MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 // Usage: 00002 // tools/h5mtoscrip -w map_atm_to_ocn.h5m -s map_atm_to_ocn.nc --coords 00003 // 00004 #include <iostream> 00005 #include <exception> 00006 #include <cmath> 00007 #include <cassert> 00008 #include <vector> 00009 #include <string> 00010 #include <fstream> 00011 #include <iomanip> 00012 00013 #include "moab/ProgOptions.hpp" 00014 #include "moab/Core.hpp" 00015 00016 #ifdef MOAB_HAVE_MPI 00017 #include "moab_mpi.h" 00018 #endif 00019 00020 #ifndef MOAB_HAVE_TEMPESTREMAP 00021 #error Tool requires compilation with TempestRemap dependency 00022 #endif 00023 00024 // TempestRemap includes 00025 #include "OfflineMap.h" 00026 #include "netcdfcpp.h" 00027 #include "NetCDFUtilities.h" 00028 #include "DataArray2D.h" 00029 00030 using namespace moab; 00031 00032 template < typename T > 00033 ErrorCode get_vartag_data( moab::Interface* mbCore, 00034 Tag tag, 00035 moab::Range& sets, 00036 int& out_data_size, 00037 std::vector< T >& data ) 00038 { 00039 int* tag_sizes = new int[sets.size()]; 00040 const void** tag_data = (const void**)new void*[sets.size()]; 00041 00042 ErrorCode rval = mbCore->tag_get_by_ptr( tag, sets, tag_data, tag_sizes );MB_CHK_SET_ERR( rval, "Getting matrix rows failed" ); 00043 00044 out_data_size = 0; 00045 for( unsigned is = 0; is < sets.size(); ++is ) 00046 out_data_size += tag_sizes[is]; 00047 00048 data.resize( out_data_size ); 00049 int ioffset = 0; 00050 for( unsigned index = 0; index < sets.size(); index++ ) 00051 { 00052 T* m_vals = (T*)tag_data[index]; 00053 for( int k = 0; k < tag_sizes[index]; k++ ) 00054 { 00055 data[ioffset++] = m_vals[k]; 00056 } 00057 } 00058 00059 return moab::MB_SUCCESS; 00060 } 00061 00062 void ReadFileMetaData( std::string& metaFilename, std::map< std::string, std::string >& metadataVals ) 00063 { 00064 std::ifstream metafile; 00065 std::string line; 00066 00067 metafile.open( metaFilename.c_str() ); 00068 metadataVals["Title"] = "MOAB-TempestRemap (MBTR) Offline Regridding Weight Converter (h5mtoscrip)"; 00069 std::string key, value; 00070 while( std::getline( metafile, line ) ) 00071 { 00072 size_t lastindex = line.find_last_of( "=" ); 00073 key = line.substr( 0, lastindex - 1 ); 00074 value = line.substr( lastindex + 2, line.length() ); 00075 00076 metadataVals[std::string( key )] = std::string( value ); 00077 } 00078 metafile.close(); 00079 } 00080 00081 int main( int argc, char* argv[] ) 00082 { 00083 moab::ErrorCode rval; 00084 int dimension = 2; 00085 NcError error2( NcError::verbose_nonfatal ); 00086 std::stringstream sstr; 00087 ProgOptions opts; 00088 std::string h5mfilename, scripfile; 00089 bool noMap = false; 00090 bool writeXYCoords = false; 00091 00092 #ifdef MOAB_HAVE_MPI 00093 MPI_Init( &argc, &argv ); 00094 #endif 00095 00096 opts.addOpt< std::string >( "weights,w", "h5m remapping weights filename", &h5mfilename ); 00097 opts.addOpt< std::string >( "scrip,s", "Output SCRIP map filename", &scripfile ); 00098 opts.addOpt< int >( "dim,d", "Dimension of entities to use for partitioning", &dimension ); 00099 opts.addOpt< void >( "mesh,m", "Only convert the mesh and exclude the remap weight details", &noMap ); 00100 opts.addOpt< void >( "coords,c", "Write the center and vertex coordinates in lat/lon format", &writeXYCoords ); 00101 00102 opts.parseCommandLine( argc, argv ); 00103 00104 if( h5mfilename.empty() || scripfile.empty() ) 00105 { 00106 opts.printHelp(); 00107 exit( 1 ); 00108 } 00109 00110 moab::Interface* mbCore = new( std::nothrow ) moab::Core; 00111 00112 if( NULL == mbCore ) 00113 { 00114 return 1; 00115 } 00116 00117 // Set the read options for parallel file loading 00118 const std::string partition_set_name = "PARALLEL_PARTITION"; 00119 const std::string global_id_name = "GLOBAL_ID"; 00120 00121 // Load file 00122 rval = mbCore->load_mesh( h5mfilename.c_str() );MB_CHK_ERR( rval ); 00123 00124 try 00125 { 00126 00127 // Temporarily change rval reporting 00128 NcError error_temp( NcError::verbose_fatal ); 00129 00130 // Open an output file 00131 NcFile ncMap( scripfile.c_str(), NcFile::Replace, NULL, 0, NcFile::Offset64Bits ); 00132 if( !ncMap.is_valid() ) 00133 { 00134 _EXCEPTION1( "Unable to open output map file \"%s\"", scripfile.c_str() ); 00135 } 00136 00137 { 00138 // NetCDF-SCRIP Global Attributes 00139 std::map< std::string, std::string > mapAttributes; 00140 size_t lastindex = h5mfilename.find_last_of( "." ); 00141 std::stringstream sstr; 00142 sstr << h5mfilename.substr( 0, lastindex ) << ".meta"; 00143 std::string metaFilename = sstr.str(); 00144 ReadFileMetaData( metaFilename, mapAttributes ); 00145 mapAttributes["Command"] = 00146 "Converted with MOAB:h5mtoscrip with --w=" + h5mfilename + " and --s=" + scripfile; 00147 00148 // Add global attributes 00149 std::map< std::string, std::string >::const_iterator iterAttributes = mapAttributes.begin(); 00150 for( ; iterAttributes != mapAttributes.end(); iterAttributes++ ) 00151 { 00152 00153 std::cout << iterAttributes->first << " -- " << iterAttributes->second << std::endl; 00154 ncMap.add_att( iterAttributes->first.c_str(), iterAttributes->second.c_str() ); 00155 } 00156 std::cout << "\n"; 00157 } 00158 00159 Tag globalIDTag, materialSetTag; 00160 globalIDTag = mbCore->globalId_tag(); 00161 // materialSetTag = mbCore->material_tag(); 00162 rval = mbCore->tag_get_handle( "MATERIAL_SET", 1, MB_TYPE_INTEGER, materialSetTag, MB_TAG_SPARSE );MB_CHK_ERR( rval ); 00163 00164 // Get sets entities, by type 00165 moab::Range meshsets; 00166 rval = mbCore->get_entities_by_type_and_tag( 0, MBENTITYSET, &globalIDTag, NULL, 1, meshsets, 00167 moab::Interface::UNION, true );MB_CHK_ERR( rval ); 00168 00169 moab::EntityHandle rootset = 0; 00170 /////////////////////////////////////////////////////////////////////////// 00171 // The metadata in H5M file contains the following data: 00172 // 00173 // 1. n_a: Total source entities: (number of elements in source mesh) 00174 // 2. n_b: Total target entities: (number of elements in target