MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef __smoab_detail_LoadGeometry_h 00002 #define __smoab_detail_LoadGeometry_h 00003 00004 #include "SimpleMoab.h" 00005 #include "MixedCellConnectivity.h" 00006 00007 #include <vtkCellArray.h> 00008 #include <vtkIdTypeArray.h> 00009 #include <vtkNew.h> 00010 #include <vtkPointData.h> 00011 #include <vtkPoints.h> 00012 #include <vtkPointSet.h> 00013 #include <vtkPolyData.h> 00014 #include <vtkUnsignedCharArray.h> 00015 #include <vtkUnstructuredGrid.h> 00016 namespace smoab 00017 { 00018 namespace detail 00019 { 00020 00021 namespace 00022 { 00023 00024 //empty definition, only allow specializations to compile 00025 template < typename VTKGridType > 00026 struct setCells; 00027 00028 template <> 00029 struct setCells< vtkUnstructuredGrid > 00030 { 00031 typedef vtkUnstructuredGrid VTKGridType; 00032 void operator()( VTKGridType* grid, 00033 int, 00034 vtkUnsignedCharArray* types, 00035 vtkIdTypeArray* locations, 00036 vtkCellArray* cells ) const 00037 { 00038 grid->SetCells( types, locations, cells, NULL, NULL ); 00039 } 00040 }; 00041 00042 template <> 00043 struct setCells< vtkPolyData > 00044 { 00045 typedef vtkPolyData VTKGridType; 00046 void operator()( VTKGridType* grid, 00047 int dim, 00048 vtkUnsignedCharArray*, 00049 vtkIdTypeArray*, 00050 vtkCellArray* cells ) const 00051 { 00052 if( dim == 0 ) 00053 { 00054 grid->SetVerts( cells ); 00055 } 00056 else if( dim == 1 ) 00057 { 00058 grid->SetLines( cells ); 00059 } 00060 else if( dim == 2 ) 00061 { 00062 grid->SetPolys( cells ); 00063 } 00064 } 00065 }; 00066 00067 } // namespace 00068 //basic class that given a range of moab cells will convert them to am unstructured grid. 00069 //holds only references to input cells, so they can't go out of scope 00070 00071 //The Topology tag is used to describe the dimensoniality of the cells we are reading 00072 // 0 == verts, 1 == lines, 2 == tri/quads, 3 = volume elements 00073 class LoadGeometry 00074 { 00075 moab::Interface* Interface; 00076 int TopologyDim; 00077 smoab::detail::MixedCellConnectivity MixConn; 00078 smoab::Range Points; 00079 00080 public: 00081 //---------------------------------------------------------------------------- 00082 //warning cells input to constructor is held by reference 00083 LoadGeometry( const smoab::Range& cells, int topologyDim, const smoab::Interface& interface ) 00084 : Interface( interface.Moab ), TopologyDim( topologyDim ), MixConn( cells, interface.Moab ), Points() 00085 { 00086 } 00087 00088 const smoab::Range& moabPoints() const 00089 { 00090 return this->Points; 00091 } 00092 00093 //---------------------------------------------------------------------------- 00094 //todo: have support for using only a subsection of the input cells 00095 template < typename vtkDataSetType > 00096 void fill( vtkDataSetType* dataSet ) 00097 { 00098 //now that mixConn has all the cells properly stored, lets fixup 00099 //the ids so that they start at zero and keep the same logical ordering 00100 //as before. 00101 vtkIdType numCells, connLen; 00102 this->MixConn.compactIds( numCells, connLen ); 00103 this->addGridsTopology( dataSet, numCells, connLen ); 00104 this->addCoordinates( dataSet ); 00105 } 00106 00107 private: 00108 //---------------------------------------------------------------------------- 00109 void addCoordinates( vtkPointSet* grid ) 00110 { 00111 //this is sorta of hackish as moabPoints is only valid 00112 //after compactIds has been called 00113 this->MixConn.moabPoints( this->Points ); 00114 00115 //since the smoab::range are always unique and sorted 00116 //we can use the more efficient coords_iterate 00117 //call in moab, which returns moab internal allocated memory 00118 vtkNew< vtkPoints > newPoints; 00119 newPoints->SetDataTypeToDouble(); 00120 newPoints->SetNumberOfPoints( this->Points.size() ); 00121 00122 //need a pointer to the allocated vtkPoints memory so that we 00123 //don't need to use an extra copy and we can bypass all vtk's check 00124 //on out of bounds 00125 double* rawPoints = static_cast< double* >( newPoints->GetVoidPointer( 0 ) ); 00126 this->Interface->get_coords( this->Points, rawPoints ); 00127 00128 grid->SetPoints( newPoints.GetPointer() ); 00129 } 00130 00131 //---------------------------------------------------------------------------- 00132 template < typename vtkDataSetType > 00133 void addGridsTopology( vtkDataSetType* grid, vtkIdType numCells, vtkIdType numConnectivity ) const 00134 { 00135 //correct the connectivity size to account for the vtk padding 00136 const vtkIdType vtkConnectivity = numCells + numConnectivity; 00137 00138 vtkNew< vtkIdTypeArray > cellArray; 00139 vtkNew< vtkIdTypeArray > cellLocations; 00140 vtkNew< vtkUnsignedCharArray > cellTypes; 00141 00142 cellArray->SetNumberOfValues( vtkConnectivity ); 00143 cellLocations->SetNumberOfValues( numCells ); 00144 cellTypes->SetNumberOfValues( numCells ); 00145 00146 vtkIdType* rawArray = static_cast< vtkIdType* >( cellArray->GetVoidPointer( 0 ) ); 00147 vtkIdType* rawLocations = static_cast< vtkIdType* >( cellLocations->GetVoidPointer( 0 ) ); 00148 unsigned char* rawTypes = static_cast< unsigned char* >( cellTypes->GetVoidPointer( 0 ) ); 00149 00150 this->MixConn.copyToVtkCellInfo( rawArray, rawLocations, rawTypes ); 00151 00152 vtkNew< vtkCellArray > cells; 00153 cells->SetCells( numCells, cellArray.GetPointer() ); 00154 00155 setCells< vtkDataSetType >()( grid, this->TopologyDim, cellTypes.GetPointer(), cellLocations.GetPointer(), 00156 cells.GetPointer() ); 00157 } 00158 }; 00159 00160 } // namespace detail 00161 } // namespace smoab 00162 00163 #endif // __smoab_detail_LoadGeometry_h
