** Rank: " << ( rank ) << " of: " << nprocs << "\n"; 00102 imesh->list_entities( 0, 0 ); 00103 std::cout << "**************\n\n"; 00104 } 00105 MPI_Barrier( MPI_COMM_WORLD ); 00106 } 00107 00108 // The refiner will need an implicit function to be used as an indicator function for 00109 // subdivision: 00110 EdgeSizeSimpleImplicit* eval = new EdgeSizeSimpleImplicit(); 00111 eval->set_ratio( 2. ); 00112 // Refine the mesh 00113 MeshRefiner* mref = new MeshRefiner( imesh, omesh ); 00114 SimplexTemplateRefiner* eref = new SimplexTemplateRefiner; 00115 mref->set_entity_refiner( eref ); 00116 // mref->add_vertex_tag( tag_floatular ); 00117 // mref->add_vertex_tag( tag_intular ); 00118 // (We don't add tag_gid to the refiner's tag manager because it is special) 00119 eref->set_edge_size_evaluator( eval ); 00120 Range ents_to_refine; 00121 imesh->get_entities_by_type( set_handle, MBTET, ents_to_refine ); // refine just the tets 00122 // ents_to_refine.insert( set_handle ); // refine everything multiple times (because subsets are 00123 // not disjoint) 00124 #ifdef _WIN32 00125 struct timeval tic, toc; 00126 gettimeofday( &tic, 0 ); 00127 mref->refine( ents_to_refine ); 00128 gettimeofday( &toc, 0 ); 00129 std::cout << "\nTime: " << ( ( toc.tv_sec - tic.tv_sec ) * 1000 + ( toc.tv_usec - tic.tv_usec ) / 1000. ) 00130 << " ms\n\n"; 00131 #endif 00132 00133 if( do_output ) 00134 { 00135 parallel_options.clear(); 00136 if( nprocs > 1 ) parallel_options << "PARALLEL=WRITE_PART"; 00137 omesh->write_file( output_filename.c_str(), NULL, parallel_options.str().c_str() ); 00138 } 00139 00140 // Print out the results, one process at a time 00141 #ifdef MOAB_HAVE_MPI 00142 for( int i = 0; i < nprocs; ++i ) 00143 { 00144 MPI_Barrier( MPI_COMM_WORLD ); 00145 if( i == rank ) 00146 { 00147 std::cout << "\n************** Rank: " << ( rank ) << " of: " << nprocs << "\n"; 00148 omesh->list_entities( 0, 0 ); 00149 std::cout << "**************\n\n"; 00150 } 00151 MPI_Barrier( MPI_COMM_WORLD ); 00152 } 00153 #else // MOAB_HAVE_MPI 00154 omesh->list_entities( 0, 1 ); 00155 #endif // MOAB_HAVE_MPI 00156 00157 // Clean up 00158 #ifdef MOAB_HAVE_MPI 00159 // delete readpar; 00160 delete ipcomm; 00161 #endif // MOAB_HAVE_MPI 00162 if( omesh != imesh ) delete omesh; 00163 delete imesh; 00164 delete mref; // mref will delete eref 00165 00166 #ifdef MOAB_HAVE_MPI 00167 MPI_Barrier( MPI_COMM_WORLD ); 00168 MPI_Finalize(); 00169 #endif // MOAB_HAVE_MPI 00170 00171 return 0; 00172 } 00173 00174 int main( int argc, char* argv[] ) 00175 { 00176 return TestMeshRefiner( argc, argv ); 00177 }
