MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*This unit test is for high order reconstruction capability, which could be used for mesh 00002 * refinement*/ 00003 #include <iostream> 00004 #include <string> 00005 #include <sstream> 00006 #if defined( __MINGW32__ ) 00007 #include <sys/time.h> 00008 #else 00009 #include <ctime> 00010 #endif 00011 00012 #include <vector> 00013 #include <algorithm> 00014 #include "moab/Core.hpp" 00015 #include "moab/Range.hpp" 00016 #include "moab/MeshTopoUtil.hpp" 00017 #include "moab/NestedRefine.hpp" 00018 #include "moab/DiscreteGeometry/DGMSolver.hpp" 00019 #include "moab/DiscreteGeometry/HiReconstruction.hpp" 00020 #include "TestUtil.hpp" 00021 #include <cmath> 00022 00023 #ifdef MOAB_HAVE_MPI 00024 #include "moab/ParallelComm.hpp" 00025 #include "MBParallelConventions.h" 00026 #include "ReadParallel.hpp" 00027 #include "moab/FileOptions.hpp" 00028 #include "MBTagConventions.hpp" 00029 #include "moab_mpi.h" 00030 #endif 00031 00032 using namespace moab; 00033 00034 #ifdef MOAB_HAVE_MPI 00035 std::string read_options; 00036 #endif 00037 00038 ErrorCode load_meshset_hirec( const char* infile, 00039 Interface* mbimpl, 00040 EntityHandle& meshset, 00041 ParallelComm*& pc, 00042 const int degree = 0, 00043 const int dim = 2 ); 00044 ErrorCode test_mesh( const char* infile, const int degree, const bool interp, const int dim ); 00045 00046 void compute_linear_coords( const int nvpe, double* elemcoords, double* naturals, double* linearcoords ); 00047 00048 ErrorCode create_unitsq_tris( Interface* mbImpl, size_t n, std::vector< EntityHandle >& tris ); 00049 ErrorCode create_unitsq_quads( Interface* mbImpl, size_t n, std::vector< EntityHandle >& quads ); 00050 ErrorCode test_unitsq_tris(); 00051 ErrorCode test_unitsq_quads(); 00052 ErrorCode test_unitsphere(); 00053 ErrorCode test_unitcircle(); 00054 00055 ErrorCode exact_error_torus( const double R, 00056 const double r, 00057 const double center[3], 00058 int npnts, 00059 double* pnt, 00060 double& error_l1, 00061 double& error_l2, 00062 double& error_li ); 00063 ErrorCode project_exact_torus( Interface* mbImpl, 00064 EntityHandle meshset, 00065 int dim, 00066 const double R, 00067 const double r, 00068 const double center[3] ); 00069 00070 int main( int argc, char* argv[] ) 00071 { 00072 #ifdef MOAB_HAVE_MPI 00073 MPI_Init( &argc, &argv ); 00074 int nprocs, rank; 00075 MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); 00076 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00077 #endif 00078 std::string infile; 00079 int degree = 2, dim = 0; 00080 bool interp = false; 00081 ErrorCode error; 00082 00083 if( argc == 1 ) 00084 { 00085 error = test_unitsq_tris();MB_CHK_ERR( error ); 00086 error = test_unitsq_quads();MB_CHK_ERR( error ); 00087 error = test_unitsphere();MB_CHK_ERR( error ); 00088 error = test_unitcircle();MB_CHK_ERR( error ); 00089 #ifdef MOAB_HAVE_MPI 00090 MPI_Finalize(); 00091 #endif 00092 return 0; 00093 } 00094 else 00095 { 00096 infile = std::string( argv[1] ); 00097 bool hasdim = false; 00098 00099 for( int i = 2; i < argc; ++i ) 00100 { 00101 if( i + 1 != argc ) 00102 { 00103 if( std::string( argv[i] ) == "-degree" ) 00104 { 00105 degree = atoi( argv[++i] ); 00106 } 00107 else if( std::string( argv[i] ) == "-interp" ) 00108 { 