MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * This library is free software; you can redistribute it and/or 00003 * modify it under the terms of the GNU Lesser General Public 00004 * License as published by the Free Software Foundation; either 00005 * version 2.1 of the License, or (at your option) any later version. 00006 * 00007 */ 00008 /** 00009 * \file testgeom.cc 00010 * 00011 * \brief testgeom, a unit test for the ITAPS geometry interface 00012 * 00013 */ 00014 #include "FBiGeom.h" 00015 #include "FBiGeom_MOAB.hpp" 00016 #include "iMesh.h" 00017 #include <iostream> 00018 #include <set> 00019 #include <algorithm> 00020 #include <vector> 00021 #include <iterator> 00022 #include <algorithm> 00023 #include <iomanip> 00024 #include <cassert> 00025 #include <cstring> 00026 #include <cmath> 00027 #define CHECK( STR ) \ 00028 if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ ) 00029 00030 #define STRINGIFY( S ) XSTRINGIFY( S ) 00031 #define XSTRINGIFY( S ) #S 00032 00033 static bool print_error( const char* desc, int err, FBiGeom_Instance geom, const char* file, int line ) 00034 { 00035 char buffer[1024]; 00036 FBiGeom_getDescription( geom, buffer, sizeof( buffer ) ); 00037 buffer[sizeof( buffer ) - 1] = '\0'; 00038 00039 std::cerr << "ERROR: " << desc << std::endl 00040 << " Error code: " << err << std::endl 00041 << " Error desc: " << buffer << std::endl 00042 << " At : " << file << ':' << line << std::endl; 00043 00044 return false; // must always return false or CHECK macro will break 00045 } 00046 00047 typedef iBase_TagHandle TagHandle; 00048 typedef iBase_EntityHandle GentityHandle; 00049 typedef iBase_EntitySetHandle GentitysetHandle; 00050 00051 extern void FBiGeom_newGeomFromMesh( iMesh_Instance mesh, 00052 iBase_EntitySetHandle set, 00053 const char* options, 00054 FBiGeom_Instance* geom, 00055 int* err, 00056 int options_len ); 00057 // the second destructor 00058 extern void FBiGeom_dtor2( FBiGeom_Instance instance, int* err ); 00059 /* Frees allocated arrays for us */ 00060 template < typename T > 00061 class SimpleArray 00062 { 00063 private: 00064 T* arr; 00065 int arrSize; 00066 int arrAllocated; 00067 00068 public: 00069 SimpleArray() : arr( 0 ), arrSize( 0 ), arrAllocated( 0 ) {} 00070 SimpleArray( unsigned s ) : arrSize( s ), arrAllocated( s ) 00071 { 00072 arr = (T*)malloc( s * sizeof( T ) ); 00073 for( unsigned i = 0; i < s; ++i ) 00074 new( arr + i ) T(); 00075 } 00076 00077 ~SimpleArray() 00078 { 00079 for( int i = 0; i < size(); ++i ) 00080 arr[i].~T(); 00081 free( arr ); 00082 } 00083 00084 T** ptr() 00085 { 00086 return &arr; 00087 } 00088 int& size() 00089 { 00090 return arrSize; 00091 } 00092 int size() const 00093 { 00094 return arrSize; 00095 } 00096 int& capacity() 00097 { 00098 return arrAllocated; 00099 } 00100 int capacity() const 00101 { 00102 return arrAllocated; 00103 } 00104 00105 typedef T* iterator; 00106 typedef const T* const_iterator; 00107 iterator begin() 00108 { 00109 return arr; 00110 } 00111 const_iterator begin() const 00112 { 00113 return arr; 00114 } 00115 iterator end() 00116 { 00117 return arr + arrSize; 00118 } 00119 const_iterator end() const 00120 { 00121 return arr + arrSize; 00122 } 00123 00124 T& operator[]( unsigned idx ) 00125 { 00126 return arr[idx]; 00127 } 00128 T operator[]( unsigned idx ) const 00129 { 00130 return arr[idx]; 00131 } 00132 }; 00133 00134 #define ARRAY_INOUT( A ) A.ptr(), &( A ).capacity(), &( A ).size() 00135 #define ARRAY_IN( A ) &( A )[0], ( A ).size() 00136 00137 bool smooth_test( const std::string& filename, FBiGeom_Instance ); 00138 00139 bool tags_test( FBiGeom_Instance geom ); 00140 bool tag_get_set_test( FBiGeom_Instance geom ); 00141 bool tag_info_test( FBiGeom_Instance geom ); 00142 bool gentityset_test( FBiGeom_Instance geom, bool /*multiset*/, bool /*ordered*/ ); 00143 bool topology_adjacencies_test( FBiGeom_Instance geom ); 00144 bool geometry_evaluation_test( FBiGeom_Instance geom ); 00145 bool construct_test( FBiGeom_Instance geom ); 00146 bool primitives_test( FBiGeom_Instance geom ); 00147 bool transforms_test( FBiGeom_Instance geom ); 00148 bool booleans_test( FBiGeom_Instance geom ); 00149 bool shutdown_test2( FBiGeom_Instance geom, std::string& engine_opt ); 00150 bool save_entset_test( FBiGeom_Instance geom ); 00151 bool mesh_size_test( FBiGeom_Instance geom ); 00152 bool normals_test( FBiGeom_Instance geom ); 00153 00154 bool ray_test( FBiGeom_Instance geom ); 00155 00156 void handle_error_code( const bool result, int& number_failed, int& /*number_not_implemented*/, int& number_successful ) 00157 { 00158 if( result ) 00159 { 00160 std::cout << "Success"; 00161 number_successful++; 00162 } 00163 else 00164 { 00165 std::cout << "Failure"; 00166 number_failed++; 00167 } 00168 } 00169 00170 int main( int argc, char* argv[] ) 00171 { 00172 std::string filename = STRINGIFY( MESHDIR ) "/shell.h5m"; 00173 00174 if( argc == 1 ) 00175 { 00176 std::cout << "Using default input file: " << filename << std::endl; 00177 } 00178 else if( argc == 2 ) 00179 { 00180 filename = argv[1]; 00181 } 00182 else 00183 { 00184 std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl; 00185 return 1; 00186 } 00187 00188 int err; 00189 int number_tests = 0; 00190 int number_tests_successful = 0; 00191 int number_tests_not_implemented = 0; 00192 int number_tests_failed = 0; 00193 00194 // initialize the FBiGeom, in a different way 00195 iMesh_Instance mesh = NULL; 00196 FBiGeom_Instance geom; 00197 iMesh_newMesh( NULL, &mesh, &err, 0 ); 00198 if( err != iBase_SUCCESS ) 00199 std::cerr << " Error code: " << err << " At : " << __FILE__ << ':' << __LINE__ << std::endl; 00200 00201 iBase_EntitySetHandle root_set; 00202 iMesh_createEntSet( mesh, 0, &root_set, &err ); 00203 if( err != iBase_SUCCESS ) 00204 std::cerr << " Error code: " << err << " failed to create a model set" 00205 << " At : " << __FILE__ << ':' << __LINE__ << std::endl; 00206 00207 iMesh_load( mesh, root_set, filename.c_str(), NULL, &err, filename.length(), 0 ); 00208 if( err != iBase_SUCCESS ) 00209 std::cerr << " Error code: " << err << " failed load the file" 00210 << " At : " << __FILE__ << ':' << __LINE__ << std::endl; 00211 00212 std::string opts( "SMOOTH;" ); 00213 // new constructor 00214 FBiGeom_newGeomFromMesh( mesh, root_set, opts.c_str(), &geom, &err, opts.length() ); 00215 00216 CHECK( "Interface initialization didn't work properly." ); 00217 00218 // Print out Header information 00219 std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n"; 00220 // gLoad test 00221 00222 bool result; 00223 std::cout << " Smooth faceting load and initialization: \n"; 00224 result = smooth_test( filename, geom ); 00225 handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful ); 00226 00227 number_tests++; 00228 std::cout << "\n"; 00229 00230 // tags test 00231 std::cout << " tags: "; 00232 result = tags_test( geom ); 00233 handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful ); 00234 number_tests++; 00235 std::cout << "\n"; 00236 /* 00237 // gentitysets test 00238 std::cout << " gentity sets: "; 00239 result = gentityset_test(geom, false, false); 00240 handle_error_code(result, number_tests_failed, 00241 number_tests_not_implemented, 00242 number_tests_successful); 00243 number_tests++; 00244 std::cout << "\n"; 00245 */ 00246 // topology adjacencies test 00247 std::cout << " topology adjacencies: "; 00248 result = topology_adjacencies_test( geom ); 00249 handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful ); 00250 number_tests++; 00251 std::cout << "\n"; 00252 00253 // geometry evaluation test 00254 std::cout << " geometry evaluation: \n"; 00255 result = geometry_evaluation_test( geom ); 00256 handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful ); 00257 number_tests++; 00258 