MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retian certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file ConditionNumberTest.cpp 00028 * \brief unit tests for ConditionNumberQualityMetric 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "ConditionNumberQualityMetric.hpp" 00034 #include "cppunit/extensions/HelperMacros.h" 00035 #include "QualityMetricTester.hpp" 00036 00037 using namespace MBMesquite; 00038 00039 class ConditionNumberTest : public CppUnit::TestFixture 00040 { 00041 private: 00042 CPPUNIT_TEST_SUITE( ConditionNumberTest ); 00043 00044 CPPUNIT_TEST( test_supported_types ); 00045 CPPUNIT_TEST( test_ideal_element_eval ); 00046 CPPUNIT_TEST( test_ideal_element_grad ); 00047 CPPUNIT_TEST( test_ideal_element_hess ); 00048 CPPUNIT_TEST( test_measures_quality ); 00049 CPPUNIT_TEST( test_gradient_reflects_quality ); 00050 CPPUNIT_TEST( test_domain_deviation ); 00051 CPPUNIT_TEST( test_inverted_elements ); 00052 CPPUNIT_TEST( test_degenerate_elements ); 00053 CPPUNIT_TEST( test_get_evaluations ); 00054 CPPUNIT_TEST( test_get_element_indices ); 00055 CPPUNIT_TEST( test_get_fixed_indices ); 00056 CPPUNIT_TEST( test_eval_with_indices ); 00057 CPPUNIT_TEST( test_location_invariant ); 00058 CPPUNIT_TEST( test_scale_invariant ); 00059 CPPUNIT_TEST( test_orient_invariant ); 00060 00061 CPPUNIT_TEST_SUITE_END(); 00062 00063 ConditionNumberQualityMetric mMetric; 00064 QualityMetricTester tester; 00065 00066 public: 00067 ConditionNumberTest() : tester( QualityMetricTester::ALL_FE_EXCEPT_SEPTAHEDRON ) 00068 { 00069 tester.ideal_pyramid_base_equals_height( true ); 00070 } 00071 00072 void test_supported_types() 00073 { 00074 tester.test_supported_element_types( &mMetric ); 00075 } 00076 00077 void test_ideal_element_eval() 00078 { 00079 tester.test_evaluate_unit_edge_element( &mMetric, TRIANGLE, 1.0 ); 00080 tester.test_evaluate_unit_edge_element( &mMetric, QUADRILATERAL, 1.0 ); 00081 tester.test_evaluate_unit_edge_element( &mMetric, TETRAHEDRON, 1.0 ); 00082 tester.test_evaluate_unit_edge_element( &mMetric, HEXAHEDRON, 1.0 ); 00083 tester.test_evaluate_unit_edge_element( &mMetric, PRISM, 1.0 ); 00084 tester.test_evaluate_unit_edge_element( &mMetric, PYRAMID, 1.0 ); 00085 } 00086 00087 void test_ideal_element_grad() 00088 { 00089 tester.test_ideal_element_zero_gradient( &mMetric, false ); 00090 } 00091 00092 void test_ideal_element_hess() 00093 { 00094 tester.test_ideal_element_positive_definite_Hessian( &mMetric, false ); 00095 } 00096 00097 void test_measures_quality() 00098 { 00099 tester.test_measures_quality( &mMetric ); 00100 } 00101 00102 void test_gradient_reflects_quality() 00103 { 00104 tester.test_gradient_reflects_quality( &mMetric ); 00105 } 00106 00107 void test_domain_deviation() 00108 { 00109 tester.test_domain_deviation_quality( &mMetric ); 00110 tester.test_domain_deviation_gradient( &mMetric ); 00111 } 00112 00113 void test_inverted_elements() 00114 { 00115 tester.test_evaluate_inverted_element( &mMetric, false ); 00116 } 00117 00118 void test_degenerate_elements() 00119 { 00120 tester.test_evaluate_degenerate_element( &mMetric, false ); 00121 } 00122 00123 void test_get_evaluations() 00124 { 00125 tester.test_get_element_evaluations( &mMetric ); 00126 } 00127 00128 void test_get_element_indices() 00129 { 00130 tester.test_get_element_indices( &mMetric ); 00131 } 00132 00133 void test_get_fixed_indices() 00134 { 00135 tester.test_get_indices_fixed( &mMetric ); 00136 } 00137 00138 void test_eval_with_indices() 00139 { 00140 tester.compare_eval_and_eval_with_indices( &mMetric ); 00141 } 00142 00143 void test_location_invariant() 00144 { 00145 tester.test_location_invariant( &mMetric ); 00146 tester.test_grad_location_invariant( &mMetric ); 00147 tester.test_hessian_location_invariant( &mMetric ); 00148 } 00149 00150 void test_scale_invariant() 00151 { 00152 tester.test_scale_invariant( &mMetric ); 00153 } 00154 00155 void test_orient_invariant() 00156 { 00157 tester.test_orient_invariant( &mMetric ); 00158 tester.test_grad_orient_invariant( &mMetric ); 00159 } 00160 }; 00161 00162 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( ConditionNumberTest, "ConditionNumberTest" ); 00163 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( ConditionNumberTest, "Unit" );
