MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifdef WIN32 00017 #ifdef _DEBUG 00018 // turn off warnings that say they debugging identifier has been truncated 00019 // this warning comes up when using some STL containers 00020 #pragma warning( disable : 4786 ) 00021 #endif 00022 #endif 00023 00024 #include "ReadUtil.hpp" 00025 #include "moab/Core.hpp" 00026 #include "AEntityFactory.hpp" 00027 #include "moab/Error.hpp" 00028 #include "SequenceManager.hpp" 00029 #include "VertexSequence.hpp" 00030 #include "ElementSequence.hpp" 00031 00032 namespace moab 00033 { 00034 00035 #define RR \ 00036 if( MB_SUCCESS != result ) return result 00037 00038 ReadUtil::ReadUtil( Core* mdb, Error* /*error_handler*/ ) : ReadUtilIface(), mMB( mdb ) {} 00039 00040 ErrorCode ReadUtil::get_node_coords( const int /*num_arrays*/, 00041 const int num_nodes, 00042 const int preferred_start_id, 00043 EntityHandle& actual_start_handle, 00044 std::vector< double* >& arrays, 00045 int sequence_size ) 00046 { 00047 ErrorCode error; 00048 EntitySequence* seq = 0; 00049 00050 if( num_nodes < 1 ) 00051 { 00052 actual_start_handle = 0; 00053 arrays.clear(); 00054 return MB_INDEX_OUT_OF_RANGE; 00055 } 00056 00057 // Create an entity sequence for these nodes 00058 error = mMB->sequence_manager()->create_entity_sequence( MBVERTEX, num_nodes, 0, preferred_start_id, 00059 actual_start_handle, seq, sequence_size ); 00060 00061 if( error != MB_SUCCESS ) return error; 00062 00063 if( seq->start_handle() > actual_start_handle || seq->end_handle() < actual_start_handle || 00064 seq->end_handle() - actual_start_handle + 1 < (unsigned)num_nodes ) 00065 return MB_FAILURE; 00066 00067 arrays.resize( 3 ); 00068 00069 error = static_cast< VertexSequence* >( seq )->get_coordinate_arrays( arrays[0], arrays[1], arrays[2] ); 00070 for( unsigned i = 0; i < arrays.size(); ++i ) 00071 if( arrays[i] ) arrays[i] += ( actual_start_handle - seq->start_handle() ); 00072 00073 return error; 00074 } 00075 00076 ErrorCode ReadUtil::get_element_connect( const int num_elements, 00077 const int verts_per_element, 00078 const EntityType mdb_type, 00079 const int preferred_start_id, 00080 EntityHandle& actual_start_handle, 00081 EntityHandle*& array, 00082 int sequence_size ) 00083 { 00084 ErrorCode error; 00085 EntitySequence* seq; 00086 00087 if( num_elements < 1 ) 00088 { 00089 actual_start_handle = 0; 00090 array = 0; 00091 return MB_INDEX_OUT_OF_RANGE; 00092 } 00093 00094 // if (mdb_type <= MBVERTEX || mdb_type >= MBPOLYHEDRON || mdb_type == MBPOLYGON) 00095 // return MB_TYPE_OUT_OF_RANGE; 00096 00097 // Make an entity sequence to hold these elements 00098 error = 00099 mMB->sequence_manager()->create_entity_sequence( mdb_type, num_elements, verts_per_element, preferred_start_id, 00100 actual_start_handle, seq, sequence_size ); 00101 if( MB_SUCCESS != error ) return error; 00102 00103 if( seq->start_handle() > actual_start_handle || seq->end_handle() < actual_start_handle || 00104 seq->end_handle() - actual_start_handle + 1 < (unsigned)num_elements ) 00105 return MB_FAILURE; 00106 00107 // Get an array for the connectivity 00108 array = static_cast< ElementSequence* >( seq )->get_connectivity_array(); 00109 if( !array ) return MB_FAILURE; 