std::cout << "\n"; 00259 00260 // normals evaluation test 00261 std::cout << " normals geometry evaluation: \n"; 00262 result = normals_test( geom ); 00263 handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful ); 00264 number_tests++; 00265 std::cout << "\n"; 00266 00267 // ray tracing test 00268 std::cout << " ray intersection test: \n"; 00269 result = ray_test( geom ); 00270 handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful ); 00271 number_tests++; 00272 std::cout << "\n"; 00273 /* 00274 // construct test 00275 std::cout << " construct: "; 00276 result = construct_test(geom); 00277 handle_error_code(result, number_tests_failed, 00278 number_tests_not_implemented, 00279 number_tests_successful); 00280 number_tests++; 00281 std::cout << "\n"; 00282 00283 // primitives test 00284 std::cout << " primitives: "; 00285 result = primitives_test(geom); 00286 handle_error_code(result, number_tests_failed, 00287 number_tests_not_implemented, 00288 number_tests_successful); 00289 number_tests++; 00290 std::cout << "\n"; 00291 00292 // transforms test 00293 std::cout << " transforms: "; 00294 result = transforms_test(geom); 00295 handle_error_code(result, number_tests_failed, 00296 number_tests_not_implemented, 00297 number_tests_successful); 00298 number_tests++; 00299 std::cout << "\n"; 00300 00301 // booleans test 00302 std::cout << " booleans: "; 00303 result = booleans_test(geom); 00304 handle_error_code(result, number_tests_failed, 00305 number_tests_not_implemented, 00306 number_tests_successful); 00307 number_tests++; 00308 std::cout << "\n"; 00309 00310 #if defined(HAVE_ACIS) && !defined(FORCE_OCC) 00311 std::cout << " mesh size: "; 00312 result = mesh_size_test(geom); 00313 handle_error_code(result, number_tests_failed, 00314 number_tests_not_implemented, 00315 number_tests_successful); 00316 number_tests++; 00317 std::cout << "\n"; 00318 00319 // save entset test 00320 std::cout << " save entset: "; 00321 result = save_entset_test(geom); 00322 handle_error_code(result, number_tests_failed, 00323 number_tests_not_implemented, 00324 number_tests_successful); 00325 number_tests++; 00326 std::cout << "\n"; 00327 #endif 00328 */ 00329 // shutdown test 00330 std::cout << " shutdown: "; 00331 std::string engine_opt; 00332 result = shutdown_test2( geom, engine_opt ); 00333 handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful ); 00334 number_tests++; 00335 std::cout << "\n"; 00336 00337 // shutdown imesh instance too 00338 iMesh_dtor( mesh, &err ); 00339 CHECK( "shutdown imesh error" ); 00340 // summary 00341 00342 std::cout << "\nTSTT TEST SUMMARY: \n" 00343 << " Number Tests: " << number_tests << "\n" 00344 << " Number Successful: " << number_tests_successful << "\n" 00345 << " Number Not Implemented: " << number_tests_not_implemented << "\n" 00346 << " Number Failed: " << number_tests_failed << "\n\n" 00347 << std::endl; 00348 00349 return number_tests_failed; 00350 } 00351 00352 /*! 00353 @test 00354 Load Mesh 00355 @li Load a mesh file 00356 */ 00357 00358 bool smooth_test( const std::string& filename, FBiGeom_Instance geom ) 00359 { 00360 int err; 00361 char opts[] = "SMOOTH;"; 00362 FBiGeom_load( geom, &filename[0], opts, &err, filename.length(), 8 ); 00363 // FBiGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 ); 00364 CHECK( "ERROR : can not load a geometry" ); 00365 00366 iBase_EntitySetHandle root_set; 00367 FBiGeom_getRootSet( geom, &root_set, &err ); 00368 CHECK( "ERROR : getRootSet failed!" ); 00369 00370 // print out the number of entities 00371 std::cout << "Model contents: " << std::endl; 00372 const char* gtype[] = { "vertices: ", "edges: ", "faces: ", "regions: " }; 00373 for( int i = 0; i <= 3; ++i ) 00374 { 00375 int count; 00376 FBiGeom_getNumOfType( geom, root_set, i, &count, &err ); 00377 CHECK( "Error: problem getting entities after gLoad." ); 00378 std::cout << gtype[i] << count << std::endl; 00379 } 00380 00381 return true; 00382 } 00383 /*! 00384 @test 00385 Test tag creating, reading, writing, deleting 00386 @li Load a mesh file 00387 */ 00388 bool tags_test( FBiGeom_Instance geom ) 00389 { 00390 bool success = tag_info_test( geom ); 00391 if( !success ) return success; 00392 00393 success = tag_get_set_test( geom ); 00394 if( !success ) return success; 00395 00396 return true; 00397 } 00398 00399 bool tag_info_test( FBiGeom_Instance geom ) 00400 { 00401 int err; 00402 00403 iBase_EntitySetHandle root_set; 00404 FBiGeom_getRootSet( geom, &root_set, &err ); 00405 CHECK( "ERROR : getRootSet failed!" ); 00406 00407 // create an arbitrary tag, size 4 00408 iBase_TagHandle this_tag, tmp_handle; 00409 std::string tag_name( "tag_info tag" ), tmp_name; 00410 FBiGeom_createTag( geom, &tag_name[0], 4, iBase_BYTES, &this_tag, &err, tag_name.length() ); 00411 CHECK( "ERROR : can not create a tag." ); 00412 00413 // get information on the tag 00414 00415 char name_buffer[256]; 00416 FBiGeom_getTagName( geom, this_tag, name_buffer, &err, sizeof( name_buffer ) ); 00417 CHECK( "ERROR : Couldn't get tag name." ); 00418 if( tag_name != name_buffer ) 00419 { 00420 std::cerr << "ERROR: getTagName returned '" << name_buffer << "' for tag created as '" << tag_name << "'" 00421 << std::endl; 00422 return false; 00423 } 00424 00425 FBiGeom_getTagHandle( geom, &tag_name[0], &tmp_handle, &err, tag_name.length() ); 00426 CHECK( "ERROR : Couldn't get tag handle." ); 00427 if( tmp_handle != this_tag ) 00428 { 00429 std::cerr << "ERROR: getTagHandle didn't return consistent result." << std::endl; 00430 return false; 00431 } 00432 00433 int tag_size; 00434 FBiGeom_getTagSizeBytes( geom, this_tag, &tag_size, &err ); 00435 CHECK( "ERROR : Couldn't get tag size." ); 00436 if( tag_size != 4 ) 00437 { 00438 std::cerr << "ERROR: getTagSizeBytes: expected 4, got " << tag_size << std::endl; 00439 return false; 00440 } 00441 00442 FBiGeom_getTagSizeValues( geom, this_tag, &tag_size, &err ); 00443 CHECK( "ERROR : Couldn't get tag size." ); 00444 if( tag_size != 4 ) 00445 { 00446 std::cerr << "ERROR: getTagSizeValues: expected 4, got " << tag_size << std::endl; 00447 return false; 00448 } 00449 00450 int tag_type; 00451 FBiGeom_getTagType( geom, this_tag, &tag_type, &err ); 00452 CHECK( "ERROR : Couldn't get tag type." ); 00453 if( tag_type != iBase_BYTES ) 00454 { 00455 std::cerr << "ERROR: getTagType: expected " << iBase_BYTES << ", got " << tag_type << std::endl; 00456 return false; 00457 } 00458 00459 FBiGeom_destroyTag( geom, this_tag, true, &err ); 00460 CHECK( "ERROR : Couldn't delete a tag." ); 00461 00462 // print information about all the tags in the model 00463 00464 std::set< iBase_TagHandle > tags; 00465 SimpleArray< iBase_EntityHandle > entities; 00466 FBiGeom_getEntities( geom, root_set, iBase_ALL_TYPES, ARRAY_INOUT( entities ), &err ); 00467 CHECK( "getEntities( ..., iBase_ALL_TYPES, ... ) failed." ); 00468 for( int i = 0; i < entities.size(); ++i ) 00469 { 00470 SimpleArray< iBase_TagHandle > tag_arr; 00471 FBiGeom_getAllTags( geom, entities[i], ARRAY_INOUT( tag_arr ), &err ); 00472 CHECK( "getAllTags failed." ); 00473 std::copy( tag_arr.begin(), tag_arr.end(), std::inserter( tags, tags.begin() ) ); 00474 } 00475 00476 std::cout << "Tags defined on model: "; 00477 bool first = true; 00478 for( std::set< iBase_TagHandle >::iterator sit = tags.begin(); sit != tags.end(); ++sit ) 00479 { 00480 FBiGeom_getTagName( geom, *sit, name_buffer, &err, sizeof( name_buffer ) ); 00481 name_buffer[sizeof( name_buffer ) - 1] = '\0'; // mnake sure of NUL termination 00482 CHECK( "getTagName failed." ); 00483 00484 if( !first ) std::cout << ", "; 00485 std::cout << name_buffer; 00486 first = false; 00487 } 00488 if( first ) std::cout << "<none>"; 00489 std::cout << std::endl; 00490 00491 return true; 00492 } 00493 00494 bool