MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #include "MBTagConventions.hpp" 00004 #define IS_BUILDING_MB 00005 #include "ReadIDEAS.hpp" 00006 #include "moab/Range.hpp" 00007 #include <cmath> 00008 #include <algorithm> 00009 00010 using namespace moab; 00011 00012 #ifdef MESHDIR 00013 static const char example[] = STRINGIFY( MESHDIR ) "/io/test.unv"; 00014 #else 00015 static const char example[] = "test.unv"; 00016 #endif 00017 00018 void read_file( Interface& moab, const char* input_file ); 00019 void test_read_nodes(); 00020 void test_read_tets(); 00021 void test_read_hexes(); 00022 void test_read_material_set(); 00023 void test_read_physical_set(); 00024 00025 int main() 00026 { 00027 int result = 0; 00028 00029 result += RUN_TEST( test_read_nodes ); 00030 result += RUN_TEST( test_read_tets ); 00031 result += RUN_TEST( test_read_hexes ); 00032 result += RUN_TEST( test_read_material_set ); 00033 result += RUN_TEST( test_read_physical_set ); 00034 00035 return result; 00036 } 00037 00038 void read_file( Interface& moab, const char* input_file ) 00039 { 00040 ErrorCode rval = moab.load_file( input_file );CHECK_ERR( rval ); 00041 } 00042 00043 void test_read_nodes() 00044 { 00045 const double eps = 1e-6; 00046 ErrorCode rval; 00047 Core moab; 00048 Interface& mb = moab; 00049 read_file( moab, example ); 00050 00051 std::vector< EntityHandle > nodes; 00052 rval = mb.get_entities_by_type( 0, MBVERTEX, nodes );CHECK_ERR( rval ); 00053 CHECK_EQUAL( (size_t)17, nodes.size() ); 00054 00055 Tag id_tag = mb.globalId_tag(); 00056 00057 std::vector< int > ids( nodes.size() ); 00058 rval = mb.tag_get_data( id_tag, &nodes[0], nodes.size(), &ids[0] );CHECK_ERR( rval ); 00059 00060 std::vector< int > sorted_ids( ids ); 00061 std::sort( sorted_ids.begin(), sorted_ids.end() ); 00062 00063 std::vector< double > coords( 3 * nodes.size() ); 00064 rval = mb.get_coords( &nodes[0], nodes.size(), &coords[0] );CHECK_ERR( rval ); 00065 00066 int idx, pos = 0; 00067 // shared between 2 tets and 2 prisms 00068 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00069 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00070 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00071 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00072 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00073 00074 ++pos; 00075 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00076 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00077 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00078 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00079 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00080 00081 ++pos; 00082 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00083 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00084 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00085 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00086 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00087 00088 // id=4 00089 ++pos; 00090 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00091 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00092 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00093 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00094 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00095 00096 ++pos; 00097 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00098 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00099 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00100 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00101 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00102 00103 ++pos; 00104 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00105 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00106 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00107 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00108 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00109 00110 ++pos; 00111 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00112 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00113 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00114 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00115 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00116 00117 // id=8 00118 ++pos; 00119 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00120 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00121 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00122 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00123 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00124 00125 ++pos; 00126 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00127 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00128 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00129 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00130 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00131 00132 ++pos; 00133 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00134 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00135 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00136 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00137 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00138 00139 ++pos; 00140 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00141 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00142 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00143 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00144 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00145 00146 // id=12 00147 ++pos; 00148 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00149 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00150 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00151 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00152 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00153 00154 ++pos; 00155 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00156 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00157 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0000022760448197, eps ); 00158 CHECK_REAL_EQUAL( coords[3 * idx + 1], -2.2760448196157412e-06, eps ); 00159 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00160 00161 ++pos; 00162 