00110 array += 00111 ( actual_start_handle - seq->start_handle() ) * static_cast< ElementSequence* >( seq )->nodes_per_element(); 00112 00113 return error; 00114 } 00115 00116 ErrorCode ReadUtil::create_entity_sets( EntityID num_sets, 00117 const unsigned* flags, 00118 EntityID start_id, 00119 EntityHandle& start_handle ) 00120 { 00121 if( num_sets < 1 ) 00122 { 00123 start_handle = 0; 00124 return MB_INDEX_OUT_OF_RANGE; 00125 } 00126 00127 ErrorCode error; 00128 EntitySequence* seq; 00129 error = mMB->sequence_manager()->create_meshset_sequence( num_sets, start_id, flags, start_handle, seq ); 00130 if( MB_SUCCESS != error ) return error; 00131 00132 if( seq->start_handle() > start_handle || seq->end_handle() < start_handle || 00133 seq->end_handle() - start_handle + 1 < (EntityHandle)num_sets ) 00134 return MB_FAILURE; 00135 00136 return MB_SUCCESS; 00137 } 00138 00139 ErrorCode ReadUtil::update_adjacencies( const EntityHandle start_handle, 00140 const int number_elements, 00141 const int number_vertices_per_element, 00142 const EntityHandle* conn_array ) 00143 { 00144 EntityHandle tmp_hndl = start_handle; 00145 AEntityFactory* adj_fact = mMB->a_entity_factory(); 00146 00147 // Iterate over the elements and update adjacency information 00148 if( adj_fact != NULL && adj_fact->vert_elem_adjacencies() ) 00149 { 00150 int j = 0; 00151 for( int i = 0; i < number_elements; i++ ) 00152 { 00153 adj_fact->notify_create_entity( tmp_hndl, ( conn_array + j ), number_vertices_per_element ); 00154 tmp_hndl++; 00155 j += number_vertices_per_element; 00156 } 00157 } 00158 00159 return MB_SUCCESS; 00160 } 00161 00162 ErrorCode ReadUtil::gather_related_ents( Range& partition, Range& related_ents, EntityHandle* file_set ) 00163 { 00164 // Loop over any sets, getting contained ents 00165 std::pair< Range::const_iterator, Range::const_iterator > pair_it = partition.equal_range( MBENTITYSET ); 00166 00167 ErrorCode result = MB_SUCCESS; 00168 for( Range::const_iterator rit = pair_it.first; rit != pair_it.second; ++rit ) 00169 { 00170 ErrorCode tmp_result = mMB->get_entities_by_handle( *rit, related_ents, Interface::UNION ); 00171 if( MB_SUCCESS != tmp_result ) result = tmp_result; 00172 } 00173 RR; 00174 00175 // Gather adjacent ents of other dimensions 00176 Range tmp_ents; 00177 for( int dim = 3; dim >= 0; dim-- ) 00178 { 00179 tmp_ents.clear(); 00180 ErrorCode tmp_result = mMB->get_adjacencies( related_ents, dim, false, tmp_ents, Interface::UNION ); 00181 if( MB_SUCCESS != tmp_result ) 00182 result = tmp_result; 00183 else 00184 related_ents.merge( tmp_ents ); 00185 } 00186 RR; 00187 00188 // Related ents includes the partition itself 00189 related_ents.merge( partition ); 00190 00191 // Get contains-related sets 00192 Range tmp_ents3, last_related; 00193 if( file_set ) 00194 result = mMB->get_entities_by_type( *file_set, MBENTITYSET, tmp_ents3 ); 00195 else 00196 result = mMB->get_entities_by_type( 0, MBENTITYSET, tmp_ents3 );RR; 00197 00198 while( related_ents.size() != last_related.size() ) 00199 { 00200 last_related = related_ents; 00201 for( Range::iterator rit = tmp_ents3.begin(); rit != tmp_ents3.end(); ++rit ) 00202 { 00203 if( related_ents.find( *rit ) != related_ents.end() ) continue; 