ConditionNumberTest Class Reference
+ Inheritance diagram for ConditionNumberTest:
+ Collaboration diagram for ConditionNumberTest:
Public Member Functions
 ConditionNumberTest ()
void test_supported_types ()
void test_ideal_element_eval ()
void test_ideal_element_grad ()
void test_ideal_element_hess ()
void test_measures_quality ()
void test_gradient_reflects_quality ()
void test_domain_deviation ()
void test_inverted_elements ()
void test_degenerate_elements ()
void test_get_evaluations ()
void test_get_element_indices ()
void test_get_fixed_indices ()
void test_eval_with_indices ()
void test_location_invariant ()
void test_scale_invariant ()
void test_orient_invariant ()
Private Member Functions
 CPPUNIT_TEST_SUITE (ConditionNumberTest)
 CPPUNIT_TEST (test_supported_types)
 CPPUNIT_TEST (test_ideal_element_eval)
 CPPUNIT_TEST (test_ideal_element_grad)
 CPPUNIT_TEST (test_ideal_element_hess)
 CPPUNIT_TEST (test_measures_quality)
 CPPUNIT_TEST (test_gradient_reflects_quality)
 CPPUNIT_TEST (test_domain_deviation)
 CPPUNIT_TEST (test_inverted_elements)
 CPPUNIT_TEST (test_degenerate_elements)
 CPPUNIT_TEST (test_get_evaluations)
 CPPUNIT_TEST (test_get_element_indices)
 CPPUNIT_TEST (test_get_fixed_indices)
 CPPUNIT_TEST (test_eval_with_indices)
 CPPUNIT_TEST (test_location_invariant)
 CPPUNIT_TEST (test_scale_invariant)
 CPPUNIT_TEST (test_orient_invariant)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
ConditionNumberQualityMetric mMetric
QualityMetricTester tester
Detailed Description
Definition at line 39 of file ConditionNumberTest.cpp.
Member Function Documentation
Definition at line 118 of file ConditionNumberTest.cpp.
References mMetric.
Definition at line 133 of file ConditionNumberTest.cpp.
References mMetric.
Definition at line 87 of file ConditionNumberTest.cpp.
References mMetric.
Definition at line 113 of file ConditionNumberTest.cpp.
References mMetric.
Definition at line 97 of file ConditionNumberTest.cpp.
References mMetric.
Definition at line 150 of file ConditionNumberTest.cpp.
References mMetric.
Member Data Documentation
List of all members.
