MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \file MeshTag.cpp 00002 * \author Jason Kraftcheck 00003 * \date 2010-12-14 00004 */ 00005 00006 #include "moab/Interface.hpp" 00007 #include "MeshTag.hpp" 00008 #include "SysUtil.hpp" 00009 #include "moab/Error.hpp" 00010 #include "moab/CN.hpp" 00011 #include "Internals.hpp" 00012 00013 namespace moab 00014 { 00015 00016 inline static ErrorCode not_root_set( const std::string& /*name*/, EntityHandle /*h*/ ) 00017 { 00018 // MB_TAG_NOT_FOUND could be a non-error condition, do not call MB_SET_ERR on it 00019 // Print warning messages for debugging only 00020 #if 0 00021 MB_SET_ERR(MB_VARIABLE_DATA_LENGTH, "Cannot get/set mesh/global tag " << name << " on non-root-set " << CN::EntityTypeName(TYPE_FROM_HANDLE(h)) << " " << (unsigned long)ID_FROM_HANDLE(h)); 00022 #endif 00023 00024 return MB_TAG_NOT_FOUND; 00025 } 00026 00027 inline static bool all_root_set( std::string name, const EntityHandle* array, size_t len ) 00028 { 00029 for( size_t i = 0; i < len; ++i ) 00030 { 00031 if( array[i] ) 00032 { 00033 not_root_set( name, array[i] ); 00034 return false; 00035 } 00036 } 00037 00038 return true; 00039 } 00040 00041 inline static ErrorCode not_found( const std::string& /*name*/ ) 00042 { 00043 // MB_TAG_NOT_FOUND could be a non-error condition, do not call MB_SET_ERR on it 00044 #if 0 00045 fprintf(stderr, "[Warning]: No mesh tag %s value for global/mesh tag\n", name.c_str()); 00046 #endif 00047 00048 return MB_TAG_NOT_FOUND; 00049 } 00050 00051 MeshTag::MeshTag( const char* name, int size, DataType type, const void* default_value, int default_value_size ) 00052 : TagInfo( name, size, type, default_value, default_value_size ) 00053 { 00054 } 00055 00056 MeshTag::~MeshTag() {} 00057 00058 TagType MeshTag::get_storage_type() const 00059 { 00060 return MB_TAG_MESH; 00061 } 00062 00063 ErrorCode MeshTag::release_all_data( SequenceManager*, Error*, bool ) 00064 { 00065 return MB_SUCCESS; 00066 } 00067 00068 ErrorCode MeshTag::get_data( const SequenceManager*, 00069 Error* /* error */, 00070 const EntityHandle* entities, 00071 size_t num_entities, 00072 void* data ) const 00073 { 00074 if( !all_root_set( get_name(), entities, num_entities ) ) return MB_TAG_NOT_FOUND; 00075 00076 const void* ptr; 00077 int len; 00078 00079 if( !mValue.empty() ) 00080 { 00081 ptr = &mValue[0]; 00082 len = mValue.size(); 00083 } 00084 else if( get_default_value() ) 00085 { 00086 ptr = get_default_value(); 00087 len = get_default_value_size(); 00088 } 00089 else 00090 { 00091 return not_found( get_name() ); 00092 } 00093 00094 SysUtil::setmem( data, ptr, len, num_entities ); 00095 return MB_SUCCESS; 00096 } 00097 00098 ErrorCode MeshTag::get_data( const SequenceManager*, Error* /* error */, const Range& r, void* ) const 00099 { 00100 if( variable_length() ) 00101 { 00102 MB_SET_ERR( MB_VARIABLE_DATA_LENGTH, "No length specified for variable-length tag " << get_name() << " value" ); 00103 } 00104 else if( r.empty() ) 00105 return MB_SUCCESS; 00106 else 00107 return not_root_set( get_name(), r.front() ); 00108 } 00109 00110 ErrorCode MeshTag::get_data( const SequenceManager*, 00111 Error* /* error */, 00112 const EntityHandle* entities, 00113 size_t num_entities, 00114 const void** data_ptrs, 00115 int* data_lengths ) const 00116 { 00117 const void* ptr; 00118 int len; 00119 00120 if( !mValue.empty() ) 00121 { 00122 ptr = &mValue[0]; 00123 len = mValue.size(); 00124 } 00125 else if( get_default_value() ) 00126 { 00127 ptr = get_default_value(); 00128 len = get_default_value_size(); 00129 } 00130 else 00131 { 00132 return not_found( get_name() ); 00133 } 00134 00135 for( size_t i = 0; i < num_entities; ++i ) 00136 { 00137 if( entities[i] ) return not_root_set( get_name(), entities[i] ); // Not root set 00138 data_ptrs[i] = ptr; 00139 if( data_lengths ) data_lengths[i] = len; 00140 } 00141 00142 return MB_SUCCESS; 00143 } 00144 00145 ErrorCode MeshTag::get_data( const SequenceManager*, Error* /* error */, const Range& range, const void**, int* ) const 00146 { 00147 if( range.empty() ) 00148 return MB_SUCCESS; 00149 else 00150 return not_root_set( get_name(), range.front() ); 00151 } 00152 00153 ErrorCode MeshTag::set_data( SequenceManager*, 00154 Error* /* error */, 00155 const EntityHandle* entities, 00156 size_t num_entities, 00157 const void* data ) 00158 { 00159 if( variable_length() ) 00160 { 00161 MB_SET_ERR( MB_VARIABLE_DATA_LENGTH, "No length specified