MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/LocalDiscretization/LinearTri.hpp" 00002 #include "moab/Forward.hpp" 00003 #include <algorithm> 00004 #include <cmath> 00005 #include <limits> 00006 00007 namespace moab 00008 { 00009 00010 const double LinearTri::corner[3][2] = { { 0, 0 }, { 1, 0 }, { 0, 1 } }; 00011 00012 ErrorCode LinearTri::initFcn( const double* verts, const int nverts, double*& work ) 00013 { 00014 // allocate work array as: 00015 // work[0..8] = T 00016 // work[9..17] = Tinv 00017 // work[18] = detT 00018 // work[19] = detTinv 00019 if( nverts != 3 ) 00020 { 00021 std::cout << "Invalid Triangle. Expected 3 vertices.\n"; 00022 return MB_FAILURE; 00023 } 00024 00025 assert( verts ); 00026 00027 Matrix3 J( verts[1 * 3 + 0] - verts[0 * 3 + 0], verts[2 * 3 + 0] - verts[0 * 3 + 0], 0.0, 00028 verts[1 * 3 + 1] - verts[0 * 3 + 1], verts[2 * 3 + 1] - verts[0 * 3 + 1], 0.0, 00029 verts[1 * 3 + 2] - verts[0 * 3 + 2], verts[2 * 3 + 2] - verts[0 * 3 + 2], 1.0 ); 00030 J *= 0.5; 00031 00032 // Update the work array 00033 if( !work ) work = new double[20]; 00034 00035 J.copyto( work ); 00036 J.inverse().copyto( work + Matrix3::size ); 00037 work[18] = J.determinant(); 00038 work[19] = ( work[18] < 1e-12 ? std::numeric_limits< double >::max() : 1.0 / work[18] ); 00039 00040 return MB_SUCCESS; 00041 } 00042 00043 ErrorCode LinearTri::evalFcn( const double* params, 00044 const double* field, 00045 const int /*ndim*/, 00046 const int num_tuples, 00047 double* /*work*/, 00048 double* result ) 00049 { 00050 assert( params && field && num_tuples > 0 ); 00051 // convert to [0,1] 00052 double p1 = 0.5 * ( 1.0 + params[0] ), p2 = 0.5 * ( 1.0 + params[1] ), p0 = 1.0 - p1 - p2; 00053 00054 for( int j = 0; j < num_tuples; j++ ) 00055 result[j] = p0 * field[0 * num_tuples + j] + p1 * field[1 * num_tuples + j] + p2 * field[2 * num_tuples + j]; 00056 00057 return MB_SUCCESS; 00058 } 00059 00060 ErrorCode LinearTri::integrateFcn( const double* field, 00061 const double* /*verts*/, 00062 const int nverts, 00063 const int /*ndim*/, 00064 const int num_tuples, 00065 double* work, 00066 double* result ) 00067 { 00068 assert( field && num_tuples > 0 ); 00069 std::fill( result, result + num_tuples, 0.0 ); 00070 for( int i = 0; i < nverts; ++i ) 00071 { 00072 for( int j = 0; j < num_tuples; j++ ) 00073 result[j] += field[i * num_tuples + j]; 00074 } 00075 double tmp = work[18] / 6.0; 00076 for( int i = 0; i < num_tuples; i++ ) 00077 result[i] *= tmp; 00078 00079 return MB_SUCCESS; 00080 } 00081 00082 ErrorCode LinearTri::jacobianFcn( const double*, const double*, const int, const int, double* work, double* result ) 00083 { 00084 // jacobian is cached in work array 00085 assert( work ); 00086 std::copy( work, work + 9, result ); 00087 return MB_SUCCESS; 00088 } 00089 00090 ErrorCode LinearTri::reverseEvalFcn( EvalFcn eval, 00091 JacobianFcn jacob, 00092 InsideFcn ins, 00093 const double* posn, 00094 const double* verts, 00095 const int nverts, 00096 const int ndim, 00097 const double iter_tol, 00098 const double inside_tol, 00099 double* work, 00100 double* params, 00101 int* is_inside ) 00102 { 00103 assert( posn && verts ); 00104 return evaluate_reverse( eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work, params, 00105 is_inside ); 00106 } 00107 00108 int LinearTri::insideFcn( const double* params, const int, const double tol ) 00109 { 00110 return ( params[0] >= -1.0 - tol && params[1] >= -1.0 - tol && params[0] + params[1] <= 1.0 + tol ); 00111 } 00112 00113 ErrorCode LinearTri::evaluate_reverse( EvalFcn eval, 00114 JacobianFcn jacob, 00115 InsideFcn inside_f, 00116 const double* posn, 00117 const double* verts, 00118 const int nverts, 00119 const int ndim, 00120 const double iter_tol, 00121 const double inside_tol, 00122 double* work, 00123 double* params, 00124 int* inside ) 00125 { 00126 // TODO: should differentiate between epsilons used for 00127 // Newton Raphson iteration, and epsilons used for curved boundary geometry errors 00128 // right now, fix the tolerance used for NR 00129 