tag_get_set_test( FBiGeom_Instance geom ) 00495 { 00496 int err; 00497 00498 // create an arbitrary tag, size 4 00499 iBase_TagHandle this_tag; 00500 std::string tag_name( "tag_get_set tag" ); 00501 FBiGeom_createTag( geom, &tag_name[0], sizeof( int ), iBase_BYTES, &this_tag, &err, tag_name.length() ); 00502 CHECK( "ERROR : can not create a tag for get_set test." ); 00503 00504 iBase_EntitySetHandle root_set; 00505 FBiGeom_getRootSet( geom, &root_set, &err ); 00506 CHECK( "ERROR : getRootSet failed!" ); 00507 00508 // set this tag to an integer on each entity; keep track of total sum 00509 int sum = 0, num = 0, dim; 00510 for( dim = 0; dim <= 3; dim++ ) 00511 { 00512 SimpleArray< iBase_EntityHandle > gentity_handles; 00513 FBiGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err ); 00514 int num_ents = gentity_handles.size(); 00515 std::vector< int > tag_vals( num_ents ); 00516 for( int i = 0; i < num_ents; ++i ) 00517 { 00518 tag_vals[i] = num; 00519 sum += num; 00520 ++num; 00521 } 00522 00523 FBiGeom_setArrData( geom, ARRAY_IN( gentity_handles ), this_tag, (char*)&tag_vals[0], 00524 tag_vals.size() * sizeof( int ), &err ); 00525 CHECK( "ERROR : can't set tag on entities" ); 00526 } 00527 00528 // check tag values for entities now 00529 int get_sum = 0; 00530 for( dim = 0; dim <= 3; dim++ ) 00531 { 00532 SimpleArray< iBase_EntityHandle > gentity_handles; 00533 FBiGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err ); 00534 int num_ents = gentity_handles.size(); 00535 00536 SimpleArray< char > tag_vals; 00537 FBiGeom_getArrData( geom, ARRAY_IN( gentity_handles ), this_tag, (void**)tag_vals.ptr(), &tag_vals.capacity(), 00538 &tag_vals.size(), &err ); 00539 CHECK( "ERROR : can't get tag on entities" ); 00540 00541 int* tag_ptr = (int*)( &tag_vals[0] ); 00542 for( int i = 0; i < num_ents; ++i ) 00543 get_sum += tag_ptr[i]; 00544 } 00545 00546 if( get_sum != sum ) 00547 { 00548 std::cerr << "ERROR: getData didn't return consistent results." << std::endl; 00549 return false; 00550 } 00551 00552 FBiGeom_destroyTag( geom, this_tag, true, &err ); 00553 CHECK( "ERROR : couldn't delete tag." ); 00554 00555 return true; 00556 } 00557 00558 /*! 00559 @test 00560 TSTT gentity sets test (just implemented parts for now) 00561 @li Check gentity sets 00562 */ 00563 bool gentityset_test( FBiGeom_Instance geom, bool /*multiset*/, bool /*ordered*/ ) 00564 { 00565 int num_type = 4; 00566 iBase_EntitySetHandle ges_array[4]; 00567 int number_array[4]; 00568 // int num_all_gentities_super = 0; 00569 int ent_type = iBase_VERTEX; 00570 00571 int err; 00572 iBase_EntitySetHandle root_set; 00573 FBiGeom_getRootSet( geom, &root_set, &err ); 00574 CHECK( "ERROR : getRootSet failed!" ); 00575 00576 // get the number of sets in the whole model 00577 int all_sets = 0; 00578 FBiGeom_getNumEntSets( geom, root_set, 0, &all_sets, &err ); 00579 CHECK( "Problem getting the number of all gentity sets in whole model." ); 00580 00581 // add gentities to entitysets by type 00582 for( ; ent_type < num_type; ent_type++ ) 00583 { 00584 // initialize the entityset 00585 FBiGeom_createEntSet( geom, true, &ges_array[ent_type], &err ); 00586 CHECK( "Problem creating entityset." ); 00587 00588 // get entities by type in total "mesh" 00589 SimpleArray< iBase_EntityHandle > gentities; 00590 FBiGeom_getEntities( geom, root_set, ent_type, ARRAY_INOUT( gentities ), &err ); 00591 CHECK( "Failed to get gentities by type in gentityset_test." ); 00592 00593 // add gentities into gentity set 00594 FBiGeom_addEntArrToSet( geom, ARRAY_IN( gentities ), ges_array[ent_type], &err ); 00595 CHECK( "Failed to add gentities in entityset_test." ); 00596 00597 // Check to make sure entity set really has correct number of entities in it 00598 FBiGeom_getNumOfType( geom, ges_array[ent_type], ent_type, &number_array[ent_type], &err ); 00599 CHECK( "Failed to get number of gentities by type in entityset_test." ); 00600 00601 // compare the number of entities by type 00602 int num_type_gentity = gentities.size(); 00603 00604 if( number_array[ent_type] != num_type_gentity ) 00605 { 00606 std::cerr << "Number of gentities by type is not correct" << std::endl; 00607 return false; 00608 } 00609 00610 // add to number of all entities in super set 00611 // num_all_gentities_super += num_type_gentity; 00612 } 00613 00614 // make a super set having all entitysets 00615 iBase_EntitySetHandle super_set; 00616 FBiGeom_createEntSet( geom, true, &super_set, &err ); 00617 CHECK( "Failed to create a super set in gentityset_test." ); 00618 00619 for( int i = 0; i < num_type; i++ ) 00620 { 00621 FBiGeom_addEntSet( geom, ges_array[i], super_set, &err ); 00622 CHECK( "Failed to create a super set in gentityset_test." ); 00623 } 00624 00625 //----------TEST BOOLEAN OPERATIONS----------------// 00626 00627 iBase_EntitySetHandle temp_ges1; 00628 FBiGeom_createEntSet( geom, true, &temp_ges1, &err ); 00629 CHECK( "Failed to create a super set in gentityset_test." ); 00630 00631 // Subtract 00632 // add all EDGEs and FACEs to temp_es1 00633 // get all EDGE entities 00634 SimpleArray< iBase_EntityHandle > gedges, gfaces, temp_gentities1; 00635 FBiGeom_getEntities( geom, ges_array[iBase_EDGE], iBase_EDGE, ARRAY_INOUT( gedges ), &err ); 00636 CHECK( "Failed to get gedge gentities in gentityset_test." ); 00637 00638 // add EDGEs to ges1 00639 FBiGeom_addEntArrToSet( geom, ARRAY_IN( gedges ), temp_ges1, &err ); 00640 CHECK( "Failed to add gedge gentities in gentityset_test." ); 00641 00642 // get all FACE gentities 00643 FBiGeom_getEntities( geom, ges_array[iBase_FACE], iBase_FACE, ARRAY_INOUT( gfaces ), &err ); 00644 CHECK( "Failed to get gface gentities in gentityset_test." ); 00645 00646 // add FACEs to es1 00647 FBiGeom_addEntArrToSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err ); 00648 CHECK( "Failed to add gface gentities in gentityset_test." ); 00649 00650 // subtract EDGEs 00651 FBiGeom_subtract( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err ); 00652 CHECK( "Failed to subtract gentitysets in gentityset_test." ); 00653 00654 FBiGeom_getEntities( geom, temp_ges1, iBase_FACE, ARRAY_INOUT( temp_gentities1 ), &err ); 00655 CHECK( "Failed to get gface gentities in gentityset_test." ); 00656 00657 if( gfaces.size() != temp_gentities1.size() ) 00658 { 00659 std::cerr << "Number of entitysets after subtraction not correct \ 00660 in gentityset_test." 00661 << std::endl; 00662 return false; 00663 } 00664 00665 // check there's nothing but gfaces in temp_ges1 00666 int num_gents; 00667 FBiGeom_getNumOfType( geom, temp_ges1, iBase_EDGE, &num_gents, &err ); 00668 CHECK( "Failed to get dimensions of gentities in gentityset_test." ); 00669 if( 0 != num_gents ) 00670 { 00671 std::cerr << "Subtraction failed to remove all edges" << std::endl; 00672 return false; 00673 } 00674 00675 //------------Intersect------------ 00676 // 00677 00678 // clean out the temp_ges1 00679 FBiGeom_rmvEntArrFromSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err ); 00680 CHECK( "Failed to remove gface gentities in gentityset_test." ); 00681 00682 // check if it is really cleaned out 00683 FBiGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err ); 00684 CHECK( "Failed to get number of gentities by type in gentityset_test." ); 00685 00686 if( num_gents != 0 ) 00687 { 00688 std::cerr << "failed to remove correctly." << std::endl; 00689 return false; 00690 } 00691 00692 // add EDGEs to temp ges1 00693 FBiGeom_addEntArrToSet( geom, ARRAY_IN( gedges ), temp_ges1, &err ); 00694 CHECK( "Failed to add gedge gentities in gentityset_test." ); 00695 00696 // add FACEs to temp ges1 00697 FBiGeom_addEntArrToSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err ); 00698 CHECK( "Failed to add gface gentities in gentityset_test." ); 00699 00700 // intersect temp_ges1 with