00109 interp = atoi( argv[++i] ); 00110 } 00111 else if( std::string( argv[i] ) == "-dim" ) 00112 { 00113 dim = atoi( argv[++i] ); 00114 hasdim = true; 00115 } 00116 else 00117 { 00118 std::cout << argv[i] << std::endl; 00119 std::cout << "usage: " << argv[0] 00120 << " <mesh file> -degree <degree> -interp <0=least square, " 00121 "1=interpolation> -dim <mesh dimension>" 00122 << std::endl; 00123 return 0; 00124 } 00125 } 00126 } 00127 00128 if( !hasdim ) 00129 { 00130 std::cout << "Dimension of input mesh should be provided, positive and less than 3" << std::endl; 00131 return 0; 00132 } 00133 00134 if( degree <= 0 || dim > 2 || dim <= 0 ) 00135 { 00136 std::cout << "Input degree should be positive number;\n"; 00137 std::cout << "Input dimesion should be positive and less than 3;" << std::endl; 00138 return -1; 00139 } 00140 00141 std::cout << "Testing on " << infile << " with dimension " << dim << "\n"; 00142 std::string opts = interp ? "interpolation" : "least square fitting"; 00143 std::cout << "High order reconstruction with degree " << degree << " " << opts << std::endl; 00144 } 00145 00146 error = test_mesh( infile.c_str(), degree, interp, dim );MB_CHK_ERR( error ); 00147 #ifdef MOAB_HAVE_MPI 00148 MPI_Finalize(); 00149 #endif 00150 return 0; 00151 } 00152 00153 ErrorCode load_meshset_hirec( const char* infile, 00154 Interface* mbimpl, 00155 EntityHandle& meshset, 00156 ParallelComm*& pc, 00157 const int degree, 00158 const int dim ) 00159 { 00160 ErrorCode error; 00161 error = mbimpl->create_meshset( moab::MESHSET_SET, meshset );MB_CHK_ERR( error ); 00162 #ifdef MOAB_HAVE_MPI 00163 int nprocs, rank; 00164 MPI_Comm comm = MPI_COMM_WORLD; 00165 MPI_Comm_size( comm, &nprocs ); 00166 MPI_Comm_rank( comm, &rank ); 00167 EntityHandle partnset; 00168 error = mbimpl->create_meshset( moab::MESHSET_SET, partnset );MB_CHK_ERR( error ); 00169 00170 if( nprocs > 1 ) 00171 { 00172 pc = moab::ParallelComm::get_pcomm( mbimpl, partnset, &comm ); 00173 } 00174 00175 if( nprocs > 1 ) 00176 { 00177 int nghlayers = degree > 0 ? HiReconstruction::estimate_num_ghost_layers( degree, true ) : 0; 00178 00179 if( nghlayers ) 00180 { 00181 // get ghost layers 00182 if( dim == 2 ) 00183 { 00184 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_" 00185 "SHARED_ENTS;PARALLEL_GHOST=2.0."; 00186 } 00187 else if( dim == 1 ) 00188 { 00189 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_" 00190 "SHARED_ENTS;PARALLEL_GHOST=1.0."; 00191 } 00192 else 00193 { 00194 MB_SET_ERR( MB_FAILURE, "unsupported dimension" ); 00195 } 00196 00197 read_options += ( '0' + nghlayers ); 00198 } 00199 else 00200 { 00201 read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; 00202 } 00203 00204 error = mbimpl->load_file( infile, &meshset, read_options.c_str() );MB_CHK_ERR( error ); 00205 } 00206 else 00207 { 00208 error = mbimpl->load_file( infile, &meshset );MB_CHK_ERR( error ); 00209 } 00210 00211 #else 00212 assert( !pc && degree && dim ); 00213 error = mbimpl->load_file( infile, &meshset );MB_CHK_ERR( error ); 00214 #endif 00215 return error; 00216 } 00217 00218 ErrorCode test_mesh( const char* infile, const int degree, const bool interp, const int dim ) 00219 { 00220 Core moab; 00221 Interface* mbimpl = &moab; 00222 ParallelComm* pc = NULL; 00223 EntityHandle meshset; 