MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Lawrence Livermore National Laboratory. Under 00005 the terms of Contract B545069 with the University of Wisconsin -- 00006 Madison, Lawrence Livermore National Laboratory retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 /** \file HexLagrangeShape.cpp 00027 * \author Nicholas Voshell 00028 */ 00029 00030 #include "HexLagrangeShape.hpp" 00031 #include "MsqError.hpp" 00032 00033 namespace MBMesquite 00034 { 00035 00036 EntityTopology HexLagrangeShape::element_topology() const 00037 { 00038 return HEXAHEDRON; 00039 } 00040 00041 int HexLagrangeShape::num_nodes() const 00042 { 00043 return 27; 00044 } 00045 00046 void HexLagrangeShape::coefficients( Sample loc, 00047 NodeSet nodeset, 00048 double* coeff_out, 00049 size_t* indices_out, 00050 size_t& num_coeff, 00051 MsqError& err ) const 00052 { 00053 if( nodeset.num_nodes() != 27 ) 00054 { 00055 MSQ_SETERR( err ) 00056 ( "Mapping function supports only 27-node hexahedra with no slaved nodes.", MsqError::UNSUPPORTED_ELEMENT ); 00057 return; 00058 } 00059 00060 switch( loc.dimension ) 00061 { 00062 case 0: // Corner sample point - assume that it is there always 00063 num_coeff = 1; 00064 indices_out[0] = loc.number; 00065 coeff_out[0] = 1.0; 00066 break; 00067 case 1: // Line sample point - check if it is there, 00068 num_coeff = 1; 00069 indices_out[0] = loc.number + 8; 00070 coeff_out[0] = 1.0; 00071 break; 00072 case 2: // Face sample point - check if it is there, 00073 num_coeff = 1; 00074 indices_out[0] = loc.number + 20; 00075 coeff_out[0] = 1.0; 00076 break; 00077 case 3: // Center sample point - check if it is there, 00078 num_coeff = 1; 00079 indices_out[0] = 26; 00080 coeff_out[0] = 1.0; 00081 break; 00082 default: 00083 MSQ_SETERR( err ) 00084 ( MsqError::UNSUPPORTED_ELEMENT, 00085 "Request for dimension %d mapping function value" 00086 "for a quadratic hexahedral element", 00087 loc.dimension ); 00088 } 00089 } 00090 00091 void HexLagrangeShape::derivatives( Sample loc, 00092 NodeSet nodeset, 00093 size_t* vertices, 00094 MsqVector< 3 >* derivs, 00095 size_t& num_vtx, 00096 MsqError& err ) const 00097 { 00098 if( nodeset.num_nodes() != 27 ) 00099 { 00100 MSQ_SETERR( err ) 00101 ( "Mapping function supports only 27-node hexahedra with no slaved nodes.", MsqError::UNSUPPORTED_ELEMENT ); 00102 return; 00103 } 00104 00105 // r coordinate 00106 const int HLS1[] = { 1, 3, 3, 1, 1, 3, 3, 1, 2, 3, 2, 1, 1, 3, 3, 1, 2, 3, 2, 1, 2, 3, 2, 1, 2, 2, 2 }; 00107 // s coordinate 00108 const int HLS2[] = { 1, 1, 3, 3, 1, 1, 3, 3, 1, 2, 3, 2, 1, 1, 3, 3, 1, 2, 3, 2, 1, 2, 3, 2, 2, 2, 2 }; 00109 // t coordinate 00110 const int HLS3[] = { 1, 1, 1, 1, 3, 3, 3, 3, 1, 1, 1, 1, 2, 2, 2, 2, 3, 3, 3, 3, 2, 2, 2, 2, 1, 3, 2 }; 00111 00112 const int HLSup1[] = { 12, 13, 14, 15, -1, -1, -1, -1, 20, 21, 22, 23, 4, 5, 00113 6, 7, -1, -1, -1, -1, 16, 17, 18, 19, 26, -1, 25 }; 00114 const int HLSup2[] = { 4, 5, 6, 7, -1, -1, -1, -1, 16, 17, 18, 19, -1, -1, 00115 -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 25, -1, -1 }; 00116 const int HLSdn1[] = { -1, -1, -1, -1, 12, 13, 14, 15, -1, -1, -1, -1, 0, 1, 00117 2, 3, 20, 21, 22, 23, 8, 9, 10, 11, -1, 26, 24 }; 00118 const int HLSdn2[] = { -1, -1, -1, -1, 0, 1, 2, 3, -1, -1, -1, -1, -1, -1, 00119 -1, -1, 8, 9, 10, 11, -1, -1, -1, -1, -1, 24, -1 }; 00120 00121 const int HLSlt1[] = { -1, 8, 10, -1, -1, 16, 18, -1, 0, 24, 3, -1, -1, 20, 00122 22, -1, 4, 25, 7, -1, 12, 26, 15, -1, 11, 19, 23 }; 00123 const int HLSlt2[] = { -1, 0, 3, -1, -1, 4, 7, -1, -1, 11, -1, -1, -1, 12, 00124 15, -1, -1, 19, -1, -1, -1, 23, -1, -1, -1, -1, -1 }; 00125 const int HLSrt1[] = { 8, -1, -1, 10, 16, -1, -1, 18, 1, -1, 2, 24, 20, -1, 00126 -1, 22, 5, -1, 6, 25, 13, -1, 14, 26, 9, 17, 21 }; 00127 const int HLSrt2[] = { 1, -1, -1, 2, 5, -1, -1, 6, -1, -1, -1, 9, 13, -1, 00128 -1, 14, -1, -1, -1, 17, -1, -1, -1, 21, -1, -1, -1 }; 00129 00130 const int HLSft1[] = { -1, -1, 9, 11, -1, -1, 17, 19, -1, 1, 24, 0, -1, -1, 00131 21, 23, -1, 5, 25, 4, -1, 13, 26, 12, 8, 16, 20 }; 00132 const int HLSft2[] = { -1, -1, 1, 0, -1, -1, 5, 4, -1, -1, 8, -1, -1, -1, 00133 13, 12, -1, -1, 16, -1, -1, -1, 20, -1, -1, -1, -1 }; 00134 const int HLSbk1[] = { 11, 9, -1, -1, 19, 17, -1, -1, 24, 2, -1, 3, 23, 21, 00135 -1, -1, 25, 6, -1, 7, 26, 14, -1, 15, 10, 18, 22 }; 00136 const int HLSbk2[] = { 3, 2, -1, -1, 7, 6, -1, -1, 10, -1, -1, -1, 15, 14, 00137 -1, -1, 18, -1, -1, -1, 22, -1, -1, -1, -1, -1, -1 }; 00138 00139 double entries[] = { 0, -3, 0, 3 }; 00140 00141 int location = loc.number; 00142 00143 switch( loc.dimension ) 00144 { 00145 case 1: 00146 location += 8; 00147 break; 00148 case 2: 00149 location += 20; 00150 break; 00151 case 3: 00152 location += 26; 00153 break; 00154 } 00155 00156 num_vtx = 0; 00157 00158 if( location != 26 ) 00159 { 00160 vertices[num_vtx] = location; 00161 derivs[num_vtx][0] = entries[HLS1[location]]; 00162 derivs[num_vtx][1] = entries[HLS2[location]]; 00163 derivs[num_vtx][2] = entries[HLS3[location]]; 00164 num_vtx++; 00165 } 00166 00167 if( HLSup1[location] != -1 ) 00168 { 00169 vertices[num_vtx] = HLSup1[location]; 00170 if( HLS3[location] == 2 ) 00171 { 00172 derivs[num_vtx][0] = 0; 00173 derivs[num_vtx][1] = 0; 00174 derivs[num_vtx][2] = 1; 00175 } 00176 else 00177 { 00178 derivs[num_vtx][0] = 0; 00179 derivs[num_vtx][1] = 0; 00180 derivs[num_vtx][2] = 4; 00181 } 00182 num_vtx++; 00183 } 00184 00185 if( HLSdn1[location] != -1 ) 00186 { 00187 vertices[num_vtx] = HLSdn1[location]; 00188 if( HLS3[location] == 2 ) 00189 { 00190 derivs[num_vtx][0] = 0; 00191 derivs[num_vtx][1] = 0; 00192 derivs[num_vtx][2] = -1; 00193 } 00194 else 00195 { 00196 derivs[num_vtx][0] = 0; 00197 derivs[num_vtx][1] = 0; 00198 derivs[num_vtx][2] = -4; 00199 } 00200 num_vtx++; 00201 } 00202 00203 