gedges set 00701 // temp_ges1 entityset is altered 00702 FBiGeom_intersect( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err ); 00703 CHECK( "Failed to intersect in gentityset_test." ); 00704 00705 // try to get FACEs, but there should be nothing but EDGE 00706 FBiGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err ); 00707 CHECK( "Failed to get gface gentities in gentityset_test." ); 00708 00709 if( num_gents != 0 ) 00710 { 00711 std::cerr << "wrong number of gfaces." << std::endl; 00712 return false; 00713 } 00714 00715 //-------------Unite-------------- 00716 00717 // get all regions 00718 iBase_EntitySetHandle temp_ges2; 00719 SimpleArray< iBase_EntityHandle > gregions; 00720 00721 FBiGeom_createEntSet( geom, true, &temp_ges2, &err ); 00722 CHECK( "Failed to create a temp gentityset in gentityset_test." ); 00723 00724 FBiGeom_getEntities( geom, ges_array[iBase_REGION], iBase_REGION, ARRAY_INOUT( gregions ), &err ); 00725 CHECK( "Failed to get gregion gentities in gentityset_test." ); 00726 00727 // add REGIONs to temp es2 00728 FBiGeom_addEntArrToSet( geom, ARRAY_IN( gregions ), temp_ges2, &err ); 00729 CHECK( "Failed to add gregion gentities in gentityset_test." ); 00730 00731 // unite temp_ges1 and temp_ges2 00732 // temp_ges1 gentityset is altered 00733 FBiGeom_unite( geom, temp_ges1, temp_ges2, &temp_ges1, &err ); 00734 CHECK( "Failed to unite in gentityset_test." ); 00735 00736 // perform the check 00737 FBiGeom_getNumOfType( geom, temp_ges1, iBase_REGION, &num_gents, &err ); 00738 CHECK( "Failed to get number of gregion gentities by type in gentityset_test." ); 00739 00740 if( num_gents != number_array[iBase_REGION] ) 00741 { 00742 std::cerr << "different number of gregions in gentityset_test." << std::endl; 00743 return false; 00744 } 00745 00746 //--------Test parent/child stuff in entiysets----------- 00747 00748 // Add 2 sets as children to another 00749 iBase_EntitySetHandle parent_child; 00750 FBiGeom_createEntSet( geom, true, &parent_child, &err ); 00751 CHECK( "Problem creating gentityset in gentityset_test." ); 00752 00753 FBiGeom_addPrntChld( geom, ges_array[iBase_VERTEX], parent_child, &err ); 00754 CHECK( "Problem add parent in gentityset_test." ); 00755 00756 // check if parent is really added 00757 SimpleArray< iBase_EntitySetHandle > parents; 00758 FBiGeom_getPrnts( geom, parent_child, 1, ARRAY_INOUT( parents ), &err ); 00759 CHECK( "Problem getting parents in gentityset_test." ); 00760 00761 if( parents.size() != 1 ) 00762 { 00763 std::cerr << "number of parents is not correct in gentityset_test." << std::endl; 00764 return false; 00765 } 00766 00767 // add parent and child 00768 // sidl::array<void*> parent_child_array = sidl::array<void*>::create1d(1); 00769 // int num_parent_child_array; 00770 // sidl::array<void*> temp_gedge_array = sidl::array<void*>::create1d(1); 00771 // int num_temp_gedge_array; 00772 // parent_child_array.set(0, parent_child); 00773 // temp_gedge_array.set(0, ges_array[TSTTG::EntityType_EDGE]); 00774 FBiGeom_addPrntChld( geom, ges_array[iBase_EDGE], parent_child, &err ); 00775 CHECK( "Problem adding parent and child in gentityset_test." ); 00776 00777 // sidl::array<void*> temp_gface_array = sidl::array<void*>::create1d(1); 00778 // int num_temp_gface_array; 00779 // temp_gface_array.set(0, ges_array[TSTTG::EntityType_FACE]); 00780 FBiGeom_addPrntChld( geom, parent_child, ges_array[iBase_FACE], &err ); 00781 CHECK( "Problem adding parent and child in gentityset_test." ); 00782 00783 // add child 00784 FBiGeom_addPrntChld( geom, parent_child, ges_array[iBase_REGION], &err ); 00785 CHECK( "Problem adding child in gentityset_test." ); 00786 00787 // get the number of parent gentitysets 00788 num_gents = -1; 00789 FBiGeom_getNumPrnt( geom, parent_child, 1, &num_gents, &err ); 00790 CHECK( "Problem getting number of parents in gentityset_test." ); 00791 00792 if( num_gents != 2 ) 00793 { 00794 std::cerr << "number of parents is not correct in gentityset_test." << std::endl; 00795 return false; 00796 } 00797 00798 // get the number of child gentitysets 00799 num_gents = -1; 00800 FBiGeom_getNumChld( geom, parent_child, 1, &num_gents, &err ); 00801 CHECK( "Problem getting number of children in gentityset_test." ); 00802 00803 if( num_gents != 2 ) 00804 { 00805 std::cerr << "number of children is not correct in gentityset_test." << std::endl; 00806 return false; 00807 } 00808 00809 SimpleArray< iBase_EntitySetHandle > children; 00810 FBiGeom_getChldn( geom, parent_child, 1, ARRAY_INOUT( children ), &err ); 00811 CHECK( "Problem getting children in gentityset_test." ); 00812 00813 if( children.size() != 2 ) 00814 { 00815 std::cerr << "number of children is not correct in gentityset_test." << std::endl; 00816 return false; 00817 } 00818 00819 // remove children 00820 FBiGeom_rmvPrntChld( geom, parent_child, ges_array[iBase_FACE], &err ); 00821 CHECK( "Problem removing parent child in gentityset_test." ); 00822 00823 // get the number of child gentitysets 00824 FBiGeom_getNumChld( geom, parent_child, 1, &num_gents, &err ); 00825 CHECK( "Problem getting number of children in gentityset_test." ); 00826 00827 if( num_gents != 1 ) 00828 { 00829 std::cerr << "number of children is not correct in gentityset_test." << std::endl; 00830 return false; 00831 } 00832 00833 // parent_child and ges_array[TSTTG::EntityType_EDGE] should be related 00834 int result = 0; 00835 FBiGeom_isChildOf( geom, ges_array[iBase_EDGE], parent_child, &result, &err ); 00836 CHECK( "Problem checking relation in gentityset_test." ); 00837 if( !result ) 00838 { 00839 std::cerr << "parent_child and ges_array[TSTTG::EntityType_EDGE] should be related" << std::endl; 00840 return false; 00841 } 00842 00843 // ges_array[TSTTG::EntityType_FACE] and ges_array[TSTTG::REGION] are not related 00844 result = 2; 00845 FBiGeom_isChildOf( geom, ges_array[iBase_FACE], ges_array[iBase_REGION], &result, &err ); 00846 if( result ) 00847 { 00848 std::cerr << "ges_array[TSTTG::REGION] and ges_array[TSTTG::EntityType_FACE] should not be " 00849 "related" 00850 << std::endl; 00851 return false; 00852 } 00853 00854 //--------test modify and query functions----------------------------- 00855 00856 // check the number of gentity sets in whole mesh 00857 SimpleArray< iBase_EntitySetHandle > gentity_sets; 00858 FBiGeom_getEntSets( geom, root_set, 1, ARRAY_INOUT( gentity_sets ), &err ); 00859 CHECK( "Problem to get all gentity sets in mesh." ); 00860 00861 if( gentity_sets.size() != all_sets + 8 ) 00862 { 00863 std::cerr << "the number of gentity sets in whole mesh should be 8 times of num_iter." << std::endl; 00864 return false; 00865 } 00866 00867 // get all gentity sets in super set 00868 SimpleArray< iBase_EntitySetHandle > ges_array1; 00869 FBiGeom_getEntSets( geom, super_set, 1, ARRAY_INOUT( ges_array1 ), &err ); 00870 CHECK( "Problem to get gentity sets in super set." ); 00871 00872 // get the number of gentity sets in super set 00873 int num_super; 00874 FBiGeom_getNumEntSets( geom, super_set, 1, &num_super, &err ); 00875 CHECK( "Problem to get the number of all gentity sets in super set." ); 00876 00877 // the number of gentity sets in super set should be same 00878 if( num_super != ges_array1.size() ) 00879 { 00880 std::cerr << "the number of gentity sets in super set should be same." << std::endl; 00881 return false; 00882 } 00883 00884 // get all entities in super set 00885 SimpleArray< iBase_EntitySetHandle > all_gentities; 00886 FBiGeom_getEntSets( geom, super_set, 1, ARRAY_INOUT( all_gentities ), &err ); 00887 CHECK( "Problem to get all gentities in super set." ); 00888 00889 // compare the number of all gentities in super set 00890 // HJK : num_hops is not implemented 00891 // if (num_all_gentities_super != ARRAY_SIZE(all_gentities)) { 00892 // std::cerr << "number of all gentities in super set should be same." << std::endl; 00893 // success = false; 00894 //} 00895 00896 // test add, remove and get all entitiy sets using super set 00897 // check GetAllGentitysets works recursively and dosen't return 00898 // multi sets 00899 for( int k = 0; k < num_super; k++ ) 00900 { 00901 // add gentity sets of super set to each gentity set of super set 00902 // make multiple child super sets 00903 iBase_EntitySetHandle ges_k = ges_array1[k]; 00904 00905 for( int a = 0; a < ges_array1.size(); a++ ) 00906 { 00907 FBiGeom_addEntSet( geom, ges_array1[a], ges_k, &err ); 00908 CHECK( "Problem to add entity set." ); 00909 } 00910 00911 // add super set to each entity set 00912 // sidl::array<GentitysetHandle> superset_array 00913 //= sidl::array<GentitysetHandle>::create1d(1); 00914 // superset_array.set(0, super_set); 00915 // int num_superset_array; 00916 00917 FBiGeom_addEntSet( geom, super_set, ges_k, &err ); 00918 CHECK( "Problem to add super set to gentitysets." ); 00919 00920 // add one gentity sets multiple times 00921 // HJK: ??? how to deal this case? 00922 // sidl::array<GentitysetHandle> temp_array1 00923 //= sidl::array<GentitysetHandle>::create1d(1); 00924 // int num_temp_array1; 00925 // temp_array1.set(0, temp_ges1); 00926 00927 // for (int l = 0; l < 3; l++) { 00928 FBiGeom_addEntSet( geom, temp_ges1, ges_k, &err ); 00929 CHECK( "Problem to add temp set to gentitysets." ); 00930 //} 00931 } 00932 00933 return true; 00934 } 00935 00936 /*! 00937 @test 00938 TSTTG topology adjacencies Test 00939 @li Check topology information 00940 @li Check adjacency 00941 */ 00942 // make each topological entity vectors, check their topology 00943 // types, get interior and exterior faces of model 00944 bool topology_adjacencies_test( FBiGeom_Instance geom ) 00945 { 00946 int i, err; 00947 iBase_EntitySetHandle root_set; 00948 FBiGeom_getRootSet( geom, &root_set, &err ); 00949 CHECK( "ERROR : getRootSet failed!" ); 00950 00951 int top = iBase_VERTEX; 00952 int num_test_top = iBase_ALL_TYPES; 00953 std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top ); 00954 00955 // fill the vectors of each topology entities 00956 // like lines vector, polygon vector, triangle vector, 00957 // quadrilateral, polyhedrron, tet, hex, prism, pyramid, 00958 // septahedron vectors 00959 for( i = top; i < num_test_top; i++ ) 00960 { 00961 SimpleArray< iBase_EntityHandle > gentities; 00962 FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err ); 00963 CHECK( "Failed to get gentities in adjacencies_test." ); 00964 00965 gentity_vectors[i].resize( gentities.size() ); 00966 std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); 00967 } 00968 00969 // check number of entities for each topology 00970 for( i = top; i < num_test_top; i++ ) 00971 { 00972 int num_tops = 0; 00973 FBiGeom_getNumOfType( geom, root_set, i, &num_tops, &err ); 00974 CHECK( "Failed to get number of gentities in adjacencies_test." ); 00975 00976 if( static_cast< int >( gentity_vectors[i].size() ) != num_tops ) 00977 { 00978 std::cerr << "Number of gentities doesn't agree with number returned for dimension " << i << std::endl; 00979 return false; 00980 } 00981 } 00982 00983 // check adjacencies in both directions 00984 std::vector< iBase_EntityHandle >::iterator vit; 00985 for( i = iBase_REGION; i >= iBase_VERTEX; i-- ) 00986 { 00987 for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) 00988 { 00989 iBase_EntityHandle this_gent = *vit; 00990 00991 // check downward adjacencies 00992 for( int j = iBase_VERTEX; j < i; j++ ) 00993 { 00994 00995 SimpleArray< iBase_EntityHandle > lower_ents; 00996 FBiGeom_getEntAdj( geom, this_gent, j, ARRAY_INOUT( lower_ents ), &err ); 00997 CHECK( "Bi-directional adjacencies test failed." ); 00998 00999 // for each of them, make sure they are adjacent to the upward ones 01000 int num_lower = lower_ents.size(); 01001 for( int k = 0; k < num_lower; k++ ) 01002 { 01003 SimpleArray< iBase_EntityHandle > upper_ents; 01004 FBiGeom_getEntAdj( geom, lower_ents[k], i, ARRAY_INOUT( upper_ents ), &err ); 01005 CHECK( "Bi-directional adjacencies test failed." ); 01006 if( std::find( upper_ents.begin(), upper_ents.end(), this_gent ) == upper_ents.end() ) 01007 { 01008 std::cerr << "Didn't find lower-upper adjacency which was supposed to be " 01009 "there, dims = " 01010 << i << ", " << j << std::endl; 01011 return false; 01012 } 01013 } 01014 } 01015 } 01016 } 01017 01018 return true; 01019 } 01020 01021 /*! 01022 @test 01023 FBiGeom_MOAB topology adjacencies Test 01024 @li Check topology information 01025 @li Check adjacency 01026 */ 01027 // make each topological entity vectors, check their topology 01028 // types, get interior and exterior faces of model 01029 bool geometry_evaluation_test( FBiGeom_Instance geom ) 01030 { 01031 int i, err; 01032 iBase_EntitySetHandle root_set; 01033 FBiGeom_getRootSet( geom, &root_set, &err ); 01034 CHECK( "ERROR : getRootSet failed!" ); 01035 01036 int top = iBase_VERTEX; 01037 int num_test_top = iBase_ALL_TYPES; 01038 std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top ); 01039 01040 // fill the vectors of each topology entities 01041 // like lines vector, polygon vector, triangle vector, 01042 // quadrilateral, polyhedrron, tet, hex, prism, pyramid, 01043 // septahedron vectors 01044 for( i = top; i < num_test_top; i++ ) 01045 { 01046 SimpleArray< iBase_EntityHandle > gentities; 01047 FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err ); 01048 CHECK( "Failed to get gentities in adjacencies_test." ); 01049 01050 gentity_vectors[i].resize( gentities.size() ); 01051 std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); 01052 } 01053 01054 // check adjacencies in both directions 01055 double min[3], max[3], on[3]; 01056 double near[3] = { .0, .0, .0 }; 01057 std::vector< iBase_EntityHandle >::iterator vit; 01058 for( i = iBase_REGION; i >= iBase_VERTEX; i-- ) 01059 { 01060 if( i != iBase_EDGE ) 01061 { 01062 for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) 01063 { 01064 iBase_EntityHandle this_gent = *vit; 01065 FBiGeom_getEntBoundBox( geom, this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err ); 01066 CHECK( "Failed to get bounding box of entity." ); 01067 01068 for( int j = 0; j < 3; j++ ) 01069 near[j] = ( min[j] + max[j] ) / 2; 01070 FBiGeom_getEntClosestPt( geom, this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2], &err ); 01071 CHECK( "Failed to get closest point on entity." ); 01072 std::cout << " entity of type " << i << " closest point to \n " << near[0] << " " << near[1] << " " 01073 << near[2] << "\n is " << on[0] << " " << on[1] << " " << on[2] << "\n"; 01074 } 01075 } 01076 } 01077 01078 return true; 01079 } 01080 // 01081 // test normals evaluations on the surface only 01082 bool normals_test( FBiGeom_Instance geom ) 01083 { 01084 int i, err; 01085 iBase_EntitySetHandle root_set; 01086 FBiGeom_getRootSet( geom, &root_set, &err ); 01087 CHECK( "ERROR : getRootSet failed!" ); 01088 01089 int top = iBase_VERTEX; 01090 int num_test_top = iBase_ALL_TYPES; 01091 std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top ); 01092 01093 // fill the vectors of each topology entities 01094 // like lines vector, polygon vector, triangle vector, 01095 // quadrilateral, polyhedrron, tet, hex, prism, pyramid, 01096 // septahedron vectors 01097 for( i = top; i < num_test_top; i++ ) 01098 { 01099 SimpleArray< iBase_EntityHandle > gentities; 01100 FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err ); 01101 CHECK( "Failed to get gentities in adjacencies_test." ); 01102 01103 gentity_vectors[i].resize( gentities.size() ); 01104 std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); 01105 } 01106 01107 // check adjacencies in both directions 01108 