MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* WriteDamsel.cpp 00002 * The Damsel library provides mesh-aware parallel I/O; see 00003 * http://cucis.ece.northwestern.edu/projects/DAMSEL/ for details, though for now that site is 00004 * restricted to project participants. Damsel uses a data model that's very similar to that used in 00005 * MOAB and ITAPS. It uses the same basic data model concepts of entities, sets, tags, and 00006 * interface. In theory, we should be able to completely save/restore to/from Damsel any data that 00007 * can be saved/restored to/from our native HDF5-based reader/writer. 00008 * 00009 * Mapping between MOAB-Damsel data models 00010 * ======================================= 00011 * Basic data model entities, MOAB <--> Damsel: 00012 * Entity <--> Entity 00013 * EntitySet <--> Collection 00014 * Tag <--> Tag 00015 * API/data strutures: 00016 * Range (n1) <--> Sequence container 00017 * std::vector <--> Vector container 00018 * Range (n2) <--> Tree container 00019 * 00020 * n1: single contiguous subrange 00021 * n2: multiple subranges 00022 * 00023 * Conventions 00024 * =========== 00025 * There are parts of MOAB data structures that need to be stored to Damsel that aren't represented 00026 * in the Damsel data model, e.g. dense vs. sparse storage type, set tracking flags. 00027 * - We need to store these as tags in Damsel. 00028 * - Since Damsel tags need to have a MOAB counterpart, we have to create those as tag data in MOAB 00029 * too (duplicating the data in the data structures, bummer). 00030 * - Because we may want to use these tags for multiple Damsel writes/models, we create the 00031 * MOAB-side tags in the WriteDamsel constructor, not in the init_tags function that's called for 00032 * every write 00033 * - Conventional tags have names prefixed with mbdmsl_ to avoid name conflicts with other MOAB 00034 * tags. Here we list the conventional tags used by MOAB's Damsel reader/writer. 00035 * 00036 * Tag name Tag char's (storage type, data type, length, def val) Values, 00037 * used for what 00038 * -------- ----------------------------------------------------- 00039 * -------------------- mbdmsl_XCOORDS dense; double[1]; 0.0 MOAB vertex x coordinate 00040 * mbdmsl_YCOORDS dense; double[1]; 0.0 MOAB 00041 * vertex y coordinate mbdmsl_ZCOORDS dense; double[1]; 0.0 MOAB vertex z coordinate 00042 * mbdmsl_COLL_FLAGS sparse; char; 1; 0x0 bit 0: 00043 * 0=set-type, 1=vector-type 1: 1=tracking, 0=not tracking mbdmsl_PARENTS sparse; handle; var; 00044 * (list of parent sets) mbdmsl_CHILDS sparse; handle; var; (list of child sets) 00045 * 00046 * 00047 * 00048 */ 00049 00050 #include "WriteDamsel.hpp" 00051 00052 #include "DamselUtil.hpp" 00053 #include "damsel.h" 00054 #include <cassert> 00055 #include "moab/Interface.hpp" 00056 #include "moab/Core.hpp" 00057 #include "moab/Range.hpp" 00058 #include "moab/Error.hpp" 00059 #include "moab/WriteUtilIface.hpp" 00060 #include "MBTagConventions.hpp" 00061 #include "EntitySequence.hpp" 00062 #include "Internals.hpp" 00063 #include "DenseTag.hpp" 00064 #include "SparseTag.hpp" 00065 00066 namespace moab 00067 { 00068 00069 WriterIface* WriteDamsel::factory( Interface* iface ) 00070 { 00071 return new WriteDamsel( iface ); 00072 } 00073 00074 WriteDamsel::WriteDamsel( Interface* impl ) 00075 : mbImpl( impl ), mWriteIface( NULL ), sequenceManager( NULL ), dU(), DAMSEL_FLAGS( DAMSEL_IS_TRACKING ) 00076 { 00077 assert( impl != NULL ); 00078 00079 impl->query_interface( mWriteIface ); 00080 assert( mWriteIface ); 00081 00082 sequenceManager = dynamic_cast< Core* >( impl )->sequence_manager(); 00083 assert( sequenceManager ); 00084 00085 ErrorCode rval = 00086 mbImpl->tag_get_handle( "mbdmsl_XCOORDS", 1, MB_TYPE_DOUBLE, dU.xcoordsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_XCOORDS" ); 00087 dU.xcoordsTag.tagType = MB_TAG_ANY; 00088 dU.tagMap.push_back( dU.xcoordsTag ); 00089 rval = 00090 mbImpl->tag_get_handle( "mbdmsl_YCOORDS", 1, MB_TYPE_DOUBLE, dU.ycoordsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_YCOORDS" ); 00091 dU.ycoordsTag.tagType = MB_TAG_ANY; 00092 dU.tagMap.push_back( dU.ycoordsTag ); 00093 00094 rval = 00095 mbImpl->tag_get_handle( "mbdmsl_ZCOORDS", 1, MB_TYPE_DOUBLE, dU.zcoordsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_ZCOORDS" ); 00096 dU.zcoordsTag.tagType = MB_TAG_ANY; 00097 dU.tagMap.push_back( dU.zcoordsTag ); 00098 00099 rval = mbImpl->tag_get_handle( "mbdmsl_COLL_FLAGS", 1, MB_TYPE_INTEGER, dU.collFlagsTag.mTagh, 00100 MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_COLL_FLAGS" ); 00101 dU.collFlagsTag.tagType = MB_TAG_ANY; 00102 dU.tagMap.push_back( dU.collFlagsTag ); 00103 00104 /* 00105 rval = mbImpl->tag_get_handle("mbdmsl_PARENTS", 1, MB_TYPE_HANDLE, 00106 dU.parentsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT | 00107 MB_TAG_VARLEN);MB_CHK_SET_ERR_CONT(rval, "Failed to create_tag mbdmsl_PARENTS"); 00108 dU.parentsTag.tagType = MB_TAG_DENSE; 00109 dU.tagMap.push_back(dU.parentsTag); 00110 00111 rval = mbImpl->tag_get_handle("mbdmsl_CHILDREN", 1, MB_TYPE_HANDLE, 00112 dU.childrenTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT | 00113 MB_TAG_VARLEN);MB_CHK_SET_ERR_CONT(rval, "Failed to create_tag mbdmsl_CHILDREN"); 00114 dU.childrenTag.tagType = MB_TAG_DENSE; 00115 dU.tagMap.push_back(dU.childrenTag); 00116 */ 00117 00118 dU.moabHandleType = ( sizeof( EntityHandle ) == 64 ? DAMSEL_HANDLE_TYPE_HANDLE64 : DAMSEL_HANDLE_TYPE_HANDLE32 ); 00119 } 00120 00121 WriteDamsel::~WriteDamsel() 00122 { 00123 if( mWriteIface ) mbImpl->release_interface( mWriteIface ); 00124 } 00125 00126 ErrorCode WriteDamsel::write_file( const char* file_name, 00127 const bool /* overwrite */, 00128 const FileOptions& opts, 00129 const EntityHandle* meshset_list, 00130 const int num_sets, 00131 const std::vector< std::string >& /* qa_records */, 00132 const Tag* /* tag_list */, 00133 int /* num_tags */, 00134 int /* requested_output_dimension */ ) 00135 { 00136 // Gather all entities into one big range 00137 Range all_ents; 00138 ErrorCode rval; 00139 damsel_err_t err; 00140 00141 dU.dmslLib = DMSLlib_init(); 00142 00143 // Create a damsel model 00144 dU.dmslModel = 00145 DMSLmodel_create( sizeof( EntityHandle ) == 8 ? DAMSEL_HANDLE_TYPE_HANDLE64 : DAMSEL_HANDLE_TYPE_HANDLE32 ); 00146 00147 // Attach to a file, since we need it for creating containers 00148 MPI_Comm comm = MPI_COMM_WORLD; 00149 unlink( file_name ); 00150 err = DMSLmodel_attach( dU.dmslModel, file_name, comm, NULL ); 00151 CHK_DMSL_ERR( err, "DMSLmodel_attach failed" ); 00152 00153 rval = mWriteIface->gather_entities( all_ents, meshset_list, num_sets );MB_CHK_SET_ERR( rval, "Gather entities failed in WriteDamsel" ); 00154 00155 if( all_ents.empty() ) return MB_SUCCESS; 00156 00157 // Create damsel tags for MOAB dense, sparse, and conventional tags 00158 rval = init_tag_info();MB_CHK_ERR( rval ); 00159 00160 // Iterate through the groups of contiguous sequences of handles 00161 RangeSeqIntersectIter rsi( sequenceManager ); 00162 rval = rsi.init( all_ents.begin(), all_ents.end() ); 