MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \file DenseTag.cpp 00002 * \author Jason Kraftcheck 00003 * \date 2010-12-14 00004 */ 00005 00006 #include "DenseTag.hpp" 00007 #include "moab/Range.hpp" 00008 #include "TagCompare.hpp" 00009 #include "SysUtil.hpp" 00010 #include "SequenceManager.hpp" 00011 #include "SequenceData.hpp" 00012 #include "moab/Error.hpp" 00013 #include "moab/ErrorHandler.hpp" 00014 #include "moab/CN.hpp" 00015 #include <utility> 00016 00017 namespace moab 00018 { 00019 00020 inline static ErrorCode not_found( const std::string& /*name*/, EntityHandle /*h*/ ) 00021 { 00022 // MB_TAG_NOT_FOUND could be a non-error condition, do not call MB_SET_ERR on it 00023 #if 0 00024 if (h) 00025 fprintf(stderr, "[Warning]: No dense tag %s value for %s %ld\n", 00026 name.c_str(), 00027 CN::EntityTypeName(TYPE_FROM_HANDLE(h)), 00028 (unsigned long)ID_FROM_HANDLE(h)); 00029 else 00030 fprintf(stderr, "[Warning]: No dense tag %s value for root set\n", name.c_str()); 00031 #endif 00032 00033 return MB_TAG_NOT_FOUND; 00034 } 00035 00036 inline static ErrorCode ent_not_found( const std::string& /*name*/, EntityHandle /*h*/ ) 00037 { 00038 // MB_ENTITY_NOT_FOUND could be a non-error condition, do not call MB_SET_ERR on it 00039 #if 0 00040 fprintf( 00041 stderr, 00042 "[Warning]: Invalid entity handle setting tag %s: %s %ld\n", 00043 name.c_str(), 00044 CN::EntityTypeName(TYPE_FROM_HANDLE(h)), 00045 (unsigned long)ID_FROM_HANDLE(h) 00046 ); 00047 #endif 00048 00049 return MB_ENTITY_NOT_FOUND; 00050 } 00051 00052 DenseTag::DenseTag( int index, const char* name, int size, DataType type, const void* default_value ) 00053 : TagInfo( name, size, type, default_value, size ), mySequenceArray( index ), meshValue( 0 ) 00054 { 00055 } 00056 00057 TagType DenseTag::get_storage_type() const 00058 { 00059 return MB_TAG_DENSE; 00060 } 00061 00062 DenseTag* DenseTag::create_tag( SequenceManager* seqman, 00063 Error* /* error */, 00064 const char* name, 00065 int bytes, 00066 DataType type, 00067 const void* default_value ) 00068 { 00069 if( bytes < 1 ) return 0; 00070 00071 int index; 00072 if( MB_SUCCESS != seqman->reserve_tag_array( NULL, bytes, index ) ) return 0; 00073 00074 return new DenseTag( index, name, bytes, type, default_value ); 00075 } 00076 00077 DenseTag::~DenseTag() 00078 { 00079 assert( mySequenceArray < 0 ); 00080 delete[] meshValue; 00081 } 00082 00083 ErrorCode DenseTag::release_all_data( SequenceManager* seqman, Error* /* error */, bool delete_pending ) 00084 { 00085 ErrorCode result = seqman->release_tag_array( NULL, mySequenceArray, delete_pending ); 00086 if( MB_SUCCESS == result && delete_pending ) mySequenceArray = -1; 00087 return result; 00088 } 00089 00090 ErrorCode DenseTag::get_array( const SequenceManager* seqman, 00091 Error* /* error */, 00092 EntityHandle h, 00093 const unsigned char* const& ptr, 00094 size_t& count ) const 00095 { 00096 // cast away the const-ness; do we really want to do this? 00097 // probably we are not calling this anywhere; 00098 // clang compiler found this 00099 return get_array_private( seqman, NULL, h, const_cast< const unsigned char*& >( ptr ), count ); 00100 } 00101 00102 ErrorCode DenseTag::get_array_private( const SequenceManager* seqman, 00103 Error* /* error */, 00104 EntityHandle h, 00105 const unsigned char*& ptr, 00106 size_t& count ) const 00107 { 00108 const EntitySequence* seq = 0; 00109 ErrorCode rval = seqman->find( h, seq ); 00110 if( MB_SUCCESS != rval ) 00111 { 00112 if( !h ) 00113 { // Root set 00114 ptr = meshValue; 00115 count = 1; 00116 return MB_SUCCESS; 