double min[3], max[3]; 01109 double normal[3] = { .0, .0, .0 }; 01110 std::vector< iBase_EntityHandle >::iterator vit; 01111 for( i = iBase_REGION; i > iBase_EDGE; i-- ) 01112 { 01113 for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) 01114 { 01115 iBase_EntityHandle this_gent = *vit; 01116 FBiGeom_getEntBoundBox( geom, this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err ); 01117 CHECK( "Failed to get bounding box of entity." ); 01118 01119 FBiGeom_getEntNrmlXYZ( geom, this_gent, ( max[0] + min[0] ) / 2, ( max[1] + min[1] ) / 2, 01120 ( max[2] + min[2] ) / 2, &normal[0], &normal[1], &normal[2], &err ); 01121 01122 CHECK( "Failed to get normal to the closest point." ); 01123 std::cout << " entity of type " << i << " closest normal to center:\n " << normal[0] << " " << normal[1] 01124 << " " << normal[2] << "\n"; 01125 } 01126 } 01127 01128 return true; 01129 } 01130 01131 // test normals evaluations on the surface only 01132 bool ray_test( FBiGeom_Instance geom ) 01133 { 01134 int err; 01135 iBase_EntitySetHandle root_set; 01136 FBiGeom_getRootSet( geom, &root_set, &err ); 01137 CHECK( "ERROR : getRootSet failed!" ); 01138 01139 int top = iBase_FACE; 01140 01141 SimpleArray< iBase_EntityHandle > faces; 01142 FBiGeom_getEntities( geom, root_set, top, ARRAY_INOUT( faces ), &err ); 01143 CHECK( "Failed to get gentities in adjacencies_test." ); 01144 01145 // check only the first face 01146 01147 // check adjacencies in both directions 01148 double min[3], max[3]; 01149 01150 iBase_EntityHandle first_face = faces[0]; 01151 01152 FBiGeom_getEntBoundBox( geom, first_face, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err ); 01153 CHECK( "Failed to get bounding box of entity." ); 01154 01155 // assume that the ray shot from the bottom of the box (middle) is a pretty good candidate 01156 // in z direction 01157 double x = ( min[0] + max[0] ) / 2, y = ( min[1] + max[1] ) / 2, z = min[2]; 01158 SimpleArray< iBase_EntityHandle > intersect_entity_handles; 01159 SimpleArray< double > intersect_coords; 01160 SimpleArray< double > param_coords; 01161 FBiGeom_getPntRayIntsct( geom, x, y, z, // shot from 01162 0., 0., 1., // direction 01163 ARRAY_INOUT( intersect_entity_handles ), iBase_INTERLEAVED, 01164 ARRAY_INOUT( intersect_coords ), ARRAY_INOUT( param_coords ), &err ); 01165 01166 CHECK( "Failed to find ray intersections points " ); 01167 for( int i = 0; i < intersect_entity_handles.size(); i++ ) 01168 { 01169 int j; 01170 FBiGeom_getEntType( geom, intersect_entity_handles[i], &j, &err ); 01171 CHECK( "Failed to get type of entity." ); 01172 01173 std::cout << " entity of type " << j << " n: " << intersect_entity_handles[i] << "\n" 01174 << intersect_coords[3 * i] << " " << intersect_coords[3 * i + 1] << " " << intersect_coords[3 * i + 2] 01175 << "\n" 01176 << " distance: " << param_coords[i] << "\n"; 01177 } 01178 01179 return true; 01180 } 01181 01182 /*! 01183 @test 01184 TSTTG construct Test 01185 @li Check construction of geometry 01186 */ 01187 bool construct_test( FBiGeom_Instance geom ) 01188 { 01189 int err; 01190 iBase_EntityHandle new_body = 0; 01191 01192 // construct a cylinder, sweep it about an axis, and delete the result 01193 iBase_EntityHandle cyl = 0; 01194 FBiGeom_createCylinder( geom, 1.0, 1.0, 0.0, &cyl, &err ); 01195 // Is the minor radius really supposed to be zero??? - JK 01196 CHECK( "Creating cylinder failed." ); 01197 01198 // move it onto the y axis 01199 FBiGeom_moveEnt( geom, cyl, 0.0, 1.0, -0.5, &err ); 01200 CHECK( "Problems moving surface." ); 01201 01202 // get the surface with max z 01203 iBase_EntityHandle max_surf = 0; 01204 SimpleArray< iBase_EntityHandle > surfs; 01205 FBiGeom_getEntAdj( geom, cyl, iBase_FACE, ARRAY_INOUT( surfs ), &err ); 01206 CHECK( "Problems getting max surf for rotation." ); 01207 01208 SimpleArray< double > max_corn, min_corn; 01209 FBiGeom_getArrBoundBox( geom, ARRAY_IN( surfs ), iBase_INTERLEAVED, ARRAY_INOUT( min_corn ), 01210 ARRAY_INOUT( max_corn ), &err ); 01211 CHECK( "Problems getting max surf for rotation." ); 01212 double dtol = 1.0e-6; 01213 for( int i = 0; i < surfs.size(); ++i ) 01214 { 01215 if( ( max_corn[3 * i + 2] ) <= dtol && ( max_corn[3 * i + 2] ) >= -dtol && ( min_corn[3 * i + 2] ) <= dtol && 01216 ( min_corn[3 * i + 2] ) >= -dtol ) 01217 { 01218 max_surf = surfs[i]; 01219 break; 01220 } 01221 } 01222 01223 if( 0 == max_surf ) 01224 { 01225 std::cerr << "Couldn't find max surf for rotation." << std::endl; 01226 return false; 01227 } 01228 01229 // sweep it around the x axis 01230 FBiGeom_moveEnt( geom, cyl, 0.0, 1.0, 0.0, &err ); 01231 CHECK( "Problems moving surface." ); 01232 01233 FBiGeom_sweepEntAboutAxis( geom, max_surf, 360.0, 1.0, 0.0, 0.0, &new_body, &err ); 01234 CHECK( "Problems sweeping surface about axis." ); 01235 01236 // now delete 01237 FBiGeom_deleteEnt( geom, new_body, &err ); 01238 CHECK( "Problems deleting cylinder or swept surface body." ); 01239 01240 // if we got here, we were successful 01241 return true; 01242 } 01243 01244 static bool compare_box( const double* expected_min, 01245 const double* expected_max, 01246 const double* actual_min, 01247 const double* actual_max ) 01248 { 01249 bool same = true; 01250 double dtol = 1.0e-6; 01251 01252 for( int i = 0; i < 3; ++i ) 01253 { 01254 if( expected_min[i] < actual_min[i] - dtol || expected_min[i] * 10 > actual_min[i] || 01255 expected_max[i] > actual_max[i] + dtol || expected_max[i] * 10 < actual_max[i] ) 01256 same = false; 01257 } 01258 return same; 01259 } 01260 01261 bool primitives_test( FBiGeom_Instance geom ) 01262 { 01263 int err; 01264 SimpleArray< iBase_EntityHandle > prims( 3 ); 01265 iBase_EntityHandle prim; 01266 01267 FBiGeom_createBrick( geom, 1.0, 2.0, 3.0, &prim, &err ); 01268 CHECK( "createBrick failed." ); 01269 prims[0] = prim; 01270 01271 FBiGeom_createCylinder( geom, 1.0, 4.0, 2.0, &prim, &err ); 01272 CHECK( "createCylinder failed." ); 01273 prims[1] = prim; 01274 01275 FBiGeom_createTorus( geom, 2.0, 1.0, &prim, &err ); 01276 CHECK( "createTorus failed." ); 01277 prims[2] = prim; 01278 01279 // verify the bounding boxes for Acis based entities 01280 SimpleArray< double > max_corn, min_corn; 01281 FBiGeom_getArrBoundBox( geom, ARRAY_IN( prims ), iBase_INTERLEAVED, ARRAY_INOUT( min_corn ), 01282 ARRAY_INOUT( max_corn ), &err ); 01283 01284 double preset_min_corn[] = 01285 // min brick corner xyz 01286 { -0.5, -1.0, -1.5, 01287 // min cyl corner xyz 01288 -4.0, -2.0, -0.5, 01289 // min torus corner xyz 01290 -3.0, -3.0, -1.0 }; 01291 01292 double preset_max_corn[] = 01293 // max brick corner xyz 01294 { 0.5, 1.0, 1.5, 01295 // max cyl corner xyz 01296 4.0, 2.0, 0.5, 01297 // max torus corner xyz 01298 3.0, 3.0, 1.0 }; 01299 01300 if( !compare_box( preset_min_corn, preset_max_corn, &min_corn[0], &max_corn[0] ) ) 01301 { 01302 std::cerr << "Box check failed for brick" << std::endl; 01303 return false; 01304 } 01305 01306 if( !compare_box( preset_min_corn + 3, preset_max_corn + 3, &min_corn[3], &max_corn[3] ) ) 01307 { 01308 std::cerr << "Box check failed for cylinder" << std::endl; 01309 return false; 01310 } 01311 01312 if( !compare_box( preset_min_corn + 6, preset_max_corn + 6, &min_corn[6], &max_corn[6] ) ) 01313 { 01314 std::cerr << "Box check failed for torus" << std::endl; 01315 return false; 01316 } 01317 // must have worked; delete the entities then return 01318 for( int i = 0; i < 3; ++i ) 01319 { 01320 FBiGeom_deleteEnt( geom, prims[i], &err ); 01321 CHECK( "Problems deleting primitive after boolean check." ); 01322 } 01323 01324 return true; 01325 } 01326 01327 bool transforms_test( FBiGeom_Instance geom ) 01328 { 01329 int err; 01330 01331 // construct a brick 01332 iBase_EntityHandle brick = 0; 01333 FBiGeom_createBrick( geom, 1.0, 2.0, 3.0, &brick, &err ); 