mesh) 00175 // 3. nv_a: Max edge size of elements in source mesh 00176 // 4. nv_b: Max edge size of elements in target mesh 00177 // 5. maxrows: Number of rows in remap weight matrix 00178 // 6. maxcols: Number of cols in remap weight matrix 00179 // 7. nnz: Number of total nnz in sparse remap weight matrix 00180 // 8. np_a: The order of the field description on the source mesh: >= 1 00181 // 9. np_b: The order of the field description on the target mesh: >= 1 00182 // 10. method_a: The type of discretization for field on source mesh: [0 = FV, 1 = cGLL, 2 00183 // = dGLL] 00184 // 11. method_b: The type of discretization for field on target mesh: [0 = FV, 1 = cGLL, 2 00185 // = dGLL] 00186 // 12. conserved: Flag to specify whether the remap operator has conservation constraints: 00187 // [0, 1] 00188 // 13. monotonicity: Flags to specify whether the remap operator has monotonicity 00189 // constraints: [0, 1, 2] 00190 // 00191 /////////////////////////////////////////////////////////////////////////// 00192 Tag smatMetadataTag; 00193 int smat_metadata_glb[13]; 00194 rval = mbCore->tag_get_handle( "SMAT_DATA", 13, MB_TYPE_INTEGER, smatMetadataTag, MB_TAG_SPARSE );MB_CHK_ERR( rval ); 00195 rval = mbCore->tag_get_data( smatMetadataTag, &rootset, 1, smat_metadata_glb );MB_CHK_ERR( rval ); 00196 // std::cout << "Number of mesh sets is " << meshsets.size() << std::endl; 00197 00198 #define DTYPE( a ) \ 00199 { \ 00200 ( ( ( a ) == 0 ) ? "FV" : ( ( ( a ) == 1 ) ? "cGLL" : "dGLL" ) ) \ 00201 } 00202 // Map dimensions 00203 int nA = smat_metadata_glb[0]; 00204 int nB = smat_metadata_glb[1]; 00205 int nVA = smat_metadata_glb[2]; 00206 int nVB = smat_metadata_glb[3]; 00207 int nDofB = smat_metadata_glb[4]; 00208 int nDofA = smat_metadata_glb[5]; 00209 int NNZ = smat_metadata_glb[6]; 00210 int nOrdA = smat_metadata_glb[7]; 00211 int nOrdB = smat_metadata_glb[8]; 00212 int nBasA = smat_metadata_glb[9]; 00213 std::string methodA = DTYPE( nBasA ); 00214 int nBasB = smat_metadata_glb[10]; 00215 std::string methodB = DTYPE( nBasB ); 00216 int bConserved = smat_metadata_glb[11]; 00217 int bMonotonicity = smat_metadata_glb[12]; 00218 00219 EntityHandle source_mesh = 0, target_mesh = 0, overlap_mesh = 0; 00220 for( unsigned im = 0; im < meshsets.size(); ++im ) 00221 { 00222 moab::Range elems; 00223 rval = mbCore->get_entities_by_dimension( meshsets[im], 2, elems );MB_CHK_ERR( rval ); 00224 if( elems.size() - nA == 0 && source_mesh == 0 ) 00225 source_mesh = meshsets[im]; 00226 else if( elems.size() - nB == 0 && target_mesh == 0 ) 00227 target_mesh = meshsets[im]; 00228 else if( overlap_mesh == 0 ) 00229 overlap_mesh = meshsets[im]; 00230 else 00231 continue; 00232 } 00233 00234 Tag srcIDTag, srcAreaTag, tgtIDTag, tgtAreaTag; 00235 rval = mbCore->tag_get_handle( "SourceGIDS", srcIDTag );MB_CHK_ERR( rval ); 00236 rval = mbCore->tag_get_handle( "SourceAreas", srcAreaTag );MB_CHK_ERR( rval ); 00237 rval = mbCore->tag_get_handle( "TargetGIDS", tgtIDTag );MB_CHK_ERR( rval ); 00238 rval = mbCore->tag_get_handle( "TargetAreas", tgtAreaTag );MB_CHK_ERR( rval ); 00239 Tag smatRowdataTag, smatColdataTag, smatValsdataTag; 00240 rval = mbCore->tag_get_handle( "SMAT_ROWS", smatRowdataTag );MB_CHK_ERR( rval ); 00241 rval = mbCore->tag_get_handle( "SMAT_COLS", smatColdataTag );MB_CHK_ERR( rval ); 00242 rval = mbCore->tag_get_handle( "SMAT_VALS", smatValsdataTag );MB_CHK_ERR( rval ); 00243 Tag srcCenterLon, srcCenterLat, tgtCenterLon, tgtCenterLat; 00244 rval = mbCore->tag_get_handle( "SourceCoordCenterLon", srcCenterLon );MB_CHK_ERR( rval ); 00245 rval = mbCore->tag_get_handle( "SourceCoordCenterLat", srcCenterLat );MB_CHK_ERR( rval ); 00246 rval = mbCore->tag_get_handle( "TargetCoordCenterLon", tgtCenterLon );MB_CHK_ERR( rval ); 00247 rval = mbCore->tag_get_handle( "TargetCoordCenterLat", tgtCenterLat );MB_CHK_ERR( rval ); 00248 Tag srcVertexLon, srcVertexLat, tgtVertexLon, tgtVertexLat; 00249 rval = mbCore->tag_get_handle( "SourceCoordVertexLon", srcVertexLon );MB_CHK_ERR( rval ); 00250 rval = mbCore->tag_get_handle( "SourceCoordVertexLat", srcVertexLat );MB_CHK_ERR( rval ); 00251 rval = mbCore->tag_get_handle( "TargetCoordVertexLon", tgtVertexLon );MB_CHK_ERR( rval ); 00252 rval = mbCore->tag_get_handle( "TargetCoordVertexLat", tgtVertexLat );MB_CHK_ERR( rval ); 00253 00254 // Get sets entities, by type 00255 moab::Range sets; 00256 // rval = mbCore->get_entities_by_type(0, MBENTITYSET, sets);MB_CHK_ERR(rval); 00257 rval = mbCore->get_entities_by_type_and_tag( 0, MBENTITYSET, &smatRowdataTag, NULL, 1, sets, 00258 moab::Interface::UNION, true );MB_CHK_ERR( rval ); 00259 00260 std::vector< int > src_gids, tgt_gids; 00261 std::vector< double > src_areas, tgt_areas; 00262 int srcID_size, tgtID_size, srcArea_size, tgtArea_size; 00263 rval = get_vartag_data( mbCore, srcIDTag, sets, srcID_size, src_gids );MB_CHK_SET_ERR( rval, "Getting source mesh IDs failed" ); 00264 rval = get_vartag_data( mbCore, tgtIDTag, sets, tgtID_size, tgt_gids );MB_CHK_SET_ERR( rval, "Getting target mesh IDs failed" ); 00265 rval = get_vartag_data( mbCore, srcAreaTag, sets, srcArea_size, src_areas );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" ); 00266 rval = get_vartag_data( mbCore, tgtAreaTag, sets, tgtArea_size, tgt_areas );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" ); 00267 00268 assert( srcArea_size == srcID_size ); 00269 assert( tgtArea_size == tgtID_size ); 00270 00271 std::vector< double > src_glob_areas( nDofA, 0.0 ), tgt_glob_areas( nDofB, 0.0 ); 00272 for( int i = 0; i < srcArea_size; ++i ) 00273 { 00274 // printf("%d/%d: %d = Found ID %d and area %5.6e\n", i, srcArea_size, nDofA, 00275 // src_gids[i], src_areas[i]); 00276 assert( i < srcID_size ); 00277 assert( src_gids[i] < nDofA ); 00278 if( src_areas[i] > src_glob_areas[src_gids[i]] ) src_glob_areas[src_gids[i]] = src_areas[i]; 00279 } 00280 for( int i = 0; i < tgtArea_size; ++i ) 00281 { 00282 // printf("%d/%d: %d = Found ID %d and area %5.6e\n", i, tgtArea_size, nDofB, 00283 // tgt_gids[i], tgt_areas[i]); 00284 assert( i < tgtID_size ); 00285 assert( tgt_gids[i] < nDofB ); 00286 if( tgt_areas[i] > tgt_glob_areas[tgt_gids[i]] ) tgt_glob_areas[tgt_gids[i]] = tgt_areas[i]; 00287 } 00288 00289 // Write output dimensions entries 00290 int nSrcGridDims = 1; 00291 int nDstGridDims = 1; 00292 00293 NcDim* dimSrcGridRank = ncMap.add_dim( "src_grid_rank", nSrcGridDims ); 00294 NcDim* dimDstGridRank = ncMap.add_dim( "dst_grid_rank", nDstGridDims ); 00295 00296 NcVar* varSrcGridDims = ncMap.add_var( "src_grid_dims", ncInt, dimSrcGridRank ); 00297 NcVar* varDstGridDims = ncMap.add_var( "dst_grid_dims", ncInt, dimDstGridRank ); 00298 00299 if( nA == nDofA ) 00300 { 00301 varSrcGridDims->put( &nA, 1 ); 00302 varSrcGridDims->add_att( "name0", "num_elem" ); 00303 } 00304 else 00305 { 00306 varSrcGridDims->put( &nDofA, 1 ); 00307 varSrcGridDims->add_att( "name1", "num_dof" ); 00308 } 00309 00310 if( nB == nDofB ) 00311 { 00312 varDstGridDims->put( &nB, 1 ); 00313 varDstGridDims->add_att( "name0", "num_elem" ); 00314 } 00315 else 00316 { 00317 varDstGridDims->put( &nDofB, 1 ); 00318 varDstGridDims->add_att( "name1", "num_dof" ); 00319 } 00320 00321 // Source and Target mesh resolutions 00322 NcDim* dimNA = ncMap.add_dim( "n_a", nDofA ); 00323 NcDim* dimNB = ncMap.add_dim( "n_b", nDofB ); 00324 00325 // Source and Target verticecs per elements 00326 const int nva = ( nA == nDofA ? nVA : 1 ); 00327 const int nvb = ( nB == nDofB ? nVB : 1 ); 00328 NcDim* dimNVA = ncMap.add_dim( "nv_a", nva ); 00329 NcDim* dimNVB = ncMap.add_dim( "nv_b", nvb ); 00330 00331 // Source and Target verticecs per elements 00332 // NcDim * dimNEA = ncMap.add_dim("ne_a", nA); 00333 // NcDim * dimNEB = ncMap.add_dim("ne_b", nB); 00334 00335 if( writeXYCoords ) 00336 { 00337 // Write coordinates 00338 NcVar* varYCA = ncMap.add_var( "yc_a", ncDouble, dimNA /*dimNA*/ ); 00339 NcVar* varYCB = ncMap.add_var( "yc_b", ncDouble, dimNB /*dimNB*/ ); 00340 00341 NcVar* varXCA = ncMap.add_var( "xc_a", ncDouble, dimNA /*dimNA*/ ); 00342 NcVar* varXCB = ncMap.add_var( "xc_b", ncDouble, dimNB /*dimNB*/ ); 00343 00344 NcVar* varYVA = ncMap.add_var( "yv_a", ncDouble, dimNA /*dimNA*/, dimNVA ); 00345 NcVar* varYVB = ncMap.add_var( "yv_b", ncDouble, dimNB /*dimNB*/, dimNVB ); 00346 00347 NcVar* varXVA = ncMap.add_var( "xv_a", ncDouble, dimNA /*dimNA*/, dimNVA ); 00348 NcVar* varXVB = ncMap.add_var( "xv_b", ncDouble, dimNB /*dimNB*/, dimNVB ); 00349 00350 varYCA->add_att( "units", "degrees" ); 00351 varYCB->add_att( "units", "degrees" ); 00352 00353 varXCA->add_att( "units", "degrees" ); 00354 varXCB->add_att( "units", "degrees" ); 00355 00356 varYVA->add_att( "units", "degrees" ); 00357 varYVB->add_att( "units", "degrees" ); 00358 00359 varXVA->add_att( "units", "degrees" ); 00360 varXVB->add_att( "units", "degrees" ); 00361 00362 std::vector< double > src_centerlat, src_centerlon; 00363 int srccenter_size; 00364 rval = get_vartag_data( mbCore, srcCenterLat, sets, srccenter_size, src_centerlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" ); 