MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "ElemUtil.hpp" 00003 #include "moab/Core.hpp" 00004 #include "moab/Range.hpp" 00005 #include <iostream> 00006 00007 #ifndef MESHDIR 00008 #error Specify MESHDIR to compile test 00009 #endif 00010 00011 using namespace moab; 00012 00013 void test_tet(); 00014 void test_hex(); 00015 void test_spectral_hex(); 00016 void test_spectral_quad(); 00017 void test_spherical_quad(); 00018 void test_linear_tri(); 00019 void test_spherical_tri(); 00020 00021 int main() 00022 { 00023 int rval = 0; 00024 rval += RUN_TEST( test_tet ); 00025 rval += RUN_TEST( test_hex ); 00026 rval += RUN_TEST( test_spectral_hex ); 00027 rval += RUN_TEST( test_spectral_quad ); 00028 rval += RUN_TEST( test_spherical_quad ); 00029 rval += RUN_TEST( test_linear_tri ); 00030 rval += RUN_TEST( test_spherical_tri ); 00031 return rval; 00032 } 00033 00034 void test_tet() 00035 { 00036 moab::Element::LinearTet tet; 00037 } // test_tet() 00038 00039 void test_hex() 00040 { 00041 double positions[] = { 236.80706050970281, -139.55422526228017, 193.27999999999997, 00042 236.47511729348639, -141.33020962638582, 193.27999999999997, 00043 237.8457938295229, -142.57076074835663, 193.27999999999997, 00044 239.12702305519684, -139.96608933577852, 193.27999999999997, 00045 236.80841321361444, -139.55341321335499, 202.654, 00046 236.47655014713746, -141.32980272396816, 202.654, 00047 237.8477913707564, -142.57047282187165, 202.654, 00048 239.12865103844533, -139.96531051891105, 202.654 }; 00049 CartVect x( 235.96518686964933, -142.43503000077749, 188.19999999999987 ); 00050 std::vector< CartVect > vertices; 00051 for( int i = 0; i < 8; i++ ) 00052 vertices.push_back( CartVect( positions + 3 * i ) ); 00053 00054 moab::Element::LinearHex hex( vertices ); 00055 double tol( 0.0001 ); 00056 if( hex.inside_box( x, tol ) ) 00057 { 00058 CartVect nat_par = hex.ievaluate( x, 0.0001 ); 00059 std::cout << nat_par << "\n"; 00060 } 00061 00062 double positions2[] = { 49.890500000000024, -20.376134375374882, 312.72000000000003, 00063 52.015875000000044, -19.149048546996006, 312.72000000000003, 00064 48.430375821458099, -18.548796774572125, 312.72000000000003, 00065 47.717616239031223, -21.191360829777231, 312.72000000000003, 00066 49.890500000000024, -20.376134375374882, 322.88, 00067 52.015875000000044, -19.149048546996006, 322.88, 00068 48.429930354643275, -18.52828610485021, 322.88, 00069 47.720552036968819, -21.167591146685712, 322.88 }; 00070 00071 CartVect x2( 51.469000000000015, -20.145482942833631, 317.80000000000001 ); 00072 00073 vertices.clear(); 00074 for( int i = 0; i < 8; i++ ) 00075 vertices.push_back( CartVect( positions2 + 3 * i ) ); 00076 moab::Element::LinearHex hex2( vertices ); 00077 if( hex2.inside_box( x2, tol ) ) 00078 { 00079 try 00080 { 00081 CartVect nat_par = hex.ievaluate( x, 0.0001 ); 00082 std::cout << nat_par << "\n"; 00083 } 00084 catch( Element::Map::EvaluationError ) 00085 { 00086 // nothing 00087 } 00088 } 00089 00090 } // test_hex() 00091 00092 void test_spectral_hex() 00093 { 00094 // first load a model that has spectral elements 00095 moab::Core* mb = new moab::Core(); 00096 std::string meshFile = STRINGIFY( MESHDIR ) "/spectral.h5m"; 00097 moab::ErrorCode rval = mb->load_mesh( meshFile.c_str() ); 00098 if( moab::MB_SUCCESS != rval ) 00099 { 00100 std::cout << "Problems reading file " << meshFile << "." << std::endl; 00101 delete mb; 00102 return; 00103 } 00104 00105 // get the ent set with SEM_DIMS tag 00106 moab::Range spectral_sets; 00107 moab::Tag sem_tag; 00108 rval = mb->tag_get_handle( "SEM_DIMS", 