for variable-length tag " << get_name() << " value" ); 00162 } 00163 if( !all_root_set( get_name(), entities, num_entities ) ) return MB_TAG_NOT_FOUND; 00164 00165 if( num_entities > 0 ) 00166 { 00167 mValue.resize( get_size() ); 00168 const unsigned char* bytes = reinterpret_cast< const unsigned char* >( data ); 00169 memcpy( &mValue[0], bytes + get_size() * ( num_entities - 1 ), get_size() ); 00170 } 00171 00172 return MB_SUCCESS; 00173 } 00174 00175 ErrorCode MeshTag::set_data( SequenceManager*, Error* /* error */, const Range& range, const void* ) 00176 { 00177 if( variable_length() ) 00178 { 00179 MB_SET_ERR( MB_VARIABLE_DATA_LENGTH, "No length specified for variable-length tag " << get_name() << " value" ); 00180 } 00181 else if( range.empty() ) 00182 return MB_SUCCESS; 00183 else 00184 return not_root_set( get_name(), range.front() ); 00185 } 00186 00187 ErrorCode MeshTag::set_data( SequenceManager*, 00188 Error* /* error */, 00189 const EntityHandle* entities, 00190 size_t num_entities, 00191 void const* const* data_ptrs, 00192 const int* data_lengths ) 00193 { 00194 if( !all_root_set( get_name(), entities, num_entities ) ) return MB_TAG_NOT_FOUND; 00195 00196 ErrorCode valid = validate_lengths( NULL, data_lengths, num_entities );MB_CHK_ERR( valid ); 00197 00198 if( num_entities > 0 ) 00199 { 00200 mValue.resize( data_lengths[num_entities - 1] ); 00201 memcpy( &mValue[0], data_ptrs[num_entities - 1], mValue.size() ); 00202 } 00203 00204 return MB_SUCCESS; 00205 } 00206 00207 ErrorCode MeshTag::set_data( SequenceManager*, Error* /* error */, const Range& range, void const* const*, const int* ) 00208 { 00209 if( range.empty() ) 00210 return MB_SUCCESS; 00211 else 00212 return not_root_set( get_name(), range.front() ); 00213 } 00214 00215 ErrorCode MeshTag::clear_data( SequenceManager*, 00216 Error* /* error */, 00217 const EntityHandle* entities, 00218 size_t num_entities, 00219 const void* value_ptr, 00220 int value_len ) 00221 { 00222 if( !all_root_set( get_name(), entities, num_entities ) ) return MB_TAG_NOT_FOUND; 00223 00224 ErrorCode valid = validate_lengths( NULL, value_len ? &value_len : 0, 1 );MB_CHK_ERR( valid ); 00225 00226 if( num_entities > 0 ) 00227 { 00228 mValue.resize( value_len ); 00229 memcpy( &mValue[0], value_ptr, value_len ); 00230 } 00231 00232 return MB_SUCCESS; 00233 } 00234 00235 ErrorCode MeshTag::clear_data( SequenceManager*, Error* /* error */, const Range& range, const void*, int ) 00236 { 00237 if( range.empty() ) 00238 return MB_SUCCESS; 00239 else 00240 return not_root_set( get_name(), range.front() ); 00241 } 00242 00243 ErrorCode MeshTag::remove_data( SequenceManager*, 00244 Error* /* error */, 00245 const EntityHandle* entities, 00246 size_t num_entities ) 00247 { 00248 if( !all_root_set( get_name(), entities, num_entities ) ) return MB_TAG_NOT_FOUND; 00249 00250 if( num_entities ) mValue.clear(); 00251 00252 return MB_SUCCESS; 00253 } 00254 00255 ErrorCode MeshTag::remove_data( SequenceManager*, Error* /* error */, const Range& range ) 00256 { 00257 if( range.empty() ) 00258 return MB_SUCCESS; 00259 else 00260 return not_root_set( get_name(), range.front() ); 00261 } 00262 00263 ErrorCode MeshTag::tag_iterate( SequenceManager*, 00264 Error* /* error */, 00265 Range::iterator& beg, 00266 const Range::iterator& end, 00267 void*&, 00268 bool ) 00269 { 00270 if( beg == end ) 00271 return MB_SUCCESS; 00272 else 00273 return not_root_set( get_name(), *beg ); 00274 } 00275 00276 ErrorCode MeshTag::get_tagged_entities( const SequenceManager*, Range&, EntityType, const Range* ) const 00277 { 00278 return MB_SUCCESS; 00279 } 00280 00281 ErrorCode MeshTag::num_tagged_entities( const SequenceManager*, size_t&, EntityType, const Range* ) const 00282 { 00283 return MB_SUCCESS; 00284 } 00285 00286 ErrorCode MeshTag::find_entities_with_value( const SequenceManager*, 00287 Error*, 00288 Range&, 00289 const void*, 00290 int, 00291 EntityType, 00292 const Range* ) const 00293 { 00294 return MB_SUCCESS; 00295 } 00296 00297 bool MeshTag::is_tagged( const SequenceManager*, EntityHandle h ) const 00298 { 00299 return ( 0 == h ) && ( !mValue.empty() ); 00300 } 00301 00302 ErrorCode MeshTag::get_memory_use( const SequenceManager*, unsigned long& total, unsigned long& per_entity ) const 00303 { 00304 total = TagInfo::get_memory_use() + sizeof( *this ) + mValue.size(); 00305 per_entity = 0; 00306 return MB_SUCCESS; 00307 } 00308 00309 } // namespace moab
