MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifdef WIN32 00002 #ifdef _DEBUG 00003 // turn off warnings that say they debugging identifier has been truncated 00004 // this warning comes up when using some STL containers 00005 #pragma warning( disable : 4786 ) 00006 #endif 00007 #endif 00008 00009 #include "MeshSet.hpp" 00010 #include "AEntityFactory.hpp" 00011 00012 namespace moab 00013 { 00014 00015 /***************************************************************************************** 00016 * Helper Function Declarations * 00017 *****************************************************************************************/ 00018 00019 /**\brief Insert into parent/child list */ 00020 static inline MeshSet::Count insert_in_vector( const MeshSet::Count count, 00021 MeshSet::CompactList& list, 00022 const EntityHandle h, 00023 int& result ); 00024 00025 /**\brief Remvoe from parent/child list */ 00026 static inline MeshSet::Count remove_from_vector( const MeshSet::Count count, 00027 MeshSet::CompactList& list, 00028 const EntityHandle h, 00029 int& result ); 00030 00031 /**\brief Resize MeshSet::CompactList. Returns pointer to storage */ 00032 static EntityHandle* resize_compact_list( MeshSet::Count& count, MeshSet::CompactList& clist, size_t new_list_size ); 00033 /**\brief Methods to insert/remove range-based data from contents list. 00034 * Templatized to operate on both Range and set-based MeshSets. 00035 */ 00036 template < typename pair_iter_t > 00037 class range_tool 00038 { 00039 public: 00040 /** Insert range-based data into range-based MeshSet */ 00041 inline static ErrorCode ranged_insert_entities( MeshSet::Count& count, 00042 MeshSet::CompactList& clist, 00043 pair_iter_t begin, 00044 pair_iter_t end, 00045 EntityHandle my_handle, 00046 AEntityFactory* adj ); 00047 00048 /** Remove range-based data from range-based MeshSet */ 00049 inline static ErrorCode ranged_remove_entities( MeshSet::Count& count, 00050 MeshSet::CompactList& clist, 00051 pair_iter_t begin, 00052 pair_iter_t end, 00053 EntityHandle my_handle, 00054 AEntityFactory* adj ); 00055 00056 /** Insert range-based data into list-based MeshSet */ 00057 inline static ErrorCode vector_insert_entities( MeshSet::Count& count, 00058 MeshSet::CompactList& clist, 00059 pair_iter_t begin, 00060 pair_iter_t end, 00061 EntityHandle my_handle, 00062 AEntityFactory* adj ); 00063 }; 00064 00065 /** Remove Range of handles fromr vector-based MeshSet */ 00066 static ErrorCode vector_remove_range( MeshSet::Count& count, 00067 MeshSet::CompactList& clist, 00068 const Range& range, 00069 EntityHandle my_handle, 00070 AEntityFactory* adj ); 00071 00072 /** Remove range-based MeshSet contents from vector-based MeshSet */ 00073 static ErrorCode vector_remove_ranges( MeshSet::Count& count, 00074 MeshSet::CompactList& clist, 00075 const EntityHandle* pair_list, 00076 size_t num_pairs, 00077 EntityHandle my_handle, 00078 AEntityFactory* adj ); 00079 00080 /** Remove unsorted array of handles from vector-based MeshSet */ 00081 static ErrorCode vector_remove_vector( MeshSet::Count& count, 00082 MeshSet::CompactList& clist, 00083 const EntityHandle* vect, 00084 size_t vect_size, 00085 EntityHandle my_handle, 00086 AEntityFactory* adj ); 00087 00088 /** Insert unsorted array of handles into vector-based MeshSet */ 00089 static ErrorCode vector_insert_vector( MeshSet::Count& count, 00090 MeshSet::CompactList& clist, 00091 const EntityHandle* vect, 00092 size_t vect_size, 00093 EntityHandle my_handle, 00094 AEntityFactory* adj ); 00095 00096 /** Convert unsorted array of handles into array of ranged [begin,end] pairs */ 00097 static void convert_to_ranges( const EntityHandle* vect_in, size_t vect_in_len, std::vector< EntityHandle >& vect_out ); 00098 00099 /***************************************************************************************** 00100 * Parent/Child Operations * 00101 *****************************************************************************************/ 00102 00103 static inline MeshSet::Count insert_in_vector( const MeshSet::Count count, 00104 MeshSet::CompactList& list, 00105 const EntityHandle h, 00106 int& result ) 00107 { 00108 switch( count ) 00109 { 00110 case MeshSet::ZERO: 00111 list.hnd[0] = h; 00112 result = true; 00113 return MeshSet::ONE; 00114 case MeshSet::ONE: 00115 if( list.hnd[0] == h ) 00116 { 00117 result = false; 00118 return MeshSet::ONE; 00119 } 00120 else 00121 { 00122 result = true; 00123 list.hnd[1] = h; 00124 return MeshSet::TWO; 00125 } 00126 case MeshSet::TWO: 00127 if( list.hnd[0] == h || list.hnd[1] == h ) 00128 { 00129 result = false; 00130 return MeshSet::TWO; 00131 } 00132 else 00133 { 00134 EntityHandle* ptr = (EntityHandle*)malloc( 3 * sizeof( EntityHandle ) ); 00135 ptr[0] = list.hnd[0]; 00136 ptr[1] = list.hnd[1]; 00137 ptr[2] = h; 00138 list.ptr[0] = ptr; 00139 list.ptr[1] = ptr + 3; 00140 result = true; 00141 return MeshSet::MANY; 00142 } 00143 case MeshSet::MANY: 00144 if( std::find( list.ptr[0], list.ptr[1], h ) != list.ptr[1] ) 00145 { 00146 result = false; 00147 } 00148 else 00149 { 00150 int size = list.ptr[1] - list.ptr[0]; 00151 list.ptr[0] = (EntityHandle*)realloc( list.ptr[0], ( size + 1 ) * sizeof( EntityHandle ) ); 00152 list.ptr[0][size] = h; 00153 list.ptr[1] = list.ptr[0] + size + 1; 00154 result = true; 00155 } 00156 return MeshSet::MANY; 00157 } 00158 00159 return MeshSet::ZERO; 00160 } 00161 00162 static inline MeshSet::Count remove_from_vector( const MeshSet::Count count, 00163 MeshSet::CompactList& list, 00164 const EntityHandle h, 00165 int& result ) 00166 { 00167 switch( count ) 00168 { 00169 case MeshSet::ZERO: 00170 result = false; 00171 return MeshSet::ZERO; 00172 case MeshSet::ONE: 00173 if( h == list.hnd[0] ) 00174 { 00175 result = true; 00176 return MeshSet::ZERO; 00177 } 00178 else 00179 { 00180 result = false; 00181 return MeshSet::ONE; 00182 } 00183 case MeshSet::TWO: 00184 if( h == list.hnd[0] ) 00185 { 00186 list.hnd[0] = list.hnd[1]; 00187 result = true; 00188 return MeshSet::ONE; 00189 } 00190 else if( h == list.hnd[1] ) 00191 { 00192 result = true; 00193 return MeshSet::ONE; 00194 } 00195 else 00196 { 00197 result = false; 00198 return MeshSet::TWO; 00199 } 00200 case MeshSet::MANY: { 00201 EntityHandle *i, *j, *p; 00202 i = std::find( list.ptr[0], list.ptr[1], h ); 00203 if( i == list.ptr[1] ) 00204 { 00205 result = false; 00206 return MeshSet::MANY; 00207 } 00208 00209 result = true; 00210 p = list.ptr[1] - 1; 00211 while( i != p ) 00212 { 00213 j = i + 1; 00214 *i = *j; 00215 i = j; 00216 } 00217 int size = p - list.ptr[0]; 00218 if( size == 2 ) 00219 { 00220 p = list.ptr[0]; 00221 list.hnd[0] = p[0]; 00222 list.hnd[1] = p[1]; 00223 free( p ); 00224 return MeshSet::TWO; 00225 } 00226 else 00227 { 00228 list.ptr[0] = (EntityHandle*)realloc( list.ptr[0], size * sizeof( EntityHandle ) ); 00229 list.ptr[1] = list.ptr[0] + size; 00230 return MeshSet::MANY; 00231 } 00232 } 00233 } 00234 00235 return MeshSet::ZERO; 00236 } 00237 00238 int MeshSet::add_parent( EntityHandle parent ) 00239 { 00240 int result = 0; 00241 mParentCount = insert_in_vector( (Count)mParentCount, parentMeshSets, parent, result ); 00242 return result; 00243 } 00244 int MeshSet::add_child( EntityHandle child ) 00245 { 00246 int result = 0; 00247 mChildCount = insert_in_vector( (Count)mChildCount, childMeshSets, child, result ); 00248 return result; 00249 } 00250 00251 int MeshSet::remove_parent( EntityHandle parent ) 00252 { 00253 int result = 0; 00254 mParentCount = remove_from_vector( (Count)mParentCount, parentMeshSets, parent, result ); 00255 return result; 00256 } 00257 int MeshSet::remove_child( EntityHandle child ) 00258 { 00259 int result = 0; 00260 mChildCount = remove_from_vector( (Count)mChildCount, childMeshSets, child, result ); 00261 return result; 00262 } 00263 00264 /***************************************************************************************** 00265 * Flag Conversion Operations * 00266 *****************************************************************************************/ 00267 00268 ErrorCode MeshSet::convert( unsigned flg, EntityHandle my_handle, AEntityFactory* adj ) 00269 { 00270 ErrorCode rval = MB_SUCCESS; 00271 if( ( mFlags & MESHSET_TRACK_OWNER ) && !( flg & MESHSET_TRACK_OWNER ) ) 00272 rval = remove_adjacencies( my_handle, adj ); 00273 else if( !( mFlags & MESHSET_TRACK_OWNER ) && ( flg & MESHSET_TRACK_OWNER ) ) 00274 rval = create_adjacencies( my_handle, adj ); 00275 if( MB_SUCCESS != rval ) return rval; 00276 00277 if( !( mFlags & MESHSET_ORDERED ) && ( flg & MESHSET_ORDERED ) ) 00278 { 00279 size_t datalen; 00280 EntityHandle* data = get_contents( datalen ); 00281 if( datalen ) 00282 { 00283 std::vector< EntityHandle > list( datalen ); 00284 memcpy( &list[0], data, datalen * sizeof( EntityHandle ) ); 00285 int num_ents = num_entities(); 00286 Count count = (Count)mContentCount; 00287 data = resize_compact_list( count, contentList, num_ents ); 00288 mContentCount = count; 00289 assert( list.size() % 2 == 0 ); 00290 std::vector< EntityHandle >::iterator i = list.begin(); 00291 while( i != list.end() ) 00292 { 00293 EntityHandle h = *i; 00294 ++i; 00295 EntityHandle e = *i; 00296 ++i; 00297 for( ; h <= e; ++h ) 00298 { 00299 *data = h; 00300 ++data; 00301 } 00302 } 00303 } 00304 } 00305 else if( ( mFlags & MESHSET_ORDERED ) && !( flg & MESHSET_ORDERED ) ) 00306 { 00307 size_t datalen; 00308 EntityHandle* data = get_contents( datalen ); 00309 if( datalen ) 00310 { 00311 std::vector< EntityHandle > ranges; 00312 convert_to_ranges( data, datalen, ranges ); 00313 Count count = (Count)mContentCount; 00314 data = resize_compact_list( count, contentList, ranges.size() ); 00315 mContentCount = count; 00316 memcpy( data, &ranges[0], ranges.size() * sizeof( EntityHandle ) ); 00317 } 00318 } 00319 00320 return MB_SUCCESS; 00321 } 00322 00323 ErrorCode MeshSet::create_adjacencies( EntityHandle my_handle, AEntityFactory* adj ) 00324 { 00325 ErrorCode rval = MB_SUCCESS; 00326 ; 00327 size_t count; 00328 const EntityHandle* const ptr = get_contents( count ); 00329 const EntityHandle* const end = ptr + count; 00330 if( vector_based() ) 00331 { 00332 for( const EntityHandle* i = ptr; i != end; ++i ) 00333 { 00334 rval = adj->add_adjacency( *i, my_handle, false ); 00335 if( MB_SUCCESS != rval ) 00336 { 00337 for( const EntityHandle* j = ptr; j != i; ++j ) 00338 adj->remove_adjacency( *j, my_handle ); 00339 return rval; 00340 } 00341 } 00342 } 00343 else 00344 { 00345 assert( 0 == count % 2 ); 00346 for( const EntityHandle* i = ptr; i != end; i += 2 ) 00347 { 00348 for( EntityHandle h = i[0]; h <= i[1]; ++h ) 00349 { 00350 rval = adj->add_adjacency( h, my_handle, false ); 00351 if( MB_SUCCESS != rval ) 00352 { 00353 for( EntityHandle j = i[0]; j < h; ++j ) 00354 adj->remove_adjacency( j, my_handle ); 00355 for( const EntityHandle* j = ptr; j != i; j += 2 ) 00356 for( EntityHandle k = j[0]; k <= j[1]; ++k ) 00357 adj->remove_adjacency( k, my_handle ); 00358 return rval; 00359 } 00360 } 00361 } 00362 } 00363 return MB_SUCCESS; 00364 } 00365 00366 ErrorCode MeshSet::remove_adjacencies( EntityHandle my_handle, AEntityFactory* adj ) 00367 { 00368 size_t count; 00369 const EntityHandle* const ptr = get_contents( count ); 00370 const EntityHandle* const end = ptr + count; 00371 if( vector_based() ) 00372 { 00373 for( const EntityHandle* i = ptr; i != end; ++i ) 00374 adj->remove_adjacency( *i, my_handle ); 00375 } 00376 else 00377 { 00378 assert( 0 == count % 2 ); 00379 for( const EntityHandle* i = ptr; i != end; i += 2 ) 00380 for( EntityHandle h = i[0]; h <= i[1]; ++h ) 00381 adj->remove_adjacency( h, my_handle ); 00382 } 00383 return MB_SUCCESS; 00384 } 00385 00386 /***************************************************************************************** 00387 * Contents Modifiction Methods * 00388 *****************************************************************************************/ 00389 00390 static EntityHandle* resize_compact_list( MeshSet::Count& count, MeshSet::CompactList& clist, size_t new_list_size ) 00391 { 00392 if( count <= 2 ) 00393 { 00394 if( new_list_size <= 2 ) 00395 { 00396 count = (MeshSet::Count)new_list_size; 00397 return clist.hnd; 00398 } 00399 else 00400 { 00401 EntityHandle* list = (EntityHandle*)malloc( new_list_size * sizeof( EntityHandle ) ); 00402 list[0] = clist.hnd[0]; 00403 list[1] = clist.hnd[1]; 00404 clist.ptr[0] = list; 00405 clist.ptr[1] = list + new_list_size; 00406 count = MeshSet::MANY; 00407 return list; 00408 } 00409 } 00410 else if( new_list_size > 2 ) 00411 { 00412 if( new_list_size > (size_t)( clist.ptr[1] - clist.ptr[0] ) ) 00413 clist.ptr[0] = (EntityHandle*)realloc( clist.ptr[0], new_list_size * sizeof( EntityHandle ) ); 00414 clist.ptr[1] = clist.ptr[0] + new_list_size; 00415 count = MeshSet::MANY; 00416 return clist.ptr[0]; 00417 } 00418 else 00419 { 00420 EntityHandle* list = clist.ptr[0]; 00421 clist.hnd[0] = list[0]; 00422 clist.hnd[1] = list[1]; 00423 free( list ); 00424 count = (MeshSet::Count)new_list_size; 00425 return clist.hnd; 00426 } 00427 } 00428 00429 typedef std::pair< EntityHandle, EntityHandle > MeshSetRange; 00430 00431 class MeshSetRComp 00432 { 00433 public: 00434 bool operator()( const MeshSetRange& r, const MeshSetRange& h ) 00435 { 00436 return r.second < h.first; 00437 } 00438 }; 00439 00440 template < typename pair_iter_t > 00441 inline ErrorCode range_tool< pair_iter_t >::ranged_insert_entities( MeshSet::Count& count, 00442 MeshSet::CompactList& clist, 00443 pair_iter_t begin, 00444 pair_iter_t end, 00445 EntityHandle my_handle, 00446 AEntityFactory* adj ) 00447 { 00448 // first pass: 00449 // 1) merge existing ranges 00450 // 2) count number of new ranges that must be inserted 00451 EntityHandle* list_ptr; 00452 size_t list_size; 00453 if( count < MeshSet::MANY ) 00454 { 00455 list_ptr = clist.hnd; 00456 list_size = count; 00457 } 00458 else 00459 { 00460 list_ptr = clist.ptr[0]; 00461 list_size = clist.ptr[1] - clist.ptr[0]; 00462 } 00463 00464 MeshSetRange* list = reinterpret_cast< MeshSetRange* >( list_ptr ); 00465 assert( 0 == list_size % 2 ); 00466 assert( 2 * sizeof( EntityHandle ) == sizeof( MeshSetRange ) ); 00467 list_size /= 2; 00468 MeshSetRange* const list_end = list + list_size; 00469 MeshSetRange *list_read = list, *list_write = list; 00470 pair_iter_t i = begin; 00471 00472 // count number of range pairs that are straight insertions 00473 // (don't overlap any range pair in the current set) that 00474 // could not be inserted during the first pass. 00475 size_t insert_count = 0; 00476 00477 // merge lists 00478 while( i != end ) 00479 { 00480 // find first range that intersects the current input range 00481 00482 // do binary search if no holes in current set contents 00483 if( list_read == list_write ) 00484 { 00485 // subtract one from i->first because if it is one greater 00486 // then the the last value of some block, then we want that 00487 // block to append to. 00488 MeshSetRange tmp; 00489 tmp.first = i->first - 1; 00490 tmp.second = i->second; 00491 list_write = std::lower_bound( list_read, list_end, tmp, MeshSetRComp() ); 00492 list_read = list_write; 00493 } 00494 // otherwise shift down until we find where we find a range block 00495 // that intersects 00496 else 00497 while( list_read != list_end && list_read->second + 1 < i->first ) 00498 { 00499 *list_write = *list_read; 00500 ++list_write; 00501 ++list_read; 00502 } 00503 00504 // handle any straight insertions of range blocks 00505 for( ; i != end && ( list_read == list_end || i->second + 1 < list_read->first ); ++i ) 00506 { 00507 // If we haven't removed any range pairs, we don't have space to 00508 // insert here. Defer the insertion until later. 