01334 CHECK( "Problems creating brick for transforms test." ); 01335 01336 // move it, then test bounding box 01337 FBiGeom_moveEnt( geom, brick, 0.5, 1.0, 1.5, &err ); 01338 CHECK( "Problems moving brick for transforms test." ); 01339 01340 double bb_min[3], bb_max[3]; 01341 FBiGeom_getEntBoundBox( geom, brick, bb_min, bb_min + 1, bb_min + 2, bb_max, bb_max + 1, bb_max + 2, &err ); 01342 CHECK( "Problems getting bounding box after move." ); 01343 01344 double dtol = 1.0e-6; 01345 if( ( bb_min[0] ) >= dtol || ( bb_min[0] ) <= -dtol || ( bb_min[1] ) >= dtol || ( bb_min[1] ) <= -dtol || 01346 ( bb_min[2] ) >= dtol || ( bb_min[2] ) <= -dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol || 01347 ( bb_max[1] - 2 ) >= dtol || 2 - bb_max[1] >= dtol || ( bb_max[2] - 3 ) >= dtol || 3 - bb_max[2] >= dtol ) 01348 { 01349 std::cerr << "Wrong bounding box after move." << std::endl; 01350 return false; 01351 } 01352 01353 // now rotate it about +x, then test bounding box 01354 FBiGeom_rotateEnt( geom, brick, 90, 1.0, 0.0, 0.0, &err ); 01355 CHECK( "Problems rotating brick for transforms test." ); 01356 01357 FBiGeom_getEntBoundBox( geom, brick, bb_min, bb_min + 1, bb_min + 2, bb_max, bb_max + 1, bb_max + 2, &err ); 01358 CHECK( "Problems getting bounding box after rotate." ); 01359 01360 if( ( bb_min[0] ) >= dtol || -bb_min[0] >= dtol || ( bb_min[1] + 3 ) >= dtol || -( bb_min[1] + 3 ) >= dtol || 01361 ( bb_min[2] ) >= dtol || -( bb_min[2] ) >= dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol || 01362 ( bb_max[1] ) >= dtol || -( bb_max[1] ) >= dtol || ( bb_max[2] - 2 ) >= dtol || 2 - bb_max[2] >= dtol ) 01363 { 01364 std::cerr << "Wrong bounding box after rotate." << std::endl; 01365 return false; 01366 } 01367 01368 // now reflect through y plane; should recover original bb 01369 FBiGeom_reflectEnt( geom, brick, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, &err ); 01370 CHECK( "Problems reflecting brick for transforms test." ); 01371 01372 FBiGeom_getEntBoundBox( geom, brick, bb_min, bb_min + 1, bb_min + 2, bb_max, bb_max + 1, bb_max + 2, &err ); 01373 CHECK( "Problems getting bounding box after reflect." ); 01374 01375 if( ( bb_min[0] ) >= dtol || -( bb_min[0] ) >= dtol || ( bb_min[1] ) >= dtol || ( bb_min[2] ) >= dtol || 01376 -( bb_min[1] ) >= dtol || -( bb_min[2] ) >= dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol || 01377 ( bb_max[1] - 3 ) >= dtol || 3 - bb_max[1] >= dtol || ( bb_max[2] - 2 ) >= dtol || 2 - bb_max[2] >= dtol ) 01378 { 01379 std::cerr << "Wrong bounding box after reflect." << std::endl; 01380 return false; 01381 } 01382 01383 // must have worked; delete the entities then return 01384 FBiGeom_deleteEnt( geom, brick, &err ); 01385 CHECK( "Problems deleting brick after transforms check." ); 01386 return true; 01387 } 01388 01389 bool booleans_test( FBiGeom_Instance geom ) 01390 { 01391 int err; 01392 01393 // construct a brick size 1, and a cylinder rad 0.25 height 2 01394 iBase_EntityHandle brick = 0, cyl = 0; 01395 FBiGeom_createBrick( geom, 1.0, 0.0, 0.0, &brick, &err ); 01396 CHECK( "Problems creating brick for booleans test." ); 01397 FBiGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err ); 01398 CHECK( "Problems creating cylinder for booleans test." ); 01399 01400 // subtract the cylinder from the brick 01401 iBase_EntityHandle subtract_result = 0; 01402 FBiGeom_subtractEnts( geom, brick, cyl, &subtract_result, &err ); 01403 CHECK( "Problems subtracting for booleans subtract test." ); 01404 01405 // section the brick 01406 iBase_EntityHandle section_result = 0; 01407 FBiGeom_sectionEnt( geom, subtract_result, 1.0, 0.0, 0.0, 0.25, true, §ion_result, &err ); 01408 CHECK( "Problems sectioning for booleans section test." ); 01409 01410 // unite the section result with a new cylinder 01411 FBiGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err ); 01412 CHECK( "Problems creating cylinder for unite test." ); 01413 iBase_EntityHandle unite_results; 01414 iBase_EntityHandle unite_input[] = { section_result, cyl }; 01415 FBiGeom_uniteEnts( geom, unite_input, 2, &unite_results, &err ); 01416 CHECK( "Problems uniting for booleans unite test." ); 01417 01418 FBiGeom_deleteEnt( geom, unite_results, &err ); 01419 CHECK( "Problems deleting for booleans unite test." ); 01420 return true; 01421 } 01422 01423 static int get_entities( FBiGeom_Instance geom, 01424 int entity_type, 01425 std::vector< iBase_EntityHandle >& entities_out, 01426 iBase_TagHandle id_tag = 0, 01427 std::vector< int >* ids_out = 0 ) 01428 { 01429 int err, num; 01430 iBase_EntitySetHandle root; 01431 FBiGeom_getRootSet( geom, &root, &err ); 01432 if( iBase_SUCCESS != err ) return err; 01433 FBiGeom_getNumOfType( geom, root, entity_type, &num, &err ); 01434 if( iBase_SUCCESS != err ) return err; 01435 01436 entities_out.resize( num ); 01437 int junk1 = entities_out.size(), junk2; 01438 iBase_EntityHandle* junk_ptr = &entities_out[0]; 01439 ; 01440 FBiGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err ); 01441 if( iBase_SUCCESS != err ) return err; 01442 assert( num == junk1 && num == junk2 ); 01443 01444 if( !ids_out ) return iBase_SUCCESS; 01445 01446 ids_out->resize( num ); 01447 int* int_ptr = &( *ids_out )[0]; 01448 FBiGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err ); 01449 if( iBase_SUCCESS != err ) return err; 01450 assert( num == junk1 && num == junk2 ); 01451 01452 return iBase_SUCCESS; 01453 } 01454 01455 static int check_firmness( FBiGeom_Instance geom, 01456 const std::vector< iBase_EntityHandle >& entities, 01457 const std::vector< int >& ids, 01458 iBase_TagHandle firmness_tag, 01459 const char* expected_value, 01460 const char* ent_type_str ) 01461 { 01462 const int firmness_size = 4; 01463 std::vector< char > firmness( firmness_size * entities.size() ); 01464 01465 char* byte_ptr = &firmness[0]; 01466 int err, junk1 = firmness.size(), junk2 = entities.size() * firmness_size; 01467 FBiGeom_getArrData( geom, &entities[0], entities.size(), firmness_tag, (void**)&byte_ptr, &junk1, &junk2, &err ); 01468 if( iBase_SUCCESS != err ) return err; 01469 01470 bool all_correct = true; 01471 for( unsigned i = 0; i < entities.size(); ++i ) 01472 if( std::string( &firmness[firmness_size * i], firmness_size ) != expected_value ) all_correct = false; 01473 if( !all_correct ) 01474 { 01475 std::cout << "ERROR: Expected \"" << expected_value << "\" firmness " 01476 << "for all " << ent_type_str << "." << std::endl; 01477 std::cout << "ID Actual " << std::endl; 01478 for( unsigned i = 0; i < entities.size(); ++i ) 01479 std::cout << std::setw( 2 ) << ids[i] << " " << std::string( &firmness[firmness_size * i], firmness_size ) 01480 << std::endl; 01481 return iBase_FAILURE; 01482 } 01483 01484 return iBase_SUCCESS; 01485 } 01486 01487 static int count_num_with_tag( FBiGeom_Instance geom, 01488 const std::vector< iBase_EntityHandle >& ents, 01489 iBase_TagHandle tag ) 01490 { 01491 int err, bytes; 01492 FBiGeom_getTagSizeBytes( geom, tag, &bytes, &err ); 01493 if( iBase_SUCCESS != err ) return -1; 01494 std::vector< char > data( bytes ); 01495 01496 int success_count = 0; 01497 for( size_t i = 0; i < ents.size(); ++i ) 01498 { 01499 char* ptr = &data[0]; 01500 int junk1 = bytes, junk2; 01501 FBiGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err ); 01502 if( iBase_TAG_NOT_FOUND == err ) continue; 01503 if( iBase_SUCCESS != err ) return -1; 01504 ++success_count; 01505 } 01506 01507 return success_count; 01508 } 01509 01510 bool mesh_size_test( FBiGeom_Instance geom ) 01511 { 01512 const char* filename = STRINGIFY( SRCDIR ) "/size.sat"; 01513 int err, junk1, junk2; 01514 bool result = true; 01515 01516 FBiGeom_deleteAll( geom, &err ); 01517 CHECK( "" ); 01518 FBiGeom_load( geom, filename, 0, &err, strlen( filename ), 0 ); 01519 