MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef MERGEMESH_HPP 00002 #define MERGEMESH_HPP 00003 00004 #include "moab/Interface.hpp" 00005 #include "moab/Range.hpp" 00006 #include <set> 00007 00008 namespace moab 00009 { 00010 00011 class AdaptiveKDTree; 00012 00013 class MergeMesh 00014 { 00015 public: 00016 /* \brief Constructor 00017 */ 00018 MergeMesh( Interface* mbImpl, bool printErrorIn = true ); 00019 00020 /* \brief Destructor 00021 */ 00022 virtual ~MergeMesh(); 00023 00024 /* \brief Merge vertices in elements passed in 00025 */ 00026 ErrorCode merge_entities( EntityHandle* elems, 00027 int elems_size, 00028 const double merge_tol, 00029 const int do_merge = true, 00030 const int update_sets = false, 00031 Tag merge_tag = 0, 00032 bool do_higher_dim = true ); 00033 00034 ErrorCode merge_entities( Range& elems, 00035 const double merge_tol, 00036 const int do_merge = true, 00037 const int update_sets = false, 00038 Tag merge_tag = 0, 00039 bool do_higher_dim = true ); 00040 00041 // Identify higher dimension to be merged 00042 ErrorCode merge_higher_dimensions( Range& elems ); 00043 00044 // merge vertices according to an input tag 00045 ErrorCode merge_using_integer_tag( Range& verts, Tag user_tag, Tag merge_tag = 0 ); 00046 00047 //- perform the actual merge 00048 ErrorCode perform_merge( Tag merged_to ); 00049 00050 // new method, for overlapped meshes 00051 // meshset could be the whole mesh, represented by root set 0; 00052 ErrorCode merge_all( EntityHandle meshset, const double merge_tol ); 00053 00054 private: 00055 // iMesh_Instance imeshImpl; 00056 00057 //- given a kdtree, set tag on vertices in leaf nodes with vertices 00058 //- to which they should be merged 00059 ErrorCode find_merged_to( EntityHandle& tree_root, AdaptiveKDTree& tree, Tag merged_to ); 00060 00061 Interface* mbImpl; 00062 00063 //- the tag pointing to the entity to which an entity will be merged 00064 Tag mbMergeTag; 00065 00066 double mergeTol, mergeTolSq; 00067 00068 //- entities which will go away after the merge 00069 std::set< EntityHandle > deadEnts; 00070 00071 // vertices that were merged with other vertices, and were left in the database 00072 std::set< EntityHandle > mergedToVertices; 00073 00074 // Allow a warning to be suppressed when no merging is done 00075 bool printError; 00076 }; 00077 00078 } // namespace moab 00079 00080 #endif