00117 } 00118 else 00119 { // Not root set 00120 ptr = 0; 00121 count = 0; 00122 return ent_not_found( get_name(), h ); 00123 } 00124 } 00125 00126 const void* mem = seq->data()->get_tag_data( mySequenceArray ); 00127 ptr = reinterpret_cast< const unsigned char* >( mem ); 00128 count = seq->data()->end_handle() - h + 1; 00129 if( ptr ) ptr += get_size() * ( h - seq->data()->start_handle() ); 00130 00131 return MB_SUCCESS; 00132 } 00133 00134 ErrorCode DenseTag::get_array( const EntitySequence* seq, const unsigned char* const& ptr ) const 00135 { 00136 // cast away the constness; otherwise it would be infinite recursion 00137 // probably we are not calling this anywhere 00138 return get_array_private( seq, const_cast< const unsigned char*& >( ptr ) ); 00139 } 00140 00141 ErrorCode DenseTag::get_array_private( const EntitySequence* seq, const unsigned char*& ptr ) const 00142 { 00143 ptr = reinterpret_cast< const unsigned char* >( seq->data()->get_tag_data( mySequenceArray ) ); 00144 if( ptr ) ptr += get_size() * ( seq->start_handle() - seq->data()->start_handle() ); 00145 00146 return MB_SUCCESS; 00147 } 00148 00149 ErrorCode DenseTag::get_array_private( SequenceManager* seqman, 00150 Error* /* error */, 00151 EntityHandle h, 00152 unsigned char*& ptr, 00153 size_t& count, 00154 bool allocate ) 00155 { 00156 EntitySequence* seq = 0; 00157 ErrorCode rval = seqman->find( h, seq ); 00158 if( MB_SUCCESS != rval ) 00159 { 00160 if( !h ) 00161 { // Root set 00162 if( !meshValue && allocate ) meshValue = new unsigned char[get_size()]; 00163 ptr = meshValue; 00164 count = 1; 00165 return MB_SUCCESS; 00166 } 00167 else 00168 { // Not root set 00169 ptr = 0; 00170 count = 0; 00171 return ent_not_found( get_name(), h ); 00172 } 00173 } 00174 00175 void* mem = seq->data()->get_tag_data( mySequenceArray ); 00176 if( !mem && allocate ) 00177 { 00178 mem = seq->data()->allocate_tag_array( mySequenceArray, get_size(), get_default_value() ); 00179 if( !mem ) 00180 { 00181 MB_SET_ERR( MB_MEMORY_ALLOCATION_FAILED, "Memory allocation for dense tag data failed" ); 00182 } 00183 00184 if( !get_default_value() ) memset( mem, 0, get_size() * seq->data()->size() ); 00185 } 00186 00187 ptr = reinterpret_cast< unsigned char* >( mem ); 00188 count = seq->data()->end_handle() - h + 1; 00189 if( ptr ) ptr += get_size() * ( h - seq->data()->start_handle() ); 00190 return MB_SUCCESS; 00191 } 00192 00193 ErrorCode DenseTag::get_data( const SequenceManager* seqman, 00194 Error* /* error */, 00195 const EntityHandle* entities, 00196 size_t num_entities, 00197 void* adata ) const 00198 { 00199 size_t junk = 0; 00200 unsigned char* ptr = reinterpret_cast< unsigned char* >( adata ); 00201 const EntityHandle* const end = entities + num_entities; 00202 for( const EntityHandle* i = entities; i != end; ++i, ptr += get_size() ) 00203 { 00204 const unsigned char* data = 0; 00205 ErrorCode rval = get_array( seqman, NULL, *i, data, junk );MB_CHK_ERR( rval ); 00206 00207 if( data ) 00208 memcpy( ptr, data, get_size() ); 00209 else if( get_default_value() ) 00210 memcpy( ptr, get_default_value(), get_size() ); 00211 else 00212 return not_found( get_name(), *i ); 00213 } 00214 00215 return MB_SUCCESS; 00216 } 00217 00218 ErrorCode DenseTag::get_data( const SequenceManager* seqman, 00219 Error* /* error */, 00220 const Range& entities, 00221 void* values ) const 00222 { 00223 ErrorCode rval; 00224 size_t avail = 0; 00225 const unsigned char* array = NULL; // Initialize to get rid of warning 00226 unsigned char* data = reinterpret_cast< unsigned char* >( values ); 00227 00228 