MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * IntxRllCssphere.cpp 00003 * 00004 * Created on: Aug 8, 2014 00005 * Author: iulian 00006 */ 00007 00008 #include "moab/IntxMesh/IntxRllCssphere.hpp" 00009 #include "moab/GeomUtil.hpp" 00010 #include "moab/IntxMesh/IntxUtils.hpp" 00011 00012 namespace moab 00013 { 00014 00015 IntxRllCssphere::IntxRllCssphere( Interface* mbimpl ) : Intx2Mesh( mbimpl ), R( 0.0 ), plane( 0 ) {} 00016 00017 IntxRllCssphere::~IntxRllCssphere() {} 00018 00019 /* 00020 * return also the area for robustness verification 00021 */ 00022 double IntxRllCssphere::setup_tgt_cell( EntityHandle tgt, int& nsTgt ) 00023 { 00024 // get coordinates of the tgt quad, to decide the gnomonic plane 00025 double cellArea = 0; 00026 00027 int num_nodes; 00028 ErrorCode rval = mb->get_connectivity( tgt, tgtConn, num_nodes ); 00029 00030 if( MB_SUCCESS != rval ) return 1; 00031 nsTgt = num_nodes; 00032 // these edges will never be polygons, only quads or triangles 00033 00034 // CartVect coords[4]; 00035 rval = mb->get_coords( tgtConn, nsTgt, &( tgtCoords[0][0] ) ); 00036 if( MB_SUCCESS != rval ) return 1; 00037 CartVect middle = tgtCoords[0]; 00038 for( int i = 1; i < nsTgt; i++ ) 00039 middle += tgtCoords[i]; 00040 middle = 1. / nsTgt * middle; 00041 00042 IntxUtils::decide_gnomonic_plane( middle, plane ); // output the plane 00043 for( int j = 0; j < nsTgt; j++ ) 00044 { 00045 // populate coords in the plane for intersection 00046 // they should be oriented correctly, positively 00047 int rc = IntxUtils::gnomonic_projection( tgtCoords[j], R, plane, tgtCoords2D[2 * j], tgtCoords2D[2 * j + 1] ); 00048 if( rc != 0 ) return 1; 00049 } 00050 00051 for( int j = 1; j < nsTgt - 1; j++ ) 00052 cellArea += IntxUtils::area2D( &tgtCoords2D[0], &tgtCoords2D[2 * j], &tgtCoords2D[2 * j + 2] ); 00053 00054 // take tgt coords in order and compute area in plane 00055 return cellArea; 00056 } 00057 00058 /* the elements are convex for sure, then do a gnomonic projection of both, 00059 * compute intersection in the plane, then go back to the sphere for the points 00060 * */ 00061 ErrorCode IntxRllCssphere::computeIntersectionBetweenTgtAndSrc( EntityHandle tgt, 00062 EntityHandle src, 00063 double* P, 00064 int& nP, 00065 double& area, 00066 int markb[MAXEDGES], 00067 int markr[MAXEDGES], 00068 int& nsSrc, 00069 int& nsTgt, 00070 bool check_boxes_first ) 00071 { 00072 // the area will be used from now on, to see how well we fill the tgt cell with polygons 00073 // the points will be at most 40; they will describe a convex patch, after the points will be 00074 // ordered and collapsed (eliminate doubles) 00075 00076 // CartVect srccoords[4]; 00077 int num_nodes = 0; 00078 ErrorCode rval = mb->get_connectivity( src, srcConn, num_nodes );MB_CHK_ERR( rval ); 00079 00080 nsSrc = num_nodes; 00081 rval = mb->get_coords( srcConn, nsSrc, &( srcCoords[0][0] ) );MB_CHK_ERR( rval ); 00082 00083 // determine the type of edge: const lat or not? 00084 // just look at the consecutive z coordinates for