00365 rval = get_vartag_data( mbCore, srcCenterLon, sets, srccenter_size, src_centerlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" ); 00366 std::vector< double > src_glob_centerlat( nDofA, 0.0 ), src_glob_centerlon( nDofA, 0.0 ); 00367 00368 for( int i = 0; i < srccenter_size; ++i ) 00369 { 00370 assert( i < srcID_size ); 00371 assert( src_gids[i] < nDofA ); 00372 00373 src_glob_centerlat[src_gids[i]] = src_centerlat[i]; 00374 src_glob_centerlon[src_gids[i]] = src_centerlon[i]; 00375 } 00376 00377 std::vector< double > tgt_centerlat, tgt_centerlon; 00378 int tgtcenter_size; 00379 rval = get_vartag_data( mbCore, tgtCenterLat, sets, tgtcenter_size, tgt_centerlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" ); 00380 rval = get_vartag_data( mbCore, tgtCenterLon, sets, tgtcenter_size, tgt_centerlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" ); 00381 std::vector< double > tgt_glob_centerlat( nDofB, 0.0 ), tgt_glob_centerlon( nDofB, 0.0 ); 00382 for( int i = 0; i < tgtcenter_size; ++i ) 00383 { 00384 assert( i < tgtID_size ); 00385 assert( tgt_gids[i] < nDofB ); 00386 00387 tgt_glob_centerlat[tgt_gids[i]] = tgt_centerlat[i]; 00388 tgt_glob_centerlon[tgt_gids[i]] = tgt_centerlon[i]; 00389 } 00390 00391 varYCA->put( &( src_glob_centerlat[0] ), nDofA ); 00392 varYCB->put( &( tgt_glob_centerlat[0] ), nDofB ); 00393 varXCA->put( &( src_glob_centerlon[0] ), nDofA ); 00394 varXCB->put( &( tgt_glob_centerlon[0] ), nDofB ); 00395 00396 src_centerlat.clear(); 00397 src_centerlon.clear(); 00398 tgt_centerlat.clear(); 00399 tgt_centerlon.clear(); 00400 00401 DataArray2D< double > src_glob_vertexlat( nDofA, nva ), src_glob_vertexlon( nDofA, nva ); 00402 if( nva > 1 ) 00403 { 00404 std::vector< double > src_vertexlat, src_vertexlon; 00405 int srcvertex_size; 00406 rval = get_vartag_data( mbCore, srcVertexLat, sets, srcvertex_size, src_vertexlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" ); 00407 rval = get_vartag_data( mbCore, srcVertexLon, sets, srcvertex_size, src_vertexlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" ); 00408 int offset = 0; 00409 for( unsigned vIndex = 0; vIndex < src_gids.size(); ++vIndex ) 00410 { 00411 for( int vNV = 0; vNV < nva; ++vNV ) 00412 { 00413 assert( offset < srcvertex_size ); 00414 src_glob_vertexlat[src_gids[vIndex]][vNV] = src_vertexlat[offset]; 00415 src_glob_vertexlon[src_gids[vIndex]][vNV] = src_vertexlon[offset]; 00416 offset++; 00417 } 00418 } 00419 } 00420 00421 DataArray2D< double > tgt_glob_vertexlat( nDofB, nvb ), tgt_glob_vertexlon( nDofB, nvb ); 00422 if( nvb > 1 ) 00423 { 00424 std::vector< double > tgt_vertexlat, tgt_vertexlon; 00425 int tgtvertex_size; 00426 rval = get_vartag_data( mbCore, tgtVertexLat, sets, tgtvertex_size, tgt_vertexlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" ); 00427 rval = get_vartag_data( mbCore, tgtVertexLon, sets, tgtvertex_size, tgt_vertexlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" ); 00428 int offset = 0; 