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00163 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00164 CHECK_REAL_EQUAL( coords[3 * idx + 0], -2.2760448196157412e-6, eps ); 00165 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0000022760448197, eps ); 00166 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00167 00168 ++pos; 00169 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00170 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00171 CHECK_REAL_EQUAL( coords[3 * idx + 0], -2.2760448197267635e-6, eps ); 00172 CHECK_REAL_EQUAL( coords[3 * idx + 1], -2.2760448196157412e-6, eps ); 00173 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00174 00175 // id=16 00176 ++pos; 00177 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00178 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00179 CHECK_REAL_EQUAL( coords[3 * idx + 0], 5.0e-1, eps ); 00180 CHECK_REAL_EQUAL( coords[3 * idx + 1], 5.0e-1, eps ); 00181 CHECK_REAL_EQUAL( coords[3 * idx + 2], 3.0, eps ); 00182 00183 ++pos; 00184 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00185 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00186 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0000022760448197, eps ); 00187 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0000022760448197, eps ); 00188 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00189 } 00190 00191 void test_read_tets() 00192 { 00193 ErrorCode rval; 00194 Core moab; 00195 Interface& mb = moab; 00196 read_file( moab, example ); 00197 00198 std::vector< EntityHandle > tets; 00199 rval = mb.get_entities_by_type( 0, MBTET, tets );CHECK_ERR( rval ); 00200 CHECK_EQUAL( (size_t)2, tets.size() ); 00201 00202 Tag id_tag = mb.globalId_tag(); 00203 00204 std::vector< int > ids( tets.size() ); 00205 rval = mb.tag_get_data( id_tag, &tets[0], tets.size(), &ids[0] );CHECK_ERR( rval ); 00206 00207 if( ids[0] != 3 ) 00208 { 00209 std::swap( ids[0], ids[1] ); 00210 std::swap( tets[0], tets[1] ); 00211 } 00212 00213 int vtx_ids[4]; 00214 const EntityHandle* conn; 00215 int len; 00216 00217 // The first tet has id=3 00218 const int conn1[] = { 13, 14, 15, 16 }; 00219 int pos = 0, offset = 3; 00220 CHECK_EQUAL( pos + offset, ids[pos] ); 00221 rval = mb.get_connectivity( tets[pos], conn, len );CHECK_ERR( rval ); 00222 CHECK_EQUAL( 4, len ); 00223 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00224 CHECK_ARRAYS_EQUAL( conn1, 4, vtx_ids, len ); 00225 00226 // The second tet has id=4 00227 const int conn2[] = { 13, 17, 14, 16 }; 00228 ++pos; 00229 CHECK_EQUAL( pos + offset, ids[pos] ); 00230 rval = mb.get_connectivity( tets[pos], conn, len );CHECK_ERR( rval ); 00231 CHECK_EQUAL( 4, len ); 00232 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00233 CHECK_ARRAYS_EQUAL( conn2, 4, vtx_ids, len ); 00234 } 00235 00236 void test_read_hexes() 00237 { 00238 ErrorCode rval; 00239 Core moab; 00240 Interface& mb = moab; 00241 read_file( moab, example ); 00242 00243 std::vector< EntityHandle > hexes; 00244 rval = mb.get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( rval ); 00245 CHECK_EQUAL( (size_t)2, hexes.size() ); 00246 00247 Tag id_tag = mb.globalId_tag(); 00248 00249 std::vector< int > ids( hexes.size() ); 00250 rval = mb.tag_get_data( id_tag, &hexes[0], hexes.size(), &ids[0] );CHECK_ERR( rval ); 00251 00252 int vtx_ids[8]; 00253 const EntityHandle* conn; 00254 int len; 00255 00256 const int conn1[] = { 1, 2, 3, 4, 5, 6, 7, 8 }; 00257 int pos = 0, offset = 1; 00258 // Element id 1 is a hex 00259 CHECK_EQUAL( pos + offset, ids[pos] ); 00260 rval = mb.get_connectivity( hexes[pos], conn, len );CHECK_ERR( rval ); 00261 CHECK_EQUAL( 8, len ); 00262 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00263 CHECK_ARRAYS_EQUAL( conn1, 8, vtx_ids, len ); 00264 00265 const int conn2[] = { 2, 9, 10, 3, 6, 11, 12, 7 }; 00266 ++pos; 00267 // Element id 2 is a hex 00268 CHECK_EQUAL( pos + offset, ids[pos] ); 00269 rval = mb.get_connectivity( hexes[pos], conn, len );CHECK_ERR( rval ); 00270 CHECK_EQUAL( 8, len ); 00271 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00272 CHECK_ARRAYS_EQUAL( conn2, 8, vtx_ids, len ); 00273 } 00274 00275 // Two tets and two hexes are in material set 100. 00276 void test_read_material_set() 00277 { 00278 ErrorCode rval; 00279 Core moab; 00280 Interface& mb = moab; 00281 read_file( moab, example ); 00282 00283 Tag mat_tag; 00284 rval = mb.tag_get_handle( MAT_PROP_TABLE_TAG, 1, MB_TYPE_INTEGER, mat_tag );CHECK_ERR( rval ); 00285 00286 Range mat_set; 00287 const int mat_set_id = 100; 00288 const void* const mat_set_id_val[] = { &mat_set_id }; 00289 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, mat_set_id_val, 1, mat_set );CHECK_ERR( rval ); 00290 CHECK_EQUAL( 1, (int)mat_set.size() ); 00291 00292 std::vector< EntityHandle > elements, contents; 00293 rval = mb.get_entities_by_type( 0, MBTET, elements );CHECK_ERR( rval ); 00294 rval = mb.get_entities_by_type( 0, MBHEX, elements );CHECK_ERR( rval ); 00295 rval = mb.get_entities_by_handle( mat_set.front(), contents );CHECK_ERR( rval ); 00296 std::sort( elements.begin(), elements.end() ); 00297 std::sort( contents.begin(), contents.end() ); 00298 CHECK_EQUAL( elements, contents ); 00299 } 00300 00301 // The tets are in physical set 4, which corresponds to volume 4 in Cubit. 00302 void test_read_physical_set() 00303 { 00304 ErrorCode rval; 00305 Core moab; 00306 Interface& mb = moab; 00307 read_file( moab, example ); 00308 00309 Tag phys_tag; 00310 rval = mb.tag_get_handle( PHYS_PROP_TABLE_TAG, 1, MB_TYPE_INTEGER, phys_tag );CHECK_ERR( rval ); 00311 00312 Range phys_set; 00313 const int phys_set_id = 4; 00314 const void* const phys_set_id_val[] = { &phys_set_id }; 00315 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &phys_tag, phys_set_id_val, 1, phys_set );CHECK_ERR( rval ); 00316 CHECK_EQUAL( 1, (int)phys_set.size() ); 00317 00318 std::vector< EntityHandle > tets, contents; 00319 rval = mb.get_entities_by_type( 0, MBTET, tets );CHECK_ERR( rval ); 00320 rval = mb.get_entities_by_handle( phys_set.front(), contents );CHECK_ERR( rval ); 00321 std::sort( tets.begin(), tets.end() ); 00322 std::sort( contents.begin(), contents.end() ); 00323 CHECK_EQUAL( tets, contents ); 00324 }