00163 00164 while( MB_SUCCESS == rval ) 00165 { 00166 // Write subrange of things to damsel: map handles, map entity definition data 00167 // (connectivity/coords/set contents), map dense tags 00168 rval = write_subrange( rsi );MB_CHK_SET_ERR( rval, "Failed to write subrange" ); 00169 00170 rval = rsi.step(); 00171 while( MB_ENTITY_NOT_FOUND == rval ) 00172 rval = rsi.step(); 00173 } 00174 00175 // Write sparse tags 00176 rval = map_sparse_tags();MB_CHK_SET_ERR( rval, "Failed to write sparse tags" ); 00177 00178 // damsel_request_t request; 00179 // err = DMSLmodel_transfer_async(dU.dmslModel, DAMSEL_TRANSFER_TYPE_WRITE, &request); 00180 err = DMSLmodel_transfer_sync( dU.dmslModel, DAMSEL_TRANSFER_TYPE_WRITE ); 00181 CHK_DMSL_ERR( err, "DMSLmodel_transfer_asynch failed" ); 00182 00183 // damsel_status_t status; 00184 // err = DMSLmodel_wait(request, &status);CHK_DMSL_ERR(err, "DMSLmodel_wait failed"); 00185 00186 DMSLmodel_close( dU.dmslModel ); 00187 00188 DMSLlib_finalize( dU.dmslLib ); 00189 00190 // We should be done 00191 return MB_SUCCESS; 00192 } 00193 00194 ErrorCode WriteDamsel::init_tag_info() 00195 { 00196 // Initialize allTags and tagIndices 00197 std::vector< Tag > tmp_mtags; 00198 ErrorCode rval = mbImpl->tag_get_tags( tmp_mtags );MB_CHK_SET_ERR( rval, "Failed to get all tag handles." ); 00199 int dum_size; 00200 damsel_err_t err; 00201 00202 // Define damsel tag handles for all dense/sparse tags 00203 for( std::vector< Tag >::iterator vit = tmp_mtags.begin(); vit != tmp_mtags.end(); ++vit ) 00204 { 00205 if( ( ( *vit )->get_storage_type() != MB_TAG_DENSE && ( *vit )->get_storage_type() != MB_TAG_SPARSE ) || 00206 mbImpl->tag_get_length( *vit, dum_size ) == MB_VARIABLE_DATA_LENGTH || dum_size != 1 ) 00207 { 00208 std::cerr << "Warning: tag " << ( *vit )->get_name() 00209 << "is not of type dense or sparse, and is not currently supported by the " 00210 "damsel writer." 00211 << std::endl; 00212 continue; 00213 } 00214 00215 std::vector< DamselUtil::tinfo >::iterator vit2 = 00216 std::find_if( dU.tagMap.begin(), dU.tagMap.end(), DamselUtil::MtagP< DamselUtil::tinfo >( *vit ) ); 00217 00218 if( vit2 != dU.tagMap.end() && ( *vit2 ).tagType == MB_TAG_ANY ) 00219 // Conventional tag - skip 00220 continue; 00221 00222 else if( vit2 == dU.tagMap.end() ) 00223 { 00224 // Create a damsel counterpart for this tag 00225 Tag thandle = *vit; 00226 err = DMSLtag_define( dU.dmslModel, (damsel_handle_ptr)&thandle, 00227 DamselUtil::mtod_data_type[( *vit )->get_data_type()], ( *vit )->get_name().c_str() ); 00228 CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" ); 00229 dU.tagMap.push_back( DamselUtil::tinfo( thandle, 0, ( *vit )->get_storage_type() ) ); 00230 } 00231 else 00232 { 00233 // Assert there's a corresponding moab tag handle 00234 assert( ( *vit2 ).mTagh ); 00235 } 00236 } 00237 00238 // Do the same for conventional tags: 00239 // XCOORDS 00240 err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.xcoordsTag.mTagh ), 00241 DamselUtil::mtod_data_type[MB_TYPE_DOUBLE], dU.xcoordsTag.mTagh->get_name().c_str() ); 00242 dU.tagMap.push_back( dU.xcoordsTag ); 00243 CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" ); 00244 00245 // YCOORDS 00246 err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.ycoordsTag.mTagh ), 00247 DamselUtil::mtod_data_type[MB_TYPE_DOUBLE], dU.ycoordsTag.mTagh->get_name().c_str() ); 00248 dU.tagMap.push_back( dU.ycoordsTag ); 00249 CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" ); 00250 00251 // ZCOORDS 00252 