for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p ) 00229 { 00230 EntityHandle start = p->first; 00231 while( start <= p->second ) 00232 { 00233 rval = get_array( seqman, NULL, start, array, avail );MB_CHK_ERR( rval ); 00234 00235 const size_t count = std::min< size_t >( p->second - start + 1, avail ); 00236 if( array ) 00237 memcpy( data, array, get_size() * count ); 00238 else if( get_default_value() ) 00239 SysUtil::setmem( data, get_default_value(), get_size(), count ); 00240 else 00241 return not_found( get_name(), start ); 00242 00243 data += get_size() * count; 00244 start += count; 00245 } 00246 } 00247 00248 return MB_SUCCESS; 00249 } 00250 00251 ErrorCode DenseTag::get_data( const SequenceManager* seqman, 00252 Error* /* error */, 00253 const EntityHandle* entities, 00254 size_t num_entities, 00255 const void** pointers, 00256 int* data_lengths ) const 00257 { 00258 ErrorCode result; 00259 const EntityHandle* const end = entities + num_entities; 00260 size_t junk = 0; 00261 const unsigned char* ptr = NULL; // Initialize to get rid of warning 00262 00263 if( data_lengths ) 00264 { 00265 const int len = get_size(); 00266 SysUtil::setmem( data_lengths, &len, sizeof( int ), num_entities ); 00267 } 00268 00269 for( const EntityHandle* i = entities; i != end; ++i, ++pointers ) 00270 { 00271 result = get_array( seqman, NULL, *i, ptr, junk );MB_CHK_ERR( result ); 00272 00273 if( ptr ) 00274 *pointers = ptr; 00275 else if( get_default_value() ) 00276 *pointers = get_default_value(); 00277 else 00278 return not_found( get_name(), *i ); 00279 } 00280 00281 return MB_SUCCESS; 00282 } 00283 00284 ErrorCode DenseTag::get_data( const SequenceManager* seqman, 00285 Error* /* error */, 00286 const Range& entities, 00287 const void** pointers, 00288 int* data_lengths ) const 00289 { 00290 ErrorCode rval; 00291 size_t avail = 0; 00292 const unsigned char* array = NULL; 00293 00294 if( data_lengths ) 00295 { 00296 int len = get_size(); 00297 SysUtil::setmem( data_lengths, &len, sizeof( int ), entities.size() ); 00298 } 00299 00300 for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p ) 00301 { 00302 EntityHandle start = p->first; 00303 while( start <= p->second ) 00304 { 00305 rval = get_array( seqman, NULL, start, array, avail );MB_CHK_ERR( rval ); 00306 00307 const size_t count = std::min< size_t >( p->second - start + 1, avail ); 00308 if( array ) 00309 { 00310 for( EntityHandle end = start + count; start != end; ++start ) 00311 { 00312 *pointers = array; 00313 array += get_size(); 00314 ++pointers; 00315 } 00316 } 00317 else if( const void* val = get_default_value() ) 00318 { 00319 SysUtil::setmem( pointers, &val, sizeof( void* ), count ); 00320 pointers += count; 00321 start += count; 00322 } 00323 else 00324 { 00325 return not_found( get_name(), start ); 00326 } 00327 } 00328 } 00329 00330 return MB_SUCCESS; 00331 } 00332 00333 ErrorCode DenseTag::set_data( SequenceManager* seqman, 00334 Error* /* error */, 00335 const EntityHandle* entities, 00336 size_t num_entities, 00337 const void* data ) 00338 { 00339 ErrorCode rval; 00340 const unsigned char* ptr = reinterpret_cast< const unsigned char* >( data ); 00341 const EntityHandle* const end = entities + num_entities; 00342 unsigned char* array = NULL; 00343 size_t junk = 0; 00344 00345 for( const EntityHandle* i = entities; i != end; ++i, ptr += get_size() ) 00346 { 00347 rval = get_array_private( seqman, NULL, *i, array, junk, true );MB_CHK_ERR( rval ); 00348 00349 memcpy( array, ptr, get_size() ); 00350 } 00351 00352 return MB_SUCCESS; 00353 } 00354 00355 ErrorCode