MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 #ifndef MESQUITE_HPP 00028 #define MESQUITE_HPP 00029 00030 #include "moab/MOABConfig.h" 00031 00032 #ifdef _WIN32 // if vc 00033 #ifdef MESQUITE_DLL_EXPORTS // if we are exporting as dll 00034 #define MESQUITE_EXPORT __declspec( dllexport ) 00035 #else // else we aren't exporting as dll 00036 #ifdef MESQUITE_STATIC_LIB // are we compiling a static lib? 00037 00038 #define MESQUITE_EXPORT 00039 #else // Calling codes need to do nothing if 00040 // they are calling as a dll 00041 #define MESQUITE_EXPORT __declspec( dllimport ) 00042 #endif 00043 #endif 00044 #elif defined( __GNUC__ ) && __GNUC__ >= 4 00045 #define MESQUITE_EXPORT __attribute__( ( visibility( "default" ) ) ) 00046 #else // else not vc 00047 #define MESQUITE_EXPORT 00048 #endif 00049 00050 #ifdef WIN32 /* windows */ 00051 #define _USE_MATH_DEFINES // For M_PI 00052 #endif 00053 00054 #include <cmath> 00055 #include <cfloat> 00056 #include <climits> 00057 #include <cstddef> 00058 #ifdef HAVE_CBRT 00059 #include <math.h> 00060 #endif 00061 00062 #include <limits> 00063 #include <vector> 00064 #include <assert.h> 00065 00066 /*! \file Mesquite.hpp 00067 */ 00068 00069 /*! 00070 \namespace Mesquite 00071 Copyright 2003 Sandia Corporation and the University of Chicago. Under 00072 the terms of Contract DE-AC04-94AL85000 with Sandia Corporation and 00073 Contract W-31-109-ENG-38 with the University of Chicago, the U.S. 00074 Government retains certain rights in this software. 00075 00076 */ 00077 namespace MBMesquite 00078 { 00079 00080 typedef int StatusCode; 00081 00082 typedef double real; 00083 00084 enum StatusCodeValues 00085 { 00086 MSQ_FAILURE = 0, 00087 MSQ_SUCCESS 00088 }; 00089 00090 enum EntityTopology 00091 { 00092 POLYGON = 7, 00093 TRIANGLE = 8, 00094 QUADRILATERAL = 9, 00095 POLYHEDRON = 10, 00096 TETRAHEDRON = 11, 00097 HEXAHEDRON = 12, 00098 PRISM = 13, 00099 PYRAMID = 14, 00100 SEPTAHEDRON = 15, 00101 MIXED 00102 }; 00103 00104 enum AssessSchemes 00105 { 00106 NO_SCHEME = 0, 00107 ELEMENT_AVG_QM = 1, 00108 ELEMENT_MAX_QM = 2, 00109 TMP_QUALITY_METRIC = 3, 00110 QUALITY_METRIC = 4 00111 }; 00112 00113 // Version information 00114 MESQUITE_EXPORT const char* version_string( bool ); 00115 MESQUITE_EXPORT unsigned int major_version_number(); 00116 MESQUITE_EXPORT unsigned int minor_version_number(); 00117 MESQUITE_EXPORT unsigned int patch_version_number(); 00118 enum ReleaseType 00119 { 00120 RELEASE, 00121 BETA, 00122 ALPHA 00123 }; 00124 MESQUITE_EXPORT MBMesquite::ReleaseType release_type(); 00125 00126 const bool OF_FREE_EVALS_ONLY = true; 00127 00128 // GLOBAL variables 00129 const int MSQ_MAX_NUM_VERT_PER_ENT = 8; 00130 const int MSQ_HIST_SIZE = 7; // number of division in histogram 00131 static const double MSQ_SQRT_TWO = std::sqrt( 2.0 ); 00132 static const double MSQ_SQRT_THREE = std::sqrt( 3.0 ); 00133 static const double MSQ_SQRT_THREE_DIV_TWO = MSQ_SQRT_THREE / 2.0; 00134 static const double MSQ_SQRT_THREE_INV = 1.0 / MSQ_SQRT_THREE; 00135 static const double MSQ_SQRT_TWO_INV = 1.0 / MSQ_SQRT_TWO; 00136 static const double MSQ_SQRT_TWO_DIV_SQRT_THREE = MSQ_SQRT_TWO / MSQ_SQRT_THREE; 00137 static const double MSQ_ONE_THIRD = 1.0 / 3.0; 00138 static const double MSQ_TWO_THIRDS = 2.0 / 3.0; 00139 static const double MSQ_3RT_2_OVER_6RT_3 = std::pow( 2 / MSQ_SQRT_THREE, MSQ_ONE_THIRD ); 00140 00141 #ifdef UINT_MAX 00142 const unsigned MSQ_UINT_MAX = UINT_MAX; 00143 #else 00144 const unsigned