err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.zcoordsTag.mTagh ), 00253 DamselUtil::mtod_data_type[MB_TYPE_DOUBLE], dU.zcoordsTag.mTagh->get_name().c_str() ); 00254 dU.tagMap.push_back( dU.zcoordsTag ); 00255 CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" ); 00256 00257 // COLL_FLAGS 00258 err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.collFlagsTag.mTagh ), 00259 DamselUtil::mtod_data_type[MB_TYPE_INTEGER], dU.collFlagsTag.mTagh->get_name().c_str() ); 00260 dU.tagMap.push_back( dU.collFlagsTag ); 00261 CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" ); 00262 00263 /* 00264 SKIP PARENTS/CHILDREN FOR NOW, UNTIL WE HAVE VAR LENGTH TAGS IN DAMSEL 00265 00266 // PARENTS 00267 dU.parentsTagPair.second = DMSLtag_define(dU.dmslModel, 00268 (damsel_handle_ptr)&(dU.collFlagsTagPair.first), 00269 DamselUtil::mtod_data_type[(dU.collFlagsTagPair.first)->get_data_type()], 00270 (dU.parentsTagPair.first)->get_name().c_str()); 00271 if (DAMSEL_TAG_INVALID == dtag) 00272 MB_SET_ERR(MB_FAILURE, "Failure to get Damsel tag for MOAB tag " << 00273 (dU.parentsTagPair.first)->get_name()); 00274 00275 // CHILDREN 00276 dU.childrenTagPair.second = DMSLtag_define(dU.dmslModel, 00277 (damsel_handle_ptr)&(dU.collFlagsTagPair.first), 00278 DamselUtil::mtod_data_type[(dU.collFlagsTagPair.first)->get_data_type()], 00279 (dU.childrenTagPair.first)->get_name().c_str()); 00280 if (DAMSEL_TAG_INVALID == dtag) 00281 MB_SET_ERR(MB_FAILURE, "Failure to get Damsel tag for MOAB tag " << 00282 (dU.childrenTagPair.first)->get_name()); 00283 */ 00284 00285 // Map the tag handles in one big call 00286 int num_tags = dU.tagMap.size(); 00287 std::vector< Tag > moab_taghs; 00288 moab_taghs.reserve( num_tags ); 00289 for( std::vector< DamselUtil::tinfo >::iterator vit = dU.tagMap.begin(); vit != dU.tagMap.end(); ++vit ) 00290 { 00291 moab_taghs.push_back( ( *vit ).mTagh ); 00292 } 00293 00294 damsel_container mtags = 00295 DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle_ptr)&moab_taghs[0], moab_taghs.size() ); 00296 std::cerr << "MOAB: created model container: mtags = " << mtags << std::endl; 00297 00298 err = DMSLmodel_map_handles_inventing_file_handles( mtags ); 00299 CHK_DMSL_ERR( err, "Failed to map tag handles" ); 00300 00301 err = DMSLcontainer_release( mtags ); 00302 CHK_DMSL_ERR( err, "Problem releasing tag handle container" ); 00303 00304 return MB_SUCCESS; 00305 } 00306 00307 ErrorCode WriteDamsel::write_vertices( RangeSeqIntersectIter& rsi ) 00308 { 00309 // Write the vertices; these vertices will be in the same sequence and will be contiguous, 00310 // guaranteed 00311 EntityHandle start_vert = rsi.get_start_handle(), end_vert = rsi.get_end_handle(); 00312 00313 // Create a damsel container for these vertex handles 00314 damsel_container vertex_cont = 00315 DMSLcontainer_create_sequence( dU.dmslModel, start_vert, (int)( end_vert - start_vert + 1 ), 1 ); 00316 std::cerr << "MOAB: created model container: vertex_cont = " << vertex_cont << std::endl; 00317 if( DAMSEL_CONTAINER_INVALID == vertex_cont ) 00318 MB_SET_ERR( MB_FAILURE, 00319 "Failed to create vertex sequence for vertices starting with handle " << rsi.get_start_handle() ); 00320 00321 damsel_err_t err = DMSLmodel_map_handles_inventing_file_handles( vertex_cont ); 00322 CHK_DMSL_ERR( err, "Failed to map handles" ); 00323 00324 // Define the entities to damsel 00325 err = DMSLentity_define( vertex_cont, DAMSEL_ENTITY_TYPE_VERTEX, 1, vertex_cont ); 00326 CHK_DMSL_ERR( err, "Failure in DMSLentity_define for