00224 // load mesh file 00225 ErrorCode error; 00226 error = load_meshset_hirec( infile, mbimpl, meshset, pc, degree, dim );MB_CHK_ERR( error ); 00227 // project to exact surface: torus 00228 double center[3] = { 0, 0, 0 }; 00229 double R = 1, r = 0.3; 00230 error = project_exact_torus( mbimpl, meshset, dim, R, r, center );CHECK_ERR( error ); 00231 // initialize 00232 HiReconstruction hirec( dynamic_cast< Core* >( mbimpl ), pc, meshset ); 00233 Range elems; 00234 error = mbimpl->get_entities_by_dimension( meshset, dim, elems );MB_CHK_ERR( error ); 00235 00236 // reconstruction 00237 if( dim == 2 ) 00238 { 00239 // error = hirec.reconstruct3D_surf_geom(degree, interp, false); MB_CHK_ERR(error); 00240 error = hirec.reconstruct3D_surf_geom( degree, interp, true );MB_CHK_ERR( error ); 00241 } 00242 else if( dim == 1 ) 00243 { 00244 error = hirec.reconstruct3D_curve_geom( degree, interp, true );MB_CHK_ERR( error ); 00245 } 00246 00247 // fitting 00248 double mxdist = 0, errl1 = 0, errl2 = 0, errli = 0; 00249 double* pnts_proj = new double[elems.size() * 3]; 00250 00251 for( Range::iterator ielem = elems.begin(); ielem != elems.end(); ++ielem ) 00252 { 00253 int nvpe; 00254 const EntityHandle* conn; 00255 error = mbimpl->get_connectivity( *ielem, conn, nvpe );MB_CHK_ERR( error ); 00256 double w = 1.0 / (double)nvpe; 00257 std::vector< double > naturalcoords2fit( nvpe, w ); 00258 double newcoords[3], linearcoords[3]; 00259 error = hirec.hiproj_walf_in_element( *ielem, nvpe, 1, &( naturalcoords2fit[0] ), newcoords );MB_CHK_ERR( error ); 00260 pnts_proj[3 * ( *ielem - *elems.begin() )] = newcoords[0]; 00261 pnts_proj[3 * ( *ielem - *elems.begin() ) + 1] = newcoords[1]; 00262 pnts_proj[3 * ( *ielem - *elems.begin() ) + 2] = newcoords[2]; 00263 std::vector< double > coords( 3 * nvpe ); 00264 error = mbimpl->get_coords( conn, nvpe, &( coords[0] ) );MB_CHK_ERR( error ); 00265 compute_linear_coords( nvpe, &( coords[0] ), &( naturalcoords2fit[0] ), linearcoords ); 00266 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00267 } 00268 00269 delete[] pnts_proj; 00270 // compute error for torus 00271 error = exact_error_torus( R, r, center, (int)elems.size(), pnts_proj, errl1, errl2, errli );MB_CHK_ERR( error ); 00272 std::cout << "Errors using exact torus for degree " << degree << " fit : L1 = " << errl1 << ", L2 = " << errl2 00273 << ", Linf = " << errli << std::endl; 00274 std::cout << "Maximum projection lift is " << mxdist << std::endl; 00275 return error; 00276 } 00277 00278 ErrorCode create_unitsq_tris( Interface* mbImpl, size_t n, std::vector< EntityHandle >& tris ) 00279 { 00280 if( n < 2 ) 00281 { 00282 MB_SET_ERR( MB_FAILURE, "n must be at least 2" ); 00283 } 00284 00285 ErrorCode error; 00286 std::vector< EntityHandle > verts( n * n ); 00287 size_t istr = tris.size(); 00288 tris.resize( istr + 2 * ( n - 1 ) * ( n - 1 ) ); 00289 double istep = 1.0 / (double)( n - 1 ); 00290 00291 for( size_t j = 0; j < n; ++j ) 00292 { 00293 for( size_t i = 0; i < n; ++i ) 00294 { 00295 double coord[3] = { i * istep, j * istep, 0 }; 00296 EntityHandle temp; 00297 error = mbImpl->create_vertex( coord, temp );MB_CHK_ERR( error ); 00298 verts[j * n + i] = temp; 00299 } 00300 } 00301 00302 for( size_t jj = 0; jj < n - 1; ++jj ) 00303 { 00304 for( size_t ii = 0; ii < n - 1; ++ii ) 00305 { 00306 EntityHandle conn[3] = { verts[jj * n + ii], verts[( jj + 1 ) * n + ii + 1], verts[( jj + 1 ) * n + ii] }; 00307 error = mbImpl->create_element( MBTRI, conn, 3, tris[istr + 2 * jj * ( n - 1 ) + 2 * ii] );MB_CHK_ERR( error ); 00308 conn[0] = verts[jj * n + ii]; 00309 conn[1] = verts[jj * n + ii + 1]; 00310 conn[2] = verts[( jj + 1 ) * n + ii + 1]; 00311 error = mbImpl->create_element( MBTRI, conn, 3, tris[istr + 2 * jj * ( n - 1 ) + 2 * ii + 1] );MB_CHK_ERR( error ); 00312 } 00313 } 00314 00315 return error; 00316 } 00317 00318 ErrorCode create_unitsq_quads( Interface* mbImpl, size_t n, std::vector< EntityHandle >& quads ) 00319 { 00320 if( n < 2 ) 00321 { 00322 MB_SET_ERR( MB_FAILURE, "n must be at least 2" ); 00323 } 00324 00325 ErrorCode error; 00326 std::vector< EntityHandle > verts( n * n ); 00327 size_t istr = quads.size(); 00328 quads.resize( istr + ( n - 1 ) * ( n - 1 ) ); 00329 double istep = 1.0 / (double)( n - 1 ); 00330 00331 for( size_t j = 0; j < n; ++j ) 00332 { 00333 for( size_t i = 0; i < n; ++i ) 00334 { 00335 double coord[3] = { i * istep, j * istep, 0 }; 00336 error = mbImpl->create_vertex( coord, verts[j * n + i] );MB_CHK_ERR( error ); 00337 } 00338 } 00339 00340 for( size_t jj = 0; jj < n - 1; ++jj ) 00341 { 00342 for( size_t ii = 0; ii < n - 1; ++ii ) 00343 { 00344 EntityHandle conn[4] = { verts[jj * n + ii], verts[jj * n + ii + 1], verts[( jj + 1 ) * n + ii + 1], 00345 verts[( jj + 1 ) * n + ii] }; 00346 error = mbImpl->create_element( MBQUAD, conn, 4, quads[istr + jj * ( n - 1 ) + ii] );MB_CHK_ERR( error ); 00347 } 00348 } 00349 00350 return error; 00351 } 00352 00353 ErrorCode test_unitsq_tris() 00354 { 00355 ErrorCode error; 00356 00357 for( size_t n = 2; n <= 2; ++n ) 00358 { 00359 Core moab; 00360 Interface* mbImpl = &moab; 00361 std::vector< EntityHandle > tris; 00362 error = create_unitsq_tris( mbImpl, n, tris );MB_CHK_ERR( error ); 00363 EntityHandle meshIn = 0; 00364 HiReconstruction hirec( dynamic_cast< Core* >( mbImpl ), 0, meshIn ); 00365 00366 for( int degree = 2; degree <= 2; ++degree ) 00367 { 00368 // reconstruct geometry, interpolation 00369 hirec.reconstruct3D_surf_geom( degree, true, true, true ); 00370 // test fitting result 00371 double mxdist = 0; 00372 00373 for( size_t itri = 0; itri < tris.size(); ++itri ) 00374 { 00375 const int nvpe = 3; 00376 double naturalcoords2fit[nvpe] = { 1.0 / (double)nvpe, 1.0 / (double)nvpe, 1.0 / (double)nvpe }, 00377 newcoords[3]; 00378 error = hirec.hiproj_walf_in_element( tris[itri], nvpe, 1, naturalcoords2fit, newcoords );MB_CHK_ERR( error ); 00379 std::vector< EntityHandle > conn; 00380 error = mbImpl->get_connectivity( &( tris[itri] ), 1, conn );MB_CHK_ERR( error ); 00381 double coords[3 * nvpe], linearcoords[3]; 00382 error = mbImpl->get_coords( &( conn[0] ), nvpe, coords );MB_CHK_ERR( error ); 00383 compute_linear_coords( nvpe, coords, naturalcoords2fit, linearcoords ); 00384 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00385 } 00386 00387 std::cout << "triangulated unit square n= " << n << " degree= " << degree << " interpolation:\n"; 00388 std::cout << "maximum projection lift is " << mxdist << std::endl; 00389 // for debug 00390 // return error; 00391 mxdist = 0; 00392 // reconstruct geometry, least square fitting 