the edge 00085 for( int i = 0; i < nsSrc; i++ ) 00086 { 00087 int nexti = ( i + 1 ) % nsSrc; 00088 if( fabs( srcCoords[i][2] - srcCoords[nexti][2] ) < 1.e-6 ) 00089 srcEdgeType[i] = 1; 00090 else 00091 srcEdgeType[i] = 0; 00092 } 00093 area = 0.; 00094 nP = 0; // number of intersection points we are marking the boundary of src! 00095 if( check_boxes_first ) 00096 { 00097 // look at the boxes formed with vertices; if they are far away, return false early 00098 // make sure the tgt is setup already 00099 setup_tgt_cell( tgt, nsTgt ); // we do not need area here 00100 if( !GeomUtil::bounding_boxes_overlap( tgtCoords, nsTgt, srcCoords, nsSrc, box_error ) ) 00101 return MB_SUCCESS; // no error, but no intersection, decide early to get out 00102 } 00103 #ifdef ENABLE_DEBUG 00104 if( dbg_1 ) 00105 { 00106 std::cout << "tgt " << mb->id_from_handle( tgt ) << "\n"; 00107 for( int j = 0; j < nsTgt; j++ ) 00108 { 00109 std::cout << tgtCoords[j] << "\n"; 00110 } 00111 std::cout << "src " << mb->id_from_handle( src ) << "\n"; 00112 for( int j = 0; j < nsSrc; j++ ) 00113 { 00114 std::cout << srcCoords[j] << "\n"; 00115 } 00116 mb->list_entities( &tgt, 1 ); 00117 mb->list_entities( &src, 1 ); 00118 } 00119 #endif 00120 for( int j = 0; j < nsSrc; j++ ) 00121 { 00122 rval = IntxUtils::gnomonic_projection( srcCoords[j], R, plane, srcCoords2D[2 * j], srcCoords2D[2 * j + 1] );MB_CHK_ERR( rval ); 00123 } 00124 #ifdef ENABLE_DEBUG 00125 if( dbg_1 ) 00126 { 00127 std::cout << "gnomonic plane: " << plane << "\n"; 00128 std::cout << " tgt src\n"; 00129 for( int j = 0; j < nsTgt; j++ ) 00130 { 00131 std::cout << tgtCoords2D[2 * j] << " " << tgtCoords2D[2 * j + 1] << "\n"; 00132 } 00133 for( int j = 0; j < nsSrc; j++ ) 00134 { 00135 std::cout << srcCoords2D[2 * j] << " " << srcCoords2D[2 * j + 1] << "\n"; 00136 } 00137 } 00138 #endif 00139 rval = IntxUtils::EdgeIntxRllCs( srcCoords2D, srcCoords, srcEdgeType, nsSrc, tgtCoords2D, tgtCoords, nsTgt, markb, 00140 markr, plane, R, P, nP );MB_CHK_ERR( rval ); 00141 00142 int side[MAXEDGES] = { 0 }; // this refers to what side? src or tgt?// more tolerant here with epsilon_area 00143 int extraPoints = IntxUtils::borderPointsOfXinY2( srcCoords2D, nsSrc, tgtCoords2D, nsTgt, &( P[2 * nP] ), side, 00144 2 * epsilon_area ); 00145 if( extraPoints >= 1 ) 00146 { 00147 for( int k = 0; k < nsSrc; k++ ) 00148 { 00149 if( side[k] ) 00150 { 00151 // this means that vertex k of src is inside convex tgt; mark edges k-1 and k in 00152 // src, 00153 // as being "intersected" by tgt; (even though they might not be intersected by 00154 // other edges, the fact that their apex is inside, is good enough) 00155 markb[k] = 1; 00156 markb[( k + nsSrc - 1 ) % nsSrc] = 00157 1; // it is the previous edge, actually, but instead of doing -1, it is 00158 // better to do modulo +3 (modulo 4) 00159 // null side b for next call 00160 side[k] = 0; 00161 } 00162 } 00163 } 00164 nP += extraPoints; 00165 00166 extraPoints = 00167 IntxUtils::borderPointsOfCSinRLL( tgtCoords, tgtCoords2D, nsTgt, srcCoords, nsSrc, srcEdgeType, &( P[2 * nP] ), 00168 side, 00169 100 * epsilon_area ); // we need to compare with 0 a volume from 3 vector 00170 // product; // lots of round off errors at stake 00171 if( extraPoints >= 1 ) 00172 { 00173 for( int k = 0; k < nsTgt; k++ ) 00174 { 00175 if( side[k] ) 00176 { 00177 // this is to mark that tgt edges k-1 and k are intersecting src 00178 markr[k] = 1; 00179 markr[( k + nsTgt - 1 ) % nsTgt] = 00180 1; // it is the previous edge, actually, but instead of doing -1, it is 00181 // better to do modulo +3 (modulo 4) 00182 // null side b for next call 00183 } 00184 } 00185 } 00186 nP += extraPoints; 00187 00188 // now sort and orient the points in P, such that they are forming a convex polygon 00189 // this will be the foundation of our new mesh 00190 // this works if the polygons are convex 00191 IntxUtils::SortAndRemoveDoubles2( P, nP, epsilon_1 ); // nP should be at most 8 in the end ? 00192 // if there are more than 3 points, some area will be positive 00193 00194 if( nP >= 3 ) 00195 { 00196 for( int k = 1; k < nP - 1; k++ ) 00197 area += IntxUtils::area2D( P, &P[2 * k], &P[2 * k + 2] ); 00198 } 00199 00200 return MB_SUCCESS; // no error 00201 } 00202 00203 // this method will also construct the triangles/polygons in the new mesh 00204 // if we accept planar polygons, we just save them 00205 // also, we could just create new vertices every time, and merge only in the end; 00206 // could be too expensive, and the tolerance for merging could be an 00207 // interesting topic 00208 ErrorCode IntxRllCssphere::findNodes( EntityHandle tgt, int nsTgt, EntityHandle src, int nsSrc, double* iP, int nP ) 00209 { 00210 // first of all, check against tgt and src vertices 00211 // 00212 #ifdef ENABLE_DEBUG 00213 if( dbg_1 ) 00214 { 00215 std::cout << "tgt, src, nP, P " << mb->id_from_handle( tgt ) << " " << mb->id_from_handle( src ) << " " << nP 00216 << "\n"; 00217 for( int n = 0; n < nP; n++ ) 00218 std::cout << " \t" << iP[2 * n] << "\t" << iP[2 * n + 1] << "\n"; 00219 } 00220 #endif 00221 00222 // get the edges for the tgt triangle; the extra points will be on those edges, saved as 00223 // lists (unordered) 00224 00225 // first get the list of edges adjacent to the tgt cell 00226 // use the neighTgtEdgeTag 00227 EntityHandle adjTgtEdges[MAXEDGES]; 00228 ErrorCode rval = mb->tag_get_data( neighTgtEdgeTag, &tgt, 1, &( adjTgtEdges[0] ) );MB_CHK_SET_ERR( rval, "can't get edge tgt tag" ); 00229 // we know that we have only nsTgt edges here; [nsTgt, MAXEDGES) are ignored, but it is small 00230 // potatoes 00231 00232 // these will be in the new mesh, mbOut 00233 // some of them will be handles to the initial vertices from src or tgt meshes (lagr or euler) 00234 00235 EntityHandle* foundIds = new EntityHandle[nP]; 00236 for( int i = 0; i < nP; i++ ) 00237 { 00238 double* pp = &iP[2 * i]; // iP+2*i 00239 // project the point back on the sphere 00240 CartVect pos; 00241 IntxUtils::reverse_gnomonic_projection( pp[0], pp[1], R, plane, pos ); 00242 int found = 0; 00243 // first, are they on vertices from tgt or src? 00244 // priority is the tgt mesh (mb2?) 