00509 if( list_read == list_write ) 00510 { 00511 ++insert_count; 00512 } 00513 else 00514 { 00515 if( adj ) 00516 for( EntityHandle j = i->first; j <= i->second; ++j ) 00517 adj->add_adjacency( j, my_handle, false ); 00518 00519 list_write->first = i->first; 00520 list_write->second = i->second; 00521 ++list_write; 00522 } 00523 } 00524 00525 // merge all the stuff that gets merged into a single range pair 00526 // from both the input list and the existing set data 00527 if( list_read != list_end ) 00528 { 00529 MeshSetRange working = *list_read; // copy because might be the same as list_write 00530 ++list_read; 00531 00532 // Check if we need to prepend to the existing block. 00533 // We only need to check this for the first input range because 00534 // after this working.first will always be the first possible handle 00535 // in the merged set of ranges. 00536 if( i != end && i->first < working.first && i->second + 1 >= working.first ) 00537 { 00538 if( adj ) 00539 for( EntityHandle h = i->first; h < working.first; ++h ) 00540 adj->add_adjacency( h, my_handle, false ); 00541 working.first = i->first; 00542 } 00543 00544 // Now append from the input list and the remaining set contents 00545 // until we've consolidated all overlapping/touching ranges. 00546 bool done = false; 00547 while( !done ) 00548 { 00549 // does next set contents range touch working range? 00550 bool set_overlap = list_read != list_end && list_read->first <= working.second + 1; 00551 // does next input range touch working range? 00552 bool inp_overlap = i != end && i->first <= working.second + 1; 00553 00554 // if both ranges touch... 00555 if( inp_overlap && set_overlap ) 00556 { 00557 // if next set range is contained in working, skip it 00558 if( list_read->second <= working.second ) ++list_read; 00559 // if next input range is contained in working, skip it 00560 else if( i->second <= working.second ) 00561 ++i; 00562 // Otherwise set the working end to the smaller of the two 00563 // ends: either the next set end or the next input end. 00564 // We want the smaller of the two because the larger might 00565 // intersect additional ranges in the other list. 00566 else if( list_read->second <= i->second ) 00567 { 00568 working.second = list_read->second; 00569 ++list_read; 00570 } 00571 else 00572 { 00573 working.second = i->second; 00574 ++i; 00575 } 00576 } 00577 // If only the input range intersect the current working range... 00578 else if( inp_overlap ) 00579 { 00580 // Would it be more efficient to just extent 'working' to 00581 // the end of the current input range? We'd end up adding 00582 // adjacencies for for entities that are already in the tracking 00583 // set and therefore already have the adjacency. 00584 EntityHandle last = i->second; 00585 if( list_read != list_end && list_read->first < last ) 00586 last = list_read->first - 1; 00587 else 00588 ++i; 00589 00590 if( last > working.second ) 00591 { 00592 if( adj ) 00593 for( EntityHandle h = working.second + 1; h <= last; ++h ) 00594 adj->add_adjacency( h, my_handle, false ); 00595 00596 working.second = last; 00597 } 00598 } 00599 else if( set_overlap ) 00600 { 00601 if( working.second < list_read->second ) working.second = list_read->second; 00602 ++list_read; 00603 } 00604 else 00605 { 00606 done = true; 00607 } 00608 } 00609 00610 assert( list_write < list_read ); 00611 *list_write = working; 00612 ++list_write; 00613 } 00614 } 00615 00616 // shuffle down entries to fill holes 00617 if( list_read == list_write ) 00618 list_read = list_write = list_end; 00619 else 00620 while( list_read < list_end ) 00621 { 00622 *list_write = *list_read; 00623 ++list_read; 00624 ++list_write; 00625 } 00626 00627 // adjust allocated array size 00628 const size_t occupied_size = list_write - list; 00629 const size_t new_list_size = occupied_size + insert_count; 00630 list_ptr = resize_compact_list( count, clist, 2 * new_list_size ); 00631 // done? 00632 if( !insert_count ) return MB_SUCCESS; 00633 list = reinterpret_cast< MeshSetRange* >( list_ptr ); 00634 00635 // Second pass: insert non-mergable range pairs 00636 // All range pairs in the input are either completely disjoint from 00637 // the ones in the mesh set and must be inserted or are entirely contained 00638 // within a range pair in the mesh set. 00639 assert( begin != end ); // can't have items to insert if given empty input list 00640 pair_iter_t ri = end; 00641 --ri; 00642 list_write = list + new_list_size - 1; 00643 list_read = list + occupied_size - 1; 00644 for( ; list_write >= list; --list_write ) 00645 { 00646 if( list_read >= list ) 00647 { 00648 while( ri->first >= list_read->first && ri->second <= list_read->second ) 00649 { 00650 assert( ri != begin ); 00651 --ri; 00652 } 00653 00654 if( list_read->first > ri->second ) 00655 { 00656 *list_write = *list_read; 00657 --list_read; 00658 continue; 00659 } 00660 } 00661 00662 assert( insert_count > 0 ); 00663 if( adj ) 00664 for( EntityHandle h = ri->first; h <= ri->second; ++h ) 00665 adj->add_adjacency( h, my_handle, false ); 00666 list_write->first = ri->first; 00667 list_write->second = ri->second; 00668 00669 // don't have reverse iterator, so check before decrement 00670 // if insert_count isn't zero, must be more in range 00671 if( 0 == --insert_count ) 00672 { 00673 assert( list_read == list_write - 1 ); 00674 break; 00675 } 00676 else 00677 { 00678 --ri; 00679 } 00680 } 00681 00682 assert( !insert_count ); 00683 return MB_SUCCESS; 00684 } 00685 00686 template < typename pair_iter_t > 00687 inline ErrorCode range_tool< pair_iter_t >::ranged_remove_entities( MeshSet::Count& count, 00688 MeshSet::CompactList& clist, 00689 pair_iter_t begin, 00690 pair_iter_t end, 00691 EntityHandle my_handle, 00692 AEntityFactory* adj ) 00693 { 00694 // first pass: 00695 // 1) remove (from) existing ranges 00696 // 2) count number of ranges that must be split 00697 ptrdiff_t split_count = 0; 00698 EntityHandle* list; 00699 size_t list_size; 00700 if( count < MeshSet::MANY ) 00701 { 00702 list = clist.hnd; 00703 list_size = count; 00704 } 00705 else 00706 { 00707 list = clist.ptr[0]; 00708 list_size = clist.ptr[1] - clist.ptr[0]; 00709 } 00710 00711 EntityHandle* list_write = list; 00712 EntityHandle *const list_end = list + list_size, *list_read = list; 00713 pair_iter_t i = begin; 00714 00715 while( list_read != list_end && i != end ) 00716 { 00717 00718 while( i != end && i->second < list_read[0] ) 00719 ++i; 00720 if( i == end ) break; 00721 00722 // if there are holes in the current array, shuffle blocks 00723 // down until we find the next block to remove 00724 if( list_read != list_write ) 00725 { 00726 while( list_read != list_end && i->second < list_read[0] ) 00727 { 00728 list_write[0] = list_read[0]; 00729 list_write[1] = list_read[1]; 00730 list_write += 2; 00731 list_read += 2; 00732 } 00733 } 00734 // otherwise do a binary search 00735 else 00736 { 00737 list_write = std::lower_bound( list_write, list_end, i->first ); 00738 // if in middle of range block (odd index), back up to start of block 00739 list_write -= ( list_write - list ) % 2; 00740 list_read = list_write; 00741 } 00742 00743 // if everything remaning is past end of set contents... 00744 if( list_read == list_end ) break; 00745 00746 // skip any remove pairs that aren't in the list 00747 if( i->second < list_read[0] ) 00748 { 00749 ++i; 00750 continue; 00751 } 00752 00753 // Begin by assuming that we will keep the entire block 00754 list_write[0] = list_read[0]; 00755 list_write[1] = list_read[1]; 00756 list_read += 2; 00757 00758 for( ; i != end && i->first <= list_write[1]; ++i ) 00759 { 00760 if( i->first <= list_write[0] ) 00761 { 00762 // remove whole block 00763 if( i->second >= list_write[1] ) 00764 { 00765 if( adj ) 00766 for( EntityHandle h = list_write[0]; h <= list_write[1]; ++h ) 00767 adj->remove_adjacency( h, my_handle ); 00768 list_write -= 2; 00769 break; 00770 } 00771 // remove from start of block 00772 else if( i->second >= list_write[0] ) 00773 { 00774 if( adj ) 00775 for( EntityHandle h = list_write[0]; h <= i->second; ++h ) 00776 adj->remove_adjacency( h, my_handle ); 00777 list_write[0] = i->second + 1; 00778 } 00779 } 00780 else if( i->first <= list_write[1] ) 00781 { 00782 // remove from end of block 00783 if( i->second >= list_write[1] ) 00784 { 00785 if( adj ) 00786 for( EntityHandle h = i->first; h <= list_write[1]; ++h ) 00787 adj->remove_adjacency( h, my_handle ); 00788 list_write[1] = i->first - 1; 00789 // list_write += 2; 00790 break; 00791 } 00792 // split block 00793 else 00794 { 00795 if( adj ) 00796 for( EntityHandle h = i->first; h <= i->second; ++h ) 00797 adj->remove_adjacency( h, my_handle ); 00798 00799 if( list_read - list_write <= 2 ) 00800 { 00801 ++split_count; 00802 continue; 00803 } 00804 else 00805 { 00806 list_write[3] = list_write[1]; 00807 list_write[1] = i->first - 1; 00808 list_write[2] = i->second + 1; 00809 list_write += 2; 00810 } 00811 } 00812 } 00813 } 00814 list_write += 2; 00815 } 00816 00817 // shuffle down entries to fill holes 00818 if( list_read == list_write ) 00819 list_read = list_write = list_end; 00820 else 00821 while( list_read < list_end ) 00822 { 00823 list_write[0] = list_read[0]; 00824 list_write[1] = list_read[1]; 00825 list_read += 2; 00826 list_write += 2; 00827 } 00828 00829 // adjust allocated array size 00830 const size_t occupied_size = list_write - list; 00831 const size_t new_list_size = occupied_size + 2 * split_count; 00832 list = resize_compact_list( count, clist, new_list_size ); 00833 // done? 00834 if( !split_count ) return MB_SUCCESS; 00835 00836 // Second pass: split range pairs 00837 // All range pairs in the input are either already removed or 00838 // require one of the existing range pairs to be split 