00393 hirec.reconstruct3D_surf_geom( degree, false, false, true ); 00394 00395 // test fitting result 00396 for( size_t itri = 0; itri < tris.size(); ++itri ) 00397 { 00398 const int nvpe = 3; 00399 double naturalcoords2fit[nvpe] = { 1.0 / (double)nvpe, 1.0 / (double)nvpe, 1.0 / (double)nvpe }, 00400 newcoords[3]; 00401 error = hirec.hiproj_walf_in_element( tris[itri], nvpe, 1, naturalcoords2fit, newcoords );MB_CHK_ERR( error ); 00402 std::vector< EntityHandle > conn; 00403 error = mbImpl->get_connectivity( &( tris[itri] ), 1, conn );MB_CHK_ERR( error ); 00404 double coords[3 * nvpe], linearcoords[3]; 00405 error = mbImpl->get_coords( &( conn[0] ), nvpe, coords );MB_CHK_ERR( error ); 00406 compute_linear_coords( nvpe, coords, naturalcoords2fit, linearcoords ); 00407 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00408 } 00409 00410 std::cout << "unit square n= " << n << " degree= " << degree << " least square:\n"; 00411 std::cout << "maximum projection lift is " << mxdist << std::endl; 00412 } 00413 } 00414 00415 return error; 00416 } 00417 00418 void compute_linear_coords( const int nvpe, double* elemcoords, double* naturals, double* linearcoords ) 00419 { 00420 assert( elemcoords && linearcoords ); 00421 00422 for( int i = 0; i < 3; ++i ) 00423 { 00424 linearcoords[i] = 0; 00425 00426 for( int j = 0; j < nvpe; ++j ) 00427 { 00428 linearcoords[i] += naturals[j] * elemcoords[3 * j + i]; 00429 } 00430 } 00431 } 00432 00433 ErrorCode test_unitsq_quads() 00434 { 00435 ErrorCode error; 00436 00437 for( size_t n = 2; n <= 8; ++n ) 00438 { 00439 Core moab; 00440 Interface* mbImpl = &moab; 00441 std::vector< EntityHandle > quads; 00442 error = create_unitsq_quads( mbImpl, n, quads );MB_CHK_ERR( error ); 00443 EntityHandle meshIn = 0; 00444 HiReconstruction hirec( dynamic_cast< Core* >( mbImpl ), 0, meshIn ); 00445 00446 for( int degree = 1; degree <= 6; ++degree ) 00447 { 00448 // reconstruct geometry, interpolation 00449 hirec.reconstruct3D_surf_geom( degree, true, false, true ); 00450 // test fitting result 00451 double mxdist = 0; 00452 00453 for( size_t iquad = 0; iquad < quads.size(); ++iquad ) 00454 { 00455 const int nvpe = 4; 00456 double w = 1.0 / (double)nvpe; 00457 double naturalcoords2fit[nvpe] = { w, w, w, w }, newcoords[3]; 00458 error = hirec.hiproj_walf_in_element( quads[iquad], nvpe, 1, naturalcoords2fit, newcoords );MB_CHK_ERR( error ); 00459 std::vector< EntityHandle > conn; 00460 error = mbImpl->get_connectivity( &( quads[iquad] ), 1, conn );MB_CHK_ERR( error ); 00461 double coords[3 * nvpe], linearcoords[3]; 00462 error = mbImpl->get_coords( &( conn[0] ), nvpe, coords );MB_CHK_ERR( error ); 00463 compute_linear_coords( nvpe, coords, naturalcoords2fit, linearcoords ); 00464 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00465 } 00466 00467 std::cout << "quadrilateral unit square n= " << n << " degree= " << degree << " interpolation:\n"; 00468 std::cout << "maximum projection lift is " << mxdist << std::endl; 00469 mxdist = 0; 00470 // reconstruct geometry, least square fitting 00471 hirec.reconstruct3D_surf_geom( degree, false, false, true ); 00472 00473 // test fitting result 00474 for( size_t iquad = 0; iquad < quads.size(); ++iquad ) 00475 { 00476 const int nvpe = 4; 00477 double w = 1.0 / (double)nvpe; 00478 double