3, moab::MB_TYPE_INTEGER, sem_tag ); 00109 if( moab::MB_SUCCESS != rval ) 00110 { 00111 std::cout << "can't find tag, no spectral set\n"; 00112 delete mb; 00113 return; 00114 } 00115 rval = mb->get_entities_by_type_and_tag( 0, moab::MBENTITYSET, &sem_tag, NULL, 1, spectral_sets ); 00116 if( moab::MB_SUCCESS != rval || spectral_sets.empty() ) 00117 { 00118 std::cout << "can't get sem set\n"; 00119 delete mb; 00120 return; 00121 } 00122 00123 moab::Range ents; 00124 00125 int sem_dims[3]; 00126 moab::EntityHandle firstSemSet = spectral_sets[0]; 00127 rval = mb->tag_get_data( sem_tag, &firstSemSet, 1, (void*)sem_dims ); 00128 if( moab::MB_SUCCESS != rval ) 00129 { 00130 delete mb; 00131 return; 00132 } 00133 00134 rval = mb->get_entities_by_dimension( firstSemSet, 3, ents ); 00135 if( moab::MB_SUCCESS != rval ) 00136 { 00137 delete mb; 00138 return; 00139 } 00140 std::cout << "Found " << ents.size() << " " << 3 << "-dimensional entities:" << std::endl; 00141 00142 if( sem_dims[0] != sem_dims[1] || sem_dims[0] != sem_dims[2] ) 00143 { 00144 std::cout << " dimensions are different. bail out\n"; 00145 delete mb; 00146 return; 00147 } 00148 00149 // get the SEM_X ...tags 00150 moab::Tag xm1Tag, ym1Tag, zm1Tag; 00151 int ntot = sem_dims[0] * sem_dims[1] * sem_dims[2]; 00152 rval = mb->tag_get_handle( "SEM_X", ntot, moab::MB_TYPE_DOUBLE, xm1Tag ); 00153 if( moab::MB_SUCCESS != rval ) 00154 { 00155 std::cout << "can't get xm1tag \n"; 00156 delete mb; 00157 return; 00158 } 00159 rval = mb->tag_get_handle( "SEM_Y", ntot, moab::MB_TYPE_DOUBLE, ym1Tag ); 00160 if( moab::MB_SUCCESS != rval ) 00161 { 00162 std::cout << "can't get ym1tag \n"; 00163 delete mb; 00164 return; 00165 } 00166 rval = mb->tag_get_handle( "SEM_Z", ntot, moab::MB_TYPE_DOUBLE, zm1Tag ); 00167 if( moab::MB_SUCCESS != rval ) 00168 { 00169 std::cout << "can't get zm1tag \n"; 00170 delete mb; 00171 return; 00172 } 00173 moab::Tag velTag; 00174 00175 rval = mb->tag_get_handle( "VX", ntot, moab::MB_TYPE_DOUBLE, velTag ); 00176 if( moab::MB_SUCCESS != rval ) 00177 { 00178 std::cout << "can't get veltag \n"; 00179 delete mb; 00180 return; 00181 } 00182 moab::Element::SpectralHex specHex( sem_dims[0] ); 00183 00184 // compute the data for some elements 00185 for( moab::Range::iterator rit = ents.begin(); rit != ents.end(); ++rit ) 00186 { 00187 // get the tag pointers to the internal storage for xm1, to not copy the values 00188 moab::EntityHandle eh = *rit; 00189 const double* xval; 00190 const double* yval; 00191 const double* zval; 00192 rval = mb->tag_get_by_ptr( xm1Tag, &eh, 1, (const void**)&xval ); 00193 if( moab::MB_SUCCESS != rval ) 00194 { 00195 std::cout << "can't get xm1 values \n"; 00196 delete mb; 00197 return; 00198 } 00199 rval = mb->tag_get_by_ptr( ym1Tag, &eh, 1, (const void**)&yval ); 00200 if( moab::MB_SUCCESS != rval ) 00201 { 00202 std::cout << "can't get ym1 values \n"; 00203 delete mb; 00204 return; 00205 } 00206 rval = mb->tag_get_by_ptr( zm1Tag, &eh, 1, (const void**)&zval ); 00207 if( moab::MB_SUCCESS != rval ) 00208 { 00209 std::cout << "can't get zm1 values \n"; 00210 delete mb; 00211 return; 00212 } 00213 if( rit == ents.begin() ) 00214 { 00215 std::cout << " xm1 for first element: \n"; 00216 for( int i = 0; i < ntot; i++ ) 00217 std::cout << " " << xval[i]; 00218 std::cout << "\n"; 00219 } 00220 specHex.set_gl_points( (double*)xval, (double*)yval, (double*)zval ); 00221 // first evaluate a point, then inverse it to see if we get the same thing 00222 moab::CartVect rst( 0.1, -0.1, 0.5 ); 00223 moab::CartVect pos = specHex.evaluate( rst ); 00224 