00429 for( unsigned vIndex = 0; vIndex < tgt_gids.size(); ++vIndex ) 00430 { 00431 for( int vNV = 0; vNV < nvb; ++vNV ) 00432 { 00433 assert( offset < tgtvertex_size ); 00434 tgt_glob_vertexlat[tgt_gids[vIndex]][vNV] = tgt_vertexlat[offset]; 00435 tgt_glob_vertexlon[tgt_gids[vIndex]][vNV] = tgt_vertexlon[offset]; 00436 offset++; 00437 } 00438 } 00439 } 00440 00441 varYVA->put( &( src_glob_vertexlat[0][0] ), nDofA, nva ); 00442 varYVB->put( &( tgt_glob_vertexlat[0][0] ), nDofB, nvb ); 00443 00444 varXVA->put( &( src_glob_vertexlon[0][0] ), nDofA, nva ); 00445 varXVB->put( &( tgt_glob_vertexlon[0][0] ), nDofB, nvb ); 00446 } 00447 00448 // Write areas 00449 NcVar* varAreaA = ncMap.add_var( "area_a", ncDouble, dimNA ); 00450 varAreaA->put( &( src_glob_areas[0] ), nDofA ); 00451 // varAreaA->add_att("units", "steradians"); 00452 00453 NcVar* varAreaB = ncMap.add_var( "area_b", ncDouble, dimNB ); 00454 varAreaB->put( &( tgt_glob_areas[0] ), nDofB ); 00455 // varAreaB->add_att("units", "steradians"); 00456 00457 std::vector< int > mat_rows, mat_cols; 00458 std::vector< double > mat_vals; 00459 int row_sizes, col_sizes, val_sizes; 00460 rval = get_vartag_data( mbCore, smatRowdataTag, sets, row_sizes, mat_rows );MB_CHK_SET_ERR( rval, "Getting matrix row data failed" ); 00461 assert( row_sizes == NNZ ); 00462 rval = get_vartag_data( mbCore, smatColdataTag, sets, col_sizes, mat_cols );MB_CHK_SET_ERR( rval, "Getting matrix col data failed" ); 00463 assert( col_sizes == NNZ ); 00464 rval = get_vartag_data( mbCore, smatValsdataTag, sets, val_sizes, mat_vals );MB_CHK_SET_ERR( rval, "Getting matrix values failed" ); 00465 assert( val_sizes == NNZ ); 00466 00467 // Let us form the matrix in-memory and consolidate shared DoF rows from shared-process 00468 // contributions 00469 SparseMatrix< double > mapMatrix; 00470 00471 for( int innz = 0; innz < NNZ; ++innz ) 00472 { 00473 #ifdef VERBOSE 00474 if( fabs( mapMatrix( mat_rows[innz], mat_cols[innz] ) ) > 1e-12 ) 00475 { 00476 printf( "Adding to existing loc: (%d, %d) = %12.8f\n", mat_rows[innz], mat_cols[innz], 00477 mapMatrix( mat_rows[innz], mat_cols[innz] ) ); 00478 } 00479 #endif 00480 mapMatrix( mat_rows[innz], mat_cols[innz] ) += mat_vals[innz]; 00481 } 00482 00483 // Write SparseMatrix entries 00484 DataArray1D< int > vecRow; 00485 DataArray1D< int > vecCol; 00486 DataArray1D< double > vecS; 00487 00488 mapMatrix.GetEntries( vecRow, vecCol, vecS ); 00489 00490 int nS = vecS.GetRows(); 00491 00492 // Print more information about what we are converting: 00493 // Source elements/vertices/type (Discretization ?) 00494 // Target elements/vertices/type (Discretization ?) 