MSQ_UINT_MAX = ~(unsigned)0; 00145 #endif 00146 00147 #ifdef INT_MAX 00148 const int MSQ_INT_MAX = INT_MAX; 00149 #else 00150 const int MSQ_INT_MAX = MSQ_UINT_MAX >> 1; 00151 #endif 00152 00153 #ifdef INT_MIN 00154 const int MSQ_INT_MIN = INT_MIN; 00155 #else 00156 const int MSQ_INT_MIN = ~MSQ_INT_MAX; 00157 #endif 00158 00159 #ifdef DBL_MIN 00160 const double MSQ_DBL_MIN = DBL_MIN; 00161 #else 00162 /* This value is rather large - DBL_MIN is normally about 2e-308 00163 Put an error here to see if any platform really doesn't 00164 have DBL_MIN or DBL_MAX defined, and evaluate what to do then. 00165 */ 00166 #error DBL_MIN not defined 00167 const double MSQ_DBL_MIN = 1.0E-30; 00168 #endif 00169 const double MSQ_MIN = MSQ_DBL_MIN; 00170 00171 #ifdef DBL_MAX 00172 const double MSQ_DBL_MAX = DBL_MAX; 00173 #else 00174 /* This value is rather small - DBL_MAX is normally about 2e308 00175 Put an error here to see if any platform really doesn't 00176 have DBL_MIN or DBL_MAX defined, and evaluate what to do then. 00177 */ 00178 #error DBL_MAX not defined 00179 const double MSQ_DBL_MAX = 1.0E30; 00180 #endif 00181 const double MSQ_MAX = MSQ_DBL_MAX; 00182 const double MSQ_MAX_CAP = 1.e6; 00183 00184 // macro to return the min/max of a set of arguements. The integer 00185 // (e.g., '2') tells how many arguements should be passed for comparison. 00186 template < class T > 00187 inline T MSQ_MIN_2( T a, T b ) 00188 { 00189 return a < b ? a : b; 00190 } 00191 template < class T > 00192 inline T MSQ_MAX_2( T a, T b ) 00193 { 00194 return a > b ? a : b; 00195 } 00196 00197 // Utility functions 00198 inline double cbrt( double d ) 00199 { 00200 #ifdef MOAB_HAVE_CBRT 00201 return ::cbrt( d ); 00202 #else 00203 return std::pow( d, MSQ_ONE_THIRD ); 00204 #endif 00205 } 00206 00207 inline double cbrt_sqr( double d ) 00208 { 00209 #ifdef MOAB_HAVE_CBRT 00210 return ::cbrt( d * d ); 00211 #else 00212 return std::pow( d, MSQ_TWO_THIRDS ); 00213 #endif 00214 } 00215 00216 /**\brief Perform safe division (no overflow or div by zero). 00217 * 00218 * Do result = num/den iff it would not result in an overflow or div by zero 00219 *\param num Numerator of division. 00220 *\param den Denominator of division 00221 *\param result The result of the division if valid, zero otherwise. 00222 *\return false if the result of the division would be invalid (inf or nan), 00223 * true otherwise. 00224 */ 00225 inline bool divide( double num, double den, double& result ) 00226 { 00227 const double fden = fabs( den ); 00228 // NOTE: First comparison is necessary to avoid overflow in second. 00229 // NOTE: Comparison in second half of condition must be '<' 00230 // rather than '<=' to correctly handle 0/0. 00231 if( fden >= 1 || fabs( num ) < fden * std::numeric_limits< double >::max() ) 00232 { 00233 result = num / den; 00234 return true; 00235 } 00236 else 00237 { 00238 result = 0.0; 00239 return false; 00240 } 00241 } 00242 00243 /**\brief get array pointer from std::vector */ 00244 template < typename T > 00245 inline T* arrptr( std::vector< T >& v, bool check_zero_size = false ) 00246 { 00247 if( check_zero_size && !v.size() ) return 0; 00248 assert( !v.empty() ); 00249 return &v[0]; 00250 } 00251 template < typename T > 00252 inline const T* arrptr( const std::vector< T >& v, bool check_zero_size = false ) 00253 { 00254 if( check_zero_size && !v.size() ) return 0; 00255 assert( !v.empty() ); 00256 return &v[0]; 00257 } 00258 00259 } // namespace MBMesquite 00260 00261 #endif