naturalcoords2fit[nvpe] = { w, w, w, w }, newcoords[3]; 00479 error = hirec.hiproj_walf_in_element( quads[iquad], nvpe, 1, naturalcoords2fit, newcoords );MB_CHK_ERR( error ); 00480 std::vector< EntityHandle > conn; 00481 error = mbImpl->get_connectivity( &( quads[iquad] ), 1, conn );MB_CHK_ERR( error ); 00482 double coords[3 * nvpe], linearcoords[3]; 00483 error = mbImpl->get_coords( &( conn[0] ), nvpe, coords );MB_CHK_ERR( error ); 00484 compute_linear_coords( nvpe, coords, naturalcoords2fit, linearcoords ); 00485 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00486 } 00487 00488 std::cout << "quadrilateral unit square n= " << n << " degree= " << degree << " least square:\n"; 00489 std::cout << "maximum projection lift is " << mxdist << std::endl; 00490 } 00491 } 00492 00493 return error; 00494 } 00495 00496 ErrorCode test_unitsphere() 00497 { 00498 // path to test files 00499 int nfiles = 4; 00500 std::string filenames[] = { TestDir + "unittest/sphere_tris_5.vtk", TestDir + "unittest/sphere_tris_20.vtk", 00501 TestDir + "unittest/sphere_quads_5.vtk", TestDir + "unittest/sphere_quads_20.vtk" }; 00502 ErrorCode error; 00503 int maxdeg = 6; 00504 00505 for( int ifile = 0; ifile < nfiles; ++ifile ) 00506 { 00507 Core moab; 00508 Interface* mbimpl = &moab; 00509 ParallelComm* pc = NULL; 00510 EntityHandle meshset; 00511 // load file 00512 error = load_meshset_hirec( filenames[ifile].c_str(), mbimpl, meshset, pc, maxdeg );MB_CHK_ERR( error ); 00513 // initialize 00514 HiReconstruction hirec( &moab, pc, meshset ); 00515 Range elems; 00516 error = mbimpl->get_entities_by_dimension( meshset, 2, elems );MB_CHK_ERR( error ); 00517 00518 // reconstruction 00519 for( int degree = 1; degree <= maxdeg; ++degree ) 00520 { 00521 hirec.reconstruct3D_surf_geom( degree, true, false, true ); 00522 // fitting 00523 double mxdist = 0, mxerr = 0; 00524 00525 for( Range::iterator ielem = elems.begin(); ielem != elems.end(); ++ielem ) 00526 { 00527 int nvpe; 00528 const EntityHandle* conn; 00529 error = mbimpl->get_connectivity( *ielem, conn, nvpe );MB_CHK_ERR( error ); 00530 double w = 1.0 / (double)nvpe; 00531 std::vector< double > naturalcoords2fit( nvpe, w ); 00532 double newcoords[3], linearcoords[3]; 00533 error = hirec.hiproj_walf_in_element( *ielem, nvpe, 1, &( naturalcoords2fit[0] ), newcoords );MB_CHK_ERR( error ); 00534 std::vector< double > coords( 3 * nvpe ); 00535 error = mbimpl->get_coords( conn, nvpe, &( coords[0] ) );MB_CHK_ERR( error ); 00536 compute_linear_coords( nvpe, &( coords[0] ), &( naturalcoords2fit[0] ), linearcoords ); 00537 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00538 mxerr = std::max( mxerr, fabs( DGMSolver::vec_2norm( 3, newcoords ) - 1 ) ); 00539 } 00540 00541 std::cout << filenames[ifile] << ": unit sphere" 00542 << " degree= " << degree << " interpolation:\n"; 00543 std::cout << "maximum projection lift is " << mxdist << ", maximum error is " << mxerr << std::endl; 00544 mxdist = 0; 00545 mxerr = 0; 00546 hirec.reconstruct3D_surf_geom( degree, false, false, true ); 00547 00548 // fitting 00549 for( Range::iterator ielem = elems.begin(); ielem != elems.end(); ++ielem ) 00550 { 00551 int nvpe; 00552 const EntityHandle* conn; 00553 error = mbimpl->get_connectivity( *ielem, conn, nvpe );MB_CHK_ERR( error ); 00554 