00245 int j = 0; 00246 EntityHandle outNode = (EntityHandle)0; 00247 for( j = 0; j < nsTgt && !found; j++ ) 00248 { 00249 // int node = tgtTri.v[j]; 00250 double d2 = IntxUtils::dist2( pp, &tgtCoords2D[2 * j] ); 00251 if( d2 < epsilon_1 ) 00252 { 00253 00254 foundIds[i] = tgtConn[j]; // no new node 00255 found = 1; 00256 #ifdef ENABLE_DEBUG 00257 if( dbg_1 ) 00258 std::cout << " tgt node j:" << j << " id:" << mb->id_from_handle( tgtConn[j] ) 00259 << " 2d coords:" << tgtCoords2D[2 * j] << " " << tgtCoords2D[2 * j + 1] << " d2: " << d2 00260 << " \n"; 00261 #endif 00262 } 00263 } 00264 00265 for( j = 0; j < nsSrc && !found; j++ ) 00266 { 00267 // int node = srcTri.v[j]; 00268 double d2 = IntxUtils::dist2( pp, &srcCoords2D[2 * j] ); 00269 if( d2 < epsilon_1 ) 00270 { 00271 // suspect is srcConn[j] corresponding in mbOut 00272 00273 foundIds[i] = srcConn[j]; // no new node 00274 found = 1; 00275 #ifdef ENABLE_DEBUG 00276 if( dbg_1 ) 00277 std::cout << " src node " << j << " " << mb->id_from_handle( srcConn[j] ) << " d2:" << d2 << " \n"; 00278 #endif 00279 } 00280 } 00281 if( !found ) 00282 { 00283 // find the edge it belongs, first, on the tgt element 00284 // 00285 for( j = 0; j < nsTgt; j++ ) 00286 { 00287 int j1 = ( j + 1 ) % nsTgt; 00288 double area = IntxUtils::area2D( &tgtCoords2D[2 * j], &tgtCoords2D[2 * j1], pp ); 00289 #ifdef ENABLE_DEBUG 00290 if( dbg_1 ) 00291 std::cout << " edge " << j << ": " << mb->id_from_handle( adjTgtEdges[j] ) << " " << tgtConn[j] 00292 << " " << tgtConn[j1] << " area : " << area << "\n"; 00293 #endif 00294 if( fabs( area ) < epsilon_1 / 2 ) 00295 { 00296 // found the edge; now find if there is a point in the list here 00297 // std::vector<EntityHandle> * expts = extraNodesMap[tgtEdges[j]]; 00298 int indx = TgtEdges.index( adjTgtEdges[j] ); 00299 // CID 181167 (#1 of 1): Argument cannot be negative (NEGATIVE_RETURNS) 00300 if( indx < 0 ) 00301 { 00302 std::cerr << " error in adjacent tgt edge: " << mb->id_from_handle( adjTgtEdges[j] ) << "\n"; 00303 delete[] foundIds; 00304 return MB_FAILURE; 00305 } 00306 std::vector< EntityHandle >* expts = extraNodesVec[indx]; 00307 // if the points pp is between extra points, then just give that id 00308 // if not, create a new point, (check the id) 00309 // get the coordinates of the extra points so far 00310 int nbExtraNodesSoFar = expts->size(); 00311 if( nbExtraNodesSoFar > 0 ) 00312 { 00313 CartVect* coords1 = new CartVect[nbExtraNodesSoFar]; 00314 mb->get_coords( &( *expts )[0], nbExtraNodesSoFar, &( coords1[0][0] ) ); 00315 // std::list<int>::iterator it; 00316 for( int k = 0; k < nbExtraNodesSoFar && !found; k++ ) 00317 { 00318 // int pnt = *it; 00319 double d2 = ( pos - coords1[k] ).length_squared(); 00320 if( d2 < epsilon_1 ) 00321 { 00322 found = 1; 00323 foundIds[i] = ( *expts )[k]; 00324 #ifdef ENABLE_DEBUG 00325 if( dbg_1 ) std::cout << " found node:" << foundIds[i] << std::endl; 00326 #endif 00327 } 00328 } 