DenseTag::set_data( SequenceManager* seqman, Error* /* error */, const Range& entities, const void* values ) 00356 { 00357 ErrorCode rval; 00358 const char* data = reinterpret_cast< const char* >( values ); 00359 unsigned char* array = NULL; 00360 size_t avail = 0; 00361 00362 for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p ) 00363 { 00364 EntityHandle start = p->first; 00365 while( start <= p->second ) 00366 { 00367 rval = get_array_private( seqman, NULL, start, array, avail, true );MB_CHK_ERR( rval ); 00368 00369 const size_t count = std::min< size_t >( p->second - start + 1, avail ); 00370 memcpy( array, data, get_size() * count ); 00371 data += get_size() * count; 00372 start += count; 00373 } 00374 } 00375 00376 return MB_SUCCESS; 00377 } 00378 00379 ErrorCode DenseTag::set_data( SequenceManager* seqman, 00380 Error* /* error */, 00381 const EntityHandle* entities, 00382 size_t num_entities, 00383 void const* const* pointers, 00384 const int* data_lengths ) 00385 { 00386 ErrorCode rval = validate_lengths( NULL, data_lengths, num_entities );MB_CHK_ERR( rval ); 00387 00388 const EntityHandle* const end = entities + num_entities; 00389 unsigned char* array = NULL; 00390 size_t junk = 0; 00391 00392 for( const EntityHandle* i = entities; i != end; ++i, ++pointers ) 00393 { 00394 rval = get_array_private( seqman, NULL, *i, array, junk, true );MB_CHK_ERR( rval ); 00395 00396 memcpy( array, *pointers, get_size() ); 00397 } 00398 00399 return MB_SUCCESS; 00400 } 00401 00402 ErrorCode DenseTag::set_data( SequenceManager* seqman, 00403 Error* /* error */, 00404 const Range& entities, 00405 void const* const* pointers, 00406 const int* /* data_lengths */ ) 00407 { 00408 ErrorCode rval; 00409 unsigned char* array = NULL; 00410 size_t avail = 0; 00411 00412 for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p ) 00413 { 00414 EntityHandle start = p->first; 00415 while( start <= p->second ) 00416 { 00417 rval = get_array_private( seqman, NULL, start, array, avail, true );MB_CHK_ERR( rval ); 00418 00419 const EntityHandle end = std::min< EntityHandle >( p->second + 1, start + avail ); 00420 while( start != end ) 00421 { 00422 memcpy( array, *pointers, get_size() ); 00423 ++start; 00424 ++pointers; 00425 array += get_size(); 00426 } 00427 } 00428 } 00429 00430 return MB_SUCCESS; 00431 } 00432 00433 ErrorCode DenseTag::clear_data( bool allocate, 00434 SequenceManager* seqman, 00435 Error* /* error */, 00436 const EntityHandle* entities, 00437 size_t num_entities, 00438 const void* value_ptr ) 00439 { 00440 ErrorCode rval; 00441 const EntityHandle* const end = entities + num_entities; 00442 unsigned char* array = NULL; 00443 size_t junk = 0; 00444 00445 for( const EntityHandle* i = entities; i != end; ++i ) 00446 { 00447 rval = get_array_private( seqman, NULL, *i, array, junk, allocate );MB_CHK_ERR( rval ); 00448 00449 if( array ) // Array should never be null if allocate == true 00450 memcpy( array, value_ptr, get_size() ); 00451 } 00452 00453 return MB_SUCCESS; 00454 } 00455 00456 ErrorCode DenseTag::clear_data( bool allocate, 00457 SequenceManager* seqman, 00458 Error* /* error */, 00459 const Range& entities, 00460 const void* value_ptr ) 00461 { 00462 ErrorCode rval; 00463 unsigned char* array = NULL; 00464 size_t avail = 0; 00465 00466 for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p ) 00467 { 00468 EntityHandle start = p->first; 00469 while( start <= p->second ) 00470 { 00471 rval = get_array_private( seqman, NULL, start, array, avail, allocate );MB_CHK_ERR( rval ); 00472 00473 const size_t count = std::min< size_t >( p->second - start + 1, avail ); 00474 if( array ) // Array should never be null if allocate == true 00475 SysUtil::setmem( array, value_ptr, get_size(), count ); 00476 start += count; 00477 } 00478 } 00479 00480 return MB_SUCCESS; 00481 } 00482 00483 ErrorCode DenseTag::clear_data( SequenceManager* seqman, 00484 Error* /* error */, 00485 const EntityHandle* entities, 00486 size_t num_entities, 00487 const void* value_ptr, 00488 int value_len ) 00489 { 00490 if( value_len && value_len != get_size() ) return MB_INVALID_SIZE; 00491 00492 return clear_data( true, seqman, NULL, entities, num_entities, value_ptr ); 00493 } 00494 00495 ErrorCode DenseTag::clear_data( SequenceManager* seqman, 00496 Error* /* error */, 00497 const Range& entities, 00498 const void* value_ptr, 00499 int value_len ) 00500 { 00501 if( value_len && value_len != get_size() ) return MB_INVALID_SIZE; 00502 00503 return clear_data( true, seqman, NULL, entities, value_ptr ); 00504 } 00505 00506 ErrorCode DenseTag::remove_data( SequenceManager* seqman, 00507 Error* /* error */, 00508 const EntityHandle* entities, 00509 size_t num_entities ) 00510 { 00511 std::vector< unsigned char > zeros; 00512 const void* value = get_default_value(); 00513 if( !value ) 00514 { 00515 zeros.resize( get_size(), 0 ); 00516 value = &zeros[0]; 00517 } 00518 00519 return clear_data( false, seqman, NULL, entities, num_entities, value ); 00520 } 00521 00522 ErrorCode DenseTag::remove_data( SequenceManager* seqman, Error* /* error */, const Range& entities ) 00523 { 00524 std::vector< unsigned char > zeros; 00525 const void* value = get_default_value(); 00526 if( !value ) 00527 { 00528 zeros.resize( get_size(), 0 ); 00529 value = &zeros[0]; 00530 } 00531 00532 return clear_data( false, seqman, NULL, entities, value ); 00533 } 00534 00535 ErrorCode DenseTag::tag_iterate( SequenceManager* seqman, 00536 Error* /* error */, 00537 Range::iterator& iter, 00538 const Range::iterator& end, 00539 void*& data_ptr, 00540 bool allocate ) 00541 { 00542 // If asked for nothing, successfully return nothing. 00543 if( iter == end ) return MB_SUCCESS; 00544 00545 unsigned char* array = NULL; 00546 size_t avail = 0; 00547 ErrorCode rval = get_array_private( seqman, NULL, *iter, array, avail, allocate );MB_CHK_ERR( rval ); 00548 data_ptr = array; 00549 00550 size_t count = std::min< size_t >( avail, *( iter.end_of_block() ) - *iter + 1 ); 00551 if( 0 != *end && *end <= *( iter.end_of_block() ) ) 00552 iter = end; 00553 else 00554 iter += count; 00555 00556 return MB_SUCCESS; 00557 } 00558 00559 ErrorCode DenseTag::get_tagged_entities( const SequenceManager* seqman, 00560 Range& entities_in, 00561 EntityType type, 00562 const Range* intersect_list ) const 00563 { 00564 Range tmp; 00565 Range* entities = intersect_list ? &tmp : &entities_in; 00566 Range::iterator hint = entities->begin(); 00567 std::pair< EntityType, EntityType > range = type_range( type ); 00568 TypeSequenceManager::const_iterator i; 00569 for( EntityType t = range.first; t != range.second; ++t ) 00570 { 00571 const TypeSequenceManager& map = seqman->entity_map( t ); 00572 for( i = map.begin(); i != map.end(); ++i ) 00573 if( ( *i )->data()->get_tag_data( mySequenceArray ) ) 00574 hint = entities->insert( hint, ( *i )->start_handle(), ( *i )->end_handle() ); 00575 } 00576 00577 if( intersect_list ) entities_in = intersect( *entities, *intersect_list ); 00578 00579 return MB_SUCCESS; 00580 } 00581 00582 ErrorCode DenseTag::num_tagged_entities( const SequenceManager* seqman, 00583 size_t& output_count, 00584 EntityType type, 00585 const