CHECK( "Failed to load input file: 'size.sat'" ); 01520 01521 // get tag handles 01522 iBase_TagHandle interval, size, firmness, id; 01523 FBiGeom_getTagHandle( geom, "MESH_INTERVAL", &interval, &err, strlen( "MESH_INTERVAL" ) ); 01524 CHECK( "FBiGeom_getTagHandle(\"MESH_INTERVAL\")" ); 01525 FBiGeom_getTagHandle( geom, "MESH_SIZE", &size, &err, strlen( "MESH_SIZE" ) ); 01526 CHECK( "FBiGeom_getTagHandle(\"MESH_SIZE\")" ); 01527 FBiGeom_getTagHandle( geom, "SIZE_FIRMNESS", &firmness, &err, strlen( "SIZE_FIRMNESS" ) ); 01528 CHECK( "FBiGeom_getTagHandle(\"SIZE_FIRMNESS\")" ); 01529 FBiGeom_getTagHandle( geom, "GLOBAL_ID", &id, &err, strlen( "GLOBAL_ID" ) ); 01530 CHECK( "FBiGeom_getTagHandle(\"GLOBAL_ID\")" ); 01531 01532 // get entity lists 01533 std::vector< iBase_EntityHandle > verts, curves, surfs, vols; 01534 std::vector< int > vert_ids, curve_ids, surf_ids, vol_ids; 01535 err = get_entities( geom, iBase_VERTEX, verts, id, &vert_ids ); 01536 CHECK( "" ); 01537 err = get_entities( geom, iBase_EDGE, curves, id, &curve_ids ); 01538 CHECK( "" ); 01539 err = get_entities( geom, iBase_FACE, surfs, id, &surf_ids ); 01540 CHECK( "" ); 01541 err = get_entities( geom, iBase_REGION, vols, id, &vol_ids ); 01542 CHECK( "" ); 01543 01544 // expect interval count to be the same as ID for every curve 01545 std::vector< int > intervals( curves.size() ); 01546 int* int_ptr = &intervals[0]; 01547 junk1 = junk2 = curves.size(); 01548 FBiGeom_getIntArrData( geom, &curves[0], curves.size(), interval, &int_ptr, &junk1, &junk2, &err ); 01549 CHECK( "Failed to get intervals for curves" ); 01550 if( intervals != curve_ids ) 01551 { 01552 std::cout << "ERROR: Incorrect curve intervals for one or more curves." << std::endl; 01553 std::cout << "ID Expected Actual" << std::endl; 01554 for( unsigned i = 0; i < curves.size(); ++i ) 01555 std::cout << std::setw( 2 ) << curve_ids[i] << " " << std::setw( 8 ) << curve_ids[i] << " " 01556 << std::setw( 6 ) << intervals[i] << std::endl; 01557 result = false; 01558 } 01559 01560 // expect size to be the same as ID for every surface 01561 std::vector< double > sizes( surfs.size() ); 01562 double* dbl_ptr = &sizes[0]; 01563 junk1 = junk2 = surfs.size(); 01564 FBiGeom_getDblArrData( geom, &surfs[0], surfs.size(), size, &dbl_ptr, &junk1, &junk2, &err ); 01565 CHECK( "Failed to get sizes for surfaces" ); 01566 bool all_correct = true; 01567 for( unsigned i = 0; i < surfs.size(); ++i ) 01568 if( fabs( sizes[i] - (double)surf_ids[i] ) > 1e-8 ) all_correct = false; 01569 if( !all_correct ) 01570 { 01571 std::cout << "ERROR: Incorrect mesh size for one or more surfaces." << std::endl; 01572 std::cout << "ID Expected Actual " << std::endl; 01573 for( unsigned i = 0; i < surfs.size(); ++i ) 01574 std::cout << std::setw( 2 ) << surf_ids[i] << " " << std::setw( 8 ) << (double)surf_ids[i] << " " 01575 << std::setw( 8 ) << sizes[i] << std::endl; 01576 result = false; 01577 } 01578 01579 err = result ? iBase_SUCCESS : iBase_FAILURE; 01580 CHECK( "Invalid size or interval data" ); 01581 01582 // expect "HARD" firmness on all curves 01583 err = check_firmness( geom, curves, curve_ids, firmness, "HARD", "curves" ); 01584 CHECK( "Invalid curve firmness" ); 01585 // expect "SOFT" firmness on all surfaces 01586 err = check_firmness( geom, surfs, surf_ids, firmness, "SOFT", "surfaces" ); 01587 CHECK( "Invalid surface firmness" ); 01588 01589 // expect no firmnes on other entities 01590 err = count_num_with_tag( geom, verts, firmness ) ? iBase_FAILURE : iBase_SUCCESS; 01591 CHECK( "Got firmness for vertex." ); 01592 err = count_num_with_tag( geom, vols, firmness ) ? iBase_FAILURE : iBase_SUCCESS; 01593 CHECK( "Got firmness for volume." ); 01594 01595 // expect no interval tag on any entities except curves 01596 err = count_num_with_tag( geom, verts, interval ) ? iBase_FAILURE : iBase_SUCCESS; 01597 CHECK( "Got interval count for vertex." ); 01598 err = count_num_with_tag( geom, vols, interval ) ? iBase_FAILURE : iBase_SUCCESS; 01599 CHECK( "Got interval count for volume." ); 01600 01601 // expect no size tag on any entities except surfaces 01602 // curves should have size of one of their parent surfaces 01603 err = count_num_with_tag( geom, verts, size ) ? iBase_FAILURE : iBase_SUCCESS; 01604 CHECK( "Got mesh size for vertex." ); 01605 err = count_num_with_tag( geom, vols, size ) ? iBase_FAILURE : iBase_SUCCESS; 01606 CHECK( "Got mesh size for volume." ); 01607 01608 return true; 01609 } 01610 01611 bool shutdown_test2( FBiGeom_Instance geom, std::string& /*engine_opt*/ ) 01612 { 01613 int err; 01614 01615 // test shutdown2 01616 FBiGeom_dtor2( geom, &err ); 01617 CHECK( "Interface destruction didn't work properly." ); 01618 01619 // FBiGeom_newGeom(engine_opt.c_str(), &geom, &err, engine_opt.length()); 01620 // CHECK( "Interface re-construction didn't work properly." ); 01621 // 01622 // FBiGeom_dtor(geom, &err); 01623 // CHECK( "2nd Interface destruction didn't work properly." ); 01624 01625 return true; 01626 } 01627 01628 bool save_entset_test( FBiGeom_Instance geom ) 01629 { 01630 int err; 01631 01632 #ifdef FORCE_OCC 01633 std::string filename = "testout.brep"; 01634 #elif defined( HAVE_ACIS ) 01635 std::string filename = "testout.sat"; 01636 #elif defined( HAVE_OCC ) 01637 std::string filename = "testout.brep"; 01638 #else 01639 std::string filename = "testout.sat"; 01640 #endif 01641 01642 // initialize number of ents and sets to compare with later 01643 int num_ents_bef, num_sets_bef; 01644 iBase_EntitySetHandle root; 01645 FBiGeom_getRootSet( geom, &root, &err ); 01646 CHECK( "Failed to get root set." ); 01647 FBiGeom_getNumEntSets( geom, root, 1, &num_sets_bef, &err ); 01648 CHECK( "Failed to get number of ent sets." ); 01649 FBiGeom_getNumOfType( geom, root, iBase_REGION, &num_ents_bef, &err ); 01650 CHECK( "Failed to get number of entities." ); 01651 01652 // create set, and entity to add to set 01653 iBase_EntityHandle cyl; 01654 FBiGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err ); 01655 CHECK( "Problems creating cylinder for save entset test." ); 01656 iBase_EntitySetHandle seth; 01657 FBiGeom_createEntSet( geom, true, &seth, &err ); 01658 CHECK( "Problems creating entity set for save entset test." ); 01659 01660 // add the entity 01661 FBiGeom_addEntToSet( geom, cyl, seth, &err ); 01662 CHECK( "Problems adding entity to set for save entset test." ); 01663 01664 // save/restore the model, and see if the entity is there 01665 FBiGeom_save( geom, filename.c_str(), NULL, &err, filename.length(), 0 ); 01666 CHECK( "Problems saving file for save entset test." ); 01667 01668 FBiGeom_destroyEntSet( geom, seth, &err ); 01669 CHECK( "Failed to destroy entity set." ); 01670 FBiGeom_deleteEnt( geom, cyl, &err ); 01671 CHECK( "Failed to destroy entity." ); 01672 01673 // read the file back in 01674 FBiGeom_load( geom, filename.c_str(), NULL, &err, filename.length(), 0 ); 01675 CHECK( "Problems reading file for save entset test." ); 01676 01677 // check number of sets and entities 01678 int num_ents_aft, num_sets_aft; 01679 FBiGeom_getNumEntSets( geom, root, 1, &num_sets_aft, &err ); 01680 CHECK( "Failed to get number of ent sets." ); 01681 FBiGeom_getNumOfType( geom, root, iBase_REGION, &num_ents_aft, &err ); 01682 CHECK( "Failed to get number of entities." ); 01683 bool success = true; 01684 if( num_ents_aft != 2 * num_ents_bef + 1 ) 01685 { 01686 print_error( "Failed to get the right number of entities.", iBase_FAILURE, geom, __FILE__, __LINE__ ); 01687 success = false; 01688 } 01689 else if( num_sets_aft != 2 * num_sets_bef + 1 ) 01690 { 01691 print_error( "Failed to get the right number of entity sets.", iBase_FAILURE, geom, __FILE__, __LINE__ ); 01692 success = false; 01693 } 01694 01695 // otherwise, we succeeded 01696 return success; 01697 }