vertices starting with handle " << rsi.get_start_handle() ); 00327 00328 // Get the vertex coordinates storage locations and pass to damsel 00329 Range vert_range( start_vert, end_vert ); 00330 double *xcoords = NULL, *ycoords = NULL, *zcoords = NULL; 00331 int count; 00332 ErrorCode rval = mbImpl->coords_iterate( vert_range.begin(), vert_range.end(), xcoords, ycoords, zcoords, count );MB_CHK_SET_ERR( rval, 00333 "Failed to get coordinate iterator for vertices starting with handle " << rsi.get_start_handle() ); 00334 if( count != (int)vert_range.size() ) 00335 { 00336 MB_SET_ERR( MB_FAILURE, "Vertex subrange not in the same sequence for vertices starting with handle " 00337 << rsi.get_start_handle() ); 00338 } 00339 00340 if( xcoords && !ycoords && !zcoords ) 00341 { 00342 // Interleaved 00343 00344 // Map the data to damsel 00345 err = DMSLmodel_map_tag( xcoords, vertex_cont, (damsel_handle_ptr)&dU.xcoordsTag.mTagh ); 00346 CHK_DMSL_ERR( err, "Failed to assign vertex coordinates tag for vertices starting with handle " 00347 << rsi.get_start_handle() ); 00348 } 00349 else 00350 { 00351 // Map the data to damsel 00352 err = DMSLmodel_map_tag( xcoords, vertex_cont, (damsel_handle_ptr)&dU.xcoordsTag.mTagh ); 00353 CHK_DMSL_ERR( err, "Failed to assign vertex x coordinates tag for vertices starting with handle " 00354 << rsi.get_start_handle() ); 00355 err = DMSLmodel_map_tag( ycoords, vertex_cont, (damsel_handle_ptr)&dU.ycoordsTag.mTagh ); 00356 CHK_DMSL_ERR( err, "Failed to assign vertex y coordinates tag for vertices starting with handle " 00357 << rsi.get_start_handle() ); 00358 err = DMSLmodel_map_tag( zcoords, vertex_cont, (damsel_handle_ptr)&dU.zcoordsTag.mTagh ); 00359 CHK_DMSL_ERR( err, "Failed to assign vertex z coordinates tag for vertices starting with handle " 00360 << rsi.get_start_handle() ); 00361 } 00362 00363 // Write/map dense tags 00364 rval = map_dense_tags( rsi, vertex_cont );MB_CHK_ERR( rval ); 00365 00366 err = DMSLcontainer_release( vertex_cont ); 00367 CHK_DMSL_ERR( err, "Problem releasing vertex handle container" ); 00368 00369 return MB_SUCCESS; 00370 } 00371 00372 ErrorCode WriteDamsel::write_entities( RangeSeqIntersectIter& rsi ) 00373 { 00374 // Write the entities; these entities will be in the same sequence and will be contiguous, 00375 // guaranteed 00376 EntityHandle start_ent = rsi.get_start_handle(), end_ent = rsi.get_end_handle(); 00377 00378 // Create a damsel container for these entity handles 00379 damsel_container ent_cont; 00380 ent_cont = DMSLcontainer_create_sequence( dU.dmslModel, start_ent, (int)( end_ent - start_ent + 1 ), 1 ); 00381 std::cerr << "MOAB: created model container: ent_cont = " << ent_cont << std::endl; 00382 if( DAMSEL_CONTAINER_INVALID == ent_cont ) MB_SET_ERR( MB_FAILURE, "Bad sequence returned by Damsel" ); 00383 00384 damsel_err_t err = DMSLmodel_map_handles_inventing_file_handles( ent_cont ); 00385 CHK_DMSL_ERR( err, "Failed to map handles" ); 00386 00387 // Get # verts per entity and entity type 00388 EntityType etype = mbImpl->type_from_handle( start_ent ); 00389 assert( MBMAXTYPE != etype ); 00390 int num_connect = rsi.get_sequence()->values_per_entity(); 00391 assert( 0 < num_connect ); 00392 00393 // Get the connectivity storage location and pass to damsel 00394 Range ent_range( start_ent, end_ent ); 00395 int count; 00396 EntityHandle* connect; 00397 int verts_per_ent; 00398 ErrorCode rval = mbImpl->connect_iterate( ent_range.begin(), ent_range.end(), connect, verts_per_ent, count );MB_CHK_SET_ERR( rval, 00399 "Failed to get connect iterator for entities starting with handle " << rsi.get_start_handle() ); 00400 if( count != (int)ent_range.size() ) 00401 MB_SET_ERR( MB_FAILURE, "Entity subrange not in the same sequence for entities starting with handle " 00402 << rsi.get_start_handle() ); 00403 00404 // Define the entities to damsel 00405 err = DMSLentity_define_fast( ent_cont, DamselUtil::mtod_entity_type[etype], num_connect, (damsel_handle*)connect ); 00406 CHK_DMSL_ERR( err, "DMSLentity_define failed for entities starting with handle " << rsi.get_start_handle() ); 00407 00408 // Write dense tags 00409 rval = map_dense_tags( rsi, ent_cont );MB_CHK_ERR( rval ); 00410 00411 err = DMSLcontainer_release( ent_cont ); 00412 CHK_DMSL_ERR( err, "Problem releasing entity handle container" ); 00413 00414 return MB_SUCCESS; 00415 } 00416 00417 ErrorCode WriteDamsel::map_dense_tags( RangeSeqIntersectIter& rsi, damsel_container& ent_cont ) 00418 { 00419 // All dense_tags have been initialized before this, so here we just go through 00420 // them and map data if there is any 00421 const unsigned char* val_ptr; 00422 ErrorCode rval = MB_SUCCESS; 00423 std::vector< DamselUtil::tinfo >::iterator tagit; 00424 damsel_err_t err; 00425 for( tagit = dU.tagMap.begin(); tagit != dU.tagMap.end(); ++tagit ) 00426 { 00427 if( ( *tagit ).tagType != MB_TAG_DENSE ) continue; 00428 00429 // Get a ptr to memory for this tag/sequence 00430 DenseTag* dtag = dynamic_cast< DenseTag* >( ( *tagit ).mTagh ); 00431 assert( dtag ); 00432 rval = dtag->get_array( rsi.get_sequence(), val_ptr );MB_CHK_SET_ERR( rval, "Failed to get tag coordinates pointer for vertices starting with handle " 00433 << rsi.get_start_handle() ); 00434 00435 // If ptr is NULL, no data for this tag in this sequence 00436 if( !val_ptr ) continue; 00437 00438 // Else, register with damsel 00439 err = DMSLmodel_map_tag( (void*)val_ptr, ent_cont, (damsel_handle_ptr)&dtag ); 00440 CHK_DMSL_ERR( err, 00441 "Failed to write coordinates tag for vertices starting with handle " << rsi.get_start_handle() ); 00442 } 00443 00444 return rval; 00445 } 00446 00447 ErrorCode WriteDamsel::map_sparse_tags() 00448 { 00449 // All sparse_tags have been initialized before this, so here we just go through 00450 // them and map data if there is any 00451 ErrorCode rval = MB_SUCCESS; 00452 damsel_err_t err; 00453 std::vector< DamselUtil::tinfo >::iterator tagit; 00454 std::vector< unsigned char > tag_values; 00455 std::vector< EntityHandle > tagged_ents; 00456 damsel_container ent_cont; 00457 for( tagit = dU.tagMap.begin(); tagit != dU.tagMap.end(); ++tagit ) 00458 { 00459 if( ( *tagit ).tagType != MB_TAG_SPARSE ) continue; 00460 // Get a ptr to memory for this tag/sequence 00461 SparseTag* stag = dynamic_cast< SparseTag* >( ( *tagit ).mTagh ); 00462 assert( stag ); 00463 Range output_ents; 00464 rval = stag->get_tagged_entities( sequenceManager, output_ents );MB_CHK_SET_ERR( rval, "Trouble getting tagged entities for tag " << stag->get_name() ); 00465 00466 // If no entities have this tag set, don't map it 00467 if( output_ents.empty() ) continue; 00468 00469 // Else, register with damsel 00470 // Allocate space for and get values 00471 tag_values.resize( stag->get_size() * output_ents.size() ); 00472 rval = mbImpl->tag_get_data( stag, output_ents, &tag_values[0] );MB_CHK_SET_ERR( rval, "Trouble getting tag values for tag " << stag->get_name() ); 00473 00474 // Build a vector of entity handles from the range, and a container from that 00475 tagged_ents.resize( output_ents.size() ); 