double w = 1.0 / (double)nvpe; 00555 std::vector< double > naturalcoords2fit( nvpe, w ); 00556 double newcoords[3], linearcoords[3]; 00557 error = hirec.hiproj_walf_in_element( *ielem, nvpe, 1, &( naturalcoords2fit[0] ), newcoords );MB_CHK_ERR( error ); 00558 std::vector< double > coords( 3 * nvpe ); 00559 error = mbimpl->get_coords( conn, nvpe, &( coords[0] ) );MB_CHK_ERR( error ); 00560 compute_linear_coords( nvpe, &( coords[0] ), &( naturalcoords2fit[0] ), linearcoords ); 00561 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00562 mxerr = std::max( mxerr, fabs( DGMSolver::vec_2norm( 3, newcoords ) - 1 ) ); 00563 } 00564 00565 std::cout << filenames[ifile] << ": unit sphere" 00566 << " degree= " << degree << " least square:\n"; 00567 std::cout << "maximum projection lift is " << mxdist << ", maximum error is " << mxerr << std::endl; 00568 } 00569 } 00570 00571 return error; 00572 } 00573 00574 ErrorCode test_unitcircle() 00575 { 00576 // path to test files 00577 int nfiles = 4; 00578 std::string filenames[] = { TestDir + "unittest/circle_3.vtk", TestDir + "unittest/circle_4.vtk", 00579 TestDir + "unittest/circle_10.vtk", TestDir + "unittest/circle_20.vtk" }; 00580 ErrorCode error; 00581 int maxdeg = 6; 00582 00583 for( int ifile = 0; ifile < nfiles; ++ifile ) 00584 { 00585 Core moab; 00586 Interface* mbimpl = &moab; 00587 ParallelComm* pc = 0; 00588 EntityHandle meshset; 00589 int dim = 1; 00590 // load file 00591 error = load_meshset_hirec( filenames[ifile].c_str(), mbimpl, meshset, pc, maxdeg, dim );MB_CHK_ERR( error ); 00592 // initialize 00593 HiReconstruction hirec( &moab, pc, meshset ); 00594 Range edges; 00595 error = mbimpl->get_entities_by_dimension( meshset, dim, edges );MB_CHK_ERR( error ); 00596 00597 // reconstruction 00598 for( int degree = 1; degree <= maxdeg; ++degree ) 00599 { 00600 hirec.reconstruct3D_curve_geom( degree, true, false, true ); 00601 // fitting 00602 double mxdist = 0, mxerr = 0; 00603 00604 for( Range::iterator iedge = edges.begin(); iedge != edges.end(); ++iedge ) 00605 { 00606 int nvpe; 00607 const EntityHandle* conn; 00608 error = mbimpl->get_connectivity( *iedge, conn, nvpe );MB_CHK_ERR( error ); 00609 double w = 1.0 / (double)nvpe; 00610 std::vector< double > naturalcoords2fit( nvpe, w ); 00611 double newcoords[3], linearcoords[3]; 00612 error = hirec.hiproj_walf_in_element( *iedge, nvpe, 1, &( naturalcoords2fit[0] ), newcoords );MB_CHK_ERR( error ); 00613 std::vector< double > coords( 3 * nvpe ); 00614 error = mbimpl->get_coords( conn, nvpe, &( coords[0] ) );MB_CHK_ERR( error ); 00615 compute_linear_coords( nvpe, &( coords[0] ), &( naturalcoords2fit[0] ), linearcoords ); 00616 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00617 mxerr = std::max( mxerr, fabs( DGMSolver::vec_2norm( 3, newcoords ) - 1 ) ); 00618 } 00619 00620 std::cout << filenames[ifile] << ": unit circle" 00621 << " degree= " << degree << " interpolation:\n"; 00622 std::cout << "maximum projection lift is " << mxdist << ", maximum error is " << mxerr << std::endl; 00623 mxdist = 0; 00624 mxerr = 0; 00625 hirec.reconstruct3D_curve_geom( degree, false, false, true ); 00626 00627 // fitting 00628 for( Range::iterator iedge = edges.begin(); iedge != edges.end(); ++iedge ) 00629 { 00630 int nvpe; 00631 const EntityHandle* conn; 