00839 assert( begin != end ); // can't have ranges to split if given empty input list 00840 pair_iter_t ri = end; 00841 --ri; 00842 list_write = list + new_list_size - 2; 00843 list_read = list + occupied_size - 2; 00844 for( ; list_write >= list; list_write -= 2 ) 00845 { 00846 if( list_read >= list ) 00847 { 00848 while( ri->second > list_read[1] ) 00849 { 00850 assert( ri != begin ); 00851 --ri; 00852 } 00853 00854 if( list_read[0] > ri->second ) 00855 { 00856 list_write[0] = list_read[0]; 00857 list_write[1] = list_read[1]; 00858 list_read -= 2; 00859 continue; 00860 } 00861 } 00862 00863 assert( split_count > 0 ); 00864 list_write[0] = ri->second + 1; 00865 list_write[1] = list_read[1]; 00866 list_read[1] = ri->first - 1; 00867 00868 // don't have reverse iterator, so check before decrement 00869 // if insert_count isn't zero, must be more in range 00870 if( 0 == --split_count ) 00871 { 00872 assert( list_read == list_write - 2 ); 00873 break; 00874 } 00875 else 00876 { 00877 --ri; 00878 } 00879 } 00880 00881 assert( !split_count ); 00882 return MB_SUCCESS; 00883 } 00884 00885 template < typename pair_iter_t > 00886 inline ErrorCode range_tool< pair_iter_t >::vector_insert_entities( MeshSet::Count& count, 00887 MeshSet::CompactList& clist, 00888 pair_iter_t begin, 00889 pair_iter_t end, 00890 EntityHandle my_handle, 00891 AEntityFactory* adj ) 00892 { 00893 const size_t init_size = count < MeshSet::MANY ? (int)count : clist.ptr[1] - clist.ptr[0]; 00894 size_t add_size = 0; 00895 for( pair_iter_t i = begin; i != end; ++i ) 00896 add_size += i->second - i->first + 1; 00897 EntityHandle* list = resize_compact_list( count, clist, init_size + add_size ); 00898 EntityHandle* li = list + init_size; 00899 00900 for( pair_iter_t i = begin; i != end; ++i ) 00901 { 00902 for( EntityHandle h = i->first; h <= i->second; ++h ) 00903 { 00904 if( adj ) adj->add_adjacency( h, my_handle, false ); 00905 *li = h; 00906 ++li; 00907 } 00908 } 00909 00910 return MB_SUCCESS; 00911 } 00912 00913 static ErrorCode vector_remove_range( MeshSet::Count& count, 00914 MeshSet::CompactList& clist, 00915 const Range& range, 00916 EntityHandle my_handle, 00917 AEntityFactory* adj ) 00918 { 00919 EntityHandle* list; 00920 size_t list_size; 00921 if( count < MeshSet::MANY ) 00922 { 00923 list = clist.hnd; 00924 list_size = count; 00925 } 00926 else 00927 { 00928 list = clist.ptr[0]; 00929 list_size = clist.ptr[1] - clist.ptr[0]; 00930 } 00931 00932 const EntityHandle* const list_end = list + list_size; 00933 EntityHandle* list_write = list; 00934 for( const EntityHandle* list_read = list; list_read != list_end; ++list_read ) 00935 { 00936 if( range.find( *list_read ) == range.end() ) 00937 { // keep 00938 *list_write = *list_read; 00939 ++list_write; 00940 } 00941 else if( adj ) 00942 { 00943 adj->remove_adjacency( *list_read, my_handle ); 00944 } 00945 } 00946 00947 resize_compact_list( count, clist, list_write - list ); 00948 return MB_SUCCESS; 00949 } 00950 00951 static ErrorCode vector_remove_ranges( MeshSet::Count& count, 00952 MeshSet::CompactList& clist, 00953 const EntityHandle* pair_list, 00954 size_t num_pairs, 00955 EntityHandle my_handle, 00956 AEntityFactory* adj ) 00957 { 00958 EntityHandle* list; 00959 size_t list_size; 00960 if( count < MeshSet::MANY ) 00961 { 00962 list = clist.hnd; 00963 list_size = count; 00964 } 00965 else 00966 { 00967 list = clist.ptr[0]; 00968 list_size = clist.ptr[1] - clist.ptr[0]; 00969 } 00970 00971 const EntityHandle *const list_end = list + list_size, *const input_end = pair_list + 2 * num_pairs; 00972 EntityHandle* list_write = list; 00973 for( const EntityHandle* list_read = list; list_read != list_end; ++list_read ) 00974 { 00975 const EntityHandle* ptr = std::lower_bound( pair_list, input_end, *list_read ); 00976 if( ( ptr != input_end && ( *ptr == *list_read || ( ptr - pair_list ) % 2 ) ) && // if in delete list 00977 std::find( list_read + 1, list_end, *list_read ) == list_end ) 00978 { // and is last occurance in list 00979 // only remove adj if no previous occurance 00980 if( adj && std::find( list, list_write, *list_read ) == list_write ) 00981 adj->remove_adjacency( *list_read, my_handle ); 00982 } 00983 else 00984 { 00985 *list_write = *list_read; 00986 ++list_write; 00987 } 00988 } 00989 00990 resize_compact_list( count, clist, list_write - list ); 00991 return MB_SUCCESS; 00992 } 00993 00994 static ErrorCode vector_remove_vector( MeshSet::Count& count, 00995 MeshSet::CompactList& clist, 00996 const EntityHandle* vect, 00997 size_t vect_size, 00998 EntityHandle my_handle, 00999 AEntityFactory* adj ) 01000 { 01001 EntityHandle* list; 01002 size_t list_size; 01003 if( count < MeshSet::MANY ) 01004 { 01005 list = clist.hnd; 01006 list_size = count; 01007 } 01008 else 01009 { 01010 list = clist.ptr[0]; 01011 list_size = clist.ptr[1] - clist.ptr[0]; 01012 } 01013 01014 const EntityHandle *const list_end = list + list_size, *const input_end = vect + vect_size; 01015 EntityHandle* list_write = list; 01016 for( const EntityHandle* list_read = list; list_read != list_end; ++list_read ) 01017 { 01018 if( std::find( vect, input_end, *list_read ) != input_end && // if in delete list 01019 std::find( list_read + 1, list_end, *list_read ) == list_end ) 01020 { // and is last occurance in list 01021 // only remove adj if no previous occurance? 