Range* intersect ) const 00586 { 00587 Range tmp; 00588 ErrorCode rval = get_tagged_entities( seqman, tmp, type, intersect ); 00589 output_count += tmp.size(); 00590 00591 return rval; 00592 } 00593 00594 ErrorCode DenseTag::find_entities_with_value( const SequenceManager* seqman, 00595 Error* /* error */, 00596 Range& output_entities, 00597 const void* value, 00598 int value_bytes, 00599 EntityType type, 00600 const Range* intersect_entities ) const 00601 { 00602 if( value_bytes && value_bytes != get_size() ) 00603 { 00604 MB_SET_ERR( MB_INVALID_SIZE, 00605 "Cannot compare data of size " << value_bytes << " with tag of size " << get_size() ); 00606 } 00607 00608 if( !intersect_entities ) 00609 { 00610 std::pair< EntityType, EntityType > range = type_range( type ); 00611 TypeSequenceManager::const_iterator i; 00612 for( EntityType t = range.first; t != range.second; ++t ) 00613 { 00614 const TypeSequenceManager& map = seqman->entity_map( t ); 00615 for( i = map.begin(); i != map.end(); ++i ) 00616 { 00617 const void* data = ( *i )->data()->get_tag_data( mySequenceArray ); 00618 if( data ) 00619 { 00620 ByteArrayIterator start( ( *i )->data()->start_handle(), data, *this ); 00621 ByteArrayIterator end( ( *i )->end_handle() + 1, 0, 0 ); 00622 start += ( *i )->start_handle() - ( *i )->data()->start_handle(); 00623 find_tag_values_equal( *this, value, get_size(), start, end, output_entities ); 00624 } 00625 } 00626 } 00627 } 00628 else 00629 { 00630 const unsigned char* array = NULL; // Initialize to get rid of warning 00631 size_t count; 00632 ErrorCode rval; 00633 00634 Range::const_pair_iterator p = intersect_entities->begin(); 00635 if( type != MBMAXTYPE ) 00636 { 00637 p = intersect_entities->lower_bound( type ); 00638 assert( TYPE_FROM_HANDLE( p->first ) == type ); 00639 } 00640 for( ; 00641 p != intersect_entities->const_pair_end() && ( MBMAXTYPE == type || TYPE_FROM_HANDLE( p->first ) == type ); 00642 ++p ) 00643 { 00644 EntityHandle start = p->first; 00645 while( start <= p->second ) 00646 { 00647 rval = get_array( seqman, NULL, start, array, count );MB_CHK_ERR( rval ); 00648 00649 if( p->second - start < count - 1 ) count = p->second - start + 1; 00650 00651 if( array ) 00652 { 00653 ByteArrayIterator istart( start, array, *this ); 00654 ByteArrayIterator iend( start + count, 0, 0 ); 00655 find_tag_values_equal( *this, value, get_size(), istart, iend, output_entities ); 00656 } 00657 start += count; 00658 } 00659 } 00660 } 00661 00662 return MB_SUCCESS; 00663 } 00664 00665 bool DenseTag::is_tagged( const SequenceManager* seqman, EntityHandle h ) const 00666 { 00667 const unsigned char* ptr = NULL; // Initialize to get rid of warning 00668 size_t count; 00669 return ( MB_SUCCESS == get_array( seqman, 0, h, ptr, count ) ) && ( NULL != ptr ); 00670 } 00671 00672 ErrorCode DenseTag::get_memory_use( const SequenceManager* seqman, 00673 unsigned long& total, 00674 unsigned long& per_entity ) const 00675 { 00676 per_entity = get_size(); 00677 total = TagInfo::get_memory_use() + sizeof( *this ); 00678 for( EntityType t = MBVERTEX; t <= MBENTITYSET; ++t ) 00679 { 00680 const TypeSequenceManager& map = seqman->entity_map( t ); 00681 const SequenceData* prev_data = 0; 00682 for( TypeSequenceManager::const_iterator i = map.begin(); i != map.end(); ++i ) 00683 { 00684 if( ( *i )->data() != prev_data && ( *i )->data()->get_tag_data( mySequenceArray ) ) 00685 { 00686 prev_data = ( *i )->data(); 00687 total += get_size() * ( *i )->data()->size(); 00688 } 00689 } 00690 } 00691 00692 return MB_SUCCESS; 00693 } 00694 00695 } // namespace moab
