Classes |
| struct | Eigen::internal::add_const_on_value_type_if_arithmetic< T > |
| class | Eigen::DenseCoeffsBase< Derived, ReadOnlyAccessors > |
| | Base class providing read-only coefficient access to matrices and arrays. More...
| class | Eigen::DenseCoeffsBase< Derived, WriteAccessors > |
| | Base class providing read/write coefficient access to matrices and arrays. More...
| class | Eigen::DenseCoeffsBase< Derived, DirectAccessors > |
| | Base class providing direct read-only coefficient access to matrices and arrays. More...
| class | Eigen::DenseCoeffsBase< Derived, DirectWriteAccessors > |
| | Base class providing direct read/write coefficient access to matrices and arrays. More...
| struct | Eigen::internal::first_aligned_impl< Alignment, Derived, JustReturnZero > |
| struct | Eigen::internal::first_aligned_impl< Alignment, Derived, false > |
| struct | Eigen::internal::inner_stride_at_compile_time< Derived, HasDirectAccess > |
| struct | Eigen::internal::inner_stride_at_compile_time< Derived, false > |
| struct | Eigen::internal::outer_stride_at_compile_time< Derived, HasDirectAccess > |
| struct | Eigen::internal::outer_stride_at_compile_time< Derived, false > |
Namespaces |
| namespace | Eigen |
| namespace | Eigen::internal |
Functions |
| template<int Alignment, typename Derived > |
| static Index | Eigen::internal::first_aligned (const DenseBase< Derived > &m) |
| template<typename Derived > |
| static Index | Eigen::internal::first_default_aligned (const DenseBase< Derived > &m) |