00632 error = mbimpl->get_connectivity( *iedge, conn, nvpe );MB_CHK_ERR( error ); 00633 double w = 1.0 / (double)nvpe; 00634 std::vector< double > naturalcoords2fit( nvpe, w ); 00635 double newcoords[3], linearcoords[3]; 00636 error = hirec.hiproj_walf_in_element( *iedge, nvpe, 1, &( naturalcoords2fit[0] ), newcoords );MB_CHK_ERR( error ); 00637 std::vector< double > coords( 3 * nvpe ); 00638 error = mbimpl->get_coords( conn, nvpe, &( coords[0] ) );MB_CHK_ERR( error ); 00639 compute_linear_coords( nvpe, &( coords[0] ), &( naturalcoords2fit[0] ), linearcoords ); 00640 mxdist = std::max( mxdist, DGMSolver::vec_distance( 3, newcoords, linearcoords ) ); 00641 mxerr = std::max( mxerr, fabs( DGMSolver::vec_2norm( 3, newcoords ) - 1 ) ); 00642 } 00643 00644 std::cout << filenames[ifile] << ": unit circle" 00645 << " degree= " << degree << " least square:\n"; 00646 std::cout << "maximum projection lift is " << mxdist << ", maximum error is " << mxerr << std::endl; 00647 } 00648 } 00649 00650 return error; 00651 } 00652 00653 ErrorCode project_exact_torus( Interface* mbImpl, 00654 EntityHandle meshset, 00655 int dim, 00656 const double R, 00657 const double r, 00658 const double center[] ) 00659 { 00660 ErrorCode error; 00661 Range elems, verts; 00662 error = mbImpl->get_entities_by_dimension( meshset, dim, elems );CHECK_ERR( error ); 00663 error = mbImpl->get_connectivity( elems, verts );CHECK_ERR( error ); 00664 double pnts[3] = { 0, 0, 0 }, cnt[3] = { 0, 0, 0 }, nrms[3] = { 0, 0, 0 }; 00665 double x = 0, y = 0, z = 0, d1 = 0, d2 = 0; 00666 00667 for( int i = 0; i < (int)verts.size(); i++ ) 00668 { 00669 EntityHandle v = verts[i]; 00670 error = mbImpl->get_coords( &v, 1, &pnts[0] );CHECK_ERR( error ); 00671 x = pnts[0] - center[0]; 00672 y = pnts[1] - center[0]; 00673 z = pnts[2] - center[2]; 00674 d1 = sqrt( x * x + y * y ); 00675 cnt[0] = R * x / d1; 00676 cnt[1] = R * y / d1; 00677 cnt[2] = 0; 00678 d2 = sqrt( ( x - cnt[0] ) * ( x - cnt[0] ) + ( y - cnt[1] ) * ( y - cnt[1] ) + z * z ); 00679 nrms[0] = ( x - cnt[0] ) / d2; 00680 nrms[1] = ( y - cnt[1] ) / d2; 00681 nrms[2] = z / d2; 00682 pnts[0] = cnt[0] + r * nrms[0]; 00683 pnts[1] = cnt[1] + r * nrms[1]; 00684 pnts[2] = cnt[2] + r * nrms[2]; 00685 error = mbImpl->set_coords( &v, 1, &pnts[0] );CHECK_ERR( error ); 00686 } 00687 00688 return MB_SUCCESS; 00689 } 00690 00691 ErrorCode exact_error_torus( const double R, 00692 const double r, 00693 const double center[], 00694 int npnts, 00695 double* pnts, 00696 double& error_l1, 00697 double& error_l2, 00698 double& error_li ) 00699 { 00700 error_l1 = 0; 00701 error_l2 = 0; 00702 error_li = 0; 00703 double x = 0, y = 0, z = 0; 00704 double error_single = 0; 00705 00706 for( int i = 0; i < npnts; i++ ) 00707 { 00708 x = pnts[3 * i] - center[0]; 00709 y = pnts[3 * i + 1] - center[1]; 00710 z = pnts[3 * i + 2] - center[2]; 00711 error_single = fabs( sqrt( pow( sqrt( pow( x, 2 ) + pow( y, 2 ) ) - R, 2 ) + pow( z, 2 ) ) - r ); 00712 error_l1 = error_l1 + error_single; 00713 error_l2 = error_l2 + error_single * error_single; 00714 00715 if( error_li < error_single ) 00716 { 00717 error_li = error_single; 00718 } 00719 } 00720 00721 error_l1 = error_l1 / (double)npnts; 00722 error_l2 = sqrt( error_l2 / (double)npnts ); 00723 return MB_SUCCESS; 00724 }