00329 delete[] coords1; 00330 } 00331 if( !found ) 00332 { 00333 // create a new point in 2d (at the intersection) 00334 // foundIds[i] = m_num2dPoints; 00335 // expts.push_back(m_num2dPoints); 00336 // need to create a new node in mbOut 00337 // this will be on the edge, and it will be added to the local list 00338 mb->create_vertex( pos.array(), outNode ); 00339 ( *expts ).push_back( outNode ); 00340 foundIds[i] = outNode; 00341 found = 1; 00342 #ifdef ENABLE_DEBUG 00343 if( dbg_1 ) std::cout << " new node: " << outNode << std::endl; 00344 #endif 00345 } 00346 } 00347 } 00348 } 00349 if( !found ) 00350 { 00351 std::cout << " tgt quad: "; 00352 for( int j1 = 0; j1 < nsTgt; j1++ ) 00353 { 00354 std::cout << tgtCoords2D[2 * j1] << " " << tgtCoords2D[2 * j1 + 1] << "\n"; 00355 } 00356 std::cout << " a point pp is not on a tgt quad " << *pp << " " << pp[1] << " tgt quad " 00357 << mb->id_from_handle( tgt ) << " \n"; 00358 delete[] foundIds; 00359 return MB_FAILURE; 00360 } 00361 } 00362 #ifdef ENABLE_DEBUG 00363 if( dbg_1 ) 00364 { 00365 std::cout << " candidate polygon: nP" << nP << " plane: " << plane << "\n"; 00366 for( int i1 = 0; i1 < nP; i1++ ) 00367 std::cout << iP[2 * i1] << " " << iP[2 * i1 + 1] << " " << foundIds[i1] << "\n"; 00368 } 00369 #endif 00370 // first, find out if we have nodes collapsed; shrink them 00371 // we may have to reduce nP 00372 // it is possible that some nodes are collapsed after intersection only 00373 // nodes will always be in order (convex intersection) 00374 correct_polygon( foundIds, nP ); 00375 // now we can build the triangles, from P array, with foundIds 00376 // we will put them in the out set 00377 if( nP >= 3 ) 00378 { 00379 EntityHandle polyNew; 00380 mb->create_element( MBPOLYGON, foundIds, nP, polyNew ); 00381 mb->add_entities( outSet, &polyNew, 1 ); 00382 00383 // tag it with the index ids from tgt and src sets 00384 int id = rs1.index( src ); // index starts from 0 00385 mb->tag_set_data( srcParentTag, &polyNew, 1, &id ); 00386 id = rs2.index( tgt ); 00387 mb->tag_set_data( tgtParentTag, &polyNew, 1, &id ); 00388 00389 counting++; 00390 mb->tag_set_data( countTag, &polyNew, 1, &counting ); 00391 00392 #ifdef ENABLE_DEBUG 00393 if( dbg_1 ) 00394 { 00395 00396 std::cout << "Counting: " << counting << "\n"; 00397 std::cout << " polygon " << mb->id_from_handle( polyNew ) << " nodes: " << nP << " :"; 00398 for( int i1 = 0; i1 < nP; i1++ ) 00399 std::cout << " " << mb->id_from_handle( foundIds[i1] ); 00400 std::cout << " plane: " << plane << "\n"; 00401 std::vector< CartVect > posi( nP ); 00402 mb->get_coords( foundIds, nP, &( posi[0][0] ) ); 00403 for( int i1 = 0; i1 < nP; i1++ ) 00404 std::cout << foundIds[i1] << " " << posi[i1] << "\n"; 00405 00406 std::stringstream fff; 00407 fff << "file0" << counting << ".vtk"; 00408 mb->write_mesh( fff.str().c_str(), &outSet, 1 ); 00409 } 00410 #endif 00411 } 00412 // disable_debug(); 00413 delete[] foundIds; 00414 foundIds = NULL; 00415 return MB_SUCCESS; 00416 } 00417 00418 } /* namespace moab */