00495 // Overlap elements/types 00496 // Rmeapping weights matrix: rows/cols/NNZ 00497 // Output the number of sets 00498 printf( "Primary sets: %15zu\n", sets.size() ); 00499 printf( "Original NNZ: %18d\n", NNZ ); 00500 printf( "Consolidated Total NNZ: %8d\n", nS ); 00501 printf( "Conservative weights ? %6d\n", ( bConserved > 0 ) ); 00502 printf( "Monotone weights ? %10d\n", ( bMonotonicity > 0 ) ); 00503 00504 printf( "\n--------------------------------------------------------------\n" ); 00505 printf( "%20s %21s %15s\n", "Description", "Source", "Target" ); 00506 printf( "--------------------------------------------------------------\n" ); 00507 00508 printf( "%25s %15d %15d\n", "Number of elements:", nA, nB ); 00509 printf( "%25s %15d %15d\n", "Number of DoFs:", nDofA, nDofB ); 00510 printf( "%25s %15d %15d\n", "Maximum vertex/element:", nVA, nVB ); 00511 printf( "%25s %15s %15s\n", "Discretization type:", methodA.c_str(), methodB.c_str() ); 00512 printf( "%25s %15d %15d\n", "Discretization order:", nOrdA, nOrdB ); 00513 00514 // Calculate and write fractional coverage arrays 00515 { 00516 DataArray1D< double > dFracA( nDofA ); 00517 DataArray1D< double > dFracB( nDofB ); 00518 00519 for( int i = 0; i < nS; i++ ) 00520 { 00521 // std::cout << i << " - mat_vals = " << mat_vals[i] << " dFracA = " << mat_vals[i] 00522 // / src_glob_areas[vecCol[i]] * tgt_glob_areas[vecRow[i]] << std::endl; 00523 dFracA[vecCol[i]] += vecS[i] / src_glob_areas[vecCol[i]] * tgt_glob_areas[vecRow[i]]; 00524 dFracB[vecRow[i]] += vecS[i]; 00525 } 00526 00527 NcVar* varFracA = ncMap.add_var( "frac_a", ncDouble, dimNA ); 00528 varFracA->put( &( dFracA[0] ), nDofA ); 00529 varFracA->add_att( "name", "fraction of target coverage of source dof" ); 00530 varFracA->add_att( "units", "unitless" ); 00531 00532 NcVar* varFracB = ncMap.add_var( "frac_b", ncDouble, dimNB ); 00533 varFracB->put( &( dFracB[0] ), nDofB ); 00534 varFracB->add_att( "name", "fraction of source coverage of target dof" ); 00535 varFracB->add_att( "units", "unitless" ); 00536 } 00537 00538 // Write out data 00539 NcDim* dimNS = ncMap.add_dim( "n_s", nS ); 00540 00541 NcVar* varRow = ncMap.add_var( "row", ncInt, dimNS ); 00542 varRow->add_att( "name", "sparse matrix target dof index" ); 00543 varRow->add_att( "first_index", "1" ); 00544 00545 NcVar* varCol = ncMap.add_var( "col", ncInt, dimNS ); 00546 varCol->add_att( "name", "sparse matrix source dof index" ); 00547 varCol->add_att( "first_index", "1" ); 00548 00549 NcVar* varS = ncMap.add_var( "S", ncDouble, dimNS ); 00550 varS->add_att( "name", "sparse matrix coefficient" ); 00551 00552 // Increment vecRow and vecCol: make it 1-based 00553 for( int i = 0; i < nS; i++ ) 00554 { 00555 vecRow[i]++; 00556 vecCol[i]++; 00557 } 00558 00559 varRow->set_cur( (long)0 ); 00560 varRow->put( &( vecRow[0] ), nS ); 00561 00562 varCol->set_cur( (long)0 ); 00563 varCol->put( &( vecCol[0] ), nS ); 00564 00565 varS->set_cur( (long)0 ); 00566 varS->put( &( vecS[0] ), nS ); 00567 00568 ncMap.close(); 00569 00570 // rval = mbCore->write_file(scripfile.c_str());MB_CHK_ERR(rval); 00571 } 00572 catch( std::exception& e ) 00573 { 00574 std::cout << " exception caught during tree initialization " << e.what() << std::endl; 00575 } 00576 delete mbCore; 00577 00578 #ifdef MOAB_HAVE_MPI 00579 MPI_Finalize(); 00580 #endif 00581 00582 exit( 0 ); 00583 }