00476 std::copy( output_ents.begin(), output_ents.end(), tagged_ents.begin() ); 00477 ent_cont = DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle_ptr)&tagged_ents[0], tagged_ents.size() ); 00478 std::cerr << "MOAB: created model container: sparse_tag_ent_cont = " << ent_cont << std::endl; 00479 if( DAMSEL_CONTAINER_INVALID == ent_cont ) 00480 MB_SET_ERR( MB_FAILURE, "Trouble creating entity handle container for tag " << stag->get_name() ); 00481 00482 // Now map it 00483 err = DMSLmodel_map_tag( (void*)&tag_values[0], ent_cont, (damsel_handle_ptr)&stag ); 00484 CHK_DMSL_ERR( err, "Failed to write tag " << stag->get_name() ); 00485 00486 err = DMSLcontainer_release( ent_cont ); 00487 CHK_DMSL_ERR( err, "Problem releasing entity handle container" ); 00488 } 00489 00490 return rval; 00491 } 00492 00493 ErrorCode WriteDamsel::write_sets( RangeSeqIntersectIter& rsi ) 00494 { 00495 // Write the sets 00496 ErrorCode rval = MB_SUCCESS; 00497 std::vector< EntityHandle > ents; 00498 damsel_container mcont; 00499 damsel_err_t err; 00500 unsigned int i, num_sets = rsi.get_end_handle() - rsi.get_start_handle() + 1; 00501 std::vector< unsigned int > set_flags( num_sets, 0 ); 00502 EntityHandle seth; 00503 for( seth = rsi.get_start_handle(), i = 0; seth <= rsi.get_end_handle(); seth++, i++ ) 00504 { 00505 // Get all the entities in the set 00506 ents.clear(); 00507 rval = mbImpl->get_entities_by_handle( seth, ents );MB_CHK_SET_ERR( rval, "get_entities_by_handle failed for set " << seth ); 00508 if( !ents.empty() ) 00509 { 00510 mcont = DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle*)&ents[0], ents.size() ); 00511 } 00512 else 00513 { 00514 mcont = DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle*)NULL, 0 ); 00515 } 00516 std::cerr << "MOAB: created model container: sets_cont = " << mcont << std::endl; 00517 00518 // Get the set type (range or set) 00519 unsigned int opts; 00520 rval = mbImpl->get_meshset_options( seth, opts );MB_CHK_SET_ERR( rval, "Failed to get options for meshset " << seth ); 00521 damsel_collection_type coll_type = 00522 ( opts & MESHSET_SET ? DAMSEL_HANDLE_COLLECTION_TYPE_SET : DAMSEL_HANDLE_COLLECTION_TYPE_VECTOR ); 00523 00524 // Parents/children... 00525 00526 // Set flags 00527 if( opts & MESHSET_TRACK_OWNER ) 00528 set_flags[i] |= MESHSET_TRACK_OWNER; 00529 else 00530 set_flags[i] &= !MESHSET_TRACK_OWNER; 00531 00532 // Create the collection 00533 DMSLcoll_create( dU.dmslModel, (damsel_handle_ptr)&seth, mcont, coll_type ); 00534 00535 // Release the container 00536 err = DMSLcontainer_release( mcont ); 00537 CHK_DMSL_ERR( err, "Problem releasing set entity handle container" ); 00538 } 00539 00540 // Set the COLL_FLAGS tag, using assign (direct) 00541 // Make a container of set handles... 00542 mcont = DMSLcontainer_create_sequence( dU.dmslModel, rsi.get_start_handle(), num_sets, 1 ); 00543 std::cerr << "MOAB: created model container: sets_cont = " << mcont << std::endl; 00544 00545 // Assign the tags on them 00546 err = DMSLmodel_map_tag( &set_flags[0], mcont, ( damsel_handle_ptr ) & ( dU.collFlagsTag.mTagh ) ); 00547 CHK_DMSL_ERR( err, "Failed to assign COLL_FLAGS tag for sets" ); 00548 00549 // Map set handles 00550 err = DMSLmodel_map_handles_inventing_file_handles( mcont ); 00551 CHK_DMSL_ERR( err, "Failed to map set handles" ); 00552 00553 // Map other dense tags 00554 rval = map_dense_tags( rsi, mcont );MB_CHK_SET_ERR( rval, "Failed to map dense tags for sets" ); 00555 00556 return rval; 00557 } 00558 00559 } // namespace moab