moab::CartVect inverse = specHex.ievaluate( pos, 0.0001 ); 00225 std::cout << "difference" << rst - inverse << "\n"; 00226 Matrix3 jac = specHex.jacobian( rst ); 00227 std::cout << "jacobian: \n" << jac << " \n determinant: " << jac.determinant() << "\n"; 00228 // evaluate vx at some point 00229 const double* vx; 00230 rval = mb->tag_get_by_ptr( velTag, &eh, 1, (const void**)&vx ); 00231 if( moab::MB_SUCCESS != rval ) 00232 { 00233 std::cout << "can't get vel values \n"; 00234 delete mb; 00235 return; 00236 } 00237 double vel1 = specHex.evaluate_scalar_field( rst, vx ); 00238 std::cout << "velocity: " << vel1 << "\n"; 00239 // compute integral over vx: 00240 double integral = specHex.integrate_scalar_field( vx ); 00241 std::cout << "integral over vx: " << integral << "\n"; 00242 } 00243 std::cout << "success...\n"; 00244 00245 delete mb; 00246 } 00247 00248 void test_spectral_quad() 00249 { 00250 // first load a model that has spectral elements 00251 moab::Core* mb = new moab::Core(); 00252 // use the grid on Sphere from mbcslam folder 00253 std::string meshFile = STRINGIFY( MESHDIR ) "/mbcslam/eulerHomme.vtk"; 00254 moab::ErrorCode rval = mb->load_mesh( meshFile.c_str() ); 00255 if( moab::MB_SUCCESS != rval ) 00256 { 00257 std::cout << "Problems reading file " << meshFile << "." << std::endl; 00258 delete mb; 00259 return; 00260 } 00261 00262 // for each element, compute the gl points and project them on sphere 00263 // the radius is the same as the one from intersection test on sphere 00264 // double R = 6. * sqrt(3.) / 2; // input 00265 00266 moab::Range ents; 00267 00268 rval = mb->get_entities_by_type( 0, moab::MBQUAD, ents ); // get all quads 00269 if( moab::MB_SUCCESS != rval ) 00270 { 00271 delete mb; 00272 return; 00273 } 00274 std::cout << "Found " << ents.size() << " " << 2 << "-dimensional entities:" << std::endl; 00275 00276 // 00277 int NP = 4; // test this.... 00278 moab::Element::SpectralQuad specQuad( NP ); 00279 00280 // compute the gl points for some elements 00281 for( moab::Range::iterator rit = ents.begin(); rit != ents.end(); ++rit ) 00282 { 00283 00284 const moab::EntityHandle* conn4 = NULL; 00285 int num_nodes = 0; 00286 rval = mb->get_connectivity( *rit, conn4, num_nodes ); 00287 if( moab::MB_SUCCESS != rval ) 00288 { 00289 std::cout << "can't get connectivity for quad \n"; 00290 delete mb; 00291 return; 00292 } 00293 assert( num_nodes == 4 ); 00294 00295 std::vector< CartVect > verts( 4 ); 00296 rval = mb->get_coords( conn4, num_nodes, &( verts[0][0] ) ); 00297 if( moab::MB_SUCCESS != rval ) 00298 { 00299 std::cout << "can't get coords for quad \n"; 00300 delete mb; 00301 return; 00302 } 00303 00304 specQuad.set_vertices( verts ); 00305 specQuad.compute_gl_positions(); 00306 // do something with the gl positions, project them on a sphere, and create another mesh? 00307 if( rit == ents.begin() ) 00308 { 00309 std::cout << " gl points for first element: \n"; 00310 int size; 00311 double* xyz[3]; 00312 specQuad.get_gl_points( xyz[0], xyz[1], xyz[2], size ); 00313 for( int i = 0; i < size; i++ ) 00314 std::cout << xyz[0][i] << " " << xyz[1][i] << " " << xyz[2][i] << "\n"; 00315 } 00316 00317 // project them on a sphere, and create another mesh with it? 00318 } 00319 std::cout << "success...