01022 if( adj ) // && std::find(list, list_write, *list_read) == list_write) 01023 adj->remove_adjacency( *list_read, my_handle ); 01024 } 01025 else 01026 { 01027 *list_write = *list_read; 01028 ++list_write; 01029 } 01030 } 01031 01032 resize_compact_list( count, clist, list_write - list ); 01033 return MB_SUCCESS; 01034 } 01035 01036 static ErrorCode vector_insert_vector( MeshSet::Count& count, 01037 MeshSet::CompactList& clist, 01038 const EntityHandle* vect, 01039 size_t vect_size, 01040 EntityHandle my_handle, 01041 AEntityFactory* adj ) 01042 { 01043 const size_t orig_size = count < MeshSet::MANY ? (int)count : clist.ptr[1] - clist.ptr[0]; 01044 EntityHandle* list = resize_compact_list( count, clist, orig_size + vect_size ); 01045 if( adj ) 01046 for( size_t i = 0; i < vect_size; ++i ) 01047 adj->add_adjacency( vect[i], my_handle, false ); 01048 memcpy( list + orig_size, vect, sizeof( EntityHandle ) * vect_size ); 01049 return MB_SUCCESS; 01050 } 01051 01052 ErrorCode MeshSet::insert_entity_ranges( const EntityHandle* range_vect, 01053 size_t len, 01054 EntityHandle my_h, 01055 AEntityFactory* adj ) 01056 { 01057 typedef const std::pair< EntityHandle, EntityHandle >* pair_vect_t; 01058 pair_vect_t pair_vect = reinterpret_cast< pair_vect_t >( range_vect ); 01059 MeshSet::Count count = static_cast< MeshSet::Count >( mContentCount ); 01060 ErrorCode rval; 01061 if( !vector_based() ) 01062 rval = range_tool< pair_vect_t >::ranged_insert_entities( count, contentList, pair_vect, pair_vect + len / 2, 01063 my_h, tracking() ? adj : 0 ); 01064 else 01065 rval = range_tool< pair_vect_t >::vector_insert_entities( count, contentList, pair_vect, pair_vect + len / 2, 01066 my_h, tracking() ? adj : 0 ); 01067 mContentCount = count; 01068 return rval; 01069 } 01070 01071 ErrorCode MeshSet::insert_entity_ranges( const Range& range, EntityHandle my_h, AEntityFactory* adj ) 01072 { 01073 ErrorCode rval; 01074 MeshSet::Count count = static_cast< MeshSet::Count >( mContentCount ); 01075 if( !vector_based() ) 01076 rval = range_tool< Range::const_pair_iterator >::ranged_insert_entities( 01077 count, contentList, range.const_pair_begin(), range.const_pair_end(), my_h, tracking() ? adj : 0 ); 01078 else 01079 rval = range_tool< Range::const_pair_iterator >::vector_insert_entities( 01080 count, contentList, range.const_pair_begin(), range.const_pair_end(), my_h, tracking() ? adj : 0 ); 01081 mContentCount = count; 01082 return rval; 01083 } 01084 01085 ErrorCode MeshSet::remove_entity_ranges( const EntityHandle* range_vect, 01086 size_t len, 01087 EntityHandle my_h, 01088 AEntityFactory* adj ) 01089 { 01090 ErrorCode rval; 01091 MeshSet::Count count = static_cast< MeshSet::Count >( mContentCount ); 01092 if( vector_based() ) 01093 rval = vector_remove_ranges( count, contentList, range_vect, len / 2, my_h, tracking() ? adj : 0 ); 01094 else 01095 { 01096 typedef const std::pair< EntityHandle, EntityHandle >* pair_vect_t; 01097 pair_vect_t pair_vect = reinterpret_cast< pair_vect_t >( range_vect ); 01098 rval = range_tool< pair_vect_t >::ranged_remove_entities( count, contentList, pair_vect, pair_vect + len / 2, 01099 my_h, tracking() ? adj : 0 ); 01100 } 01101 mContentCount = count; 01102 return rval; 01103 } 01104 01105 ErrorCode MeshSet::remove_entity_ranges( const Range& range, EntityHandle my_h, AEntityFactory* adj ) 01106 { 01107 ErrorCode rval; 01108 MeshSet::Count count = static_cast< MeshSet::Count >( mContentCount ); 01109 if( vector_based() ) 01110 rval = vector_remove_range( count, contentList, range, my_h, tracking() ? adj : 0 ); 01111 else 01112 rval = range_tool< Range::const_pair_iterator >::ranged_remove_entities( 01113 count, contentList, range.const_pair_begin(), range.const_pair_end(), my_h, tracking() ? adj : 0 ); 01114 mContentCount = count; 01115 return rval; 01116 } 01117 01118 ErrorCode MeshSet::intersect( const MeshSet* other, EntityHandle my_handle, AEntityFactory* adj ) 01119 { 01120 ErrorCode rval; 01121 if( !vector_based() && !other->vector_based() ) 01122 { 01123 size_t other_count = 0; 01124 const EntityHandle* other_vect = other->get_contents( other_count ); 01125 if( !other_count ) return clear( my_handle, adj ); 01126 assert( 0 == other_count % 2 ); 01127 01128 std::vector< EntityHandle > compliment; 01129 compliment.reserve( other_count + 4 ); 01130 if( *other_vect > 0 ) 01131 { 01132 compliment.push_back( 0 ); 01133 compliment.push_back( *other_vect - 1 ); 01134 } 01135 ++other_vect; 01136 const EntityHandle* const other_end = other_vect + other_count - 2; 01137 for( ; other_vect < other_end; other_vect += 2 ) 01138 { 01139 compliment.push_back( other_vect[0] + 1 ); 01140 compliment.push_back( other_vect[1] - 1 ); 01141 } 01142 if( *other_vect < ~(EntityHandle)0 ) 01143 { 01144 compliment.push_back( *other_vect + 1 ); 01145 compliment.push_back( ~(EntityHandle)0 ); 01146 } 01147 01148 return remove_entity_ranges( &compliment[0], compliment.size(), my_handle, adj ); 01149 } 01150 else 01151 { 01152 Range my_ents, other_ents; 01153 rval = get_entities( my_ents ); 01154 if( MB_SUCCESS != rval ) return rval; 01155 rval = other->get_entities( other_ents ); 01156 return remove_entities( moab::subtract( my_ents, other_ents ), my_handle, adj ); 01157 } 01158 } 01159 01160 static void convert_to_ranges( const EntityHandle* vect_in, size_t vect_in_len, std::vector< EntityHandle >& vect_out ) 01161 { 01162 vect_out.reserve( 2 * vect_in_len ); 01163 vect_out.resize( vect_in_len ); 01164 std::copy( vect_in, vect_in + vect_in_len, vect_out.begin() ); 01165 std::sort( vect_out.begin(), vect_out.end() ); 01166 vect_out.erase( std::unique( vect_out.begin(), vect_out.end() ), vect_out.end() ); 01167 01168 // duplicate all entries 01169 vect_out.resize( vect_out.size() * 2 ); 01170 for( long i = vect_out.size() - 1; i >= 0; --i ) 01171 vect_out[i] = vect_out[i / 2]; 01172 01173 // compact adjacent ranges 01174 std::vector< EntityHandle >::iterator r = vect_out.begin(), w = vect_out.begin(); 01175 while( r != vect_out.end() ) 01176 { 01177 *w = *r; 01178 ++w; 01179 ++r; 01180 *w = *r; 01181 ++r; 01182 01183 while( r != vect_out.end() && *w + 1 == *r ) 01184 { 01185 ++r; 01186 *w = *r; 01187 ++r; 01188 } 01189 ++w; 01190 } 01191 01192 // remove extra space 01193 vect_out.erase( w, vect_out.end() ); 01194 } 01195 01196 ErrorCode MeshSet::insert_entity_vector( const EntityHandle* vect, size_t len, EntityHandle my_h, AEntityFactory* adj ) 01197 { 01198 MeshSet::Count count = static_cast< MeshSet::Count >( mContentCount ); 01199 ErrorCode rval; 01200 if( vector_based() ) 01201 rval = vector_insert_vector( count, contentList, vect, len, my_h, tracking() ? adj : 0 ); 01202 else 01203 { 01204 std::vector< EntityHandle > rangevect; 01205 convert_to_ranges( vect, len, rangevect ); 01206 typedef const std::pair< EntityHandle, EntityHandle >* pair_vect_t; 01207 pair_vect_t pair_vect = ( rangevect.empty() ) ? NULL : reinterpret_cast< pair_vect_t >( &rangevect[0] ); 01208 rval = range_tool< pair_vect_t >::ranged_insert_entities( 01209 count, contentList, pair_vect, pair_vect + rangevect.size() / 2, my_h, tracking() ? adj : 0 ); 01210 } 01211 mContentCount = count; 01212 return rval; 01213 } 01214 01215 ErrorCode MeshSet::remove_entity_vector( const EntityHandle* vect, size_t len, EntityHandle my_h, AEntityFactory* adj ) 01216 { 01217 MeshSet::Count count = static_cast< MeshSet::Count >( mContentCount ); 01218 ErrorCode rval; 01219 if( vector_based() ) 01220 rval = vector_remove_vector( count, contentList, vect, len, my_h, tracking() ? adj : 0 ); 01221 else 01222 { 01223 std::vector< EntityHandle > rangevect; 01224 convert_to_ranges( vect, len, rangevect ); 01225 typedef const std::pair< EntityHandle, EntityHandle >* pair_vect_t; 01226 pair_vect_t pair_vect = ( rangevect.empty() ) ? NULL : reinterpret_cast< pair_vect_t >( &rangevect[0] ); 01227 rval = range_tool< pair_vect_t >::ranged_remove_entities( 01228 count, contentList, pair_vect, pair_vect + rangevect.size() / 2, my_h, tracking() ? adj : 0 ); 01229 } 01230 mContentCount = count; 01231 return rval; 01232 } 01233 01234 ErrorCode MeshSet::replace_entities( EntityHandle my_handle, 01235 const EntityHandle* old_entities, 01236 const EntityHandle* new_entities, 01237 size_t num_ents, 01238 AEntityFactory* adjfact ) 01239 { 01240 if( vector_based() ) 01241 { 01242 ErrorCode result = MB_SUCCESS; 01243 size_t count; 01244 EntityHandle* vect = get_contents( count ); 01245 EntityHandle* const vect_end = vect + count; 01246 for( size_t i = 0; i < num_ents; ++i ) 01247 { 01248 EntityHandle* p = std::find( vect, vect_end, old_entities[i] ); 01249 if( p == vect_end ) 01250 { 01251 result = MB_ENTITY_NOT_FOUND; 01252 } 01253 else 01254 do 01255 { 01256 if( tracking() ) 01257 { 01258 adjfact->remove_adjacency( *p, my_handle ); 01259 adjfact->add_adjacency( new_entities[i], my_handle, false ); 01260 } 01261 *p = new_entities[i]; 01262 p = std::find( p + 1, vect_end, old_entities[i] ); 01263 } while( p != vect_end ); 01264 } 01265 return result; 01266 } 01267 else 01268 { 01269 ErrorCode r1 = remove_entities( old_entities, num_ents, my_handle, adjfact ); 01270 ErrorCode r2 = add_entities( new_entities, num_ents, my_handle, adjfact ); 01271 return ( MB_SUCCESS == r2 ) ? r1 : r2; 01272 } 01273 } 01274 01275 /***************************************************************************************** 01276 * Misc. Methods * 01277 *****************************************************************************************/ 01278 01279 unsigned long MeshSet::get_memory_use() const 01280 { 01281 unsigned long result = 0; 01282 if( mParentCount == MANY ) result += parentMeshSets.ptr[1] - parentMeshSets.ptr[0]; 01283 if( mChildCount == MANY ) result += childMeshSets.ptr[1] - childMeshSets.ptr[0]; 01284 if( mContentCount == MANY ) result += contentList.ptr[1] - contentList.ptr[0]; 01285 return sizeof( EntityHandle ) * result; 01286 } 01287 01288 } // namespace moab