if( HLSup2[location] != -1 ) 00204 { 00205 vertices[num_vtx] = HLSup2[location]; 00206 derivs[num_vtx][0] = 0; 00207 derivs[num_vtx][1] = 0; 00208 derivs[num_vtx][2] = -1; 00209 num_vtx++; 00210 } 00211 00212 if( HLSdn2[location] != -1 ) 00213 { 00214 vertices[num_vtx] = HLSdn2[location]; 00215 derivs[num_vtx][0] = 0; 00216 derivs[num_vtx][1] = 0; 00217 derivs[num_vtx][2] = 1; 00218 num_vtx++; 00219 } 00220 00221 if( HLSlt1[location] != -1 ) 00222 { 00223 vertices[num_vtx] = HLSlt1[location]; 00224 if( HLS1[location] == 2 ) 00225 { 00226 derivs[num_vtx][0] = -1; 00227 derivs[num_vtx][1] = 0; 00228 derivs[num_vtx][2] = 0; 00229 } 00230 else 00231 { 00232 derivs[num_vtx][0] = -4; 00233 derivs[num_vtx][1] = 0; 00234 derivs[num_vtx][2] = 0; 00235 } 00236 num_vtx++; 00237 } 00238 00239 if( HLSrt1[location] != -1 ) 00240 { 00241 vertices[num_vtx] = HLSrt1[location]; 00242 if( HLS1[location] == 2 ) 00243 { 00244 derivs[num_vtx][0] = 1; 00245 derivs[num_vtx][1] = 0; 00246 derivs[num_vtx][2] = 0; 00247 } 00248 else 00249 { 00250 derivs[num_vtx][0] = 4; 00251 derivs[num_vtx][1] = 0; 00252 derivs[num_vtx][2] = 0; 00253 } 00254 num_vtx++; 00255 } 00256 00257 if( HLSlt2[location] != -1 ) 00258 { 00259 vertices[num_vtx] = HLSlt2[location]; 00260 derivs[num_vtx][0] = 1; 00261 derivs[num_vtx][1] = 0; 00262 derivs[num_vtx][2] = 0; 00263 num_vtx++; 00264 } 00265 00266 if( HLSrt2[location] != -1 ) 00267 { 00268 vertices[num_vtx] = HLSrt2[location]; 00269 derivs[num_vtx][0] = -1; 00270 derivs[num_vtx][1] = 0; 00271 derivs[num_vtx][2] = 0; 00272 num_vtx++; 00273 } 00274 00275 if( HLSft1[location] != -1 ) 00276 { 00277 vertices[num_vtx] = HLSft1[location]; 00278 if( HLS2[location] == 2 ) 00279 { 00280 derivs[num_vtx][0] = 0; 00281 derivs[num_vtx][1] = -1; 00282 derivs[num_vtx][2] = 0; 00283 } 00284 else 00285 { 00286 derivs[num_vtx][0] = 0; 00287 derivs[num_vtx][1] = -4; 00288 derivs[num_vtx][2] = 0; 00289 } 00290 num_vtx++; 00291 } 00292 00293 if( HLSbk1[location] != -1 ) 00294 { 00295 vertices[num_vtx] = HLSbk1[location]; 00296 if( HLS2[location] == 2 ) 00297 { 00298 derivs[num_vtx][0] = 0; 00299 derivs[num_vtx][1] = 1; 00300 derivs[num_vtx][2] = 0; 00301 } 00302 else 00303 { 00304 derivs[num_vtx][0] = 0; 00305 derivs[num_vtx][1] = 4; 00306 derivs[num_vtx][2] = 0; 00307 } 00308 num_vtx++; 00309 } 00310 00311 if( HLSft2[location] != -1 ) 00312 { 00313 vertices[num_vtx] = HLSft2[location]; 00314 derivs[num_vtx][0] = 0; 00315 derivs[num_vtx][1] = 1; 00316 derivs[num_vtx][2] = 0; 00317 num_vtx++; 00318 } 00319 00320 if( HLSbk2[location] != -1 ) 00321 { 00322 vertices[num_vtx] = HLSbk2[location]; 00323 derivs[num_vtx][0] = 0; 00324 derivs[num_vtx][1] = -1; 00325 derivs[num_vtx][2] = 0; 00326 num_vtx++; 00327 } 00328 } 00329 00330 void HexLagrangeShape::ideal( Sample, MsqMatrix< 3, 3 >& J, MsqError& ) const 00331 { 00332 J = MsqMatrix< 3, 3 >( 1.0 ); 00333 } 00334 00335 } // namespace MBMesquite