const double error_tol_sqr = iter_tol * iter_tol; 00130 CartVect* cvparams = reinterpret_cast< CartVect* >( params ); 00131 const CartVect* cvposn = reinterpret_cast< const CartVect* >( posn ); 00132 00133 // find best initial guess to improve convergence 00134 CartVect tmp_params[] = { CartVect( -1, -1, -1 ), CartVect( 1, -1, -1 ), CartVect( -1, 1, -1 ) }; 00135 double resl = std::numeric_limits< double >::max(); 00136 CartVect new_pos, tmp_pos; 00137 ErrorCode rval; 00138 for( unsigned int i = 0; i < 3; i++ ) 00139 { 00140 rval = ( *eval )( tmp_params[i].array(), verts, ndim, 3, work, tmp_pos.array() ); 00141 if( MB_SUCCESS != rval ) return rval; 00142 double tmp_resl = ( tmp_pos - *cvposn ).length_squared(); 00143 if( tmp_resl < resl ) 00144 { 00145 *cvparams = tmp_params[i]; 00146 new_pos = tmp_pos; 00147 resl = tmp_resl; 00148 } 00149 } 00150 00151 // residual is diff between old and new pos; need to minimize that 00152 CartVect res = new_pos - *cvposn; 00153 Matrix3 J; 00154 rval = ( *jacob )( cvparams->array(), verts, nverts, ndim, work, J[0] ); 00155 #ifndef NDEBUG 00156 double det = J.determinant(); 00157 assert( det > std::numeric_limits< double >::epsilon() ); 00158 #endif 00159 Matrix3 Ji = J.inverse(); 00160 00161 int iters = 0; 00162 // while |res| larger than tol 00163 while( res % res > error_tol_sqr ) 00164 { 00165 if( ++iters > 25 ) return MB_FAILURE; 00166 00167 // new params tries to eliminate residual 00168 *cvparams -= Ji * res; 00169 00170 // get the new forward-evaluated position, and its difference from the target pt 00171 rval = ( *eval )( params, verts, ndim, 3, work, new_pos.array() ); 00172 if( MB_SUCCESS != rval ) return rval; 00173 res = new_pos - *cvposn; 00174 } 00175 00176 if( inside ) *inside = ( *inside_f )( params, ndim, inside_tol ); 00177 00178 return MB_SUCCESS; 00179 } // Map::evaluate_reverse() 00180 00181 /* ErrorCode LinearTri::get_normal( int facet, double *work, double *normal) 00182 { 00183 ErrorCode error; 00184 //Get the local vertex ids of local edge 00185 int id1 = ledges[facet][0]; 00186 int id2 = ledges[facet][1]; 00187 00188 //Find the normal to the face 00189 double face_normal[3]; 00190 00191 00192 }*/ 00193 00194 ErrorCode LinearTri::normalFcn( const int ientDim, 00195 const int facet, 00196 const int nverts, 00197 const double* verts, 00198 double normal[3] ) 00199 { 00200 // assert(facet < 3 && ientDim == 1 && nverts==3); 00201 if( nverts != 3 ) MB_SET_ERR( MB_FAILURE, "Incorrect vertex count for passed triangle :: expected value = 3 " ); 00202 if( ientDim != 1 ) MB_SET_ERR( MB_FAILURE, "Requesting normal for unsupported dimension :: expected value = 1 " ); 00203 if( facet > 3 || facet < 0 ) MB_SET_ERR( MB_FAILURE, "Incorrect local edge id :: expected value = one of 0-2" ); 00204 00205 // Get the local vertex ids of local edge 00206 int id0 = CN::mConnectivityMap[MBTRI][ientDim - 1].conn[facet][0]; 00207 int id1 = CN::mConnectivityMap[MBTRI][ientDim - 1].conn[facet][1]; 00208 00209 // Find a vector along the edge 00210 double edge[3]; 00211 for( int i = 0; i < 3; i++ ) 00212 { 00213 edge[i] = verts[3 * id1 + i] - verts[3 * id0 + i]; 00214 } 00215 // Find the normal of the face 00216 double x0[3], x1[3], fnrm[3]; 00217 for( int i = 0; i < 3; i++ ) 00218 { 00219 x0[i] = verts[3 * 1 + i] - verts[3 * 0 + i]; 00220 x1[i] = verts[3 * 2 + i] - verts[3 * 0 + i]; 00221 } 00222 fnrm[0] = x0[1] * x1[2] - x1[1] * x0[2]; 00223 fnrm[1] = x1[0] * x0[2] - x0[0] * x1[2]; 00224 fnrm[2] = x0[0] * x1[1] - x1[0] * x0[1]; 00225 00226 // Find the normal of the edge as the cross product of edge and face normal 00227 00228 double a = edge[1] * fnrm[2] - fnrm[1] * edge[2]; 00229 double b = edge[2] * fnrm[0] - fnrm[2] * edge[0]; 00230 double c = edge[0] * fnrm[1] - fnrm[0] * edge[1]; 00231 double nrm = sqrt( a * a + b * b + c * c ); 00232 00233 if( nrm > std::numeric_limits< double >::epsilon() ) 00234 { 00235 normal[0] = a / nrm; 00236 normal[1] = b / nrm; 00237 normal[2] = c / nrm; 00238 } 00239 return MB_SUCCESS; 00240 } 00241 00242 } // namespace moab