00204 00205 tmp_ents.clear(); 00206 result = mMB->get_entities_by_handle( *rit, tmp_ents, true );RR; 00207 Range tmp_ents2 = intersect( tmp_ents, related_ents ); 00208 00209 // If the intersection is not empty, set is related 00210 if( !tmp_ents2.empty() ) related_ents.insert( *rit ); 00211 } 00212 } 00213 00214 // Get child-related sets 00215 last_related.clear(); 00216 while( related_ents.size() != last_related.size() ) 00217 { 00218 last_related = related_ents; 00219 std::pair< Range::const_iterator, Range::const_iterator > it_pair = last_related.equal_range( MBENTITYSET ); 00220 00221 for( Range::const_iterator rit = it_pair.first; rit != it_pair.second; ++rit ) 00222 { 00223 // Get all children and add to related ents 00224 tmp_ents.clear(); 00225 result = mMB->get_child_meshsets( *rit, tmp_ents, 0 );RR; 00226 related_ents.merge( tmp_ents ); 00227 } 00228 } 00229 00230 // Get parent-related sets 00231 last_related.clear(); 00232 while( related_ents.size() != last_related.size() ) 00233 { 00234 last_related = related_ents; 00235 std::pair< Range::const_iterator, Range::const_iterator > it_pair = last_related.equal_range( MBENTITYSET ); 00236 00237 for( Range::const_iterator rit = it_pair.first; rit != it_pair.second; ++rit ) 00238 { 00239 // Get all parents and add to related ents 00240 tmp_ents.clear(); 00241 result = mMB->get_parent_meshsets( *rit, tmp_ents, 0 );RR; 00242 related_ents.merge( tmp_ents ); 00243 } 00244 } 00245 00246 return MB_SUCCESS; 00247 } 00248 00249 ErrorCode ReadUtil::get_ordered_vertices( EntityHandle* bound_ents, 00250 int* sense, 00251 int bound_size, 00252 int dim, 00253 EntityHandle* bound_verts, 00254 EntityType& etype ) 00255 { 00256 // Get dimension of bounding entities 00257 int bound_dim = CN::Dimension( TYPE_FROM_HANDLE( bound_ents[0] ) ); 00258 int indices[MAX_SUB_ENTITY_VERTICES]; 00259 const EntityHandle* connect = NULL; 00260 std::vector< EntityHandle > tmp_connect; 00261 00262 // Find the right entity type based on # bounding ents 00263 int numv = 0, num_connect = 0; 00264 ErrorCode result; 00265 for( EntityType t = MBEDGE; t < MBENTITYSET; t++ ) 00266 { 00267 int nindex = CN::NumSubEntities( t, bound_dim ); 00268 if( CN::Dimension( t ) != dim || nindex != bound_size ) continue; 00269 00270 // Fill in vertices from bounding entity vertices 00271 int nverts = CN::VerticesPerEntity( t ); 00272 std::fill( bound_verts, bound_verts + nverts, 0 ); 00273 for( int index = 0; index < nindex; index++ ) 00274 { 00275 result = mMB->get_connectivity( bound_ents[index], connect, num_connect, false, &tmp_connect ); 00276 if( MB_SUCCESS != result ) return result; 00277 00278 CN::SubEntityVertexIndices( t, bound_dim, index, indices ); 00279 00280 for( int c = 0; c < num_connect; c++ ) 00281 { 00282 if( !bound_verts[indices[c]] ) 00283 { 00284 bound_verts[indices[c]] = ( sense[index] > 0 ) ? connect[c] : connect[num_connect - c - 1]; 00285 numv++; 00286 } 00287 } 00288 if( numv == nverts ) 00289 { 00290 etype = t; 00291 return MB_SUCCESS; 00292 } 00293 } 00294 } 00295 00296 // If we get here, we didn't get full connectivity 00297 etype = MBMAXTYPE; 00298 return MB_FAILURE; 00299 } 00300 00301 static ErrorCode check_int_tag( Interface* mb, Tag tag ) 00302 { 00303 int size; 00304 DataType type; 00305 ErrorCode rval = mb->tag_get_bytes( tag, size ); 00306 if( MB_SUCCESS != rval ) return rval; 00307 if( size != sizeof( int ) ) return MB_TYPE_OUT_OF_RANGE; 00308 rval = mb->tag_get_data_type( tag, type ); 00309 if( type != MB_TYPE_OPAQUE && type != MB_TYPE_INTEGER ) return MB_TYPE_OUT_OF_RANGE; 00310 00311 return MB_SUCCESS; 00312 } 00313 00314 ErrorCode ReadUtil::assign_ids( Tag id_tag, const Range& ents, int start ) 00315 { 00316 ErrorCode rval = check_int_tag( mMB, id_tag ); 00317 if( MB_SUCCESS != rval ) return rval; 00318 00319 Range tmp_range; 00320 std::vector< int > data; 00321 for( Range::const_pair_iterator i = ents.pair_begin(); i != ents.pair_end(); ++i ) 00322 { 00323 data.resize( i->second + 1 - i->first ); 00324 for( std::vector< int >::iterator j = data.begin(); j != data.end(); ++j ) 00325 *j = start++; 00326 tmp_range.clear(); 00327 tmp_range.insert( i->first, i->second ); 00328 rval = mMB->tag_set_data( id_tag, tmp_range, &data[0] ); 00329 if( MB_SUCCESS != rval ) return rval; 00330 } 00331 00332 return MB_SUCCESS; 00333 } 00334 00335 ErrorCode ReadUtil::assign_ids( Tag id_tag, const EntityHandle* ents, size_t num_ents, int start ) 00336 { 00337 ErrorCode rval = check_int_tag( mMB, id_tag ); 00338 if( MB_SUCCESS != rval ) return rval; 00339 00340 std::vector< int > data; 00341 const EntityHandle* const end = ents + num_ents; 00342 const EntityHandle* i = ents; 00343 while( i != end ) 00344 { 00345 const EntityHandle* next = std::find( i, end, 0u ); 00346 size_t size = next - i; 00347 if( !size ) 00348 { 00349 ++i; 00350 continue; 00351 } 00352 00353 int id = start + ( i - ents ); 00354 data.resize( size ); 00355 for( std::vector< int >::iterator j = data.begin(); j != data.end(); ++j ) 00356 *j = id++; 00357 00358 rval = mMB->tag_set_data( id_tag, i, size, &data[0] ); 00359 if( MB_SUCCESS != rval ) return rval; 00360 } 00361 00362 return MB_SUCCESS; 00363 } 00364 00365 ErrorCode ReadUtil::create_gather_set( EntityHandle& gather_set ) 00366 { 00367 ErrorCode rval = mMB->create_meshset( MESHSET_SET, gather_set ); 00368 if( MB_SUCCESS != rval ) return rval; 00369 00370 Tag gather_set_tag; 00371 rval = mMB->tag_get_handle( "GATHER_SET", 1, MB_TYPE_INTEGER, gather_set_tag, MB_TAG_CREAT | MB_TAG_SPARSE ); 00372 if( MB_SUCCESS != rval ) return rval; 00373 00374 int gather_val = 1; 00375 rval = mMB->tag_set_data( gather_set_tag, &gather_set, 1, &gather_val ); 00376 if( MB_SUCCESS != rval ) return rval; 00377 00378 return MB_SUCCESS; 00379 } 00380 00381 ErrorCode ReadUtil::get_gather_set( EntityHandle& gather_set ) 00382 { 00383 Tag gather_set_tag; 00384 ErrorCode rval = mMB->tag_get_handle( "GATHER_SET", 1, MB_TYPE_INTEGER, gather_set_tag, MB_TAG_SPARSE ); 00385 if( MB_SUCCESS != rval ) return rval; 00386 00387 int gather_val = 1; 00388 void* vals[] = { &gather_val }; 00389 Range gather_sets; 00390 rval = mMB->get_entities_by_type_and_tag( 0, MBENTITYSET, &gather_set_tag, vals, 1, gather_sets ); 00391 if( MB_SUCCESS != rval ) return rval; 00392 00393 if( gather_sets.empty() ) return MB_ENTITY_NOT_FOUND; 00394 00395 gather_set = gather_sets[0]; 00396 00397 return MB_SUCCESS; 00398 } 00399 00400 } // namespace moab