\n"; 00320 00321 delete mb; 00322 } 00323 void test_spherical_quad() 00324 { 00325 // example from one coupler test, run like this 00326 // ./mbcoupler_test -meshes sphere_16p.h5m mpas_p8.h5m -itag vertex_field -meth 4 -outfile 00327 // dd.h5m method 4 is spherical 00328 double positions[] = { -0.88882388032987436, -0.069951956448441419, 0.45287838714646161, -0.88226455385461389, 00329 -0.13973697758043971, 0.4495362433757738, -0.84497006020160348, -0.13383011007602069, 00330 0.51779831884618843, -0.85072691325794214, -0.066953660115039074, 0.52132612293631853 }; 00331 CartVect x( -0.85408569769999998, -0.12391301439999999, 0.50515659540000002 ); 00332 std::vector< CartVect > vertices; 00333 for( int i = 0; i < 4; i++ ) 00334 vertices.push_back( CartVect( positions + 3 * i ) ); 00335 00336 moab::Element::SphericalQuad squad( vertices ); 00337 double tol( 0.0001 ); 00338 if( squad.inside_box( x, tol ) ) 00339 { 00340 CartVect nat_par = squad.ievaluate( x, 0.000001 ); 00341 std::cout << nat_par << "\n"; 00342 } 00343 std::cout << "success...\n"; 00344 } 00345 00346 void test_linear_tri() 00347 { 00348 double positions[] = { 0, 0, 0, 2, 0, 0, 0, 3, 0 }; 00349 CartVect x( 1, 0.5, 0 ); 00350 std::vector< CartVect > vertices; 00351 for( int i = 0; i < 3; i++ ) 00352 vertices.push_back( CartVect( positions + 3 * i ) ); 00353 00354 moab::Element::LinearTri tri( vertices ); 00355 double tol( 0.0001 ); 00356 if( tri.inside_box( x, tol ) ) 00357 { 00358 CartVect nat_par = tri.ievaluate( x ); 00359 std::cout << x << " :" << nat_par << "\n"; 00360 } 00361 00362 x = CartVect( 0, 2, 0 ); 00363 if( tri.inside_box( x, tol ) ) 00364 { 00365 CartVect nat_par = tri.ievaluate( x ); 00366 std::cout << x << " :" << nat_par << "\n"; 00367 } 00368 00369 x = CartVect( 1, 0, 0.5 ); 00370 if( tri.inside_box( x, tol ) ) 00371 { 00372 CartVect nat_par = tri.ievaluate( x ); 00373 std::cout << x << " :" << nat_par << "\n"; 00374 } 00375 00376 double positions2[] = { -0.866026, -0.500001, 0., 0.866026, -0.500001, 0., 0.000000, 100.000000, 0. }; 00377 x = CartVect( 0, 0, 0 ); 00378 std::vector< CartVect > vertices2; 00379 for( int i = 0; i < 3; i++ ) 00380 vertices2.push_back( CartVect( positions2 + 3 * i ) ); 00381 00382 moab::Element::LinearTri tri2( vertices2 ); 00383 00384 if( tri2.inside_box( x, tol ) ) 00385 { 00386 CartVect nat_par = tri2.ievaluate( x ); 00387 std::cout << x << " :" << nat_par << "\n"; 00388 } 00389 00390 std::cout << "vertices2 " << vertices2[0] << " " << vertices2[1] << " " << vertices2[2] << "\n"; 00391 00392 x = CartVect( -0.866026, -0.500001, 0. ); 00393 std::cout << x << " :" << tri2.ievaluate( x ) << "\n"; 00394 00395 x = CartVect( +0.866026, -0.500001, 0. ); 00396 std::cout << x << " :" << tri2.ievaluate( x ) << "\n"; 00397 x = CartVect( 0.000000, 100.000000, 0. ); 00398 std::cout << x << " :" << tri2.ievaluate( x ) << "\n"; 00399 00400 std::cout << "success...\n"; 00401 } 00402 00403 void test_spherical_tri() 00404 { 00405 // example from one coupler test, run like this 00406 // ./mbcoupler_test -meshes tri_fl_8p.h5m mpas_p8.h5m -itag vertex_field -meth 4 -outfile 00407 // oo.h5m -eps 1.e-9 method 4 is spherical 00408 double positions[] = { -0.86339258282987197, -0.17004443185241255, 0.47501383044112816, 00409 -0.80777478326268271, -0.15172299908552511, 0.5696314870803928, 00410 -0.8655618847392077, -0.061613422011313854, 0.49699739427361828 }; 00411 CartVect x( -0.85408569769999998, -0.12391301439999999, 0.50515659540000002 ); 00412 std::vector< CartVect > vertices; 00413 for( int i = 0; i < 3; i++ ) 00414 vertices.push_back( CartVect( positions + 3 * i ) ); 00415 00416 moab::Element::SphericalTri sphtri( vertices ); 00417 double tol( 0.000001 ); 00418 if( sphtri.inside_box( x, tol ) ) 00419 { 00420 CartVect nat_par = sphtri.ievaluate( x, 0.000001 ); 00421 std::cout << nat_par << "\n"; 00422 } 00423 std::cout << "success...\n"; 00424 }
